02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10202-WLAN Command Reference
05-WLAN RRM Commands
05-WLAN RRM Commands 241.57 KB
WLAN RRM configuration commands· 1
adjacent-channel interference trap· 1
ap radio· 1
autochannel-set avoid-dot11h· 2
channel holddown-time· 3
channel-utilization threshold· 3
co-channel interference trap· 4
description· 5
display wlan ap rrm-history· 5
display wlan ap rrm-status· 7
display wlan mesh calibrate-channel history· 8
display wlan rrm·· 9
display wlan rrm-calibration-group· 13
dot11a· 13
dot11a adjacency-factor 14
dot11a calibrate-channel 15
dot11a calibrate-channel persistent 15
dot11a calibrate-channel pronto· 16
dot11a calibrate-channel self-decisive· 17
dot11a calibrate-power 17
dot11a calibrate-power min· 18
dot11a calibrate-power persistent 18
dot11a calibrate-power pronto· 19
dot11a calibrate-power self-decisive· 19
dot11a calibrate-power threshold· 20
dot11a calibration-interval 20
dot11a crc-error-threshold· 21
dot11a exclude-channel 21
dot11a interference-threshold· 22
dot11a max-bandwidth· 23
dot11a tolerance-level 23
dot11ac mandatory maximum-nss· 24
dot11ac multicast-rate nss· 24
dot11ac support maximum-nss· 25
dot11b· 25
dot11b max-bandwidth· 26
dot11bg adjacency-factor 27
dot11bg calibrate-channel 27
dot11bg calibrate-channel persistent 28
dot11bg calibrate-channel pronto· 28
dot11bg calibrate-channel self-decisive· 29
dot11bg calibrate-power 29
dot11bg calibrate-power min· 30
dot11bg calibrate-power persistent 30
dot11bg calibrate-power pronto· 31
dot11bg calibrate-power self-decisive· 31
dot11bg calibrate-power threshold· 32
dot11bg calibration-interval 32
dot11bg crc-error-threshold· 33
dot11bg exclude-channel 34
dot11bg interference-threshold· 34
dot11bg tolerance-level 35
dot11g· 35
dot11g max-bandwidth· 36
dot11g protection enable· 37
dot11g protection-mode· 37
dot11n mandatory maximum-mcs· 38
dot11n max-bandwidth· 39
dot11n multicast-rate· 39
dot11n protection enable· 40
dot11n protection-mode· 40
dot11n support maximum-mcs· 41
mesh calibrate-channel 41
mesh calibrate-channel pronto· 42
mesh calibrate-channel self-decisive· 42
power holddown-time· 43
power-constraint 43
scan channel 44
scan report-interval 45
scan type· 45
spectrum-management enable· 46
wlan rrm·· 46
wlan rrm-calibration-group· 47
WLAN load balancing configuration commands· 47
ap radio· 47
description· 48
display wlan load-balance-group· 49
display wlan load-balance neighbor-list ap· 50
display wlan load-balance neighbor-list client 50
display wlan load-balance reject-client ap· 51
display wlan load-balance reject-client client 52
load-balance access-denial 52
load-balance rssi-threshold· 53
load-balance session· 53
load-balance traffic· 54
wlan load-balance-group· 55
Band navigation configuration commands· 55
band-navigation aging-time· 55
band-navigation balance access-denial 56
band-navigation balance session· 56
band-navigation enable (AP template view) 57
band-navigation enable (WLAN RRM view) 57
band-navigation rssi-threshold· 58
Use adjacent-channel interference trap threshold to set the adjacent channel interference trap threshold.
Use undo adjacent-channel interference trap threshold to restore the default.
adjacent-channel interference trap threshold value
The adjacent channel interference trap threshold is 60.
WLAN RRM view
Default command level
2: System level
threshold value: Specifies the adjacent channel interference trap threshold in the range of 10 to 90 dBm. The value range corresponds to the actual power range –10 to –90. If the detected adjacent channel interference reaches the threshold, the device sends a trap to the NMS.
# Configure the adjacent channel interference trap threshold as 80.
[Sysname] wlan rrm
[Sysname-wlan-rrm] adjacent-channel interference trap threshold 80
ap radio
Use ap radio to add a radio of an AP to the load balancing group.
Use undo ap to remove radios from the radio group.
ap ap-name radio radio-number
undo ap { ap-name [ radio radio-number ] | all }
No radio exists in the radio group.
Radio group view
2: System level
ap-name: Specifies an AP by its name. It is a string of 1 to 64 characters that can contain case-insensitive letters and digits, and special characters such as underscore(_), left bracket ([), right bracket (]), slash (/), hyphen (-), and spaces. The specified AP must exist.
radio-number: Specifies a radio by its number. The value range depends on your device model.
all: Removes all radios from the radio group.
If you do not specify the radio radio-number or all option, the undo ap command removes all radios of the specified AP from the radio group.
The members of a radio group are radios.
A radio can belong to only one radio group.
# Add radio 2 of AP 1 to radio group 10.
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rc-group-10] ap ap1 radio 2
# Remove all radios from radio group 10.
[Sysname-wlan-rc-group-10] undo ap all
# Remove all radios of AP 1 from radio group 10.
[Sysname-wlan-rc-group-10] undo ap ap1
# Remove radio 2 of AP 1 from radio group 10.
[Sysname-wlan-rc-group-10] undo ap ap1 radio 2
Use autochannel-set avoid-dot11h to configure that only the non-dot11h channels of the country code are scanned during initial channel selection and channel adjustment.
Use undo autochannel-set to restore the default.
This function is disabled.
WLAN RRM view
2: System level
Some of 802.11h channels, also called radar channels, overlap some 802.11a channels. If the device operates on an overlapping channel, radar signals might be affected. With this command enabled, the device scans only non-802.11h channels belonging to the configured country code to avoid channel collision.
# Configure RRM to scan only non-dot11h channels.
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
scan channel
Use channel holddown-time to set the channel holddown time for the radio group.
Use undo channel holddown-time to restore the default.
channel holddown-time minutes
The channel holddown time is 720 minutes.
Radio group view
2: System level
minutes: Channel holddown time, within which the channel of any radio in the radio group remains unchanged after an auto or initial DFS operation. The value is in the range of 10 to 1440, in minutes.
If the AC detects any radar signals on the channel of any radio in the radio group within the specified holddown time, the AC immediately selects a new channel for the radio and resets the holddown timer.
# Set the channel holddown time for radio group 10 to 600 minutes.
[Sysname-wlan-rc-group-10] channel holddown-time 600
Use channel-utilization threshold to configure a channel utilization threshold.
Use undo channel-utilization threshold to restore the default.
channel-utilization threshold threshold
The channel utilization threshold is 90%.
RRM view
2: System level
threshold: Specifies the channel utilization threshold in the range of 5% to 100%.
