H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
08-Basic Port Configuration Command
08-Basic Port Configuration Command 134.16 KB
Basic Port Configuration Commands
broadcast-suppression
broadcast-suppression { ratio | pps max-pps }
undo broadcast-suppression
View
System view or Ethernet port view
ratio: Specifies the allowed maximum ratio of the broadcast traffic to the total bandwidth on one or each port. The value ranges form 1 to 100 and defaults to 100. The smaller the ratio is, the smaller the broadcast traffic is allowed.
max-pps: Maximum number of broadcast packets that can be received on an Ethernet port per second (in pps).
l          In system view, the max-pps argument is in the range of 200 to 14,881,000.
l          In Ethernet port view, the max-pps argument is in the range of 200 to 1,488,100.
Use the broadcast-suppression command to define the broadcast traffic ratio allowed on one port or each of the ports.
Use the undo broadcast-suppression command to restore the default ratio.
l          When you execute the command here in system view, the command takes effect on all ports.
l          When you execute the command here in Ethernet port view, the command takes effect only on the current port.
Once broadcast traffic exceeds the value set by the user, the system maintains an appropriate broadcast traffic ratio by discarding the overflow traffic, so as to suppress broadcast storm, avoid network congestion and ensure normal network services.
By default, broadcast suppression is disabled.
# Allow the broadcast traffic passing through GigabitEthernet 1/0/1 to occupy at most 20% of the bandwidth.
<device> system-view
[device] interface GigabitEthernet1/0/1
[device-GigabitEthernet1/0/1] broadcast-suppression 20
# Configure the maximum number of broadcast packets that can be received on GigabitEthernet 1/0/1 per second as 1000.
[device-GigabitEthernet1/0/1] broadcast-suppression pps 1000
copy configuration
copy configuration source { interface-type interface-number | aggregation-group source-agg-id } destination { interface-list [ aggregation-group destination-agg-id ] | aggregation-group destination-agg-id }
View
interface-type: Port type.
interface-number: Port number.
source-agg-id: Source aggregation group number, in the range of 1 to 12. The port with the smallest port number in the aggregation group is used as the source port.
interface-list: Destination port list, interface-list = { interface-type interface-number } [ to interface-type interface-number ] &<1-10. &<1-10> means that you can enter the former parameter ten times at most.
destination-agg-id: Destination aggregation group number, in the range of 1 to 12.
Use the copy configuration command to copy the configuration on a port to some other ports to keep consistent configuration on them.
l          If you specify a source aggregation group ID, the system uses the port with the smallest port number in the aggregation group as the source.
l          If you specify a destination aggregation group ID, the configuration of the source port will be copied to all ports in the aggregation group and all ports in the group will have the same configuration as that of the source port.
The configuration that can be copied includes: VLAN configuration, protocol-based VLAN configuration, LACP configuration, QoS configuration, GARP configuration, STP configuration and initial port configuration.
l          VALN configuration: includes IDs of the VLANs allowed on the port and the default VLAN ID of the port;
l          Protocol-based VLAN configuration: includes IDs and indexes of the protocol-based VLANs allowed on the port;
l          Link aggregation control protocol (LACP) configuration: includes LACP enable/disable status;
The copy command can only be used to copy the configuration of LACP’s enable state, but not to copy the configuration of aggregation group, i.e., you can not add a port to the aggregation group bye the command.
l          QoS configuration: includes Traffic Policing, Packets Priority Marking, Port Priority, Traffic Shaping, Traffic Statistics, Traffic Redirecting, VLAN Mapping, Port Rate Limiting, Priority Trust Mode, QoS Profile ( excludes qos-profile port-based ), and so on;
l          Generic attribute registration protocol (GARP) configuration: includes GVRP enable/disable status, timer settings, and registration mode;
l          STP configuration: includes STP enable/disable status on the port, link attribute on the port (point-to-point or non-point-to-point), STP priority, path cost, packet transmission rate limit, whether loop protection is enabled, whether root protection is enabled, and whether the port is an edge port;
l          Port configuration: includes link type of the port, port rate and duplex mode.
