H3C WX3000E Series Wireless Switches Switching Engine Web-Based Configuration Guide(R3507P26)-6W102
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployUser ManualsH3C WX3000E Series Wireless Switches Switching Engine Web-Based Configuration Guide(R3507P26)-6W102
03-Web Overview
03-Web Overview 314.67 KB
Web overview
Overview
The device provides web-based configuration interfaces for visual device management and maintenance.
Figure 1 Web-based network management operating environment
Logging in to the web interface
You can log in to the web interface through the browser or through the switching engine on a WX3000E series wireless switch.
Logging in through the browser
You can use the following default settings to log in to the web interface:
Item
Access controller engine
Switching engine
Username
admin
admin
Password
admin
admin
Default IP address
192.168.0.100/24
192.168.0.101/24
To log in to the web interface of the device from a PC:
1.     Connect the GigabitEthernet interface of the switching engine to the PC by using a crossover Ethernet cable.
By default, all ports belong to VLAN 1.
2.     Configure an IP address for the PC and make sure that the PC and the device can reach each other.
For example, assign the PC an IP address (for example, 192.168.0.7) within 192.168.0.0/24.
3.     Open the browser and input the login information:
a.     Type the IP address http:// 192.168.0.101 in the address bar and press Enter.
The login page of the web interface (see Figure 2) appears.
b.     Enter the username admin, password admin, and the verification code, select the language (English and Chinese are supported at present), and click Login.
Figure 2 Login page of the web interface
·     The PC where you configure the device is not necessarily a web-based network management terminal. A web-based network management terminal is a PC used to log in to the web interface and is required to be reachable to the device.
·     After logging in to the web interface, you can select Device > Users from the navigation tree, create a new user, and select Wizard or Network > VLAN interface to configure the IP address of the VLAN interface acting as the management interface. For more information, see the corresponding configuration guides of these modules.
·     If you click the verification code displayed on the web login page, you can get a new verification code.
·     Up to 5 users can concurrently log in to the device through the web interface.
·     The procedures for logging in to the access controller engine are the same except that the default IP address of the access controller engine is 192.168.0.100.
Logging in through the access controller engine
To log in to the switching engine through the access controller engine:
1.     Log in to the access controller engine by following Logging in through the browser.
2.     Configure the oap management-ip ip-address slot 0 command in system view.
ip-address represents the default IP address of the switching engine.
3.     Click Switch Engine.
4.     On the page that appears, enter the login settings (see Figure 3).
Figure 3 Switch from the access controller engine to the switching engine
Logging out of the web interface
Click Logout in the upper-right corner of the web interface, as shown in Figure 4 to quit the web interface.
The system does not automatically save the current configuration, so save the current configuration before logout.
Introduction to the web interface
The web interface is composed of three parts: navigation tree, title area, and body area.
Figure 4 Web-based configuration interface
(1) Navigation tree
(2) Body area
(3) Title area
·     Navigation tree—Organizes the web-based NM functions as a navigation tree, where you can select and configure functions as needed. The result is displayed in the body area.
·     Body area—Allows you to configure and display features.
·     Title area—On the left, displays the path of the current configuration interface in the navigation area; on the right, provides the Save button to quickly save the current configuration, the Help button to display the web related help information, and the Logout button to log out of the web interface
Web user level
Web user levels, from low to high, are visitor, monitor, configure, and management. A user with a higher level has all the operating rights of a user with a lower level.
·     Visitor—Users of this level can use the network diagnostic tools ping and Trace Route, but they can neither access the device data nor configure the device.
·     Monitor—Users of this level can only access the device data but cannot configure the device.
·     Configure—Users of this level can access device data and configure the device, but they cannot upgrade the host software, add/delete/modify users, or back up/restore configuration files.
·     Management—Users of this level can perform any operations to the device.
Introduction to the web-based NM functions
User level in Table 1 indicates that users of this level or users of a higher level can perform the corresponding operations.
Table 1 Description of web-based NM functions
Function menu
User level
Wizard
IP Setup
Perform quick configuration of the device.
Management
Summary
System Information
Display the system information, system resource status, and the recent system operation logs.
Monitor
Device Information
Display the port, power supply, and fan information of the device.
Monitor
Device Management
Display the card information of the device, and log in to some cards to configure them.
Monitor
Device
Basic
System Name
Display and configure the system name.