# Set the channel utilization threshold to 60%.
[Sysname] wlan rrm
[Sysname-rrm] channel-utilization threshold 60
Use co-channel interference trap threshold to set the co-channel interference trap threshold.
Use undo co-channel interference trap threshold to restore the default.
co-channel interference trap threshold value
The co-channel interference trap threshold is 60.
WLAN RRM view
2: System level
threshold value: Specifies the co-channel interference trap threshold in the range of 10 to 90, in dBm. The value range corresponds to the actual power range –10 to –90. If the detected co-channel interference reaches the threshold, the device sends a trap to the NMS.
# Configure the co-channel interference trap threshold as 80.
[Sysname] wlan rrm
[Sysname-wlan-rrm] co-channel interference trap threshold 80
description
Use description to configure the description of the load balancing group.
Use undo description to remove the description of the load balancing group.
The radio group has no description.
Radio group view
2: System level
text: Description of the radio group, a case-sensitive string of 1 to 64 characters.
# Configure the description of radio group 10 as office.
[Sysname-wlan-rc-group-10] description office
Use display wlan ap rrm-history to display the details of the latest three channel changes and power changes applied on all APs or a specified AP. The output includes time of the change, reason for the change, and the channel, power, and interference parameters.
display wlan ap { all | name ap-name } rrm-history [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a string of 1 to 64 characters that can contain case-insensitive letters and digits, and special characters such as underscore(_), left bracket ([), right bracket (]), slash (/), hyphen (-), and spaces.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the RRM history information about AP1.
<Sysname> display wlan ap name ap1 rrm-history
                         AP RRM History
 Flags : I - Interference,   P - Packets discarded,    F - Retransmission,
         R - Radar,          C - Coverage,             O - Others
                         AP RRM History : ap1
 Radio : 2                                Basic BSSID : 000f-e2ff-7700
        Chl Power Load Util Intf PER Retry Reason  Date         Time
            (dBm) (%)  (%)  (%)  (%) (%)           (yyyy-mm-dd) (hh:mm:ss)
 Before 6   20    24   2    21   11  18    -P----  2008-01-07   17:31:50
 After  1   20    9    0    8    0   27    -       -            -
 Before 1   20    54   1    53   11  15    IP----  2008-01-08   12:19:50
 After  6   20    10   0    10   3   29    -       -            -
 Before 6   20    29   1    28   21  20    -P----  2008-01-08   12:59:50
 After  1   20    30   0    29   2   24    -       -            -
Radio
Radio ID of the AP.
Basic BSSID
MAC address of the radio interface of the AP.
Chl
Channel on which the radio operates before/after the change of channel or power.
Power
Power of the radio before/after the change of channel or power.
Load
Load observed on the radio in percentage before/after the change of channel or power.
Util
Utilization of the radio in percentage before/after the change of channel or power.
Intf
Interference observed on the radio in percentage before/after the change of channel or power.
PER
Packet error rate, which is the duration of invalid packets that include CRC errors and physical errors over the medium.
Retry
Percentage of retransmission that happened on the radio before/after the change of channel or power.
Reason
Reason for the change of channel or power, such as interference, packets discarded, retransmission, radar, or coverage.
Date
Date when the channel or power change occurred.
Time
Time when the channel or power change occurred.
Use display wlan ap rrm-status to display the RRM profile information of each radio on all APs or a specified AP, including the channel on which the AP is operating, the power level of the AP, interference observed, and the number of neighbors.
display wlan ap { all | name ap-name } rrm-status [ | { begin | exclude | include } regular-expression ]
1: Monitor level
When you execute the command on an AC, if RRM is not enabled, only the channel on which the AP is operating and the power level of the AP are displayed. Other information such as interference observed and the number of neighbors is not displayed. If RRM is enabled, it means that dynamic power selection or automatic dynamic frequency selection is enabled.
# Display RRM profile information about AP 1.
<Sysname> display wlan ap name ap1 rrm-status
                         AP RRM Profile : ap1
 Channel : 6 (Good)                       Tx Power (dBm) : 20
   Chl   NbrCnt   Load   Util   Intf   PER   Retry   Radar
   1     6        33     -      33     1     -       -
   6     6        25     0      25     8     0       -
   11    4        48     -      48     5     -       -
   Nbr-BasicBSSID   Chl   Intf   SignalStrength   Type
                          (%)    (dBm)
   000f-e20c-4080   6     8      -69              Unmanaged
   000f-e211-2220   6     0      -63              Unmanaged
   000f-e232-5500   6     1      -79              Unmanaged
   000f-e23e-e740   1     1      -71              Unmanaged
   000f-e23e-e760   1     1      -63              Unmanaged
   000f-e25d-f3c0   11    0      -59              Unmanaged
   000f-e25d-f420   1     2      -89              Unmanaged
   000f-e267-9990   1     8      -80              Unmanaged
   000f-e267-9b10   11    0      -65              Unmanaged
   000f-e26c-2980   6     0      -85              Unmanaged
   000f-e26e-5f00   11    0      -63              Unmanaged
   000f-e274-1020   6     5      -60              Unmanaged
   000f-e299-5510   1     2      -78              Unmanaged
   000f-e2c0-0120   1     4      -76              Unmanaged
   000f-e2ff-ee10   6     1      -74              Unmanaged
   5055-5555-5500   11    41     -67              Unmanaged
Radio
Radio ID of the AP.
Basic BSSID
Channel
Channel on which the radio operates.
Tx Power
Current transmit power of the radio.
Chl
Channel number.
NbrCnt
Neighbor count, or the number of neighbors found on the channel.
Load
Load observed on the channel in percentage.
Util
Utilization of the channel in percentage.
Intf
Interference observed on the channel in percentage.
PER
Packet error rate observed on the channel in percentage.
Retry
Percentage of retransmission happened on the channel.
Radar
Radar detection status.
Nbr-BasicBSSID
MAC address of the radio interface of the neighbor AP.
SignalStrength
Signal strength of the AP in dBm.
Type of the AP, managed or unmanaged.
Use display wlan mesh calibrate-channel history to display mesh auto DFS history information.
display wlan mesh calibrate-channel history [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display mesh auto DFS history information
<Sysname> display wlan mesh calibrate-channel history
                            Mesh RRM History
    Mesh-ID: outdoor                                    Number of Radios: 2
 AP                                Radio  Chl(After/Before)  Date/Time
 mpp                               1      149/auto           2009-10-10/13:16:19
 mpp                               1      153/149            2009-10-10/13:19:22
 map                               1      149/auto           2009-10-10/13:17:1
 map                               1      153/149            2009-10-10/13:19:24
display wlan rrm
Use display wlan rrm to display basic RRM configuration information.
display wlan rrm [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display RRM configuration information.
