02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10202-WLAN Command Reference
11-WLAN IPS Commands
11-WLAN IPS Commands 512.88 KB
WIPS commands· 1
action· 1
ados enable· 1
ap-classification-rule (virtual security domain view) 2
ap-classification-rule (WIPS view) 3
attack-detect-policy (virtual security domain view) 3
attack-detect-policy (WIPS view) 4
blocklist-action block· 4
classify-type· 5
countermeasure external-ap· 6
countermeasure fixed-channel 6
countermeasure misassociation-client 7
countermeasure misconfigured-ap· 7
countermeasure potential-authorized-ap· 8
countermeasure potential-external-ap· 9
countermeasure potential-rogue-ap· 9
countermeasure rogue-ap· 10
countermeasure static (countermeasures policy view) 10
countermeasure static (WIPS view) 11
countermeasure unauthorized-client 12
countermeasure uncategorized-ap· 12
countermeasure uncategorized-client 13
countermeasure-policy (virtual security domain view) 13
countermeasure-policy (WIPS view) 14
detect access-flow-scan enable· 14
detect adhoc-network· 15
detect admin-mac-scan· 15
detect all 16
detect all action· 16
detect ap-flood· 18
detect ap-impersonation· 18
detect ap-spoofing· 19
detect client-spoofing· 20
detect deauth-spoofing· 20
detect dos-association· 21
detect dos-authentication· 21
detect dos-eapol-start 22
detect dos-reassociation· 23
detect duplicated-ie action· 23
detect fata-jack action· 24
detect honeypot-ap· 24
detect hotspot-attack· 25
detect ht-40mhz-intolerance· 26
detect ht-greenfield· 26
detect illegal-ibss-ess action· 27
detect invalid-channel action· 27
detect invalid-deauth-code action· 28
detect invalid-disassoc-code action· 29
detect invalid-ie-length action· 29
detect invalid-oui 30
detect invalid-pkt-length action· 31
detect invalid-source-address action· 31
detect large-duration action· 32
detect malformed-assoc-req action· 33
detect malformed-auth action· 33
detect malformed-ht-ie action· 34
detect null-probe-resp action· 35
detect overflow-eapol-key action· 35
detect overflow-ssid action· 36
detect prohibited-channel 36
detect ps-attack· 37
detect redundant-ie action· 38
detect scan-channel 39
detect soft-ap· 39
detect unencrypted-authorized-ap· 40
detect unencrypted-trust-client 40
detect weak-iv· 41
detect windows-bridge· 41
detect wireless-bridge· 42
detect wireless-device disable· 43
detect-period· 43
detect-threshold· 44
display wlan ips ap-classification-rule· 45
display wlan ips attack-detect-policy· 47
display wlan ips authssidlist 50
display wlan ips blocklist 51
display wlan ips channel 52
display wlan ips countermeasure-devices· 53
display wlan ips countermeasure-policy· 56
display wlan ips devices· 59
display wlan ips event 65
display wlan ips hotspotlist 72
display wlan ips ignorelist 73
display wlan ips malformed-detect-policy· 74
display wlan ips network· 75
display wlan ips oui 80
display wlan ips sensor 81
display wlan ips signature· 82
display wlan ips signature-policy· 87
display wlan ips static-trustoui 88
display wlan ips statistics· 89
display wlan ips statistics sensor 93
display wlan ips summary· 94
display wlan ips trustlist 98
display wlan ips vsd-policy· 99
export wips-cfg-file oui 100
hotspot 101
ignorelist 101
import wips-cfg-file oui 102
malformed-detect-policy (virtual security domain view) 103
malformed-detect-policy (WIPS view) 103
manual-classify ap (virtual security domain view) 104
manual-classify ap (WIPS view) 105
match all (AP classification rule view) 106
match all (SIG view) 106
permit-channel 107
quiet-time (malformed packet detection policy view) 107
quiet-time (SIG view) 108
reset wlan ips event 109
reset wlan ips statistic sensor 109
sensor 110
severity-level 110
signature· 111
signature (signature policy view) 113
signature-policy (virtual security domain view) 114
signature-policy (WIPS view) 114
static-blocklist 115
static-trustlist 115
static-trustoui 116
sub-rule (AP classification rule view) 117
sub-rule (SIG view) 118
timer ap-inactivity· 121
timer client-inactivity· 121
timer device-aging· 122
timer device-update· 122
timer dynamic-trustlist-aging· 123
timer mesh-link-aging· 123
timer reclassification· 124
timer statistic-period· 124
track-method· 125
undo wips-cfg-file oui 126
virtual-security-domain· 126
wips detect mode· 127
wips enable· 128
wipslogfile· 128
wipslogfile enable· 129
wireless-probe client-aging· 129
wireless-probe enable· 130
wireless-probe ignore ap· 130
wireless-probe location· 131
wireless-probe server 131
wireless-probe timezone· 132
wlan ips· 133
WIPS commands
Support for the commands in this chapter depends on the device model. For more information, see About the H3C Access Controllers Command References.
action
Use action to specify the action that WIPS takes when the number of matching times for a signature reaches the detect threshold.
action { none | report event-level level-value }
The action for a user-defined signature is none, the action for a system-defined signature is report, and the alarm level depends on the signature.
SIG view
Default command level
2: System level
none: Configures WIPS to not take any action when the number of matching times for a signature reaches the detect-threshold within the statistics collection period.
report: Configures WIPS to generate signature alarms when the number of matching times for a signature reaches the detect-threshold within the statistics collection period.
event-level level-value: Sets the alarm level for a signature in the range of 0 to 7. A smaller value represents a higher precedence.
To modify the action for a signature that has been bound to a signature policy, remove the binding first.
If you configure an action multiple times, the most recent configuration overwrites the previous configuration.
You cannot modify the action for a system-defined signature, but you can modify the alarm level for that rule.
# Specify that WIPS generates signature alarms with level 6 when the number of matching times for the signature office reaches the detect-threshold.
[Sysname] wlan ips
[Sysname-wlan-ips] signature office
[Sysname-wlan-ips-sig-office] action report event-level 6
ados enable
Use ados enable to enable the anti-denial-of-service function.
Use undo ados enable to disable the anti-denial-of-service function.
ados enable
undo ados enable
The anti-denial-of-service function is disabled.
WIPS view
2: System level
# Enable the anti-denial-of-service function.
[Sysname] wlan ips
[Sysname-wlan-ips] ados enable
Use ap-classification-rule to add an AP classification rule to the current virtual security domain.
Use undo ap-classification-rule to remove the specified AP classification rule from the current virtual security domain.
ap-classification-rule rule-name [ precedence number ]
undo ap-classification-rule { rule-name }
No AP classification rule exists in a virtual security domain.
Virtual security domain view
2: System level
rule-name: Specifies an AP classification rule by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
precedence number: Specifies the matching precedence for an AP classification rule, in the range of 0 to 15.
If you specify the precedence for a new AP classification rule, the rule uses the specified precedence. If you do not specify a precedence, the rule uses the default precedence 0. AP classification rules are matched in the order of precedence from high to low. Rules with the same precedence are matched according the order they are configured.
# Add an AP classification rule to the virtual security domain office, and specify its precedence as 15.
[Sysname] wlan ips
[Sysname-wlan-ips] virtual-security-domain office
[Sysname-wlan-ips-vsd-office]ap-classification-rule external-ap precedence 15
Use ap-classification-rule to create an AP classification rule and enter AP classification rule view. For an existing AP classification rule, this command enters the corresponding AP classification rule view.
Use undo ap-classification-rule to remove the specified AP classification rule view.
undo ap-classification-rule rule-name
No AP classification rule exists.
WIPS view
2: System level
# Create an AP classification rule named invalid_ap.
[Sysname] wlan ips
[Sysname-wlan-ips] ap-classification-rule invalid_ap
[Sysname-wlan-ips-class-invalid_ap]
Use attack-detect-policy to configure an attack detection policy for the current virtual security domain.
Use undo attack-detect-policy to restore the default attack detection policy.
attack-detect-policy policy-name
A virtual security domain uses the attack detection policy named default.
2: System level
policy-name: Specifies an attack detection policy by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
# Configure the virtual security domain office to use the attack detection policy office.
[Sysname] wlan ips
[Sysname-wlan-ips-vsd-office]attack-detect-policy office
Use attack-detect-policy to create an attack detection policy and enter attack detection policy view. For an existing attack detection policy, this command directly enters the corresponding attack detection policy view.
Use undo attack-detect-policy to remove the specified attack detection policy.
undo attack-detect-policy policy-name
An attack detection policy named default exists in the system. You cannot create or delete the default attack detection policy.
WIPS view
2: System level
# Create an attack detection policy named office and enter attack detection policy view.
[Sysname] wlan ips
[Sysname-wlan-ips] attack-detect-policy office
[Sysname-wlan-ips-dctp-office]
Use blocklist-action block to disable wireless devices in the prohibited device list from accessing the WLAN.
Use undo blocklist-action block to enable wireless devices in the prohibited device list to access the WLAN.
Wireless devices in the prohibited device list are allowed to access the WLAN.
WIPS view
2: System level
None
The blocklist-action block command takes effect only in a WIPS-compatible networking environment and does not take effect in an independent WIPS networking environment.
# Disable wireless devices in the prohibited device list from accessing the WLAN.
[Sysname] wlan ips
[Sysname-wlan-ips] blocklist-action block
classify-type
Use classify-type to specify the type of the AP that matches a specified AP classification rule.
Use undo classify-type to remove the specified AP type.
classify-type { authorized-ap | external-ap | misconfigured-ap | rogue-ap }
undo classify-type
No AP type is specified for an AP that matches an AP classification rule.
2: System level
authorized-ap: Specifies an authorized AP.
external-ap: Specifies an external AP.
misconfigured-ap: Specifies a mis-configured AP.
rogue-ap: Specifies a rogue AP.
You do not necessarily need to set the type of the AP that matches an AP classification rule. If you do not set the AP type but specify the severity level, in the AP classification rule, the severity level takes effect.
# Specify the type of the AP that matches the invalid_ap classification rule as rogue-ap.
[Sysname] wlan ips
[Sysname-wlan-ips-class-invalid_ap] classify-type rogue-ap
Use countermeasure external-ap to take countermeasures against external APs.
Use undo countermeasure external-ap to restore the default.
countermeasure external-ap [ precedence number ]
No countermeasures are taken against external APs.
Countermeasures policy view
2: System level
precedence number: Specifies the precedence for taking countermeasures against external APs, in the range of 0 to 9. The default is 1.
# Use countermeasures policy office to take countermeasures against external APs.
[Sysname] wlan ips
[Sysname-wlan-ips] countermeasure-policy office
[Sysname-wlan-ips-cmep-office] countermeasure external-ap
Use countermeasure fixed-channel enable to enable the sensor to take countermeasures against wireless devices on a fixed channel.
Use undo countermeasure fixed-channel enable to restore the default.
No countermeasures are taken against wireless devices on a fixed channel.
2: System level
This function enables a sensor to continually take countermeasures on a fixed channel where the target wireless devices are operating if other countermeasures are not effective.
The sensor stops scanning on other channels when it is taking countermeasures on a fixed channel.
# Use the countermeasures policy office to enable the sensor to take countermeasures on a fixed channel.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure fixed-channel enable
Use countermeasure misassociation-client to take countermeasures against misassociated clients.
Use undo countermeasure misassociation-client to restore the default.
countermeasure misassociation-client [ precedence number ]
No countermeasures are taken against misassociated clients.
2: System level
precedence number: Specifies the precedence for taking countermeasures against misassociated clients, in the range of 0 to 9. The default is 6.
# Use countermeasures policy office to take countermeasures against misassociated clients.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure misassociation-client
Use countermeasure misconfigured-ap to take countermeasures against misconfigured APs.
Use undo countermeasure misconfigured-ap to restore the default.
countermeasure misconfigured-ap [ precedence number ]
No countermeasures are taken against misconfigured APs.
2: System level
precedence number: Specifies the precedence for taking countermeasures against misconfigured APs, in the range of 0 to 9. The default is 3.
# Use countermeasures policy office to take countermeasures against misconfigured APs.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure misconfigured-ap
Use countermeasure potential-authorized-ap to take countermeasures against potential-authorized APs.
Use undo countermeasure potential-authorized-ap to restore the default.
countermeasure potential-authorized-ap [ precedence number ]
No countermeasures are taken against potential-authorized APs.
2: System level
precedence number: Specifies the precedence for taking countermeasures against potential-authorized APs, in the range of 0 to 9. The default is 0.
# Use countermeasures policy office to take countermeasures against potential-authorized APs.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure potential-authorized-ap
Use countermeasure potential-external-ap to take countermeasures against potential-external APs.
Use undo countermeasure potential-external-ap to restore the default.
countermeasure potential-external-ap [ precedence number ]
No countermeasures are taken against potential-external APs.
2: System level
precedence number: Specifies the precedence for taking countermeasures against potential-external APs, in the range of 0 to 9. The default is 2.
# Use countermeasures policy office to take countermeasures against potential-external APs.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure potential-external-ap
Use countermeasure potential-rogue-ap to take countermeasures against potential-rogue APs.
Use undo countermeasure potential-rogue-ap to restore the default.
countermeasure potential-rogue-ap [ precedence number ]
No countermeasures are taken against potential-rogue APs.
2: System level
precedence number: Specifies the precedence for taking countermeasures against potential-rogue APs, in the range of 0 to 9. The default is 7.
# Use countermeasures policy office to take countermeasures against potential-rogue APs.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure potential-rogue-ap
Use countermeasure rogue-ap to take countermeasures against rogue APs.
Use undo countermeasure rogue-ap to restore the default.
countermeasure rogue-ap [ precedence number ]
No countermeasures are taken against rogue APs.
2: System level
precedence number: Specifies the precedence for taking countermeasures against rogue APs, in the range of 0 to 9. The default is 9.
# Use countermeasures policy office to take countermeasures against rogue APs.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure rogue-ap
Use countermeasure static to add the MAC address of a specific wireless device to the static countermeasures address list.
Use undo countermeasure static to remove all wireless devices or a wireless device with a specific MAC address from the static countermeasures address list.
countermeasure static mac-addr
undo countermeasure static { mac-addr | all }
No countermeasures are taken on wireless devices.
2: System level
mac-address: Specifies the MAC address of the wireless device to be added to or removed from the static countermeasures address list.
all: Removes all entries from the static countermeasures list.
Only virtual security domains where a countermeasures policy is applied take countermeasures against the wireless devices in the static countermeasures list defined by the policy.
The precedence of the wireless devices in the static countermeasures list is 10.
# Add MAC address 1234-5678-90ab to the static countermeasures address list defined by the countermeasures policy office.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure static 1234-5678-90ab
countermeasure static mac-address
undo countermeasure static { mac-address | all }
WIPS view
2: System level
All virtual security domains will take countermeasures against the wireless devices that are added to the countermeasures list in WIPS view.
# Add MAC address 0016-6f9d-612e to the static countermeasures address list.
[Sysname] wlan ips
[Sysname-wlan-ips] countermeasure static 0016-6f9d-612e
Use countermeasure unauthorized-client to take countermeasures against unauthorized clients.
Use undo countermeasure unauthorized-client to restore the default.
countermeasure unauthorized-client [ precedence number ]
No countermeasures are taken against unauthorized clients.
2: System level
precedence number: Specifies the precedence for taking countermeasures against unauthorized clients, in the range of 0 to 9. The default is 8.
# Use countermeasures policy office to take countermeasures against unauthorized clients.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure unauthorized-client
Use countermeasure uncategorized-ap to take countermeasures against uncategorized APs.
Use undo countermeasure uncategorized-ap to restore the default.
countermeasure uncategorized-ap [ precedence number ]
No countermeasures are taken against uncategorized APs.
2: System level
precedence number: Specifies the precedence for taking countermeasures against uncategorized APs, in the range of 0 to 9. The default is 5.
# Use countermeasures policy office to take countermeasures against uncategorized APs.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure uncategorized-ap
Use countermeasure uncategorized-client to take countermeasures against uncategorized clients.
Use undo countermeasure uncategorized-client to restore the default.
countermeasure uncategorized-client [ precedence number ]
No countermeasures are taken against uncategorized clients.
2: System level
precedence number: Specifies the precedence for taking countermeasures against uncategorized clients, in the range of 0 to 9. The default is 4.
# Use countermeasures policy office to take countermeasures against uncategorized clients.
[Sysname] wlan ips
[Sysname-wlan-ips-cmep-office] countermeasure uncategorized-client
Use countermeasure-policy to configure a countermeasures policy for a virtual security domain.
Use undo countermeasure-policy to restore the default countermeasures policy for the virtual security domain.
countermeasure-policy policy-name
The default countermeasures policy is applied to a virtual security domain.
2: System level
policy-name: Specifies a countermeasures policy by its name, a case-insensitive string of 1 to 32 characters that contain letters, numbers, and underlines (_).
Only one countermeasures policy can be applied to a virtual security domain.
# Specify countermeasures policy office for virtual security domain vsda.
[Sysname] wlan ips
[Sysname-wlan-ips] virtual-security-domain vsda
[Sysname-wlan-ips-vsd-vsda] countermeasure-policy office
Use countermeasure-policy to create a new countermeasures policy and enter countermeasures policy view, or directly enter countermeasures policy view if a countermeasures policy already exists.
Use undo countermeasure-policy to remove a countermeasures policy.
undo countermeasure-policy policy-name
The default countermeasures policy exists. It cannot be created or removed.
WIPS view
2: System level
# Create a countermeasures policy named office, and enter its view.
[Sysname] wlan ips
Use detect access-flow-scan enable to enable WIPS for a hybrid sensor that provides access services.
Use undo detect access-flow-scan enable to restore the default.
WIPS is not enabled for a hybrid sensor that provides access services.
WIPS view
2: System level
When this command is enabled, WIPS detection and attack prevention capabilities are improved, but the access performance is decreased.
# Enable WIPS for a hybrid sensor that provides access services.
[Sysname] wlan ips
[Sysname-wlan-ips] detect access-flow-scan enable
Use detect adhoc-network to enable Ad hoc network detection specified in the current attack detection policy.
Use undo detect adhoc-network to disable Ad hoc network detection specified in the current attack detection policy.
Ad hoc network detection is disabled.
Attack detection policy view
2: System level
# Enable Ad hoc network detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office]detect adhoc-network
Use detect admin-mac-scan enable to enable random MAC address filtering.
Use undo detect admin-mac-scan enable to disable random MAC address filtering.
Random MAC address filtering is disabled.
WIPS view
2: System level
# Enable random MAC address filtering.
[Sysname] wlan ips
[Sysname-wlan-ips] detect admin-mac-scan enable
detect all
Use detect all to enable all detections, including Ad hoc network, AP MAC address spoofing, client MAC address spoofing, and invalid channel detections specified in the current attack detection policy.
Use undo detect all to disable all detections specified in the current attack detection policy.
detect all
undo detect all
All-detection is disabled.
2: System level
# Enable all detections specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office]detect all
detect all action
Use detect all action { log | trap }* to configure a sensor to send a log or an alarm to the AC when it detects a malformed packet of any type specified in Table 1.
Use undo detect all action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects a malformed packet of specified types.
Malformed packet detection policy view
2: System level
log: Configures the sensor to send a log to the AC when it detects a malformed packet. The log contains information about malformed packet contents, statistics, and so on.
trap: Configures the sensor to send an alarm to the AC when it detects a malformed packet.