Configure
Web Idle Timeout
Display and configure the idle timeout period for logged-in users.
Configure
Reboot
Reboot the device.
Management
Electronic Label
Display the electronic label of the device.
Monitor
Diagnostic Information
Generate diagnostic information file, and view or save the file to local host.
Management
System Time
System Time
Display the system date and time.
Monitor
Configure the system date and time
Configure
Net Time
Display the synchronization status of system clock and network time configuration information.
Monitor
Configure the network time.
Configure
Syslog
Loglist
Display and refresh system logs.
Monitor
Clear system logs.
Configure
Loghost
Display and configure the loghost.
Configure
Log Setup
Display and configure the buffer capacity, and interval for refreshing system logs.
Configure
Configuration
Backup
Back up the configuration file to be used at the next startup from the device to the host of the current user.
Management
Restore
Upload the configuration file to be used at the next startup from the host of the current user to the device.
Management
Save
Save the current configuration to the configuration file to be used at the next startup.
Configure
Initialize
Restore the factory default settings.
Configure
File Manage
File Manage
Manage files on the device, such as displaying the file list, downloading a file, uploading a file, removing a file, and setting the main boot file.
Management
Port Management
Summary
Display port information by features.
Monitor
Detail
Display feature information by ports.
Monitor
Setup
Create, modify, delete, or enable/disable a port, and clear port statistics.
Configure
Port Mirroring
Summary
Display the configuration information of a port mirroring group.
Monitor
Create
Create a port mirroring group.
Configure
Remove
Remove a port mirroring group.
Configure
Modify Port
Configure ports for a mirroring group.
Configure
Users
Summary
Display the brief information of FTP and Telnet users.
Monitor
Super Password
Configure a password for a lower-level user to switch from the current access level to the management level.
Management
Create
Create an FTP or Telnet user.
Management
Modify
Modify FTP or Telnet user information.
Management
Remove
Remove an FTP or a Telnet user.
Management
Switch To Management
Switch the current user level to the management level.
Visitor
Loopback
Loopback
Perform loopback tests on Ethernet interfaces.
Configure
VCT
VCT
Check the status of the cables connected to Ethernet ports.
Configure
Flow Interval
Port Traffic Statistics
Display the number of packets and bytes received and sent by the interface, and the bandwidth usage within a specified time interval.
Monitor
Interval Configuration
Set an interval for collecting traffic statistics on interfaces.
Configure
Storm Constrain
Storm Constrain
Display and set the interval for collecting storm constrain statistics.
Display, create, modify, and remove the port traffic threshold.
Configure
RMON
Statistics
Display, create, modify, and clear RMON statistics.
Configure
History
Display, and create, modify, and clear RMON history sampling information.
Configure
Alarm
View, create, modify, and clear alarm entries.
Configure
Event
View, create, modify, and clear event entries.
Configure
Log
Display log information about RMON events.
Configure
Energy Saving
Energy Saving
Display and configure the energy saving settings of an interface.
Configure
SNMP
Setup
Display and refresh SNMP configuration and statistics information.
Monitor
Configure SNMP.
Configure
Community
Display SNMP community information.
Monitor
Create, modify, and delete an SNMP community.
Configure
Group
Display SNMP group information.
Monitor
Create, modify, and delete an SNMP group.
Configure
User
Display SNMP user information.
Monitor
Create, modify, and delete an SNMP user.
Configure
Trap
Display the status of the SNMP trap function and information about target hosts.
Monitor
Enable or disable the SNMP trap function, or create, modify and delete a target host.
Configure
View
Display SNMP view information.
Monitor
Create, modify, and delete an SNMP view.
Configure
Interface Statistics
Display and clear the statistics information of an interface.
Configure
Network
VLAN
Select VLAN
Select a VLAN range.
Monitor
Create
Create VLANs.
Configure
Port Detail
Display the VLAN-related details of a port.
Monitor
Detail
Display the member port information of a VLAN.
Monitor
Modify VLAN
Modify the description and member ports of a VLAN.
Configure
Modify Port
Change the VLAN to which a port belongs, the connection type and PVID of the port.
Configure
Remove
Remove VLANs.
Configure
VLAN Interface
Summary
Display information about VLAN interfaces by address type.
Monitor
Create
Create VLAN interfaces and configure IP addresses for them.
