- H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
- 01-H3C Access Controllers AP's Association with the AC at Layer 2 Configuration Examples
- 02-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 2 (IPv6) Configuration Examples
- 03-H3C Access Controllers AP's Association with the AC at Layer 3 Configuration Examples
- 04-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 3 (IPv6) Configuration Examples
- 05-H3C Access Controllers Local MAC Authentication Configuration Examples (V7)
- 06-H3C Access Controllers MAC Authentication with Guest VLAN Assignment Configuration Examples (V7)
- 07-H3C Access Controllers Comware 7 MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 08-H3C Access Controllers MAC Authentication and PSK Authentication Configuration Examples (V7)
- 09-H3C Access Controllers Auto AP Configuration Examples (V7)
- 10-H3C Access Controllers WLAN Load Balancing Configuration Examples (V7)
- 11-H3C Access Controllers WEP Encryption Configuration Examples
- 12-H3C Access Controllers Local Forwarding Configuration Examples
- 13-H3C Access Controllers Layer 2 Static Aggregation Configuration Examples (V7)
- 14-H3C Access Controllers Remote 802.1X Authentication Configuration Examples (V7)
- 15-H3C Access Controllers Comware 7 Remote 802.1X Authentication (IPv6) Configuration Examples
- 16-H3C Access Controllers 802.1X Authentication with ACL Assignment Through IMC Server @CE@ (V7)
- 17-H3C Access Controllers 802.1X Authentication with User Profile Assignment Through IMC Server @CE@ (V7)
- 18-H3C Access Controllers EAD Authentication Configuration Examples (V7)
- 19-H3C Access Controllers Comware 7 EAD Authentication (IPv6) Configuration Examples
- 20-H3C Access Controllers Remote Portal Authenticaiton Configuration Examples (V7)
- 21-H3C Access Controllers Comware 7 Remote Portal Authenticaiton (IPv6) Configuration Examples
- 22-H3C Access Controllers Local Portal Authentication Configuration Examples (V7)
- 23-H3C Access Controllers Comware 7 Local Portal Authentication (IPv6) Configuration Examples
- 24-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication Configuration Examples (V7)
- 25-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples(V7)
- 26-H3C Access Controllers Local Portal Authentication through LDAP Server Configuration Examples (V7)
- 27-H3C Access Controllers Local Portal Authentication through LDAP Server (IPv6) Configuration Examples(V7)
- 28-H3C Access Controllers MAC-based Portal Quick Authenticaiton Configuration Example (V7)
- 29-H3C Access Controllers Comware 7 MAC-based Quick Portal Authenticaiton (IPv6) Configuration Example
- 30-H3C Access Controllers SSH Configuration Examples (7)
- 31-H3C Access Controllers Internal-to-External Access Through NAT Configuration Examples (V7)
- 32-H3C Access Controllers Static Blacklist Configuration Examples
- 33-H3C Access Controllers Comware 7 WLAN Access (IPv6) Configuration Examples
- 34-H3C Access Controllers Inter-AC Roaming Configuration Examples (V7)
- 35-H3C Access Controllers Comware 7 Inter-AC Roaming (IPv6) Configuration Examples
- 36-H3C Access Controllers HTTPS Login Configuration Examples (V7)
- 37-H3C Access Controllers Client Rate Limiting Configuration Examples (V7)
- 38-H3C Access Controllers Client Quantity Control Configuration Examples
- 39-H3C Access Controllers Medical RFID Tag Management Configuration Examples (V7)
- 40-H3C Access Controllers iBeacon Management Configuration Examples (V7)
- 41-H3C Access Controllers Remote AP Configuration Examples (V7)
- 42-H3C Access Controllers PSK Encryption Configuration Examples
- 43-H3C Access Controllers WIPS Configuration Examples (V7)
- 44-H3C Access Controllers Layer 2 Multicast Configuration Example (V7)
- 45-H3C Access Controllers IRF Setup with Members Directly Connected Configuration Examples (V7)
- 46-H3C Access Controllers IRF Setup with Members Not Directly Connected Configuration Examples (V7)
- 47-H3C Access Controller Modules IRF Setup with Members in One Chassis Configuration Examples (V7)
- 48-H3C Access Controller Modules IRF Setup with Members in Different Chassis Configuration Examples (V7)
- 49-H3C Access Controllers Comware 7 IP Source Guard (IPv6) Configuration Examples
- 50-Policy-Based Forwarding with Dual Gateways Configuration Example
- 51-H3C Access Controllers Comware 7 Policy-Based Forwarding with Dual Gateways (IPv6) Configuration Example
- 52-Policy-Based Local Forwarding Configuration Examples
| 23-H3C Access Controllers Comware 7 Local Portal Authentication (IPv6) Configuration Examples | 177.15 KB |
H3C Access Controllers |
Comware 7 Local Portal Authentication (IPv6) |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring local IPv6 portal authentication on the AC.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, portal, and WLAN.