 <Sysname>display wlan rrm
                                 RRM Configuration
 11a Configured Rates (Mbps)
   Mandatory                   : 6, 12, 24
   Supported                   : 9, 18, 36, 48, 54
   Disabled                    : -NA-
   Multicast                   : Auto
 11b Configured Rates (Mbps)
   Mandatory                   : 1, 2
   Supported                   : 5.5, 11
   Disabled                    : -NA-
   Multicast                   : Auto
 11g Configured Rates (Mbps)
   Mandatory                   : 1, 2, 5.5, 11
   Supported                   : 6, 9, 12, 18, 24, 36, 48, 54
   Disabled                    : -NA-
   Multicast                   : Auto
 Scan Configuration
   Scan Type                   : Passive
   Channel Mode                : Auto
   Report-Interval (s)         : 10
 11a Configuration
   Automatic Channel Selection : Disabled
   Automatic Power Selection   : Disabled
   Calibration Mode-Channel    : -NA-
   Mesh Calibration Mode-Channel: -NA-
   Calibration Mode-Power      : -NA-
   exclude-channel             : -NA-
   Calibration Interval (min)  : 8
   Interference Threshold (%)  : 50
   Tolerance Level (%)         : 20
   Adjacency Factor            : 3
   CRC-Error Threshold (%)     : 20
   Power Threshold (dBm)       : -65
   Minimum Power (dBm)         : 1
   max-bandwidth (kbps)        : 30000
 11bg Configuration
 11b Configuration
   max-bandwidth (kbps)        : 7000
 11g Configuration
   11g Protection              : Disabled
   11g Protection Mode         : RTS/CTS
 11n Configuration
   Mandatory Maximum MCS       : -NA-
   Supported Maximum MCS       : 76
   Multicast MCS               : -NA-
   11n Protection              : Disabled
   11n Protection Mode         : RTS/CTS
   max-bandwidth (kbps)        : 180000
 11h Configuration
   Spectrum Management         : Disabled
   Power Constraint (dBm)      : 0
   Channel Set                 : All
 11ac Configuration
   Mandatory Maximum NSS       : -NA-
   Support Maximum NSS         : 8
   Multicast NSS               : -NA-
   Multicast VHT-MCS           : -NA-
 Band Navigation Configuration
   Band Navigation             : Disabled
 Load Balance Configuration
   Load Balancing Mode         : Disabled
<Sysname>
802.11a rates. The same field for 802.11b and 802.11g has the same meaning.
Mandatory
Rates that the AP is required to support.
Supported
Additional rates supported by the client or AP.
Disabled
Rates that an AP cannot use.
Multicast
Multicast rate.
Scan Type
Active or passive.
Channel Mode
If the channel mode is auto, only regulatory domain channels will be scanned. If the mode is all, all channels in the band will be scanned.
Report-Interval (s)
Report interval.
11a Configuration
802.11a configuration. The same field for 802.11b and 802.11n has the same meaning.
Whether DFS is enabled or disabled.
Whether Transmit power control (TPC) is enabled or disabled.
·     Self-decisive—Auto DFS.
·     Pronto—One-time DFS.
·     -NA-—Not configured.
·     Self-decisive—Mesh auto DFS.
·     Pronto—Mesh one-time DFS.
·     Self-decisive—Auto TPC.
·     Pronto—One-time TPC.
Exclude-channel
Channels to be excluded.
Calibration interval.
Channel interference threshold.
Tolerance Level (%)
Tolerance factor.
Adjacency Factor
Adjacency factor.
CRC-error threshold.
Power adjustment threshold in dBm.
Minimum Power (dBm)
Minimum transmission power in dBm.
11g Protection
802.11g protection: Enabled or Disabled.
11g Protection Mode
802.11g protection mode: CTS-to-Self or RTS/CTS.
11n Protection Mode
802.11n protection mode: CTS-to-Self or RTS/CTS.
11h Configuration
802.11h configuration.
Spectrum Management
Enabled or disabled.
Power constraint for all 802.11a radios.
Channel Set
All or Non-dot11h.
11ac Configuration
802.11ac configurations.
Band Navigation
Band navigation status: Enabled or Disabled.
Load balancing configuration.
Load Balancing Mode
Session mode, or traffic mode. If load balancing is disabled, this field displays "disabled" and the next two fields are absent.
Session Threshold (users)
Session threshold. If the load balancing mode is set to "traffic", the field will be replaced by "Traffic Threshold (%)".
Session Gap (users)
The value of session gap. If the load balancing mode is set to "traffic", the field will be replaced by "Traffic Gap (%)".
Use display wlan rrm-calibration-group to display radio group configuration information.
display wlan rrm-calibration-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group-id: ID of a radio group. The value range depends on your device model. For more information, see About the H3C Access Controllers Command References.
all: Specifies all radio groups.
# Display configuration information about radio group 10.
<Sysname> display wlan rrm-calibration-group 10
                  RRM Calibration Group Information
Group ID                : 10
Description             : office
Channel holddown time   : 720  (in minutes)
Power holddown time     : 60   (in minutes)
Group members           : ap4-radio2,
                          ap3-radio2,
dot11a
Use dot11a to configure 802.11a rates.
Use undo dot11a to restore the default 802.11a rates.
dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
·     Disabled rates: none.
·     Mandatory rates: 6, 12, and 24.
·     Multicast rates: automatically selected from the mandatory rates.
·     Supported rates: 9, 18, 36, 48 and 54.
WLAN RRM view
2: System level
disabled-rate: Specifies a disabled rate.
mandatory-rate: Specifies mandatory rates.
multicast-rate: Specifies multicast rates, at which the AP sends multicasts to clients. Multicasts rates must be selected from the mandatory rates.
supported-rate: Specifies supported rates.
rate-value: The following rates can be specified:
·     6 Mbps
·     9 Mbps
·     12 Mbps
·     18 Mbps
·     24 Mbps
·     36 Mbps
·     48 Mbps
·     54 Mbps
# Configure 802.11a rates (multicast: 6; supported: 12).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a multicast-rate 6
[Sysname-wlan-rrm] dot11a supported-rate 12
Use dot11a adjacency-factor to set the maximum number of neighbors for 802.11a, and specify that when the maximum neighbor number is reached, the neighbor AP whose power is at the place specified by the maximum number among neighbors performs power detection.
Use undo dot11a adjacency-factor to restore the default.
dot11a adjacency-factor neighbor
The maximum number of neighbors is 3, and when the maximum neighbor number is reached, the AP with the power at the third position among all neighbors performs power detection.
WLAN RRM view
2: System level
neighbor: Specifies the maximum number of neighbors. The value is in the range of 1 to 16.
# Set the maximum number of neighbors for 802.11a to 7, and specify that when the maximum neighbor number is reached, the AP with the power at the seventh position among the neighbors performs power detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a adjacency-factor 7
Use dot11a calibrate-channel to enable 802.11a channel monitoring for DFS.
Use undo dot11a calibrate-channel to restore the default.
Channel monitoring is disabled.
WLAN RRM view
2: System level
With dynamic channel selection enabled, the maximum power depends on the last selected channel.