Table 1 Malformed packet types
invalid-ie-length
Invalid IE length.
duplicated-ie
Duplicate IE.
redundant-ie
Redundant IE.
invalid-pkt-length
Invalid packet length.
illegal-ibss-ess
Abnormal IBSS or ESS setting.
invalid-beacon-channel
Abnormal beacon channel.
overflow-eapol-key
Oversized EAPOL key.
malformed-auth
Malformed authentication frame.
malformed-assoc-req
Malformed association request frame.
malformed-ht-ie
Malformed HT IE.
large-duration
Oversized duration.
null-probe-resp
Null SSID for probe response frame.
invalid-deauth-code
Invalid deauthentication reason code.
Invalid disassociation reason code.
overflow-ssid
Oversized SSID.
fata-jack
FATA Jack attack.
FATA Jack is a kind of DOS attack. The attacker sends spoof authentication frames to the AP. After receiving the spoof frames, the AP sends disconnect frames to authorized users, so the authorized users will be disconnected.
Invalid source address.
Invalid-channel
Invalid channel ID.
# Configure the sensor to send a log and an alarm to the AC when it detects a malformed packet of any type specified in the malformed packet detection policy normal.
[Sysname] wlan ips
[Sysname-wlan-ips] malformed-detect-policy normal
[Sysname-wlan-ips-mdctp-normal]detect all action log trap
detect ap-flood
Use detect ap-flood to enable AP flooding detection specified in the current attack detection policy.
Use undo detect ap-flood to disable AP flooding detection specified in the current attack detection policy.
detect ap-flood [ quiet-time time-value ]
Detection on AP flooding is disabled.
2: System level
time-value: Specifies the quiet time after AP flooding is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable AP flooding detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect ap-flood
Use detect ap-impersonation to enable AP impersonation attack detection specified in the current attack detection policy.
Use undo detect windows-bridge to disable AP impersonation attack detection specified in the current attack detection policy.
detect ap-impersonation [ quiet-time time-value | beacon-inc-threshold beacon-inc-threshold-value | beacon-inc-wait-time beacon-inc-wait-time-value ]*
undo detect ap-impersonation
AP impersonation attack detection is disabled.
2: System level
quiet-time time-value: Specifies the quiet time after an alarm is generated for detecting an AP impersonation attack, in the range of 5 to 604800 seconds. The default is 600 seconds.
beacon-inc-threshold beacon-inc-threshold-value: Specifies the threshold for beacon frame transmission rate increase in percentage. WIPS generates an alarm when the threshold is reached. The value range for the beacon-inc-threshold-value argument is 1 to 100, and the default is 30.
beacon-inc-wait-time beacon-inc-wait-time-value: Specifies the time to wait after a suspicious AP impersonator is detected, in the range of 0 to 360000 seconds. The default is 10 seconds. WIPS generates an alarm if the number of beacon frames is increasing within the time period.
# Enable AP impersonation attack detection specified in the attack detection policy named office, and specify the beacon-inc-threshold-value, beacon-inc-wait-time-value, and time-value as 10, 20, and 30, respectively.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-1] detect ap-impersonation beacon-inc-threshold 10 beacon-inc-wait-time 20 quiet-time 30
detect ap-spoofing
Use detect ap-spoofing to enable AP MAC address spoofing detection specified in the current attack detection policy.
Use undo detect ap-spoofing to disable AP MAC address spoofing detection specified in the current attack detection policy.
detect ap-spoofing [ quiet-time time-value ]
AP MAC address spoofing detection is disabled.
2: System level
time-value: Specifies the quiet time when AP MAC spoofing is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable AP spoofing detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office]detect ap-spoofing
Use detect client-spoofing to enable client MAC address spoofing detection specified in the current attack detection policy.
Use undo detect client-spoofing to disable client MAC address spoofing detection specified in the current attack detection policy.
detect client-spoofing [ quiet-time time-value ]
Client MAC address spoofing detection is disabled.
2: System level
time-value: Specifies the quiet time when client MAC spoofing is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable client spoofing detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office]detect client-spoofing
Use detect deauth-spoofing to enable spoofed deauthentication frame detection specified in the current attack detection policy.
Use undo detect deauth-spoofing to disable spoofed deauthentication frame detection specified in the current attack detection policy.
Spoofed deauthentication frame detection is disabled.
2: System level
# Enable spoofed deauthentication frame detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-1] detect deauth-spoofing
Use detect dos-association to enable association DoS attack detection specified in the current attack detection policy.
Use undo detect dos-association to disable association DoS attack detection specified in the current attack detection policy.
detect dos-association [ quiet-time time-value ]
Association DoS attack detection is disabled.
2: System level
time-value: Specifies the quiet time when association DoS attack is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable association DoS attack detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect dos-association
Use detect dos-authentication to enable authentication DoS attack detection specified in the current attack detection policy.
Use undo detect dos-authentication to disable authentication DoS attack detection specified in the current attack detection policy.
detect dos-authentication [ quiet-time time-value ]
Authentication DoS attack detection is disabled.
2: System level
time-value: Specifies the quiet time when authentication DoS attack is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable authentication DoS attack detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect dos-authentication
Use detect dos-eapol-start to enable EAPOL-Start DoS attack detection specified in the current attack detection policy.
Use undo detect dos-eapol-start to disable EAPOL-Start DoS attack detection specified in the current attack detection policy.
detect dos-eapol-start [ quiet-time time-value ]
EAPOL-Start DoS attack detection is disabled.
2: System level
time-value: Specifies the quiet time when EAPOL-Start DoS attack is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable EAPOL-Start DoS attack detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect dos-eapol-start
Use detect dos-reassociation to enable reassociation DoS attack detection specified in the current attack detection policy.
Use undo detect dos-reassociation to disable reassociation DoS attack detection specified in the current attack detection policy.
detect dos-reassociation [ quiet-time time-value ]
2: System level
time-value: Specifies the quiet time when reassociation DoS attack is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable reassociation DoS attack detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect dos-reassociation
Use detect duplicated-ie action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a duplicate IE.
Use undo detect duplicated-ie action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects a duplicate IE.
2: System level
log: Configures the sensor to send a log to the AC when it detects a duplicate IE.
trap: Configures the sensor to send an alarm to the AC when it detects a duplicate IE.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a duplicate IE.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect duplicated-ie action log trap
Use detect fata-jack action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a FATA Jack attack.
Use undo detect fata-jack action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects a FATA Jack attack.
2: System level
log: Configures the sensor to send a log to the AC when it detects a FATA Jack attack.
trap: Configures the sensor to send an alarm to the AC when it detects a FATA Jack attack.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a FATA Jack attack.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect fata-jack action log trap
detect honeypot-ap
Use detect honeypot-ap to enable honeypot AP detection specified in the current attack detection policy.
Use undo detect honeypot-ap to disable honeypot AP detection specified in the current attack detection policy.
detect honeypot-ap [ quiet-time time-value | similarity similarity-value ]* [ action classify rogue ]
Honeypot AP detection is disabled.
2: System level
quiet-time time-value: Specifies the quiet time after an alarm is generated for detecting a honeypot AP, in the range of 5 to 604800 seconds. The default is 600 seconds.
similarity similarity-value: Specifies the similarity threshold that triggers a honeypot AP alarm, in the range of 70 to 100 in percentage. The default value is 90%. An AP is determined as a honeypot AP if the similarity between the SSID of the AP and the SSID of a legitimate AP reaches the threshold.
action classify rogue: Classifies the detected attackers as rogue APs or unauthorized clients.
# Enable honeypot AP detection specified in the attack detection policy named office. Set the similarity threshold and quite time to 80% and 900 seconds, respectively, and classify the detected attackers as rogue APs or unauthorized clients.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-1] detect honeypot-ap similarity 80 quiet-time 900 action classify rogue
Use detect hotspot-attack to enable hotspot attack detection specified in the current attack detection policy.
Use undo detect hotspot-attack to disable hotspot attack detection specified in the current attack detection policy.
detect hotspot-attack [ action classify rogue ]
Hotspot attack detection is disabled.
2: System level
# Enable hotspot attack detection specified in the attack detection policy named office, and classify the detected attackers as rogue APs or unauthorized clients.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect hotspot-attack action classify rogue
Use detect ht-40mhz-intolerance to enable detection on clients with the 40 MHz bandwidth mode disabled specified in the current attack detection policy.
Use undo detect ht-40mhz-intolerance to disable detection on clients with the 40 MHz bandwidth mode disabled specified in the current attack detection policy.
detect ht-40mhz-intolerance [ quiet-time time-value ]
Detection on clients with the 40 MHz bandwidth mode disabled is disabled.
2: System level
quiet-time time-value: Specifies the quiet time after an alarm is generated for detecting a client with the 40 MHz bandwidth mode disabled, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable detection on clients with the 40 MHz bandwidth mode disabled specified in the attack detection policy named office, and set the quite time to 900 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-1] detect ht-40mhz-intolerance quiet-time 900
Use detect ht-greenfield to enable HT-greenfield AP detection specified in the current attack detection policy.
Use undo detect ht-greenfield to disable HT-greenfield AP detection specified in the current attack detection policy.
detect ht-greenfield [ quiet-time time-value ]
HT-greenfield AP detection is disabled.
2: System level
time-value: Specifies the quiet time after an alarm is generated for detecting an HT-greenfield AP, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable HT-greenfield AP detection specified in the attack detection policy named office, and set the quiet time to 30 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-1] detect ht-greenfield quiet-time 30
Use detect illegal-ibss-ess action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects abnormal IBSS or ESS setting.
Use undo detect illegal-ibss-ess action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects abnormal IBSS or ESS setting.
2: System level
log: Configures the sensor to send a log to the AC when it detects abnormal IBSS or ESS setting.
trap: Configures the sensor to send an alarm to the AC when it detects abnormal IBSS or ESS setting.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects abnormal IBSS or ESS setting.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect illegal-ibss-ess action log trap
Use detect invalid-channel action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an invalid channel ID.
Use undo detect invalid-channel action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects an invalid channel ID.
2: System level
log: Configures the sensor to send a log to the AC when it detects an invalid channel ID.
trap: Configures the sensor to send an alarm to the AC when it detects an invalid channel ID.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an invalid channel ID.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect invalid-channel action log trap
Use detect invalid-deauth-code action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an invalid deauthentication reason code.
Use undo detect invalid-deauth-code action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects an invalid deauthentication reason code.
2: System level
log: Configures the sensor to send a log to the AC when it detects an invalid deauthentication reason code.
trap: Configures the sensor to send an alarm to the AC when it detects an invalid deauthentication reason code.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an invalid deauthentication reason code.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect invalid-deauth-code action log trap
Use detect invalid-disassoc-code action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an invalid disassociation reason code.
Use undo detect invalid-disassoc-code action { log | trap }* to disable the function.
The sensor does not send a log or alarm to the AC when it detects an invalid disassociation reason code.
2: System level
log: Configures the sensor to send a log to the AC when it detects an invalid disassociation reason code.
trap: Configures the sensor to send an alarm to the AC when it detects an invalid disassociation reason code.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an invalid disassociation reason code .
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect invalid-disassoc-code action log trap
Use detect invalid-ie-length action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects invalid IE length.
Use detect invalid-ie-length action { log | trap }* to disable the function.
undo detect invalid-ie-length action { log | trap }*
The sensor does not send a log or alarm to the AC when it detects invalid IE length.
2: System level
log: Configures the sensor to send a log to the AC when it detects invalid IE length.
trap: Configures the sensor to send an alarm to the AC when it detects invalid IE length.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects invalid IE length .
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect invalid-ie-length action log trap
detect invalid-oui
Use detect invalid-oui to enable invalid OUI attack detection for an attack detection policy, and classify the detected devices.
Use undo detect invalid-oui to restore the default.
detect invalid-oui [ action classify rogue ]
Invalid OUI attack detection is disabled in an attack detection policy.
2: System level
action classify rogue: Classifies detected APs as rogue APs, and detected clients as unauthorized clients..
Invalid OUIs are OUIs that do not exist in the OUI library in the WIPS system. The OUI library can be imported by using the import oui command.
# Enable invalid OUI attack detection specified in the attack detection policy office, and classify the detected devices as rogue devices.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office]detect invalid-oui action classify rogue
Use detect invalid-pkt-length action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects invalid packet length.
Use undo detect invalid-pkt-length action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects invalid packet length.
2: System level
log: Configures the sensor to send a log to the AC when it detects invalid packet length.
trap: Configures the sensor to send an alarm to the AC when it detects invalid packet length.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects invalid packet length.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect invalid-pkt-length action log trap
Use detect invalid-source-address action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an authentication/association request frame with a multicast or broadcast source address.
Use undo detect invalid-source-address action { log | trap }* to disable the function.
The sensor does not send a log or alarm to the AC when it detects an authentication/association request frame with a multicast or broadcast source address.
2: System level
log: Configures the sensor to send a log to the AC when it detects an authentication/association request frame with a broadcast or multicast source address.
trap: Configures the sensor to send an alarm to the AC when it detects an authentication/association request frame with a broadcast or multicast source address.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an authentication/association request frame with a multicast or broadcast source address.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect invalid-source-address action log trap
Use detect large-duration threshold time to set the duration threshold.
Use undo detect large-duration threshold to restore the default.
Use detect large-duration action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an oversized duration.
Use undo detect large-duration action { log | trap }* to disable the function.
Use detect large-duration threshold time action { log | trap }* to set the duration threshold, and configure the sensor to send a log, an alarm, or both to the AC when it detects a duration value higher than the threshold.
detect large-duration { threshold time | action { log | trap }* }*
undo detect large-duration { threshold | action { log | trap }* }
The sensor does not send a log or alarm to the AC when it detects an oversized duration.
2: System level
threshold time: Specifies the duration threshold for a malformed packet detection policy, in the range of 1 to 32767 microseconds. The default value is 5000 microseconds.
log: Configures the sensor to send a log to the AC when it detects an oversized duration.
trap: Configures the sensor to send an alarm to the AC when it detects an oversized duration.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an oversized duration.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect large-duration action log trap
# Configure the duration threshold for the malformed packet detection policy normal as 2000 μs, and configure the sensor to send a log and an alarm to the AC when the duration exceeds 2000 μs.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect large-duration threshold 2000 action log trap
Use detect malformed-assoc-req action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a malformed association request frame.
Use undo detect malformed-assoc-req action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects a malformed association request frame.
2: System level
log: Configures the sensor to send a log to the AC when it detects a malformed association request frame.
trap: Configures the sensor to send an alarm to the AC when it detects a malformed association request frame.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a malformed association request frame.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect malformed-assoc-req action log trap
Use detect malformed-auth action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a malformed authentication frame.
Use undo malformed-auth action { log | trap }* to disable the function.
undo detect malformed-auth action { log | trap }*
The sensor does not send a log or an alarm to the AC when it detects a malformed authentication frame.
2: System level
log: Configures the sensor to send a log to the AC when it detects a malformed authentication frame.
trap: Configures the sensor to send an alarm to the AC when it detects a malformed authentication frame.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a malformed authentication frame.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect malformed-auth action log trap
Use detect malformed-ht-ie action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a malformed HT IE.
Use undo detect malformed-ht-ie action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects a malformed HT IE.
2: System level
log: Configures the sensor to send a log to the AC when it detects a malformed HT IE.
trap: Configures the sensor to send an alarm to the AC when it detects a malformed HT IE.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a malformed HT IE.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect malformed-ht-ie action log trap
Use detect null-probe-resp action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a probe response frame with a null SSID.
Use undo detect null-probe-resp { log | trap }* to disable the function.
undo detect null-probe-resp action { log | trap }*
The sensor does not send a log or an alarm to the AC when it detects a probe response frame with a null SSID.
2: System level
log: Configures the sensor to send a log to the AC when it detects a null SSID in the probe response frame.
trap: Configures the sensor to send an alarm to the AC when it detects a null SSID in the probe response frame.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a probe response frame with a null SSID.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect null-probe-resp action log trap
Use detect overflow-eapol-key action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an EAPOL packet with an oversized key.
Use undo detect overflow-eapol-key action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects an EAPOL packet with an oversized key.
2: System level
log: Configures the sensor to send a log to the AC when it detects an EAPOL packet with an oversized key.
trap: Configures the sensor to send an alarm to the AC when it detects an EAPOL packet with an oversized key.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an EAPOL packet with an oversized key.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect overflow-eapol-key action log trap
Use detect overflow-ssid action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects an oversized SSID.
Use undo detect overflow-ssid action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects an oversized SSID.
2: System level
log: Configures the sensor to send a log to the AC when it detects an oversized SSID.
trap: Configures the sensor to send an alarm to the AC when it detects an oversized SSID.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects an oversized SSID.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal]detect overflow-ssid action log trap
Use detect prohibited-channel to enable prohibited channel detection specified in the current attack detection policy.
Use undo detect prohibited-channel to disable prohibited channel detection specified in the current attack detection policy.
detect prohibited-channel [ action classify rogue ]
Prohibited channel detection is disabled.
2: System level
action classify rogue: Classifies devices on a detected prohibited channel as rogue APs or unauthorized clients.
Use the detect prohibited-channel command in combination with the permit-channel command.
# Specify channels 1, 6, 11, 149, 153, and 157 as permitted channels and enable prohibited channel detection specified in the attack diction policy office. Classify devices on a detected prohibited channel as rogue APs or unauthorized clients.
[Sysname] wlan ips
[Sysname-wlan-ips] permit-channel 1 6 11 149 153 157
[Sysname-wlan-ips-dctp-office]detect prohibited-channel action classify rogue
detect ps-attack
Use detect ps-attack to enable power saving attack detection specified in the current attack detection policy.
Use undo detect ps-attack to disable power saving attack detection specified in the current attack detection policy.
detect ps-attack [ quiet-time quiet-time-value | threshold { minoffpacket minoffpacket-value | onoffpercent onoffpercent-value}* ]*
Power saving attack detection is disabled.
2: System level
quiet-time quiet-time-value: Specifies the quiet time after an alarm is generated for detecting a power saving attack, in the range of 5 to 604800 seconds. The default is 600 seconds.
threshold: Specifies parameters for power saving attack detection.
minoffpacket minoffpacket-value: Specifies the minimum number of off packets a client in power saving mode sends within 10 seconds. The value range for the argument is 10 to 150, and the default is 50.
onoffpercent onoffpercent-value: Specifies the threshold for the ratio between the on packets and off packets a client in power saving mode sends. WIPS generates an alarm when the threshold is reached. The value range for this argument is 0 to 100, and the default is 80.
# Enable power saving attack detection specified in the attack detection policy named office, and specify the quiet-time-value, minoffpacket-value, and onoffpercent-value as 60, 60, and 90, respectively.
<sysname> system-view
[sysname] wlan ips
[sysname-wlan-ips] attack-detect-policy office
[sysname-wlan-ips-dctp-office] detect ps-attack quiet-time 60 threshold minioffpacket
60 onoffpercent 90
Use detect redundant-ie action { log | trap }* to configure the sensor to send a log, an alarm, or both to the AC when it detects a redundant IE.
Use undo detect redundant-ie action { log | trap }* to disable the function.
The sensor does not send a log or an alarm to the AC when it detects a redundant IE.
2: System level
log: Configures the sensor to send a log to the AC when it detects a redundant IE.
trap: Configures the sensor to send an alarm to the AC when it detects a redundant IE.
# In the malformed packet detection policy named normal, configure the sensor to send a log and an alarm to the AC when it detects a redundant IE.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-normal] detect redundant-ie action log trap
detect scan-channel
Use detect scan-channel to add one or multiple channels to the channel scanning list.
