- 02-WLAN Command Reference
- 01-WLAN Interface Commands
- 02-WLAN Access Commands
- 03-WLAN Security Commands
- 04-IACTP Tunnel and WLAN Roaming Commands
- 05-WLAN RRM Commands
- 06-WLAN IDS Commands
- 07-WLAN QoS Commands
- 08-WLAN Mesh Link Commands
- 09-Advanced WLAN Commands
- 10-WLAN High Availability Commands
- 11-WLAN IPS Commands
- 12-WLAN Optimization Commands
| 04-IACTP Tunnel and WLAN Roaming Commands | 64.21 KB |
WLAN roaming configuration commands
display wlan client roam-track
wlan mobility-group-isolation enable
Support for the commands in this chapter depends on the device model. For more information, see About the H3C Access Controllers Command References.
display wlan client
Use display wlan client to display information about clients that have roamed in or out.
display wlan client { roam-in | roam-out } [ member { ip ipv4-address | ipv6 ipv6-address } ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
2: System level
roam-in: Displays information about clients that have roamed in.
roam-out: Displays information about clients that have roamed out.
member ip ipv4-address: IPv4 address of the member AC.
member ipv6 ipv6-address: IPv6 address of the member AC.
verbose: Displays detailed information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If a member is included, the display wlan client roam-in command displays the MAC addresses and associated BSSIDs of all the clients that have roamed in from the specified member, and the display wlan client roam-out command displays the MAC addresses and associated BSSIDs of all the clients that have roamed out to the specified member.
If no member is included, the display wlan client roam-in command displays the MAC addresses, associated BSSIDs, and home AC IP address of all the roam-in clients, and the display wlan client roam-out command shows the MAC addresses, associated BSSIDs, and foreign AC IP address of all the roam-out clients.
# Display all roam-in client information.
<Sysname> display wlan client roam-in
Roam-In Table
Client-MAC-address BSSID Home-AC-IP-address
0012-f0cc-489d 000f-e25d-f3e0 202.0.0.13
# Display information about clients that have roamed in from member AC 202.0.0.13.
<Sysname> display wlan client roam-in member ip 202.0.0.13
Roam-In Table
# Display roam-in client information in detail.
<Sysname> display wlan client roam-in verbose
Roam-In Client Information
Client-MAC-address : 0012-f0cc-489d
BSSID : 000f-e25d-f3e0
Vlan-ID : 30
Home-AC-IP-address : 202.0.0.13
# Display roam-in client information from member AC 202.0.0.13 in detail.
<Sysname> display wlan client roam-in member ip 202.0.0.13 verbose
Vlan-ID : 30
# Display all roam-out client information.
<Sysname> display wlan client roam-out
Roam-Out Table
Client-MAC-address BSSID Foreign-AC-IP-address
0012-f0cc-489d 000f-e25d-f3e0 202.0.0.101
# Display roam-out client information to member AC 202.0.0.101.
<Sysname> display wlan client roam-out member ip 202.0.0.101
Roam-Out Table
# Display all roam-out client information in detail.
<Sysname> display wlan client roam-out verbose
Roam-Out Client Information
Vlan-ID : 30
Online time (hh:mm:ss) : 00:00:29
Foreign-AC-IP-address : 202.0.0.101
# Display roam-out client information to member AC 202.0.0.101 in detail.
<Sysname> display wlan client roam-out member ip 202.0.0.101 verbose
Vlan-ID : 30
Online time (hh:mm:ss) : 00:03:27
Client-MAC-address |
MAC address of the client. |
BSSID |
BSSID of the AP to which the client is associated. |
Vlan-ID |
VLAN ID of the client. |
Online-time |
How long the client has been associated with the AP. |
Foreign-AC-IP-address |
IP address of the foreign access controller. |
Use display wlan client roam-track mac-address to display the roam-track information of a specified client on the client’s HA.
display wlan client roam-track mac-address mac-address [ | { begin | exclude | include } regular-expression ]
2: System level
mac-address mac-address: Displays the roam-track information of a specified client.
