- H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
- 01-H3C Access Controllers AP's Association with the AC at Layer 2 Configuration Examples
- 02-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 2 (IPv6) Configuration Examples
- 03-H3C Access Controllers AP's Association with the AC at Layer 3 Configuration Examples
- 04-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 3 (IPv6) Configuration Examples
- 05-H3C Access Controllers Local MAC Authentication Configuration Examples (V7)
- 06-H3C Access Controllers MAC Authentication with Guest VLAN Assignment Configuration Examples (V7)
- 07-H3C Access Controllers Comware 7 MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 08-H3C Access Controllers MAC Authentication and PSK Authentication Configuration Examples (V7)
- 09-H3C Access Controllers Auto AP Configuration Examples (V7)
- 10-H3C Access Controllers WLAN Load Balancing Configuration Examples (V7)
- 11-H3C Access Controllers WEP Encryption Configuration Examples
- 12-H3C Access Controllers Local Forwarding Configuration Examples
- 13-H3C Access Controllers Layer 2 Static Aggregation Configuration Examples (V7)
- 14-H3C Access Controllers Remote 802.1X Authentication Configuration Examples (V7)
- 15-H3C Access Controllers Comware 7 Remote 802.1X Authentication (IPv6) Configuration Examples
- 16-H3C Access Controllers 802.1X Authentication with ACL Assignment Through IMC Server @CE@ (V7)
- 17-H3C Access Controllers 802.1X Authentication with User Profile Assignment Through IMC Server @CE@ (V7)
- 18-H3C Access Controllers EAD Authentication Configuration Examples (V7)
- 19-H3C Access Controllers Comware 7 EAD Authentication (IPv6) Configuration Examples
- 20-H3C Access Controllers Remote Portal Authenticaiton Configuration Examples (V7)
- 21-H3C Access Controllers Comware 7 Remote Portal Authenticaiton (IPv6) Configuration Examples
- 22-H3C Access Controllers Local Portal Authentication Configuration Examples (V7)
- 23-H3C Access Controllers Comware 7 Local Portal Authentication (IPv6) Configuration Examples
- 24-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication Configuration Examples (V7)
- 25-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples(V7)
- 26-H3C Access Controllers Local Portal Authentication through LDAP Server Configuration Examples (V7)
- 27-H3C Access Controllers Local Portal Authentication through LDAP Server (IPv6) Configuration Examples(V7)
- 28-H3C Access Controllers MAC-based Portal Quick Authenticaiton Configuration Example (V7)
- 29-H3C Access Controllers Comware 7 MAC-based Quick Portal Authenticaiton (IPv6) Configuration Example
- 30-H3C Access Controllers SSH Configuration Examples (7)
- 31-H3C Access Controllers Internal-to-External Access Through NAT Configuration Examples (V7)
- 32-H3C Access Controllers Static Blacklist Configuration Examples
- 33-H3C Access Controllers Comware 7 WLAN Access (IPv6) Configuration Examples
- 34-H3C Access Controllers Inter-AC Roaming Configuration Examples (V7)
- 35-H3C Access Controllers Comware 7 Inter-AC Roaming (IPv6) Configuration Examples
- 36-H3C Access Controllers HTTPS Login Configuration Examples (V7)
- 37-H3C Access Controllers Client Rate Limiting Configuration Examples (V7)
- 38-H3C Access Controllers Client Quantity Control Configuration Examples
- 39-H3C Access Controllers Medical RFID Tag Management Configuration Examples (V7)
- 40-H3C Access Controllers iBeacon Management Configuration Examples (V7)
- 41-H3C Access Controllers Remote AP Configuration Examples (V7)
- 42-H3C Access Controllers PSK Encryption Configuration Examples
- 43-H3C Access Controllers WIPS Configuration Examples (V7)
- 44-H3C Access Controllers Layer 2 Multicast Configuration Example (V7)
- 45-H3C Access Controllers IRF Setup with Members Directly Connected Configuration Examples (V7)
- 46-H3C Access Controllers IRF Setup with Members Not Directly Connected Configuration Examples (V7)
- 47-H3C Access Controller Modules IRF Setup with Members in One Chassis Configuration Examples (V7)
- 48-H3C Access Controller Modules IRF Setup with Members in Different Chassis Configuration Examples (V7)
- 49-H3C Access Controllers Comware 7 IP Source Guard (IPv6) Configuration Examples
- 50-Policy-Based Forwarding with Dual Gateways Configuration Example
- 51-H3C Access Controllers Comware 7 Policy-Based Forwarding with Dual Gateways (IPv6) Configuration Example
- 52-Policy-Based Local Forwarding Configuration Examples
| 04-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 3 (IPv6) Configuration Examples | 73.07 KB |
H3C Access Controllers |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring an AP to associate with the AC at Layer 3 (IPv6)
Configuring the Layer 3 switch
Introduction
The following information provides an example for configuring APs to associate with the AC at Layer 3 on an IPv6 network.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of IPv6 basics and WLAN access.
