- 02-WLAN Command Reference
- 01-WLAN Interface Commands
- 02-WLAN Access Commands
- 03-WLAN Security Commands
- 04-IACTP Tunnel and WLAN Roaming Commands
- 05-WLAN RRM Commands
- 06-WLAN IDS Commands
- 07-WLAN QoS Commands
- 08-WLAN Mesh Link Commands
- 09-Advanced WLAN Commands
- 10-WLAN High Availability Commands
- 11-WLAN IPS Commands
- 12-WLAN Optimization Commands
| 06-WLAN IDS Commands | 111.12 KB |
WLAN IDS configuration commands
WLAN IDS rogue detection configuration commands
countermeasures on-service interval
display wlan ids rogue-history
WLAN IDS attack detection configuration commands
Blacklist and whitelist configuration commands
countermeasures enable
Use countermeasures enable to enable countermeasures against rogue devices present in the attack list.
Use undo countermeasures enable to restore the default.
No countermeasures are enabled.
WLAN IDS view
Default command level
2: System level
# Enable countermeasures.
[Sysname] wlan ids
[Sysname-wlan-ids] countermeasures enable
countermeasures mode
Use countermeasures mode to set the countermeasures mode.
Use undo countermeasures mode to restore the default.
countermeasures mode { all | { rogue | adhoc | config }* }
The countermeasures mode is config.
WLAN IDS view
2: System level
all: Takes countermeasures against all rogue devices present in the attack list.
rogue: Takes countermeasures against all rogue APs and clients.
adhoc: Takes countermeasures against all rogue ad hoc devices.
config: Takes countermeasures against statically configured rogue devices.
Wireless bridge devices are classified as rogues. Countermeasures are not taken against rogue wireless bridges.
# Set the countermeasures mode to rogue.
[Sysname] wlan ids
[Sysname-wlan-ids] countermeasures mode rogue
Use countermeasures on-service interval to configure the interval at which the AP takes countermeasures against rogue devices and the maximum number of devices against which the AP can take countermeasures.
Use undo countermeasures on-service to restore the default.
countermeasures on-service interval interval [ max-device max-device ]
WLAN IDS view
2: System level
interval: Specifies the interval at which the AP takes countermeasures against rogue devices, in the range of 100 to 5000 milliseconds. By default, the value is 5000 milliseconds.
max-device: Specifies the maximum number of devices against which the AP can take countermeasures, in the range of 1 to 256. By default, the value is 256.
# Configure the interval at which the AP takes countermeasures against rogue devices as 1000 milliseconds and the maximum number of devices against which the AP can take countermeasures as 5.
[Sysname] wlan ids
[Sysname-wlan-ids] countermeasures on-service interval 1000 max-device 5
device aging-duration
Use device aging-duration to set the age time for entries in the detected device table.
Use undo device aging-duration to restore the default.
device aging-duration duration
The age time is 600 seconds.
WLAN IDS view
2: System level
duration: Interval, in the range of 300 to 1800 seconds.
If an entry is not detected within the interval, it is deleted from the detected device table. If the deleted entry is that of a rogue, it is added to the rogue history table.
# Specify the age time for device entries as 1200 seconds.
[Sysname] wlan ids
[Sysname-wlan-ids] device aging-duration 1200
device attack mac-address
Use device attack mac-address to add an entry to the static attack list.
Use undo device attack mac-address to remove the specified entry or all entries from the static attack list.
device attack mac-address mac-address
undo device attack mac-address [ mac-address ]
WLAN IDS view
2: System level
mac-address: MAC address of an AP or client.
The maximum number of entries in the static attack list is 64.
# Add a MAC address to, and then remove it from, the static attack list.
[Sysname] wlan ids
[Sysname-wlan-ids] device attack mac-address aabb-cc00-0001
[Sysname-wlan-ids] undo device attack mac-address aabb-cc00-0001
# Remove all entries from the static attack list.
[Sysname] wlan ids
device permit
Use device permit to add an entry to the permitted MAC address list, permitted SSID list, or permitted vendor list.
