02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10202-WLAN Command Reference
08-WLAN Mesh Link Commands
08-WLAN Mesh Link Commands 125.58 KB
WLAN mesh link configuration commands
Support for the commands in this chapter depends on the device model. For more information, see About the H3C Access Controllers Command References.
bind wlan-mesh
Use bind wlan-mesh to bind the specified mesh interface to the mesh profile.
Use undo bind wlan-mesh to unbind the interface to the mesh profile.
bind wlan-mesh interface-index
undo bind wlan-mesh
No mesh interface is bound to the mesh profile.
Mesh profile view
Default command level
2: System level
interface-index: Specifies the index of the WLAN mesh interface in the range of 1 to 32.
One mesh interface can be bound to only one mesh profile.
# Bind interface WLAN-mesh 1 to mesh profile 1.
[Sysname] wlan mesh-profile 1
[Sysname-wlan-mshp-1] bind wlan-mesh 1
display wlan mesh-link ap
Use display wlan mesh-link ap to display WLAN mesh link information for the specified AP or all APs.
display wlan mesh-link ap { all | name ap-name  [ verbose ] } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Specifies all APs.
name ap-name: Specifies an AP by its name.
verbose: Displays the detailed mesh link information of the specified AP.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the mesh link information about all APs.
<Sysname> display wlan mesh-link ap all
                               Mesh Link Information
AP Name:  ap1
 Peer             Local            Status       RSSI   Packets(Rx/Tx)
 00ef-2231-0b4a   00aa-4433-6699   Forwarding   50     13442/134234
 00ae-2231-0d63   00aa-4433-6699   Discarding   46     24534/255
AP Name:  ap2
 00aa-4433-6699   00ef-2231-0b4a   Forwarding   54     231/14234
 00ae-2231-0d63   00ef-2231-0b4a   Discarding   32     2545/2234
Peer
MAC address of the neighbor on the link.
Local
MAC address of the local AP.
RSSI
Received signal strength indicator (RSSI), which indicates the signal strength of the AP detected by the mesh peer.
Packets(Rx/Tx)
Packets sent and received.
Status
State of the mesh link:
·     Forwarding.
·     Discarding.
RSSI
Received signal strength indication.
# Display the detailed mesh link information about the specified AP.
<Sysname> display wlan mesh-link ap name ap1 verbose
                                  Mesh Link Verbose
AP Name: ap1
 Peer MAC       : 00ef-2231-0b4a
 Local MAC      : 00aa-4433-6699
 Status         : Discarding
 RSSI           : 15
 SNR            : 1
 Noise (dBm)    : 0
 Cost           : 100000
 Link PER (%)   : 13
 Packets
      Receive   : 12
      Transmit  : 3
      Resend    : 2
      TxDiscard : 0
Peer MAC
MAC address of the peer AP.
Local MAC
RSSI
Received signal strength indicator (RSSI), which indicates the mesh link signal strength detected by the AP.
SNR
Signal-to-noise ratio.
Cost
Mesh link cost.
Link PER (%)
Number of error packets to the total packets sent.
Receive
Number of packets received.
Transmit
Number of packets sent.
Resend
Number of packets resent repeatedly.
TxDiscard
Number of packets discarded.
display wlan mesh-profile
Use display wlan mesh-profile to display mesh profile information.
display wlan mesh-profile { mesh-profile-number | all } [ | { begin | exclude | include } regular-expression ]
2: System level
mesh-profile-number: Specifies a mesh profile by its number in the range of 1 to 32.
all: Specifies all mesh profiles.
This command is available only on the AC.
# Display the mesh profile information about mesh profile 1.
<Sysname> display wlan mesh-profile 1
                                 Mesh Profile Parameters
 Mesh Profile Number                     : 1
 Mesh ID                                 : sys_mesh
 Binding Interface                       : WLAN-MESH1
 MKD Service                             : Enable
 Link Keep Alive Interval (s)            : 2 (Default)
 Link Backhaul Rate (Mbps)               : 18 (Default)
 Mesh Profile Status                     : Enable
Mesh Profile Number
Mesh profile number.
Mesh ID
Mesh ID of the mesh profile.
Binding Interface
Mesh interface bound to the mesh profile (the interface has security parameters configured).
MKD Service
Whether the mesh profile has mesh key domain service enabled or not.
Keep-alive interval to be used by devices bound to the mesh profile.
Link Backhaul Rate
Backhaul rate to be used by devices bound to the mesh profile.