# Enable channel monitoring for DFS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel
Use dot11a calibrate-channel persistent to execute channel persistence on all 5 GHz radios.
RRM view
2: System level
The device executes channel persistence on automatically selected or adjusted channels. After the AC reboots, the AP continues to use the persistent channel.
·     The device switches to a new channel if radar signals are detected on the channel, even if you have executed channel persistence on the channel with the dot11a calibrate-channel persistent command.
·     If you have configured the channel auto command, and execute channel persistence on a radio after the radio automatically selects a working channel, the device automatically saves the channel value with the channel channel-number command. After the AC reboots, the AP continues to use the persistent channel.
·     If you execute the channel lock command first, and then execute the dot11a calibrate-channel persistent command, the locked channel is unlocked. The device uses the channel channel-number command to automatically save the channel value. After the AC reboots, the AP continues to use the persistent channel.
# Execute channel persistence on all 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel persistent
Use dot11a calibrate-channel pronto ap to execute one-time DFS for an AP or all APs of 802.11a. The result of DFS is applied to the APs at the next calibration interval.
dot11a calibrate-channel pronto ap { all | name apname radio radio-num }
One-time DFS is not executed.
WLAN RRM view
2: System level
name apname: Specifies the name of an AP, a case-insensitive string of 1 to 64 characters.
radio radio-num: Specifies a radio of the AP.
This command cannot be undone.
Enable 802.11a channel monitoring before executing one-time DFS.
# Execute one-time DFS for all 802.11a APs.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel pronto ap all
Use dot11a calibrate-channel self-decisive to enable automatic dynamic frequency selection (DFS) (channel monitoring also needs to be enabled).
Use undo dot11a calibrate-channel self-decisive to restore the default.
Auto-DFS is disabled.
WLAN RRM view
2: System level
# Enable auto-DFS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel self-decisive
Use dot11a calibrate-power to enable power monitoring for TPC.
Use undo dot11a calibrate-power to restore the default.
Power monitoring is disabled.
WLAN RRM view
2: System level
# Enable power monitoring for TPC.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power
Use dot11a calibrate-power min to configure the minimum 802.11a radio transmission power.
Use undo dot11a calibrate-power min to restore the default.
dot11a calibrate-power min tx-power
The minimum 802.11a radio transmission power is 1 dBm.
WLAN RRM view
2: System level
tx-power: Minimum 802.11a radio transmission power in the range of 1 to 20 dBm.
# Set the minimum 802.11a radio transmission power to 10 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power min 10
Use dot11a calibrate-power persistent to execute power persistence on all 5 GHz radios.
RRM view
2: System level
This command enables the device to execute power persistence on the adjusted power. If the adjusted power value is not the default value set through the max-power command, the device automatically saves the power value with the max-power command. After the AC reboots, the AP continues to use the persistent power.
# Execute power persistence on all 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power persistent
Use dot11a calibrate-power pronto ap to execute one-time TPC for an AP or all APs. The result of TPC is applied to the APs at the next calibration interval.
dot11a calibrate-power pronto ap { all | name apname radio radio-num }
One-time TPC is not executed.
WLAN RRM view
2: System level
Enable power monitoring before executing one-time TPC.
# Execute one-time TPC for radio 1 of AP 1 in 802.11a mode.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power pronto ap name ap1 radio 1
Use dot11a calibrate-power self-decisive to enable automatic TPC (power monitoring also needs to be configured).
Use undo dot11a calibrate-power self-decisive to restore the default.
Automatic TPC is disabled.
WLAN RRM view
2: System level
# Enable automatic TPC.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power self-decisive
Use dot11a calibrate-power threshold to configure the power adjustment threshold for 802.11a radios.
Use undo dot11a calibrate-power threshold to restore the default.
dot11a calibrate-power threshold value
The power adjustment threshold for 802.11a radios is 80.
WLAN RRM view
2: System level
value: Power adjustment threshold in the range of 50 to 90 dBm. The value range indicates that the power of the AP ranges from –90 to –50 dBm.
# Set the power adjustment threshold to 70.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power threshold 70
Use dot11a calibration-interval to set the calibration interval for 802.11a.
Use undo dot11a calibration-interval to restore the default value.
dot11a calibration-interval minutes
The calibration interval is 8 minutes.
WLAN RRM view
2: System level
minutes: Calibration interval in the range of 3 to 180 minutes.
The calibration interval takes effect for mesh network optimization, channel calibration, and power calibration.
# Set the calibration interval to 10 minutes for 802.11a.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibration-interval 10
# Restore the default calibration interval for 802.11a.
[Sysname-wlan-rrm] undo dot11a calibration-interval
Use dot11a crc-error-threshold to set the CRC error threshold value for 802.11a.
Use undo dot11a crc-error-threshold to restore the default for 802.11a.
dot11a crc-error-threshold percent
WLAN RRM view
WLAN RRM view
2: System level
percent: Threshold in the range of 1 to 100 percentage.
The default CRC error threshold is 20%.
# Set the CRC error threshold for 802.11a to 50%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a crc-error-threshold 50
Use dot11a exclude-channel to configure the 5 GHz channel exclusion list.
Use undo dot11a exclude-channel to remove the channels in the 5 GHz channel list.
dot11a exclude-channel channel-list
undo dot11a exclude-channel { channel-list | all }
No channels exist in the channel exclusion list.
WLAN RRM view
2: System level
channel-list: Specifies a channel list, in the format of channel-list = { channel }& <1-10>, where channel represents a 5 GHz channel supported by the AP and &<1-10> indicates that you can specify up to 10 channels.
all: Specifies all channels.
# Add channels 149 and 153 to the 5 GHz channel exclusion list.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 149 153
Use dot11a interference-threshold to set the channel interference threshold value for 802.11a.
Use undo dot11a interference-threshold to restore the default for 802.11a.
dot11a interference-threshold percent
The interference threshold for 802.11a is 50%.
WLAN RRM view
2: System level
percent: Channel interference threshold in the range of 1 to 100 percentage.
# Set the channel interference threshold for 802.11a to 60%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a interference-threshold 60
Use dot11a max-bandwidth to configure the maximum 802.11a bandwidth.
Use undo dot11a max-bandwidth to restore the default.
dot11a max-bandwidth 11a-bandwidth
The maximum 802.11a bandwidth is 30000 kbps.
WLAN RRM view
2: System level
11a-bandwidth: Maximum 802.11a bandwidth in the range of 16 to 30000 kbps.
# Configure the maximum 802.11a bandwidth as 15000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a max-bandwidth 15000
Use dot11a tolerance-level to set the tolerance factor for the band.
Use undo dot11a tolerance-level to restore the default.
dot11a tolerance-level percentage
The tolerance factor is 20%.
WLAN RRM view
2: System level
percentage: Tolerance factor in percentage, in the range of 1 to 45.
A new channel is selected when the interference threshold is exceeded on the current channel. However, the new channel is not applied until the quality of the current channel is worse than that of the new channel by the tolerance threshold.
