- 02-WLAN Command Reference
- 01-WLAN Interface Commands
- 02-WLAN Access Commands
- 03-WLAN Security Commands
- 04-IACTP Tunnel and WLAN Roaming Commands
- 05-WLAN RRM Commands
- 06-WLAN IDS Commands
- 07-WLAN QoS Commands
- 08-WLAN Mesh Link Commands
- 09-Advanced WLAN Commands
- 10-WLAN High Availability Commands
- 11-WLAN IPS Commands
- 12-WLAN Optimization Commands
| 03-WLAN Security Commands | 74.21 KB |
WLAN security configuration commands
authentication-method
Use authentication-method to enable an 802.11 authentication method. You can enable open system authentication, shared key authentication, or both.
Use undo authentication-method to disable the authentication method.
authentication-method { open-system | shared-key }
undo authentication-method { open-system | shared-key }
The open system authentication method is enabled.
Service template view
Default command level
2: System level
open-system: Enables open system authentication.
shared-key: Enables shared key authentication.
# Enable open system authentication.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] authentication-method open-system
# Enable shared key authentication.
[Sysname] wlan service-template 1 crypto
[Sysname-wlan-st-1] authentication-method shared-key
cipher-suite
Use cipher-suite to select the cipher suite used in the encryption of frames.
Use undo cipher-suite to disable the selected cipher suite.
cipher-suite { ccmp | tkip | wep40 | wep104 | wep128 }*
undo cipher-suite { ccmp | tkip | wep40 | wep104 | wep128 }*
No cipher suite is selected.
2: System level
ccmp: Enables the AES-CCMP cipher suite.
tkip: Enables the TKIP cipher suite.
wep40: Enables the WEP-40 cipher suite.
wep104: Enables the WEP-104 cipher suite.
wep128: Enables the WEP-128 cipher suite.
# Enable the TKIP cipher suite.
[Sysname-wlan-st-1] cipher-suite tkip
dot1x supplicant eap-method
Use dot1x supplicant eap-method to specify an 802.1X client EAP authentication method.
Use undo dot1x supplicant eap-method to restore the default.
dot1x supplicant eap-method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
MD5 authentication is used as the 802.1X client EAP authentication method.
AP provision view
2: System level
md5: Specifies the MD5 EAP authentication method.
peap-gtc: Specifies the PEAP-GTC EAP authentication method.
peap-mschapv2: Specifies the PEAP-MSCHAPv2 EAP authentication method
ttls-gtc: Specifies the TTLS-GTC EAP authentication method.
ttls-mschapv2: Specifies the TTLS-MSCHAPv2 EAP authentication method.
# Specify MD5 as the 802.1X client EAP authentication method for AP ap1.
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant eap-method md5
dot1x supplicant enable
Use dot1x supplicant enable to enable the 802.1X client feature.
Use undo dot1x supplicant enable to restore the default.
The 802.1X client feature is disabled.
AP provision view
2: System level
# Enable the 802.1X client feature for AP ap1.
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant enable
dot1x supplicant password
Use dot1x supplicant password to set the 802.1X client authentication password.
Use undo dot1x supplicant password to restore the default.
dot1x supplicant password { cipher | simple } password
No 802.1X client authentication password is set for an AP.
AP provision view
2: System level
simple: Specifies a password in plaintext form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 127 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
# Set the 802.1X client password to 123456 in plaintext form for AP ap1.
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant supplicant password simple 123456
dot1x supplicant username
Use dot1x supplicant username to configure an 802.1X client username.
Use undo dot1x supplicant username to restore the default.
dot1x supplicant username username
No 802.1X client username exists.
AP provision view
2: System level
username: Specifies the 802.1X client username, a case-sensitive string of 1 to 253 characters.
# Configure the 802.1X client username as aaa for AP ap1.
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant username aaa
gtk-rekey client-offline enable
Use gtk-rekey client-offline enable to enable refreshing the GTK when a client goes offline. This function is effective when GTK rekey is enabled with the gtk-rekey enable command.
Use undo gtk-rekey client-offline to disable this feature.
The GTK is not refreshed when a client goes off-line.
2: System level
# Enable GTK rekeying when a client goes off-line.
[Sysname-wlan-st-1] gtk-rekey client-offline enable
gtk-rekey enable
Use gtk-rekey enable to enable GTK rekey.
Use undo gtk-rekey enable to disable GTK rekey.
gtk-rekey enable
GTK rekey is enabled.