Mesh Profile Status
Mesh profile status, enabled or disabled.
display wlan mp-policy
Use display wlan mp-policy to display MP policy information.
display wlan mp-policy { mp-policy-name | all } [ | { begin | exclude | include } regular-expression ]
2: System level
mp-policy-name: Specifies an MP policy by its name, a string of 1 to 15 alphanumeric characters with underscores. It cannot contain any space characters.
all: Specifies all MP policies.
# Display information about all MP policies.
<Sysname> display wlan mp-policy all
                      Mesh Policy Parameters
 MP Policy Name              : default_mp_plcy
 Mesh Link Initiation        : Enable
 Mlsp                        : Disable
 Authenticator Role          : Enable
 Max Links                   : 2 (Default)
 Probe Request Interval (ms) : 1000 (Default)
 Link Hold RSSI              : 15 (Default)
 Link Hold Time (ms)         : 4000 (Default)
 Link Switch Margin          : 10 (Default)
 Link saturation RSSI        : 150 (Default)
 Link rate-mode              : fixed (Default)
 MP Policy Name              : new
 Mlsp                        : Enable
 Max Links                   : 5
MP Policy Name
Name of the MP policy.
Whether link initiation is enabled or not.
Authenticator Role
Whether role authenticator is enabled or not.
Mlsp
Whether the mobile link switch protocol is enabled or not.
Max Links
Maximum number of links on a device using this MP policy.
Interval between probe requests sent by a device using this MP policy.
Link Hold RSSI
Default link hold RSSI.
Link Hold Time
Default link hold time.
Link Switch Margin
Default link switch margin.
Default link saturation RSSI.
Link rate-mode
Link rate mode:
·     fixed—Use the maximum fixed rate of the current radio to calculate the cost of a mesh link.
·     real-time—Use the real-time RSSI to calculate the cost of a mesh link.
link-backhaul-rate
Use link-backhaul-rate to configure the link backhaul rate.
Use undo link-backhaul-rate to restore the default.
link-backhaul-rate rate-value
The default link backhaul rate is 18 Mbps.
Mesh profile view
2: System level
rate-value: Specifies the rate value in Mbps, which can be set to one of the following values: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54.
# Set the link backhaul rate as 6 Mbps for mesh profile 1.
[Sysname-wlan-mshp-1] link-backhaul-rate 6
link-hold-rssi
Use link-hold-rssi to configure the minimum signal strength to allow a mesh link to be formed and held.
Use undo link-hold-rssi to restore the system default.
link-hold-rssi value
undo link-hold-rssi
The minimum signal strength to allow a link to be formed and held is 15.
MP policy view
2: System level
value: Specifies the link formation/Link hold RSSI (received signal strength indicator), or, the minimum signal strength to allow a mesh link to be formed and held. The argument is in the range of 5 to 100, in dBm.
# Set the minimum signal strength to allow a link to be formed and held for MP policy sys_mp to 10 dBm.
[Sysname] wlan mp-policy sys_mp
[Sysname-wlan-mp-policy-sys_mp] link-hold-rssi 10
link-hold-time
Use link-hold-time to configure the link hold time.
Use undo link-hold-time to restore the system default.
link-hold-time value
undo link-hold-time
The link hold time is 4000 milliseconds.
MP policy view
2: System level
value: Specifies the link hold time, or, the minimum time for keeping an active link up. It is in the range of 1000 to 20000, in milliseconds.
# Set the link hold time for MP policy sys_mp to 2000 milliseconds.
[Sysname-wlan-mp-policy-sys_mp] link-hold-time 2000
link-initiation enable
Use link-initiation enable to enable link initiation for the MP policy. An MP using the MP policy will perform link initiation with a peer.
Use undo link-initiation enable to disable link initiation for the MP policy.
Link initiation is enabled.
MP policy view
2: System level
This feature is used for train MPs in a subway WLAN mesh network to initiate link creation. When you configure MP policies for rail APs, disable this function.
# Disable link initiation for MP policy sys_mp.
[Sysname-wlan-mp-policy-sys_mp] undo link-initiation enable
link-keep-alive
Use link-keep-alive to configure the mesh link keep alive interval.
Use undo link-keep-alive to restore the system default.
link-keep-alive keep-alive-interval
The mesh link keep alive interval is 2 seconds.
Mesh profile view
2: System level
keep-alive-interval: Specifies the link keep alive interval in seconds, in the range of 1 to 1800.
# Set the mesh link keep alive interval to 60 seconds.
[Sysname-wlan-mshp-1] link-keep-alive 60
link-saturation-rssi
Use link-saturation-rssi to configure the link saturation RSSI.
Use undo link-saturation-rssi to restore the system default. If the value is reached, the chipset is saturated and link switch will happen.
link-saturation-rssi value
The link saturation RSSI is 150 dBm.