Use undo device permit to remove a specified entry, or, if no entry is specified, all entries from the permitted MAC address list, permitted SSID list, or permitted vendor list.
device permit { mac-address mac-address | ssid ssid | vendor oui }
undo device permit { mac-address [ mac-address ] | ssid [ ssid ] | vendor [ oui ] }
WLAN IDS view
2: System level
mac-address: MAC address of an AP or client, such as known devices which are to be ignored during RF scan. The maximum number of entries in the permitted MAC address list is 256.
ssid: SSID to be added to the permitted SSID list, a case-sensitive string of characters. It is in the range of 1 to 32. The maximum number of entries in the permitted SSID list is 256.
oui: OUI of an AP, a string of six hexadecimal digits. The maximum number of entries in the permitted vendor list is 64.
# Add a MAC address to the MAC address list and then remove it from the list.
[Sysname] wlan ids
[Sysname-wlan-ids] device permit mac-address aabb-cccc-dddd
[Sysname-wlan-ids] undo device permit mac-address aabb-cccc-dddd
device-detection enable
Use device-detection enable to set the AP to operate in hybrid mode.
Use undo device-detection enable to restore the default.
The AP operates in normal mode and only provides WLAN data services. For an AP in monitor mode, this command is invisible.
AP template view, AP group view
2: System level
Support for this command depends on the device model. For more information, see About the H3C Access Controllers Command References.
If an AP is operating in hybrid mode, configure a service template for the AP.
Executed in AP template view, this command applies to the specified AP.
Executed in AP group view, this command applies to all APs in an AP group.
# Set an AP to operate in hybrid mode.
[Sysname] wlan ap 2 model WA3628i-AGN
[Sysname-wlan-ap2] device-detection enable
# Set all APs in AP group office to operate in hybrid mode.
[Sysname] wlan ap-group office
[Sysname-ap-group-office] device-detection enable
display wlan ids attack-list
Use display wlan ids attack-list to display attack list information in the order of MAC address.
display wlan ids attack-list { config | all | ap ap-name } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
config: Displays the static attack list.
all: Displays the dynamic attack list established based on the rules for detection of rogue devices, for all APs. If the number of entries for an AP exceeds 256, only the first 256 entries will be sent and present in the attack list of that AP.
ap ap-name: Displays dynamic attack list information about the specified AP. Its name is a string of characters. If the number of entries for the AP exceeds 256, only the first 256 entries will be sent and present in the attack list of the AP.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display dynamic attack list information for all APs.
<Sysname> display wlan ids attack-list all
Total Number of Entries: 2
Flags: a = adhoc, w = ap, c = client
#AP = number of active APs detecting, Ch = channel number
Attack List - All
MAC Address type #AP Ch Last Detected Time SSID
0009-5b94-2fb0 --c 1 1 2012-05-16/14:16:05 -
001b-1109-a32b --c 1 5 2012-05-16/14:16:17 -
MAC address |
MAC address of the device that is to be attacked by the monitor AP. |
Flags |
Type of the device, which can be ad hoc, AP, or client. |
#AP |
Number of active APs that detect the device. If WIDS is enabled on multiple APs, these APs may detect the same device. |