Use undo detect scan-channel to restore the default.
detect scan-channel channel-list
undo detect scan-channel { all | channel-list }
No channels are added to the channel scanning list.
WIPS view
2: System level
channel-list: Specifies a space-separated list of up to 10 channel items. Each item specifies a channel number or a channel number range. The value range for channel numbers is 1 to 196.
all: Specifies all channels in the channel scanning list.
# Add channels 1, 6, and 11 to the channel scanning list.
[Sysname] wlan ips
[Sysname-wlan-ips] detect scan-channel 1 6 11
detect soft-ap
Use detect soft-ap to enable soft AP detection specified in the current attack detection policy.
Use undo detect soft-ap to disable soft AP detection specified in the current attack detection policy.
detect soft-ap [ convert-time convert-time-value ]*
undo detect soft-ap
Soft AP detection is disabled.
2: System level
convert-time-value: Specifies the interval at which a soft AP switches between client and AP. The value range for this argument is 5 to 600 seconds, and the default is 10 seconds.
# Enable soft AP detection specified in the attack detection policy named office, and specify the convert-time-value as 20.
[sysname] wlan ips
[sysname-wlan-ips-dctp-office] detect soft-ap convert-time 20
Use detect unencrypted-authorized-ap to enable unencrypted authorized AP detection specified in the current attack detection policy.
Use undo detect unencrypted-authorized-ap to disable unencrypted authorized AP detection specified in the current attack detection policy.
detect unencrypted-authorized-ap [ quiet-time quiet-time-value ]
Unencrypted authorized AP detection is disabled.
2: System level
quiet-time quiet-time-value: Specifies the quiet time after an alarm is generated for detecting an unencrypted authorized AP, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable unencrypted authorized AP detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect unencrypted-authorized-ap
Use detect unencrypted-trust-client to enable unencrypted trust client detection specified in the current attack detection policy.
Use undo detect unencrypted-trust-client to disable unencrypted trust client detection specified in the current attack detection policy.
detect unencrypted-trust-client [ quiet-time quiet-time-value ]
Unencrypted trust client detection is disabled.
2: System level
quiet-time quiet-time-value: Specifies the quiet time after an alarm is generated for detecting an unencrypted trust client, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable unencrypted trust client detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office]detect unencrypted-trust-client
detect weak-iv
Use detect weak-iv to enable weak-IV detection for an attack detection policy.
Use undo detect weak-iv to restore the default.
detect weak-iv [ quiet-time time-value ]
undo detect weak-iv
Weak-IV detection is disabled in an attack detection policy.
2: System level
time-value: Specifies the quiet time after weak-IV is detected and an alarm is generated, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable weak-IV detection for the attack detection policy office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect weak-iv quiet-time 10
Use detect windows-bridge to enable Windows bridge detection specified in the current attack detection policy.
Use undo detect windows-bridge to disable Windows bridge detection specified in the current attack detection policy.
Windows bridge detection is disabled.
2: System level
# Enable Windows bridge detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-1] detect windows-bridge
Use detect wireless-bridge to enable wireless bridge detection specified in the current attack detection policy.
Use undo detect wireless-bridge to disable wireless bridge detection specified in the current attack detection policy.
detect wireless-bridge [ quiet-time time-value ]
Wireless bridge detection is disabled.
2: System level
quiet-time time-value: Specifies the quiet time after an alarm is generated for detecting a wireless bridge, in the range of 5 to 604800 seconds. The default is 600 seconds.
# Enable wireless bridge detection specified in the attack detection policy named office.
[Sysname] wlan ips
[Sysname-wlan-ips-dctp-office] detect wireless-bridge quite-time 480
Use detect wireless-device disable to disable wireless device detection for WIPS.
Use undo detect wireless-device disable to enable wireless device detection for WIPS.
Wireless device detection for WIPS is enabled.
WIPS view
2: System level
# Disable wireless device detection for WIPS.
[Sysname] wlan ips
[Sysname-wlan-ips] detect wireless-device disable
detect-period
Use detect-period to configure the statistics collection period for a signature. With this command enabled, WIPS takes further actions according to the configuration of the action command when the number of matching times of a signature reaches the detection threshold configured with the detect-threshold command within this statistics collection period.
Use undo detect-period to restore the default.
detect-period period-time
undo detect-period
The statistics collection period for a user-defined signature is 60 seconds and that for a system-defined signature depends on the specific system-defined signature.
SIG view
2: System level
period-time: Specifies the statistics collection period for a signature, in the range of 1 to 3600 seconds.
If you configure the statistics collection period for a signature multiple times, the most recent configuration overwrites the previous one.
To modify the statistics collection period for a signature that has been bound to a signature policy, remove the binding first.
# Configure the statistics collection period for the user-defined signature office as 500 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips]signature office
[Sysname-wlan-ips-sig-office] detect-period 500
detect-threshold
Use detect-threshold to configure the maximum matching times for a signature within the specified statistics collection period. When the matching times reach this threshold, WIPS takes further actions according to the configuration of the action command.
Use undo detect-threshold to restore the default.
detect-threshold { per-mac number | per-signature number }
undo detect-threshold { per-mac | per-signature }
The maximum matching times for a user-defined signature is 1000 and that for a system-defined signature depends on the specific system-defined signature.
SIG view
2: System level
per-mac number: Specifies the maximum matching times for a signature when the track-method in the signature is configured as per-mac. The value is in the range of 1 to 32000 times.
per-signature number: Specifies the maximum matching times for a signature when the track-method in the signature is configured as per-signature. The value is in the range of 1 to 32000 times.
If you configure the detect-threshold for a signature multiple times, the most configuration overwrites the previous one.
You cannot configure the maximum matching times for a signature if a track method does not exist.
To modify the detect-threshold for a signature that has been bound to a signature policy, remove the binding first.
# Configure the maximum matching times for the signature office as 6000 when the track-method is per-mac.
[Sysname] wlan ips
[Sysname-wlan-ips-sig-office] detect-threshold per-mac 6000
display wlan ips ap-classification-rule
Use display wlan ips ap-classification-rule to display information about the specified or all AP classification rules.
display wlan ips ap-classification-rule [ rule-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
rule-name: Specifies an AP classification rule by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines, but not spaces.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
# Display information about all AP classification rules in the system.
[Sysname]display wlan ips ap-classification-rule rule1
                            AP Classification Rules
Classifictaion Rule Name  : rule1
 Classify Type            : authorized-ap
 Severity Level          : -NA-
 Match                    : Any
 SSID                     : not include "test"
 SSID Match Case          : Ignore
 Security                 : equal WPA2
 Authentication Method    : 802.1X
 RSSI                     : > 40
 Duration                 : > 86400
 Client Count             : -NA-
 Discovered APs           : < 10
 OUI                      : -NA-
 OUI Vendor               : h3c
 Applied to VSD
  VSD 1                   : office
  VSD 2                   : lab
Classifictaion Rule Name  : rule2
 Classify Type            : -NA-
 Serverity Level          : 10
 Match                    : Any
 SSID                     : include "test"
 Security                 : include WPA
 Authentication Method    : PSK
 RSSI                     : < 20
 Duration                 : < 86400
 Client Count             : -NA-
 Discovered APs           : > 10
 OUI                      : 00-01-02
 OUI Vendor               : -NA-
 Applied to VSD
  VSD 1                   : office
Severity Level
Severity level for an AP that matches an AP classification rule. The value is in the range of 0 to 100.
Match
Match policy for the rule.
·     AllAn AP is considered as matching the rule when it matches all match criteria of the rule.
·     Any—An AP is considered as matching an AP classification rule as long as it matches any match criterion of the rule.
SSID
Match criteria for an SSID.
·     include—Includes the configured character string.
·     not Include—Does not include the configured character string.
·     equal—Equal to the configured characters string.
·     not equal—Not equal to the configured characters string.
SSID Match Case
Whether case is considered when the SSID is matched:
·     ignore—Case insensitive.
·     exact—Case sensitive.
Security
Security type used by the AP.
·     Clear.
·     WEP.
·     WPA.
·     WPA2.
Authentication method used by the AP:
·     802.1X—802.1X authentication.
·     PSK—PSK authentication.
·     None—No authentication.
·     Other—Authentication other than 802.1X, PSK, and None.
RSSI
RSSI of the AP.
Duration
Bootup time of the AP.
Client Count
Number of clients associated with the AP.
Discovered Aps
Number of APs discovered by the current sensor.
OUI
OUI of the AP.
OUI Vendor
Vendor of the AP.
Applied to VSD
Virtual security domain where the AP classification rule is applied.
VSD n
Name of the virtual security domain, where n represents a number automatically assigned by the system.
display wlan ips attack-detect-policy
Use display wlan ips attack-detect-policy to display information about the specified or all attack detection policies.
display wlan ips attack-detect-policy [ policy-name ] [ | { begin | exclude | include } regular-expression ]
Default command level
2: System level
policy-name: Specifies an attack detection policy by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines, but not spaces.
# Display information about attack detection policy policy1.
[Sysname]display wlan ips attack-detect-policy
                             Attack Detect Policies
Detection-Type       Status Quiet-Time Action
Policy Name: default
Adhoc-network        off    --         --
Prohibited-channel   off    --         --
AP-spoofing          on     100        --
Client-spoofing      on     200        --
AP-Flood             off    --         --
Dos-eapol-start      off    --         --
Dos-authentication   off    --         --
Dos-association      off    --         --
Dos-reassociation    off    --         --
Weak-iv              off    --         --
Invalid-OUI          on     --         --
Ps-attack            on     600        --
Windows-Bridge       on     --         --
Hotspot-attack       on     --         --
AP-Impersonation     on     600        --
Soft-ap              on     --         --
Unencrypt-auth-ap    on     600        --
Unencrypt-trust-cli  on     600        --
Applied To VSD : default, vsd_office
Policy Name: lab
Adhoc-network        on     --         --
Prohibited-channel   on     --         --
AP-spoofing          off    --         --
Client-spoofing      off    --         --
AP-Flood             on     600        --
Weak-iv              on     500        --
Invalid-OUI          off    --         --
Ps-attack            off    --         --
Windows-Bridge       off    --         --
Hotspot-attack       off    --         --
AP-Impersonation     off    --         --
Soft-ap              off    --         --
Unencrypt-auth-ap    off    --         --
Unencrypt-trust-cli  off    --         --
Applied To VSD : vsd_lab
Detection-Type
Detection type.
Status
Detection status, enabled or disabled.
Quiet-Time
Quiet time when an attack is detected.
Action
Action to take when an attack is detected.
Policy Name
Attack detection policy name.
Adhoc-network
Whether to detect Ad hoc networks.
·     on.
·     off.
Prohibited-channel
Whether to detect prohibited channels.
·     on.
·     off.
AP-spoofing
Whether to detect AP spoofing.
·     on.
·     off.
Client-spoofing
Whether to detect client spoofing.
·     on.
·     off.
AP-Flood
Whether to detect AP flood.
·     on.
·     off.
Dos-eapol-start
Whether to detect EAPOL-Start DoS attacks.
·     on.
·     off.
Dos-authentication
Whether to detect authentication DoS attacks.
·     on.
·     off.
Dos-association
Whether to detect association DoS attacks.
·     on.
·     off.
Dos-reassociation
Whether to detect reassociation DoS attacks.
·     on.
·     off.
Weak-iv
Whether to detect weak-IV.
·     on.
·     off.
Invalid-OUI
Whether to detect invalid OUIs.
·     on.
·     off.
Ps-attack
Whether to detect power saving attacks.
·     on.
·     off.
Windows-Bridge
Whether to detect Windows bridge.
·     on.
·     off.
Hotspot-attack
Whether to detect hotspot attacks.
·     on.
·     off.
AP-Impersonation
Whether to detect AP impersonation attacks.
·     on.
·     off.
Soft-ap
Whether to detect soft APs.
·     on.
·     off.
Unencrypt-auth-ap
Whether to detect unencrypted authorized APs.
·     on.
·     off.
Unencrypt-trust-cli
Whether to detect unencrypted trust clients.
·     on.
·     off.
Applied to VSD
Virtual security domain where the attack detection policy is applied.
display wlan ips authssidlist
Use display wlan ips authssidlist to display information about the specified or all entries in the WIPS authorized SSID list.
display wlan ips authssidlist [ | { begin | exclude | include } regular-expression ]
2: System level
regular-expression: Specifies a regular expression, which is a case-sensitive string of 1 to 256 characters.
# Display information about all entries in the authorized SSID list.
<Sysname> display wlan ips authssidlist
Total Number of Entries:      6
                                     AuthSSID List
SSID                                                        Added-Time
Cmcc                                                        2014-06-07/15:42:31
Y6066                                                       2014-06-07/15:42:31
c4                                                          2014-06-07/15:42:31
full                                                        2014-06-07/15:42:31
full2                                                       2014-06-07/15:42:31
z05066t                                                     2014-06-07/15:42:31
display wlan ips blocklist
Use display wlan ips blocklist to display information about the specified or all entries in a WIPS prohibited device list.
display wlan ips blocklist [ static | dynamic | mac-address mac-addr ] [ | { begin | exclude | include } regular-expression ]
2: System level
static: Specifies manually configured entries in the prohibited device list.
dynamic: Specifies dynamically added entry in the prohibited device list.
mac-address mac-addr: Specifies an entry with a specific MAC address in the prohibited device list.
# Display information about all entries in the prohibited device list.
[Sysname] display wlan ips blocklist
Total Number of Entries: 2
State:  S = Static,  D = Dynamic,  S&D = Static & Dynamic
Blocklist-Action Block : Disable
                                   Block List
MAC-Address              Status
0001-0002-0003           S
0001-0002-0004           S
Disable wireless devices in the prohibited device list from accessing the WLAN.
·     Enable.
·     Disable.
MAC-Address
MAC address of the wireless device in the prohibited device list.
Status
Status of the entries in the prohibited device list.
·     S—Manually configured.
·     DDynamically generated.
·     S&D—Manually configured and dynamically generated.
display wlan ips channel
Use display wlan ips channel to display information about the specified or all channels.
display wlan ips channel [ permit | prohibit ] [ | { begin | exclude | include } regular-expression ]
2: System level
permit: Specifies permitted channels.
prohibit: Specifies prohibited channels.
# Display information about all channels.
[Sysname] display wlan ips channel
                                   Channel List
  Channel       Radio-Type       Permit      Last-Time
    1           11gn             No          2013-06-21/16:00:47
    2           11gn             No          2013-06-21/16:00:47
    3           11gn             No          2013-06-21/16:00:47
    4           11gn             No          2013-06-21/16:00:47
    5           11gn             No          2013-06-21/16:00:47
    6           11gn             No          2013-06-21/16:00:47
    7           11gn             No          2013-06-21/16:00:47
    8           11gn             No          2013-06-21/16:00:47
    9           11gn             No          2013-06-21/16:00:47
   10           11gn             No          2013-06-21/16:00:47
   11           11gn             No          2013-06-21/16:00:47
   12           11gn             No          2013-06-21/16:00:47
   13           11gn             No          2013-06-21/16:00:47
  149           11an             No          2013-06-21/16:00:47
  153           11an             No          2013-06-21/16:00:47
  157           11an             No          2013-06-21/16:00:47
  161           11an             No          2013-06-21/16:00:47
  165           11an             No          2013-06-21/16:00:47
Table 5 Command output
Channel
Channels supported by the current country/region code.
Radio-Type
Type of the radio.
Permit
Whether the channel is permitted.
·     Yes.
·     No.
Last-Time
Time when the most recent transmission activity was detected on the channel.
display wlan ips countermeasure-devices
Use display wlan ips countermeasure-devices to display countermeasures statistics for one or all virtual security domains.
display wlan ips [ vsd vsd-name ] countermeasure-devices [ static [ countermeasure | pending | idle ] | dynamic [ countermeasure | pending ] | mac-address mac-addr ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
2: System level
vsd vsd-name: Specifies a virtual security domain by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
static: Displays information about wireless devices added to the countermeasures list from WIPS view and countermeasures policy view.
dynamic: Displays information about wireless devices dynamically added to the countermeasures list.
countermeasure: Displays information about wireless devices against which countermeasures are being taken.
pending: Displays information about wireless devices against which countermeasures are to be taken.
idle: Displays information about wireless devices added to the countermeasures list but are not in any virtual security domain.
mac-address mac-addr: Displays information about wireless devices with the specified MAC addresses.
verbose: Displays detailed information about wireless devices in the countermeasures list.
# Display countermeasures statistics for all virtual security domains.
<Sysname> display wlan ips countermeasure-devices
 S = Static, D = Dynamic, VSD = virtual security domain, Chl = Channel
 P = Pending, C = Countermeasure, I = Idle, PRI = Precedence
                             Countermeasure Devices
Mac-address     Type  State  Start-Time          Classification          Chl PRI
VSD: default
 c4ca-d97e-2680 S&D   C      2013-06-21/16:11:44 rogue-ap                6   10
 3ce5-a68b-9030 D     P      2013-06-21/16:15:26 rogue-ap                6   9
 c4ca-d9f0-cab0 S     C      2013-06-21/16:15:26 potential-external-ap   1   10
 006a-ff00-0001 D     C      2013-06-21/16:11:29 rogue-ap                5   9
VSD: vsd_office
 c4ca-d97e-2680 S     I      --                   --                     --  --
 c4ca-d9f0-cab0 S     I      --                   --                     --  --
VSD: vsd_lab
Table 6 Command output
Type of the wireless device.
·     S—Manually added.
·     D—Dynamically added.
·     S&D—Both manually and dynamically added.
State of the wireless device against which countermeasures are taken.
·     Pending.
·     Countermeasure.
·     Idle.
Start-Time
Time when the wireless device enters the current state.
Classification
Type of the wireless device against which countermeasures are taken.
·     Potential-rogue-ap
·     Rogue-ap
·     Misconfigured-ap
·     Uncategorized-ap
·     Potential-external-ap
·     External-ap
·     Potential-authorized-ap
·     Uncategorized-client
·     Misassociation-client
·     Unauthorized-client
Chl
Channel on which the sensor is operating.
PRI
Countermeasures precedence.
# Display detailed countermeasures statistics for the virtual security domain lab.
<Sysname> display wlan ips vsd default countermeasure-devices verbose
VSD: default
 Device: c4ca-d97e-2680
 Type                                    : Static
 Classification                          : potential-external-ap
 Precedence                              : 10
 State                                   : Countermeasure
 Channel                                 : 6
 Sensor                                  : ap3
 Start-Time                              : 2013-06-21/16:11:44
 Global Static Countermeasure            : YES
 Applied to Countermeasure-policies      : --
  default
  office
 Countermeasure records                  : 1
  2013-06-21/16:11:29 - 2013-06-21/16:11:44 Pending
 Device: c4ca-d9f0-cab0
 Type                                    : Static
 Precedence                              : 10
 State                                   : Pending
 Channel                                 : 1
 Sensor                                  : --
 Start-Time                              : 2013-06-21/16:25:56
 Countermeasure records                  : 0
 Device: 006a-ff00-0001
 Type                                    : Dynamic
 Classification                          : rogue-ap
 Precedence                              : 9
 Channel                                 : 5
 Sensor                                  : ap3
 Start-Time                              : 2013-06-21/16:11:29
 Global Static Countermeasure            : NO
  2013-06-21/16:11:29 - 2013-06-21/16:11:29 Pending
Table 7 Command output
Device
MAC address of the wireless device in the countermeasures list.
Type of the wireless device in the countermeasures list.
·     Static—Manually added.
·     Dynamic—Dynamically added.