Example: Configuring local IPv6 portal authentication
As shown in Figure 1, the switch acts as the DHCP server and the DHCPv6 server. The AP and the client obtain IPv4 addresses and IPv6 addresses from the switch.
· Configure the access device AC to also act as the portal Web server and the portal authentication server.
· Use the RADIUS server as both the authentication server and the authorization server.
· Configure direct portal authentication on the AC.
Analysis
To allow an authenticated user to access network resources on any Layer 2 ports in its access VLAN without re-authentication, you must enable the portal roaming feature.
In wireless networks where the AP forwards client traffic, the AC does not have ARP entries for clients. Therefore, the AC cannot check the validity of portal clients by using ARP entries. To ensure that valid users can perform portal authentication, you must enable wireless client validity check on the AC.
To allow portal users to access both IPv4 and IPv6 networks after passing one type (IPv4 or IPv6) of portal authentication, enable portal to support IPv4/IPv6 dual stack.
To avoid possible authentication failure caused by frequent logins and logouts of portal clients in a short time, disable the Rule ARP entry feature.
To allow the RADIUS server to modify user authorization information and log out users, enable the RADIUS session-control feature.
When you configure local portal authentication, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· The portal authentication server type and portal Web server type configured on the AC must be the same as the types of the servers actually used.
· By default, the portal Web server URL redirected to users does carry parameters. You can configure the parameters to be carried in the redirection URL as needed.
· To enable portal authentication on a VLAN interface, you must use the centralized forwarding mode. To enable portal authentication on a service template, you can use the centralized forwarding mode or the local forwarding mode. In this example, portal authentication is enabled on a service template.
· Edit portal authentication pages, compress them to a .zip file (this example uses abc.zip), and then upload the file to the root directory of the storage medium of the AC. On the AC, you must specify this file as the default authentication page file.
· To change the default authentication page file, you must first execute the undo default-logon-page command, and then specify a new default authentication page file.
Procedures
Configuring the AC
1. Configuring VLANs and interfaces:
# Create VLAN 100 and VLAN-interface 100. Assign an IPv4 address and an IPv6 address to the VLAN interface. The AC will establish a CAPWAP tunnel with the AP in this VLAN.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.1.1 24
[AC-Vlan-interface100] ipv6 address 2001::1 64
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200. Assign an IPv4 address and an IPv6 address to the VLAN interface. This VLAN will be used for wireless client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.168.2.1 24
[AC-Vlan-interface200] ipv6 address 2004::1 64
[AC-Vlan-interface200] quit
# Configure GigabitEthernet1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 1, VLAN 100, and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