Ch |
Channel in which the device was last detected. |
Last Detected Time |
Time at which the entry was last detected. |
SSID |
Service set identifier for the ESS of the entry. |
# Display attack list information for AP 6.
<Sysname> display wlan ids attack-list ap ap6
Total Number of Entries: 22
Attack List - AP
MAC Address type #AP Ch Last Detected SSID
000b-6b8f-fc6a --c 1 11 2012-01-22/15:33:21 -
000f-e000-0052 -w- 1 10 2012-01-22/15:33:58 "xxxx-xxxx-xxxx"
000f-e200-0000 -w- 1 9 2012-01-22/15:33:59 "6103_kaifang"
000f-e200-0001 -w- 1 9 2012-01-22/15:33:59 "6103_youxian"
000f-e200-0002 -w- 1 9 2012-01-22/15:33:59 "6103_zhengshu"
000f-e200-0003 -w- 1 9 2012-01-22/15:33:59 "6103_zhengshu+WPA2"
000f-e200-00a2 --c 1 9 2012-01-22/15:33:29 -
000f-e25d-f4b0 -w- 1 9 2012-01-22/15:33:58 "6103_kaifang"
000f-e25d-f4b1 -w- 1 9 2012-01-22/15:33:59 "6103_youxian"
000f-e25d-f4b2 -w- 1 9 2012-01-22/15:33:59 "6103_zhengshu"
000f-e25d-f4b3 -w- 1 9 2012-01-22/15:33:59 "6103_zhengshu+WPA2"
000f-e26c-2250 -w- 1 11 2012-01-22/15:33:59 "bjwifidata"
000f-e26c-2251 -w- 1 11 2012-01-22/15:33:58 "bjwifivoice"
000f-e26c-2252 -w- 1 11 2012-01-22/15:33:58 "voice"
000f-e26c-28d0 -w- 1 11 2012-01-22/15:33:58 "wyg3000"
000f-e278-8020 -w- 1 6 2012-01-22/15:33:58 "test11"
000f-e278-8181 -w- 1 7 2012-01-22/15:33:59 "nsw-wep"
000f-e27b-3f80 -w- 1 6 2012-01-22/15:33:38 "ytj-a"
000f-e27b-4230 -w- 1 4 2012-01-22/15:33:58 "test2"
0011-9548-4007 --c 1 7 2012-01-22/15:33:49 -
0019-5bcf-cce3 --c 1 5 2012-01-22/15:33:25 -
001a-9228-2d3e --c 1 11 2012-01-22/15:33:53 -
See Table 1 for related information.
display wlan ids detected
Use display wlan ids detected to display detected devices in the WLAN in the order of MAC address or SSID.
display wlan ids detected { all | rogue { ap | client } | adhoc | ssid | mac-address mac-address } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays all devices detected (rogues and friends) in the WLAN.
rogue: Displays rogue devices detected (AP or clients) in the WLAN.
ap: Displays all rogue APs detected in the WLAN.
client: Displays all rogue clients detected in the WLAN.
adhoc: Displays clients that belong to adhoc networks detected in the WLAN.
ssid: Displays all SSIDs detected in the WLAN.
mac-address mac-address: Displays information about an AP or client.
# Display information about all detected devices.
<Sysname> display wlan ids detected all
Total Number of Entries : 18
Flags: r = rogue, p = permit, a = adhoc, w = ap, b = wireless-bridge,
c = client
Detected Device(s) List
MAC Address Vendor Type #AP Ch Last Detected SSID
000f-e281-1322 XEROX CORP... -p-w- 1 4 2012-05-16/10:49:15 "cyh-psk2"
000f-e281-1323 XEROX CORP... -p-w- 1 4 2012-05-16/10:49:05 "cyh-ccmp"
000f-e281-1460 XEROX CORP... -p-w- 1 6 2012-05-16/10:49:26 "fl"
000f-e281-1461 XEROX CORP... -p-w- 1 6 2012-05-16/10:49:26 "fg2"
0012-f0cc-4789 XEROX CORP... -p--c 1 1 2012-05-16/10:49:11 -
0013-f702-dbd2 XEROX CORP... -p--c 1 7 2012-05-16/10:46:58 -
0016-6f99-fbf6 XEROX CORP... -p--c 1 11 2012-05-16/10:49:02 -
0016-6f99-fc21 XEROX CORP... -p--c 1 6 2012-05-16/10:49:25 -
0017-9a00-7986 XEROX CORP... -p--c 1 8 2012-05-16/10:48:04 -
0017-9a00-79bd XEROX CORP... -p--c 1 7 2012-05-16/10:47:18 -
0017-9a00-7b47 XEROX CORP... r---c 1 10 2012-05-16/10:48:49 -
0017-9a00-7cb8 XEROX CORP... -p--c 1 1 2012-05-16/10:49:20 -
0019-5bcf-ccfd XEROX CORP... -p--c 1 11 2012-05-16/10:49:24 -
001b-111d-b46f XEROX CORP... -p--c 1 6 2012-05-16/10:48:56 -
001c-f017-41dc XEROX CORP... -p--c 1 6 2012-05-16/10:48:00 -
001c-f017-41dd XEROX CORP... -p--c 1 6 2012-05-16/10:49:19 -
001d-0f32-4305 XEROX CORP... -p--c 1 1 2012-05-16/10:48:33 -
0810-741a-1b4c XEROX CORP... -p--c 1 11 2012-05-16/10:49:04 -
MAC Address |
MAC address of the device detected. |
Vendor |
Vendor of the detected device. |
Flags |
Whether the device detected is an AP, wireless bridge, ad hoc, or client, and whether it is permitted or a rogue. |