# Set the tolerance factor for 802.11a to 25%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a tolerance-level 25
Use dot11ac mandatory maximum-nss to specify the maximum NSS for 802.11ac mandatory rates.
Use undo dot11ac mandatory maximum-nss to remove the configuration.
dot11ac mandatory maximum-nss number
No mandatory maximum NSS is configured.
RRM view
2: System level
number: Specifies the maximum NSS for 802.11ac mandatory rates, in the range of 1 to 8.
# Specify the maximum NSS for 802.11ac mandatory rates as 4.
<sysname> system-view
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac mandatory maximum-nss 4
Use dot11ac multicast-rate to specify the 802.11ac multicast NSS and the VHT-MCS index.
Use undo dot11ac multicast-rate to remove the configuration.
dot11ac multicast-rate nss number vht-mcs index
No 802.11ac multicast NSS and VHT-MCS index are configured.
RRM view
2: System level
number: Specifies the multicast NSS in the range of 1 to 8.
index: Specifies the multicast VHT-MCS index in the range of 0 to 9.
# Specify the 802.11ac multicast NSS and the VHT-MCS index as 2 and 7, respectively.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac multicast-rate nss 2 VHT-MCS 7
Use dot11ac support maximum-nss to specify the maximum NSS for 802.11ac supported rates.
Use undo dot11ac support maximum-nss to remove the configuration.
dot11ac support maximum-nss number
The maximum NSS for 802.11ac supported rates is 8.
RRM view
2: System level
number: Specifies the maximum NSS for 802.11ac supported rates, in the range of 1 to 8.
The maximum NSS specified by this command cannot be smaller than the maximum NSS specified by the dot11ac mandatory maximum-nss command.
# Specify the maximum NSS for 802.11ac supported rates as 5.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac support maximum-nss 5
dot11b
Use dot11b to configure 802.11b rates.
Use undo dot11b to restore the default rates.
dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
WLAN RRM view
2: System level
disabled-rate: Specifies disabled rates.
multicast-rate: Specifies multicast rates, at which the AP send multicasts to clients. Multicast rates must be selected from the mandatory rates.
·     1 Mbps
·     2 Mbps
·     5.5 Mbps
·     11 Mbps
# Configure 802.11b rates (disabled: 1; multicast: 2; supported: 11).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1
[Sysname-wlan-rrm] dot11b multicast-rate 2
[Sysname-wlan-rrm] dot11b supported-rate 11
Use dot11b max-bandwidth to configure the maximum 802.11b bandwidth.
Use undo dot11b max-bandwidth to restore the default.
dot11b max-bandwidth 11b-bandwidth
The maximum 802.11b bandwidth is 7000 kbps.
WLAN RRM view
2: System level
11b-bandwidth: Maximum 802.11b bandwidth in the range of 16 to 7000 kbps.
# Configure the maximum 802.11b bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b max-bandwidth 6000
Use dot11bg adjacency-factor to set the maximum number of neighbors for 802.11b/g, and specify that when the maximum neighbor number is reached, the neighbor AP whose power is at the place specified by the maximum number among neighbors performs power detection.
Use undo dot11bg adjacency-factor to restore the default.
dot11bg adjacency-factor neighbor
The maximum number of neighbors is 3, and when the maximum neighbor number is reached, the AP with the power at the third place among all neighbors performs power detection.
WLAN RRM view
2: System level
# Set the maximum number of neighbors for 802.11b/g to 7, and specify that when the maximum neighbor number is reached, the AP with the power at the seventh place among the neighbors performs power detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg adjacency-factor 7
Use dot11bg calibrate-channel to enable channel monitoring for 802.11b/g.
Use undo dot11bg calibrate-channel to restore the default.
WLAN RRM view
2: System level
# Enable channel monitoring for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel
Use dot11bg calibrate-channel persistent to execute channel persistence on all 2.4 GHz radios.
RRM view
2: System level
·     If you execute the channel lock command first, and then execute the dot11bg calibrate-channel persistent command, the locked channel is unlocked. The device uses the channel channel-number command to automatically save the channel value. After the AC reboots, the AP continues to use the persistent channel.
# Execute channel persistence on all 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel persistent
Use dot11bg calibrate-channel pronto ap to configure one-time DFS for an AP or all APs of 802.11b/g. The DFS result is applied to the APs at the next calibration interval.
dot11bg calibrate-channel pronto ap { all | name apname radio radio-num }
One-time DFS is not configured for 802.11b/g.
WLAN RRM view
2: System level
Enable 802.11b/g channel monitoring before executing one-time DFS.
# Configure one-time DFS for radio 1 of AP 1 in 802.11b/g mode.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel pronto ap name ap1 radio 2
Use dot11bg calibrate-channel self-decisive to enable auto DFS for 802.11b/g (channel monitoring also needs to be enabled).
Use undo dot11bg calibrate-channel self-decisive to restore the default.
WLAN RRM view
2: System level
# Enable auto-DFS for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel self-decisive
Use dot11bg calibrate-power to enable power monitoring for 802.11b/g.
Use undo dot11bg calibrate-power to restore the default.
WLAN RRM view
2: System level
# Enable power monitoring for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power
Use dot11bg calibrate-power min to configure the minimum 802.11b/g radio transmission power.
Use undo dot11bg calibrate-power min to restore the default.
dot11bg calibrate-power min tx-power
The minimum 802.11b/g radio transmission power is 1 dBm.
WLAN RRM view
2: System level
tx-power: Minimum 802.11b/g radio transmission power in the range of 1 to 20 dBm.
# Set the minimum 802.11b/g radio transmission power to 10 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power min 10
Use dot11bg calibrate-power persistent to execute power persistence on all 2.4 GHz radios.
RRM view
2: System level
# Execute power persistence on all 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power persistent
Use dot11bg calibrate-power pronto ap to configure one-time TPC for an AP or all APs. The TPC result is applied to the APs at the next calibration interval.
dot11bg calibrate-power pronto ap { all | name apname radio radio-num }
One-time TPC is not configured.
WLAN RRM view
2: System level
name apname: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters.
# Configure one-time TPC for all APs in 802.11b/g mode.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power pronto all
Use dot11bg calibrate-power self-decisive to enable automatic TPC (power monitoring also needs to be enabled).
Use undo dot11bg calibrate-power self-decisive to restore the default.
WLAN RRM view
2: System level
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power self-decisive
Use dot11bg calibrate-power threshold to configure the power adjustment threshold for 802.11b/g radios.
Use undo dot11bg calibrate-power threshold to restore the default.
dot11bg calibrate-power threshold value
The power adjustment threshold for 802.11b/g radios is 80.
WLAN RRM view
2: System level
value: Power adjustment threshold in the range of 50 to 90 dBm. The value range indicates that the power of the AP is in the range of –90 to –50.