When you configure AP's association with the AC at Layer 3, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· To prevent too many packets from entering VLAN 1, configure the switch's interface that connects the switch to the AP to deny packets from VLAN 1.
As shown in Figure 1, the AC acts as a DHCPv6 server to assign IPv6 addresses to the AP, client, and host. Assume centralized forwarding is used in this example.
Configure wireless services to enable the client to access the wireless services and communicate with the host.
Procedures
Configuring the AC
1. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IPv6 address to the VLAN interface. The AC will use this IPv6 address to establish a CAPWAP tunnel with the AP.
[AC] vlan 100
[AC-vlan100] interface vlan-interface 100
[AC-Vlan-interface100] ipv6 address 1::1:0:0:1/96
[AC-Vlan-interface100] quit
# Create VLAN 200. VLAN 200 will be used for client access.
[AC] vlan 200
[AC-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2. Configure an IPv6 static route.
[AC] ipv6 route-static 1::4:0:0:0 96 1::1:0:0:2
3. Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Enable the service template.
# Enable snooping DHCPv6 packets..
[AC-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
[AC-wlan-st-1] quit
4. Configure the AP:
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA4320i-ACN
[AC-wlan-ap-officeap] serial-id 210235A1GQB147031200
# Bind service template 1 and VLAN 200 to radio 1.
[AC-wlan-ap-officeap] radio 1
[AC-wlan-ap-officeap-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-officeap-radio-1] radio enable
[AC-wlan-ap-officeap-radio-1] return
1. Configure switch interfaces:
# Create VLAN 100, VLAN 400, VLAN-interface 100 and VLAN-interface 400, and assign IPv6 addresses to the VLAN interfaces. The switch will use VLAN 100 and VLAN 400 to forward packets between AC and AP.
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ipv6 address 1::1:0:0:2/96
[L3 switch-Vlan-interface100] quit
[L3 switch] vlan 400
[L3 switch-vlan400] quit
[L3 switch] interface vlan-interface 400
[L3 switch-Vlan-interface400] ipv6 address 1::4:0:0:1/96
[L3 switch-Vlan-interface400] quit
# Create VLAN 200 and VLAN-interface 200 and assign an IPv6 address to the VLAN interface. This VLAN will be used for client access.
[L3 switch] vlan 200
[L3 switch-vlan200] quit
[L3 switch] interface vlan-interface 200
[L3 switch-Vlan-interface200] ipv6 address 1::2:0:0:1/96
[L3 switch-Vlan-interface200] quit
# Create VLAN 300 and VLAN-interface 300 and assign an IPv6 address to the VLAN interface. This VLAN will be used for host access.
[L3 switch] vlan 300
[L3 switch-vlan300] quit
[L3 switch] interface vlan-interface 300
[L3 switch-Vlan-interface300] ipv6 address 1::3:0:0:1/96
[L3 switch-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[L3 switch] interface gigabitEthernet 1/0/1
[L3 switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L3 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[L3 switch-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, configure the PVID as VLAN 400, and assign the port to VLANs 200 and 400.
[L3 switch] interface gigabitEthernet 1/0/2
[L3 switch-GigabitEthernet1/0/2] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] port trunk permit vlan 200 400
[L3 switch-GigabitEthernet1/0/2] port trunk pvid vlan 400
[L3 switch-GigabitEthernet1/0/2] quit
# Configure GigabitEthernet 1/0/3 that connects the switch to the host as an access port, and assign the port to VLAN 300.
[L3 switch] interface gigabitEthernet 1/0/3
[L3 switch-GigabitEthernet1/0/3] port access vlan 300
[L3 switch-GigabitEthernet1/0/3] quit
2. Configure DHCPv6:
# Enable the DHCPv6 server on VLAN-interface 200, VLAN-interface 300, and VLAN-interface 400, and apply address pools 1, 2, and 3 to these interfaces, respectively.