# Copy the configuration of GigabitEthernet 1/0/1 to GigabitEthernet 1/0/2.
[device] copy configuration source GigabitEthernet1/0/1 destination GigabitEthernet1/0/2
 Copying VLAN configuration...
 Copying Protocol based VLAN configuration...
 Copying LACP configuration...
 Copying QOS configuration...
 Copying GARP configuration...
 Copying STP configuration...
 Copying speed/duplex configuration...
description
View
Ethernet port view
text: Port description, a string of up to 80 characters.
Use the description command to set a port description string.
Use the undo description command to remove the port description string.
By default, no description is defined for a port.
# Set GigabitEthernet 1/0/1 description lanswitch-interface.
[device-GigabitEthernet1/0/1] description lanswitch-interface
display brief interface
display brief interface [ interface-type interface-number ] [ | { begin | include | exclude } string ]
View
|: Used to describe the details of configuration information entries to be displayed.
begin: Each entry must begin with a specified character string.
include: Each entry must include a specified character string.
exclude: Each entry must not include a specified character string.
string: A character string of 1 to 256 characters.
Use the display brief interface command to display the brief configuration information about one or all interfaces, including: interface type, link state, link rate, duplex attribute, link type, and default VLAN ID.
This command is similar to the display interface command, but the information it displays is briefer.
Currently, for the port types other than Ethernet port, this command only displays the link state, and shows "--" in all other configuration information fields.
Related commands: display interface.
# Display the brief configuration information about GigabitEthernet 1/0/3.
<device> display brief interface GigabitEthernet 1/0/3
Interface:
Eth  - Ethernet  GE   - GigabitEthernet TENGE - tenGigabitEthernet
Loop - LoopBack  Vlan - Vlan-interface  Cas   - Cascade
Speed/Duplex:
A - auto-negotiation
Interface   Link     Speed  Duplex Type   PVID Description
GE1/0/3     UP       A100M  Afull  access 1    office
Table 1-1 display brief interface command output description
Port type
Link
Current link state: UP, DOWN or ADMINISTRATIVELY DOWN
Speed
Link rate
Duplex
Duplex attribute
Link type: access, hybrid or trunk
PVID
Default VLAN ID
The port’s description string
display interface
display interface [ interface-type | interface-type interface-number ]
View
Use the display interface command to display port configuration.
l          If you specify neither port type nor port number, the command displays information about all ports.
l          If specify only port type, the command displays information about all ports of this type.
l          If specify both port type and port number, the command displays information about the specified port.
# Display the configuration information of GigabitEthernet 1/0/1.
<device> display interface GigabitEthernet1/0/1
 GigabitEthernet1/0/1 current state : DOWN
 IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 0012-a990-2240
 Media type is twisted pair, loopback not set
 Port hardware type is 100_BASE_TX
 100Mbps-speed mode, full-duplex mode
 Link speed type is force link, link duplex type is force link
 Flow-control is enabled
 The Maximum Frame Length is 4096
 Broadcast MAX-pps: 500
 Unknown Multicast Packet drop: Disable
 Unknown Unicast Packet drop: Disable
 Allow jumbo frame to pass
 PVID: 1
 Mdi type: auto
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Last 300 seconds input:  0 packets/sec 0 bytes/sec
 Last 300 seconds output:  0 packets/sec 0 bytes/sec
 Input(total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts, - pauses
 Input(normal):  - packets, - bytes
          - broadcasts, - multicasts, - pauses
 Input:  0 input errors, 0 runts, 0 giants,  - throttles, 0 CRC
          0 frame,  - overruns, 0 aborts, 0 ignored, - parity errors
 Output(total): 0 packets, 0 bytes
          0 broadcasts, 0 multicasts, 0 pauses
 Output(normal): - packets, - bytes
 Output: 0 output errors,  - underruns, - buffer failures
          0 lost carrier, - no carrier
Table 1-2 display interface command output description
Current Ethernet port state: UP, DOWN or ADMINISTRATIVELY DOWN
Ethernet frame format
Hardware address
Port hardware address
Media type
Media type
loopback not set
No loopback is configured
Port hardware type
Port hardware type
The Maximum Transmit Unit
The maximum transmit unit
1000Mbps-speed mode, full-duplex mode
Flow-control is not enabled
Port flow control state
The maximum frame length allowed on the port
Broadcast MAX-ratio
Port broadcast suppression ratio
The unknown multicast packet dropping function is disabled
Jumbo frame allowed on the port
PVID
Default VLAN ID for the port
Mdi type
Network cable type
Port link-type
Port link type
Tagged VLAN ID
Assign tags to packets of which VLANs on the port.
