02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10202-WLAN Command Reference
10-WLAN High Availability Commands
10-WLAN High Availability Commands 57.39 KB
WLAN high availability configuration commands
AC backup commands
backup-ac
Use backup-ac to specify an IPv4/IPv6 backup AC.
Use undo backup-ac to remove the IPv4/IPv6 backup ACs.
backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo backup-ac { ip | ipv6 }
By default, no IP address is configured for the backup AC, and the IP address configured in system view is used.
AP template view, AP group view
Default command level
2: System level
ip ipv4-address: Specifies an IPv4 backup AC.
ip ipv6-address: Specifies an IPv6 backup AC.
The backup AC configured in AP template view takes effect on the specified AP.
The backup AC configured in AP group view takes effect on all APs in the AP group.
# Specify the backup AC at 192.168.1.2 for AP 1.
[Sysname] wlan ap ap1 model WA4620i-ACN
[Sysname-wlan-ap-ap1] backup-ac ip 192.168.1.2
# Specify the backup AC at 192.168.1.2 for all APs in the AP group named office.
[Sysname] wlan ap-group office
[Sysname-ap-group-office] backup-ac ip 192.168.1.2
wlan backup-ac
display hot-backup state
Use display hot-backup state to display the AC hot backup state.
display hot-backup state [ | { begin | exclude | include } regular-expression ]
2: System level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Support for this command depends on the device model. For more information, see About the H3C Access Controllers Command References.
# Display the AC hot backup state.
[Sysname]display hot-backup state
Vlan ID              : 21
Domain ID            : 1
Link State           : Connect
Peer Board MAC       : 000f-e212-ff02
Peer Board State     : Normal
Hello Interval       : 200
Vlan ID
ID of the VLAN for AC hot backup.
Domain ID
Domain to which the AC belongs.
Link State
AC link state:
·     Close—Not connected.
·     Init—Being connected.
·     Connect—Connected.
Peer Board MAC
MAC address of the peer AC.
Peer Board State
Status of the peer AC:
·     Normal.
·     Abnormal.
·     Unknown—No connection is established.
Hello Interval
Heartbeat interval.
hot-backup enable
Use hot-backup enable to enable the AC hot backup function.
Use undo hot-backup enable to disable the AC hot backup function.
hot-backup enable [ domain domain-id ] *
The AC hot backup function is disabled.
2: System level
domain domain-id: Specifies the domain ID of the AC. It is in the range of 1 to 16 and defaults to 1.
You can manually configure the domain to which the AC belongs.
Support for this command depends on the device models. For more information, see About the H3C Access Controllers Command References.
# Enable the AC hot backup function.
[Sysname]hot-backup enable
hot-backup hellointerval
Use hot-backup hellointerval to set the interval for sending heartbeat messages. If the master AC or backup AC does not receive any heartbeat packets from the peer within three heartbeat intervals, it considers the peer device disconnected.
hot-backup hellointerval hellointerval
2: System level
hellointerval: Sets the interval for sending heartbeat messages, in milliseconds. The default value is 2000 milliseconds. The value range depends on your AC model. For more information, see About the H3C Access Controllers Command References.
For WX5004, WX5002V2, WX3510E, and WX3540E, set the heartbeat interval to more than 1.2 seconds.
# Set the heartbeat interval to 100 milliseconds.
[Sysname]hot-backup hellointerval 100
hot-backup vlan
Use hot-backup vlan to set the ID of the VLAN to which the port connected to another AC belongs.
hot-backup vlan vlan-id
The port connected to another AC belongs to VLAN 1.
2: System level
vlan vlan-id: Sets the ID of the VLAN to which the port connected to another AC belongs. A vlan-id is in the range of 1 to 4094.
# Set the ID of the VLAN to which the port connected to another AC belongs to 5.
[Sysname]hot-backup vlan 5
priority level
Use priority level to configure the connection priority for the AP.
Use undo priority level to restore the default.
priority level priority
undo priority level
The connection priority of an AP is 4.
2: System level
priority: Specifies the AP connection priority in the range of 0 to 7. The higher the value, the higher the priority.
# Configure the connection priority for AP 3 as 1.
[Sysname] wlan ap ap3 model WA4620I-ACN
[Sysname-wlan-ap-ap3] priority level 1
# Configure the connection priority for all APs in the AP group named office as 1.
[Sysname-ap-group-office] priority level 1
wlan backup-ac
Use wlan backup-ac to specify the backup AC.
Use undo wlan backup-ac to remove the configuration.
wlan backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo wlan backup-ac { ip | ipv6 }
No backup AC address exists.
ip ipv4-address: Specifies the IPv4 address of the backup AC.
ipv6 ipv6-address: Specifies the IPv6 address of the backup AC.
# Configure the IP address of a backup AC as 192.168.1.1.
[Sysname] wlan backup-ac ip 192.168.1.1
wlan backup-ac switch-delay
Use wlan backup-ac switch-delay to set the delay for an AP to switch from a backup AC to a primary AC.
Use undo wlan backup-ac switch-delay to remove the configuration.
wlan backup-ac switch-delay time
The delay for an AP to switch from a backup AC to a primary AC is 5 seconds.
2: System level
time: Sets the delay for an AP to switch from a backup AC to a primary AC. The value range is 0 to 600 seconds. The delay timer starts when the AP starts to establish a tunnel with the primary AC.
# Set the delay for an AP to switch from a backup AC to a primary AC to 10 seconds.
[Sysname] wlan backup-ac switch-delay 10
Client information backup commands
wlan backup-client enable
IMPORTANT
IMPORTANT:
Use wlan backup-client enable to enable client information backup.
Use undo wlan backup-client enable to disable client information backup.
Client information backup is disabled.
2: System level
Enable client information backup after you complete AC backup and mobility group configurations.
# Enable client information backup.
[Sysname] wlan backup-client enable
Uplink detection commands
wlan uplink track
Use wlan uplink track to specify a track entry for uplink detection.
Use undo wlan uplink-interface to remove the configuration.
wlan uplink track track-entry-number
undo wlan uplink track
No track entry is specified for uplink detection.
track-entry-number: Specifies the number of the track entry to be detected, in the range of 1 to 1024.
2: System level
# Specify a track entry for uplink detection.
<Sysname> system
[Sysname] wlan uplink track 1