[L3 switch-Vlan-interface200] ipv6 dhcp select server
[L3 switch-Vlan-interface200] ipv6 dhcp server apply pool 1
[L3 switch-Vlan-interface300] ipv6 dhcp select server
[L3 switch-Vlan-interface300] ipv6 dhcp server apply pool 2
[L3 switch-Vlan-interface400] ipv6 dhcp select server
[L3 switch-Vlan-interface400] ipv6 dhcp server apply pool 3
# Disable RA message suppression, and set both the managed address configuration flag (M) and the other stateful configuration flag (O) to 1 in RA advertisements to be sent for the created VLAN interfaces.
[L3 switch-Vlan-interface200] undo ipv6 nd ra halt
[L3 switch-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[L3 switch-Vlan-interface200] ipv6 nd autoconfig other-flag
[L3 switch-Vlan-interface300] undo ipv6 nd ra halt
[L3 switch-Vlan-interface300] ipv6 nd autoconfig managed-address-flag
[L3 switch-Vlan-interface300] ipv6 nd autoconfig other-flag
[L3 switch-Vlan-interface400] undo ipv6 nd ra halt
[L3 switch-Vlan-interface400] ipv6 nd autoconfig managed-address-flag
[L3 switch-Vlan-interface400] ipv6 nd autoconfig other-flag
# Create DHCPv6 address pool 1 to assign an IPv6 address to the AP, and specify subnet 1::2:0:0:0/96 in the DHCP address pool.
[L3 switch] ipv6 dhcp pool 1
[L3 switch-dhcp6-pool-1] network 1::2:0:0:0/96
[L3 switch-dhcp6-pool-1] quit
# Create DHCPv6 address pool 2 to assign an IPv6 address to the client, and specify subnet 1::3:0:0:0/96 in the DHCP address pool.
[L3 switch] ipv6 dhcp pool 2
[L3 switch-dhcp6-pool-2] network 1::3:0:0:0/96
[L3 switch-dhcp6-pool-2] quit
# Create DHCPv6 address pool 3 to assign an IPv6 address to the host, specify subnet 1::4:0:0:0/96 in the DHCP address pool, and configure Option 52 to specify the AC's IPv6 address.
[L3 switch] ipv6 dhcp pool 3
[L3 switch-dhcp6-pool-3] network 1::4:0:0:0/96
[L3 switch-dhcp6-pool-3] option 52 hex 00010000000000000001000000000001
[L3 switch-dhcp6-pool-3] quit
# Verify that the AP is in R/M state.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 512
Local AP licenses: 512
Server AP licenses: 0
Remaining Local AP licenses: 511
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
officeap 1 R/M WA4320i-ACN 210235A1GQB147031200
# Verify that the client is connected to radio 1 on AP officeap.
<AC> display wlan client ipv6
Total number of clients: 1
MAC address AP name RID IPv6 address VLAN
784f-43b6-077c officeap 1 1::2:0:0:2 200
# Verify that the client and the host can ping each other successfully.
C:\Users\system32>ping 1::2:0:0:2 -t
Pinging 1::2:0:0:2 with 32 bytes of data:
Reply from 1::2:0:0:2: bytes=32 time=2470ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=2ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=1427ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=86ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=142ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=561ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=84ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=465ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=114ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=124ms TTL=63
Reply from 1::2:0:0:2: bytes=32 time=446ms TTL=63
Ping statistics for 1::2:0:0:2:
Packets: Sent = 12, Received = 12, Lost = 0 (0% loss),
Minimum = 2ms, Maximum = 2470ms, Average = 495ms
Control-C
^C
C:\Users\system32>
Configuration files
· AC:
vlan 100
vlan 200
interface Vlan-interface100
ssid service
vlan 1
radio 1
radio enable
radio 2
· Layer 3 switch:
vlan 100
vlan 200
vlan 300
vlan 400
ipv6 dhcp pool 1
ipv6 dhcp pool 2
ipv6 dhcp pool 3
interface Vlan-interface200
interface Vlan-interface300
interface Vlan-interface400
Related documentation
· Layer 3 Command Reference in H3C Access Controllers Command References
· Layer 3 Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Command Reference in H3C Access Controllers Command References
· WLAN Configuration Guide in H3C Access Controllers Configuration Guides
%20Configuration%20Examples.files/x_Img_x_png_0.png)