·     Static & Dynamic—Both manually and dynamically added.
Classification
Classification of the device in the current virtual security domain.
Precedence
Countermeasures precedence of the device in the current virtual security domain.
State of the wireless device.
·     Pending.
·     Countermeasure.
·     Idle.
Channel
Channel on which the sensor that is taking countermeasures against the wireless device is operating.
Sensor
Sensor that is taking countermeasures against the wireless device
Start-Time
Time when the wireless device entered the current countermeasures state.
Whether the wireless device is a globally configured device against which countermeasures are taken.
Applied to Countermeasure-policy
Countermeasures policy applied to the wireless device.
Countermeasures record for the wireless device.
display wlan ips countermeasure-policy
Use display wlan ips countermeasure-policy to display information about one or all countermeasures policies.
display wlan ips countermeasure-policy [ policy-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
countermeasure-policy policy-name: Specifies a countermeasures policy by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines (_).
# Display information about countermeasures policy office.
<Sysname> display wlan ips countermeasure-policy officecmp
                              Countermeasure Policy
Policy Name : officecmp
  Countermeasure on Fixedchannel          : Disable
  Countermeasure Device-Classification
   misconfigured-ap                       : Off
   rogue-ap                               : Off
   unauthorized-client                    : Off
   external-ap                            : Off
   misassociation-client                  : On     precedence : 6
   potential-authorized-ap                : Off
   potential-rogue-ap                     : Off
   potential-external-ap                  : Off
   uncategorized-ap                       : Off
   uncategorized-client                   : Off
  Countermeasure Static Devices           : 0
  Applied to VSD                          :
   VSD 1                                  : vsd_office
Table 8 Command output
Policy Name
Countermeasures policy name.
Countermeasures policy on fixed channel.
·     enable.
·     disable.
Taking countermeasures by device type.
misconfigured-ap
Whether to take countermeasures against misconfigured APs.
·     on.
·     off.
rogue-ap
Whether to take countermeasures against rogue APs.
·     on.
·     off.
unauthorized-client
Whether to take countermeasures against unauthorized clients.
·     on.
·     off.
external-ap
Whether to take countermeasures against external APs.
·     on.
·     off.
Whether to take countermeasures against misassociated clients.
·     on.
·     off.
Whether to take countermeasures against potential-authorized APs.
·     on.
·     off.
potential-rogue-ap
Whether to take countermeasures against potential-rogue APs.
·     on.
·     off.
Whether to take countermeasures against potential-external APs.
·     on.
·     off.
uncategorized-ap
Whether to take countermeasures against uncategorized APs.
·     on.
·     off.
Whether to take countermeasures against uncategorized clients.
·     on.
·     off.
Information about the wireless devices in the static countermeasures list specified by the current countermeasures policy.
Applied to VSD
Virtual security domain where the current countermeasures policy is applied.
VSD n
Virtual security domain name, where n is a number automatically assigned by the system.
display wlan ips devices
Use display wlan ips devices to display information about wireless devices detected in the specified or all virtual security domains.
display wlan ips [ vsd vsd-name ] devices [ ap [ adhoc | authorized | external | misconfigured | potential-authorized | potential-external | potential-rogue | rogue | uncategorized | mesh-ap ] | client [ authorized | misassociation | unauthorized | uncategorized | unassociated ] | mac-address mac-addr ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
2: System level
ap: Displays AP information.
adhoc: Displays Ad hoc AP information.
authorized: Displays authorized AP information.
external: Displays external AP information.
misconfigured: Displays misconfigured AP information.
potential-authorized: Displays potential-authorized AP information.
potential-external: Displays potential-external AP information.
potential-rogue: Displays potential-rogue AP information.
rogue: Displays rogue AP information.
uncategorized: Displays uncategorized AP information.
mesh-ap: Displays mesh AP information.
client: Displays client information.
authorized: Displays authorized client information.
unauthorized: Displays unauthorized client information.
misassociation: Displays misassociated client information.
uncategorized: Displays uncategorized client information.
unassociated: Displays unassociated client information.
mac-address mac-addr: Displays information about the wireless device with a specified MAC address.
verbose: Displays device detailed information.
# Display information about all wireless devices in all virtual security domains.
<Sysname> display wlan ips devices
SL = severity level, #S = number of reporting sensors, S = status
VSD = virtual security domain, I = inactive, A = active
Cli = client, Chl = channel
                           Detected Wireless Devices
MAC-Address     Type Classification        SL  Last-Time            #S  Chl S
VSD default: 0
VSD vsd_office: 6
 000f-e2a2-2420 AP   Misconfigured         0   2014-06-22/15:52:26  1   149 A
 000f-e233-5500 AP   Misconfigured         0   2014-06-22/15:52:19  1   153 A
 044f-aa03-9fec AP   Potential-External    0   2014-06-22/15:52:19  1   157 A
 0021-632f-f77d Cli  Uncategorized         -   2014-06-22/15:52:29  1   149 A
 0024-012d-ecec Cli  Unassociated          -   2014-07-18/14:29:55  1    -  -
 d4c9-efe4-d3e1 AP   Mesh                  0   2014-07-22/11:38:14  1    161 A
Table 9 Command output
MAC-Address
MAC address of the wireless device.
·     AP
·     Cli: Client.
Classification
Category of the wireless device.
SL
Severity level of the wireless device.
Last-Time
Time when WIPS last detected the AP or client.
#S
Number of sensors that detected the wireless device.
Chl
Channel where the wireless device was detected.
S
AP or client status.
·     Active—Enabled.
·     Inactive—Disabled.
# Display detailed information about all wireless devices in all virtual security domains.
<Sysname> display wlan ips devices verbose
VSD: default
 Total Number of APs: 0
 Total Number of Clients: 0
VSD: vsd_office
 Total Number of APs: 4
BSSID : 000f-e2a2-2420
Vendor: New H3C Technologies Co., Ltd.
 SSID                      : office
 Status                    : Active
 Classification            : Misconfigured
 Severity Level            : 0
 Security                  : WPA2/WPA
 Encrypt Method            : TKIP/CCMP
 Radio Type                : 802.11an
 Channel                   : 149
 In Countermeasure List    : No
 Up Time                   : 2013-06-22/15:43:16
 First Reported Time       : 2013-06-22/15:40:56
 Last Reported Time        : 2013-06-22/15:53:26
 Reporting Sensor          : 1
  Sensor 1                 : ap3
      RadioId              : 1
      RSSI                 : 72
 Attached Clients          : 1
  Client 1                 : 0021-632f-f77d
Detected Attacks          : invalid-oui,
BSSID : 000f-e233-5500
 SSID                      : bignetwork-a
 Status                    : Active
 Severity Level            : 0
 Security                  : Clear
 Encrypt Method            : -NA-
 Authentication Method     : None
 Channel                   : 153
 Up Time                   : 2013-05-09/14:46:57
 First Reported Time       : 2013-06-22/15:38:26
 Last Reported Time        : 2013-06-22/15:53:21
  Sensor 1                 : ap3
      RadioId              : 1
      RSSI                 : 25
 Attached Clients          : 0
Detected Attacks          : -NA-
BSSID : 044f-aa03-9fec
Vendor: Ruckus Wireless
 SSID                      : Ruckus-Wireless-1
 Status                    : Active
 Classification            : Potential-External
 Severity Level            : 0
 Security                  : Clear
 Channel                   : 157
 Up Time                   : 2013-06-13/20:10:13
 First Reported Time       : 2013-06-22/15:38:27
 Last Reported Time        : 2013-06-22/15:53:22
  Sensor 1                 : ap3
      RadioId              : 1
      RSSI                 : 5
      Last Reported Time   : 2013-06-22/15:53:42
BSSID : d4c9-efe4-d3e1
Vendor: Hewlett Packard
 MeshID                    : wsj
 Status                    : Active
 Classification            : Mesh
 Severity Level            : 0
 Security                  : WPA2
 Encrypt Method            : CCMP
 Authentication Method     : Other
 Radio Type                : 802.11ac
 Channel                   : 161
 Up Time                   : 2014-06-22/11:37:29
 First Reported Time       : 2014-06-22/11:37:46
 Last Reported Time        : 2014-06-22/11:38:42
  Sensor 1                 : sensor2
      RadioId              : 1
      RSSI                 : 70
 Attached MeshAPs          : 1
  MeshAP 1            : 000f-e2c0-4440
 Detected Attacks          : wireless-bridge,
 Total Number of Clients: 2
MAC Address: 0021-632f-f77d
Vendor: ASKEY COMPUTER CORP
 Status                    : Active
 State                     : EAPSuccess
 Classification            : Uncategorized
 RadioType                 : 802.11an
 Channel                   : 149
 First Reported Time       : 2013-06-22/15:46:31
 Last Reported Time        : 2013-06-22/15:53:33
  Sensor 1                 : ap3
      RadioId              : 1
      RSSI                 : 66
MAC Address: 0015-af75-3f0f
Vendor: AzureWave Technologies, Inc.
 BSSID                     : -NA-
Status                    : -NA-
 State                     : Unassociation
 Classification            : Unassociated
 RadioType                 : 802.11n
 Channel                   : -NA-
 First Reported Time       : 2013-09-18/14:35:14
 Last Reported Time        : 2013-09-18/14:36:10
  Sensor 1                 : ap0
      RadioId              : 2
      RSSI                 : 18
Table 10 Command output
VSD
Name of the virtual security domain.
Total Number of APs
Number of APs detected in the virtual security domain.
BSSID
Basic SSID.
SSID
SSID with which the client is associated.
MeshID
Mesh ID of the WLAN mesh network.
Hotspot
Whether the SSID is in the hotspot list.
Status
·     Active—Enabled.
Client association state.
·     Association—The client has been associated with the AP.
·     Unassociation—The client is not associated with the AP.
·     EAPSuccess—The client has passed the PSK or 802.1X authentication.
·     EAPLogoff—The client has been logged off.
Classification
Category of the AP or client.
·     AP.
¡     Ad_hoc.
¡     Authorized.
¡     Rogue.
¡     Misconfigured.
¡     External.
¡     Potential-authorized.
¡     Potential-rogue.
¡     Potential-external.
¡     Uncategorized.
¡     Wireless-bridge.
·     Client.
¡     Authorized.
¡     Unauthorized.
¡     Misassociated.
¡     Uncategorized.
¡     Unassociated.
Severity Level
Security
Security type used by the wireless device.
·     Clear.
·     WEP.
·     WPA.
·     WPA2.
Encrypt Method
Data encryption mode.
·     TKIP.
·     CCMP.
·     WEP.
·     -NA-.
Authentication method for the AP.
·     Other—Authentication other than None, PSK, and 802.1X.
RadioType
Radio type of the wireless device.
Channel
Working channel of the wireless device.
Whether the AP or client is in the countermeasures list.
·     Yes.
·     No.
Up Time
First Reported Time
Time when WIPS first detected the AP or client.
Last Reported Time
Reporting Sensor
Sensor n
Name of the sensor that detected the wireless device, where n represents a number automatically assigned by the system.
RadioId
Radio ID detected by the sensor.
RSSI
RSSI of the device.
Attached Clients
Attached MeshAPs
Number of mesh APs that connect to the mesh AP.
Client n
MAC address of the client associated with the AP, where n represents a number automatically assigned by the system.
MeshAP n
MAC address of the mesh AP that connects to the mesh AP, where n represents a number automatically assigned by the system.
MAC Address
MAC address of the client.
Detected Attacks
Attacks detected on the device.
display wlan ips event
Use display wlan ips event to display the specified or all alarm events generated by the WIPS system.
display wlan ips event [ source-mac source-mac | causer-mac causer-mac | id event-id | level event-level | type event-type | vsd vsd-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
2: System level
source-mac source-mac: Specifies the MAC address of the WIPS-enabled device that generates alarm events.
causer-mac source-mac: Specifies the MAC address of the wireless device that causes alarm events.
id event-id: Specifies an event ID in the range of 1 to 1200.
level event-level: Specifies the level for an alarm event in the range of 0 to 7.
type event-type: Specifies the type of an alarm event.
verbose: Displays detailed information for alarm events.
vsd vsd-name: Specifies a virtual security domain by its name.
# Display information about all alarm events.
[Sysname] display wlan ips event
L = Level
 Total Number of Events: 20
                                  WIPS Events
 Causer-Mac     Type              L ID   First-Reported-Time Last-Reported-Time
d4c9-efe4-d3e1 wireless-bridge   4 240  2014-06-20/17:41:24 2014-06-22/11:38:42
000f-e2c0-4440 mesh-ap           4 1125 2014-06-22/11:38:14 2014-06-22/11:38:14
0021-632f-e71d man-in-the-middle 4 234  2014-06-07/18:24:27 2014-06-07/18:24:48
d4c9-efe4-d3e0 deauth-spoofing   2 233  2014-06-07/18:24:21 2014-06-07/18:24:46
0023-895e-0320 honeypot-ap       4 149  2014-06-07/18:15:21 2014-06-07/18:15:21
0021-632f-e71d ht-40MHz-intoler  5 200  2014-06-07/18:19:06 2014-06-07/18:19:06
7425-8a61-1211 ht-greenfield     2 8    2014-03-04/11:10:06 2014-03-05/11:03:55
c4ca-d9f0-8ba0 invalid-channel   4 49   2014-03-28/14:56:27 2014-03-28/14:58:42
0021-632f-e4fb ps-attack         4 575  2013-12-10/14:34:45 2013-12-10/14:34:45
e4b0-2140-9247 soft-ap           4 270  2013-12-10/09:45:16 2013-12-10/09:45:16
5866-ba9f-3680 unencrypt-auth-ap 5 22   2013-11-28/18:11:47 2013-11-29/11:27:52
5866-ba9f-3680 unencry-trust-cli 5 22   2013-11-28/18:11:47 2013-11-29/11:27:52
-NA-           prohibited-chl    2 5    2013-06-22/15:35:30 2013-06-22/15:35:30
 044f-aa03-9fec pt-external-ap    4 4    2013-06-22/15:33:08 2013-06-22/15:33:08
 044f-aa03-9fec vsd-ap-add        5 3    2013-06-22/15:33:08 2013-06-22/15:33:08
 000f-e233-5500 misconfigured-ap  3 2    2013-06-22/15:33:08 2013-06-22/15:33:08
 000f-e233-5500 vsd-ap-add        5 1    2013-06-22/15:33:08 2013-06-22/15:33:08
 0021-632f-e71d windows-bridge    2 67   2013-06-22/14:47:36 2013-06-22/14:47:36
7425-8a61-1200 ap-impersonation  4 52   2013-06-22/14:30:14 2013-06-22/14:36:31
 0079-e65a-e600 hotspot-attack    2 338  2013-06-22/14:27:30 2013-06-22/14:27:30
Table 11 Command output
Causer-MAC
MAC address of the wireless device that causes the alarm events.
Type of the alarm event.
L
Level of the alarm event in the range of 0 to 7.
ID
ID of the alarm event.
First-Reported-Time
Time when the alarm event was first reported.
Last-Reported-Time
Time when the alarm event was last reported.
# Display detailed information for all alarm events generated by WIPS.
<Sysname> display wlan ips event verbose
                                  WIPS Events
ID: 5                     Event Level: 2
Event Type              : prohibited-chl
Reported Time           : 2013-06-22/15:35:30 - 2013-06-22/15:35:30
Aggregate times         : 1
Causer                  : -NA-
Source:
 Source  1              : c4ca-d9f0-e3e0  VSD: default
Detail Information:
 In the VSD default, inhibitory channel 157 is active.
ID: 4                     Event Level: 4
Event Type              : pt-external-ap
Reported Time           : 2013-06-22/15:33:08 - 2013-06-22/15:33:08
Aggregate times         : 1
Causer                  : 044f-aa03-9fec
Source:
 Source  1              : 3822-d6c1-55fd  VSD: -NA-
Detail Information:
 In the VSD default, AP 044f-aa03-9fec is classified as Potential-External AP, w
here severity level is 0.
ID: 3                     Event Level: 5
Event Type              : vsd-ap-add
Aggregate times         : 2
Source:
 Source  2              : 3822-d6c1-55fd  VSD: -NA-
Detail Information:
 In the VSD default,the AP 044f-aa03-9fec is added.
ID: 2                     Event Level: 3
Event Type              : misconfigured-ap
Aggregate times         : 1
Causer                  : 000f-e233-5500
Source:
Detail Information:
 In the VSD default, AP 000f-e233-5500 is classified as Misconfigured AP.
ID: 1                     Event Level: 5
Aggregate times         : 2
Source:
Detail Information:
 In the VSD default,the AP 000f-e233-5500 is added.
ID: 342                   Event Level: 2
Event Type              : hotspot-attack
Reported Time           : 2013-10-16/14:27:50 - 2013-10-16/14:27:50
Aggregate times         : 1
Causer                  : 000f-e27b-4580
Source:
 Source  1              : 3822-d6c1-55ff  VSD: -NA-
Detail Information:
 In the VSD han, detect AP(BSSID:000f-e27b-4580) using hotspot H3C.
ID: 354                   Event Level: 2
Reported Time           : 2013-10-16/14:27:48 - 2013-10-16/14:27:48
Aggregate times         : 1
Causer                  : 5866-ba9f-3680
Source:
Detail Information:
 In the VSD han, detect the client(MAC:0021-6330-0f04) connecting to AP(BSSID:
5866-ba9f-3680) using hotspot xlan.
ID: 67                    Event Level: 2
Event Type              : windows-bridge
Reported Time           : 2013-11-15/08:47:36 - 2013-11-15/08:47:36
Aggregate times         : 1
Causer                  : 0021-632f-e71d
Source:
 Source  1              : 00a9-a755-fd00  VSD: 1
Detail Information:
  In the VSD 1,detect the client(MAC:7425-8a61-1202), which connects to AP (BSSID:0021-632f-e71d), in a windows network bridge.                            --------------------------------------------------------------------------------
ID: 22                    Event Level: 5
Event Type              : unencrypt-auth-ap
Reported Time           : 2013-11-28/18:11:47 - 2013-11-29/11:27:52
Aggregate times         : 63
Source:
 Source  1              : 80f6-2ee6-d3da  VSD: -NA-
Detail Information:
 In the vsd default, detect an unencrypted authorized AP 5866-ba9f-3680.
ID: 535                   Event Level: 5
Event Type              : unencrypted-trust-client
Reported Time           : 2013-11-29/10:00:00 - 2013-11-29/11:18:25
Aggregate times         : 4
Causer                  : ccef-48f4-7850
Source:
Detail Information:
 In the vsd default, detect a trust client 0021-6330-0f04 connect to an unencrypted AP ccef-48f4-7850.
ID: 52                    Event Level: 4
Event Type              : ap-impersonation
Reported Time           : 2013-12-05/14:12:14 - 2013-12-05/17:06:31
Aggregate times         : 670
Causer                  : 7425-8a61-1200
Source:
 Source  1              : 00a9-a75b-5100  VSD: 1
Detail Information:
 In the vsd 1, detect AP impersonation of BSSID 7425-8a61-1200.
ID: 270                   Event Level: 4
Event Type              : soft-ap
Reported Time           : 2013-12-10/09:45:16 - 2013-12-10/09:45:16
Aggregate times         : 1
Causer                  : e4b0-2140-9247
Source:
 Source  1              : e4b0-2140-9247
Detail Information:
 In the VSD 1, detect soft ap e4b0-2140-9247.