# Display the roam-track information about client 0012-f0cc-489d.
<Sysname> display wlan client roam-track mac-address 0012-f0cc-489d
Roam Track Table
BSSID Online-time(d:h:m:s) AC-IP-address
000f-e25d-f3e0 0000:00:02:44 202.0.0.101
000f-e26c-2805 0000:00:02:11 202.0.0.100 (HOME AC)
# Display the roam-track information about client 1234-19af-cb39 (The configured mobility tunnel version is ipv6).
<Sysname> display wlan client roam-track 1234-19af-cb39
Roam Track Table
0e45-38bd-4479 0000:10:30:01 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF4
0000-05b2-ac45 0001:09:00:04 -HOME AC-
BSSID |
BSSID of the AP with which the client is associated. |
Online-time |
AC-IP-address |
IP address of the access controller with which the client is connected. If mobility tunnel version is set to IPv6, the IPv6 address of the access controller will be present. |
roam enable
Use roam enable to enable WLAN roaming.
Use undo roam enable to disable WLAN roaming.
roam enable
undo roam enable
WLAN roaming is disabled.
IACTP tunnel view
2: System level
Before you enable or disable WLAN roaming, make sure mobility group is disabled. Otherwise, you cannot modify the roaming configuration.
Disable WLAN roaming if no clients want to roam between ACs and packets exchanged in a mobility group need to be reduced. After WLAN roaming is disabled, clients cannot roam between ACs.
# Display WLAN roaming.
[Sysname] wlan mobility-group abc
[Sysname-wlan-mg-abc] undo roam enable
mobility-group enable
IACTP configuration commands
authentication-mode
Use authentication-mode to configure an IACTP control message integrity authentication mode. When the IACTP control message integrity authentication mode is configured, all control messages transmitted in the IACTP tunnel will carry a digest (integrity code) that is calculated based on the message content. On receiving such a message, the member will calculate the digest again and compare it against the digest present in the message to verify the integrity of the packet received.
Use undo authentication-mode to restore the default.
authentication-mode authentication-method [ cipher | simple ] authentication-key
IACTP control message integrity authentication is disabled.
Mobility group view
2: System level
authentication-method: Authentication method to be used in IACTP control message exchange. Only 128-bit MD5 authentication method is supported.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key.
authentication-key: Specifies the key string. This argument is case sensitive. The length of a plaintext key is in the range of 1 to 16, and the length of a ciphertext key is in the range of 24 to 53. If neither cipher nor simple is specified, you set a plaintext key string.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
# Configure the IACTP control message integrity authentication mode as MD5 and set a plaintext key 12345.
[Sysname] wlan mobility-group office
[Sysname-wlan-mg-office] authentication-mode md5 simple 12345
display wlan mobility-group
Use display wlan mobility-group to display the mobility group configuration and status.
display wlan mobility-group [ member { ip ipv4-address | ipv6 ipv6-address } ] [ | { begin | exclude | include } regular-expression ]
2: System level
member ip ipv4-address: IPv4 address of a member AC whose information will be displayed.
member ipv6 ipv6-address: IPv6 address of a member AC whose information will be displayed.
