H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
32-VLAN-VPN Command
32-VLAN-VPN Command 60.04 KB
VLAN-VPN Configuration Commands
display port vlan-vpn
View
None
Use the display port vlan-vpn command to display the information about VLAN-VPN configuration of the current system. including current TPID value, VLAN-VPN ports, and VLAN-VPN uplink ports.
# Display the information about VLAN-VPN configuration of the current system
<device> display port vlan-vpn
 VLAN-VPN TPID: 8100
GigabitEthernet1/0/4
 VLAN-VPN status: enabled
 VLAN-VPN VLAN: 1
GigabitEthernet1/0/11
 VLAN-VPN uplink status: enabled
GigabitEthernet1/0/12
vlan-vpn enable
vlan-vpn enable
undo vlan-vpn
View
Ethernet port view
None
Use the vlan-vpn enable command to enable the VLAN-VPN feature for a port.
Use the undo vlan-vpn command to disable the VLAN-VPN feature for a port.
By default, the VLAN-VPN feature is disabled.
With the VLAN-VPN feature enabled, a received packet is tagged with the default VLAN tag of the receiving port no matter whether or not the packet already carries a VLAN tag.
l          If the packet already carries a VLAN tag, the packet becomes a dual-tagged packet.
l          Otherwise, the packet becomes a packet carrying the default VLAN tag of the port.
l          If this port is a remote mirror reflection port, the VLAN-VPN function cannot be enabled on the port.
l          If this port is a VLAN-VPN uplink port, the VLAN-VPN function cannot be enabled on the port.
# Enable the VLAN-VPN feature for GigabitEthernet 1/0/1.
<device> system-view
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] vlan-vpn enable
vlan-vpn tpid
vlan-vpn tpid value
undo vlan-vpn tpid
View
value: User-defined TPID value (in hexadecimal format), in the range 0x0001 to 0xFFFF.
Use the vlan-vpn tpid command to set the TPID value.
Use the undo vlan-vpn tpid command to restore the default TPID value.
The default TPID value is 0x8100.
The position of the TPID field in an Ethernet packet is the same as the position of the protocol type field in a packet without VLAN Tag. Thus, to avoid confusion happening when the device forwards or receives a packet, do not configure the protocol type values listed in Table 1-1 as the TPID value.
Table 1-1 Common Ethernet frame protocol type values
Protocol type
Value
ARP
0x0806
IP
0x0800
MPLS
0x8847/0x8848
IPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1x
0x888E
# Set the TPID value to 0x9100.
[device] vlan-vpn tpid 9100
vlan-vpn uplink enable
undo vlan-vpn uplink
View
Ethernet port view
None
Use the vlan-vpn uplink enable command to configure a port to be a VLAN-VPN uplink port.
Use the undo vlan-vpn uplink command to remove the configuration.
By default, no port is configured to VLAN-VPN uplink port.
When sending a VLAN-VPN packet, a VLAN-VPN uplink port replaces the TPID value in the outer VLAN tag of the packet with the customized TPID value. You can use the vlan-vpn tpid command to set the TPID value used by the VLAN-VPN uplink port.
l          A port cannot be configured to VLAN-VPN port and VLAN-VPN uplink port at the same time.
l          With the TPID being 0x8100, every port can be configured as a VLAN VPN uplink port. However, if the TPID value is not the default value, you need to use the vlan-vpn uplink enable command to specify a VLAN VPN uplink port.
# Configure GigabitEthernet1/0/2 to be a VLAN-VPN uplink port.
[device] interface GigabitEthernet 1/0/2
[device-GigabitEthernet1/0/2] vlan-vpn uplink enable
Selective QinQ Configuration Commands
raw-vlan-id inbound
raw-vlan-id inbound vlan-id-list
undo raw-vlan-id inbound { all | vlan-id-list }
View
QinQ view
vlan-id-list: Lists of VLAN IDs to be tagged as outer VLAN tags. You need to provide this argument in the form of { vlan-id [ to vlan-id ] }&<1-10>, where the VLAN ID after the to keyword must be larger than or equal to the VLAN ID before the to keyword and &<1-10> means that you can specify up to 10 VLANs/VLAN ranges for this argument.
all: Specifies not to tag any packet carrying an inner VLAN tag with an outer VLAN tag.