#AP |
Ch |
Last Detected |
SSID |
# Display information about detected rogue APs.
<Sysname> display wlan ids detected rogue ap
Total Number of Entries : 6
Detected Rogue AP(s) List
MAC Address Vendor #AP Ch Last Detected Time SSID
000B-8580-738F Aires... 1 10 2012-03-16/12:44:11 "Diamond"
000F-E212-1230 Hangz... 1 5 2012-03-16/12:44:11 "1"
000F-E234-0200 Hangz... 1 11 2012-03-16/12:44:11 "VClear"
000F-E2AA-CC04 Hangz... 1 12 2012-03-16/12:44:11 "baba"
000F-E2BB-CCD0 Hangz... 1 1 2012-03-16/12:44:11 "Rogue AP Team B..."
000F-E2F2-2230 Hangz... 1 7 2012-03-16/12:44:11 "int-RT"
See Table 2 for the command output description.
# Display information about the detected rogue clients.
<Sysname> display wlan ids detected rogue client
Detected Rogue Client(s) List
MAC Address Vendor #AP Ch Last Detected SSID
0017-9a00-7b47 XEROX CORP... 1 9 2012-05-16/10:49:30 -
# Display information about all the detected adhoc devices.
<Sysname> display wlan ids detected adhoc
Total Number of Entries : 4
#AP = number of active APs, Ch = channel number
Detected Adhoc(s) List
000F-E212-1230 Hangz... 1 5 2012-03-16/12:44:11 -
000F-E234-0200 Hangz... 1 11 2012-03-16/12:44:11 -
000F-E2AA-CC04 Hangz... 1 12 2012-03-16/12:44:11 -
000F-E2BB-CCD0 Hangz... 1 1 2012-03-16/12:44:11 -...