Configure
Modify
Modify the IP addresses and status of VLAN interfaces.
Configure
Remove
Remove VLAN interfaces.
Configure
Voice VLAN
Summary
Display voice VLAN information globally or on a port.
Monitor
Setup
Configure the global voice VLAN.
Configure
Port Setup
Configure a voice VLAN on a port.
Configure
OUI Summary
Display the addresses of the OUIs that can be identified by voice VLAN.
Monitor
OUI Add
Add the address of an OUI that can be identified by voice VLAN.
Configure
OUI Remove
Remove the address of an OUI that can be identified by voice VLAN.
Configure
MAC
MAC
Display MAC address information.
Monitor
Create and remove MAC addresses.
Configure
Setup
Display and configure MAC address aging time.
Configure
MSTP
Region
Display information about MST regions.
Monitor
Modify MST regions.
Configure
Global
Set global MSTP parameters.
Configure
Port Summary
Display the MSTP information of ports.
Monitor
Port Setup
Set MSTP parameters on ports.
Configure
Link Aggregation
Summary
Display information about aggregated interface, and information about member ports.
Monitor
Create
Create link aggregation groups.
Configure
Modify
Modify link aggregation groups.
Configure
Remove
Remove link aggregation groups.
Configure
LACP
Summary
Display information about LACP-enabled ports and their partner ports.
Monitor
Setup
Set LACP priorities.
Configure
LLDP
Port Setup
Display the LLDP configuration information, local information, neighbor information, statistics information, and status information of a port.
Monitor
Modify LLDP configuration on a port.
Configure
Global Setup
Display global LLDP configuration information.
Monitor
Configure global LLDP parameters.
Configure
Global Summary
Display global LLDP local information and statistics.
Monitor
Neighbor Summary
Display global LLDP neighbor information.
Monitor
ARP Management
ARP Table
Display ARP table information.
Monitor
Add, modify, or delete an ARP entry.
Configure
Gratuitous ARP
Display configuration information of gratuitous ARP.
Monitor
Configure gratuitous ARP.
Configure
ARP Anti-Attack
ARP Detection
Display the configuration information of ARP detection.
Monitor
Configure ARP detection.
Configure
IGMP Snooping
Basic
Display global IGMP snooping configuration information or the IGMP snooping configuration information in a VLAN, and view the IGMP snooping multicast entry information.
Monitor
Configure IGMP snooping globally or in a VLAN.
Configure
Advanced
Display the IGMP snooping configuration information on a port.
Monitor
Configure IGMP snooping on a port.
Configure
IPv4 Routing
Summary
Display the IPv4 active route table.
Monitor
Create
Create an IPv4 static route.
Configure
Remove
Delete the selected IPv4 static routes.
Configure
IPv6 Routing
Summary
Display the IPv6 active route table.
Monitor
Create
Create an IPv6 static route.
Configure
Remove
Delete the selected IPv6 static routes.
Configure
DHCP
DHCP Server
Display the DHCP service status, the DHCP address pool information, the DHCP server status on an interface, and the information of an address assigned from a DHCP address pool.
Monitor
Set the DHCP service status, add, modify, or delete a DHCP address pool, and modify the DHCP server status on an interface.
Configure
DHCP Relay
Display information about the DHCP status, advanced configuration information of the DHCP relay agent, DHCP server group configuration, DHCP relay agent interface configuration, and the DHCP client information.
Monitor
Enable or disable DHCP, configure advanced DHCP relay agent settings, configure a DHCP server group, and enable or disable the DHCP relay agent on an interface.
Configure
DHCP Snooping
Display the status, trusted and untrusted ports and DHCP client information of DHCP snooping.
Monitor
Enable or disable DHCP snooping, and configure DHCP snooping trusted and untrusted ports.
Configure
Service
Service
Display the states of services: enabled or disabled.
Configure
Enable or disable services, and set related parameters.
Management
Diagnostic Tools
Ping
Ping an IP address and display the operation result.
Visitor
Trace Route
Perform trace route operation and display the operation result.
Visitor
Authentication
MAC Authentication
MAC Authentication
Display MAC authentication configuration information.
Monitor
Configure MAC authentication.
Configure
802.1X
802.1X
Display 802.1X configuration information globally or on a port.
Monitor
Configure 802.1X globally or on a port.