2: System level
# Disable GTK rekey.
[Sysname-wlan-st-1] undo gtk-rekey enable
gtk-rekey method
Use gtk-rekey method to select a mechanism for rekeying the GTK. If option time-based is selected, the GTK will be refreshed after a specified period of time. If option packet-based is selected, the GTK will be refreshed after a specified number of packets are transmitted.
Use undo gtk-rekey method to restore the default.
gtk-rekey method { packet-based [ packet ] | time-based [ time ] }
The GTK rekeying method is time-based, and the interval is 86400 seconds.
2: System level
packet-based: Indicates the GTK will be refreshed after a specified number of packets are transmitted.
packet: Number of multicast packets that are transmitted before the GTK is refreshed. The value is in the range of 5000 to 4294967295 and defaults to 10000000.
time-based: Indicates the GTK will be refreshed based on time.
time: Time after which the GTK is refreshed. The value is in the range of 180 to 604800 seconds defaults to 86400 seconds.
The method configured most recently overwrites the previous method. For example, if you configure the packet-based method and then configure the time-based method, the time-based method is enabled.
# Enable packet-based GTK rekeying and the packet number is 60000.
[Sysname-wlan-st-1] gtk-rekey method packet-based 60000
key-derivation
Use key-derivation to specify a key derivation type.
Use undo key-derivation to restore the default.
key-derivation { sha1 | sha1-and-sha256 | sha256 }
undo key-derivation
The key derivation type is sha1.
2: System level
sha1: Specifies the HMAC-SHA1 hash algorithm.
sha1-and-sha256: Specifies the HMAC-SHA1 and the HMAC-SHA256 hash algorithms.
sha256: Specifies the HMAC-SHA256 hash algorithm.
A key derivation type takes effect only when the authentication type is PSK or 802.1X.
If the management frame protection status is mandatory, H3C recommends that you specify the key derivation type as sha256.
# Specify the key derivation type as sha1-and-sha256.
[Sysname-wlan-st-1] key-derivation sha1-and-sha256
pmf
Use pmf to configure management frame protection.
Use undo pmf to disable management frame protection.
pmf { mandatory | optional }
undo pmf
Management frame protection is disabled.
2: System level
mandatory: Allows only clients supporting PMF to associate with the AP.
optional: Allows all clients to associate with the AP.
# Enable PMF to allow all clients to associate with the AP.
[Sysname-wlan-st-1] pmf mandatory
pmf association-comeback
Use pmf association-comeback to configure the association comeback time.
Use undo pmf association-comeback to restore the default.
pmf association-comeback value
The association comeback time is 1 second.
2: System level
value: Specifies the association comeback time in the range of 1 to 20 seconds. Within the association comeback time, the AP does not respond to any association or reassociation requests from the client.
# Configure the association comeback time as 2 seconds.
[Sysname-wlan-st-1] pmf association-comeback 2
· pmf
· pmf saquery retry
· pmf saquery timeout
pmf saquery retry
Use pmf saquery retry to configure the retransmission time for the AP to send SA Query requests.
Use undo pmf saquery retry to restore the default.
pmf saquery retry value
The retransmission time for the AP to send SA Query requests is 4.
2: System level
value: Specifies the retransmission time for the AP to send SA Query requests, in the range of 1 to 16.
# Configure the retransmission time for the AP to send SA Query requests as 3.
[Sysname-wlan-st-1] pmf saquery retry 3
· pmf
· pmf association-comeback
pmf saquery timeout
Use pmf saquery timeout to configure the timeout time for SA Query responses.
Use undo pmf saquery timeout to restore the default.
pmf saquery timeout value
The timeout time for SA Query responses is 200 milliseconds.
2: System level
value: Specifies the timeout time for SA Query responses, in the range of 100 to 500 milliseconds. If the AP does not receive any SA Query responses from the client within the timeout time, the AP resends the SA Query request.
# Configure the timeout time for SA Query responses as 300 milliseconds.
[Sysname-wlan-st-1] pmf saquery timeout 300
· pmf
· pmf saquery retry
ptk-lifetime
Use ptk-lifetime to configure the PTK lifetime.
Use undo ptk-lifetime to restore the default.
ptk-lifetime time
undo ptk-lifetime
The PTK lifetime is 43200 seconds.
2: System level
time: Specifies the PKI lifetime in the range of 180 to 604800 seconds.
# Specify the PTK lifetime as 86400 seconds.
[Sysname-wlan-st-1] ptk-lifetime 86400
security-ie
Use security-ie to enable the WPA-IE, RSN-IE, or both in beacon and probe responses.