2. Configure a static IPv4 route and a static IPv6 route to the IMC server.
[AC] ip route-static 192.168.3.0 255.255.255.0 192.168.2.2
[AC] ipv6 route-static 2003:: 64 2004::2
3. Configure the wireless service:
# Create a service template named st1 and enter its view.
[AC] wlan service-template st1
# Configure the SSID of the service template as service.
[AC-wlan-st-st1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-st1] vlan 200
# Enable snooping ND packets on the service template.
[AC-wlan-st-st1] client ipv6-snooping nd-learning enable
# Enable snooping DHCPv6 packets on the service template.
[AC-wlan-st-st1] client ipv6-snooping dhcpv6-learning enable
# Enable the service template.
[AC-wlan-st-st1] service-template enable
[AC-wlan-st-st1] quit
# Create an AP named office with model WA4320i-ACN, and set the serial ID to 219801A0CNC138011454.
[AC] wlan ap office model WA4320i-ACN
[AC-wlan-ap-office] serial-id 219801A0CNC138011454
# Enter the view of radio 2.
[AC-wlan-ap-office] radio 2
# Bind service template st1 to radio 2 and enable the radio.
[AC-wlan-ap-office-radio-2] service-template st1
[AC-wlan-ap-office-radio-2] radio enable
[AC-wlan-ap-office-radio-2] quit
[AC-wlan-ap-office] quit
4. Configure an IPv4 RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
[AC] radius scheme rs1
# Configure the primary authentication and accounting servers and shared keys used for secure communication with the servers.
[AC-radius-rs1] primary authentication 192.168.3.2
[AC-radius-rs1] primary accounting 192.168.3.2
[AC-radius-rs1] key authentication simple radius
[AC-radius-rs1] key accounting simple radius
# Configure the AC to remove the domain name from the usernames sent to the RADIUS servers.
[AC-radius-rs1] user-name-format without-domain
# Configure the BAS-IP attribute as 192.168.1.1.
[AC-radius-rs1] nas-ip 192.168.1.1
[AC-radius-rs1] quit
5. Configure an IPv6 RADIUS scheme:
# Create a RADIUS scheme named rs2 and enter its view.
[AC] radius scheme rs2
[AC-radius-rs2] primary authentication ipv6 2003::2
[AC-radius-rs2] primary accounting ipv6 2003::2
[AC-radius-rs2] key authentication simple radius
[AC-radius-rs2] key accounting simple radius
[AC-radius-rs2] user-name-format without-domain
# Configure the BAS-IPv6 attribute as 2001::1.
[AC-radius-rs2] nas-ip ipv6 2001::1
[AC-radius-rs2] quit
# Enable the RADIUS session-control feature.
[AC] radius session-control enable
# Enable the RADIUS DAS feature and enter RADIUS DAS view.
[AC] radius dynamic-author server
# Specify a session-control client at IPv4 address 192.168.3.2 and shared key radius in plaintext form.
[AC-radius-da-server] client ip 192.168.3.2 key simple radius
# Specify a session-control client at IPv6 address 2003::2 and shared key radius in plaintext form.
[AC-radius-da-server] client ipv6 2003::2 key simple radius
[AC-radius-da-server] quit
6. Configure an IPv4 authentication domain:
# Create an ISP domain named dm1 and enter its view.
[AC] domain dm1
# Configure the authentication and authorization methods as RADIUS and the accounting method as none for portal users.
[AC-isp-dm1] authentication portal radius-scheme rs1
[AC-isp-dm1] authorization portal radius-scheme rs1
[AC-isp-dm1] accounting portal none
# Configure the idle cut feature for users in the ISP domain. Log out a user if the user's traffic is less than 1024 bytes in 15 minutes.
[AC-isp-dm1] authorization-attribute idle-cut 15 1024
[AC-isp-dm1] quit
7. Configure an IPv6 authentication domain:
# Create an ISP domain named dm2 and enter its view.
[AC] domain dm2
[AC-isp-dm2] authentication portal radius-scheme rs2
[AC-isp-dm2] authorization portal radius-scheme rs2
[AC-isp-dm2] accounting portal none
[AC-isp-dm2] authorization-attribute idle-cut 15 1024
[AC-isp-dm2] quit
8. Configure portal authentication:
# Create an IPv4 portal Web server named newptv4 and specify the server's URL as http://192.168.2.1/portal.
[AC] portal web-server newptv4
[AC-portal-websvr-newptv4] url http://192.168.2.1/portal
# Configure the portal redirection URL to carry the wlanuserip parameter and the parameter value is the user's IP address.