Configure
Port Security
Port Security
Display port security configuration information.
Monitor
Configure port security.
Configure
Portal
Portal Server
Display configuration information about the portal server and advanced parameters for portal authentication.
Monitor
Add and delete a portal server, and modify advanced parameters for portal authentication.
Configure
Free Rule
Display the portal-free rule configuration information.
Monitor
Add and delete a portal-free rule.
Configure
AAA
Domain Setup
Display ISP domain configuration information.
Monitor
Add and remove ISP domains.
Management
Authentication
Display the authentication configuration information of an ISP domain.
Monitor
Specify authentication methods for an ISP domain.
Management
Authorization
Display the authorization method configuration information of an ISP domain.
Monitor
Specify authorization methods for an ISP domain.
Management
Accounting
Display the accounting method configuration information of an ISP domain.
Monitor
Specify accounting methods for an ISP domain.
Management
RADIUS
Display, add, modify, and delete a RADIUS scheme.
Management
Users
Local User
Display configuration information about local users.
Monitor
Create, modify, and remove a local user.
Management
User Group
Display configuration information about user groups.
Monitor
Create, modify, and remove a user group.
Management
PKI
Entity
Display information about PKI entities.
Monitor
Add, modify, and delete a PKI entity.
Configure
Domain
Display information about PKI domains.
Monitor
Add, modify, and delete a PKI domain.
Configure
Certificate
Display the certificate information of PKI domains and view the contents of a certificate.
Monitor
Generate a key pair, destroy a key pair, retrieve a certificate, request a certificate, and delete a certificate.
Configure
CRL
Display the contents of the CRL.
Monitor
Receive the CRL of a domain.
Configure
Port Isolate Group (for multiple isolation groups)
Summary
Display port isolation group information.
Monitor
Group Setup
Add and delete an isolation group.
Configure
Port Setup
Configure the ports in an isolation group.
Configure
Authorized IP
Summary
Display the configurations of authorized IP, the associated IPv4 ACL list, and the associated IPv6 ACL list.
Management
Setup
Configure authorized IP.
Management
QoS
Time Range
Summary
Display time range configuration information.
Monitor
Add
Add a time range.
Configure
Remove
Delete a time range.
Configure
ACL IPv4
Summary
Display IPv4 ACL configuration information.
Monitor
Add
Add an IPv4 ACL.
Configure
Basic Setup
Configure a rule for a basic IPv4 ACL.
Configure
Advanced Setup
Configure a rule for an advanced IPv4 ACL.
Configure
Link Layer Setup
Create a rule for a link layer ACL.
Configure
Remove
Delete an IPv4 ACL or its rules.
Configure
ACL IPv6
Summary
Display IPv6 ACL configuration information.
Monitor
Add
Add an IPv6 ACL.
Configure
Basic Setup
Configure a rule for a basic IPv6 ACL.
Configure
Advanced Setup
Configure a rule for an advanced IPv6 ACL.
Configure
Remove
Delete an IPv6 ACL or its rules.
Configure
Queue
Summary
Display the queue information of a port.
Monitor
Setup
Configure a queue on a port.
Configure
Line Rate
Summary
Display line rate configuration information.
Monitor
Setup
Configure the line rate.
Configure
Classifier
Summary
Display classifier configuration information.
Monitor
Add
Add a class.
Configure
Setup
Configure the classification rules for a class.
Configure
Remove
Delete a class or its classification rules.
Configure
Behavior
Summary
Display traffic behavior configuration information.
Monitor
Add
Add a traffic behavior.
Configure
Setup
Configure actions for a traffic behavior.
Configure
Port Setup
Configure traffic mirroring and traffic redirecting for a traffic behavior.
Configure
Remove
Delete a traffic behavior.
Configure
QoS Policy
Summary
Display QoS policy configuration information.
Monitor
Add
Add a QoS policy.
Configure
Setup
Configure the classifier-behavior associations for a QoS policy.
Configure
Remove
Delete a QoS policy or its classifier-behavior associations.
Configure
Port Policy
Summary
Display the QoS policy applied to a port.
Monitor
Setup
Apply a QoS policy to a port.
Configure
Remove
Remove the QoS policy from the port.
Configure
Priority Mapping
Priority Mapping
Display priority mapping table information.
Monitor
Modify the priority mapping entries.
