H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
36-PoE-PoE Profile Command
36-PoE-PoE Profile Command 64.45 KB
PoE Configuration Commands
display poe interface
display poe interface [ interface-type interface-number ]
View
interface-type interface-number: Port type and port number.
Use the display poe interface command to view the PoE status of a specific port or all ports of the device.
l          If the interface-type interface-number argument is specified, the command displays the PoE status of the specified port of the device.
l          If the interface-type interface-number argument is not specified, the command displays the PoE status of all ports of the device.
# Display the PoE status of GigabitEthernet 1/0/10.
<device> display poe interface GigabitEthernet1/0/10
Port power enabled           :enable
Port power ON/OFF            :on
Port power status            :Standard PD was detected
Port power mode              :signal
Port PD class                :0
port power priority          :low
Port max power               :25000 mW
Port current power           :460 mW
Port peak power              :552 mW
Port average power           :547 mW
Port current                 :10 mA
Port voltage                 :51 V
Table 1-1 display poe interface command output description
Port power enabled
PoE is enabled on the port
Port power ON/OFF
The power on the port is on/off
Port power status
PoE status on the port:
l      user command set port to off: PoE to the port is turned off by the user
l      Standard PD was detected: A standard PD is detected
l      Legacy PD was detected: A non-standard PD is detected
l      detection is in process: PDs are being detected
Port power mode
PoE mode on the port:
signal: PoE through the signal cable
Port PD class
Class of power to the PD
Port power priority
PoE priority of the port:
l      critical: The highest
l      high: High
l      low: Low
Port max power
The maximum available power on the port
Port current power
The current power on the port
Port average power
The average power on the port
Port peak power
The peak power on the port
Port current
The current on the port
Port voltage
The voltage on the port
# Display the PoE status of all ports.
       PORT INDEX      POWER ENABLE   MODE  PRIORITY       STATUS
 GigabitEthernet1/0/1   off  disable signal  low      user command set port to off
 GigabitEthernet1/0/2   off  disable signal  low      user command set port to off
 GigabitEthernet1/0/3   off  disable signal  low      user command set port to off
 GigabitEthernet1/0/4   off  disable signal  low      user command set port to off
 GigabitEthernet1/0/5   off  disable signal  low      user command set port to off
 GigabitEthernet1/0/6   off  disable signal  low      user command set port to off
<Omitted>
Table 1-2 display poe interface command output description
PORT INDEX
Port index
POWER
Power status on the port: ON/OFF
ENABLE
PoE enabled/disabled status on the port
MODE
l      signal: PoE through the signal cable
l      spare: PoE through the spare cable
PRIORITY
l      critical: Highest
l      high: High
l      low: Low
STATUS
l      PD detection is in process: PDs are being detected
display poe interface power
display poe interface power [ interface-type interface-number ]
View
Use the display poe interface power command to view the power information of a specific port of the device. If the interface-type interface-number argument is not specified, the command displays the power information of all ports of the device.
# Display the power information of GigabitEthernet 1/0/10.
<device> display poe interface power GigabitEthernet1/0/10
Port power                   :12400 mW
# Display the power information of all ports.
       PORT INDEX       POWER (mW)                PORT INDEX      POWER (mW)
 GigabitEthernet1/0/1    0                  GigabitEthernet1/0/2    0
 GigabitEthernet1/0/3    0                  GigabitEthernet1/0/4    0
 GigabitEthernet1/0/5    0                  GigabitEthernet1/0/6    0
 GigabitEthernet1/0/7    0                  GigabitEthernet1/0/8    0
 GigabitEthernet1/0/9    0                  GigabitEthernet1/0/10   12400
<Omitted>
display poe powersupply
View
None
Use the display poe powersupply command to view the parameters of the power sourcing equipment (PSE).