# Display information about all member ACs in an IPv4 mobility group.
<Sysname> display wlan mobility-group
Mobility Group Information
Group Name : asd
Source IP Address : 196.168.1.4
Authentication Method : MD5
Member Information
IP-address State Interface
192.168.1.10 Run wlan-tunnel0
192.168.1.34 Idle wlan-tunnel1
# Display information about all member ACs in an IPv6 mobility group.
Group Name : asd
Source IP Address : 55F2::1001
Member Information
IPv6-address State Interface
3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF4 Run wlan-tunnel0
4523::3345 Idle wlan-tunnel1
# Display the configuration and status of the member AC with the address 192.168.1.10.
<Sysname> display wlan mobility-group member ip 192.168.1.10
Member Information
IP Address : 192.168.1.10
State : Run
Interface : WLAN-Tunnel0
Online Time (hh:mm:ss) : 00:16:05
Group Name |
WLAN mobility group name. |
Source IP Address |
Source IPv4 address of the mobility group. |
Authentication Method |
Authentication method used for the mobility group. |
IP Address |
IPv4 address of the AC. |
State |
IACTP state. |
Tunnel interface name. |
Online Time (hh:mm:ss) |
IACTP tunnel up time. |
member
Use member to configure the IP address for an AC.
Use undo member to remove the configured IP address.
member { ip ipv4-address | ipv6 ipv6-address } [ vlan vlan-id-list ]
undo member { all | ip ipv4-address | ipv6 ipv6-address }
No AC exists in a mobility group.
Mobility group view
2: System level
ip ipv4-address: IPv4 address of an AC in the mobility group.
ipv6 ipv6-address: IPv6 address of an AC.
vlan vlan-id-list: VLANs to which the member ACs belong. This argument is expressed in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. If this option is not specified, local forwarding is enabled on all the VLANs.
all: Removes all the ACs from the mobility group.
If multiple ACs are in the same mobility group, make sure no IACTP loop exists among ACs when you configure WLAN parameters.
# Add an IPv4 member to the mobility group.
[Sysname-wlan-mg-abc] member ip 192.168.1.55
# Add an IPv6 member to the mobility group.
[Sysname-wlan-mg-abc] member ipv6 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF4
Use mobility-group enable to enable IACTP.
Use undo mobility-group enable to disable IACTP.
IACTP is disabled.
Mobility group view
2: System level
IACTP can be enabled only when the IACTP source IP address is configured.
# Enable IACTP.
[Syaname] wlan mobility-group abc
[Sysname-wlan-mg-abc] source ip 1.1.1.1
[Sysname-wlan-mg-abc] mobility-group enable
mobility-tunnel
Use mobility-tunnel to set the IACTP tunnel protocol type.
mobility-tunnel { iactp | iactp6 }
The IACTP type is IPv4.
Mobility group view
2: System level
iactp: Specifies IPv4 IACTP.
iactp6: Specifies IPv6 IACTP.
You can set the IACTP type only when mobility group is disabled.
# Set the IACTP tunnel protocol type to IPv6.
[Sysname-wlan-mg-abc] mobility-tunnel iactp6
source
Use source to set the IACTP tunnel source IP address.
Use undo source to restore the default.
source { ip ipv4-address | ipv6 ipv6-address }
undo source
No IACTP source IP address is configured.
Mobility group view
2: System level
ip ipv4-address: Specifies the IACTP tunnel source IPv4 address.
ipv6 ipv6-address: Specifies the IACTP tunnel source IPv6 address.
This command can be configured only when the mobility group is disabled.
# Set the IACTP tunnel source IP address to 192.168.1.66.
[Sysname-wlan-mg-abc] source ip 192.168.1.66
wlan mobility-group
Use wlan mobility-group to create a mobility group and enter mobility group view.
Use undo wlan mobility-group to remove the mobility group and all its configurations.
wlan mobility-group name
undo wlan mobility-group name
2: System level
name: Name of the mobility group, a case-insensitive string of 1 to 15 characters.
An AC can establish IACTP tunnels with at most seven ACs in the same mobility group.
ACs in the same mobility group must have the same group name.
# Enter mobility group view.
Use wlan mobility-group-isolation enable to isolate tunnels in a mobility group.
Use undo wlan mobility-group-isolation enable to disable the tunnel isolation function.
Tunnel isolation in a mobility group is enabled.
2: System level
# Isolate tunnels in a mobility group.
[Sysname] wlan mobility-group-isolation enable