Untagged VLAN ID
Do not assign tags to packets of which VLANs on the port.
Rate and number of incoming and outgoing packets in the last 300 seconds
Statistics on the total incoming packets ( including normal packets, error packets and pauses frames ) on the port
The “-” indicates that the statistical item is not supported.
Statistics on the normal incoming packets on the port
Statistics on the abnormal incoming packets on the port
Statistics on the total outgoing packets ( including normal packets, error packets and pauses frames ) on the port
Statistics on the normal outgoing packets on the port
Statistics on the abnormal outgoing packets on the port
display loopback-detection
View
None
Use the display loopback-detection command to display the loopback detection status on the port. If loopback detection is enabled, this information will also be displayed: time interval for loopback detection and the loopback ports.
# Display the loopback detection status on the port.
<device> display loopback-detection
Port GigabitEthernet1/0/1 loopback-detection is running
System Loopback-detection is running
Detection interval time is 30 seconds
There is no port existing loopback link
Table 1-3 display loopback-detection command output description
Loopback detection is enabled on the port.
Loopback detection is enabled globally.
Time interval for loopback detection is 30 seconds.
No loopback port exists.
display port
display port { hybrid | trunk | combo }
View
hybrid: Displays current hybrid ports.
trunk: Displays current trunk ports.
combo: Displays current combo ports.
Use the display port command to display all current ports with their type indicated.
# Display current hybrid ports.
<device> display port hybrid
The following hybrid ports exist:
  GigabitEthernet1/0/1          GigabitEthernet1/0/2
The above information shows that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are two hybrid ports.
# Displays current combo ports.
<device> display port combo
  Combo-group       Active                     Inactive
       1       GigabitEthernet1/0/21      GigabitEthernet1/0/27
       2       GigabitEthernet1/0/22      GigabitEthernet1/0/25
       3       GigabitEthernet1/0/23      GigabitEthernet1/0/28
       4       GigabitEthernet1/0/24      GigabitEthernet1/0/26
display port-group
display port-group group-id
View
group-id: Number of port group, in the range of 1 to 100.
Use the display port-group command to display information for a specified port group .
# Display information for the port group 1.
<device> display port-group 1
Port Group 1:
  Interface list: GigabitEthernet1/0/2-5
The above information indicates that port group 1 includes 4 ports: GigabitEthernet 1/0/2 through GigabitEthernet 1/0/5.
display unit
display unit unit-id interface
View
unit-id: Unit ID. For WX3000 series devices, this value can only be 1.
Use the display unit command to display information about the ports on a specified unit.
# Display information about the ports on unit 1.
<device> display unit 1 interface
Aux1/0/0
Description :  Aux Interface
 IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e20f-5111
 Port hardware type is 1000_BASE_T
 Broadcast MAX-ratio: 100%
 PVID: 1
 Mdi type: auto
 It belongs to a link-aggregation. It is the master port
 Input(total):  - packets, - bytes
 Input(normal):  22 packets, 1497 bytes
          1 broadcasts, 21 multicasts, - pauses
          0 frame,  0 overruns, 0 aborts, - ignored, - parity errors
 Output(total): - packets, - bytes
 Output(normal): 22 packets, 1497 bytes
          1 broadcasts, 21 multicasts, 0 pauses
          - lost carrier, - no carrier
(The following displayed information is omitted. For the description on the output, refer to Table 1-2.)
duplex
duplex { auto | full | half }
undo duplex
View
Ethernet port view
auto: Auto-negotiation mode
full: Full duplex mode
half: Half duplex mode
Use the duplex command to set port duplex attribute.
