H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
18-IP Address and Performance Command
18-IP Address and Performance Command 86.17 KB
IP Address Configuration Commands
display ip interface
display ip interface [ interface-type interface-number ]
View
Use the display ip interface command to display information about a specified or all Layer 3 interfaces.
If no argument is specified, information about all Layer 3 interfaces is displayed.
# Display information about VLAN-interface 1.
<device> display ip interface vlan-interface 1
Vlan-interface1 current state :UP
Line protocol current state :UP
Internet Address is 192.168.0.39/24 Primary
Broadcast address : 192.168.0.255
The Maximum Transmit Unit : 1500 bytes
IP packets input number: 9678, bytes: 475001, multicasts: 7
IP packets output number: 8622, bytes: 391084, multicasts: 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
Table 1-1 display ip interface command output description
Current physical state of VLAN interface 1
Current state of the link layer protocol
Internet Address
IP address. Primary indicates it is the primary IP address and Sub indicates it is a secondary IP address
Broadcast address
Broadcast address
Max transmit unit
Total number of input/output packets, bytes, and multicast packets
Number of received invalid TTL packets
    Echo reply:                                0
    Unreachable:                            0
    Source quench:                        0
    Routing redirect:                       0
    Echo request:                            0
    Router advert:                           0
    Router solicit:                            0
    Time exceed:                            0
    IP header bad:                          0
    Timestamp reply:                      0
    Netmask request:                      0
    Netmask reply:                          0
    Unknown type:                          0
Total number of received ICMP packets, including:
Echo reply packet, unreachable packet, source quench packet, routing redirect packet, Echo request packet, router advert packet, router solicit packet, time exceed packet, IP header bad packet, timestamp request packet, timestamp  reply packet, information request packet, information reply packet, netmask request packet, netmask reply packet, and unknown types of packets.
display ip interface brief
display ip interface brief [ interface-type [ interface-number ] ]
View
interface-type: Interface type.
interface-number: Interface number.
Use the display ip interface brief command to display brief information about a specified or all Layer 3 interfaces.
With no argument included, the command displays information about all Layer 3 interfaces; with only the interface type specified, it displays information about all Layer 3 interfaces of the specified type; with both the interface type and interface number specified, it displays information about the specified interface.
Related commands: display ip interface.
# Display brief information about VLAN-interface1.
<device> display ip interface brief vlan-interface 1
*down: administratively down
(l): loopback
(s): spoofing
 Interface               IP Address     Physical Protocol     Description
 Vlan-interface1         192.168.0.39    up       up           Vlan-inte...
Table 1-2 display ip interface brief command output description
*down
The interface is administratively shut down with the shutdown command.
(s)
Spoofing attribute of the interface. It indicates that the interface whose link layer protocol is displayed up may have no such a link present or the link is set up only on demand.
Interface name
IP Address
IP address of the interface (If no IP address is configured, “unassigned” is displayed.)
Physical
Physical state of the interface
Protocol
Link layer protocol state of the interface
Description information for the interface
ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
VLAN interface view/loopback interface view
ip-address: IP address, in dotted decimal notation.
mask: Subnet mask, in dotted decimal notation.
mask-length: Length of a subnet mask, in the range of 0 to 32.
sub: Specifies a secondary IP address of a VLAN or loopback interface.
Use the ip address command to specify an IP address and mask for a VLAN or loopback interface.
Use the undo ip address command to remove an IP address and mask of a VLAN or loopback interface.
By default, no IP address is configured for VLAN or loopback interface.
Note that:
l          If you execute the undo ip address command without any parameter, the device deletes both primary and secondary IP addresses of the interface.
l          The undo ip address ip-address { mask | mask-length } command is used to delete the primary IP address.
l          The undo ip address ip-address { mask | mask-length } sub command is used to delete specified secondary IP addresses.
l          You can assign at most two IP address to an interface, among which one is the primary IP address and another is secondary IP addresses. A newly specified primary IP address overwrites the previous one if there is any.
l          The primary and secondary IP addresses of an interface cannot reside on the same network segment; the IP address of a VLAN interface must not be in the same network segment as that of a loopback interface on a device.
l          A VLAN interface cannot be configured with a secondary IP address if the interface has been configured to obtain an IP address through BOOTP or DHCP.
# Assign the primary IP address 129.12.0.1 and secondary IP address 129.12.1.1 to VLAN interface 1 with subnet mask 255.255.255.0.
<device> system-view
[device] interface vlan-interface 1
[device-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[device-Vlan-interface1] ip address 129.12.1.1 255.255.255.0 sub
IP Performance Configuration Commands
display fib
display fib
View
None
Use the display fib command to display all forwarding information base (FIB) information.