# Set the power adjustment threshold for 802.11b/g radios to 70.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power threshold 70
Use dot11bg calibration-interval to set the calibration interval for 802.11b/g.
Use undo dot11bg calibration-interval to restore the default.
dot11bg calibration-interval minutes
WLAN RRM view
2: System level
RRM algorithms run periodically at the calibration interval for transmit power control or dynamic frequency selection.
# Set the calibration interval to 10 minutes for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibration-interval 10
# Restore the default calibration interval for 802.11b/g.
[Sysname-wlan-rrm] undo dot11bg calibration-interval
Use dot11bg crc-error-threshold to set the CRC error threshold value for 802.11b/g.
Use undo dot11bg crc-error-threshold to restore the default for 802.11b/g.
dot11bg crc-error-threshold percent
The CRC error threshold is 20%.
WLAN RRM view
2: System level
# Set the CRC error threshold to 50% for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg crc-error-threshold 50
Use dot11bg exclude-channel to configure the 2.4 GHz channel exclusion list.
Use undo dot11bg exclude-channel to remove the channels in the 2.4 GHz channel exclusion list.
dot11bg exclude-channel channel-list
undo dot11bg exclude-channel { channel-list | all }
WLAN RRM view
2: System level
# Add channels 2 and 3 to the 2.4 GHz channel exclusion list.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 2 3
Use dot11bg interference-threshold to set the channel interference threshold value for 802.11b/g.
Use undo dot11bg interference-threshold to restore the default for 802.11b/g.
dot11bg interference-threshold percent
The interference threshold is 50%.
WLAN RRM view
2: System level
When channel adjustment is enabled, a new channel is selected when the following conditions occur:
·     The interference threshold is exceeded on the current channel.
·     The channel quality gap between the new channel and the current channel exceeds the limit.
# Set the channel interference threshold to 60% for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg interference-threshold 60
Use dot11bg tolerance-level to set the tolerance factor for the band.
Use undo dot11bg tolerance-level to restore the default.
dot11bg tolerance-level percentage
WLAN RRM view
2: System level
percentage: Tolerance level in percentage, in the range of 1 to 45.
# Set the tolerance-level for 802.11b/g to 25%
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg tolerance-level 25
dot11g
Use dot11g to configure 802.11g rates.
Use undo dot11g to restore the default rates.
dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
·     Mandatory rates: 1, 2, 5.5, and 11.
·     Supported rates: 6, 9, 12, 18, 24, 36, 48, and 54.
WLAN RRM view
2: System level
multicast-rate: Specifies multicast rates, which are the rates at which the AP send multicasts to clients. Multicasts rates must be selected from the mandatory rates.
·     1 Mbps
·     2 Mbps
·     5.5 Mbps
·     6 Mbps
·     9 Mbps
·     11 Mbps
·     12 Mbps
·     18 Mbps
·     24 Mbps
·     36 Mbps
·     48 Mbps
·     54 Mbps
# Configure 802.11g rates (disabled: 2, 36; multicast: 11; supported: 54).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g multicast-rate 11
[Sysname-wlan-rrm] dot11g supported-rate 54
Use dot11g max-bandwidth to configure the maximum 802.11g bandwidth.
Use undo dot11g max-bandwidth to restore the default.
dot11g max-bandwidth 11g-bandwidth
The maximum 802.11g bandwidth 30000 kbps.
WLAN RRM view
2: System level
11g-bandwidth: Maximum 802.11g bandwidth in kbps in the range of 16 to 30000 kbps.
# Configure the maximum 802.11g bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g max-bandwidth 6000
Use dot11g protection enable to enable 802.11g protection.
Use undo dot11g protection enable to restore the default.
802.11g protection is disabled.
WLAN RRM view
2: System level
# Enable 802.11g protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
Use dot11g protection-mode to configure the 802.11g protection mode.
Use undo dot11g protection-mode to restore the default.
dot11g protection-mode { cts-to-self | rts-cts }
The 802.11g protection mode is CTS-to-Self.
WLAN RRM view
2: System level
cts-to-self: Specifies the Clear to Send (CTS)-to-Self mode.
rts-cts: Specifies the Request to Send (RTS)/CTS mode.
# Configure the 802.11g protection mode as RTS/CTS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection-mode rts-cts
Use dot11n mandatory maximum-mcs to specify the maximum MCS index for 802.11n mandatory rates.
Use undo dot11n mandatory maximum-mcs to remove the configuration.
dot11n mandatory maximum-mcs index
No maximum MCS index is specified for 802.11n mandatory rates.
RRM view
2: System level
index: Specifies the maximum MCS index for 802.11n mandatory rates, in the range of 0 to 76.
If you configure the client dot11n-only command for a radio, you must configure the maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n mandatory rates as 7.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 7
Use dot11n max-bandwidth to configure the maximum 802.11n bandwidth.
Use undo dot11n max-bandwidth to restore the default.
dot11n max-bandwidth 11n-bandwidth
The maximum 802.11n bandwidth is 250000 kbps.
WLAN RRM view
2: System level
11a-bandwidth: Maximum 802.11n bandwidth in the range of 16 to 250000 kbps.
# Configure the maximum 802.11n bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n max-bandwidth 6000
Use dot11n multicast-rate to specify the maximum MCS index for 802.11n multicast rates.
Use undo dot11n multicast-rate to remove the configuration.
dot11n multicast-rate index
The maximum MCS index for 802.11n multicast rates is not configured.
RRM view
2: System level
index: Specifies the maximum MCS index for 802.11n multicast rates, in the range of 0 to 76.
The multicast MCS is adopted only when all the clients use 802.11n.
If a non-802.11n client exists, multicast traffic is transmitted at an 802.11a/b/g rate.
If you configure a multicast MCS index greater than the maximum MCS index supported by the radio, the maximum MCS index is adopted.
When the multicast MCS takes effect, the corresponding data rates defined for 20 MHz are adopted no matter whether the 802.11n radio operates in 40 MHz mode or in 20 MHz mode.
Before configuring the multicast MCS, specify the maximum mandatory MCS. The multicast MCS cannot exceed the maximum mandatory MCS.
# Specify the maximum MCS index for 802.11n multicast rates as 70.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n mandatory maximum-mcs 70
[Sysname-wlan-rrm] dot11n multicast-rate 70
Use dot11n protection enable to enable 802.11n protection.
Use undo dot11n protection enable to restore the default.
802.11n protection is disabled.
WLAN RRM view
2: System level
# Enable 802.11n protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection enable
Use dot11n protection-mode to configure the 802.11n protection mode.
Use undo dot11n protection-mode to restore the default.
dot11n protection-mode { cts-to-self | rts-cts }
The 802.11n protection mode is CTS-to-Self.
WLAN RRM view
2: System level
# Configure the 802.11n protection mode as RTS/CTS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection-mode rts-cts
Use dot11n support maximum-mcs to specify the maximum MCS index for 802.11n supported rates.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
The maximum MCS index for 802.11n supported rates is 76.