Use the undo duplex command to restore the default duplex mode (auto).
By default, a port is in auto duplex mode.
Related commands: speed.
# Set GigabitEthernet 1/0/1 in auto duplex mode.
[device-GigabitEthernet1/0/1] duplex auto
enable log updown
enable log updown
undo enable log updown
View
Ethernet port view
None
Use the enable log updown command to enable the port to output Up/Down log information.
Use the undo log enable updown command to disable the port from outputting Up/Down log information.
By default, a port is allowed to output Up/Down log information.
# By default, port GigabitEthernet 1/0/1 is allowed to output the Up/Down log information. Execute the shutdown command or the undo shutdown command on GigabitEthernet 1/0/1, and the system outputs Up/Down log information of GigabitEthernet 1/0/1.
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] shutdown
%Apr  2 08:11:14:220 2000 device L2INF/5/PORT LINK STATUS CHANGE:- 1 -
 GigabitEthernet1/0/1 is DOWN
[device-GigabitEthernet1/0/1] undo shutdown
%Apr  2 08:11:32:253 2000 device L2INF/5/PORT LINK STATUS CHANGE:- 1 -
 GigabitEthernet1/0/1 is UP
# Disable GigabitEthernet 1/0/1 from outputting Up/Down log information, execute the shutdown command or the undo shutdown command on GigabitEthernet 1/0/1, and no Up/Down log information is output for GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] undo enable log updown
flow-control
flow-control
undo flow-control
View
Ethernet port view
None
Use the flow-control command to enable port flow control, to avoid packet loss in the event of network congestion.
Use the undo flow-control command to disable flow control on the port.
By default, port flow control is disabled.
# Enable flow control on GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] flow-control
flow interval
flow-interval interval
undo flow-interval
View
Ethernet port view
Interval: Interval (in seconds) to perform statistics on port information. This argument ranges from 5 to 300 (in step of 5) and is 300 by default.
Use the flow-interval command to set the interval to perform statistics on port information.
Use the undo flow-interval command to restore the default interval.
By default, this interval is 300 seconds.
When you use the display interface interface-type interface-number command to display the information of a port, the system performs statistical analysis on the traffic flow passing through the port during the specified interval and displays the average rates in the interval. For example, if you set the interval to 100 seconds, the displayed information is as follows:
Last 100 seconds input:  0 packets/sec 0 bytes/sec
Last 100 seconds output:  0 packets/sec 0 bytes/sec
# Set the interval to perform statistics on GigabitEthernet 1/0/1 to 100 seconds.
[device-GigabitEthernet1/0/1] flow-interval 100
interface
View
interface-type: Port type, it can be Aux, GigabitEthernet, LoopBack, NULL or Vlan-interface.
interface-number: Port number. For a GigabitEthernet port, it is in the format of slot number/subslot number/port number.
l          The slot number is fixed to 1;
l          The subslot number is 0 if the port is a GigabitEthernet port;
l          The port number is relevant to the device.
Use the interface command to enter Ethernet port view. To configure parameters for a port, you must enter the port view first.
# Enter GigabitEthernet1/0/1 port view.
jumboframe enable
jumboframe enable
undo jumboframe enable
View
Ethernet port view
None
Use the jumboframe enable command to allow jumbo frames that are not larger than 4096 bytes to pass through the current Ethernet port.
Use the undo jumboframe enable command to allow frames that are not larger than 1536 bytes to pass through the current Ethernet port.
By default, frames that are not larger than 4096 bytes are allowed to pass through the Ethernet port.