# Display all FIB information.
<device> display fib
Flag:
  U:Usable   G:Gateway    H:Host       B:Blackhole  D:Dynamic    S:Static
  R:Reject   E:Equal cost multi-path   L:Generated by ARP or ESIS     Destination/Mask   Nexthop         Flag TimeStamp     Interface
10.153.17.0/24     10.153.17.99    U    t[37]          Vlan-interface1
10.153.18.88/32    127.0.0.1       GHU  t[37]          InLoopBack0
10.153.18.0/24     10.153.18.88    U    t[37]          LoopBack0
10.153.17.99/32    127.0.0.1       GHU  t[37]          InLoopBack0
127.0.0.0/8        127.0.0.1       U    t[33]          InLoopBack0
Table 2-1 display fib command output description
Flag
Flags:
U: A route is up and available.
G: Gateway route
H: Local host route
B: Blackhole route
D: Dynamic route
S: Static route
R: Rejected route
E: Multi-path equal-cost route
L: Route generated by ARP or ESIS
Destination/Mask
Destination address/mask length
Nexthop
Next hop address
TimeStamp
Timestamp
Forwarding interface
display fib ip-address
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
View
ip-address1, ip-address2: Destination IP addresses, in dotted decimal notation. ip-address1 and ip-address2 together define an address range. The FIB entries in this address range will be displayed.
mask1, mask2: Subnet masks, in dotted decimal notation.
mask-length1, mask-length2: Length of the subnet masks, in the range of 0 to 32.
longer: Displays the FIB entries matching the specified address/mask and having masks longer than or equal to the specified mask. If no masks are specified, FIB entries that match the natural network address and have the masks longer than or equal to the natural mask will be displayed.
Use the display fib ip-address command to view the FIB entries matching the specified destination IP address.
# Display the FIB entries whose destination addresses match 12.158.10.0 in the natural mask range.
<device> display fib 12.158.10.0 longer
  Route Entry Count: 1
Flag:
12.158.10.0/24     12.158.10.1     U    t[85391]      Vlan-interface10
# Display the FIB entries whose destination addresses are in the range of 12.158.10.0/24 to 12.158.10.6/24.
<device> display fib 12.158.10.0 255.255.255.0 12.158.10.6 255.255.255.0
Flag:
For details about the displayed information, see Table 2-1.
display fib acl
display fib acl acl-number
View
acl-number: Basic ACL number, in the range of 2000 to 2999.
Use the display fib acl command to display the FIB entries matching a specific ACL. For ACL, refer to ACL in H3C WX3000 Series Unified Switches Switching Engine Configuration Guide
# Display ACL 2001.
<device>display acl 2001
Basic ACL  2001, 1 rule
Acl's step is 1
 rule 0 permit source 211.71.75.0 0.0.0.255
# Display the FIB entries filtered by ACL 2001.
<device> display fib acl 2001
Route Entry matched by access-list 2001
  Summary Counts :1
Flag:
211.71.75.0/24     1.1.1.2         GSU  t[250763]     Vlan-interface2
display fib |
display fib | { begin | exclude | include } regular-expression
View
begin: Displays the FIB entries from the first one containing the regular expression string.
exclude: Displays only those FIB entries excluding the regular expression character string.
include: Display only those FIB entries containing the regular expression character string.
regular-expression: Regular expression. For details about regular expression, refer to File System Management in H3C WX3000 Series Unified Switches Switching Engine Configuration Guide.
Use the display fib | command to output the FIB entries related to the specific character string from the buffer according to the regular expression.
# Display the entries starting from the first one containing the string 169.254.0.0.
<device> display fib | begin 169.254.0.0
169.254.0.0/16    2.1.1.1     U       t[0]            Vlan-interface1
2.0.0.0/16        2.1.1.1     U       t[0]            Vlan-interface1
display fib statistics
View
None
Use the display fib statistics command to display the total number of FIB entries.
# Display the total number of FIB entries.
<device> display fib statistics
Route Entry Count : 8
display icmp statistics
View
None
Use the display icmp statistics command to display the statistics about ICMP packets.
Related commands: display ip interface, reset ip statistics.