RRM view
2: System level
index: Specifies the maximum MCS index for 802.11n supported rates, in the range of 0 to 76.
The specified maximum MCS index for 802.11n supported rates must be no less than the specified maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n supported rates as 25.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
Use mesh calibrate-channel to enable mesh channel monitoring for mesh auto DFS.
Use undo mesh calibrate-channel to restore the default.
Mesh channel monitoring is not enabled.
WLAN RRM view
2: System level
# Enable mesh channel monitoring.
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel
Use mesh calibrate-channel pronto to configure one-time mesh DFS for a specific or all mesh profiles. The result of DFS is applied to the mesh profiles at the next calibration interval.
mesh calibrate-channel pronto mesh-profile { mesh-profile-number | all }
One-time mesh DFS is not configured.
WLAN RRM view
2: System level
mesh-profile-number: Specifies a mesh profile by its number, in the range of 1 to 32.
all: Specifies mesh profiles.
Enable mesh channel monitoring before executing one-time mesh DFS.
# Configure one-time DFS for all mesh profiles.
[Sysname] wlan rrm
Use mesh calibrate-channel self-decisive to enable automatic DFS (mesh channel monitoring also needs to be enabled).
Use undo mesh calibrate-channel self-decisive to restore the default.
Automatic mesh DFS is disabled.
WLAN RRM view
2: System level
# Enable automatic mesh DFS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel self-decisive
power holddown-time
Use power holddown-time to set the power holddown time for the radio group.
Use undo power holddown-time to restore the default.
power holddown-time minutes
The power holddown time is 60 minutes.
Radio group view
2: System level
minutes: Power holddown time, within which the power of any radio in the radio group stays unchanged after each power adjustment. The value is in the range of 10 to 1440 minutes.
# Set the power holddown time of radio group 10 to 600 minutes.
[Sysname-wlan-rc-group-10] power holddown-time 600
power-constraint
Use power-constraint to enable the device to notify all 802.11a clients to reduce their transmit power by a specified value.
Use undo power-constraint to restore the default.
power-constraint power-constraint
Transmit power is not restricted on 802.11a clients.
WLAN RRM view
2: System level
power-constraint: Power constraint value in dBm, in the range of 0 to 30.
This command takes effect only when spectrum management is enabled. After you configure the power constraint, the device will notify 802.11a clients to reduce their maximum transmit power by the specified value.
# Enable spectrum management and enable the device to notify 802.11a clients to reduce their maximum transmit power by 5 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
[Sysname-wlan-rrm] power-constraint 5
scan channel
Use scan channel to set the scan mode.
Use undo scan channel to restore the default.
scan channel { all | auto }
undo scan channel
The scan mode is auto.
WLAN RRM view
2: System level
all: Sets the scan mode to all. When this option is set, all the channels of the radio band are scanned.
auto: Sets the scan mode to auto. When this option is set, all channels of the country code are scanned.
# Set the scan mode to all.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan channel all
Use scan report-interval to set the scan report interval.
Use undo scan report-interval to restore the default.
scan report-interval seconds
The scan report interval is 10 seconds.
WLAN RRM view
2: System level
seconds: Interval for sending scan reports to the AC, in the range of 5 to 120 seconds.
# Set the scan report interval to 20 seconds.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan report-interval 20
scan type
Use scan type to set the scan type.
Use undo scan type to restore the default.
scan type { active | passive }
undo scan type
The scan type is passive.
WLAN RRM view
2: System level
active: Sets the active scanning mode.
passive: Sets the passive scanning mode.
# Set the scan type to active.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan type active
Use spectrum-management enable to enable spectrum management for 802.11a radios.
Use undo spectrum-management enable to restore the default.
Spectrum management for 802.11a radios is disabled.
WLAN RRM view
2: System level
After you enable spectrum management, the AP will notify its power capabilities and power constraint on clients.
# Enable spectrum management.
[Sysname] wlan rrm
power-constraint
wlan rrm
Use wlan rrm to enter WLAN RRM view.
wlan rrm
2: System level
# Enter WLAN RRM view.
[Sysname] wlan rrm
[Sysname-wlan-rrm]
Use wlan rrm-calibration-group to create a radio group and enter its view.
Use undo wlan rrm-calibration-group to remove one or all radio groups.
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { group-id | all }
No radio group exists.
2: System level
all: Removes all radio groups.
# Create radio group 10.
ap radio
Use ap radio to add a radio of an AP to the radio group.
Use undo ap to remove radios in the load balancing group.
No radio exists in the load balancing group.
Load balancing group view
2: System level
ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The specified AP must exist.
radio-number: Number of a radio of the AP. The value range depends on your device model.
all: Removes all radios in the load balancing group.
If you do not specify the radio radio-number and all parameters, the undo ap command removes all the radios of the specified AP in the load balancing group.
# Add radio 2 of AP 1 to load balancing group 10.
[Sysname] wlan load-balance-group 10
[Sysname-wlan-lb-group-10] ap ap1 radio 2
# Remove all radios from load balancing group 10.
[Sysname-wlan-lb-group-10] undo ap all
# Remove all radios of AP 1 from load balancing group 10.
[Sysname-wlan-lb-group-10] undo ap ap1
# Remove radio 2 of AP 1 from load balancing group 10.
[Sysname-wlan-lb-group-10] undo ap ap1 radio 2
description
Use description to configure the description of the radio group.
The load balancing group has no description.
2: System level
text: Description of the load balancing group, a case-sensitive string of 1 to 64 characters.
# Configure the description of load balancing group 10 as marketing.
[Sysname-wlan-lb-group10] description marketing
Use display wlan load-balance-group to display load balancing group configuration information.
display wlan load-balance-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group-id: ID of a load balancing group. The value range depends on your device model. For more information, see About the H3C Access Controllers Command References.
all: Displays the configuration of all load balancing groups.
# Display configuration information about load balancing group 10.
<Sysname> display wlan load-balance-group 10
                  Load Balance Group Information
Group ID                : 10
Description             : AA
Group members           : ap5-radio2,
                          ap4-radio2,
                          ap3-radio2,
                          ap2-radio2,
Use display wlan load-balance neighbor-list ap to display the MAC addresses of all neighbors of an AP.
display wlan load-balance neighbor-list ap ap-name
1: Monitor level
ap ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters.
# Display the MAC addresses of all neighbors of ap1.
<Sysname> display wlan load-balance neighbor-list ap ap1
Total entry(ies): 6
AP Neighbor List
Neighbor MAC-Address of Radio 1
0014-6c8a-43ff
0016-6F9D-61F3
0019-5B79-F04A
Neighbor MAC-Address of Radio 2
0012-e235-dc71
0011-6c2a-abcd
0013-e201-0101
Total entry(ies):
Number of neighbors of the AP.
MAC addresses of the neighbors detected on Radio 1.
