H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
10-Port Isolation Command
10-Port Isolation Command 16.79 KB
Port Isolation Configuration Commands
display isolate port
View
None
Use the display isolate port command to display the information about the Ethernet ports added to an isolation group.
# Display the information about the Ethernet ports added to the isolation group.
<device> display isolate port
 Isolated port(s) on UNIT 1:
 GigabitEthernet1/0/2, GigabitEthernet1/0/3, GigabitEthernet1/0/4
port isolate
port isolate
undo port isolate
View
Ethernet port view
None
Use the port isolate command to add an Ethernet port to the isolation group.
Use the undo port isolate command to remove an Ethernet port from the isolation group.
By default, an isolation group contains no port.
# Add GigabitEthernet 1/0/1 to the isolation group.
<device> system-view
[device] interface GigabitEthernet1/0/1
[device-GigabitEthernet1/0/1] port isolate
 All aggregated ports in same unit will join isolated group together
# Remove GigabitEthernet 1/0/1 from the isolation group.
[device-GigabitEthernet1/0/1] undo port isolate
 All aggregated ports in same unit will leave isolated group together
