H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers and Access Points Configuration Examples(V7)-6W101
Table of Contents
Related Documents
36-H3C Access Controllers HTTPS Login Configuration Examples (V7)
Comware 7 HTTPS Login
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides an HTTPS login configuration example.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of WLAN access and HTTPS login.
Example: Configuring HTTPS login
Network requirements
As shown in Figure 1, configure the switch and the AC to achieve the following goals:
·     The AC allows only authorized users to access the Web interface by using HTTPS.
·     The switch acts as the DHCP server to assign IP addresses to the AP and client.
·     The AP and AC use VLAN 100 to establish a CAPWAP tunnel.
·     The client uses VLAN 200 to access the wireless network.
Figure 1 Network diagram
When you configure HTTPS login, follow these restrictions and guidelines:
·     Use the serial ID labeled on the AP's rear panel to specify an AP.
·     In this example, the CA certificate and local certificate for the AC are transferred in advance to the AC in offline mode. Make sure the certificates have not expired.
Configuration procedures
Configuring the AC
1.     Configure interfaces of the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.0.1 16
[AC-Vlan-interface200] quit
# Configure the interface that is connected to the switch as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure the wireless service:
# Create wireless service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Assign clients coming online through service template 1 to VLAN 200.
[AC-wlan-st-1] vlan 200
# Enable service template 1.
[AC-wlan-st-1] quit
3.     Configure the AP:
# Create AP ap1. Set the model and serial ID.
[AC] wlan ap ap1 model WA560-WW
[AC-wlan-ap-ap1] serial-id 219801A1NM8182032235
# Enter the view of radio 1 and bind service template service with radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
4.     Configure HTTPS login:
# Create PKI domain 1 and disable CRL checking. (If CRL checking is required, enable CRL checking.)
[AC] pki domain 1
[AC-pki-domain-1] undo crl check enable
[AC-pki-domain-1] quit
# Import CA certificate file root.pem in PEM format to PKI domain 1.
[AC] pki import domain 1 pem ca filename root.pem
# Import local certificate file radius.pem in PEM format to PKI domain 1.
[AC] pki import domain 1 pem local filename radius.pem
Please input the password:****
# Create SSL server policy myssl and specify PKI domain 1 for the policy.
[AC] ssl server-policy myssl
[AC-ssl-server-policy-myssl] pki-domain 1
[AC-ssl-server-policy-myssl] quit
# Apply SSL server policy myssl to the HTTPS service.
[AC] ip https ssl-server-policy myssl
# Enable the HTTPS service.
[AC] ip https enable
# Add device management user usera and set the password. Assign the HTTPS service type and network-admin user role to the user.
[AC] local-user usera
[AC-luser-manage-usera] password simple 123
[AC-luser-manage-usera] service-type https
[AC-luser-manage-usera] authorization-attribute user-role network-admin
[AC-luser-manage-usera] quit
Configuring the switch
1.     Configure interfaces of the switch:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward AC traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 16
[Switch-Vlan-interface200] quit
# Configure the interface that is connected to the AC as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure the interface that is connected to the AP as a trunk port, set its PVID to VLAN 100, and assign it to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
# Enable PoE on the interface that is connected to the AP.
2.     Configure the DHCP server:
# Enable the DHCP service.
[Switch] dhcp enable
# Create DHCP address pool 100. Specify the 192.1.0.0/16 subnet and the 192.1.0.2 gateway for the pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.1.0.0 16
[Switch-dhcp-pool-100] gateway-list 192.1.0.2
# Use option 43 to assign the IP address of the AC to the AP. (The last four bytes of the hexadecimal option content are c0010001, which represents 192.1.0.1.)
[Switch-dhcp-pool-100] option 43 hex 8007000001c0010001
[Switch-dhcp-pool-100] quit
# Create DHCP address pool 200. Specify the 192.2.0.0/16 subnet and the 192.2.0.2 gateway for the pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.2.0.0 16
[Switch-dhcp-pool-200] gateway-list 192.2.0.2
[Switch-dhcp-pool-200] quit
# On the client, launch the Web browser and enter https://192.2.0.1 in the address bar. (Details not shown.)
# When the Web login page appears, enter username usera and password 123 to log in to the Web interface of the AC. (Details not shown.)
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
interface Vlan-interface100
 ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
 ip address 192.2.0.1 255.255.0.0
local-user usera class manage
 password hash $h$6$FOrfdnZ2QRORxu7o$OK/dcQ/N/S7m+zrhpyh+xDm2aerS7vvN8WwFVuhQuk8hdeFjDtqzPJthCen1ylElTkE7OqbCG5YhiRnjHtEr0g==
 service-type https
pki domain 1
 pki-domain 1
 ip https enable
 vlan 1
 radio 1
  radio enable
  service-template 1
·     Switch:
 dhcp enable
vlan 100
vlan 200
 ip address 192.1.0.2 255.255.0.0
 ip address 192.2.0.2 255.255.0.0
 network 192.1.0.0 mask 255.255.0.0
 option 43 hex 8007000001C0010001
 network 192.2.0.0 mask 255.255.0.0
poe enable
Related documentation
·     Fundamentals Command Reference in H3C Access Controllers Command References
·     Fundamentals Configuration Guide in H3C Access Controllers Configuration Guides
·     Security Command Reference in H3C Access Controllers Command References
·     Security Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Command Reference in H3C Access Controllers Command References
·     WLAN Configuration Guide in H3C Access Controllers Configuration Guides