ID: 575                   Event Level: 4
Event Type              : ps-attack
Reported Time           : 2013-12-10/14:34:45 - 2013-12-10/14:34:45
Aggregate times         : 1
Causer                  : 0021-632f-e4fb
Source:
 Source  1              : 00a9-a69b-4c00  VSD: 1
Detail Information:
 In the VSD 1, detect power save attack to client 0021-632f-e4fb.
ID: 8                     Event Level: 2
Event Type              : ht-greenfield
Aggregate times         : 1008
Causer                  : 7425-8a61-1211
Source:
 Source  1              : 3ce5-a68b-9020  VSD: vsd2
Detail Information:
 In the vsd vsd2, detect an active HT-greenfield mode AP(BSSID:7425-8a61-1211).
ID: 49                    Event Level: 4
Event Type              : invalid-channel
Aggregate times         : 3
Causer                  : c4ca-d9f0-8ba0
Source:
 Source  1              : 80f6-2e02-f880
 Source  2              : 5866-abc0-4620  VSD: default
Detail Information:
 In the VSD default, detect the device c4ca-d9f0-8ba0 launching a malformed pack
et with type of invalid-channel.
ID: 200                   Event Level: 5
Event Type              : ht-40MHz-intoler
Reported Time           : 2014-06-07/18:19:06 - 2014-06-07/18:20:04
Aggregate times         : 2
Source:
 Source  1              : cc3e-5f26-0e00  VSD: 2
Detail Information:
 In the vsd 2, detect a client(MAC:0021-632f-e71d) setting 40MHz intolerance and
 connecting with AP(BSSID:0023-895e-0320).
ID: 149                   Event Level: 4
Event Type              : honeypot-ap
Reported Time           : 2014-06-07/18:15:21 - 2014-06-07/18:15:21
Aggregate times         : 1
Causer                  : 0023-895e-0320
Source:
 Source  1              : 5866-babe-d0a4  VSD: -NA-
Detail Information:
 In the VSD 2, detect honeypot ap 0023-895e-0320.
ID: 233                   Event Level: 2
Event Type              : deauth-spoofing
Reported Time           : 2014-06-07/18:24:21 - 2014-06-07/18:24:46
Aggregate times         : 3
Causer                  : d4c9-efe4-d3e0
Source:
Detail Information:
 In the vsd 2, detect a spoof deauthentication frame from AP(BSSID:d4c9-efe4-d3e
0) to CLIENT(MAC:0021-632f-e71d).
ID: 234                   Event Level: 4
Event Type              : man-in-the-middle
Reported Time           : 2014-06-07/18:24:27 - 2014-06-07/18:24:48
Aggregate times         : 2
Source:
Detail Information:
 In the VSD 2,  detect the client(mac:0021-632f-e71d) that connects to the honey
pot AP(BSSID:0023-895e-0330, SSID:"H3C", AuthSSID:"H3C") attacked by the man-in-
the-middle attack.
ID: 240                   Event Level: 4
Event Type              : wireless-bridge
Reported Time           : 2014-06-20/17:41:24 - 2014-06-22/11:38:42
Aggregate times         : 33
Causer                  : d4c9-efe4-d3e1
Source:
Detail Information:
  In the VSD 2, detect an AP(MAC:d4c9-efe4-d3e1), which connects with another AP
(MAC:000f-e2c0-4440), in a wireless-bridge.
Table 12 Command output
Total number of alarm events.
ID
Event Level
Event Type
Reported Time
Time when WIPS first and last reported the alarm event.
Aggregate times
Number of times that alarm events are aggregated.
Causer
MAC address of the wireless device that causes the alarm event.
Source
MAC address of the WIPS-enabled device that generated the alarm event.
VSD
Name of the virtual security domain to which the WIPS-enabled device belongs.
Detail Information
Detailed information for the alarm event.
display wlan ips hotspotlist
Use display wlan ips hotspotlist to display information about the hotspots in the WIPS system.
display wlan ips hotspotlist [ | { begin | exclude | include } regular-expression ]
2: System level
# Display information about the hotspots in the WIPS system.
[Sysname] display wlan ips hotspotlist
Total Number of Entries:      8
                            Hotspot List
SSID                                                          Last-Reported-Time
ANY        --
H3C                                                           2013-12-16/10:46:55
any        --
hello                                                              --
lwq                                                           2013-12-16/10:46:47
wlan                                                               --
wsj        --
y06066                                                        2013-12-16/10:46:52
Table 13 Command output
Number of hotspots in the WIPS system.
SSID
SSID of the hotspot.
Last-Reported-Time
Time when the hotspot is detected most recently.
display wlan ips ignorelist
Use display wlan ips ignorelist to display a specific device or all devices in the alarm-ignored device list.
display wlan ips ignorelist [ mac-address mac-addr ] [ | { begin | exclude | include } regular-expression ]
2: System level
mac-address mac-addr: Specifies the MAC address of the wireless device for which WIPS alarming information can be ignored.
# Display information about all wireless devices for which WIPS alarming information can be ignored.
[sysname] display wlan ips ignorelist
Ignore List
MAC-Address      Hit-Count   First-Reported-Time  Last-Reported-Time
0001-0002-0003         100   2011-04-08/09:17:25  2011-04-11/09:15:11
0001-0002-0004        2098   2011-04-05/19:35:50  2011-04-11/08:35:26
Table 14 Command output
MAC-Address
MAC address of the device in the list.
Hit-Count
Number of times that the entry in the list was hit.
First-Reported-Time
Time when the first alarm event was generated for the device.
Last-Reported-Time
Time when the last alarm event was generated for the device.
display wlan ips malformed-detect-policy
Use display wlan ips malformed-detect-policy to display information about the specified or all malformed packet detection policies.
display wlan ips malformed-detect-policy [ policy-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
policy-name: Specifies a malformed packet detection policy by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines, but not spaces.
# Display information about the malformed packet detection policy named lab.
[Sysname]display wlan ips malformed-detect-policy
Malformed Detect Policies
Detection-Type           Status  Quiet-Time   Action      Threshold
invalid-ie-length         off       600          --            --
duplicated-ie             off       600          --            --
redundant-ie              off       600          --            --
invalid-pkt-length        off       600          --            --
illegal-ibss-ess          off       600          --            --
invalid-source-address    off       600          --            --
overflow-eapol-key        off       600          --            --
malformed-auth            off       600          --            --
malformed-assoc-req       off       600         --            --
malformed-ht-ie           off       600         --            --
large-duration            off       600         --            5000
null-probe-resp           off       600         --            --
invalid-deauth-code       off       600         --            --
invalid-disassoc-code     off       600         --            --
overflow-ssid             off       600         --            --
fata-jack                 off       600         --            --
Policy Name: mf2
invalid-ie-length         on         5          log|trap     --
duplicated-ie             on         5          log|trap     --
redundant-ie              on         5          log|trap     --
invalid-packet-length     off        5           --          --
illegal-ibss-ess          on         5          log|trap     --
invalid-source-address    on         5          log|trap     --
overflow-eapol-key        on         5          log|trap     --
malformed-auth            on         5          log|trap     --
malformed-assoc-req       on         5          log|trap     --
malformed-ht-ie           on         5          log|trap     --
large-duration            on         5          log|trap     200
null-probe-resp           on         5          log|trap     --
invalid-deauth-code       on         5          log|trap     --
invalid-disassoc-code     on         5          log|trap     --
overflow-ssid             on         5          log|trap     --
fata-jack                 on         5          log|trap     --
 Applied To VSD : han
Table 15 Command output
Policy Name
Name of the malformed packet detection policy.
Detection-Type
Type of the malformed packet detection policy: invalid-ie-length, duplicated-ie, redundant-ie, invalid-pkt-length, illegal-ibss-ess, invalid-source-address, overflow-eapol-key, malformed-auth, malformed-assoc-req, malformed-ht-ie, large-duration, null-probe-resp, invalid-deauth-code, invalid-disassoc-code, overflow-ssid, or fata-jack.
Status
Status of the log and alarm functions:
·     on—The log and alarm functions are enabled.
·     off—The log and alarm functions are disabled.
Quiet-Time
Quiet time before alarming the next malformed packet.
Action
Action to take when the sensor detects a malformed packet: send a log or alarm to the AC.
Threshold
Duration threshold.
Applied To VSD
Virtual security domain using the malformed packet detection policy.
display wlan ips network
Use display wlan ips network to display information about wireless services in the specified or all virtual security domains.
display wlan ips [ vsd vsd-name ] network bss [ verbose ] [ name network-name | hotspot ] [ | { begin | exclude | include } regular-expression ]
display wlan ips [ vsd vsd-name ] network [ mesh ] [ verbose ] [ name network-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
network: Displays information about the detected wireless service.
bss: Displays information about a WLAN ESS or IBSS network.
mesh: Displays information about a WLAN mesh network.
verbose: Displays detailed information about a wireless service.
name network-name: Specifies a WLAN ESS, IBSS, or mesh network by its name, a case-sensitive string of 1 to 32 characters that can contain spaces.
hotspot: Displays information about a hotspot in the hotspot list.
# Display information about the wireless services in all virtual security domains.
<Sysname> display wlan ips network
#AP = number of APs, VSD = virtual security domain
                           Detected Wireless Networks
  SSID                            Security       Auth-Method Encrypt-Method #AP
VSD default: 0
VSD vsd_office: 3
 office                           WPA2/WPA       PSK         TKIP/CCMP      1
 Ruckus-Wireless-1                Clear          None        -NA-           1
 bignetwork-a                     Clear          None        -NA-           1
  MeshID                          Security       Auth-Method Encrypt-Method #AP
VSD default: 0
VSD vsd_office: 2
                                  Clear          None        -NA-           1
 wsj                              WPA2           Other       CCMP           1
# Display information about all hotspots in the hotspot list in virtual security domain default.
[Sysname] display wlan ips vsd default network bss hotspot
VSD default: 16
 h3c-zc                           Clear          None        -NA-           1
 CMCC                             Clear          None        -NA-           16
 lkf3994                          Clear          None        -NA-           1
 n1006                            WPA2           PSK         CCMP           1
 AndroidAP                        WPA2           PSK         CCMP           1
 lwq                              Clear          None        -NA-           1
Table 16 Command output
SSID
SSID of the wireless service.
MeshID
Mesh ID of the WLAN mesh service.
Security
·     Clear.
·     WEP.
·     WPA.
·     WPA2.
Auth-Method
Authentication method.
Encrypt-Method
·     TKIP.
·     CCMP.
·     WEP.
#AP
Number of APs that use the SSID.
# Display detailed information about the wireless services in all virtual security domains.
[Sysname] display wlan ips network verbose
VSD: default
 Total number of bss-networks: 0
VSD: vsd_office
 Total number of bss-networks: 3
SSID: office
 Hotspot                    : No
 Status                     : Active
 Security                   : WPA2/WPA
 First Reported Time        : 2013-06-22/15:43:18
 Last Reported Time         : 2013-06-22/15:43:38
 APs                        : 1
  BSSID  1    : 000f-e2a2-2420  Channel: 149  Clients: 0    SSID Hide: No
SSID: Ruckus-Wireless-1
 Hotspot                    : No
 Status                     : Active
 Security                   : Clear
 Last Reported Time         : 2013-06-22/15:43:44
 APs                        : 1
  BSSID  1    : 044f-aa03-9fec  Channel: 157  Clients: 0    SSID Hide: No
SSID: bignetwork-a
 Hotspot                    : Yes
 Status                     : Active
 Security                   : Clear
 Last Reported Time         : 2013-06-22/15:43:31
 APs                        : 1
  BSSID  1    : 000f-e233-5500  Channel: 153  Clients: 0    SSID Hide: No
VSD: default
 Total number of mesh-networks: 0
VSD: vsd_office
 Total number of mesh-networks: 2
 MeshID:
 Status                     : Active
 Security                   : Clear
 First Reported Time        : 2014-06-22/11:38:14
 Last Reported Time         : 2014-06-22/11:38:14
 APs                        : 1
  BSSID  1    : 000f-e2c0-4440    Channel: 161   Attached MeshAPs: 1
 MeshID: wsj
 Status                     : Active
 Security                   : WPA2
 Last Reported Time         : 2014-06-22/11:37:46
 APs                        : 1
  BSSID  1    : d4c9-efe4-d3e1    Channel: 161   Attached MeshAPs: 1
Table 17 Command output
VSD
Total number of networks
Total number of wireless services detected in the virtual security domain.
SSID
MeshID
Hotspot
Status
SSID status.
·     Active—Enabled.
Security
·     Clear.
·     WEP.
·     WPA.
·     WPA2.
Encrypt Method
·     TKIP.
·     CCMP.
·     WEP.
First Reported Time
Time when WIPS first detected the SSID.
Last Reported Time
Time when WIPS last detected the SSID.
APs
BSSID n
BSSID, where n represents a number automatically assigned by the system.
Channel
Channel used by the BSSID.
Clients
Number of clients associated with the BSSID.
Attached MeshAPs
SSID Hide
Whether the SSID is hidden.
·     Yes.
·     No.
display wlan ips oui
Use display wlan ips oui to display all OUI information for the specified vendor in the OUI library of WIPS.
display wlan ips oui vendor-name
2: System level
vendor-name: Specifies a vendor by its name, a case-insensitive string of 1 to 64 characters.
# Display all OUI information for the vendor H3C in the OUI library of WIPS.
[Sysname]display wlan ips oui h3c
                              Vendor OUI List
OUI           Vendor
00-0F-E2      New H3C Technologies Co., Ltd.
00-23-89      New H3C Technologies Co., Ltd.
0C-DA-41      New H3C Technologies Co., Limited
38-22-D6      New H3C Technologies Co., Limited
3C-E5-A6      New H3C Technologies Co., Ltd.
58-66-BA      New H3C Technologies Co., Limited
80-F6-2E      New H3C Technologies Co., Limited
C4-CA-D9      New H3C Technologies Co., Limited
Table 18 Command output
Vendor
Device vendor. If the OUI corresponding to the vendor is not in the OUI library of WIPS, this field displays –NA-.
display wlan ips sensor
Use display wlan ips sensor to display sensors in a specified or all virtual security domains.
display wlan ips sensor [ vsd vsd-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
# Display sensors in all virtual security domains.
[Sysname] display wlan ips sensor
Total Number of Sensors:  5
 wips = dedicated wips mode,              hyb-l = low scan-time in hybrid mode,
 hyb-m = medium scan-time in hybrid mode, hyb-h = high scan-time in hybrid mode,
 S = state,                               R = run,
 I = idle
                                   Sensor List
Sensor-Name                   Radio  Mode   S  --------------------------------------------------------------------------------
VSD: office
 office_ap1                       1  wips   R
 office_ap2                       2  hyb-l  R
 office_ap3                       2  hyb-m  R
VSD: lab
lab_ap1                          1  hyb-h  R
lab_ap2                          1  hyb-l  I
Table 19 Command output
Total number of configured sensors.
Sensor-Name
Name of the AP that is configured as a sensor.
Radio
ID of the radio that is configured as a sensor.
Mode
WIPS operation mode.
·     wips—Monitor mode.
·     hyb-l—Access first hybrid mode, short scanning duration.
·     hyb-m—Balanced hybrid mode, middle scanning duration.
·     hyb-h—Scanning first hybrid mode, long scanning duration.
S
Running status of the sensor.
·     R—The AP has been connected to the AC and WIPS is running on the AP.
·     I—The AP is not connected to the AC or WIPS is not running due to limitation of licenses on the AP.
VSD
Name of the virtual security domain to which the sensor belongs.
display wlan ips signature
Use display wlan ips signature to display information about the specified or all signatures.
display wlan ips signature { all | custom | signature-id id-value | signature-name name-string | standard } [ verbose ] [ | { begin | exclude | include } regular-expression ]
2: System level
custom: Specifies all user-defined signatures.
all: Specifies all signatures.
signature-name name-string: Specifies a signature by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
signature-id id-value: Specifies a signature by its rule ID.
standard: Specifies all system-defined signatures.
verbose: Displays detailed signature information.
Sub-rule information is not displayed for a system-defined signature.
# Display information about all system-defined signatures.
[Sysname] display wlan ips signature standard
Total Number of Entries:11
           Standard Signature Information
ID   SignatureName                      Type
1    deauth_flood                       Standard
2    broadcast_deauth_flood             Standard
3    disassoc_flood                     Standard
4    broadcast_disassoc_flood           Standard
5    eapol_logoff_flood                 Standard
6    eap_success_flood                  Standard
7    eap_failure_flood                  Standard
8    pspoll_flood                       Standard
9    cts_flood                          Standard
10   rts_flood                          Standard
11   addba_req_flood                    Standard
# Display information about all user-defined signatures.
[sysname] display wlan ips signature custom
             Custom Signature Information
40   office                             Custom
# Display information about all signatures.
[Sysname] display wlan ips signature all
Total Number of Entries: 12
40   office                             Custom
Table 20 Command output
ID
Signature ID. 1 to 32 represent system-defined signatures, and 33 to 64 represent user-defined signatures.
SignatureName
Signature name.
Signature type.
·     Standard—System-defined signature.
·     Custom—User-defined signature.
# Display detailed information about the signature cts_flood.
[sysname] display wlan ips signature signature-name cts_flood verbose
Signature Name      :    cts_flood
Signature ID        :    9
Signature Type      :    Standard
Track Method        :    per-signature
Detect Threshold    :
    per-signature   :    5000 pkts/period
    per-mac         :    -NA-
Detect Period       :    5 s
Action              :    report
Event Level         :    2
Quiet Time          :    900 s
Applied on Signature Policy
    Signature Policy 1    : office
              Precedence :1
# Display detailed information about the signature with the ID 40.
[sysname] display wlan ips signature signature-id 40 verbose
Signature Name      :    office
Signature ID        :    40
Signature Type      :    Custom
Track Method        :    per-signature and per-mac
Detect Threshold   :
    per-signature   :    1000 pkts/period
    per-mac         :    1000 pkts/period
Detect Period       :    60 s
Action              :    none
Event Level         :    -NA-
Quiet Time          :    900 s
Sub Rule            :    7
Match               :    Any
Frame Type          :    management
Frame Subtype       :    association-request
MAC                 :
    Source Mac      :    ffff-ffff-ffff
    Dest Mac        :    -NA-
    Bssid           :    -NA-
Seq Number          :    > 100
SSID Length         :    15 - 20
SSID                :    not include "H3C"
SSID Match Case     :    exact
Pattern             :    2
    Pattern Name                   Offset Mask    Match           FromPayload
    pattern1                         8      0xabcd > 0x9               Yes
    pattern2                         8      0xffff 0x15   - 0x20       No
Applied on Signature Policy : -NA-
Table 21 Command output
Signature Name
Signature name.
Signature ID
Signature Type
Signature type.
Track Method
Tracking method for the signature.
·     per-mac.
·     per-signature.
·     both: Uses both methods.
Detect Threshold
Maximum matching times for the signature.
·     per-mac—Maximum matching times for a signature when the track-method in the signature is configured as per-mac. The value is in the range of 1 to 32000 times. By default, the maximum matching times for a user-defined signature is 1000 and that for a system-defined signature depends on the specific system-defined signature.
·     per-signature—Maximum matching times for a signature when the track-method in the signature is configured as per-signature. The value is in the range of 1 to 32000 times. By default, the maximum matching times for a user-defined signature is 1000 and that for a system-defined signature depends on the specific system-defined signature.
Detect Period
Statistics collection period for a signature in the range of 1 to 3600 seconds. By default, the statistics collection period for a user-defined signature is 60 seconds and that for a system-defined signature depends on the specific system-defined signature.
Action
Action that WIPS takes when the number of matching times for a signature reaches the configured threshold within the statistics collection period.
