02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10202-WLAN Command Reference
09-Advanced WLAN Commands
09-Advanced WLAN Commands 349.58 KB
WLAN sniffer configuration commands· 1
display wlan capture· 1
wlan capture file-name· 2
wlan capture packet-limit 3
wlan capture start ap· 3
wlan capture start client 4
wlan capture stop· 4
AP provision configuration commands· 6
ac· 6
data-tunnel encryption enable· 6
dns domain· 7
dns server 8
dot1x supplicant eap-method· 8
dot1x supplicant enable· 9
dot1x supplicant password· 10
dot1x supplicant username· 10
gateway· 11
initial-country-code· 12
ip address· 12
ipv6 address· 13
provision· 13
provision auto-recovery enable· 14
reset wlan ap provision· 15
save wlan ap provision· 15
tunnel encryption ipsec pre-shared-key· 16
vlan pvid· 17
vlan tagged· 17
vlan untagged· 18
wlan ap-provision ac· 18
wlan ap-provision dns domain· 19
wlan ap-provision dns server 20
VLAN pool configuration commands· 21
display wlan statistics client vlan-pool 21
vlan-id· 22
work-mode static· 22
wlan vlan-pool 23
Wireless location configuration commands· 24
display wlan rfid-tracking radio· 24
rfid-tracking engine-address· 25
rfid-tracking mode· 26
rfid-tracking omnitrail apid· 26
rrm-report send-inhibitory enable· 27
wlan rfid-tracking antenna-change-report min-interval 27
wlan rfid-tracking client-rate-limit 28
wlan rfid-tracking cupid ap-report enable· 29
wlan rfid-tracking cupid ap-report interval 29
wlan rfid-tracking cupid unassociated-measurement enable· 30
wlan rfid-tracking cupid unassociated-measurement rssi-threshold· 30
wlan rfid-tracking dilution· 31
wlan rfid-tracking enable· 31
wlan rfid-tracking engine-detection· 32
wlan rfid-tracking engine-type· 32
wlan rfid-tracking fingerprint cupid-report enable· 33
wlan rfid-tracking ignore· 34
wlan rfid-tracking ignore radio-mode· 34
wlan rfid-tracking omnitrail 35
wlan rfid-tracking raw-frame-report enable· 35
wlan rfid-tracking rate-limit 36
wlan rfid-tracking rssi-threshold· 37
wlan rfid-tracking tag-multicast-address· 37
wlan rfid-tracking vendor-port 38
Multicast optimization configuration commands· 39
display wlan multicast optimization· 39
multicast optimization enable· 40
wlan multicast optimization aging-time· 41
wlan multicast optimization threshold· 41
wlan multicast optimization threshold-action· 42
Spectrum analysis configuration commands· 44
display wlan spectrum-analysis channel-quality· 44
display wlan spectrum-analysis device· 44
dot11a calibrate-channel sensitivity· 46
dot11a calibrate-channel track spectrum-analysis· 47
dot11a spectrum-analysis device· 47
dot11a spectrum-analysis enable· 48
dot11a spectrum-analysis trap channel-quality enable· 48
dot11a spectrum-analysis trap channel-quality threshold· 49
dot11a spectrum-analysis trap device· 49
dot11a spectrum-analysis trap device enable· 50
dot11bg calibrate-channel sensitivity· 51
dot11bg calibrate-channel track spectrum-analysis· 51
dot11bg spectrum-analysis device· 52
dot11bg spectrum-analysis enable· 53
dot11bg spectrum-analysis trap channel-quality enable· 53
dot11bg spectrum-analysis trap channel-quality threshold· 54
dot11bg spectrum-analysis trap device· 54
dot11bg spectrum-analysis trap device enable· 55
spectrum-analysis enable· 56
MAC-BAC configuration commands· 57
wlan bas-ac enable· 57
wlan bas-ac ip· 57
wlan bas-ac retry-interval 58
wlan bas-ac synchronize-configuration· 58
wlan capwap address· 59
wlan master-ac· 59
Guest access tunnel configuration commands· 61
aggregation-ac· 61
display wlan guest-tunnel 61
edge-ac· 63
keep-alive· 64
reset wlan guest-tunnel 64
wlan guest-tunnel aggregation-ac· 65
wlan guest-tunnel edge-ac· 65
Bonjour gateway commands· 67
bonjour-gateway enable· 67
bonjour-policy· 67
display wlan bonjour-policy· 68
display wlan bonjour-service· 69
service type· 70
service vlan· 71
wlan bonjour-gateway enable· 72
wlan bonjour-gateway multicast threshold· 73
wlan bonjour-gateway query enable· 73
wlan bonjour-gateway query interval 74
wlan bonjour-policy (system view) 74
wlan bonjour-policy (user profile view) 75
Hotspot 2.0 commands· 76
3gpp-info· 76
ap-venue group· 76
ap-venue name· 79
authentication-type· 80
comeback-delay· 81
dgaf enable· 81
domain-name· 82
gas-limit 82
hessid· 83
hotspot-policy· 83
ip-protocol 84
ip-type· 85
nai-realm·· 86
nai-realm unsorted· 88
network-type· 88
operator-name· 89
policy-name· 90
roam-oui 90
wan-metrics· 91
wlan hotspot-policy· 91
Support for the commands in this chapter depends on the device model. For more information, see About the H3C Access Controllers Command References.
Use display wlan capture to display information about the WLAN sniffer function.
display wlan capture [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
The information displayed varies by WLAN sniffer types.
# Display information about the radio-based WLAN sniffer function.
<Sysname> display wlan capture
                            WLAN Capture
 Capture Type   : Radio
 AP Name        : ap1
 Radio          : 1
 Radio Mode     : 802.11n(2.4GHz)
 Channel        : 1
 Capture Limit  : 10000
 File Name      : CaptureRecord.dmp
 Status         : Capturing
# Display information about the client-based WLAN sniffer function.
                            WLAN Capture
 Capture Type   : Client
 Capture ACL    : 4000
 Status         : Capturing
Capture Type
Capture types:
·     Client—Client-based WLAN sniffer.
·     Radio—Radio-based WLAN sniffer.
AP Name
AP name.
Radio
Radio ID.
Radio Mode
Radio mode, which depends on the device model.
Channel
Channel where the radio operates to capture packets.
Capture ACL
Ethernet frame header ACL used to match the MAC addresses of clients.
Capture Limit
Maximum number of packets that can be captured.
File Name
Name of the file to save the captured packets.
Status
WLAN sniffer status:
·     Capturing.
·     Writing capture file.
Use wlan capture file-name to set the name of the CAP file to which the captured packets are saved.
Use undo wlan capture file-name to restore the default.
wlan capture file-name file-name
The name of the CAP file to which the captured packets are saved is CaptureRecord.
2: System level
file-name file-name: Specifies the name of the CAP file (without an extension) to which the captured packets are saved, a string of 1 to 31 characters.
The file has a fixed extension .dmp, which is not configurable.
You are not allowed to change the name of the CAP file during the WLAN sniffer process.
# Set the name of the CAP file to which the captured packets are saved to CaptureRecord_001.
[Sysname] wlan capture file-name CaptureRecord_001
Use wlan capture packet-limit to set the maximum number of packets that can be captured by an AP.
Use undo wlan capture packet-limit to restore the default.
wlan capture packet-limit packet-limit
The maximum number of packets that can be captured by an AP is 10000.
2: System level
packet-limit packet-limit: Specifies the maximum number of packets that can be captured by an AP, in the range of 1 to 10000.
You are not allowed to change the maximum number of packets that can be captured by an AP during the WLAN sniffer process.
WLAN sniffer stops when the maximum number is reached.
# Set the maximum number of packets that can be captured by an AP to 5000.
[Sysname] wlan capture packet-limit 5000
Use wlan capture start ap to enable the radio-based WLAN sniffer function.
wlan capture start ap ap-name  radio radio-number
2: System level
ap ap-name: Specifies an AP name, a case-insensitive string of 1 to 32 characters.
radio radio-number: Specifies a radio number.
·     An auto AP does not support the WLAN sniffer function.
·     WLAN sniffer can be enabled for only one radio of an AP.
·     To enable WLAN sniffer on a radio, the AP must operate in normal mode and must be in Run state, and the working channel of the radio must be manually specified.
·     Disabling the sniffer-enabled radio or disabling WLAN sniffer stops the sniffer operation. The records are saved to the specified CAP file in the default storage medium with the specified name. The default storage medium varies by device model.
·     The working mode of the AP cannot be changed using the work-mode monitor or device-detection enable command when it is capturing packets.
# Enable the radio-based WLAN sniffer function.
[Sysname] wlan capture start ap ap1 radio 1
Use wlan capture start client acl to enable the client-based WLAN sniffer function.
wlan capture start client acl acl-number
2: System level
acl acl-number: Specifies an Ethernet frame header ACL by its number, in the range of 4000 to 4999. An Ethernet frame header ACL matches the source MAC addresses of clients.
If no rule is configured in an Ethernet frame header ACL, no MAC addresses are matched. The AP does not capture packets.
# Enable the client-based WLAN sniffer function, and configure the AP to capture the packets from MAC address 0011-0011-0011.
[Sysname] acl number 4400
[Sysname-acl-ethernetframe-4400] rule permit source-mac 0011-0011-0011 FFFF-FFFF-FFFF
[Sysname-acl-ethernetframe-4400] quit
[Sysname] wlan capture start client acl 4400
wlan capture stop
Use wlan capture stop to disable the WLAN sniffer function, and save the captured packets in the specified CAP file.
wlan capture stop
2: System level
# Disable the WLAN sniffer function.
[Sysname] wlan capture stop
ac
Use ac to specify the IP address or host name of an AC so that the AP can discover the AC.
Use undo ac to remove the AC configuration.
ac { host-name host-name | ip ip-address | ipv6 ipv6-address }
undo ac { host-name | ip { ip-address | all } | ipv6 { ipv6-address | all } }
No AC IP address or host name is specified.
AP provision view
2: System level
host-name host-name: Specifies the host name of an AC, which is a case-insensitive string of 1 to 255 characters. The string can contain letters, digits, "-", "_" and ".", and must contain at least one letter.
ip ip-address: Specifies the IPv4 address of an AC.
ipv6 ipv6-address: Specifies the IPv6 address of an AC.
all: Removes the IPv4/IPv6 addresses of all ACs.
You can specify a maximum number of three AC IP addresses, three AC IPv6 addresses, and an AC host name for the AP.
The IPv6 address of an AC cannot be the link local address.
The wlan ap-provision ac command takes effect for all APs, and the ac command in AP provision view takes effect for the specified AP. If you configure both commands, the configuration in AP provision view takes effect for the AP.
# Specify the AC 192.168.100.11 so that AP 1 can discover the AC.
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.100.11
Use data-tunnel encryption enable to configure the AP to use IPsec to encrypt the data tunnel.
Use undo data-tunnel encryption enable to remove the configuration.
The AP does not encrypt the data tunnel.
AP configuration view
2: System level
# Configure the AP to use IPsec to encrypt the data tunnel.
[Sysname] wlan ap ap1 model WA2620-AGN
[Sysname-wlan-ap-ap1-prvs] tunnel encryption ipsec pre-shared-key simple 12345
[Sysname-wlan-ap-ap1-prvs] data-tunnel encryption enable
dns domain
Use dns domain to set a domain name for the AP.
Use undo dns domain to remove the configuration.
dns domain domain-name
undo dns domain
No domain name is specified for the AP.
AP provision view
Default Level
2: System level
domain-name: Specifies a domain name for the DNS server. It is a case-insensitive string of 1 to 238 characters separated by dots and can contain letters, digits, "-", and "_".
You can set only one domain name for the AP.
The wlan ap-provision dns domain command takes effect on all APs, and the dns domain command in AP provision view takes effect on the specified AP. If you configure both commands, the configuration in AP provision view applies to the specified AP.
# Set the domain name for AP 1 to com.
[Sysname-wlan-ap-ap1-prvs] dns domain com
dns server
Use dns server to set a DNS server for the AP.
Use undo dns server to remove the DNS server for the AP.
dns server { ip ip-address | ipv6 ipv6-address }
undo dns server { ip | ipv6 }
No DNS server is specified for the AP.