[AC-portal-websvr-newptv4] url-parameter wlanuserip source-address
[AC-portal-websvr-newptv4] quit
# Create an IPv6 portal Web server named newptv6 and specify the server's URL as http://[2004::1]/portal.
[AC] portal web-server newptv6
[AC-portal-websvr-newptv6] url http://[2004::1]/portal
[AC-portal-websvr-newptv6] url-parameter wlanuserip source-address
[AC-portal-websvr-newptv6] quit
# Enable direct IPv4 portal authentication and direct IPv6 portal authentication on service template st1.
[AC-wlan-st-st1] portal enable method direct
[AC–wlan-st-st1] portal ipv6 enable method direct
# Specify ISP domain dm1 as the authentication domain for IPv4 portal users on service template st1.
[AC-wlan-st-st1] portal domain dm1
# Specify ISP domain dm2 as the authentication domain for IPv6 portal users on service template st1.
[AC-wlan-st-st1] portal ipv6 domain dm2
# Specify IPv4 portal Web server newptv4 on service template st1.
[AC-wlan-st-st1] portal apply web-server newptv4
# Specify IPv6 portal Web server newptv6 on service template st1.
[AC–wlan-st-st1] portal ipv6 apply web-server newptv6
# Enable portal to support IPv4/IPv6 dual stack on service template st1.
[AC-wlan-st-st1] portal dual-stack enable
[AC–wlan-st-st1] quit
# Create an HTTP-based local portal service and enter its view.
[AC] portal local-web-server http
# Specify the default authentication page file as defaultfile.zip. (The file must already exist in the root directory of the storage medium of the AC.)
[AC–portal-local-websvr-http] default-logon-page defaultfile.zip
[AC–portal-local-websvr-http] quit
# Enable the portal roaming feature.
[AC] portal roaming enable
# Disable the Rule ARP entry feature for portal clients.
[AC] undo portal refresh arp enable
# Enable the wireless client validity check feature.
[AC] portal host-check enable
# Configure a source-based portal-free rule. Set the rule number to 3 and the source interface to aggregate interface 1. This rule allows the portal user on the aggregate interface to access network resources without authentication.
[AC] portal free-rule 3 source interface Bridge-Aggregation1
Configuring the switch
1. Configure VLANs and interfaces:
# Create VLAN 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward traffic of wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port. Assign the trunk port to VLAN 1, VLAN 100, and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as an access port. Assign the access port to VLAN 100.
# Enable PoE on the access port.
# Create VLAN-interface 1 and assign an IPv4 address and an IPv6 address to the VLAN interface.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.3.1 255.255.255.0
[Switch-Vlan-interface1] ipv6 address 2003::1 64
[Switch-Vlan-interface1] quit
# Create VLAN-interface 100 and assign an IPv4 address and an IPv6 address to the VLAN interface.
[Switch-Vlan-interface100] ip address 192.168.1.2 255.255.255.0
[Switch-Vlan-interface100] ipv6 address 2001::2 64
# Create VLAN-interface 200 and assign an IPv4 address and an IPv6 address to the VLAN interface.
2. Configure the DHCP server:
# Enable DHCP.
[Switch] dhcp enable
# Configure DHCP address pool named 100 and specify subnet 192.168.1.0/24 and gateway address 192.168.1.1 for the DHCP address pool. The switch will assign an IPv4 address in this address pool to the AP.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.168.1.0 mask 255.255.255.0
[Switch-dhcp-pool-100] gateway-list 192.168.1.1
# Configure Option 43 that specifies the AC's IPv6 address in hexadecimal notation in DHCP address pool 100.
[Switch-dhcp-pool-100] option 43 hex 8007000001c0a80101
[Switch-dhcp-pool-100] quit
# Configure DHCP address pool named 200 and specify subnet 192.168.2.0/24 and gateway address 192.168.2.2 for the DHCP address pool. The switch will assign an IPv4 address in this address pool to the client.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.168.2.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 192.168.2.2
[Switch-dhcp-pool-200] quit
3. Configure the DHCPv6 server:
# Configure DHCPv6 address pool named 1 and specify subnet 2001::/64 for the DHCPv6 address pool. The switch will assign an IPv6 address in this address pool to the AP.