# Display the statistics about ICMP packets.
<device> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                   information reply       0
         time exceeded 0
Table 2-2 display icmp statistics command output description
bad formats
Number of input wrong format packets
bad checksum
Number of input wrong checksum packets
echo
Number of input/output echo packets
Number of input/output destination unreachable packets
source quench
Number of input/output source quench packets
redirects
Number of input/output redirection packets
echo reply
Number of input/output replies
parameter problem
Number of input/output parameter problem packets
timestamp
Number of input/output time stamp packets
information request
Number of input information request packets
mask requests
Number of input/output mask requests
mask replies
Number of input/output mask replies
information reply
Number of output information reply packets
time exceeded
Number of input/output expiration packets
display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ]
View
sock-type: Type of a socket, ranging from 1 to 3. These values correspond to SOCK_STREAM (TCP socket), SOCK_DGRAM (UDP socket or socket based on the link layer), and SOCK_RAW (RAW IP socket).
task-id: ID of a task, with the value ranging from 1 to 100.
socket-id: ID of a socket, with the value ranging from 0 to 3072.
Use the display ip socket command to display the information of the current socket.
# Display the information about the socket of the TCP type.
<device> display ip socket socktype 1
SOCK_STREAM:
Task = VTYD(18), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 2, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.56:1161,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 3, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.82:1121,
Table 2-3 display ip socket command output description
SOCK_STREAM
Indicates the socket type is TCP
Task ID
socketid
Socket ID
Proto
Protocol number used by the socket
sndbuf
Sending buffer size of the socket
rcvbuf
Receiving buffer size of the socket
sb_cc
Current data size in the sending buffer. The value makes sense only for the socket of TCP type, because only TCP is able to cache data.
rb_cc
Current data size in the receiving buffer
socket option
Option of a socket
socket state
State of a socket
display ip statistics
View
None
Use the display ip statistics command to display the statistics about IP packets.
# Display the statistics about IP packets.
<device> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Table 2-4 display ip statistics command output description
Input:
sum
Total number of packets received
local
Total number of packets with destination being local
bad protocol
Total number of unknown protocol packets
bad format
Total number of packets with incorrect format
bad checksum
Total number of packets with incorrect checksum
bad options
Total number of packets with incorrect option
Output:
forwarding
Total number of packets forwarded
local
Total number of packets sent from the local
dropped
Total number of packets discarded
no route
Total number of packets for which no route is available
compress fails
Total number of packets failed to compress
Fragment:
input
Total number of fragments received
output
Total number of fragments sent
dropped
Total number of fragments dropped
fragmented
Total number of packets successfully fragmented
couldn't fragment
Total number of packets that can’t be fragmented
Reassembling:
sum
Total number of packets reassembled
timeouts
Total number of reassembly timeout packets
display tcp statistics
View
None
Use the display tcp statistics command to display the statistics about TCP packets.
Related commands: display tcp status, reset tcp statistics.
# Display the statistics about TCP connections.
<device> display tcp statistics
Received packets:
     Total: 753
     packets in sequence: 412 (11032 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
     out-of-order packets: 0 (0 bytes)
     packets of data after window: 0 (0 bytes)
     packets received after close: 0
     ACK packets: 481 (8776 bytes)
     duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
     Total: 665
     urgent packets: 0
     control packets: 5 (including 1 RST)
     window probe packets: 0, window update packets: 2
     data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
     ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 2-5 display tcp statistics command output description
Received packets:
Total
packets in sequence
Number of packets arriving in sequence
Number of window probe packets received
Number of window update packets received
checksum error
Number of checksum error packets received
offset error
Number of offset error packets received
short error
Number of received packets with length being too small
duplicate packets
Number of completely duplicate packets received
Number of partially duplicate packets received
Number of out-of-order packets received
Number of packets outside the receiving window
Number of packets that arrived after connection is closed
ACK packets
Number of ACK packets received
Number of duplicate ACK packets received
Number of ACK packets for data unsent
Sent packets:
Total
urgent packets
Number of urgent packets sent
control packets
Number of control packets sent
Number of window probe packets sent; in the brackets are resent packets
Number of window update packets sent
data packets
Number of data packets sent
Number of data packets retransmitted
Number of ACK packets sent; in brackets are delayed ACK packets
Number of retransmission timer timeouts
Number of connections broken due to retransmission timeouts
Keepalive timeout
Number of keepalive timer timeouts
keepalive probe
Number of keepalive probe packets sent
Number of connections broken due to keepalive probe failures
Number of connections initiated
Number of connections accepted
Number of connections established
Closed connections
Number of connections closed; in brackets are connections closed accidentally (before receiving SYN from the peer) and connections closed initiatively (after receiving SYN from the peer)
Number of packets dropped with MD5 authentication
Number of packets permitted with MD5 authentication
display tcp status
display tcp status
View
None
Use the display tcp status command to display the state of all the TCP connections so that you can monitor TCP connections in real time.