AP provision view
Default Level
2: System level
ip ip-address: Specifies the IPv4 address of the DNS server.
ipv6 ip-address: Specifies the IPv6 address of the DNS server.
You can specify only one IPv4 DNS server and one IPv6 DNS server.
The wlan ap-provision dns server command takes effect on all APs, and the dns server command in AP provision view takes effect on the specified AP. If you configure both commands, the configuration in AP provision view applies to the specified AP.
# Set the IPv4 address of the DNS server to 192.168.100.123.
[Sysname-wlan-ap-ap1-prvs] dns server ip 192.168.100.123
Use dot1x supplicant eap-method to set the authentication method for an AP acting as an 802.1X client.
Use undo dot1x supplicant eap-method to remove the authentication method.
dot1x supplicant eap-method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
No authentication method is configured for an AP when it acts as an 802.1X client.
AP template view
2: System level
md5: Specifies the MD5 authentication method.
peap-gtc: Specifies the PEAP-GTC authentication method.
peap-mschapv2: Specifies the PEAP-MSCHAPV2 authentication method.
ttls-gtc: Specifies the TTLS-GTC authentication method.
ttls-mschapv2: Specifies the TTLS-MSCHAPV2 authentication method.
The MD5 authentication method is used by default after you enable the 802.1X client function for the AP.
# Set the authentication method for AP 1 that acts as an 802.1X client to md5.
[Sysname] wlan ap ap1 model MSM460-WW
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant eap-method md5
Use dot1x supplicant enable to enable the 802.1X client function for an AP.
Use undo dot1x supplicant enable to disable the 802.1X client function for an AP.
The 802.1X client is not enabled for an AP.
AP template view
2: System level
# Enable the 802.1X client function for AP 1.
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant enable
Use dot1x supplicant password to configure an authentication password for an AP acting as an 802.1X client.
Use undo dot1x supplicant password to remove the authentication password.
dot1x supplicant password { cipher | simple } password
No authentication password is configured for an AP when it acts as an 802.1X client.
AP template view
2: System level
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies the password string. This argument is case sensitive. A cipher password is a string of 1 to 201 characters. A plaintext password is a string of 1 to 127 characters.
# Set the authentication password for AP 1 that acts as an 802.1X client to 123456.
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant password simple 123456
Use dot1x supplicant username to set an authentication username for an AP acting as an 802.1X client.
Use undo dot1x supplicant username remove the authentication username.
dot1x supplicant username username
No authentication username is configured for an AP when it acts as an 802.1X client.
AP template view
2: System level
username: Specifies the authentication username for 802.1X authentication, a case-sensitive string of 1 to 253 characters.
# Set the authentication username for AP 1 that acts as an 802.1X client to aaa.
[Sysname-wlan-ap-ap1-prvs] dot1x supplicant username aaa
gateway
Use gateway to set a gateway for the AP.
Use undo gateway to remove gateway configuration.
gateway { ip ip-address | ipv6 ipv6-address }
undo gateway { ip | ipv6 | all }
No gateway is specified for the AP.
AP provision view
2: System level
ip ip-address: Specifies the IPv4 address of the gateway.
ipv6 ipv6-address: Specifies the IPv6 address of the gateway.
all: Removes all IP addresses of gateways.
You can specify only one IPv4 gateway and one IPv6 gateway for the AP.
# Set the gateway IP address for AP 1 to 192.168.100.1
[Sysname-wlan-ap-ap1-prvs] gateway ip 192.168.100.1
Use initial-country-code to set the initial country code for an AP when the AP scans the mesh network at the first startup.
Use undo initial-country-code to restore the default.
initial-country-code code
No initial country code is configured for an AP.
2: System level
code: Specifies the initial country code for an AP.
An AP uses the initial country code configured with this command when it scans the mesh network at the first startup. Otherwise, it uses the default country code CN.
After the AP is associated with an AC, it uses the country code applied by the AC.
# Set the initial country code to AU for AP 1 when the AP scans the mesh network at the first startup.
[Sysname-wlan-ap-ap1-prvs] initial-country-code AU
ip address
Use ip address to set the IP address of the management VLAN interface of the AP.
Use undo ip address to remove the IP address of the management VLAN interface of the AP.
ip address ip-address { mask | mask-length }
undo ip address
No IP address is specified for the management VLAN interface of an AP.
2: System level
ip-address: IP address of the management VLAN interface of the AP, in dotted decimal notation.
mask: Subnet mask in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask. It is in the range of 0 to 32.
# Set the IP address of the management VLAN interface of AP 1 to 192.168.100.100/24.
[Sysname-wlan-ap-ap1-prvs] ip address 192.168.100.100 24
ipv6 address
Use ipv6 address to set the IPv6 address of the management VLAN interface of the AP.
Use undo ipv6 address to remove the IPv6 address of the management VLAN interface of the AP.
undo ipv6 address
No IPv6 address is specified for the management VLAN interface of the AP.
2: System level
ipv6-address: IPv6 address of the management VLAN interface of the AP.
prefix-length: Prefix length, in the range of 1 to 128.
# Set the IPv6 address of the management VLAN interface of AP 1 to 2001::1/64.
[Sysname-wlan-ap-ap1-prvs] ipv6 address 2001::1/64
provision
Use provision to create and enter AP provision view.
Use undo provision to remove the AP provision view and all configurations in the view.
provision
undo provision
No AP provision view is created.
AP template view
2: System level
After you create the AP provision view, the device automatically adds the vlan untagged 1 command.
An auto AP cannot be configured with the AP provision function.
# Create and enter the provision view for AP 1.
Use provision auto-recovery enable to enable auto recovery of startup with zero-configuration.
Use undo provision auto-recovery enable to restore the default.
Auto recovery of startup with zero-configuration is enabled.
AP template view, AP group view
2: System level
When preprovisioned settings are configured, an AP restarts with the preprovisioned settings to establish a tunnel with the AC. If tunnel establishment fails, the AP restarts after a period of time.
If this feature is enabled, the AP restarts with zero-configuration. Otherwise, the AP continues to restart with the preprovisioned settings.
# Disable auto recovery of startup with zero-configuration for AP ap1.
[Sysname] wlan ap ap3 model WA3628i-AGN
[Sysname-wlan-ap-ap3] undo provision auto-recovery enable
# Disable auto recovery of startup with zero-configuration for APs in AP group office.
[Sysname] wlan ap-group office
[Sysname-ap-group-office] undo provision auto-recovery enable
Use reset wlan ap provision to remove the wlan_ap_cfg.wcfg file of the specified AP or all APs.
reset wlan ap provision { all | name ap-name }
2: System level
all: Specifies all APs.
name ap-name: Specifies an AP by its name, which is a string of 1 to 32 characters that can contain case-insensitive letters and digits, and special characters such as underscore(_), left bracket ([), right bracket (]), slash (/), hyphen (-), and spaces.
This command takes effect only on APs in Run state.
# AP 1 has been connected to the AC. Remove the wlan_ap_cfg.wcfg file of AP 1.
<Sysname> reset wlan ap provision name ap1
Use save wlan ap provision to save the configuration in AP provision view to the wlan_ap_cfg.wcfg file of the specified AP or all APs.
save wlan ap provision { all | name ap-name }
2: System level
name ap-name: Specifies an AP by its name, a string of 1 to 32 characters that can contain case-insensitive letters and digits, and special characters such as underscore(_), left bracket ([), right bracket (]), slash (/), hyphen (-), and spaces.
·     This command takes effect only on APs in Run state. It does not take effect on APs that establish a connection with the AC after you execute the save wlan ap-provision command.
·     After you execute the save wlan ap-provision command, restart the specified AP to validate the configuration.
·     After restart, the AP executes the configuration file, the wlan_ap_cfg.wcfg file, and the configuration file specified by the map-configuration command in turn. Make sure the wlan_ap_cfg.wcfg file and the configuration file specified by the map-configuration command are correct because wrong configurations may make the three configuration files overwrite or conflict with one another.
·     After you execute the save wlan ap provision command on the AC, the configuration is saved to the wlan_ap_cfg.wcfg file of the specified AP. When the wlan_ap_cfg.wcfg file takes effect, the AP can only be managed by the AC specified by the ac or wlan ap-provision ac command. Make sure the correct AC is specified; otherwise, the AP cannot be managed by the specified AC, and you have to log in to the AP to modify its configuration.
# AP 1 has established a connection with the AC. Save the configuration in AP provision view to the wlan_ap_cfg.wcfg file of AP 1.
<Sysname> save wlan ap provision name ap1
·     map-configuration
·     reset wlan ap provision
·     reset wlan ap
Use tunnel encryption ipsec pre-shared-key to configure the AP to use IPsec to encrypt the control tunnel.
Use undo tunnel encryption ipsec pre-shared-key to remove the configuration.
tunnel encryption ipsec pre-shared-key { cipher | simple } key
The AP does not encrypt the control tunnel.
2: System level
cipher: Specifies a ciphertext key.
simple: Specifies a plaintext key.
key: Encryption key. It is a case-sensitive string of 1 to 128 characters for a plaintext key, or a case-sensitive string of 1 to 201 characters for a ciphertext key.
This command only enables the AP to encrypt the control tunnel. To enable the AP to encrypt the data tunnel, use the data-tunnel encryption enable command. The undo tunnel encryption ipsec pre-shared-key command removes the configuration for both data tunnel encryption and control tunnel encryption.
# Configure the AP to use plaintext key 12345 to encrypt the control tunnel.
vlan pvid
Use vlan pvid to set the default VLAN ID of the Ethernet interface on the AP.
Use undo vlan pvid to restore the default.
vlan pvid vlan-id
undo vlan pvid
The default VLAN ID of the Ethernet interface on an AP is 1.
2: System level
vlan-id: Default VLAN ID of the Ethernet interface on the AP. It is in the range of 1 to 4094.
# Set the default VLAN ID of the Ethernet interface on AP 1 to 5.
[Sysname-wlan-ap-ap1-prvs] vlan pvid 5
vlan tagged
Use vlan tagged to set a list of VLANs whose packets are sent tagged on the Ethernet interface of the AP.
vlan tagged vlan-id-list
undo vlan tagged vlan-id-list
No packets are sent tagged on the Ethernet interface on the AP.
2: System level
vlan-id-list: Specifies a list of VLANs whose packets are sent tagged on the Ethernet interface of the AP. It is in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs.
# Configure packets in VLAN 6 to be sent tagged on the Ethernet interface on AP 1.
[Sysname-wlan-ap-ap1-prvs] vlan tagged 6
vlan untagged
Use vlan untagged to configure a list of VLANs whose packets are sent untagged on the Ethernet interface of the specified AP.
Use undo vlan tagged to remove the configuration.
vlan untagged vlan-id-list
undo vlan untagged vlan-id-list
The packets of VLAN 1 are sent untagged on the Ethernet interface of the specified AP.
2: System level
vlan-id-list: Specifies a list of VLANs whose packets are sent untagged on the Ethernet interface of the AP. It is in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs.
# Configure packets in VLAN 7 to be sent untagged on the Ethernet interface of AP 1.
[Sysname-wlan-ap-ap1-prvs] vlan untagged 7
Use wlan ap-provision ac to set a global AC so that all APs can discover the AC.
Use undo wlan ap-provision ac to restore the default.
wlan ap-provision ac { host-name host-name | ip ip-address | ipv6 ipv6-address }
undo wlan ap-provision ac { host-name | ip { ip-address | all } | ipv6 { ipv6-address | all } }
No global AC is specified.
2: System level
host-name host-name: Specifies the host name of a global AC. It is a case-insensitive string of 1 to 255 characters, which can contain letters, digits, "-", "_" and ".", and must contain at least one letter.
ip ip-address: Specifies the IPv4 address of a global AC.
ipv6 ipv6-address: Specifies the IPv6 address of a global AC.
all: Removes the IPv4/IPv6 addresses of all global ACs.
The wlan ap-provision ac command takes effect on all APs, and the ac command in AP provision view takes effect on the specified AP. If you configure both commands, the configuration in AP provision view is preferred by the specified AP.