[Switch] ipv6 dhcp pool 1
[Switch-dhcp6-pool-1] network 2001::/64
# Configure Option 52 that specifies the AC's IPv6 address in DHCPv6 address pool 1.
[Switch-dhcp6-pool-1] option 52 hex 20010000000000000000000000000001
[Switch-dhcp6-pool-1] quit
[Switch] ipv6 dhcp server forbidden-address 2001::1
# Apply DHCPv6 address pool 1 to VLAN-interface 100, and enable the DHCPv6 server on the VLAN interface.
[Switch-Vlan-interface100] ipv6 dhcp server apply pool 1
[Switch-Vlan-interface100] ipv6 dhcp select server
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent on VLAN-interface 100.
[Switch-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface100] ipv6 nd autoconfig other-flag
# Disable RA message suppression.
[Switch-Vlan-interface100] undo ipv6 nd ra halt
# Configure DHCPv6 address pool named 2 and specify subnet 2004::/64 for the DHCPv6 address pool. The switch will assign an IPv6 address in this address pool to the client.
[Switch] ipv6 dhcp pool 2
[Switch-dhcp6-pool-2] network 2004::/64
[Switch-dhcp6-pool-2] quit
# Exclude IPv6 address 2004::1 in the DHCPv6 address pool from dynamic allocation.
[Switch] ipv6 dhcp server forbidden-address 2004::1
# Apply DHCPv6 address pool 2 to VLAN-interface 200, and enable the DHCPv6 server on the VLAN interface.
[Switch] interface Vlan-interface 200
[Switch-Vlan-interface200] ipv6 dhcp server apply pool 2
[Switch-Vlan-interface200] ipv6 dhcp select server
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent on VLAN-interface 200.
[Switch-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface200] ipv6 nd autoconfig other-flag
[Switch-Vlan-interface200] undo ipv6 nd ra halt
[Switch-Vlan-interface200] quit
Configuring the RADIUS server
This example uses the IMC server to describe the RADIUS server configuration. The IMC server runs on IMC PLAT 7.1, IMC EIA 7.1, and IMC EIP 7.1.
1. Add an access device:
a. Log in to IMC and click the User tab.
b. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c. Click Add.
The Add Access Device page opens.
d. In the Access Configuration area, set the shared key to radius
The shared key must be the same as that configured for the RADIUS server on the AC.
e. In the Device List area, perform the following actions:
- Click Add Manually to open the Add Access Device Manually page. Enter the start IPv4 address 2.2.2.1 and click OK.
- Click Add IPv6 Dev to open the Add Access Device Manually page. Enter the start IPv6 address 2001::1 and click OK.
f. Use the default settings for other parameters.
g. Click OK.
Figure 2 Adding an access device
2. Add an access policy:
a. From the navigation tree, select User Access Policy > Access Policy.
b. Click Add.
The Add Access Policy page opens.
c. Enter the policy name.
d. Select a service group.
e. Use the default settings for other parameters.
f. Click OK.
Figure 3 Adding an access policy
3. Add an access service:
a. From the navigation tree, select User Access Policy > Access Service.
b. Click Add.
The Add Access Service page opens.
c. Enter the service name.
d. Select the access policy configured in the previous step as the default access policy.
f. Click OK.
Figure 4 Adding an access service
4. Add an access user:
a. From the navigation tree, select Access User > All Access Users.
b. Click Add.