Use undo security-ie to disable the WPA-IE or RSN-IE in beacon and probe responses.
security-ie { rsn | wpa }
undo security-ie { rsn | wpa }
Both WPA-IE and RSN-IE are disabled.
2: System level
rsn: Enables the RSN information element in beacon and probe response frames. The RSN IE advertises the RSN capabilities of APs.
wpa: Enables the WPA Information element in beacon and probe response frames. The WPA IE advertises the WPA capabilities of APs.
# Enable the WPA-IE in beacon and probe responses.
[Sysname-wlan-st-1] security-ie wpa
tkip-cm-time
Use tkip-cm-time to set the TKIP countermeasure time.
Use undo tkip-cm-time to restore the default.
tkip-cm-time time
undo tkip-cm-time
The TKIP countermeasure time is 0 seconds. No countermeasures are taken.
2: System level
time: TKIP countermeasure time in seconds. The value is in the range of 0 to 3600 seconds.
If more than two MIC failures occur within a certain time after TKIP countermeasures are enabled, the TKIP associations are disassociated, and new associations can be established only after the specified TKIP countermeasure time expires.
# Set the TKIP countermeasure time to 90 seconds.
[Sysname-wlan-st-1] tkip-cm-time 90
wep default-key
Use wep default-key to configure the WEP default key.
Use undo wep default-key to delete the configured WEP default key.
wep default-key key-index { wep40 | wep104 | wep128} { pass-phrase | raw-key } [ cipher | simple ] key
undo wep default-key key-index
The WEP default key index number is 1.
2: System level
key-index: The key index values can be:
1: Configures the 1st WEP default key.
2: Configures the 2nd WEP default key.
3: Configures the 3rd WEP default key.
4: Configures the 4th WEP default key.
wep40: Indicates the WEP40 key option.
wep104: Indicates the WEP104 key option.
wep128: Indicates the WEP128 key option.
pass-phrase: Inputs a character-string pre-shared key.
raw-key: Inputs a hexadecimal-string pre-shared key.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key.
key: Specifies the key string. The length of a ciphertext key is in the range of 24 to 88 characters. If neither cipher nor simple is specified, you set a plaintext key string. The length of a plaintext key depends on the key options selected:
· For wep40 pass-phrase, the key length is 5 alphanumeric characters.
· For wep104 pass-phrase, the key length is 13 alphanumeric characters.
· For wep128 pass-phrase, the key length is 16 alphanumeric characters.
· For wep40 raw-key, the key length is a 10-digit hexadecimal number.
· For wep104 raw-key, the key length is a 26-digit hexadecimal number.
· For wep128 raw-key, the key length is a 32-digit hexadecimal number.
When security IE is configured, WEP default key 1 is not allowed for configuration.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
# Specify the first WEP default key as a simple text key 12345.
[Sysname-wlan-st-1] wep default-key 1 wep40 pass-phrase simple 12345
wep key-id
Use wep key-id to specify the default WEP key used in the encryption and decryption of broadcast and multicast frames. There are four static keys in WEP. The key index can be 1, 2, 3, or 4. The key corresponding to the specified key index will be used for encrypting and decrypting broadcast and multicast frames.
Use undo wep key-id to restore the default.
wep key-id { 1 | 2 | 3 | 4 }
undo wep key-id
The key index number is the one configured with the wep default-key command.
2: System level
1: Specifies key index 1.
2: Specifies key index 2.
3: Specifies key index 3.
4: Specifies key index 4.
# Specify the index of the key for broadcast/multicast encryption and decryption as 2.
[Sysname-wlan-st-1] wep key-id 2
wep default-key
wep mode
Use wep mode to enable WEP encryption.
Use undo wep mode to restore the default.
wep mode dynamic
undo wep mode
Static WEP encryption is enabled.
2: System level
dynamic: Enables dynamic WEP encryption.
Dynamic WEP encryption must be used together with 802.1X authentication, and the WEP key ID cannot be configured as 4.
The device automatically uses the WEP 104 encryption method when dynamic WEP encryption is configured. To change the encryption method, use the cipher-suite command.
The WEP key used to encrypt unicast frames is negotiated between client and server when dynamic WEP encryption is configured. If the WEP default key is configured, the WEP default key is used to encrypt multicast frames. If the WEP default key is not configured, the device randomly generates a multicast WEP key.
# Specify the WEP encryption mode as dynamic.
[Sysname-wlan-st-1] wep mode dynamic
· wep key-id
· cipher-suite