You can specify a maximum number of three AC IP addresses, three AC IPv6 addresses, and an AC host name for all APs.
# Set the IPv4 address of the global AC to 192.168.100.11 so that all APs can discover the AC.
[Sysname] wlan ap-provision ac ip 192.168.100.11
ac
Use wlan ap-provision dns domain to set a global domain name.
Use undo wlan ap-provision dns domain to remove the configuration.
wlan ap-provision dns domain domain-name
No global domain name is specified.
Default Level
2: System level
domain-name: Specifies a domain name. It is a case-insensitive string of 1 to 238 characters separated by dots, which can contain letters, digits, "-", and "_".
You can specify only one global domain name.
# Set the global domain name to com.
[Sysname] wlan ap-provision dns domain com
dns domain
Use wlan ap-provision dns server to specify a global DNS server.
Use undo wlan ap-provision dns server to remove the configuration.
wlan ap-provision dns server { ip ip-address | ipv6 ipv6-address }
undo wlan ap-provision dns server { ip | ipv6 }
No global DNS server is specified.
Default Level
2: System level
ip ip-address: Specifies a global DNS server by its IPv4 address.
ipv6 ip-address: Specifies a global DNS server by its IPv6 address.
You can specify only one global IPv4 DNS server and one global IPv6 DNS server.
# Specify the global DNS server with the IPv4 address 192.168.100.124.
[Sysname] wlan ap-provision dns server ip 192.168.100.124
dns server
Use display wlan statistics client vlan-pool to display statistics about a VLAN pool.
display wlan statistics client vlan-pool vlan-pool-name [ | { begin | exclude | include } regular-expression ]
1: Monitor level
vlan-pool-name: Specifies a VLAN pool by its name, a case-insensitive string of 1 to 16 characters.
# Display statistics about the specified VLAN pool.
<Sysname> display wlan statistic client vlan-pool office
                        VLAN Pool Information
 VLAN Pool Name   : office
 VLAN List        : 1 to 6, 10, 12
 VLANs in Use     : 1 to 5, 10, 12
 Total Clients    : 59
 VLAN ID      Number of Clients
 1              10
 2              6
 3              10
 4              9
 5            9
 10           7
 12           8
VLAN Pool Name
VLAN pool name.
VLAN List
VLAN IDs in the VLAN pool.
VLANs in Use
VLANs used by clients.
After a client goes online by using the VLAN ID assigned by the VLAN pool, if you remove the VLAN ID from the VLAN pool, this field still displays the VLAN ID.
Total Clients
Total number of online clients that obtain VLAN IDs through the VLAN pool.
VLAN ID
Assigned VLAN IDs in the VLAN pool.
Number of Clients
Number of clients corresponding to each VLAN ID.
This field displays the number of clients that obtain VLAN IDs through the VLAN pool, but not the clients that obtain VLAN IDs through other methods such as a server-assigned VLAN.
vlan-id
Use vlan-id to add VLANs to a VLAN pool.
vlan-id vlan-list
undo vlan-id { vlan-list | all }
VLAN pool view
2: System level
vlan-list: Specifies a list of VLANs, in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }, where vlan-id is in the range of 1 to 4094.
all: Specifies all VLANs in the VLAN pool.
# Add VLANs to a VLAN pool.
<Sysname> system
[Sysname] wlan vlan-pool office
[Sysname-wlan-vp-office] vlan-id 3 5 to 8
work-mode static
Use work-mode static to enable static VLAN assignment.
Use undo work-mode static to restore the default.
work-mode static
Static VLAN assignment is disabled.
VLAN pool view
2: System level
To avoid frequent VLAN changes, you can enable static VLAN assignment. This feature allows a client to use the VLAN that has been assigned to it when the client comes online again by using the same SSID.
# Enable static VLAN assignment.
<Sysname> system
[Sysname-wlan-vp-office] work-mode static
wlan vlan-pool
Use wlan vlan-pool to create a VLAN pool and enter its view.
Use undo wlan vlan-pool to remove the specified VLAN pool.
wlan vlan-pool vlan-pool-name
undo wlan vlan-pool vlan-pool-name
No VLAN pool exists.
2: System level
vlan-pool-name: Specifies the VLAN pool name, a case-insensitive string of 1 to 16 characters.
You can create up to 32 VLAN pools.
# Create a VLAN pool named office.
Use display wlan rfid-tracking radio to display radio information for wireless location.
display wlan rfid-tracking radio [ ap ap-name radio radio-id ] [ | { begin | exclude | include } regular-expression ]
2: System level
ap ap-name: Displays radio information about the specified AP. If no AP is specified, radio information about all APs is displayed.
radio radio-id: Displays information about the specified radio. If you do not provide the option, information about all radios is displayed.
# Display radio information for wireless location.
<Sysname> display wlan rfid-tracking radio
                            WLAN RFID Tracking
 AP                                 Radio   Mode
 2220                               1       MU/Tag
 AP_wa2620e_agn_1                   1       MU
 AP_wa2620e_agn_1                   2       Tag
 AP_wa2620e_agn_2                   1       N/A
AP
AP name.
Radio
Radio ID.
Mode
Wireless location mode:
·     MU/Tag—Supports both MU and Tag modes.
·     MUMU mode.
·     TagTag mode.
·     N/A—No wireless location mode is configured.
Use rfid-tracking engine-address to set an IPv4 address for the wireless location server. The AP uses this IP address as the destination address to send location frames to the location server.
Use undo rfid-tracking engine-address to restore the default.
rfid-tracking engine-address engine-address
No IPv4 address is configured for the location server.
View
2: System level
engine-address: Specifies an IPv4 address for the location server.
This command is available only when the wireless location method is static.
When you change the wireless location method from static to dynamic, the command becomes unavailable and restores to its default setting.
# In AP template view, set the IPv4 address of the location server to 192.168.10.10.
[Sysname-ap-ap1] rfid-tracking engine-address 192.168.10.10
# In AP group view, set the IPv4 address of the location server to 192.168.10.10.
[Sysname] wlan ap-group 10
[Sysname-ap-group10] rfid-tracking engine-address 192.168.10.10
rfid-tracking mode
Use rfid-tracking mode to set the wireless location mode.
Use undo rfid-tracking mode to restore the default.
rfid-tracking mode { all | mu | tag }
undo rfid-tracking mode { all | mu | tag }
Radio view
2: System level
all: Supports both tag and mu modes.
tag: Specifies the AeroScout-proprietary mode. Wireless devices in this mode are provided by AeroScout.
mu: Specifies the mu mode. Wireless location devices in this mode refer to all wireless devices such as mobiles phones, wireless network interface cards, and APs compliant with 802.11 protocols.
# Set the wireless location mode.
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rfid-tracking mode tag
Use rfid-tracking omnitrail apid to set the AP identifier for OmniTrail location.
Use undo rfid-tracking omnitrail apid to restore the default.
rfid-tracking omnitrail apid { ascii ascii-string | hex hex-string }
No AP identifier is specified for OmniTrail location.
AP template view
2: System level
ascii ascii-string: Specifies an ASCII string of 1 to 12 characters.
hex hex-string: Specifies a hexadecimal string of 1 to 24 characters.
# Set the AP identifier for OmniTrail location to hexadecimal string 1234.
[Sysname-wlan-ap-ap3] rfid-tracking omnitrail apid hex 1234
Use rrm-report send-inhibitory enable to enable channel scanning report suppression.
Use undo rrm-report send-inhibitory enable to restore the default.
Channel scanning report suppression is disabled.
AP template view
2: System level
When this feature is enabled, an AP reports a maximum of one scanning report every 10 seconds. Whether to send the report depends on the scanning status and scanning result.
This feature is available only when wireless location is enabled and WLAN RRM is not configured.
# Enable channel scanning report suppression.
[Sysname-wlan-ap-ap1] rrm-report send-inhibitory enable
Use wlan rfid-tracking antenna-change-report min-interval to set the minimum interval at which APs report client antenna changes.
Use undo wlan rfid-tracking antenna-change-report min-interval to restore the default.
wlan rfid-tracking antenna-change-report min-interval value
APs report client antenna changes at a minimum interval of 10 seconds.
2: System level
value: Specifies the minimum interval at which APs report client antenna changes, in the range of 1 to 60 seconds.
This feature takes effect only when fingerprint location is enabled.
# Set the minimum interval at which APs report client antenna changes to 5 seconds.
[Sysname] wlan rfid-tracking antenna-change-report min-interval 5
Use wlan rfid-tracking client-rate-limit to set the rate at which a client sends wireless location frames to the location server. The excessive frames are discarded when the configured rate is exceeded.
Use undo wlan rfid-tracking client-rate-limit to restore the default.
wlan rfid-tracking client-rate-limit cir [ cbs cbs ]
Client wireless location frame sending rate is not limited.
2: System level
cir: Specifies the committed information rate in the range of 1 to 1300000 Kbps.
cbs cbs: Specifies the committed burst size in the range of 80 to 130000000 bytes.
The dilution factor and dilution timeout configurations do not take effect after you configure this command.
# Limit the committed information rate to 1 Kbps, and the committed burst size to 1000 bytes.
[Sysname] wlan rfid-tracking client-rate-limit 1 cbs 1000
Use wlan rfid-tracking cupid ap-report enable to enable AP reporting for CUPID location.
Use undo wlan rfid-tracking cupid ap-report enable to restore the default.
AP reporting for CUPID location is disabled.
2: System level
This feature enables APs to periodically send AP and client information to the CUPID location server for wireless location. The AP and client information includes AP serial ID, AP MAC address, radio information, client MAC address, and client encryption information.
# Enable AP reporting.
[Sysname] wlan rfid-tracking cupid ap-report enable
Use wlan rfid-tracking cupid ap-report interval to set the AP reporting interval.
Use undo wlan rfid-tracking cupid ap-report interval to restore the default.
wlan rfid-tracking cupid ap-report interval interval
The AP reporting interval is 2 seconds.
2: System level
interval: Specifies the AP reporting interval in the range of 1 to 10 seconds.
# Set the AP reporting interval to 5 seconds.
[Sysname] wlan rfid-tracking cupid ap-report interval 5
Use wlan rfid-tracking cupid unassociated-measurement enable to enable CUPID location for unassociated clients.
Use undo wlan rfid-tracking cupid unassociated-measurement enable to restore the default.
CUPID location for unassociated clients is disabled.
2: System level
# Enable CUPID location for unassociated clients.
[Sysname] wlan rfid-tracking cupid unassociated-measurement enable
Use wlan rfid-tracking cupid unassociated-measurement rssi-threshold to set the RSSI threshold for unassociated client CUPID location.
Use undo wlan rfid-tracking cupid unassociated-measurement rssi-threshold to restore the default.
wlan rfid-tracking cupid unassociated-measurement rssi-threshold rssi
undo wlan rfid-tracking cupid unassociated-measurement rssi-threshold rssi
No RSSI threshold is specified for unassociated client CUPID location.
2: System level
rssi: Specifies the RSSI threshold in the range of 5 to 100. The system does not perform CUPID location on an unassociated client if the RSSI of the client is lower than the threshold.
# Set the RSSI threshold for unassociated client CUPID location to 20.
[Sysname] wlan rfid-tracking cupid unassociated-measurement rssi-threshold 20
Use wlan rfid-tracking dilution to set a dilution factor and dilution timeout for wireless location frames.
Use undo wlan rfid-tracking dilution to restore the default.
wlan rfid-tracking dilution factor factor timeout timeout
No dilution factor and dilution timeout are configured.
2: System level
factor factor: Specifies the dilution factor for wireless location frames, in the range of 1 to 10000. A dilution factor restricts the number of frames reported by the AP to the location server. For example, if you configure the dilution factor as 10, the AP sends a wireless location frame to the location server every time it receives 10 wireless frames from a client (excluding management and broadcast frames).
timeout timeout: Specifies the dilution timeout for wireless location frames, in the range of 1 to 60 seconds. When this option is specified, if the number of wireless frames does not reach the dilution factor within the timeout, the AP sends the most recent frame it received to the location server.
This command does not take effect when wireless location frame rate limit is configured.