The Add Access User page opens.
c. Click Select to select an existing user or click Add User to add a new user.
d. Enter the account name.
e. Enter and confirm the password.
f. Select the access service configured in the previous step.
g. Use the default settings for other parameters.
h. Click OK.
Figure 5 Adding an access user
1. Verify that the dual-stack client can access network resources after passing IPv4 portal authentication.
a. Use the configured username and password to perform IPv4 portal authentication through a Web browser on the client.
b. Verify that all Web accesses of the user are redirected to the portal authentication page (http://192.168.2.1/portal) before the client passes IPv4 portal authentication. After the user passes IPv4 portal authentication, the user can access network resources. (Details not shown.)
c. Display the online portal user information on the AC after the client passes IPv4 portal authentication.
[AC] display portal user all
Total portal users: 1
Username: client
AP name: office
Radio ID: 2
SSID: service
Portal server: N/A
State: Online
VPN instance: N/A
MAC IP VLAN Interface
3829-5a40-9589 192.168.2.3 200 WLAN-BSS1/0/2
Authorization information:
DHCP IP pool: N/A
User profile: N/A
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
The output shows that the client has come online.
2. Verify that the dual-stack client can access network resources after passing IPv6 portal authentication.
a. Use the configured username and password to perform IPv6 portal authentication through a Web browser on the client.
b. Verify that all Web accesses of the user are redirected to the portal authentication page (http://[2004::1]/portal) before the client passes IPv6 portal authentication. After the user passes IPv6 portal authentication, the user can access network resources. (Details not shown.)
c. Display the online portal user information on the AC after the client passes authentication.
Username: client
AP name: office
Radio ID: 2
SSID: service
Portal server: N/A
State: Online
VPN instance: N/A
3829-5a40-9589 2004::E97F:BBE1:832C: 200 WLAN-BSS1/0/2
3D3E
DHCP IP pool: N/A
User profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Configuration files
· AC:
vlan 100
vlan 200
ssid service
vlan 200
portal domain dm1
interface Vlan-interface100
ipv6 address 2001::1/64
interface Vlan-interface200
ip address 192.168.2.1 255.255.255.0
ipv6 address 2004::1/64
port link-mode bridge
ip route-static 192.168.3.0 24 192.168.2.2
radius scheme rs1
key authentication cipher $c$3$2m4BXR2X65vE59L0SyyHH0tRVpkKDgym9w==
key accounting cipher $c$3$4ieHsnXQVnQ7GwywFS+H0MoQdb6SEmJSRg==
nas-ip 192.168.1.1
radius scheme rs2
key authentication cipher $c$3$8bAMsBFXCGlbmynTi08YCxotgTXYwzES0w==
key accounting cipher $c$3$QeTcfxJGTnPJ98PsCSbLnaZP6KAG6q42aQ==
nas-ip ipv6 2001::1
client ip 192.168.3.2 key cipher $c$3$l9xAYe5vBJQMTOv6quHJFXtZlti404CjBg==
client ipv6 2003::2 key cipher $c$3$ELOjfzKgjUoRbJ/wZX0E9eVdGBFeTQzmHA==
domain dm1
domain dm2
radio 2
radio enable
return
· Switch:
vlan 1
vlan 100
vlan 200
ipv6 dhcp pool 1
network 2001::/64
ipv6 dhcp pool 2
network 2004::/64
ipv6 address 2003::1/64
ipv6 address 2001::2/64
ip address 192.168.2.2 255.255.255.0
ipv6 address 2004::2/64
poe enable
Return
Related documentation
· Security Command Reference in H3C Access Controllers Command References
· Security Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Command Reference in H3C Access Controllers Command References
· WLAN Configuration Guide in H3C Access Controllers Configuration Guides
%20Configuration%20Examples.files/x_Img_x_png_0.png)
%20Configuration%20Examples.files/x_Img_x_png_1.png)
%20Configuration%20Examples.files/x_Img_x_png_2.png)
%20Configuration%20Examples.files/x_Img_x_png_3.png)
%20Configuration%20Examples.files/x_Img_x_png_4.png)