Configure
Port Priority
Port Priority
Display port priority and trust mode information.
Monitor
Modify port priority and trust mode.
Configure
PoE
PoE
Summary
Display PSE information and PoE interface information.
Monitor
Setup
Configure a PoE interface.
Configure
Introduction to the common items on the web pages
Buttons and icons
Table 2 Commonly used buttons and icons
Button and icon
Function
Apply the configuration on the current page.
Cancel the configuration on the current page, and return to the corresponding list page or the Device Info page.
Refresh the information on the current page.
Clear all the information on a list or all statistics.
Enter a page for adding an item.
Remove the selected items.
Select all the entries on a list, or all the ports on the device panel.
Clear all the entries on a list, or all the ports on the device panel.
Generally present on the configuration wizard; used to buffer but not apply the configuration of the current step and enter the next configuration step.
Generally present on the configuration wizard; used to buffer but not apply the configuration of the current step and return to the previous configuration step.
Generally present on the configuration wizard; used to apply the configurations of all configuration steps.
icon_mdf
Generally present on the “Operation” column on a list; used to enter the modification page of an item so that you can modify the configurations of the item.
icon_del
Generally present on the “Operation” column on a list; used to delete the item corresponding to this icon.
Page display
The web interface can display a long list by pages, as shown in Figure 5. You can set the number of entries displayed per page, and use the First, Prev, Next, and Last links to view the contents on the first, previous, next, and last pages, or go to any page that you want to view.
Figure 5 Content display by pages
Search function
On some list pages, the web interface provides basic search function. You can use the search function to display those entries matching certain search criteria.
Basic search function: Enter the keyword in the field above the list, select a search item from the list and click Search to display the entries that match the criteria. Figure 6 shows an example of searching for entries with VLAN ID 2.
Figure 6 Basic search function example
Sorting function
On some list pages, the web interface provides basic sorting function to display the entries in certain orders.
On a list page, you can click the blue heading item of each column to sort the entries based on the heading item you selected. Then the heading item is displayed with an arrow beside it as shown in Figure 7. The upward arrow indicates the ascending order, and the downward arrow indicates the descending order.
Figure 7 Basic sorting function (based on IP address in the descending order)
Configuration guidelines
·     The web interface supports Windows XP, Windows 2000, Windows Server 2003 Enterprise Edition, Windows Server 2003 Standard Edition, Windows Vista, Linux and MAC OS operating systems.
·     The web console supports Microsoft Internet Explorer 6.0 SP2 and higher, Mozilla Firefox 3.0 and higher, Google Chrome 2.0.174.0 and higher.
·     The web console does not support the Back, Next, Refresh buttons. Using these buttons may result in abnormal display of web pages.
·     The Windows firewall limits the number of TCP connections, so when you use IE to log in to the web interface, sometimes you may be unable to open the web interface. To avoid this problem, turn off the Windows firewall before login.
·     If the software version of the device changes, when you log in to the device through the web interface, delete the cached data of IE; otherwise, the web page content may not be displayed correctly.
·     A list can contain a maximum of 20000 entries if displayed in pages.
Troubleshooting web console
Failure to access devices through the web console
Symptom
You can ping and Telnet to a device, on which the HTTP service is running and the versions of the used operating system and IE browser comply with the requirements of the web console. However, you are unable to access the web console of the device.
Analysis
To access the web console:
·     When using the Microsoft Internet Explorer browser, you must enable the security settings, including Run ActiveX controls and plug-ins, Script ActiveX controls marked safe for scripting, and Active scripting.
·     When using the Mozilla Firefox browser, you must enable JavaScript.
For IE Browser
1.     Launch the Internet Explorer, and select Tools > Internet Options from the main menu.
2.     Click the Security tab, and select the content zone where the target website resides.
Figure 8 Internet Explorer settings (I)
3.     Click Custom Level.
The Security Settings dialog box appears.
4.     Enable Run ActiveX controls and plug-ins, Script ActiveX controls marked safe for scripting, and Active scripting.
Figure 9 Internet Explorer settings (II)
5.     Click OK to save your settings.
For Firefox Browser
1.     Launch the Firefox browser, and select Tools > Options.
The Options dialog box appears.
2.     Click Content, and select the Enable JavaScript box.
Figure 10 Firefox browser settings
3.     Click OK to save your settings.
