H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
01-CLI Command
01-CLI Command 32.28 KB
CLI Configuration Commands
command-privilege level
command-privilege level level view view command
undo command-privilege view view command
View
level level: Command level to be set, in the range of 0 to 3.
view view: CLI view. It can be any CLI view that the device supports.
command: Command for which the level is to be set.
Use the command-privilege level command to set the level of a specified command in a specified view.
Use the undo command-privilege view command to restore the default level of a specified command in a specified view.
Commands fall into four levels: visit (level 0), monitor (level 1), system (level 2), and manage (level 3). The administrator can change the level of a command as required. For example, the administrator can change a command from a higher level to a lower level so that the lower level users can use the command.
By default, the ping, tracert, and telnet commands are at the visit level (level 0), the debugging and terminal commands are at the monitor level (level 1), all configuration commands are at the system level (level 2), and FTP, TFTP, Xmodem and file system operation commands are at the manage level (level 3).
# Set the level of the system-view command in user view (shell) to 0.
<device> system-view
[device] command-privilege level 0 view shell system-view
display history-command
View
None
Use the display history-command command to display the history commands of the current user, so that the user can check the configurations performed formerly.
History commands are those commands that was successfully executed recently and saved in the history command buffer. You can set the size of the buffer by the history-command max-size command. When the history command buffer is full, the earlier commands will be overwritten by the new ones.
By default, the CLI can save 10 history commands for each user.
Related commands: history-command max-size in Login.
# Display the history commands of the current user.
<device> display history-command
super
super [ level ]
View
level: User level, in the range of 0 to 3.
Use the super command to switch from the current user level to a specified level.
Executing this command without the level argument will switch the current user level to level 3 by default.
Note that:
l          Users logged into the switch fall into four user levels, which correspond to the four command levels respectively. Users at a specific level can only use the commands at the same level or lower levels.
l          If a switching password is set for a specific user level by the super password command, all users must enter the password correctly when they switch from lower user levels to this level (if a wrong password is entered, they will remain at their original levels).
l          If no switching password is set for a specific user level, the Console user can directly switch to the level, while the Telnet users at lower levels will fail to switch to the level (they will remain at their original levels) and the information like the following will be displayed: % Password is not set.
l          Users can directly switch from a higher user level to a lower user level, no matter whether a switching password is set.
Related commands: super password.
# Switch from current user level (a lower level) to user level 3.
<device> super 3
 Password:
User privilege level is 3, and only those commands can be used
whose level is equal or less than this.
Privilege note: 0-VISIT, 1-MONITOR, 2-SYSTEM, 3-MANAGE
super password
super password [ level level ] { cipher | simple } password
undo super password [ level level ]
View
level level: User level, in the range of 1 to 3. it is 3 by default.
cipher: Stores the password in the configuration file in ciphered text.
simple: Stores the password in the configuration file in plain text.
password: Password to be set. If the simple keyword is used, you must provide a plain-text password, that is, a string of 1 to 16 characters. If the cipher keyword is used, you can provide a password in either of the two ways:
l          Input a plain-text password, that is, a string of 1 to 16 characters, which will be automatically converted into a 24-character cipher-text password.
l          Directly input a cipher-text password, that is, a string of 1 to 24 characters, which must correspond to a plain-text password. For example, The cipher-text password “_(TT8F]Y\5SQ=^Q`MAF4<1!!” corresponds to the plain-text password “1234567”.
Use the super password command to set a switching password for a specified user level, which will be used when users switch from a lower user level to the specified user level.
Use the undo super password command to restore the default configuration.
By default, no such password is set.
For security purpose, the password entered is not displayed when you switch to another user level. You will remain at the original user level if you have tried three times but failed to enter the correct password.
Note that, no matter whether a plain-text or cipher-text password is set, users must enter the plain-text password during authentication.
# Set the switching password for level 3 to “0123456789” in plain text.
[device] super password level 3 simple 0123456789