·     ReportWIPS generates corresponding signature alarms when the number of matching times for a signature reaches the threshold within the specified statistics collection period.
·     NoneWIPS does not take any action when the number of matching times for a signature reaches the threshold within the specified statistics collection period.
Event Level
Alarm level for a signature in the range of 0 to 7. A smaller value represents a higher alarm level.
Quiet Time
Quiet time for a signature in the range of 60 to 32000, in seconds. By default, the quiet time for a user-defined signature is 900 seconds and that for a system-defined signature depends on the specific system-defined signature.
Sub Rule
Number of subsignatures.
Match
Match rule.
·     Any.
·     All.
Frame Type
Frame type.
·     data—Data frames.
·     management—Management frames.
·     control—Control frames.
Frame Subtype
Sub type of a management frame.
·     Association Request.
·     Association Response.
·     Authentication.
·     Beacon.
·     Deauthentication.
·     Disassociation.
·     Probe Request.
MAC
Matches MAC addresses of a specified type.
·     Source Mac.
·     Dest Mac.
·     Bssid.
Seq Number
Packet sequence number.
SSID Length
SSID length.
SSID
Match mode for the SSID.
·     Include—Includes the configured character string.
·     not equalNot equal to the configured characters string.
SSID Match Case
SSID Length
SSID length.
·     number1 – number2: The value range is number1 (inclusive) to number2 (inclusive).
·     =: Equal to the configured length.
·     >: Greater than the configured length.
·     <: Smaller than the configured length.
Seq Number
Sequence number of wireless packets.
Pattern
Pattern match mode.
·     OffsetMatches frames from the specified starting bit in the range of 0 to 2346.
·     MaskMatches frames with a specified mask.
·     Match—Match mode.
·     From Payload—Matches frames starting from the frame body.
Signature policy list.
display wlan ips signature-policy
Use display wlan ips signature-policy to display information about the specified or all signature policies.
display wlan ips signature-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
2: System level
policy-name: Specifies a signature policy by its name.
all: Specifies all signature policies.
# Display information about the signature policy office.
[sysname] display wlan ips signature-policy policy default
        Signature Policy Information
Signature Policy Name   : default
Applied on VSD          :
    VSD 0               : default
Include Signature Num   : 11
    ID   SignatureName                      Type      Precedence
    36   test                               Custom       60
    10   rts_flood                          Standard     20
    1    deauth_flood                       Standard      1
    2    broadcast_deauth_flood             Standard      1
    3    disassoc_flood                     Standard      1
    4    broadcast_disassoc_flood           Standard      1
    5    eapol_logoff_flood                 Standard      1
    6    eap_success_flood                  Standard      1
    7    eap_failure_flood                  Standard      1
    8    pspoll_flood                       Standard      1
    9    cts_flood                          Standard      1
Table 22 Command output
Signature policy name.
VSD
Virtual security domain.
Number of signatures.
ID
Signature Name
Name of the signature bound to the signature policy.
Signature type.
Precedence
Signature precedence in the range of 1 to 64. A greater value represents a higher precedence.
display wlan ips static-trustoui
Use display wlan ips static-trustoui to display information about the specified OUI or all OUIs in the static trusted OUI list.
display wlan ips static-trustoui [ oui-info | vendor ]
Information about all OUIs and vendors in the static trusted OUI list is displayed.
2: System level
oui-info: Specifies an OUI, a case-insensitive string of hexadecimal characters in the format XXXXXX.
vendor: Specifies all vendors in the static trusted OUI list.
# Display information about OUI 58-66-BA in the static trusted OUI list.
[Sysname] display wlan ips static-trustoui 5866ba
                               Trust OUI List
OUI           Vendor
58-66-ba      New H3C Technologies Co., Limited
# Display information about all vendors in the static trusted OUI list.
[Sysname]display wlan ips static-trustoui vendor
                        Trust OUI Vendor List
Vendor
h3c
# Display information about all entries in the static trusted OUI list.
                               Trust OUI List
Total Number of Entries: 5
OUI           Vendor
00-00-09      XEROX CORPORATION
80-f6-2e      New H3C Technologies Co., Limited
c4-ca-d9      New H3C Technologies Co., Limited
ff-ff-ff      -NA-
Vendor: 1
h3c
Table 23 Command output
Total number of entries in the current static trusted OUI list.
Vendor
Device vendor. If the OUI corresponding to the vendor is not in the OUI library of WIPS, the field displays -NA-.
display wlan ips statistics
Use display wlan ips statistics to display frame statistics about a device or channel.
display wlan ips statistics { sensor sensor-name } { device [ mac-address mac-address ] | channel [ channel-num ] } { total | recent } [ | { begin | exclude | include } regular-expression ]
2: System level
sensor sensor-name: Specifies a sensor by its name.
device: Displays frame statistics by wireless device.
mac-address mac-address: Specifies a MAC address.
channel: Displays frame statistics about a channel. If you do not specify the channel-num argument, frame statistics about all channels are displayed.
total: Displays all frame statistics.
recent: Displays frame statistics within the last statistics collection period.
# Display total frame statistics about the wireless device with the MAC address 00fc-4a38-4fc5 detected by sensor office_ap1.
[Sysname] display wlan ips statistics sensor office_ap1 device mac-address 00fc-4a38-4fc5
 total
 Sensor: office_ap1
                           WIPS Device Total Statistics
Device: 00fc-4a38-4fc5                      Channel:149
 Transmitted Frames Statistics:
  Total (Frames/Bytes)                : 646/158163
  Unicast (Frames/Bytes)              : 118/26578
  Broadcast/Multicast (Frames/Bytes)  : 528/131585
  Management   : 610                   Control            : 0
  Data         : 36                    Fragment           : 0
  Retry        : 35                    Beacon             : 514
  Probe Req    : 0                     Authentication     : 0
  Probe Resp   : 96                    Unicast Deauth     : 0
  Assoc req    : 0                     Broadcast Deauth   : 0
  Assoc Resp   : 0                     Unicast Disassoc   : 0
  RTS          : 0                     Broadcast Disassoc : 0
  EAPOL Start  : 0                     EAP Success        : 0
  EAPOL Logoff : 0                     EAP Failure        : 0
  Abnormal     : 0
 Received Frames Statistics:
  Total (Frames/Bytes)                : 12/1862
  Unicast (Frames/Bytes)              : 12/1862
  Management   : 0                     Control            : 0
  Data         : 12                    Fragment           : 0
  Retry        : 8                     Authentication     : 0
  Probe req    : 0                     Probe resp         : 0
  Assoc req    : 0                     Assoc resp         : 0
  Disassoc     : 0                     Deauth             : 0
  RTS          : 0                     CTS                : 0
  EAPOL start  : 0                     EAP success        : 0
  EAPOL logoff : 0                     EAP Failure        : 0
  Abnormal     : 0
Device: 00fc-4a38-4fc5                      Channel:153
  Total (Frames/Bytes)                : 1/106
  Unicast (Frames/Bytes)              : 1/106
  Broadcast/Multicast (Frames/Bytes)  : 0/0
  Data         : 1                     Fragment           : 0
  Retry        : 1                     Beacon             : 0
  Probe Resp   : 0                     Unicast Deauth     : 0
  Abnormal     : 0
  Total (Frames/Bytes)                : 21/2875
  Unicast (Frames/Bytes)              : 21/2875
  Management   : 0                     Control            : 1
  Data         : 20                    Fragment           : 0
  Retry        : 12                    Authentication     : 0
  RTS          : 0                     CTS                : 0
  Abnormal     : 0
# Display frame statistics about channel 149 detected by sensor ap3 within the last statistics collection period.
[Sysname] display wlan ips statistics sensor ap3 channel 149 recent
 Sensor: ap3
                         WIPS Channel Recent Statistics
Channel: 149
 Total (Frames/Bytes)               : 293/49008
 Unicast (Frames/Bytes)             : 114/11866
 Broadcast/Multicast (Frames/Bytes) : 179/37142
  Management   : 185                   Control            : 0
  Data         : 108                   Abnormal           : 0
  Fragment     : 0                     Retry              : 56
  Beacon       : 115                   RTS                : 0
  CTS          : 0                     Authentication     : 0
  Probe Resp   : 19                    Unicast Disassoc   : 0
  Probe Req    : 51                    Broadcast Disassoc : 0
  Assoc Resp   : 0                     Unicast Deauth     : 0
Table 24 Command output
Sensor
Name of the sensor.
Device
Channel
Channel number.
Total(Frames/Bytes)
Total number of frames/bytes.
Total number of unicast frames/bytes.
Broadcast/Multicast(Frames/Bytes)
Total number of broadcast/multicast frames/bytes.
Management
Total number of management frames.
Control
Total number of control frames.
Data
Total number of data frames.
Fragment
Total number of fragments.
Retry
Total number of retransmission frames.
Beacon
Total number of Beacon frames.
Probe Req
Total number of probe requests.
Authentication
Total number of authentication frames.
Probe Resp
Total number of probe responses.
Unicast Deauth
Total number of unicast deauthentication frames.
Assoc Req
Total number of association requests.
Broadcast Deauth
Total number of broadcast deauthentication frames.
Assoc Resp
Total number of association responses.
Unicast Disassoc
Total number of unicast diassociation frames.
RTS
Total number of RTS frames.
Broadcast Disassoc
Total number of broadcast diassociation frames.
Disassoc
Total number of diassociation frames.
Deauth
Total number of deauthentication frames.
CTS
Total number of CTS frames.
EAPOL Start
Total number of EAPOL Start packets.
EAP Success
Total number of EAP Success packets.
EAPOL Logoff
Total number of EAPOL Logoff packets.
EAP Failure
Total number of EAP Failure packets.
Abnormal
Total number of abnormal packets.
Use display wlan ips statistics sensor to display the malformed packet statistics about a specified sensor.
display wlan ips statistics sensor sensor-name malformed-counter
2: System level
sensor-name: Specifies a sensor by its name, a case-insensitive string of 1 to 64 characters.
# Display the malformed packet statistics about sensor 1.
[Sysname] display wlan ips statistics sensor sensor1 malformed-counter
Sensor name:  sensor1
In the VSD: VSD1
Malformation-Specify             Count
invalid-ie-length            :  15564
duplicated-ie                :  44
redundant-ie                 :  899
invalid-pkt-length           :  870
illegal-ibss-ess             :  0
invalid-source-address       :  0
overflow-eapol-key           :  0
malformed-auth               :  12
malformed-assoc-req          :  15
malformed-ht-ie              :  0
large-duration               :  0
null-probe-resp              :  0
invalid-deauth-code          :  0
invalid-disassoc-code        :  0
overflow-ssid                :  1450
fata-jack                    :  1866
Table 25 Command output
Sensor name
Name of the sensor.
In the VSD
Count
Count of malformed packets of all types.
display wlan ips summary
Use display wlan ips summary to display the WIPS status of the current system or the specified virtual security domain.
display wlan ips summary [ vsd vsd-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
# Display the current WIPS status of the system.
[Sysname] display wlan ips summary
WIPS is enabled
WIPS's Running Time: 0 Days, 4 Hours, 9 Minutes
Max Sensor Number               : 128
Used Sensor Number              : 1
Blocklist-Action Block          : Enable
Block-list Entry Number         : 2
Trust-list Entry Number         : 2
Hotspot-list Entry Number       : 4
Countermeasure-list Entry Number: 3
Ignore-list Entry Number        : 1
Trust OUI Entry Number          : 5
Trust Vendor-OUI Entry Number   : 2
Ados State                      : Disable
Total Number of Signatures      : 11
  Standard Signature            : 10
  Custom Signature              : 1
Timer:
  Inactivity Timer of AP        : 300s
  Inactivity Timer of Client    : 600s
  Aging Timer of AP and Client  : 86400s
  Statistic Period              : 103s
  Reclassification Period       : 800s
Dynamic Trustlist Aging Period: 300s
  Update Timer of Device        : 20s
Total Number of Events: 214
  Level-0: 0       Level-1: 4       Level-2: 14      Level-3: 0
  Level-4: 70      Level-5: 126     Level-6: 0       Level-7: 0
Virtual Security Domain Name    : default
Configured Sensor Number        : 1
Running Sensor Number           : 0
Detection Information:
  Detected Network Number       : 0
    AP: 0
      Authorized                : 0
      Mis-Configured            : 0
      Rogue                     : 0
      External                  : 0
      Ad-hoc                    : 0
      Potential-Authorized      : 0
      Potential-Rogue           : 0
      Potential-External        : 0
      Uncategorized             : 0
    STA: 0
      Authorized                : 0
      Rogue                     : 0
      Mis-Association           : 0
      Uncategorized             : 0
      Unassociated              : 0
Total Number of Events: 39
Virtual Security Domain Name    : vsd_lab
Configured Sensor Number        : 2
Running Sensor Number           : 1
  Detected Network Number       : 25
    AP: 33
      Authorized                : 0
      Mis-Configured            : 0
      Rogue                     : 2
      External                  : 2
      Ad-hoc                    : 0
      Potential-Rogue           : 0
      Potential-External        : 29
      Uncategorized             : 0
    STA: 1
      Authorized                : 0
      Rogue                     : 0
      Mis-Association           : 0
      Uncategorized             : 1
      Unassociated              : 0
Total Number of Events: 60
Virtual Security Domain Name    : vsd_office
Configured Sensor Number        : 0
    AP: 0
      Authorized                : 0
      Mis-Configured            : 0
      Rogue                     : 0
      External                  : 0
      Ad-hoc                    : 0
      Potential-Rogue           : 0
      Uncategorized             : 0
    STA: 0
      Authorized                : 0
      Rogue                     : 0
      Mis-Association           : 0
      Uncategorized             : 0
      Unassociated              : 0
Total Number of Events: 0
Table 26 Command output
Max Sensor Number
Maximum number of supported sensors. The value depends on the number of licenses installed on the device.
Used Sensor Number
Number of sensors in use.
Whether to enable or disable the device in the prohibited device list from accessing the WLAN.
·     Enable.
·     Disable.
Number of entries in the prohibited device list.
Number of entries in the permitted device list.
Number of entries in the countermeasures list.
Number of entries in the alarm-ignored device list.
Ados State
ADoS status.
·     Enabled.
·     Disabled.
Standard Signature
Number of system-defined signatures.
Custom Signature
Number of user-defined signatures.
Timer
Global timer.
Maximum idle time for an AP.
Maximum idle time for a client.
Aging time for inactive APs or clients.
Statistic Period
Packet statistics collection period.
Time for WIPS to reclassify wireless devices.
Total number of alarm events in the system or in the specified virtual security domain.
Level-0
Number of level 0 alarm events.
Level-1
Number of level 1 alarm events.
Level-2
Number of level 2 alarm events.
Level-3
Number of level 3 alarm events.
Level-4
Number of level 4 alarm events.
Level-5
Number of level 5 alarm events.
Level-6
Number of level 6 alarm events.
Level-7
Number of level 7 alarm events.
Number of sensors configured for the virtual security domain.
Number of sensors running in the virtual security domain.
Number of wireless services detected in the virtual security domain.
AP
Authorized
Number of authorized APs detected in the virtual security domain.
Mis-Configured
Number of misconfigured APs detected in the virtual security domain.
Rogue
Number of rogue APs detected in the virtual security domain.
External
Number of external APs detected in the virtual security domain.
Ad-hoc
Number of Ad hoc connections detected in the virtual security domain.
Potentia- Authorized
Number of potential-authorized APs detected in the virtual security domain.
Potential-Rogue
Number of potential-rogue APs detected in the virtual security domain.
Potential-External
Number of potential-external APs detected in the virtual security domain.
Uncategorized
Number of uncategorized APs detected in the virtual security domain.
STA
Number of clients detected in the virtual security domain.
Authorized
Number of authorized clients detected in the virtual security domain.
Rogue
Number of rogue APs.
Mis-Association
Number of misassociated clients.
Uncategorized
Number of uncategorized APs or clients.
Unassociated
Number of unassociated clients.
display wlan ips trustlist
Use display wlan ips trustlist to display information about the specified or all entries in the permitted device list.
display wlan ips trustlist [ static | dynamic | mac-address mac-addr ] [ | { begin | exclude | include } regular-expression ]
2: System level
static: Specifies manually-configured entries in the permitted device list.
dynamic: Specifies dynamically added entry in the permitted device list.
mac-address mac-addr: Specifies a MAC address in the permitted device list.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
# Display information about all entries in the permitted device list.
[sysname] display wlan ips trustlist
                          Trust List
      MAC-Address                       Status
    0001-0002-0003                        S
    0001-0002-0004                       S&D
Table 27 Command output
Status
Status of the entries in the permitted device list.
·     D—Dynamically generated.
display wlan ips vsd-policy
Use display wlan ips vsd-policy to display policy information for the specified or all virtual security domains.
display wlan ips vsd-policy [ vsd vsd-name ] [ | { begin | exclude | include } regular-expression ]
None
Default command level
2: System level
# Display policy information for all virtual security domains.
[sysname]display wlan ips vsd-policy
                    Virtual Security Domain Policy
VSD Name              : office
Attack Detect Policy    : policy1
Signature Policy        : default
AP Classification Rules:
  Priority 15           : auth_ap
  Priority 10           : invalid_ap
  Priority 0            : default_rule
VSD Name                : lab
Attack Detect Policy    : policy2
Signature Policy        : sigpolicy1
  Priority 13           : invalid_ap
Table 28 Command output
VSD Name
Name of the attack detection policy applied in the virtual security domain.
Signature Policy
Name of the signature policy applied in the virtual security domain.
Name of the countermeasures policy applied in the virtual security domain.
All AP classification rules applied in the virtual security domain, displayed by precedence in descending order.
Priority n
Name of the AP classification rule, where n represents the precedence of the rule.
export wips-cfg-file oui
Use export wips-cfg-file oui to export OUI information in the OUI library of WIPS to the specified configuration file.
export wips-cfg-file oui filename
OUI information in the OUI library of WIPS is not exported.
WIPS view
2: System level
file-name: Specifies a configuration file by its name, a case-insensitive string of 1 to 32 characters. It cannot contain special characters back slash (\), slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), and vertical bar (|).
Export OUI information in the following format:
000FE2     (base 16)      New H3C Technologies Co., Ltd.
You cannot export OUI information to multiple configuration files at the same time.
# Export OUI information in the OUI library to configuration file OUIInfo.
[Sysname] wlan ips
[Sysname-wlan-ips] export wips-cfg-file oui OUIInfo
hotspot
Use hotspot to add the specified hotspot to the hotspot list of WIPS.
Use undo hotspot to remove the specified or all hotspots from the hotspot list of WIPS.
hotspot ssid-name
undo hotspot [ ssid-name ]
No hotspot list is configured.
WIPS view
2: System level
ssid-name: Specifies a hotspot by its SSID, a case-sensitive string of 1 to 32 characters that can contain letters, numbers, underlines, and spaces.
# Add hotspot kfc to the hotspot list of WIPS.
[Sysname] wlan ips
[Sysname-wlan-ips] hotspot kfc
ignorelist
Use ignorelist to add the MAC address of a wireless device to the alarm-ignored device list.
Use undo ignorelist to remove the MAC address of the specified or all wireless devices in the alarm-ignored device list.
ignorelist mac-address
undo ignorelist { mac-address | all }
No alarm-ignored device list exists.
WIPS view
2: System level
mac-address: Specifies the MAC address of the wireless device to be added to or removed from the alarm-ignored device list.
all: Removes all entries in the alarm-ignored device list.
For wireless devices in the list, WIPS only monitors them but do not generate any alarms for their actions.