MP policy view
2: System level
value: Specifies the link saturation RSSI in the range of 30 to 150, in dBm.
# Set the link saturation RSSI for MP policy sys_mp to 44 dBm.
[Sysname-wlan-mp-policy-sys_mp] link-saturation-rssi 44
link-switch-margin
Use link-switch-margin to configure the link switch margin.
link-switch-margin value
undo link-switch-margin
The link switch margin is 10 dBm.
MP policy view
2: System level
value: Specifies the link switch margin. If the RSSI of the new link is greater than that of the current active link by the link switch margin, active link switch happens. This argument is in the range of 1 to 100, in dBm.
# Set the link switch margin for MP policy sys_mp to 11 dBm.
[Sysname-wlan-mp-policy-sys_mp] link-switch-margin 11
link-maximum-number
Use link-maximum-number to configure the maximum number of links that an MP can form in a mesh network.
Use undo link-maximum-number to restore the system default.
link-maximum-number max-link-number
The maximum link number is 2.
MP policy view
2: System level
max-link-number: Specifies the maximum link number in the range of 1 to 8.
# Set the maximum number of links to 5 for MP policy sys_mp.
[Sysname-wlan-mp-policy-sys_mp] link-maximum-number 5
link rate-mode
Use link rate-mode to set the method to calculate the cost of a mesh link.
Use undo link rate-mode to restore the system default.
link rate-mode { fixed | real-time }
undo link rate-mode
The cost of a mesh link is calculated with the fixed method.
MP policy view
2: System level
fixed: Uses the maximum fixed rate of the current radio to calculate the cost of a mesh link.
real-time: Uses the real-time RSSI to calculate the cost of a mesh link.
# Calculate the cost of a mesh link according to the real-time RSSI.
[Sysname-wlan-mp-policy-sys_mp] link rate-mode real-time
mesh-id
Use mesh-id to configure the mesh ID for the current mesh profile.
Use undo mesh-id to remove the mesh ID.
mesh-id mesh-id-name
undo mesh-id
No mesh ID is set for the mesh profile.
Mesh profile view
2: System level
mesh-id-name: Specifies the mesh ID name, a case-sensitive string of 1 to 32 characters.
Same mesh ID cannot be assigned for two mesh profiles.
# Set the mesh ID to sys_mesh for mesh profile 1.
[Sysname-wlan-mshp-1] mesh-id sys_mesh
mesh-profile
Use mesh-profile to map the mesh profile to the current radio.
Use undo mesh-profile to unmap the specified mesh profile from the radio.
mesh-profile mesh-profile-number
undo mesh-profile mesh-profile-number
No mesh profile is mapped to the radio.
Radio-Template view
2: System level
mesh-profile-number: Mesh profile number, in the range of 1 to 32.
Only one mesh profile can be mapped to the radio.
# Map the mesh profile 1 for radio 1.
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] radio 1 type dot11an
[Sysname-wlan-ap-ap1-radio-1] mesh-profile 1
mesh-profile enable
Use mesh-profile enable to enable the mesh profile.
Use undo mesh-profile enable to disable the mesh profile.
mesh-profile enable
The mesh profile is disabled.
Mesh profile view
2: System level
A mesh profile can be enabled only when it has been bound to a mesh interface and has had a mesh ID configured.
You cannot delete a mesh profile if it has been mapped to a radio interface.
# Enable the mesh profile 1.
[Sysname] interface wlan-mesh 1
[Sysname-wlan-mesh1] port-security tx-key-type 11key
[Sysname-wlan-mesh1] port-security preshared-key pass-phrase 12345678
[Sysname-wlan-mesh1] port-security port-mode psk
[Sysname-wlan-mesh1] quit
[Sysname-wlan-mshp-1] mesh-id outdoor
[Sysname-wlan-mshp-1] mesh-profile enable
·     bind wlan-mesh
·     mesh-id
·     mesh-profile
mesh peer-mac-address
Use mesh peer-mac-address to specify the MAC address of a peer.
Use undo mesh peer-mac-address to remove the configuration.
mesh peer-mac-address mac-address [ cost cost ]
undo mesh peer-mac-address { mac-address | all }
No peer MAC address is specified. All peers are permitted for link formation, and the cost of the mesh link to the peer is automatically calculated.
Radio view
2: System level
mac-address: Specifies the MAC address of a peer MP.
all: Removes all peer MAC addresses.
cost cost: Specifies the cost of the mesh link to the specified peer. It is in the range of 1 to 65535.