# Set both the dilution factor and timeout to 10 for wireless location packets.
[Sysname] wlan rfid-tracking dilution factor 10 timeout 10
·     wlan rfid-tracking engine-detection
·     wlan rfid-tracking rate-limit
Use wlan rfid-tracking enable to enable wireless location.
Use undo wlan rfid-tracking enable to restore the default.
Wireless location is disabled.
2: System level
# Enable wireless location.
[Sysname] wlan rfid-tracking enable
Use wlan rfid-tracking engine-detection to set the wireless location method.
Use undo wlan rfid-tracking engine-detection to restore the default.
wlan rfid-tracking engine-detection { static | dynamic }
The static wireless location method is used.
2: System level
static: Specifies the static wireless location method.
dynamic: Specifies the dynamic wireless location method.
You can change the wireless location method only when wireless location is disabled.
This command is available only when the wireless location protocol is AeroScout.
# Set the wireless location method to dynamic.
[Sysname] wlan rfid-tracking engine-detection dynamic
Use wlan rfid-tracking engine-type to set the wireless location protocol.
Use undo wlan rfid-tracking engine-type to restore the default.
wlan rfid-tracking engine-type { aero-scout | general [ mode { fingerprint | cupid } ] | omnitrail }
The AeroScout protocol is used for wireless location.
2: System level
aero-scout: Specifies the AeroScout protocol.
general: Specifies a general wireless location protocol.
mode fingerprint: Specifies the fingerprint location mode. By default, the general wireless location protocol uses the fingerprint location mode.
mode cupid: Specifies the CUPID location mode.
omnitrail: Specifies the OmniTrail protocol.
If the wireless location protocol is general or OmniTrail, only the static wireless location method can be used. If the wireless location protocol is AeroScout, both static and dynamic wireless location methods can be used.
You can change the protocol for wireless location only when wireless location is disabled.
# Set the protocol for wireless location to AeroScout.
[Sysname] wlan rfid-tracking engine-type aero-scout
Use wlan rfid-tracking fingerprint cupid-report enable to enable an AP to send fingerprint location packets in CUPID packet format.
Use undo wlan rfid-tracking fingerprint cupid-report enable to restore the default.
An AP sends fingerprint location packets in fingerprint packet format.
2: System level
# Enable an AP to send fingerprint location packets in CUPID packet format.
[Sysname] wlan rfid-tracking fingerprint cupid-report enable
Use wlan rfid-tracking ignore to enable ignoring AP frames or beacon frames.
Use undo wlan rfid-tracking ignore to restore the default.
wlan rfid-tracking ignore { ap-frame | beacon }
undo wlan rfid-tracking ignore { ap-frame | beacon }
AP frames and beacon frames are not ignored.
2: System level
ap-frame: Specifies AP frames.
beacon: Specifies beacon frames.
Ignoring beacon frames prevents traffic flood to the location server. Ignoring AP frames saves uplink bandwidth and improves the server's performance. When this command is enabled, the wireless location module does not process received beacon frames or AP frames.
# Enable ignoring beacon frames.
[Sysname] wlan rfid-tracking ignore beacon
# Enable ignoring AP frames.
[Sysname] wlan rfid-tracking ignore ap-frame
Use wlan rfid-tracking ignore radio-mode to enable the AC to ignore radio modes.
Use undo wlan rfid-tracking ignore radio-mode to restore the default.
Ignoring radio modes is enabled.
2: System level
This command is available only when the wireless location method is dynamic.
# Disable the AC from ignoring radio modes.
[Sysname] undo wlan rfid-tracking ignore radio-mode
Use wlan rfid-tracking omnitrail to specify the server port to which OmniTrail location packets are reported.
Use undo wlan rfid-tracking omnitrail to restore the default.
wlan rfid-tracking omnitrail { data-port-2g port-number | data-port-5g port-number }
undo wlan rfid-tracking omnitrail { data-port-2g | data-port-5g }
No server port is specified for OmniTrail location packets to be reported.
2: System level
data-port-2g port-number: Specifies the server port to which 2.4 GHz radios report packets, in the range of 0 to 65535.
data-port-5g port-number: Specifies the server port to which 5 GHz radios report packets, in the range of 0 to 65535.
# Specify the server port to which 2.4 GHz radios report OmniTrail location packets as 1000.
Use wlan rfid-tracking raw-frame-report enable to enable raw frame reporting.
Use undo wlan rfid-tracking raw-frame-report enable to restore the default.
Raw frame reporting is enabled.
2: System level
This feature enables an AP to encapsulate both the raw frames and the location information obtained from the frames in location packets.
# Enable raw frame reporting.
[Sysname] undo wlan rfid-tracking raw-frame-report enable
Use wlan rfid-tracking rate-limit to set the rate at which the AP sends wireless location frames to the location server to prevent wireless location frame flood to the location server. The excessive frames are discarded when the configured rate is exceeded.
Use undo wlan rfid-tracking rate-limit to restore the default.
wlan rfid-tracking rate-limit cir [ cbs cbs ]
AP wireless location frame sending rate is not limited.
2: System level
cir: Sets the committed information rate in the range of 8 to 1300000 Kbps.
cbs cbs: Sets the committed burst size in the range of 500 to 130000000 bytes.
# Limit the committed information rate to 16 Kbps, and the committed burst size to 3000 bytes.
[Sysname] wlan rfid-tracking rate-limit 16 cbs 3000
Use wlan rfid-tracking rssi-threshold to set an RSSI threshold for wireless location frames. When the RSSI of the wireless frames received by the AP is lower than the RSSI threshold, the wireless location module does not process these frames.
Use undo wlan rfid-tracking rssi-threshold to restore the default.
wlan rfid-tracking rssi-threshold rssi-threshold
No RSSI threshold is configured.
2: System level
rssi-threshold: Specifies an RSSI threshold for wireless location packets, in the range of 5 to 100.
# Set the RSSI threshold for wireless location packets to 40.
[Sysname] wlan rfid-tracking rssi-threshold 40
Use wlan rfid-tracking tag-multicast-address to specify a multicast MAC address for Tags.
Use undo wlan rfid-tracking tag-multicast-address to restore the default.
wlan rfid-tracking tag-multicast-address mac-address
No multicast MAC address is specified for Tags.
2: System level
mac-address: Specifies a MAC address.
An AP identifies a Tag by the destination MAC address in the received wireless packet. Location information about Tags with a matched destination MAC address will be reported to the location server.
# Specify a multicast MAC address for Tags as 010c-cc00-0000.
[Sysname] wlan rfid-tracking tag-multicast-address 010c-cc00-0000
Use wlan rfid-tracking vendor-port to set the port number for the location server vendor.
Use undo wlan rfid-tracking vendor-port to restore the default.
wlan rfid-tracking vendor-port vendor-port-value
The port number for the location server vendor is 1144.
2: System level
vendor-port vendor-port-value: Port number for the wireless location server vendor, in the range of 0 to 65535.
# Set the port number for the location server vendor to 3000.
[Sysname] wlan rfid-tracking vendor-port 3000
Use display wlan multicast optimization to display multicast optimization information.
display wlan multicast optimization { all | ap-name ap-name radio radio-id } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ap-name ap-name radio radio-id: Specifies an AP by its name and a radio by its ID.
# Display multicast optimization information for radios on all APs.
<Sysname> display wlan multicast optimization all
                      Multicast Optimization Information
AP Name: ap1
  Radio: 2
    Total clients: 7
    Action: Optimize
      Multicast Address: 229.0.0.1
        MAC Address:
        8234-1101-1116, 8234-1101-1117
      Multicast Address: 229.0.0.2
        MAC Address:
      Multicast Address: FF00:AC1E:A::1
        MAC Address:
        8234-1101-1116, 8234-1101-1117, 8234-1101-1118
# Display multicast optimization information for radio 2 on AP 1.
<Sysname> display wlan multicast optimization ap1 radio 2
Total clients: 7
Action: Halt
    MAC Address:
    MAC Address:
    MAC Address:
AP Name
The name of an AP.
Radio ID
The Radio ID clients used to access an AP.
Total clients
Total number of clients served by multicast optimization.
If a client joins multiple multicast groups, the client is counted as multiple clients. For example, if a client has joined two multicast groups through a radio, the client is counted as two clients by multicast optimization.
Action
Operating status of the multicast optimization function:
·     OptimizeThe multicast optimization function is operating.
·     HaltThe multicast optimization function is halted.
Multicast Address
Address of the multicast group that the clients has joined.
MAC Address
MAC addresses of the clients that have joined the multicast group.
Use multicast optimization enable to enable multicast optimization.
Use undo multicast optimization enable to restore the default.
Multicast optimization is disabled.
Service template view
2: System level
# Enable multicast optimization for service template 1.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] multicast optimization enable
Use wlan multicast optimization aging-time to set the aging time for multicast optimization entries.
Use undo wlan multicast optimization aging-time to restore the default.
wlan multicast optimization aging-time time
The aging time for multicast optimization entries is 260 seconds.
2: System level
time: Specifies the aging time for multicast optimization entries, in the range of 200 to 1000 seconds.
If the AP does not receive any IGMP report from a client within the aging time, the AP removes the client from the multicast optimization entry.
Enable IGMP snooping on the AC before enabling multicast optimization and configure the aging time of multicast optimization entries to be greater than the aging time of IGMP snooping dynamic member ports.
# Set the aging time for multicast optimization entries to 300 seconds.
[Sysname] wlan multicast optimization aging-time 300
·     display wlan multicast optimization
·     igmp-snooping enable in IP Multicast Commands.
·     igmp-snooping host-aging-time in IP Multicast Commands.
Use wlan multicast optimization threshold to set the maximum number of clients supported by multicast optimization.
Use undo wlan multicast optimization threshold to restore the default.
wlan multicast optimization threshold threshold-value
The maximum number of clients supported by multicast optimization is 6.
2: System level
threshold-value: Specifies the maximum number of clients supported by multicast optimization, in the range of 2 to 124.
If a client joins multiple multicast groups, the client is counted as multiple clients in multicast optimization statistics. For example, if a client has joined two multicast groups, the client is counted as two clients in the multicast optimization statistics.
Each client can join eight multicast groups at most.
# Set the maximum number of clients allowed for multicast optimization to 7.
[Sysname] wlan multicast optimization threshold 7
Use wlan multicast optimization threshold-action to set the action to take when the maximum number of clients supported multicast optimization is reached.
Use undo wlan multicast optimization threshold-action to restore the default.
wlan multicast optimization threshold-action { halt | reject-client }
The multicast optimization function is halted when the maximum number of clients supported by multicast optimization is reached.
2: System level
halt: Invalidates the multicast optimization function. A new client can join a multicast group and receive multicast packets, and a multicast optimization entry can be created for the client. However, the multicast optimization function for all clients in the multicast group becomes invalid. When the number of clients drops below the upper limit, the multicast optimization function takes effect again.
reject-client: Rejects new clients. A new client can join a multicast group, but no new multicast optimization entries can be created. If multicast optimization entries have been created for other clients in the multicast group, the client cannot receive multicast packets. If not, the client can receive multicast packets.
If you configure the halt mode first, and then configure the reject mode, the existing multicast optimization entries still take effect.
# Configure the AC to reject new clients when the maximum number of clients supported multicast optimization is reached.
[Sysname] wlan multicast optimization threshold-action reject-client
·     wlan multicast optimization threshold
Support for spectrum analysis depends on AP models.
Use display wlan spectrum-analysis channel-quality to display channel quality information detected by an AP.
display wlan spectrum-analysis channel-quality [ ap ap-name ]
2: System level
ap ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 32 characters.
# Display channel quality information detected by AP 1.
<Sysname> display wlan spectrum-analysis channel-quality ap ap1
                                 Channel Quality
 AP Name                           RID   Channel   Avg-AQ   Min-AQ  Interference
 ap1                               1     1         95       84      1
Table 5 Command output
AP Name
Name of the AP that is detecting channel quality.
RID
Radio ID of the AP that detected the interference device.
Channel
Detected channel.
Avg-AQ
Average channel quality of the detected channel.
Min-AQ
Worst channel quality of the detected channel.
Interference
Number of non-802.11n interference devices detected on the channel.