# Display information about all detected SSIDs.
<Sysname> display wlan ids detected ssid
Total Number of Entries : 7
#Device = number of devices using SSID
Detected SSID List
SSID #Device Last Detected Time
"Crywep" 1 2012-03-16/12:44:37
"H3COMTEST11" 1 2012-03-16/12:44:37
"autowep" 2 2012-03-16/12:44:37
"baba" 2 2012-03-16/12:44:37
"s1" 1 2012-03-16/12:44:37
"s2" 1 2012-03-16/12:44:37
"s4crypto" 1 2012-03-16/12:43:48
# Display the detailed information about a device detected.
<Sysname> display wlan ids detected mac-address 000F-E2BB-CCD0
Detected Device Profile
MAC Address : 000F-E2BB-CCD0
BSSID : 000F-E2BB-CCD0
Type : Rogue-AP
SSID : "H3C"
Vendor : New H3C Tech. Co., Ltd
Number of APs detected it : 2
Channel : 11
Maximum RSSI Detected : 47
Beacon Interval : 100
First Detected(yyyy-mm-dd/hh:mm:ss) : 2012-03-16/11:32:54
Reported AP 1
MAC Address : 000F-E210-2000
AP Name : ap1
Radio Type : 11g
RSSI : 75
Last Detected(yyyy-mm-dd/hh:mm:ss): 2012-03-16/12:43:37
Reported AP 2:
MAC Address : 000F-E210-2001
AP Name : ap12
Radio Type : 11g
RSSI : 75
Last Detected(yyyy-mm-dd/hh:mm:ss): 2012-03-16/12:44:37
MAC Address |
BSSID |
Basic service set identifier of the detected device. |
Type |
Whether the device detected is an AP, wireless bridge, ad hoc device, or client, and whether it is permitted or a rogue. |
SSID |
Vendor |
Vendor for the detected device. |
Number of APs detected it |
Number of active APs that detected the device. If WIDS is enabled on multiple APs, these APs may detect the same device. In this output, the value indicates that there are two APs detecting the device with the MAC address 000F-E2BB-CCD0, and considering the device as a rogue device. |
Channel |
RSSI |
Maximum detected RSSI of the device. |
Beacon Interval |
Beacon interval for the detected AP. |
First Detected |
Time at which the entry was first detected. |
Mac Address |
MAC address of the AP that detected the device. |
AP name |
Name of the AP. |
Radio type |
Radio type of the AP. |
RSSI |
Last Detected (yyyy-mm-dd/hh:mm:ss) |
Time at which the rogue AP was detected. |
display wlan ids permitted
Use display wlan ids permitted to display the list of permitted MAC addresses, permitted SSIDs, or permitted vendor OUIs.
display wlan ids permitted { mac-address | ssid | vendor } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
mac-address: Displays the permitted MAC address list.
ssid: Displays the permitted SSID list.
vendor: Displays the permitted vendor OUI list.
# Display the permitted MAC-address list.
<Sysname> display wlan ids permitted mac-address
Total Number of Entries: 4
Flags: a = adhoc, w = ap, b = wireless-bridge, c = client
Permitted Mac Address(s)
MAC Address Detected Type
0000-0000-0001 Yes a--
0000-1111-1111 Yes -b-
0000-1111-1234 No -
0000-1111-5634 Yes --c
MAC address |
MAC address of the device permitted. |
Detected |
Whether the device is detected or not. |
Type |
Type of the device, which can be adhoc, wireless bridge, AP, or client. |
# Display information about the permitted SSID list.
<Sysname> display wlan ids permitted ssid
Total Number of Entries: 5
Permitted SSID(s)
SSID Detected
"s1" Yes
"s2" Yes
"s3" Yes
"s4" Yes
"s5" No
Table 5 Command output
SSID |
Service set identifier for the ESS. |
Detected |
Whether the device has been detected or not. |
# Display information about the permitted OUI list.
<Sysname> display wlan ids permitted vendor
Total Number of Entries: 3
Permitted Vendor(s)
OUI Vendor Name
New H3C Tech. Co., Ltd.Netgear Inc.Cisco Systems, Inc.
Table 6 Command output
OUI |
OUI (organizational unique identifier) of the AP. |
Vendor |
Vendor of the device. |
Use display wlan ids rogue-history to display all expired rogue devices which have been deleted from the list of detected rogue devices because they cannot be detected within the device aging duration.
display wlan ids rogue-history [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about all expired rogue devices.
<Sysname> display wlan ids rogue-history
Total Number of Entries: 6
Ch = channel number
Rogue History List
MAC Address Vendor Type Ch Last Detected SSID
00E0-9855-1D9A AboCo... -w- 11 2012-03-16/11:38:22 "ATNet"
000F-E2CC-0005 Hangz... -b- 4 2012-03-16/11:37:06 -
000F-E2CC-0004 Hangz... --c 4 2012-03-16/11:36:20 -
000F-E2CC-DD00 Hangz... -w- 2 2012-03-16/11:36:17 "AKHIL"
000F-E2CC-0003 Hangz... --c 4 2012-03-16/11:35:34 -
0013-4651-23E7 D-Lin... -w- 6 2012-03-16/11:35:10 "home"
Table 7 Command output
MAC Address |
MAC address of the device. |
Vendor |
Vendor for the device. |
Flags |
Type of the device, which can be ad hoc, wireless bridge, AP, or client. |
Ch |
Last Time Heard |
SSID |
wlan ids
Use wlan ids to enter WLAN IDS view.
wlan ids
2: System level
This view enables you to configure WLAN IDS parameters, such as scan parameters and device lists.