You can specify up to 8 peer MAC addresses.
# Configure the MAC address of a peer MP for AP 3, and configure the link cost for the mesh link as 20000.
[Sysname] wlan ap ap3 model WA3628i-AGN
[Sysname-wlan-ap-ap3] radio 1 type dot11an
[Sysname-wlan-ap-ap3-radio-1] mesh peer-mac-address 0023-8980-569b cost 20000
mkd-service enable
Use mkd-service enable to enable the mesh key distributor (MKD) service for the specific mesh profile.
Use undo mkd-service enable to disable the MKD service for the specific mesh profile.
mkd-service enable mesh-profile mesh-profile-number
undo mkd-service enable mesh-profile mesh-profile-number
The MKD service is disabled for all mesh profiles.
2: System level
mesh-profile-number: Specifies the mesh profile number in the range of 1 to 32.
# Enable the MKD service for mesh profile 1.
[Sysname]wlan mesh-profile 1
[Sysname-wlan-mshp-1]quit
[Sysname] mkd-service enable mesh-profile 1
mlsp enable
Use mlsp enable to enable mesh link switch protocol (MLSP) on the radio.
Use undo mlsp enable to disable MLSP on the radio.
mlsp enable
undo mlsp enable
MLSP is disabled.
MP policy view
2: System level
·     MLSP is used for switching between the active and dormant links.
·     This command is used for subway WLAN mesh deployment.
·     When MLSP is disabled on the radio, the MLSP proxy MAC address configured under the current MP policy is removed.
# Enable MLSP for MP policy sys_mp.
[Sysname-wlan-mp-policy-sys_mp] mlsp enable
mlsp-proxy
Use mlsp-proxy to configure MLSP proxy for a connected device on an MP.
Use undo mlsp-proxy to remove the configuration.
mlsp-proxy mac-address mac-address [ vlan vlan-id ] [ ip ip-address ]
undo mlsp-proxy mac-address { all | mac-address }
No MLSP proxy is configured.
MP policy view
2: System level
mac-address mac-address: Specifies the MAC address of the device connected to the MP.
vlan vlan-id: Specifies the VLAN where the device connected to the MP resides by VLAN ID, which is in the range of 1 to 1094 and defaults to 1.
ip ip-address: Specifies the IP address of the device connected to the MP.
all: Removes MLSP proxy configuration for all devices .
This command is available only when MLSP is enabled.
# Configure MLSP proxy for the device with MAC address 000f-e287-8700 in VLAN 10.
[Sysname-wlan-mp-policy-sys_mp] mlsp-proxy mac-address 000f-e287-8700 vlan 10
# Configure MLSP proxy for the device with MAC address 000f-e287-8700 and IP address 1.1.1.1 in VLAN 10.
[Sysname-wlan-mp-policy-sys_mp] mlsp-proxy mac-address 000f-e287-8700 vlan 10 ip 1.1.1.1
mp-policy
Use mp-policy to bind the MP policy to the current radio.
Use undo mp-policy to restore the default.
mp-policy policy-name
undo mp-policy
The radio adopts the default MP policy default_mp_plcy.
Radio-Template view
2: System level
policy-name: Specifies the name of the MP policy bound to the current radio. MP policy name is a case-insensitive string of 1 to 15 characters, which can contain letters, digits, and underlines.
·     Only one MP policy can be bound to the radio.
·     To remove an MP policy-radio binding, disable the radio first. After you unbind an MP policy to a radio, the default MP policy is bound to the radio automatically.
·     You cannot map the default MP policy.
# Bind the MP policy sys_mp to radio 1.
[Sysname-wlan-ap-ap1-radio-1] mp-policy sys_mp
portal-service enable
Use portal-service enable to enable the portal service.
Use undo portal-service enable to disable the portal service.
The portal service is disabled.
AP-Template view
2: System level
# Enable the portal service to the MP ap1.
[Sysname-wlan-ap-ap1] portal-service enable
probe-request-interval
Use probe-request-interval to configure the probe request interval.
Use undo probe-request-interval to restore the system default.
probe-request-interval interval-value
The probe request interval is 1000 ms.
Mesh profile view
2: System level
interval-value: Specifies the probe request interval in the range of 100 to 8191, in ms.
# Set the probe request interval to 500 ms for MP policy sys_mp.
[Sysname-wlan-mp-policy-sys_mp] probe-request-interval 500
role-authenticator enable
Use role-authenticator enable to enable the device to play the role of an authenticator based on negotiation results.
Use undo role-authenticator enable to disable the device to play the role of an authenticator. The device will always be a supplicant.
Whether a device plays the role of an authenticator is based on negotiation results.