# Display the state of all the TCP connections.
<device> display tcp status
 *: TCP MD5 Connection
TCPCB     Local Add:port      Foreign Add:port        State
03e37dc4  0.0.0.0:4001            0.0.0.0:0           Listening
04217174  100.0.0.204:23      100.0.0.253:65508   Established
Table 2-6 display tcp status command output description
If there is an asterisk before a connection, it means that the TCP connection is authenticated through the MD5 algorithm
TCPCB
TCP control block
Local Add:port
Local IP address and port number
Foreign Add:port
Remote IP address and port number
State of the TCP connection
display udp statistics
View
None
Use the display udp statistics command to display the statistics about UDP packets.
Related commands: reset udp statistics.
# Display the statistics about UDP packets.
<device> display udp statistics
Received packets:
     Total: 26320
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     no socket on port: 0
     total broadcast or multicast packets : 25006
     no socket broadcast or multicast packets: 24989
     not delivered, input socket full: 0
     input packets missing pcb cache: 1314
Sent packets:
     Total: 7187
Table 2-7 display udp statistics command output description
Received packets:
Total
Total number of received UDP packets
checksum error
shorter than header
Number of packets with data shorter than header
Number of packets with data longer than packet
no socket on port
Number of unicast packets with no socket on port
Total number of transmitted broadcast or multicast packets
Total number of broadcast or multicast packets without socket on port
Number of not delivered packets because the socket cache is full
Number of packets without matching PCB cache
Sent packets:
Total
Total number of UDP packets sent
icmp redirect send
icmp redirect send
undo icmp redirect send
View
None
Use the icmp redirect send command to enable the device to send ICMP redirection packets.
Use the undo icmp redirect send command to disable the device from sending ICMP redirection packets.
By default, the device is enabled to send ICMP redirection packets.
# Disable the device from sending ICMP redirection packets.
[device] undo icmp redirect send
icmp unreach send
icmp unreach send
undo icmp unreach send
View
None
Use the icmp unreach send command to enable the device to send ICMP destination unreachable packets.
Use the undo icmp unreach send command to disable the device from sending ICMP destination unreachable packets.
By default, the device is enabled to send ICMP destination unreachable packets.
# Disable the device from sending ICMP destination unreachable packets.
[device] undo icmp unreach send
reset ip statistics
reset ip statistics
View
None
Use the reset ip statistics command to clear the statistics about IP packets.
Related commands: display ip interface, display ip statistics.
# Clear the statistics about IP packets.
<device> reset ip statistics
View
None
Use the reset tcp statistics command to clear the statistics about TCP packets.
Related commands: display tcp statistics.
# Clear the statistics about TCP packets.
<device> reset tcp statistics
View
None
Use the reset udp statistics command to clear the statistics about UDP packets.
Related commands: display udp statistics.
# Clear the statistics about UDP packets.
<device> reset udp statistics
tcp timer fin-timeout
undo tcp timer fin-timeout
View
time-value: TCP finwait timer value, in seconds, with the value ranging from 76 to 3600.
Use the tcp timer fin-timeout command to configure the TCP finwait timer.
Use the undo tcp timer fin-timeout command to restore the default value of the TCP finwait timer.
By default, the value of the TCP finwait timer is 675 seconds.
When the TCP connection state changes from FIN_WAIT_1 to FIN_WAIT_2, the finwait timer is enabled. If the device does not receive FIN packets before finwait timer times out, the TCP connection will be terminated.
Related commands: tcp timer syn-timeout, tcp window.
# Configure the value of the TCP finwait timer to 800 seconds.
[device] tcp timer fin-timeout 800
undo tcp timer syn-timeout
View
time-value: TCP synwait timer value, in seconds, with the value ranging from 2 to 600.
Use the tcp timer syn-timeout command to configure the TCP synwait timer.
Use the undo tcp timer syn-timeout command to restore the default value of the TCP synwait timer.
By default, the value of the TCP synwait timer is 75 seconds.
When sending the SYN packet, TCP starts the synwait timer. If the response packet is not received before synwait times out, the TCP connection will be terminated.
Related commands: tcp timer fin-timeout, tcp window.
# Configure the value of the TCP synwait timer to 80 seconds.
[device] tcp timer syn-timeout 80
tcp window
tcp window window-size
undo tcp window
View
window-size: Size of the transmission and receiving buffers of the connection-oriented socket, measured in kilobytes (KB), in the range of 1 to 32.
Use the tcp window command to configure the size of the transmission and receiving buffers of the connection-oriented socket.
Use the undo tcp window command to restore the default size of the transmission and receiving buffers of the connection-oriented socket.
By default, the size of the transmission and receiving buffers is 8 KB.
Related commands: tcp timer fin-timeout, tcp timer syn-timeout.
# Configure the size of the transmission and receiving buffers of the connection-oriented socket to 3KB.
[device] tcp window 3