Use display wlan spectrum-analysis device to display information about non-802.11n interference devices detected by an AP.
display wlan spectrum-analysis device [ ap ap-name ]
2: System level
# Display information about non-802.11n interference devices detected by AP 1.
<Sysname> display wlan spectrum-analysis device ap ap1
SI     : Interference Severity Index
         1-Low Interference, 100-High Interference
Interference detected by ap1 Radio1
Device ID         : 0x0005
Type              : Video device using fixed frequency
SI                : 50
RSSI              : -35
Duty Cycle (%)    : 20
Affected Channels : 3,4,5,6,7
Detected Time     : Jan 6 10:42:56 2012
Device ID         : 0x0007
Type              : Bluetooth
SI                : 80
RSSI              : -49
Duty Cycle (%)    : 35
Affected Channels : 1,3,5,6,10
Device ID         : 0x000a
Type              : Microwave oven
SI                : 32
RSSI              : -25
Duty Cycle (%)    : 50
Affected Channels : 1,2,7,13,14
Table 6 Command output
AP and its radio that detected the interference device.
Device ID
ID assigned to the interference device.
Interference type.
SI
Interference severity level. A larger value indicates a stronger interference.
RSSI
Signal strength of the interference device.
Duty Cycle (%)
Percentage of time for which the interference device was active.
Affected Channels
Channels affected by the interference device.
Detected Time
Time that the interference device was last detected.
Use dot11a calibrate-channel sensitivity to set the sensitivity level that triggers channel adjustment on 5 GHz radios.
Use undo dot11a calibrate-channel sensitivity to restore the default.
dot11a calibrate-channel sensitivity { high | low | medium }
The sensitivity level that triggers channel adjustment is medium.
RRM view
2: System level
high: Specifies the high sensitivity level.
low: Specifies the low sensitivity level.
medium: Specifies the medium sensitivity level.
When the channel quality is lower than the sensitivity level, the AC begins to calculate the channel quality, and switches to a new channel with a higher quality.
This command takes effect only for spectrum analysis. Channel adjustment is triggered only when the channel quality calculated by spectrum analysis is lower than the sensitivity level specified by the dot11a calibrate-channel sensitivity command.
# Set the sensitivity level that triggers channel adjustment to high on 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel sensitivity high
Use dot11a calibrate-channel track spectrum-analysis to enable spectrum analysis to trigger channel adjustment on 5 GHz radios.
Use undo dot11a calibrate-channel track spectrum-analysis to disable spectrum analysis from triggering channel adjustment on 5 GHz radios.
Spectrum analysis does not trigger channel adjustment.
RRM view
2: System level
# Enable spectrum analysis to trigger channel adjustment on 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel track spectrum-analysis
Use dot11a spectrum-analysis device to set the type of interference devices to be detected on 5 GHz radios.
Use undo dot11a spectrum-analysis device to remove the configuration.
dot11a spectrum-analysis device { device-type | all }
undo dot11a spectrum-analysis device { device-type | all }
The type of interference devices to be detected on 5 GHz radios is cordless-Network-fh.
View
RRM view
Default level
2: System level
device-type: Specifies the type of interference devices to be detected. The interference device that can be detected on 5 GHz radios is the cordless-Network-fh device.
all: Detects all interference devices.
# Set the type of interference devices to be detected on 5 GHz radios to cordless-Network-fh.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a spectrum-analysis device cordless-Network-fh
Use dot11a spectrum-analysis enable to enable spectrum analysis on all 5 GHz radios.
Use undo dot11a spectrum-analysis enable to disable spectrum analysis on all 5 GHz radios.
Spectrum analysis is disabled on all 5 GHz radios.
RRM view
2: System level
Spectrum analysis takes effect on a radio only when both globally and on the radio are enabled.
# Enable spectrum analysis on all 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a spectrum-analysis enable
Use dot11a spectrum-analysis trap channel-quality enable to enable the AC to send SNMP traps to the NMS when the channel quality on 5 GHz radios is lower than the channel quality alarm threshold.
Use undo dot11a spectrum-analysis trap channel-quality enable to disable the function.
The AC sends SNMP traps to the NMS when the channel quality on 5 GHz radios is lower than the channel quality alarm threshold.
RRM view
2: System level
# Configure the AC to not send any SNMP traps to the NMS when the channel quality on 5 GHz radios is lower than the channel quality alarm threshold.
[Sysname] wlan rrm
[Sysname-wlan-rrm] undo dot11a spectrum-analysis trap channel-quality enable
Use dot11a spectrum-analysis trap channel-quality threshold to set the channel quality alarm threshold on 5 GHz radios.
Use undo dot11a spectrum-analysis trap channel-quality threshold to restore the default.
dot11a spectrum-analysis trap channel-quality threshold threshold-value
The channel quality alarm threshold is 35.
RRM view
2: System view
threshold-value: Specifies the channel quality alarm threshold in the range of 1 to 100. A smaller value represents a worse channel quality.
# Set the channel quality alarm threshold on 5 GHz radios to 45.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a spectrum-analysis trap channel-quality threshold 45
Use dot11a spectrum-analysis trap device to enable the AC to send SNMP traps to the NMS when an interference device is detected on 5 GHz radios.
Use undo dot11a spectrum-analysis trap device to remove the configuration.
dot11a spectrum-analysis trap device { device-type | all }
undo dot11a spectrum-analysis trap device { device-type | all }
The AC sends SNMP traps to the NMS when a cordless-Network-fh device is detected on 5 GHz radios.
RRM view
2: System level
device-type: Specifies the device type. The interference device that can be detected on 5 GHz radios is the cordless-Network-fh device.
all: Specifies all device types.
The dot11a spectrum-analysis trap device command takes effect only when the dot11a spectrum-analysis trap device enable command is executed.
Before configuring this command, use the dot11a spectrum-analysis device device-type command to specify the type of interference devices to be detected. Otherwise, this command does not take effect.
# Configure the AC to not send any SNMP traps to the NMS when a cordless-Network-fh device is detected on 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] undo dot11a spectrum-analysis trap device cordless-Network-fh
Use dot11a spectrum-analysis trap device enable to enable the AC to send SNMP traps to the NMS when interference devices are detected on 5 GHz radios.
Use undo dot11a spectrum-analysis trap device enable to disable the function.
The AC sends SNMP traps to the NMS when interference devices are detected on 5 GHz radios.
RRM view
2: System level
# Configure the AC to not send any SNMP traps to the NMS when interference devices are detected on 5 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] undo dot11a spectrum-analysis trap device enable
dot11a spectrum-analysis trap device.
dot11bg calibrate-channel sensitivity
Use dot11bg calibrate-channel sensitivity to set the sensitivity level that triggers channel adjustment on 2.4 GHz radios.
Use undo dot11bg calibrate-channel sensitivity to restore the default.
dot11bg calibrate-channel sensitivity { high | low | medium }
RRM view
2: System level
This command takes effect only for spectrum analysis. Channel adjustment is triggered only when the channel quality calculated in spectrum analysis is lower than the sensitivity level specified by the dot11bg calibrate-channel sensitivity command.
# Set the sensitivity level that triggers channel adjustment to high on 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel sensitivity high
dot11bg calibrate-channel track spectrum-analysis.
Use dot11bg calibrate-channel track spectrum-analysis to enable spectrum analysis to trigger channel adjustment on 2.4 GHz radios.
Use undo dot11bg calibrate-channel track spectrum-analysis to disable spectrum analysis from triggering channel adjustment on 2.4 GHz radios.
RRM view
Default command level
2: System level
# Enable spectrum analysis to trigger channel adjustment on 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel track spectrum-analysis
dot11bg spectrum-analysis device
Use dot11bg spectrum-analysis device to set the type of interference devices to be detected on 2.4 GHz radios.
Use undo dot11bg spectrum-analysis device to remove the configuration.
dot11bg spectrum-analysis device { device-type | all }
undo dot11bg spectrum-analysis device { device-type | all }
All interference devices are detected on 2.4 GHz radios.
RRM view
2: System level
device-type: Specifies the type of interference devices to be detected, including microwave, Bluetooth, video-ff, cordless-network-fh, and xbox-fh.
# Set the type of interference devices to be detected on 2.4 GHz radios to bluetooth.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg spectrum-analysis device bluetooth
dot11bg spectrum-analysis enable
Use dot11bg spectrum-analysis enable to enable spectrum analysis on all 2.4 GHz radios.
Use undo dot11bg spectrum-analysis enable to disable spectrum analysis on all 2.4 GHz radios.
Spectrum analysis is disabled on all 2.4 GHz radios.
RRM view
2: System level
Spectrum analysis takes effect on a radio only when enabled both globally and on the radio.
# Enable spectrum analysis on all 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg spectrum-analysis enable
dot11bg spectrum-analysis trap channel-quality enable
Use dot11bg spectrum-analysis trap channel-quality enable to enable the AC to send SNMP traps to the NMS when the channel quality on 2.4 GHz radios is lower than the channel quality alarm threshold.
Use undo dot11bg spectrum-analysis trap channel-quality enable to disable the function.
The AC sends SNMP traps to the NMS when the channel quality on 2.4 GHz radios is lower than the channel quality alarm threshold.
RRM view
2: System level
# Configure the AC to not send any SNMP traps to the NMS when the channel quality on 2.4 GHz radios is lower than the channel quality alarm threshold.
[Sysname] wlan rrm
[Sysname-wlan-rrm] undo dot11bg spectrum-analysis trap channel-quality enable
dot11bg spectrum-analysis trap channel-quality threshold
Use dot11bg spectrum-analysis trap channel-quality threshold to set the channel quality alarm threshold on 2.4 GHz radios.
Use undo dot11bg spectrum-analysis trap channel-quality threshold to restore the default.
dot11bg spectrum-analysis trap channel-quality threshold threshold-value
RRM view
2: System level
# Set the channel quality alarm threshold on 2.4 GHz radios to 45.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg spectrum-analysis trap channel-quality threshold 45
dot11bg spectrum-analysis trap device
Use dot11bg spectrum-analysis trap device to enable the AC to send SNMP traps to the NMS when an interference device is detected on 2.4 GHz radios.
Use undo dot11bg spectrum-analysis trap device to remove the configuration.
dot11bg spectrum-analysis trap device { device-type | all }
undo dot11bg spectrum-analysis trap device { device-type | all }
The AC sends SNMP traps to the NMS when all specified interference devices are detected on 2.4 GHz radios.
RRM view
2: System level
device-type: Enables the AC to send SNMP traps to the NMS when the specified type of interference device is detected. The interference devices that can be detected include microwave, Bluetooth, video-ff, audio-ff, cordless-network-fh, and xbox-fh.
all: Enables the AC to send SNMP traps to the NMS when any specified interference devices are detected.
The dot11bg spectrum-analysis trap device command takes effect only if the dot11bg spectrum-analysis trap device enable command is executed.
Before configuring this command, use the dot11bg spectrum-analysis device device-type command to specify the type of interference devices to be detected. Otherwise, this command does not take effect.
# Configure the AC to not send any SNMP traps to the NMS when a Bluetooth device is detected on 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] undo dot11bg spectrum-analysis trap device Bluetooth
Use dot11bg spectrum-analysis trap device enable to enable the AC to send SNMP traps to the NMS when interference devices are detected on 2.4 GHz radios.
Use undo dot11bg spectrum-analysis trap device enable to disable the function.
The AC sends SNMP traps to the NMS when interference devices are detected on 2.4 GHz radios.
RRM view
2: System level
# Configure the AC to not send any SNMP traps to the NMS when interference devices are detected on 2.4 GHz radios.
[Sysname] wlan rrm
[Sysname-wlan-rrm] undo dot11bg spectrum-analysis trap device enable
Use spectrum-analysis enable to enable spectrum analysis on a radio.
Use undo spectrum-analysis enable to disable spectrum analysis on a radio.
Spectrum analysis is disabled on a radio.
Radio view
2: System level
Spectrum analysis takes effect only when both globally and on a radio are enabled.