# Add a wireless device with the MAC address 000f-e45d-fa00 to the alarm-ignored device list.
[Sysname] wlan ips
[Sysname-wlan-ips] ignorelist 000f-e45d-fa00
import wips-cfg-file oui
Use import wips-cfg-file oui to import OUI information from a specific configuration file to the OUI library of WIPS.
import wips-cfg-file oui [ filename ]
WIPS automatically imports OUI information to the OUI library.
WIPS view
2: System level
Download the specified configuration files from the H3C website, as follows:
38-22-D6   (hex)          H3C Technologies Co., Limited
3822D6     (base 16)      H3C Technologies Co., Limited
00-00-00   (hex)          XEROX CORPORATION
000000     (base 16)      XEROX CORPORATION
                              M/S 105-50C
                              800 PHILLIPS ROAD
                              WEBSTER NY 14580
                              UNITED STATES
If multiple imported OUI configuration files contain information about the same OUI, the new OUI information overwrites the old OUI information.
Only one OUI configuration file can be imported at a time.
# Import OUI information from configuration file oui.txt to the OUI library of WIPS.
[Sysname] wlan ips
[Sysname-wlan-ips] import wips-cfg-file oui oui.txt
malformed-detect-policy (virtual security domain view)
Use malformed-detect-policy to configure a malformed packet detection policy for the virtual security domain.
Use undo malformed-detect-policy to restore the default.
malformed-detect-policy policy-name
The virtual security domain uses the malformed packet detection policy named default.
Virtual security domain view
2: System level
policy-name: Specifies a malformed packet detection policy by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
You can configure only one malformed packet detection policy for the virtual security domain.
# Configure virtual security domain office to use the malformed packet detection policy all.
[Sysname] wlan ips
[Sysname-wlan-ips] virtual-security-domain office
[Sysname-wlan-ips-vsd-office] malformed-detect-policy all
malformed-detect-policy (WIPS view)
Use malformed-detect-policy to create a malformed packet detection policy and enter its view. If the malformed packet detection policy already exists, the command enters its view.
Use undo malformed-detect-policy to remove the specified malformed packet detection policy.
undo malformed-detect-policy policy-name
A malformed packet detection policy named default exists in the system.
WIPS view
2: System level
You cannot create or delete the malformed packet detection policy named default.
# Create a malformed packet detection policy named all, and enter its view.
[Sysname] wlan ips
[Sysname-wlan-ips] malformed-detect-policy all
manual-classify ap (virtual security domain view)
Use manual-classify ap to configure the WIPS device type for an AP with a specific MAC address in a virtual security domain.
Use undo manual-classify to remove the device type configuration for an AP with a specific MAC address in a virtual security domain.
manual-classify ap { authorized-ap | external-ap | misconfigured-ap | rogue-ap } mac-address &<1-2>
undo manual-classify { mac-address &<1-2> | all }
No WIPS device type is configured for an AP in a virtual security domain.
2: System level
authorized-ap: Specifies an authorized AP.
external-ap: Specifies an external AP.
misconfigured-ap: Specifies a misconfigured AP.
rogue-ap: Specifies a rogue AP.
mac-address&<1-2>: Specifies the MAC address of an AP, in the H-H-H format. When you specify this argument, you can omit the 0s for each octet in the MAC address. For example, f-e2-1 represents 000f-00e2-0001. &<1-2> indicates you can enter up to two MAC addresses.
all: Removes the WIPS device type configuration for all APs in the virtual security domain.
If you configure the WIPS device type for an AP with a specific MAC address in both WIPS view and virtual security domain view, the configuration in virtual security domain view takes effect.
# Configure the WIPS device type for the AP with the MAC address 000f-00e2-0001 in virtual security domain office as authorized-ap.
[Sysname] wlan ips
[Sysname-wlan-ips-vsd-office]manual-classify ap authorized-ap f-e2-1
manual-classify ap (WIPS view)
Use manual-classify ap to configure the WIPS device type for an AP with a specific MAC address.
Use undo manual-classify to remove the device type configuration for an AP with a specific MAC address.
No WIPS device type is configured for an AP.
WIPS view
2: System level
all: Removes the WIPS device type configuration for all APs.
# Configure the WIPS device type of the AP with the MAC address 000f-00e2-0001 as authorized-ap.
[Sysname] wlan ips
[Sysname-wlan-ips]manual-classify ap authorized-ap f-e2-1
match all (AP classification rule view)
Use match all to set the match criteria relationship for an AP classification rule. An AP is considered as matching the rule when it matches all match criteria of the rule.
Use undo match all to restore the default match criteria relationship.
match all
undo match all
An AP is considered as matching an AP classification rule as long as it matches any match criterion of the rule.
2: System level
# Set the match criteria relationship for the AP classification rule invalid_ap. An AP is considered as matching the rule when it matches all match criteria of the rule.
[Sysname] wlan ips
[Sysname-wlan-ips] ap-classification-rule invalid_ap
[Sysname-wlan-ips-class-invalid_ap]match all
match all (SIG view)
Use match all to set the match criteria relationship for a signature. A packet is considered as matching the rule when it matches all match criteria of the rule.
match all
undo match all
A packet is considered as matching a user-defined signature as long as it matches any match criterion of the rule. A packet is considered as matching a system-defined signature when it matches all match criteria of the rule.
SIG view
2: System level
To modify the match criteria relationship for a signature that has been bound to a signature policy, remove the binding first.
# Set the match criteria relationship for the user-defined signature office. A packet is considered as matching the rule when it matches all match criteria of the rule.
[Sysname] wlan ips
[Sysname-wlan-ips] signature office
[Sysname-wlan-ips-sig-office] match all
permit-channel
Use permit-channel to configure the list of permitted channels. Channels not in the list are considered as prohibited channels.
Use undo permit-channel to remove the configured permitted channels.
permit-channel channel-list
undo permit-channel { channel-list | all }
Channels supported by the current country code are permitted channels.
WIPS view
2: System level
channel-list: Specifies a list of channels to be added to or removed from the permitted channel list, in the range of 1 to 224. You can configure a maximum of 10 permitted channels at a time.
all: Removes all permitted channels.
Use the permit-channel command in combination with the detect prohibited-channel command. The permit-channel command takes effect only when the detect prohibited-channel command is configured.
# Specify channels 1, 6, 11, 149, 153, and 157 as permitted channels.
[Sysname] wlan ips
[Sysname-wlan-ips] permit-channel 1 6 11 149 153 157
quiet-time (malformed packet detection policy view)
Use quiet-time to configure the quiet time after malformed packets of the same type and MAC address are detected and an alarm is generated.
Use undo quiet-time to restore the default.
quiet-time time
undo quiet-time
The quiet time is 600 seconds.
Malformed packet detection policy view
2: System level
time: Specifies the quiet time after malformed packets of the same type and MAC address are detected and an alarm is generated. The value range is 5 to 604800 seconds.
# In the malformed packet detection policy all, configure the quiet time as 120 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips-mdctp-all]quiet-time 120
quiet-time (SIG view)
Use quiet-time to configure the quiet time for a signature. A signature in quiet state is not matched.
quiet-time time
undo quiet-time
The quiet time for a user-defined signature is 900 seconds and that for a system-defined signature depends on the specific system-defined signature.
SIG view
2: System level
time: Specifies the quiet time for a signature in the range of 60 to 32000, in seconds.
To modify the quiet time for a signature that has been bound to a signature policy, remove the binding first.
If you configure the quiet time for a signature multiple times, the most recent configuration overwrites the previous one.
A signature enters the quiet state only when the matching times of the rule reaches the detect-threshold within the specified statistics collection time period.
# Configure the quiet time for the user-defined signature office as 600 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips-sig-office] quiet-time 600
reset wlan ips event
Use reset wlan ips event to delete the specified or all alarm events generated by the WIPS system.
reset wlan ips event { all | causer-mac causer-mac | id event-id | level event-level | | source-mac source-mac | type event-type }
2: System level
all: Deletes all events generated by the WIPS system.
level event-level: Specifies the level for an alarm in the range of 0 to 7.
source-mac source-mac: Specifies the MAC address of the WIPS-enabled device that generates alarm events to be deleted.
type event-type: Specifies the type of an alarm.
# Delete the alarm event with the ID 10.
<Sysname> reset wlan ips event id 10
reset wlan ips statistic sensor
Use reset wlan ips statistics sensor to clear the malformed packet statistics about the specified sensor.
reset wlan ips statistics sensor [ sensor-name ] malformed-counter
2: System level
sensor [ sensor-name ]: Specifies a sensor by its name, a case-insensitive string of 1 to 64 characters.
# Clear the malformed packet statistics about sensor 1.
<Sysname> reset wlan ips statistics sensor sensor1 malformed-counter
sensor
Use sensor to add a sensor to the current virtual security domain.
Use undo sensor to remove a sensor from the current virtual security domain.
sensor ap-name-list
undo sensor ap-name-list
All sensors are in the default virtual security domain.
2: System level
ap-name-list: Specifies a space-separated list of up to 10 items. Each item specifies an AP by its name or a range of names in the form of ap-name. The ap-name argument is a case-insensitive string of 1 to 64 characters.
If you execute the command multiple times, WIPS adds the specified AP into the virtual security domain until the upper limit is reached, regardless of whether the AP exists.
If the AP you specified is not a sensor, the command does not take effect.
If you do not specify the virtual security domain for an AP that has been configured as a sensor, the AP belongs to the default virtual security domain default.
Sensors in the default virtual security domain cannot be deleted.
# Add AP 1 and AP 2 to the virtual security domain office and AP 3 and AP 4 to the virtual security domain lab.
[Sysname] wlan ips
[Sysname-wlan-ips-vsd-office]sensor ap1 ap2
[Sysname-wlan-ips-vsd-office]quit
[Sysname-wlan-ips] virtual-security-domain lab
[Sysname-wlan-ips-vsd-lab]sensor ap3 ap4
severity-level
Use severity-level to set a severity level for an AP that matches an AP classification rule.
Use undo severity-level to delete a severity level.
severity-level level-value
undo severity-level
No severity level is set for an AP that matches an AP classification rule.
2: System level
level-value: Specifies the severity level for an AP that matches an AP classification rule. The value is in the range of 0 to 100. A greater value represents a higher severity level.
A severity level takes effect only when no AP type is specified for an AP classification rule. If an AP matches multiple AP classification rules, WIPS uses the sum of the severity levels as the severity level for the AP. The maximum value is 100, even if the sum exceeds 100.
# Create AP classification rule invalid_ap and set the severity level for the devices matching the rule to 40.
[Sysname] wlan ips
[Sysname-wlan-ips-class-invalid_ap]severity-level 40
signature
Use signature to create a signature and enter signature view. For an existing signature, this command enters the corresponding signature view.
Use undo signature to remove a signature.
signature { rts_flood | cts_flood | pspoll_flood | eap_failure_flood | eap_success_flood | eapol_logoff_flood | broadcast_disassoc_flood | disassoc_flood | broadcast_deauth_flood | deauth_flood | addba_req_flood | signature-name } [ signature-id id-value ]
undo signatrue signatrue-name
System-defined signatures exist.
WIPS view
2: System level
rts_flood: System-defined signature, used to reconfigure the RST flooding attack detection parameters.
cts_flood: System-defined signature, used to reconfigure the CTS flooding attack detection parameters.
pspoll_flood: System-defined signature, used to reconfigure the PS-Poll flooding attack detection parameters.
eap_failure_flood: System-defined signature, used to reconfigure the EAP-failure flooding attack detection parameters.
eap_success_flood: System-defined signature, used to reconfigure the EAP-success flooding attack detection parameters.
eapol_logoff_flood: System-defined signature, used to reconfigure the EAPOL-logoff flooding attack detection parameters.
broadcast_disassoc_flood: System-defined signature, used to reconfigure the broadcast diassociation flooding attack detection parameters.
disassoc_flood: System-defined signature, used to reconfigure the unicast diassociation flooding attack detection parameters.
broadcast_deauth_flood: System-defined signature, used to reconfigure the broadcast deauthentication flooding attack detection parameters.
deauth_flood: System-defined signature, used to reconfigure the unicast deauthentication flooding attack detection parameters.
addba_req_flood: System-defined signature, used to reconfigure the ADDBA-request flooding attack detection parameters.
signature-name: Specifies a signature by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
signature-id id-value: Specifies a signature ID in the range of 1 to 64. The ID of a system-defined signature is in the range of 1 to 32 and cannot be modified. The ID of a user-defined signature is in the range of 33 to 64. It can only be specified when you create a signature. If you do not specify this option when you create a signature, the system assigns an ID to this signature. You cannot modify the ID of a signature.
Bind a signature to a signature policy first, and then bind the signature policy to a virtual security domain.
To modify the attribute for a signature that has been bound to a signature policy, remove the binding first.
You can configure up to 32 subsignatures, including 5 basic subsignatures and 27 user-defined subsignatures, for a user-defined signature.
A system-defined signature cannot be deleted.
You cannot configure subsignatures and track methods, modify the action and the match relationship for a system-defined signature.
# Create a signature named office and specify its ID as 48.
[Sysname] wlan ips
[Sysname-wlan-ips]signature office signature-id 48
# Create a signature named assoc_rsp_flood and specify its ID as 50.
[Sysname] wlan ips
[Sysname-wlan-ips]signature assoc_rsp_flood signature-id 50
[Sysname-wlan-ips-sig-assoc_rsp_flood]
signature (signature policy view)
Use signature to specify a signature by its name or ID for a signature policy.
Use undo signature to remove a specified signature from a signature policy.
signature { signature-name name-string | signature-id signature-list } [ precedence level ]
undo signature { name name-string | signature-id signature-list }
No signature is configured for a signature policy.
Signature policy view
2: System level
signature-name name-string: Specifies the name of the signature. It is a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
signature-id: Specifies the ID of a signature.
signature-list: Specifies a space-separated list of up to 10 items. Each item specifies a signature to be bound to the current signature policy by its ID or a range of IDs in the form of start-signature-id to end-signature-id. The signature-id argument is in the range of 1 to 64. The signatures must exist in the system. Otherwise, the signatures cannot be bound to the signature policy.
precedence level: Specifies the precedence of a signature in the range of 1 to 64. A greater value represents a higher precedence. The precedence of a signature is 1.
To bind a signature to virtual security domain, add it to a signature policy first, and then bind the signature policy to the virtual security domain.
Signatures in a signature policy are listed by precedence in descending order. Those with the same precedence are listed by rule ID in ascending order.
After you specify a signature-list, the system binds signatures to a signature policy by signature ID in ascending order. For example, If you specify the signature-list as signature signature-id 10 to 45 2 to 4 12 to 12 34 to 36 56 to 64 54 precedence 14, the system matches the signatures in the order to signature signature-id 2 to 4 10 to 45 54 56 to 64 precedence 14, where signature 2 is matched the first.
If you configure a precedence for a signature multiple times, the new configuration overwrites the previous one.
If the end-signature-id is smaller than the start-signature-id, the command cannot be executed. For example, if you specify the signature-list as signature signature-id 10 to 45 8 to 4 precedence 14, the command cannot be executed, and signatures 10 to 45 cannot be bound to a signature policy either.
A signature with no subsignatures cannot be bound to a signature policy.
# Enable detection specified by user-defined signature office1 in signature policy office, with the match precedence 21.
[Sysname] wlan ips
[Sysname-wlan-ips] signature-policy office
[Sysname-wlan-ips-sigpolicy-office] signature signature-name office1 precedence 21
signature-policy (virtual security domain view)
Use signature-policy to bind a signature policy to a virtual security domain.
Use undo signature-policy to unbind a signature policy from a virtual security domain.
signature-policy policy-name
A virtual security domain uses the signature policy named default.
2: System level
policy-name: Specifies a signature policy by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
You can bind only one signature policy to a virtual security domain.
# Bind signature policy office to virtual security domain floor1.
[Sysname] wlan ips
[Sysname-wlan-ips] virtual-security-domain floor1
[Sysname-wlan-ips-vsd-whr]signature-policy office
signature-policy (WIPS view)
Use signature-policy to create a signature policy and enter signature policy view. For an existing signature policy, this command enters the corresponding signature policy view.
Use undo signature-policy to remove a signature policy.
undo signature-policy policy-name
WIPS view
2: System level
The system supports up to 16 signature policies, including the default signature policy default.
You cannot remove a signature policy that has been applied to a virtual security domain.
You cannot create or remove the default signature policy default.
# Create a signature policy named office.
[Sysname] wlan ips
static-blocklist
Use static-blocklist to add the MAC address of a specified wireless device to the static prohibited device list.
Use undo static-blocklist to remove all wireless devices or the device with a specific MAC address from the static prohibited device list.
static-blocklist mac-address
undo static-blocklist { mac-address | all }
No static prohibited device list is configured.
WIPS view
2: System level
mac-address: Specifies the MAC address of the wireless device to be added to or removed from the static prohibited device list.
all: Removes all entries from the static prohibited device list.
# Add the wireless device with the MAC address 0016-6f9d-612e to the static prohibited device list.
[Sysname] wlan ips
[Sysname-wlan-ips] static-blocklist 0016-6f9d-612e
static-trustlist
Use static-trustlist to add the MAC address of a specified wireless device to the static permitted device list.
Use undo static-trustlist to remove all wireless devices or the device with a specific MAC address from the static permitted device list.
static-trustlist mac-address
undo static-trustlist { mac-address | all }
No static permitted device list is configured.
WIPS view
2: System level
mac-address: Specifies the MAC address of the wireless device to be added to or removed from the static permitted device list.
all: Removes all entries from the static permitted device list.
# Add the wireless device with the MAC address 000f-e45d-fa00 to the static permitted device list.
[Sysname] wlan ips
[Sysname-wlan-ips] static-trustlist 000f-e45d-fa00
static-trustoui
Use static-trustoui to add an OUI or vendor to the static trusted OUI list.
Use undo static-trustoui to remove a specific OUI or vendor or all OUIs and vendors from the static trusted OUI list.
static-trustoui { oui-info | vendor vendor-name }
undo static-trustoui { oui-info | vendor vendor-name | all }
No static trusted OUI list is configured.
WIPS view
2: System level
vendor vendor-name: Specifies a vendor by its name, a case-sensitive string of 1 to 64 characters.
all: Removes all OUIs and vendors in the static trusted OUI list.
You can specify a maximum of 512 OUIs and 64 vendors.
The command does not take effect if the OUI library has no OUI information for the specified vendor.
# Add OUI 00-0f-e4 to the static trusted OUI list.
[Sysname] wlan ips
[Sysname-wlan-ips] static-trustoui 000fe4
# Add vendor h3c to the static trusted OUI list.
[Sysname] wlan ips
[Sysname-wlan-ips] static-trustoui vendor h3c
sub-rule (AP classification rule view)
Use sub-rule to set subsignatures for an AP classification rule.
Use undo sub-rule to delete the specified subsignatures.
sub-rule { ssid [ case-sensitive ] [ not ] { equal | include } string | security { equal | include } { clear | wep | wpa | wpa2 }* | authentication { equal | include } { 802.1x | psk | other | none } | { rssi | duration | client-on-ap | discovered-ap } { greater-than min-value | less-than max-value | between min-value max-value } | oui { oui-info | vendor vendor-name } }
undo sub-rule { ssid | security | authentication | rssi | duration | clients-on-ap | discovered-ap | oui }
No subsignatures are specified for an AP classification rule.