# Enter WLAN IDS view.
[Sysname] wlan ids
[Sysname-wlan-ids]
work-mode monitor
Use work-mode monitor to configure the AP to operate in monitor mode to scan rogue devices.
Use undo work-mode to restore the default.
work-mode monitor
undo work-mode
The AP operates in normal mode to provide WLAN data services.
2: System level
monitor: Configures the AP to operate in monitor mode.
If the AP operates in monitor mode, it can only operate as a monitor AP. It cannot operate as an access AP, and cannot provide WLAN services.
The maximum number of APs that can operate in monitor mode is the maximum number of APs that the AC supports. Make sure the sum of APs operating in monitor mode configured in AP template view and those configured in AP group view does not exceed the maximum number of APs operating in monitor mode supported by the AC. For example, the maximum number of APs operating in monitor mode supported by an AC is 32, and you have configured 30 APs to operate in monitor mode. If there are 5 APs in an AP group, when you execute the work-mode monitor command in AP group view, only the two APs with the smallest ID can operate in monitor mode.
Before you change the operating mode of an AP from hybrid to monitor, execute the undo device-detection enable command.
# Set the monitor operation mode for the AP.
[Sysname] wlan ap ap2 model WA3628i-AGN
[Sysname-wlan-ap-ap2] work-mode monitor
# Configure all APs in AP group office to operate in monitor mode.
[Sysname-ap-group-office] work-mode monitor
reset wlan ids detected
Use reset wlan ids detected to clear information about specified device or all devices detected in the WLAN.
reset wlan ids detected { all | rogue { ap | client } | adhoc | ssid | mac-address mac-address }
1: Monitor level
all: Clears information about all devices detected in the WLAN.
rogue: Clears information about detected rogue devices (AP or clients) in the WLAN.
ap: Clears information about rogue APs detected in the WLAN.
client: Clears information about rogue clients detected in the WLAN.
adhoc: Clears information about ad hoc devices detected in the WLAN.
ssid: Clears information about SSIDs detected in the WLAN.
mac-address mac-address: Clears information about the device (AP or client) detected in the WLAN.
# Clear information about all devices (permitted and non-permitted) detected in the WLAN.
<Sysname> reset wlan ids detected all
reset wlan ids rogue-history
Use reset wlan ids rogue-history to delete all entries from the rogue history table.
1: Monitor level
# Delete all entries from the rogue history table.
<Sysname> reset wlan ids rogue-history
attack-detection enable
Use attack-detection enable to enable the WIDS-IPS detection of various DoS attacks.
Use undo attack-detection enable to restore the default.
attack-detection enable { all | flood | spoof | weak-iv }
No WIDS-IPS detection is enabled.
WLAN IDS view
2: System level
all: Enables detection of all kinds of attacks.
flood: Enables detection of flood attacks.
spoof: Enables detection of spoof attacks.
weak-iv: Enables weak-IV detection.
# Enable spoof attack detection.
[Sysname] wlan ids
[Sysname-wlan-ids] attack-detection enable spoof
display wlan ids history
Use display wlan ids history to display the history of attacks detected in the WLAN system. It supports a maximum of 512 entries.
display wlan ids history [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display attack history.
<Sysname> display wlan ids history
Flags:
act = Action Frame asr = Association Request
aur = Authentication Request daf = Deauthentication Frame
dar = Disassociation Request ndf = Null Data Frame
pbr = Probe Request rar = Reassociation Request
saf = Spoofed Disassociation Frame
sdf = Spoofed Deauthentication Frame
wiv = Weak IV Detected
AT - Attack Type, Ch - Channel Number, AR - Average RSSI
WIDS History Table
MAC Address AT Ch AR Detected Time AP
0027-E699-CA71 asr 8 44 2010-06-12/19:47:54 ap12
0015-E9A4-D7F4 wiv 8 45 2010-06-12/19:45:28 ap48
0027-E699-CA71 asr 8 20 2010-06-12/19:18:17 ap12
003d-B5A6-539F pbr 8 43 2010-06-12/19:10:48 ap56
0015-E9A4-D7F4 wiv 8 50 2010-06-12/19:01:28 ap48
Table 8 Command output
MAC-Address/BSSID |
In case of spoof attacks, this field provides the BSSID which was spoofed. In case of other attacks, this field provides the MAC address of the device which initiated the attack. |
AT |
Type of attack. |
Ch |
Channel in which the attack was detected. |
AR |
Average RSSI of the attack frames. |
Detected time |
Time at which this attack was detected. |
AP |
Name of the AP that detected this attack. |
display wlan ids statistics
Use display wlan ids statistics to display the count of attacks detected.
