H3C WX3000E Series Wireless Switches Switching Engine Web-Based Configuration Guide(R3507P26)-6W102
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployUser ManualsH3C WX3000E Series Wireless Switches Switching Engine Web-Based Configuration Guide(R3507P26)-6W102
04-Summary
04-Summary 106.52 KB
Summary
Overview
The device summary module allows you to:
·     Display the system information, including the basic system information, system resources state, and recent system operation logs.
·     Display the device information, including port, power supply, and fan information.
Displaying device summary
Displaying system information
1.     Select System Information from the navigation tree.
The system information page appears.
2.     View the system basic information, system resource state, and recent system logs.
Figure 1 System information
Basic system information
Table 1 Field description
Device Name
Display the device model.
Product Information
Display the product information.
Device Location
Display the location of the device.
To configure the device location information, select Device > SNMP. For more information, see the chapter “SNMP configuration.”
Contact Information
Display the contact information for device maintenance.
To configure the contact information, select Device > SNMP. For more information, see the chapter “SNMP configuration.”
SerialNum
Display the serial number of the device.
Software Version
Display the software version of the device.
Hardware Version
Display the hardware version of the device.
Bootrom Version
Display the Boot ROM version of the device.
Running Time
Display the running time after the latest boot of the device.
System resource state
Table 2 Field description
CPU Usage
Display the real-time CPU usage.
Memory Usage
Display the real-time memory usage.
Temperature
Display the temperature of the device.
Recent system logs
Table 3 Field description
Time
Displays the time when the system logs are generated.
Level
Displays the severity of the system logs.
Displays the description of the system logs.
·     The Summary page displays up to five the most recent system logs about the login and logout events.
·     For more system logs, you can click More to enter the Log List page. You can also enter this page by selecting Device > Syslog. For more information, see the chapter “Log management.”
Specifying system information refresh period
Select from the Refresh Period list:
·     If you select a certain period, the system refreshes the system information at the specified interval.
·     If you select Manual, the system refreshes the information only when you click the Refresh button.
Displaying device information
2.     Click the Device Information tab.
The page for displaying system information appears.
Figure 2 Device information
3.     View the device ports.
Hover the cursor over a port and the port details appears, including the port name, type, speed, utilization, status, and aggregation group number. For the description about the port number and its color, see Figure 2.
Similarly, you can also view the power type and working status and the fan working status.
·     If you select a certain period, the system refreshes the information at the specified interval.