2: System level
ssid: Matches SSIDs.
case-sensitive: Specifies a case-sensitive character string.
not: Matches SSIDs that are not equal to or do not include the specified value.
equal: Matches SSIDs equal to the specified value.
include: Matches SSIDs that include the specified value.
string: Specifies a character string in the range of 1 to 32.
security: Matches security methods used by the AP.
clear: Specifies the clear security method.
wep: Specifies the WEP security method.
wpa: Specifies the WPA security method.
wpa2: Specifies the WPA2 security method.
authentication: Matches the authentication method of APs.
802.1x: Specifies the 802.1X authentication method.
psk: Specifies the PSK authentication method.
other: Specifies an authentication method other than 802.1X and PSK.
none: Specifies no authentication.
rssi: Matches RSSIs of APs in the range of 0 to 90 dBm.
duration: Matches running duration of APs in the range of 0 to 2592000 seconds.
clients-on-ap: Matches number of associated clients of APs in the range of 0 to 128.
discovered-ap: Matches number of APs detected by the current sensor in the range of 0 to 128.
greater-than: Matches values greater than or equal to the specified value.
less-than: Matches values smaller than the specified value.
between: Matches values between the specified minimum value (exclusive) and maximum value (inclusive).
min-value: Specifies a minimum value, which cannot be equal to the maximum value.
max-value: Specifies a maximum value, which cannot be equal to the minimum value.
oui: Matches OUIs of APs.
vendor vendor-name: Specifies a vendor by its name, a case-insensitive string of 1 to 64 characters.
# Configure the following subsignatures for the AP classification rule invalid_ap.
·     SSID—Does not contain H3C, case-insensitive.
·     Security method—Clear or WEP.
·     RSSI—Greater than 80.
·     Running time of the AP—Smaller than 172800 seconds (2 days).
·     Number of associated clients—Greater than 10.
·     Number of APs detected by the sensor—Greater than 6.
·     OUI and vendorh3c.
[Sysname] wlan ips
[Sysname-wlan-ips-class-invalid_ap] sub-rule ssid not include H3C
[Sysname-wlan-ips-class-invalid_ap] sub-rule security include clear wep
[Sysname-wlan-ips-class-invalid_ap] sub-rule rssi greater-than 80
[Sysname-wlan-ips-class-invalid_ap] sub-rule duration less-than 172800
[Sysname-wlan-ips-class-invalid_ap] sub-rule clients-on-ap greater-than 10
[Sysname-wlan-ips-class-invalid_ap] sub-rule discovered-ap greater-than 6
[Sysname-wlan-ips-class-invalid_ap] sub-rule oui vendor h3c
sub-rule (SIG view)
Use sub-rule to configure subsignatures for a user-defined signature.
sub-rule { frame-type { data | management [ frame-subtype { association-request | association-response | authentication | beacon | deauthentication | disassociation | probe-request } ] | control } | mac { source-mac mac-address | dest-mac mac-address | bssid mac-address } | ssid { [ case-sensitive ] [ not ] { equal | include } string } | ssid-length { equal length-value | greater-than min-value | less-than max-value | between min-value max-value } | seq-number { equal seq-value | greater-than min-value | less-than max-value | between min-value max-value } | pattern pattern-id id [ pattern-name name ] offset offset-value mask hex-value { equal value | greater-than min-value | less-than max-value | between min-value max-value } [ from-payload ] }
undo sub-rule { frame-type | mac | ssid | ssid-length | seq-number | pattern pattern-id id }
No subsignatures are configured for a signature.
SIG view
2: System level
frame-type: Specifies a frame type.
data: Matches data frames.
management: Matches management frames.
frame-subtype: Specifies the subtype of frames.
association-request: Matches association requests.
association-response: Matches association responses.
authentication: Matches authentication frames.
beacon: Matches beacon frames.
deauthentication: Matches de-authentication frames.
disassociation: Matches disassociation frames.
probe-request: Matches probe requests.
control: Matches control frames.
mac: Matches MAC addresses.
source-mac mac-address: Matches a source MAC address in the format of FFFF-FFFF-FFFF, case-insensitive.
dest-mac mac-address: Matches a destination MAC address in the format of FFFF-FFFF-FFFF, case-insensitive.
bssid mac-address: Matches a BSSID in the format of FFFF-FFFF-FFFF, case-insensitive.
ssid-length: Matches the SSID length.
length-value: Specifies an SSID length in the range of 0 to 32.
greater-than: Matches values greater than the specified value.
between: Matches values between the specified minimum value (inclusive) and maximum value (inclusive). The maximum value must be greater than the minimum value.
min-value: Specifies a minimum value, which depends on values to match.
max-value: Specifies a maximum value, which depends on values to match.
seq-number: Matches sequence numbers of wireless packets.
seq-value: Specifies a sequence number in the range of 0 to 4095.
pattern: Specifies a frame match pattern by its name.
pattern-id id: Specifies a frame match pattern by its ID.
pattern-name name: Specifies a frame match pattern by its name.
offset offset-value: Matches frames from the specified starting bit in the range of 0 to 2346.
mask hex-value: Matches frames with a specified mask in the range of 0 to ffff in hexadecimal format.
from-payload: Matches frames starting from the frame body.
To modify the subsignatures for a signature that has been bound to a signature policy, remove the binding first.
You cannot configure subsignatures for a system-defined signature.
You can configure up to 32 subsignatures, including 5 basic subsignatures, for a signature. If you configure a subsignature for a signature multiple times, the most recent configuration overwrites the previous one.
If you do not specify the pattern-id keyword in the undo sub-rule command, all subsignatures specifying a frame match pattern are removed.
# Configure the subsignatures for signature office as the following:
·     Frame type—Association Request.
·     Source MAC address—0000-0000-0001.
·     SSID—Does not contain H3C, case sensitive.
·     SSID length—Between 15 (inclusive) and 20 (inclusive).
·     Wireless packet sequence number—Greater than 100.
·     The frame body starting from the eighth bit ANDed with mask 0xabcd is greater than 9.
·     The eighth bit of the frame ANDed with mask 0xabcd is between 0x15 (inclusive) and 0x20 (inclusive).
[Sysname] wlan ips
[Sysname-wlan-ips-sig-office] sub-rule frame-type management frame-subtype association-request
[Sysname-wlan-ips-sig-office] sub-rule mac source-mac 0000-0000-0001
[Sysname-wlan-ips-sig-office] sub-rule ssid case-sensitive not include H3C
[Sysname-wlan-ips-sig-office] sub-rule ssid-length between 15 20
[Sysname-wlan-ips-sig-office] sub-rule seq-number greater-than 100
[Sysname-wlan-ips-sig-office] sub-rule pattern pattern-id 1 offset 8 mask abcd greater-than 9 from-payload
[Sysname-wlan-ips-sig-office] sub-rule pattern pattern-id 2 pattern-name pattern2 offset 8 mask ffff between 15 20
timer ap-inactivity
Use timer ap-inactivity to set the maximum idle time for an AP.
Use undo timer ap-inactivity to restore the default maximum idle time.
timer ap-inactivity time
The maximum idle time is 300 seconds.
WIPS view
2: System level
time: Specifies the maximum idle time in the range of 60 to 600 in seconds. If an AP does not send any packets within the time, WIPS switches the state of the AP to inactive.
WIPS considers an AP inactive when it detects that the AP has not sent any packets within the specified time.
# Set the maximum idle time for an AP to 120 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips] timer ap-inactivity 120
timer client-inactivity
Use timer client-inactivity to set the maximum idle time for an associated client.
Use undo timer client-inactivity to restore the default maximum idle time.
timer client-inactivity time
The maximum idle time for an associated client is 600 seconds.
WIPS view
2: System level
time: Specifies the maximum idle time in the range of 120 to 1200 in seconds. If an associated client does not send any packets within the time, WIPS switches the state of the client to inactive.
# Set the maximum idle time for an associated client to 300 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips] timer client-inactivity 300
timer device-aging
Use timer device-aging to set the aging time for inactive APs or clients.
Use undo timer device-aging to restore the default aging time.
timer device-aging time
The aging time is 86400 seconds.
WIPS view
2: System level
time: Specifies the aging time of inactive APs or clients, in the range of 60 to 2592000 seconds.
# Set the aging time for inactive APs or clients to 604800 seconds (7 days).
[Sysname] wlan ips
[Sysname-wlan-ips]timer device-aging 604800
timer device-update
Use timer device-update to set the information update interval for wireless devices in WIPS.
Use undo timer device-update to restore the default.
timer device-update time
The information update interval for wireless devices in WIPS is 20 seconds.
WIPS view
2: System level
time: Specifies the information update interval in the range of 10 to 30 seconds.
# Set the information update interval for wireless devices in WIPS to 30 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips]timer device-update 30
timer dynamic-trustlist-aging
Use timer dynamic-trustlist-aging to set the aging time of the wireless devices dynamically added to the trusted device list.
Use undo timer dynamic-trustlist-aging to restore the default.
timer dynamic-trustlist-aging time
The aging time is 300 seconds.
WIPS view
2: System level
time: Specifies the aging time of the wireless devices dynamically added to the trusted device list, in the range of 60 to 86400 seconds.
# Set the aging time of the wireless devices dynamically added to the trusted device list to 360 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips]timer dynamic-trustlist-aging 360
timer mesh-link-aging
Use timer mesh-link-aging to configure the aging time for WLAN mesh links.
Use undo timer mesh-link-aging to restore the default.
timer mesh-link-aging time-value
The aging time for WLAN mesh links is 600 seconds.
WIPS view
2: System level
mesh-link-aging time-value: Specifies the aging time for WLAN mesh links, in the range of 60 to 86400 seconds.
# Set the aging time for WLAN mesh links to 3600 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips] timer mesh-link-aging 3600
timer reclassification
Use timer reclassification to set the interval for WIPS to re-classify detected wireless devices.
Use undo timer reclassification to restore the default.
timer reclassification time
The interval for WIPS to re-classify the detected APs and clients is 600 seconds.
WIPS view
2: System level
time: Specifies the interval for WIPS to re-classify detected wireless devices, in the range of 10 to 3600 seconds.
# Set the interval for WIPS to re-classify the detected APs and clients to 300 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips]timer reclassification 300
timer statistic-period
Use timer statistic-period to set the packet statistics collection period.
Use undo timer statistic-period to restore the default.
timer statistic-period time
The statistics collection period for wireless packets is 900 seconds.
WIPS view
2: System level
time: Specifies the packet statistics collection period in the range of 60 to 86400 seconds.
# Set the packet statistics collection period to 3600 seconds (1 hour).
[Sysname] wlan ips
[Sysname-wlan-ips]timer statistic-period 3600
track-method
Use track-method to configure the match track method for signatures.
track-method { both | per-mac | per-signature }
The track method for user-defined signatures is both and that for system-defined signatures depends on the specific signature.
SIG view
2: System level
per-mac: Tracks and matches packets by MAC address according to signatures on all channels supported by the current country code.
per-signature: Tracks and matches packets according to signatures without distinguishing MAC addresses on all channels supported by the current country code.
To modify the track method for a signature that has been bound to a signature policy, remove the binding first.
If you configure the track-method for a signature multiple times, the most recent configuration overwrites the previous one.
You cannot modify the track method for a system-defined signature.
If you set the track-method to both, configure both the per-mac and per-signature keywords. If you only configure one of them, the default maximum matching times for either per-mac mode or per-signature mode apply.
# Configure the match track method for signature office as per-mac.
[Sysname] wlan ips
[Sysname-wlan-ips-sig-office] track-method per-mac
# Change the match track method for signature office to per-signature.
[Sysname] wlan ips
[Sysname-wlan-ips-sig-office] track-method per-signature
undo wips-cfg-file oui
Use undo wips-cfg-file oui to clear the OUI configurations in the OUI library.
The OUI configurations in the OUI library are not cleared.
WIPS view
2: System level
# Clear the OUI configurations in the OUI library.
[Sysname] wlan ips
[Sysname-wlan-ips] undo wips-cfg-file oui
Use virtual-security-domain to create a virtual security domain and enter virtual security domain view. For an existing virtual security domain, this command directly enters the corresponding virtual security domain view.
Use undo virtual-security-domain to remove the specified virtual security domain.
virtual-security-domain vsd-name
undo virtual-security-domain vsd-name
The virtual security domain default is used as the default virtual security domain. You cannot create or remove it.
WIPS view
2: System level
vsd-name: Specifies a virtual security domain by its name, a case-insensitive string of 1 to 32 characters that can contain letters, numbers, and underlines.
# Create a virtual security domain named office.
[Sysname] wlan ips
wips detect mode
Use wips detect mode to enable WIPS and configure the operating mode for a sensor.
Use undo wips detect mode to disable WIPS.
wips detect mode { access-first | access-only [ scan-time time-value ] | detect-first | detect-only | middle }
No operating mode is configured for a sensor.
AP radio view
2: System level
access-first: Specifies the access first policy for the sensor operating in hybrid mode.
access-only: Specifies the access only policy for the sensor operating in hybrid mode. The sensor provides access services and scans only the working channel.
scan-time time-value: Specifies the time period during which the sensor scans the working channel, in the range of 60 to 200 milliseconds. The default is 60 milliseconds.
detect-first: Specifies the detection first policy for the sensor operating in hybrid mode.
detect-only: Specifies a monitor sensor.
middle: Specifies the balanced policy for the sensor operating in hybrid mode.
If you configure a radio as a sensor operating in monitor mode, you do not need to configure wireless service for the radio.
# Enable WIPS on radio 2 of AP 1 and set the operating mode of radio 2 to detect-only.
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2]wips detect mode detect-only
wips enable
Use wips enable to enable WIPS.
Use undo wips enable to disable WIPS.
wips enable
undo wips enable
WIPS is disabled.
WIPS view
2: System level
# Enable WIPS.
[Sysname] wlan ips
[Sysname-wlan-ips]wips enable
wipslogfile
Use wipslogfile to configure the maximum size of WIPS logs. When the upper limit is reached, WIPS removes the earliest logs of the corresponding type.
Use undo wipslogfile to restore the default.
wipslogfile { event | malformed-packet } size value
undo wipslogfile { event | malformed-packet } size
The size of WIPS logs depends on the device model. For more information, see About the H3C Access Controllers Command References.
event: Specifies system event logs.
malformed-packet: Specifies error packet logs.
size value: Specifies the size of a certain type of logs in MB. The value range for this option depends on the device model. For more information, see About the H3C Access Controllers Command References.
WIPS view
2: System level
# Configure the maximum size of system event logs as 5 MB.
[Sysname] wlan ips
[Sysname-wlan-ips] wipslogfile event size 5
wipslogfile enable
Use wipslogfile enable to enable automatic WIPS log saving.
Use undo wipslogfile enable to disable automatic WIPS log saving.
wipslogfile enable
Automatic WIPS log saving is disabled.
WIPS view
2: System level
# Enable automatic WIPS log saving.
[Sysname] wlan ips
[Sysname-wlan-ips] wipslogfile enable
wireless-probe client-aging
Use wireless-probe client-aging to set the client entry aging timer.
Use undo wireless-probe client-aging to restore the default.
wireless-probe client-aging time-value
The client entry aging timer is 300 seconds.
WIPS view
2: System level
time-value: Specifies the client entry aging timer in the range of 1 to 3600 seconds. The default is 300 seconds.
# Set the client entry aging timer to 600 seconds.
[Sysname] wlan ips
[Sysname-wlan-ips] wireless-probe client-aging 600
wireless-probe enable
Use wireless-probe enable to enable client probing.
Use undo wireless-probe enable to disable client probing.
Client probing is disabled.
AP template view
2: System level
# Enable client probing for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] wireless-probe enable
wireless-probe ignore ap
Use wireless-probe ignore to configure APs to ignore the specified wireless devices.
Use undo wireless-probe ignore to restore the default.
wireless-probe ignore { ap | rssi rssi-value }
undo wireless-probe ignore { ap | rssi }
APs do not ignore wireless devices.
WIPS view
2: System level
ap: Configures APs to ignore detected APs.
rssi rssi-value: Configures APs to ignore wireless devices with an RSSI lower than the value specified by the rssi-value argument. The value range for the rssi-value argument is 1 to 60.
# Configure APs to ignore detected APs.
[Sysname] wlan ips
[Sysname-wlan-ips] wireless-probe ignore ap
# Configure APs to ignore wireless devices with an RSSI lower than 10.
[Sysname] wlan ips
[Sysname-wlan-ips] wireless-probe ignore rssi 10
wireless-probe location
Use wireless-probe location to set the longitude and latitude of an AP.
Use undo wireless-probe location to remove the configuration.
wireless-probe location longitude longitude-value latitude latitude-value
The longitude and latitude of an AP are not set.
AP template view
2: System level
longitude longitude-value: Specifies the longitude of the AP, in XXX-XX-XX.X format. The value ranges for XXX and XX are 0 to 180 and 0 to 60, respectively. The value of X can be e or w and is case insensitive.
latitude latitude-value: Specifies the latitude of the AP, in XXX-XX-XX.X format. The value ranges for XXX and XX are 0 to 90 and 0 to 60, respectively. The value of X can be s or n and is case insensitive.
# Set the longitude and latitude for AP sensor to 123-40-40.e and 80-30-30.n, respectively.
[Sysname] wlan ap sensor model WA4320i-ACN
[Sysname-wlan-ap-sensor] wireless-probe location longitude 123-40-40.e latitude 80-30-30.n
wireless-probe server
Use wireless-probe server to specify a server to receive wireless device information.
Use undo wireless-probe sever to restore the default.
wireless-probe server ip ip-address port port-number [ interval interval ] preshared-key [ cipher | simple ] key-string
undo wireless-probe server
No server is specified to receive wireless device information.
WIPS view
AP template view
2: System level
ip ip-address: Specifies the IP address of the server.
port port-number: Specifies the port number of the server, in the range of 1 to 65534.
interval interval: Specifies the interval at which APs send device information to the server, in the range of 1 to 600 seconds. The default interval is 30 seconds.
simple: Specifies a key in plaintext form.
key-string: Specifies the key. Its plaintext form is a case-sensitive string of 8 to 63 characters. Its encrypted form is a case-sensitive string of 41 to 117 characters.
The configuration in AP template view takes precedence over the configuration in WIPS view.
# In WIPS view, specify the server with IP address 8.3.1.2 and port number 5060 to receive device information. Set the report interval to 60 seconds and the key to 12345678 in plaintext form.
[Sysname] wlan ips
[Sysname-wlan-ips] wireless-probe server ip 8.3.1.2 port 5060 interval 60 preshared-key simple 12345678
# In AP template view, specify the server with IP address 8.3.1.2 and port number 5060 to receive device information. Set the report interval to 60 seconds and the key to 12345678 in plaintext form.
[Sysname-wlan-ap-ap1] wireless-probe server ip 8.3.1.2 port 5060 interval 60 preshared-key simple 12345678
wireless-probe timezone
Use wireless-probe timezone to set the time difference between the AC and an AP.
Use undo wireless-probe timezone to remove the configuration.
wireless-probe timezone { add | minus } timevalue
The time difference between the AC and an AP is not set.
AP template view
2: System level
add: Configures a positive time difference between the AP and the AC.
minus: Configures a negative time difference between the AP and the AC.
timevalue: Specifies the time difference between the AP and the AC in hh: mm: ss format.
# Configure a negative time difference between AP sensor and the AC and set the time difference to 8 hours, which means that the time of AP sensor is the AC' s time minus 8 hours.
[Sysname-wlan-ap-sensor] wireless-probe timezone minus 08:00:00
wlan ips
Use wlan ips to enter WLAN IPS view.
wlan ips
2: System level
# Enter WLAN IPS view.
[Sysname] wlan ips
[Sysname-wlan-ips]