display wlan ids statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display WLAN IDS statistics.
<Sysname> display wlan ids statistics
Current attack tracking since: 2010-06-21/12:46:33
Type Current Total
Probe Request Frame Flood Attack 2 7
Authentication Request Frame Flood Attack 0 0
Deauthentication Frame Flood Attack 0 0
Association Request Frame Flood Attack 1 1
Disassociation Request Frame Flood Attack 4 8
Reassociation Request Frame Flood Attack 0 0
Action Frame Flood Attack 0 0
Null Data Frame Flood Attack 0 0
Weak IVs Detected 12 21
Spoofed Deauthentication Frame Attack 0 0
Spoofed Disassociation Frame Attack 0 2
Table 9 Command output
Current |
Provides the count of attacks detected since the time specified by the current attack tracking time (specified in the "Current attack tracking since:" field). The current attack tracking time is started at the system startup and is refreshed each hour subsequently. |
Total |
Provides the total count of the attacks detected since the system startup. |
Probe Request Frame Flood Attack |
Number of probe request frame flood attacks detected. |
Authentication Request Frame Flood Attack |
Number of authentication request frame flood attack detected. |
Deauthentication Frame Flood Attack |
Number of deauthentication frame flood attacks detected. |
Association Request Frame Flood Attack |
Number of association request frame flood attacks detected. |
Disassociation Request Frame Flood Attack |
Number of disassociation request frame flood attacks detected. |
Reassociation Request Frame Flood Attack |
Number of reassociation request frame flood attacks detected. |
Action Frame Flood Attack |
Number of action frame flood attacks detected. |
Null Data Frame Flood Attack |
Number of null data frame flood attacks detected. |
Weak IVs Detected |
Number of weak IVs detected. |
Spoofed Deauthentication Frame Attack |
Number of spoofed deauthentication frame attacks detected. |
Spoofed Disassociation Frame Attack |
Number of spoofed disassociation frame attacks detected. |
reset wlan ids history
Use reset wlan ids history to clear the history information of attacks detected in the WLAN.
1: Monitor level
After this command is executed, all the history information regarding attacks will be cleared, and the history table will be empty.
# Clear all history information of attacks.
<Sysname> reset wlan ids history
reset wlan ids statistics
Use reset wlan ids statistics to clear the statistics of attacks detected in the WLAN system.
1: Monitor level
This command clears both the "current" and "total" of all attack types in the WLAN IDS statistics table.
# Clear WLAN IDS statistics.
<Sysname>reset wlan ids statistics
display wlan blacklist
Use display wlan blacklist to display the static or dynamic blacklist entries.
display wlan blacklist { static | dynamic } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
static: Displays static blacklist entries.
dynamic: Displays dynamic blacklist entries.
# Display information about the static blacklist.
<Sysname> display wlan blacklist static
Static Blacklist
MAC-Address
0014-6c8a-43ff
0016-6F9D-61F3
0019-5B79-F04A
Table 10 Command output
MAC-Address |
MAC addresses of clients. |
# Display information about the dynamic blacklist.
<Sysname> display wlan blacklist dynamic
Dynamic Blacklist
MAC-Address APID Lifetime(s) Blacklisted For (hh:mm:ss) Reason
000f-e2cc-0001 1 60 00:02:11 Assoc-Flood
000f-e2cc-0002 2 60 00:01:17 Deauth-Flood
000f-e2cc-0003 3 60 00:02:08 Auth-Flood
Table 11 Command output
MAC-Address |
MAC address of the device inserted into the dynamic blacklist. |
APID |
AP ID of the corresponding entry in the dynamic blacklist. |
Lifetime(s) |
Lifetime of the corresponding entry in seconds. |
Blacklisted For (hh:mm:ss) |
Time elapsed since the entry was last updated. |
Reason |
Reason why the entry was added into the dynamic blacklist. |
display wlan whitelist
Use display wlan whitelist to display the configured whitelist.
display wlan whitelist [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the whitelist.