# Enable spectrum analysis on a radio.
[Sysname] wlan ap ap3 model MSM460-WW
[sysname-wlan-ap-ap3] radio 1 type dot11an
[sysname-wlan-ap-ap3-radio-1] spectrum-analysis enable
·     dot11a spectrum-analysis enable
·     dot11bg spectrum-analysis enable
MAC-BAC configuration commands
Support for the commands in this chapter depends on the device model. For more information, see About the H3C Access Controllers Command References.
wlan bas-ac enable
Use wlan bas-ac enable to enable BAS AC.
Use undo wlan bas-ac enable to disable BAS AC.
wlan bas-ac enable
BAS AC is disabled.
2: System level
# Enable BAS AC.
[Sysname] wlan bas-ac enable
wlan bas-ac ip
Use wlan bas-ac ip to specify the IP address that the BAS AC uses to connect to the master AC.
Use undo wlan bas-ac ip to remove the configuration.
wlan bas-ac ip ip-address
undo wlan bas-ac ip
No IP address is specified for the BAS AC.
2: System level
ip-address: Specifies the IP address that the BAS AC uses to connect to the master AC. It can only be an IPv4 address.
# Specify the IP address that the BAS AC uses to connect to the master AC as 1.1.1.1.
[Sysname] wlan bas-ac ip 1.1.1.1
wlan bas-ac retry-interval
Use wlan bas-ac retry-interval to specify the retry interval at which the BAS AC sends connection requests to the master AC.
Use undo wlan bas-ac retry-interval to restore the default.
wlan bas-ac retry-interval seconds
The retry interval is 15 seconds.
2: System level
seconds: Specifies the retry interval at which the BAS AC sends connection requests to the master AC after the connection between them fails or is terminated. The value range is 1 to 60 seconds.
# Specify the retry interval at which the BAS AC sends connection requests to the master AC as 10 seconds.
[Sysname] wlan bas-ac retry-interval 10
wlan bas-ac synchronize-configuration
Use wlan bas-ac synchronize-configuration to synchronize the configuration of the current BAS AC to other BAS ACs in the MAC-BAC network.
Use undo wlan bas-ac synchronize-configuration to disable the BAS AC configuration synchronization function.
2: System level
# Synchronize the configuration of the current BAS AC to other BAS ACs in the MAC-BAC network.
[Sysname] wlan bas-ac synchronize-configuration
wlan capwap address
Use wlan capwap address to specify a CAPWAP IP address.
Use undo wlan capwap address to remove the configured CAPWAP IP address.
wlan capwap address { ip ip-address | ipv6 ipv6-address }
undo wlan capwap address { ip | ipv6 }
No CAPWAP IP address is configured.
2: System level
ip ip-address: Specifies an IPv4 CAPWAP address for the BAS AC.
ipv6 ipv6-address: Specifies an IPv6 CAPWAP address for the BAS AC.
If a tunnel has been established between the master AC and each BAS AC, when receiving a discovery request from an AP, the master AC assigns one BAS AC with the smallest workload to the AP and sends back a discovery response. The IP address of the BAS AC assigned to the AP is called a CAPWAP IP address. The AP uses this address to establish a tunnel with the BAS AC.
Make sure the CAPWAP IP address and the IP address of the AP can reach each other at Layer 3.
You can use this command to configure one IPv4 CAPWAP address and one IPv6 CAPWAP address. They can exist at the same time.
# Specify the CAPWAP IP address as 1.1.1.1.
[Sysname] wlan capwap address ip 1.1.1.1
wlan master-ac
Use wlan master-ac to specify a master AC for the BAS AC.
Use undo wlan master-ac to remove the configuration about the master AC.
wlan master-ac { ip ipv4-address | ipv6 ipv6-address } port port-number [ authentication { cipher | simple } authentication-key ]
undo wlan master-ac
No master AC is specified for the BAS AC.
2: System level
ip ipv4-address: Specifies the IPv4 address of the master AC.
ipv6 ipv6-address: Specifies the IPv6 address of the master AC.
port port-number: Specifies the number of the port used to connect the master AC, in the range of 1 to 65535. By default, this value is 35001.
authentication: Specifies the MD5 authentication.
authentication-key: Specifies a ciphertext key or the plaintext key. A plaintext key is a case-sensitive string of 1 to 16 characters. A ciphertext key is a case sensitive string of 24 to 53 characters.
If authentication is configured, the master AC uses MD5 algorithm to calculate a message digest, adds the digest into the packet, and sends the packet to the BAS AC. The BAS AC does the same after receiving the packet and compares the result with the digest in the packet. If the two are identical, the packet passes the authentication and is accepted by the BAS AC. Otherwise the packet fails the authentication and is dropped.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
Specify the same key on the BAS AC and the master AC.
# Assign a master AC to the BAS AC, specify the IP address of the master AC as 1.1.1.1, and specify a plaintext key abcdefg.
[Sysname] wlan master-ac ip 1.1.1.1 authentication simple abcdefg
Guest access tunnel configuration commands
aggregation-ac
Use aggregation-ac ip to configure an aggregation AC on an edge AC.
Use undo aggregation-ac ip to remove the configuration.
aggregation-ac ip ipv4-address source ip ipv4-address vlan vlan-id-list
undo aggregation-ac { all | ip ipv4-address [ vlan vlan-id-list ] }
No aggregation AC information is available on the edge AC.
Edge AC view
2: System level
ip ipv4-address: Specifies an aggregation AC by its IPv4 address.
source ip ipv4-address: Specifies the source IPv4 address for the edge AC to establish a guest access tunnel with the aggregation AC.
vlan vlan-id-list: Specifies a guest VLAN list. It is in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs.
all: Deletes information about all aggregation ACs on the edge AC.
# Set the IP address of the aggregation AC configured on the edge AC to 192.168.2.21 and set the guest VLAN to VLAN 7.
[Sysname] wlan guest-tunnel edge-ac
[Sysname-wlan-edge-ac] aggregation-ac ip 192.168.2.21 source ip 192.168.2.20 vlan 7
display wlan guest-tunnel
Use display wlan guest-tunnel to display information about the guest access tunnels on the current AC.
display wlan guest-tunnel { all | ip ipv4-address } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Specifies all guest access tunnels.
ip ipv4-address: Specifies a peer AC by its IPv4 address.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about all guest access tunnels on the edge AC.
<Sysname> display wlan guest-tunnel all
                              Guest-Tunnel Information
 Local Mode: Edge AC                           Tunnel Count: 2
 Peer IP Address   Local IP Address     VLAN           State    Interface
 2.2.2.2           5.5.5.1              4              Up       WLAN-Tunnel9
 2.2.2.3           5.5.5.1              5              Down     WLAN-Tunnel10
# Display information about all guest access tunnels on the aggregation AC.
 Local Mode: Aggregation AC                  Tunnel Count: 2
 Peer IP Address         VLAN           State            Interface
 1.1.1.1                 4-5            Down             WLAN-Tunnel9
 1.1.1.2                 6              Down             WLAN-Tunnel10
# Display information about the guest access tunnel established with the AC with the IP address 1.1.1.1.
<Sysname> display wlan guest-tunnel ip 1.1.1.1
 Local Mode: Edge AC
 Peer IP Address        : 1.1.1.1
 Local IP Address       : 1.1.1.2
 VLAN                   : 4
 State                  : Down
 Interface              : WLAN-Tunnel9
 Online time (hh:mm:ss) : -NA-
Table 7 Command output
Local Mode
Role of the AC, Edge or Aggregation.
Tunnel Count
Number of guest access tunnels.
Peer IP Address
IP address of the peer AC.
Local IP Address
IP address of the local AC.
VLAN
Configured guest VLAN.
State of the guest access tunnel:
·     Up
·     Down
Local interface used to establish the guest access tunnel.
This field is displayed as -NA- if the WLAN-Tunnel interface fails to be created.
Length of time when the guest access tunnel is in Up state.
edge-ac
Use edge-ac ip to configure an edge AC on an aggregation AC.
Use undo edge-ac ip to remove the configuration.
edge-ac ip ipv4-address vlan vlan-id-list
undo edge-ac { all | ip ipv4-address [ vlan vlan-id-list ] }
Aggregation AC view
2: System level
ip ipv4-address: Specifies an edge AC by its IP address.
all: Deletes information about all edge ACs on the aggregation AC.
# Set the IP address of the edge AC configured on the aggregation AC to 192.168.2.20 and set the guest VLAN to VLAN 7.
[Sysname] wlan guest-tunnel aggregation-ac
[Sysname-wlan-aggregation-ac] edge-ac ip 192.168.2.20 vlan 7
keep-alive
Use keep-alive to set the interval at which the edge AC sends keep-alive requests to aggregation ACs.
Use undo keep-alive to restore the default.
keep-alive time-interval
undo keep-alive
The interval at which the edge AC sends keep-alive requests to aggregation ACs is 10 seconds.
Edge AC view
2: System level
time-interval: Specifies the interval at which the edge AC sends keep-alive requests to aggregation ACs, in the range of 5 to 80 seconds.
When this command is configured, the edge AC sends a keep-alive request to the aggregation AC. Upon receiving the request, the aggregation AC determines whether the source IP address of the request belongs to one of the edge ACs configured on it. If it does, the aggregation AC sends a response and a guest access tunnel is established.
The edge AC sends keep-alive requests to the aggregation AC at a specific interval. If the edge AC does not receive any response from the aggregation AC after three successive attempts, the edge AC terminates the guest access tunnel. If the aggregation AC does not receive any keep-alive request three times the interval, it terminates the guest access tunnel.
# Set the interval at which the edge AC sends keep-alive requests to aggregation ACs to 7 seconds.
[Sysname-wlan-edge-ac] keep-alive 7
reset wlan guest-tunnel
Use reset wlan guest-tunnel to remove guest access tunnels.
reset wlan guest-tunnel { all | ip ipv4-address }
View
2: System level
all: Removes all guest access tunnels.
ip ipv4-address: Specifies a peer AC by its IP address.
# Remove all guest access tunnels.
<Sysname> reset wlan guest-tunnel all
Use wlan guest-tunnel aggregation-ac to specify the current AC as the aggregation AC and create an aggregation AC view. If the aggregation AC view has been created, this command enters the aggregation AC view.
Use undo wlan guest-tunnel aggregation-ac to delete the aggregation AC view and all configurations of the aggregation AC.
2: System level
When you delete the aggregation AC view, all guest access tunnels established with this aggregation AC are also removed.
# Specify the current AC as the aggregation AC.
Use wlan guest-tunnel edge-ac to specify the current AC as the edge AC and create an edge AC view. If the edge AC view has been created, this command enters the edge AC view.
Use undo wlan guest-tunnel edge-ac to delete the edge AC view and all configurations of the edge AC.
2: System level
When you delete the edge AC view, all guest access tunnels established with this edge AC are also removed.
# Specify the current AC as the edge AC.
Bonjour gateway commands
bonjour-gateway enable
Use bonjour-gateway enable to enable Bonjour gateway.
Use undo bonjour-gateway enable to disable Bonjour gateway.
Bonjour gateway is enabled.
AP template view, AP group view
2: System level
Bonjour gateway takes effect only after you enable Bonjour gateway both globally and for an AP. You can enable Bonjour gateway for an AP in AP template view or AP group view.
# Enable Bonjour gateway.
[Sysname] wlan ap ap3 model WA3628i-AGN
[Sysname-wlan-ap-ap3] bonjour-gateway enable
# Enable Bonjour gateway for AP group office.
[Sysname] wlan ap-group office
[Sysname-ap-group-office] bonjour-gateway enable
wlan bonjour-gateway enable
bonjour-policy
Use bonjour-policy to apply a Bonjour policy to an AP template, an AP group, or a service template.
Use undo bonjour-policy to remove the applied Bonjour policy.
bonjour-policy policy-name
undo bonjour-policy
No Bonjour policy is applied to an AP template, an AP group, or a service template.
AP template view, AP group view, service template view
2: System level
policy-name: Specifies a Bonjour policy by its name, a case-sensitive string of 1 to 31 characters.