Use display wlan load-balance neighbor-list client to display the neighbors (radios that are detected by the client and associated with the same AC) of a client.
display wlan load-balance neighbor-list client mac-address
1: Monitor level
mac-address: Specifies a client by its MAC address.
# Display the neighbors of the client with MAC address 0014-6c8a-4322.
<Sysname> display wlan load-balance neighbor-list client 0014-6c8a-4322
Total entry(ies): 3
Client Neighbor List
AP ID         RadioID
APID : 1    Radio ID : 1
APID : 1    Radio ID : 2
APID : 2    Radio ID : 1
Table 5 Command output
Total entry(ies):
Number of neighbors of the client.
AP ID
AP ID of the neighbor of the client.
Radio ID
Use display wlan load-balance reject-client ap to display clients rejected by load balancing on the specified AP.
display wlan load-balance reject-client ap ap-name
1: Monitor level
# Display clients rejected by load balancing on AP ap1.
<Sysname> display wlan load-balance reject-client ap ap1
                    WLAN load balance rejected client
 Radio 1: 3
 BSSID          MAC            Aging time(ms) Rejections
 CC3E-5F1D-5EE0 8C70-5A7B-2B38 89900          9
 CC3E-5F1D-57C0 8C70-5A7B-2B38 80100          5
 CC3E-5F1D-57C0 0027-10BD-0338 38300          7
 Radio 2: 0
Use display wlan load-balance reject-client client to display the rejection history of the specified client due to load balancing.
display wlan load-balance reject-client client mac-address
1: Monitor level
# Display the rejection history of the client with MAC address 8C70-5A7B-2B38 due to load balancing.
<Sysname> display wlan load-balance reject-client client 8C70-5A7B-2B38
 MAC: 8C70-5A7B-2B38
AP                             BSSID          Aging time(ms) Rejections
ap1                            CC3E-5F1D-57C0 43200          3
ap2                            CC3E-5F1D-5EE0 87600          9
Use load-balance access-denial to configure the maximum denial count of association requests sent by a client.
Use undo load-balance access-denial to restore the default.
load-balance access-denial access-denial
The maximum denial count is 10.
WLAN RRM view
2: System level
access-denial: Maximum denial count of client association requests, in the range of 2 to 10.
# Configure the maximum denial count of client association requests as 4.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance access-denial 4
Use load-balance rssi-threshold to configure the load balancing RSSI threshold.
Use undo load-balance rssi-threshold to restore the default.
load-balance rssi-threshold rssi-threshold
The load balancing RSSI threshold is 25.
WLAN RRM view
2: System level
rssi-threshold: Band navigation RSSI threshold in the range of 5 to 100.
# Configure the load balancing RSSI threshold as 40.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance rssi-threshold 40
Use load-balance session to configure session-mode load balancing. Load balancing is carried out when the session threshold and session gap are reached.
Use undo load-balance to remove the configuration.
load-balance session value [ gap gap-value ]
undo load-balance
Load balancing is disabled.
WLAN RRM view
2: System level
value: Session threshold, or, the number of maximum sessions, in the range of 1 to 40.
gap gap-value: Specifies a session gap threshold in the range of 1 to 8. The default is 4.
# Configure the session threshold as 7 and the session gap threshold as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance session 7 gap 5
Use load-balance traffic to configure traffic-mode load balancing.
load-balance traffic value [ gap gap-value ]
undo load-balance
WLAN RRM view
2: System level
value: Traffic threshold in the range of 10 to 80 percent.
gap gap-value: Specifies a traffic gap threshold in the range of 10 to 40 percent. The default is 20 percent.
Load balancing is carried out when the traffic threshold and session gap are reached.
The dot11g protection feature enabled with the dot11g protection enable command occupies bandwidth, affecting forwarding performance. If you configure load balancing after you have enabled dot11g protection, lower the traffic gap threshold.
# Configure the traffic threshold as 20% and the traffic gap threshold as 25%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance traffic 20 gap 25
Use wlan load-balance-group to create a load balancing group and enter its view.
Use undo wlan load-balance-group to remove one or all load balancing groups.
wlan load-balance-group group-id
undo load-balance-group { group-id | all }
No load balancing group exists.
Default Level
2: System level
all: Removes all load balancing groups.
# Create load balancing group 10.
Use band-navigation aging-time to configure the client information aging time.
Use undo band-navigation aging-time to restore the default.
band-navigation aging-time aging-time
The client information aging time is 180 seconds.
WLAN RRM view
2: System level
aging time: Client information aging time in the range of 10 to 600 seconds.
# Configure the client information aging time as 50 seconds.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation aging-time 50
Use band-navigation balance access-denial to configure the maximum denial count of association requests sent by a 5 GHz-capable client.
Use undo band-navigation balance access-denial to restore the default.
The AP does not deny the association requests sent by a 5 GHz-capable client.
WLAN RRM view
2: System level
access-denial: Maximum denial count of client association requests, in the range of 1 to 10.
If the number of times a client has been denied reaches the maximum denial count on the 5 GHz radio, the AP considers that the client is unable to associate with any other AP, and allows the 5 GHz radio to accept the client.
# Configure the maximum denial count of client association requests as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance access-denial 5
Use band-navigation balance session to configure the band navigation load balancing session threshold and session gap.
Use undo band-navigation balance session to restore the default.
band-navigation balance session session [ gap gap ]
Band navigation load balancing is disabled.
WLAN RRM view
2: System level
session: Band navigation load balancing session threshold for the 5 GHz band, in the range of 2 to 40.
gap: Band navigation load balancing session gap, which is the number of clients on the 5 GHz band minus the number of clients on the 2.4 GHz band. It is in the range of 1 to 8.
# Configure the session threshold as 10 and session gap as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance session 10 gap 5
Use band-navigation enable to enable band navigation for an AP.
Use undo band-navigation enable to disable band navigation for an AP.
Band navigation is enabled on an AP.
AP template view
2: System level
Band navigation takes effect on an AP only when it is enabled both globally and for the AP.
# Enable band navigation for AP 1.
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] band-navigation enable
band-navigation enable (WLAN RRM view)
Use band-navigation enable to enable band navigation globally.
Use undo band-navigation enable to disable band navigation globally.
Band navigation is disabled globally.
WLAN RRM view
Default command level
2: System level
Band navigation takes effect on an AP only when it is enabled both globally and for the AP..
# Enable band navigation globally.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation enable
band-navigation rssi-threshold
Use band-navigation rssi-threshold to configure the band navigation RSSI threshold.
Use undo band-navigation rssi-threshold to restore the default.
band-navigation rssi-threshold rssi-threshold
The band navigation RSSI threshold is 15.
WLAN RRM view
2: System level
An AP directs a client to its 5 GHz radio only when the AP detects that the RSSI of the client is higher than the band navigation RSSI threshold.
# Configure the band navigation RSSI threshold as 40.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation rssi-threshold 40