Use the raw-vlan-id inbound command to specify the outer tag for the packets with the specified inner VLAN tags. This command must be configured on ports receiving packets from the private network.
Use the undo raw-vlan-id inbound command to remove the configuration.
A packet cannot be tagged with different outer VLAN tags. To change the outer VLAN tag of a packet, you need to remove the existing outer VLAN tag configuration and configure a new outer VLAN tag.
Related commands: vlan-vpn vid.
# Specify to add the tag of VLAN 20 as the outer tag to the packets with their inner VLAN IDs being 8 through 15 for GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] vlan-vpn vid 20
[device-GigabitEthernet1/0/1-vid-20] raw-vlan-id inbound 8 to 15
vlan-vpn priority
vlan-vpn priority old-priority remark new-priority
undo vlan-vpn priority old-priority
View
Ethernet port view
old-priority: 802.1p priority of the inner VLAN tag in a packet. This argument can be in the range 0 to 7 or a keyword listed in Table 2-1.
new-priority: Priority for the outer VLAN tag in a packet. This argument can be in the range 0 to 7 or a keyword listed in Table 2-1.
Table 2-1 Description on 802.1p priority
IP Precedence (decimal)
Keyword
0
Best-effort
1
Background
2
Spare
3
Excellent-effort
4
Controlled-load
5
Video
6
Voice
7
Network-management
For the description on the priority values and the keywords listed in Table 2-1, refer to Qos-QoS profile.in H3C WX3000 Series Unified Switches Switching Engine Configuration Guide.
Use the vlan-vpn priority command to configure the mapping relationship between the inner VLAN priority and the outer VLAN priority.
Use the undo vlan-vpn priority command to remove the configuration.
When the outer VLAN tag is inserted, the VLAN-VPN feature assigns a priority to the outer VLAN tag based on the inner VLAN tag priority according to the configured mapping relationship.
By default, the priority in the outer VLAN tag is the port priority.
# Enable the inner-to-outer tag priority mapping feature for GigabitEthernet 1/0/1. Insert outer tags with the priorities being 5 to packets with the priorities of their inner tags being 3.
[device-GigabitEthernet1/0/1] vlan-vpn priority 3 remark 5
vlan-vpn vid
vlan-vpn vid vlan-id
undo vlan-vpn vid vlan-id
View
Ethernet port view
vlan-id: VLAN ID, in the range 1 to 4094.
Use the vlan-vpn vid command to configure the outer VLAN tag for a selective-QinQ-enabled port. This command also leads you to QinQ view. A selective-QinQ-enabled port adds user-defined outer VLAN tags to the packets received. You can use the raw-vlan-id inbound command to add outer VLAN tags to the packets with the specified inner VLAN tags.
Use the undo vlan-vpn vid command to remove the configuration.
Before configuring this command, make sure that the vlan-vpn enable command is configured.
l          Before configuring this command, make sure that the vlan-vpn enable command is configured.
l          You are not recommended to configure both the DHCP snooping and selective Q-in-Q function on the device, which may result in the DHCP snooping to function abnormally.
By default, the outer VLAN tag added in the selective QinQ feature is the VLAN tag corresponding to the port’s default VLAN ID.
This command must be coupled with the raw-vlan-id inbound command to add different outer VLAN tags for packets of different VLANs.
Related commands: raw-vlan-id inbound.
# Specify to add VLAN 20 tag as the outer tags to the packets with their inner VLAN IDs being 2 through 14 for GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1-vid-20] raw-vlan-id inbound 2 to 1