# Apply Bonjour policy teacher to an AP template.
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] bonjour-policy teacher
# Apply Bonjour policy teacher to an AP group.
[Sysname-ap-group-office] bonjour-policy teacher
# Apply Bonjour policy teacher to a service template.
[Sysname-wlan-st-1] bonjour-policy teacher
display wlan bonjour-policy
Use display wlan bonjour-policy to display Bonjour policy information.
display wlan bonjour-policy [ policy-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
# Display Bonjour policy information.
<Sysname> display wlan bonjour-policy
Total number of configured bonjour policies: 1
                         Bonjour policy parameters
Bonjour policy name                     : student
VLAN                                    : 1 2 to 5
Access-VLAN                             : Enabled
Service list:
  Service type                    IP address/Instance name
  ichat                           192.168.0.1
  printer
Table 8 Command output
VLAN
List of VLANs where the AC can forward queries and responses.
Access-VLAN
Whether the AC can forward queries and responses to the VLANs to which the clients belong:
·     Enabled.
·     Disabled.
Service type
Types of service that can be queried by clients.
IP address or instance name of the service that can be queried by clients.
display wlan bonjour-service
Use display wlan bonjour-service to display information about services discovered by the AC.
display wlan bonjour-service [ | { begin | exclude | include } regular-expression ]
2: System level
# Display information about services discovered by the AC.
<Sysname> display wlan bonjour-service
  Total number of discarded query packets   : 0
  Total number of discarded response packets: 20
  Total number of bonjour services          : 3
                         Bonjour Services
 Name                       Type           VLAN  TTL   IP
 Apple TV                   airplay        1     4500  192.168.10.2
 B8782E5101E7@Apple TV      raop           2     4500  192.168.10.2
 70-35-60-63.1 Apple TV     sleep-proxy    3     4500  192.168.10.2
Table 9 Command output
Name
Instance name of the service.
Service type.
VLAN
VLAN to which the service belongs.
TTL
TTL of the service, in seconds. When the Bonjour gateway receives a new response for the service, it resets the TTL for the service.
IP
IP address of the service.
service type
Use service type to configure the type of service that can be queried by clients.
Use undo service type to remove the service type.
service type service-type [ ip ipv4-address | ipv6 ipv6-address | instance instance-name ]
undo service type service-type [ ip ipv4-address | ipv6 ipv6-address | instance instance-name ]
Clients can query all services.
Bonjour policy view
2: System level
service-type: Specifies the type of service that can be queried by clients. Table 10 lists some Bonjour protocols by their names and service type strings.
Table 10 Apple Bonjour protocols and service type strings
Service type
Protocol name
afpovertcp
AppleTalkFiling Protocol
airplay
Airplay
airport
Airport Base Station
apple-sasl
Apple Password Server
daap
Digital Audio Access Protocol
dacp
Digital Audio Control Protocol
distcc
Distributed Compiler
dpap
Digital Photo Access Protocol
eppc
Remote AppleEvents
ftp
File Transfer Protocol
http
Hypertext Transfer Protocol
Ica-networking
Image Capture Sharing
ichat
iChat Instant Messaging Protocol
ipp
Internet Printing Protocol
ipps
nfs
Network File System
pdl-stream
PDL Data Stream
printer
Line Printer Daemon
raop
Remote Audio Output Protocol
riousbprint
Remote I/O USB Printer Protocol
servermgr
Server Admin
ssh
Secure Shell
telnet
Remote Login
webdav
WebDav File System
workstation
Workgroup Manager
xserveraid
Xerver RAID
ipv4-address: Specifies an IP address of the service that can be queried by clients.
ipv6-address: Specifies an IPv6 address of the service that can be queried by clients.
instance-name: Specifies the instance name of the service that can be queried by clients, a case-sensitive string of 1 to 63 characters. An instance name uniquely identifies a service.
# Set the type of service that can be queried by clients to ichat and the service IP address to 192.168.1.10.
[Sysname] wlan bonjour-policy teacher
[Sysname-wlan-bp-teacher] service type ichat ip 192.168.1.10
service vlan
Use service vlan to configure the VLANs to which the AC can forward queries and responses.
Use undo service vlan to remove the configuration.
service vlan vlan-id-list [ access-vlan ]
undo service vlan [ vlan-id-list ] [ access-vlan ]
The AC cannot forward queries and responses.
Bonjour policy view
2: System level
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
access-vlan: Allows the AC to forward queries and responses to the VLANs to which the clients belong. If you delete all VLAN lists, the access-vlan keyword is unavailable.
# Enable the AC to forward queries and responses to VLAN 100.
[Sysname-wlan-bp-teacher] service vlan 100
Use wlan bonjour-gateway enable to enable Bonjour gateway globally.
Use undo wlan bonjour-gateway enable to disable Bonjour gateway globally.
Bonjour gateway is disabled globally.
2: System level
Bonjour gateway takes effect only after you enable it both globally and for an AP. You can enable Bonjour gateway for an AP in AP template view or AP group view.
# Enable Bonjour gateway globally.
[Sysname] wlan bonjour-gateway enable
wlan bonjour-gateway multicast threshold
Use wlan bonjour-gateway multicast threshold to set the threshold for the AC to start sending multicast responses to clients.
Use undo wlan bonjour-gateway multicast threshold to restore the default.
wlan bonjour-gateway multicast threshold threshold-number
The threshold for the AC to start sending multicast responses to clients is 10.
2: System level
threshold-number: Specifies the threshold for the AC to start sending multicast responses to clients, in the range of 1 to 64.
The AC can send unicast or multicast responses to clients in Bonjour service advertisement snooping. When the AC sends a multicast response to clients, it converts the multicast response to multiple unicast responses by default.
This command prevents the AC from sending excessive unicast responses to clients.
With this function enabled, the AC sends one multicast response instead of multiple unicast responses to clients when the following conditions are met:
·     The clients are associated with the same BSS.
·     The clients query for the same service.
·     The number of clients meeting the above conditions reaches the threshold within 500 ms.
# Set the threshold for the AC to start sending multicast responses to clients to 15.
[Sysname] wlan bonjour-gateway multicast threshold 15
wlan bonjour-gateway query enable
Use wlan bonjour-gateway query enable to enable active query for Bonjour services on the AC.
Use undo wlan bonjour-gateway query enable to disable the function.
Active query for Bonjour services is disabled on the AC.
2: System level
# Enable active query for Bonjour services on the AC.
[Sysname] wlan bonjour-gateway query enable
wlan bonjour-gateway query interval
Use wlan bonjour-gateway query interval to set the interval at which the AC sends queries for a service.
Use undo wlan bonjour-gateway query interval to restore the default.
wlan bonjour-gateway query interval number
The AC sends queries for a service every 15 seconds.
2: System level
number: Specifies the interval at which the AC sends queries for a service, in the range of 5 to 600 seconds.
# Set the interval at which the AC sends queries for a service to 30 seconds.
[Sysname] wlan bonjour-gateway query interval 30
wlan bonjour-policy (system view)
Use wlan bonjour-policy to create a Bonjour policy.
Use undo wlan bonjour-policy to remove a Bonjour policy.
wlan bonjour-policy policy-name
undo wlan bonjour-policy policy-name
No Bonjour policy is created.
2: System level
You can configure a maximum of 1000 Bonjour policies.
# Create Bonjour policy teacher.
wlan bonjour-policy (user profile view)
Use wlan bonjour-policy to apply a Bonjour policy to a user profile.
Use undo wlan bonjour-policy to remove the Bonjour policy.
No Bonjour policy is applied to a user profile.
User profile view
2: System level
# Apply Bonjour policy teacher to user profile a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123] wlan bonjour-policy teacher
Hotspot 2.0 commands
3gpp-info
Use 3gpp-info to configure 3rd Generation Partnership Project (3GPP) information.
Use undo 3gpp-info to remove the configuration.
3gpp-info country-code country-code network-code network-code
undo 3gpp-info country-code country-code network-code network-code
No 3GPP information is configured.
Hotspot 2.0 policy view
2: System level
country-code country-code: Specifies a country or region code. A country or region code is a three-digit numeric code that uniquely identifies the country or region to which a client belongs.
network-code network-code: Specifies a mobile network code. A mobile network code is a two-digit or three-digit numeric code that uniquely identifies the mobile network to which a client belongs.
One country or region code can correspond to multiple mobile network codes.
You can configure a maximum of 32 country/region code and mobile network code combinations in a Hotspot 2.0 policy.
# Configure 3GPP information.
[Sysname] wlan hotspot-policy 1
[Sysname-wlan-hs-1] 3gpp-info country-code 310 network-code 00
[Sysname-wlan-hs-1] 3gpp-info country-code 460 network-code 01
ap-venue group
Use ap-venue group to set a venue group and venue type for an AP.
Use undo ap-venue group to remove the configuration.
ap-venue group venue-group type venue-type
undo ap-venue group
No venue group and venue type are configured for an AP.
2: System level
venue-group: Specifies a venue group by its name, in the range of 1 to 11.
Table 11 Venue group codes and description
Code
1
Assembly
2
Business
3
Educational
4
Factory and Industrial
5
Institutional
6
Mercantile
7
Residential
8
Storage
9
Utility and Miscellaneous
10
Vehicular
11
Outdoor
venue-type: Specifies a venue by its type. The value depends on the venue group name. For more information, see Table 12.
Table 12 Venue type assignments
Venue group code
Venue type code
Venue description
1
0
Unspecified
1
1
Arena
1
2
Stadium
1
3
Passenger Terminal (e.g., airport, bus, ferry, train station)
1
4
Amphitheater
1
5
Amusement Park
1
6
Place of Worship
1
7
Convention Center
1
8
Library
1
9
Museum
1
10
Restaurant
1
11
Theater
1
12
Bar
1
13
Coffee Shop
1
14
Zoo or Aquarium
1
15
Emergency Coordination Center
2
0
Unspecified Business
2
1
Doctor or Dentist office
2
2
Bank
2
3
Fire Station
2
4
Police Station
2
6
Post Office
2
7
Professional Office
2
8
Research and Development Facility
2
9
Attorney Office
3
0
Unspecified Educational
3
1
School, Primary
3
2
School, Secondary
3
3
University or College
4
0
Unspecified Factory and Industrial
4
1
Factory
5
0
Unspecified Institutional
5
1
Hospital
5
2
Long-Term Care Facility (e.g., Nursing home, Hospice, etc.)
5
3
Alcohol and Drug Rehabilitation Center
5
4
Group Home
5
5
Prison or Jail
6
0
Unspecified Mercantile
6
1
Retail Store
6
2
Grocery Market
6
3
Automotive Service Station
6
4
Shopping Mall
6
5
Gas Station
7
0
Unspecified Residential
7
1
Private Residence
7
2
Hotel or Motel
7
3
Dormitory
7
4
Boarding House
8
0
Unspecified Storage
9
0
Unspecified Utility and Miscellaneous
10
0
Unspecified Vehicular
10
1
Automobile or Truck
10
2
Airplane
10
3
Bus
10
4
Ferry
10
5
Ship or Boat
10
6
Train
10
7
Motor Bike
11
0
Unspecified Outdoor
11
1
Muni-mesh Network
11
2
City Park
11
3
Rest Area
11
4
Traffic Control
11
5
Bus Stop
11
6
Kiosk
# Specify venue group 1 and venue type 2 for AP 3.
[sysname] wlan ap ap3 model WA4620i-CAN
[Sysname] ap-venue group 1 type 2
ap-venue name
Use ap-venue name to set a venue name and language code for an AP.
Use undo ap-venue name to remove the configuration.
ap-venue name venue-name lang-code lang-code
undo ap-venue name venue-name lang-code lang-code
No venue name information is configured for an AP.
2: System level
venue-name: Specifies a venue by its name, a case-insensitive string of 1 to 255 characters.
lang-code lang-code: Specifies the language code corresponding to a venue name.
One venue name can correspond to multiple language codes.
You can configure a maximum of 32 venue name and language code combinations.
# Set the venue name to office and language codes to English and Japanese for AP 3.
[sysname-wlan-ap-ap3] ap-venue office lang-code en
[sysname-wlan-ap-ap3] ap-venue office lang-code ja
authentication-type
Use authentication-type to set the network authentication type.
Use undo authentication-type to remove the configuration.
authentication-type authentication-type [ redirect-url url-address ]
undo authentication-type network-authentication-type [ redirect-url url-address ]
No network authentication type is configured.
