H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers and Access Points Configuration Examples(V7)-6W101
Table of Contents
Related Documents
41-H3C Access Controllers Remote AP Configuration Examples (V7)
Comware 7 Remote AP
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides an example for configuring remote AP.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of remote AP.
Example: Configuring remote AP
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the clients. Configure remote AP on the AC so that the AP can still provide services for clients when the tunnel between the AP and the AC is disconnected.
Figure 1 Network diagram
When you configure remote AP, follow these restrictions and guidelines:
·     Use the serial ID labeled on the AP's rear panel to specify an AP.
·     Remote AP takes effect only on an AP that operates in local forwarding mode.
·     For GigabitEthernet 1/0/1 on the AP to join VLAN 200, edit the AP configuration file, and upload it to the storage media of the AC.
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.0.1 16
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC and the switch as a trunk port, and assign it to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure wireless services:
# Create a service template named 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID of service template 1 as service.
[AC-wlan-st-1] ssid service
# Specify the AP as the client traffic forwarder for clients in VLAN 200.
[AC-wlan-st-1] client forwarding-location ap vlan 200
# Enable the service template.
[AC-wlan-st-1] quit
3.     Configure the AP:
# Create a manual AP named officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA560-WW
[AC-wlan-ap-officeap] serial-id 219801A1NM8182032235
# Enter the view of radio 2.
[AC-wlan-ap-officeap] radio 2
# Bind service template 1 and VLAN 200 to radio 2.
[AC-wlan-ap-officeap-radio-2] service-template 1 vlan 200
# Enable radio 2.
[AC-wlan-ap-officeap-radio-2] radio enable
[AC-wlan-ap-officeap-radio-2] quit
# Enable remote AP.
[AC-wlan-ap-officeap] hybrid-remote-ap enable
4.     Deploy configuration file apcfg.txt to the AP.
[AC-wlan-ap-officeap] map-configuration apcfg.txt
[AC-wlan-ap-officeap] quit
Configuring the switch
1.     Configure interfaces on the switch:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward the traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 16
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch and the AC as a trunk port, and assign the trunk port to VLANs 100 and 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch and the AP as a trunk port, remove the port from VLAN 1, and assign the trunk port to VLANs 100 and 200.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
# Set the PVID of GigabitEthernet 1/0/2 to VLAN 100.
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
2.     Configure DHCP services:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan100 to assign an IP address to the AP.
[Switch] dhcp server ip-pool vlan100
# In DHCP address pool vlan100, specify subnet 192.1.0.0/16 for dynamic allocation, exclude 192.1.0.1 from dynamic allocation, and specify gateway IP address 192.1.0.2.
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.0.1
[Switch-dhcp-pool-vlan100] gateway-list 192.1.0.2
[Switch-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 to assign IP address to clients.
[Switch] dhcp server ip-pool vlan200
# In DHCP address pool vlan200, specify subnet 192.2.0.0/16 for dynamic allocation, exclude 192.2.0.1 from dynamic allocation, and specify gateway IP address 192.2.0.2.
[Switch-dhcp-pool-vlan200] network 192.2.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.0.1
[Switch-dhcp-pool-vlan200] gateway-list 192.2.0.2
[Switch-dhcp-pool-vlan200] quit
Configuring AP configuration file apcfg.txt
# Copy the following text to a text file and upload the file to the AC.
vlan 200
interface GigabitEthernet 1/0/1
port trunk permit vlan 200
# Verify that clients remain online and the AP can still forward client traffic when the tunnel between the AP and the AC is disconnected. (Details not shown.)
Configuration files
·     AC:
vlan 100
Vlan 200
 ssid service
interface Vlan-interface100
 ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
 ip address 192.2.0.1 255.255.0.0
map-configuration flash:/apcfg.txt
 radio 1
 radio 2
  radio enable
 gigabitethernet 1
 gigabitethernet 2
·     apcfg.txt:
vlan 200
·     Switch:
dhcp enable
vlan 100
vlan 200
 ip address 192.1.0.2 255.255.0.0
 ip address 192.2.0.2 255.255.0.0
Related documentation
·     WLAN Command Reference in H3C Access Controllers Command References
·     WLAN Configuration Guide in H3C Access Controllers Configuration Guides
