- 02-WLAN Command Reference
- 01-WLAN Interface Commands
- 02-WLAN Access Commands
- 03-WLAN Security Commands
- 04-IACTP Tunnel and WLAN Roaming Commands
- 05-WLAN RRM Commands
- 06-WLAN IDS Commands
- 07-WLAN QoS Commands
- 08-WLAN Mesh Link Commands
- 09-Advanced WLAN Commands
- 10-WLAN High Availability Commands
- 11-WLAN IPS Commands
- 12-WLAN Optimization Commands
| 00-Preface | 113.20 KB |
Preface
This command reference describes the WLAN configuration commands.
The WLAN Command Reference describes the configuration commands for WLAN interface, WLAN access, WLAN security, WLAN roaming, WLAN RRM, WLAN IDS, WLAN QoS, WLAN mesh link, WLAN high availability, WLAN IPS, WLAN optimization, and advanced WLAN.
NOTE: Support of the H3C access controllers for commands might vary by device model. For the command matrixes, see About the H3C Access Controllers Command References. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