2: System level
authentication-type: Specifies a network authentication type in the range of 0 to 3.
Table 13 Network authentication type
Value
0
Acceptance of terms and conditions
1
On-line enrollment supported
2
HTTP/HTTPS redirection
3
DNS redirection
url-address: Specifies a redirected URL address, a string of 1 to 64 characters.
# Set the network authentication type to 1.
[Sysname-wlan-hs-1] authentication-type 1
comeback-delay
Use comeback-delay to set the delay time before the clients can send GAS comeback frames.
Use undo comeback-delay to restore the default.
comeback-delay value
undo comeback-delay
The delay time is 1 TU.
2: System level
value: Specifies the delay time in TU, in the range of 1 to 1024. 1 TU is equal to 1024 milliseconds. Clients will not send GAS comeback frames to the AC until the delay time is reached.
# Set the delay time to 10 TUs.
[Sysname-wlan-hs-1] comeback-delay 10
dgaf enable
Use dgaf enable to enable the Downstream Group-Addressed Forwarding (DGAF) function.
Use undo dgaf enable to disable the DGAF function.
dgaf enable
undo dgaf enable
The DGAF function is enabled.
2: System level
When the DGAF function is enabled for an AP, the AP forwards all downstream wireless broadcast ARP packets and wireless multicast packets. To prevent spoofing attacks by using downstream multicasts, you can disable the DGAF function for the AP.
As a best practice to avoid packet loss, enable proxy ARP and multicast optimization before disabling this function.
# Disable the DGAF function.
[Sysname-wlan-hs-1] undo dgaf enable
domain-name
Use domain-name to set a domain name.
Use undo domain-name to remove the configuration.
domain-name name
undo domain-name name
No domain name is configured.
2: System level
name: Specifies a domain by its name, a case-insensitive string of 1 to 255 characters.
You can configure a maximum of 32 domain names in one Hotspot 2.0 policy.
# Set the domain name to abc in Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] domain abc
gas-limit
Use gas-limit to set the maximum number of GAS Initial frames the AC can receive from clients within the specified interval.
Use undo gas-limit to restore the default.
gas-limit number number interval interval
undo gas-limit
The number of GAS Initial frames the AC can receive is not restricted.
2: System level
number number: Specifies the maximum number of GAS Initial frames that the AC can receive, in the range of 10 to 128.
interval interval: Specifies the interval at which GAS Initial frames received by the AC are counted, in the range of 10 to 60 seconds.
If the number of GAS Initial frames sent by clients exceeds the maximum number, the exceeded frames will be discarded.
# Set the maximum number of GAS Initial frames that the AC can receive within 15 seconds to 120.
[Sysname-wlan-hs-1] gas-limit number 120 interval 15
hessid
Use hessid to set a homogenous ESS identifier (HESSID).
Use undo hessid to remove the configuration.
hessid hessid
undo hessid
No HESSID is configured.
2: System level
hessid: Specifies an HESSID that uniquely identifies a homogeneous ESS, in the H-H-H format.
# Set the HESSID to 0021-1bea-3660 in Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] hessid 0021-1bea-3660
hotspot-policy
Use hotspot-policy to apply a Hotspot 2.0 policy to a service template.
Use undo hotspot-policy to remove the application.
hotspot-policy policy-number
undo hotspot-policy
No Hotspot 2.0 policy is applied to a service template.
2: System level
policy-number: Specifies the number of the Hotspot 2.0 policy to be applied to the service template, in the range of 1 to 32.
You can only apply a Hotspot 2.0 policy to a crypto-type service template.
# Apply Hotspot 2.0 policy 1 to service template 1.
[Sysname] wlan service-template 1 crypto
[Sysname-wlan-st-1] hotspot-policy 1
ip-protocol
Use ip-protocol to configure the port status for an IP protocol.
Use undo ip-protocol to remove the configuration.
ip-protocol { esp | icmp | tcp | udp } port-number port-number { closed | open | unknown }
undo ip-protocol { esp | icmp | tcp | udp } port-number port-number
The port status is not configured for an IP protocol.
2: System level
esp: Specifies the ESP protocol.
Icmp: Specifies the ICMP protocol.
tcp: Specifies the TCP protocol.
udp: Specifies the UDP protocol.
port-number port-number: Specifies a port by its number.
Table 14 Port number and protocol type
Protocol type
Port number
ICMP
0
ICMP, used for diagnostics
TCP
20
FTP
TCP
22
SSH
TCP
80
HTTP
TCP
443
Used by TLS VPNs
TCP
1723
Used by Point to Point
Tunneling Protocol VPNs
TCP
5060
VoIP
UDP
500
Used by IKEv2 (IPSec VPN)
UDP
5060
VoIP
UDP
4500
May be used by IKEv2 (IPSec VPN)
ESP
0
ESP, used by IPSec VPNs
closed: Specifies the port status as closed.
open: Specifies the port status as open.
unknown: Specifies the port status as unknown.
# Configure the port number for TCP as 20, and set the port status to open.
[Sysname-wlan-hs-1] ip-protocol tcp port-number 20 open
ip-type
Use ip-type to set the address type availability.
Use undo ip-type to restore the default.
ip-type ipv4 ipv4-type ipv6 ipv6-type
undo ip-type
The availability is 1 for IPv4 addresses and 2 for IPv6 addresses.
2: System level
ipv4 ipv4-type: Specifies the availability for an IPv4 address, in the range of 0 to 7.
Table 15 IPv4 address availability
Address value
0
Address type not available
1
Public IPv4 address available
2
Port-restricted IPv4 address available
3
Single NATed private IPv4 address available
4
Double NATed private IPv4 address available
5
Port-restricted IPv4 address and single NATed IPv4 address available
6
Port-restricted IPv4 address and double NATed IPv4 address available
7
Availability of the address type is not known
ipv6 ipv6-type: Specifies the availability for an IPv6 address, in the range of 0 to 3.
Table 16 IPv6 address availability
Address value
0
1
Address type available
2
Availability of the address type not known
# Set the availability to 2 for IPv4 addresses and 1 for IPv6 addresses.
[Sysname-wlan-hs-1] ip-type ipv4 2 ipv6 1
nai-realm
Use nai-realm name to configure the authentication type supported by a Network Access Identifier (NAI) realm.
Use undo nai-realm name to remove the configuration.
nai-realm name name eap-method eap-method-id authentication authentication
undo nai-realm name name [ eap-method eap-method [ authentication authentication ] ]
No authentication type is configured for an NAI realm.
2: System level
name name: Specifies an NAI realm by its name, a case-insensitive string of 1 to 255 characters.
eap-method eap-method-id: Specifies an EAP authentication method by its ID, in the range of 1 to 5.
authentication authentication: Specifies an authentication parameter by its ID.
Table 17 EAP parameter
Value
1
EAP-Transport Layer Security (EAP-TLS)
2
Lightweight Extensible Authentication Protocol (LEAP)
3
EAP for GSM Subscriber Identity Module (EAP-SIM)
4
EAP-Tunneled Transport Layer Security (EAP-TTLS)
5
Protected EAP (PEAP)
Table 18 EAP method and authentication parameter
eap-method-id
eap-method
authentication
2
Non-EAP Inner Authentication Type
·     0Reserved.
·     1PAP.
·     2CHAP.
·     3MSCHAP.
·     4MSCHAPV2.
5
Credential Type
·     1—SIM.
·     2—USIM.
·     3—NFC Secure Element.
·     4—Hardware Token.
·     5—Softoken.
·     6—Certificate.
·     7—username/password.
·     8—none*.
·     9—Reserved.
·     10Vendor Specific.
·     *none means server-side authentication only.
6
Tunneled EAP Method Credential Type
·     1SIM.
·     2USIM.
·     3NFC Secure Element.
·     4Hardware Token.
·     5Softoken.
·     6Certificate.
·     7username/password.
·     8Reserved.
·     9Anonymous.
You can configure a maximum of 32 NAI realm names in a Hotspot 2.0 policy.
# Configure the authentication type for NAI realm wifi in Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] nai-realm name wifi eap-method 2 authentication 1
nai-realm unsorted
Use nai-realm unsorted to configure the NAI realms to use the manually configured storage sequence.
Use undo nai-realm unsorted to restore the default.
nai-realm unsorted
By default, NAI realms use the alphabetical storage sequence.
2: System level
# Configure the NAI realms to use the manually configured storage sequence.
<sysname> system-view
[sysname] wlan hotspot-policy 1
[sysname-wlan-hs-1] nai-realm unsorted
network-type
Use network-type to set the access network type.
Use undo network-type to remove the configuration.
network-type network-type [ access-internet ]
undo network-type
No access network type is configured.
2: System level
network-type: Specifies an access network type in the range of 0 to 5, 14, and 15.
Table 19 Access network type
Value
0
Private network
1
Private network with guest access
2
Chargeable public network
3
Free public network
4
Personal device network
5
Emergency services only network
14
Test or experimental
15
Wildcard
access-internet: Enables access to the Internet. By default, the Internet cannot be accessed.
# Set the access network type to 1 and enable access to the Internet.
[Sysname-wlan-hs-1] network-type 1 access-internet
operator-name
Use operator-name to set a language code for a service provider.
Use undo operator-name to remove the configuration.
operator-name operator-name lang-code lang-code
undo operator-name operator-name lang-code lang-code
No service provider information is configured.
2: System level
operator-name: Specifies a service provider by its name, a case-insensitive string of 1 to 255 characters.
lang-code: Specifies a language code.
One service provider can correspond to multiple language codes.
You can configure a maximum of 32 service provider and language code combinations in a Hotspot 2.0 policy.
# Set the language code to en for service provider cmcc.
[Sysname-wlan-hs-1] operator-name cmcc lang-code en
policy-name
Use policy-name to set a Hotspot 2.0 policy name.
Use undo policy-name to remove the configuration.
policy-name policy-name
undo policy-name
A Hotspot 2.0 policy does not have a name.
2: System level
policy-name: Specifies a Hotspot 2.0 policy by its name, a case-insensitive string of 1 to 32 characters.
# Set the name of Hotspot 2.0 policy 1 to market.
[Sysname-wlan-hs-1] policy-name market
roam-oui
Use roam-oui to set an OUI for a roaming consortium.
Use undo roam-oui to remove the configuration.
roam-oui oui [ in-beacon ]
undo roam-oui oui
No OUI is configured for a roaming consortium.
2: System level
oui: Specifies an OUI that can uniquely identify a roaming consortium, a six-digit octet.
in-beacon: Adds the OUI to Beacon frames. By default, there is no OUI in a Beacon frame.
You can configure a maximum of 32 OUIs in a Hotspot 2.0 policy, and can add a maximum of three OUIs to Beacon frames.
# Set the OUI to 004096 for a roaming consortium.
[Sysname-wlan-hs-1] roam-oui 004096
wan-metrics
Use wan-metrics to configure WAN parameters.
Use undo wan-metrics to remove the configuration.
wan-metrics { link-down | link-test | link-up } [ asymmetric downlink-speed downlink-speed uplink-speed uplink-speed | symmetric link-speed link-speed ]
undo wan-metrics
No WAN parameters are configured.
2: System level
link-down: Configures the link status for the WAN as down.
link-test: Configures the link status for the WAN as testing.
link-up: Configures the link status for the WAN as up.
asymmetric: Specifies the asymmetric link.
downlink-speed downlink-speed: Specifies the downlink speed in the range of 1 to 4194304 Kbps.
uplink-speed uplink-speed: Specifies the uplink speed in the range of 1 to 4194304 Kbps.
symmetric: Specifies the symmetric link.
link-speed link-speed: Specifies the symmetric link speed in the range of 1 to 4194304 Kbps.
# Configure the link status for the WAN as up.
[Sysname-wlan-hs-1] wan-matrics link-up
wlan hotspot-policy
Use wlan hotspot-policy to create a Hotspot 2.0 policy and enter its view.
Use undo wlan hotspot-policy to remove the configured Hotspot 2.0 policy.
wlan hotspot-policy policy-number
undo wlan hotspot-policy policy-number
2: System level
policy-number: Specifies a Hotspot 2.0 policy number in the range of 1 to 32.
# Create Hotspot 2.0 policy 1.