# Allow frames that are not larger than 1536 bytes to pass through GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] undo jumboframe enable
loopback
View
Ethernet port view
external: Performs external loop test. In the external loop test, self-loop headers (which are made from four cores of the 8-core cables) must be used on the port of the device. The external loop test can locate the hardware failures on the port.
internal: Performs internal loop test. In the internal loop test, self loop is established in the switching chip to locate the chip failure which is related to the port.
Use the loopback command to perform a loopback test on the current Ethernet port to check whether the Ethernet port works normally. The loopback test terminates automatically after running for a specific period.
By default, no loopback test is performed on the Ethernet port.
# Perform an internal loop test on GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] loopback internal
 Loopback internal succeeded.
loopback-detection control enable
undo loopback-detection control enable
View
Ethernet port view
None
Use the loopback-detection control enable command to enable loopback port control on the trunk or hybrid port.
Use the undo loopback-detection control enable command to disable loopback port control.
l          When the loopback port control function is enabled on the trunk or hybrid port and loopback is found on the port, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
l          When the loopback port control function is disabled, the system sends a Trap message to the client if a loopback port is found. The port still operates normally.
By default, the loopback port control function is disabled on the trunk or hybrid port.
This command is invalid for the access port, since the loopback port control function is always enabled on the access port.
# Enable loopback port control on trunk port GigabitEthernet1/0/1.
[device] loopback-detection enable
[device-GigabitEthernet1/0/1] loopback-detection enable
[device-GigabitEthernet1/0/1] loopback-detection control enable
undo loopback-detection enable
View
System view, Ethernet port view
None
Use the loopback-detection enable command to enable loopback detection globally or on a specified port.
Use the undo loopback-detection enable command to disable loopback detection globally or on a specified port.
l          To enable loopback detection on a specific port, you must use the loopback-detection enable command in both system view and the specified port view.
l          After you use the undo loopback-detection enable command in system view, loopback detection will be disabled on all ports.
l          If loopback is found on an access port, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
l          If loopback is found on a trunk or hybrid port, the system sends a Trap message to the client. When the loopback port control function is enabled on these ports, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
By default, loopback port control is disabled.
Related commands: loopback-detection control enable.
# Enable loopback detection on GigabitEthernet 1/0/1.
loopback-detection interval-time
loopback-detection interval-time time
undo loopback-detection interval-time
View
time: Time interval for loopback detection, in the range of 5 to 300 (seconds). It defaults to 30 seconds.
Use the loopback-detection interval-time command to set time interval for loopback detection.
Use the undo loopback-detection interval-time command to restore the default time interval.
Related commands: display loopback-detection.
# Set time interval for loopback detection to 10 seconds.
[device] loopback-detection interval-time 10
loopback-detection per-vlan enable
undo loopback-detection per-vlan enable
View
Ethernet port view
None
Use the loopback-detection per-vlan enable command to configure the system to run loopback detection on all VLANs for the trunk and hybrid ports.
Use the undo loopback-detection per-vlan enable command to restore the default setting.
By default, the system runs loopback detection only on the default VLAN for the trunk and hybrid ports.
This command is invalid for the access port.
# Configure the system to run loopback detection on all VLANs for trunk port GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] loopback-detection per-vlan enable
mdi
mdi { across | auto | normal }
undo mdi
View
Ethernet port view
across: Sets the port to support MDIX.
auto: Sets the port to support auto-MDI/MDIX.
normal: Sets the port to support MDI.
Use the mdi command to set port MDI attribute.
Use the undo mdi command to restore the default setting.
By default, the port MDI attribute is auto.
The mdi and undo mdi commands cannot be configured on the combo ports.
# Set the port to support auto-MDI/MDIX.
[device] interface GigiabitEthernet1/0/1
[device-GigabitEthernet1/0/1] mdi auto
port
port interface-list
undo port interface-list
View
Port group view
interface-list: Ethernet interface list, in the format of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges.
Use the port command to add Ethernet interface(s) to a specified port group.