MP policy view
2: System level
# Set authenticator role for an MP policy as sys_mp.
[Sysname-wlan-mp-policy-sys_mp] role-authenticator enable
signal
Use signal to specify the mesh signal transmission media.
Use undo signal to restore the default.
signal { air | wave-guide }
undo signal
The mesh signal transmission media is air.
MP policy view
2: System level
air: Specifies the transmission media as air.
wave-guide: Specifies the transmission media as waveguides.
# Specify the mesh signal transmission media as waveguides.
[Sysname] wlan mp-policy 1
[Sysname-wlan-mp-policy-1]signal wave-guide
temporary-link enable
Use temporary-link enable to enable the temporary link function.
Use undo temporary-link enable to disable the temporary link function.
The temporary link function is enabled.
MP policy view
2: System level
# Disable the temporary link function.
[Sysname-wlan-mp-policy-1]undo temporary-link enable
waveguide-to-air
Use waveguide-to-air to set the air-transmitted RSSI threshold for an MP to switch the transmission media from waveguide to air.
Use undo waveguide-to-air to restore the default.
waveguide-to-air rssi-threshold rssi-threshold
undo waveguide-to-air rssi-threshold
The air-transmitted RSSI threshold is 20 for switching the transmission media from waveguide to air.
MP policy view
2: System level
rssi-threshold: Specifies the threshold in the range of 5 to 150 dbm.
This feature enables an MP to switch the mesh signal transmission media from waveguide to air if the detected air-transmitted signal strength is higher than the specified threshold.
Make sure the configured threshold is higher than the link hold RSSI and lower than the link saturation RSSI.
# Set the air-transmitted signal strength threshold to 30 for an MP to switch the media from waveguide to air.
[Sysname-wlan-mp-policy-1] waveguide-to-air rssi-threshold 30
link-hold-rssi
wlan mesh-link-test
Use wlan mesh-link-test to perform mesh link test on the specified AP and display the test results five seconds later.
wlan mesh-link-test ap-name
1: Monitor level
ap-name: Specifies the name of the AP, a case-insensitive string of 1 to 64 characters.
# Perform mesh link test on AP 1.
<Sysname> wlan mesh-link-test ap1
Testing mesh link of ap1, press CTRL_C to break.....done.
AP Name:  ap1
00ef-2231-0b4a   00aa-4433-6699   Forwarding    54     231/14234
Table 5 Command output
Peer
Local
Local MAC address.
Status
·     Forwarding.
·     Discarding.
RSSI
Received signal strength indication, which indicates the AP signal strength detected by the mesh peer.
Packets(Rx/Tx)
wlan mesh-profile
Use wlan mesh-profile to create a mesh profile and enter mesh profile view.
Use undo wlan mesh-profile to delete the specified mesh profile.
wlan mesh-profile mesh-profile-number
undo wlan mesh-profile mesh-profile-number
2: System level
The properties of a mesh profile can be changed only when it is disabled.
# Create mesh profile 1 and enter mesh profile 1 view.
·     bind wlan-mesh
·     mesh-id
·     link-keep-alive
·     mesh-profile enable
·     link-backhaul-rate
wlan mkd-id
Use wlan mkd-id to configure the MKD ID.
Use undo wlan mkd-id to remove the MKD ID.
wlan mkd-id mkd-id
undo wlan mkd-id
The MKD ID is 000F-E200-0001.
2: System level
mkd-id: Specifies the MKD ID, which is a MAC address.
·     Make sure the MAC address configured is unused and has the correct vendor specific part.
·     The MAC address of an AC cannot be configured as the MKD ID.
# Configure the MKD ID as 00-0f-e2-00-00-02.
[Sysname] wlan mkd-id 000f-e200-0002
wlan mp-policy
Use wlan mp-policy to create an MP policy and enter MP policy view.
Use undo wlan mp-policy to delete the specified MP policy.
wlan mp-policy policy-name
undo wlan mp-policy policy-name
There is a default MP policy default_mp_plcy.
2: System level
policy-name: Specifies an MP policy by its name, a case-insensitive string of 1 to 15 characters.
The name of an MP policy cannot be a, al, all, and default_mp_plcy.
Modification or deletion of default MP policy named default_mp_plcy is not allowed.
You cannot delete an MP policy if it has been mapped to a radio.
You cannot change the properties of an MP policy if the radio to which the policy has mapped has been enabled.
# Create an MP policy named sys_mp and enter MP policy view.
·     link-initiation enable
·     link-maximum-number
·     probe-request-interval
·     mlsp enable
·     role-authenticator enable