<Sysname> display wlan whitelist
Whitelist
MAC-Address
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
0000-0000-00EE
0400-0000-0000
0400-0000-00EE
Table 12 Command output
MAC-Address |
MAC addresses of clients in the whitelist. |
dynamic-blacklist enable
Use dynamic-blacklist enable to enable the dynamic blacklist feature.
Use undo dynamic-blacklist enable to disable the dynamic blacklist feature.
The dynamic blacklist feature is disabled.
WLAN IDS view
2: System level
enable: Enables the dynamic blacklist feature.
With this feature, a WLAN device, upon detecting flood attacks from a device, adds the device to the dynamic blacklist, and denies any packets from this device until the dynamic blacklist entry ages out.
The maximum number of entries in the dynamic blacklists depends on the device model. For more information, see About the H3C Access Controllers Command References.
# Enable the dynamic blacklist feature.
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist enable
dynamic-blacklist lifetime
Use dynamic-blacklist lifetime to set the lifetime for dynamic blacklist entries.
Use undo dynamic-blacklist lifetime to restore the default.
dynamic-blacklist lifetime lifetime
The lifetime is 300 seconds.
WLAN IDS view
2: System level
lifetime: Interval, in the range of 60 to 3600 seconds.
If a dynamic blacklist entry is not detected within the lifetime, the entry is removed from the dynamic blacklist.
# Specify a lifetime of 1200 seconds for dynamic blacklist entries.
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist lifetime 1200
reset wlan dynamic-blacklist
Use reset wlan dynamic-blacklist to remove a specified entry or all entries from the dynamic blacklist.
reset wlan dynamic-blacklist { mac-address mac-address | all }
1: Monitor level
mac-address mac-address: Removes an entry with the specified MAC address from the dynamic blacklist.
all: Removes all entries from the dynamic blacklist.
The maximum number of entries in the dynamic blacklist is 128.
# Remove a client with MAC address 001d-0f31-87d from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address 001d-0f31-87d
static-blacklist mac-address
Use static-blacklist mac-address to add a client with a specified MAC address to the static blacklist.
Use undo static-blacklist to remove the client with the specified MAC address or all clients from the static blacklist.
static-blacklist mac-address mac-address
undo static-blacklist { mac-address mac-address | all }
WLAN IDS view
2: System level
mac-address: Adds or deletes a client to or from the static blacklist.
all: Deletes all entries from the static blacklist.
No static blacklist exists.
Clients in the static blacklist cannot get associated with the AP.
The maximum number of entries in the static blacklist depends on the device model. For more information, see About the H3C Access Controllers Command References.
# Add the client with MAC address 0014-6c8a-43ff to the static blacklist.
[Sysname] wlan ids
[Sysname-wlan-ids] static-blacklist mac-address 0014-6c8a-43ff
whitelist mac-address
Use whitelist mac-address to add a client with a specified MAC address to the whitelist.
Use undo whitelist to remove the client with the specified MAC address or all clients from the whitelist.
whitelist mac-address mac-address
undo whitelist { mac-address mac-address | all }
WLAN IDS view
2: System level
mac-address: Adds or deletes the client with the MAC address to or from the whitelist.
all: Deletes all entries from the whitelist.
No whitelist exists.
Clients in the whitelist can be associated with the AP.
The maximum number of entries in the whitelist varies with device models (see About the H3C Access Controllers Command References).
# Add the client with MAC address 001c-f0bf-9c92 to the whitelist.
[Sysname] wlan ids
[Sysname-wlan-ids] whitelist mac-address 001c-f0bf-9c92