Use the undo port command to remove specified Ethernet interface(s) from a port group.
By default, a port group is empty, that is, there is no Ethernet interface in it.
You cannot add a member port in an aggregate group to a port group. The opposite is also true.
# Add GigabitEthernet 1/0/2 through GigabitEthernet1/0/5 to port group 1.
[device] port-group 1
[device-port-group-1] port GigabitEthernet 1/0/2 to GigabitEthernet 1/0/5
port-group
port-group
undo port-group
View
Use the port-group command to create a port group or enter the specified port group view.
Use the undo port-group command to remove a port group.
By default, no port group is configured.
# Create port group 1.
port access vlan
port access vlan vlan-id
undo port access vlan
View
Ethernet port view
vlan-id: VLAN ID, in the range of 1 to 4094.
Use the port access vlan command to add the access port into the specified VLAN.
Use the undo port access vlan command to remove the access port from the specified VLAN.
You must specify the ID of an existing VLAN in the command.
# Add port GigabitEthernet 1/0/1 into VLAN 3.
[device] vlan 3
[device-vlan3] quit
[device-GigabitEthernet1/0/1] port access vlan 3
port hybrid pvid vlan
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Ethernet port view
vlan-id: VLAN ID, in the range of 1 to 4094. It defaults to 1.
Use the port hybrid pvid vlan command to set the default VLAN ID for the hybrid port.
Use the undo port hybrid pvid command to restore the default setting.
To guarantee the proper packet transmission, the default VLAN ID of the local hybrid port should be identical with that of the hybrid port on the peer device.
Related commands: port link-type.
# Set the default VLAN ID for hybrid port GigabitEthernet1/0/1 to 100.
[device-GigabitEthernet1/0/1] port hybrid pvid vlan 100
port hybrid vlan
undo port hybrid vlan vlan-id-list
View
Ethernet port view
vlan-id-list: vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, VLAN range to which the hybrid ports are added. vlan-id is in the range of 1 to 4094 and can be discrete. &<1-10> means you can enter the parameter for ten times at most.
tagged: The packets of the specified VLAN will be assigned with tags.
untagged: The packets of the specified VLAN will not be assigned with tags.
Use the port hybrid vlan command to add the hybrid port into the specified VLAN.
Use the undo port hybrid vlan command to remove the hybrid port from the specified VLAN.
A hybrid port can belong to multiple VLANs. When you use the command several times, all VLAN specified in the commands will be allowed to pass the port.
# Add hybrid port GigabitEthernet 1/0/1 to VLAN 2, VLAN 5 and VLAN 50 through VLAN 100, with tags assigned to their packets.
[device-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
undo port link-type
View
Ethernet port view
access: Specifies the link type as access.
hybrid: Specifies the link type as hybrid.
trunk: Specifies the link type as trunk.
Use the port link-type command to set link type for the Ethernet port.
Use the undo port link-type command to restore the default link type, that is, access.
You can configure all the three port types on a device. However, note that you cannot directly change a trunk port to a hybrid port or a hybrid port to a trunk port. To do that, you need to set the link type of the trunk or hybrid port to access first.
By default, the link type for all ports is access.
# Set the link type of GigabitEthernet 1/0/1 to trunk.
[device-GigabitEthernet1/0/1] port link-type trunk
port trunk permit vlan
undo port trunk permit vlan { vlan-id-list | all }
View
Ethernet port view
vlan-id-list: vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, VLAN range to which the trunk ports are added. vlan-id is in the range of 1 to 4094 and can be discrete. &<1-10> means you can enter the parameter for ten times at most.
all: Adds the trunk port into all VLANs.
Use the port trunk permit vlan command to add the trunk port into the specified VLAN.
Use the undo port trunk permit vlan command to remove the hybrid port from the specified VLAN.
A trunk port can belong to multiple VLANs. When you use the command several times, all VLAN specified in the commands will be allowed to pass the port.
# Add trunk port GigabitEthernet 1/0/1 to VLAN 2, VLAN 5 and VLAN 50 through VLAN 100.
[device-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
Please wait...
Done.
port trunk pvid vlan
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Ethernet port view
Use the port trunk pvid vlan command to set the default VLAN ID for the trunk port.
Use the undo port trunk pvid command to restore the default setting.
To guarantee the proper packet transmission, the default VLAN ID of the local trunk port should be identical with that of the trunk port on the peer device.
# Set the default VLAN ID for trunk port GigabitEthernet 1/0/1 to 100.
[device-GigabitEthernet1/0/1] port trunk pvid vlan 100
reset counters interface
reset counters interface [ interface-type | interface-type interface-number ]
View
For details about the parameters, see the description part of the interface command.
Use the reset counters interface command to clear the statistics of the port, preparing for a new statistics collection.
l          If you specify neither port type nor port number, the command clears statistics of all ports.
l          If specify only port type, the command clears statistics of all ports of this type.
l          If specify both port type and port number, the command clears statistics of the specified port.
# Clear the statistics of port GigabitEthernet 1/0/1.
<device> reset counters interface GigabiEthernet1/0/1
shutdown
shutdown
View
Ethernet port view
None
Use the shutdown command to disable an Ethernet port.
Use the undo shutdown command to enable an Ethernet port.
By default, an Ethernet port is enabled.
# Disable then enable port GigabitEthernet 1/0/1.
speed
speed { 10 | 100 | 1000 | auto }
undo speed
View
Ethernet port view
10: 10 Mbps port rate.
100: 100 Mbps port rate.
1000: 1000 Mbps port rate.
auto: Auto-negotiation rate mode.
Use the speed command to set port rate.
Use the undo speed command to restore default setting.
By default, the port is in auto-negotiation rate mode.
Related commands: duplex.
The speed and undo speed commands cannot be configured on a combo port.
# Set the rate of port GigabitEthernet 1/0/1 to 100 Mbps.
[device-GigabitEthernet1/0/1] speed 100
speed auto
speed auto [ 10 | 100 | 1000 ]*
View
Ethernet port view
10: Configures 10 Mbps as an auto-negotiation speed of the port.
100: Configures 100 Mbps as an auto-negotiation speed of the port.
1000: Configures 1000 Mbps as an auto-negotiation speed of the port.
Use the speed auto [ 10 | 100 | 1000 ]* command to configure auto-negotiation speed(s) for the current port.
By default, the port speed is auto-negotiated.
The last configuration will take effect if you configure the command for multiple times.
# Configure 10 Mbps and 1000 Mbps as the auto-negotiation speeds of GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] speed auto 10 1000
virtual-cable-test
virtual-cable-test
View
Ethernet port view
None
Use the virtual-cable-test command to enable the system to test the cable connected to a specific port and to display the results. The system can test these attributes of the cable:
l          Cable status, including normal, abnormal, abnormal-open, abnormal-short and failure
l          Cable length
l          If the cable is in normal state, the displayed length value is the total length of the cable.
l          If the cable is in any other state, the displayed length value is the length from the port to the faulty point.
The testing functions that are available on the WX3000 series devices vary with port state as follows:
l          For ports that are Down, the cable status testing and cable length testing are available.
l          For ports that are Up, the cable status testing, cable length testing, and Pair skew testing are available.
l          Pair impedance mismatch
l          Pair skew
l          Pair swap
l          Pair polarity
l          Insertion loss
l          Return loss
l          Near-end crosstalk
By default, the system does not test the cable connected to the Ethernet port.
l          Optical port (including Combo optical port) does not support VCT (virtual-cable-test) function.
l          Combo electrical port supports VCT function only when it is in UP condition (using undo shutdown command), normal Ethernet electrical port always supports this function.
l          A hyphen (-) indicates that the corresponding test item is not supported.
# Enable the system to test the cable connected.
[device-GigabitEthernet0/1] virtual-cable-test
Cable status: normal, 6 metres
Pair Impedance mismatch: -
Pair skew: 8 ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