# Display the PSE parameters.
<device> display poe powersupply
Unit 1
PSE ID                      :0
PSE Legacy Detection        :disable
PSE Total Power Consumption :0 mW
PSE Available Power         :128000 mW
PSE Peak Value              :0 mW
PSE Average Value           :0 mW
PSE Software Version        :501
PSE Hardware Version        :000
PSE CPLD Version            :001
PSE Power-Management mode   :auto
Table 1-3 display poe powersupply command output description
PSE ID
Identification of the PSE
The enabled/disabled status of the nonstandard PD detection
Total power consumption of the PSE
PSE Available Power
Available power of the PSE
Power Peak Value
Peak power value of the PSE
Power Average Value
Average power value of the PSE
Power Software Version
Version of the PSE software
Power Hardware Version
Version of the PSE hardware
PSE CPLD Version
Version of the PSE complex programmable logical device (CPLD)
PoE management mode on the port when the PSE is overloaded:
The auto keyword indicates that the auto mode is adopted, that is, the PoE management mode based on the PoE priority of the port is adopted
The manual keyword indicates that the manual mode is adopted in the PoE management on the port
poe enable
poe enable
undo poe enable
View
Ethernet port view
None
Use the poe enable command to enable the PoE feature on a port.
Use the undo poe enable command to disable the PoE feature on a port.
By default, the PoE feature on a port is enabled by the default configuration file when the device is delivered.
If you delete the default configuration file without specifying another one, the PoE function on a port will be disabled after you restart the device.
# Enable the PoE feature on GigabitEthernet 1/0/3.
<device> system-view
[device] interface GigabitEthernet 1/0/3
[device-GigabitEthernet1/0/3] poe enable
poe legacy enable
poe legacy enable
undo poe legacy enable
View
None
Use the poe legacy enable command to enable the PD compatibility detection function.
Use the undo poe legacy enable command to disable the PD compatibility detection function.
PDs compliant with 802.3af standards are called standard PDs.
By default, the PD compatibility detection function is disabled.
# Enable the PD compatibility detection function.
[device] poe legacy enable
Legacy detection is enabled
poe max-power
poe max-power max-power
undo poe max-power
View
Ethernet port view
max-power: Maximum power distributed to the port, ranging from 1,000 to 25,000, in mW.
Use the poe max-power command to configure the maximum power that can be supplied by the current port.
Use the undo poe max-power command to restore the maximum power supplied by the current port to the default value.
By default, the maximum power that a port can supply is 25,000 mW.
Note that the unit of the power is mW and you can set the power in the granularity of 1 mW. The actual maximum power will be 5% larger than what you have set allowing for the effect of transient peak power.
# Set the maximum power supplied by GigabitEthernet 1/0/3 to 15,000 mW.
[device-GigabitEthernet1/0/3] poe max-power 15000
poe mode
poe mode { signal | spare }
undo poe mode
View
Ethernet port view
signal: Supplies power through a signal cable.
spare: Supplies power through a spare cable.
Use the poe mode command to configure the PoE mode on the current port.
Use the undo poe mode command to restore the PoE mode on the current port to the default mode.
By default, signal mode is adopted on a port.
Note that the device does not support the spare mode currently.
# Set the PoE mode on GigabitEthernet 1/0/3 to signal.
[device-GigabitEthernet1/0/3] poe mode signal
poe power-management
poe power-management { auto | manual }
undo poe power-management
View
auto: Adopts the auto mode, namely, a PoE management mode based on PoE priority of the port.
manual: Adopts the manual mode.
Use the poe power-management command to configure the PoE management mode of port used in the case of power overloading.
Use the undo poe power-management command to restore the default mode.
By default, the PoE management mode on port is auto.
# Configure the PoE management mode on a port to auto, that is, adopt the PoE management mode based on the PoE priority of the port.
[device] poe power-management auto
Auto Power Management is enabled
poe priority
poe priority { critical | high | low }
undo poe priority
View
Ethernet port view
critical: Sets the port priority to critical.
high: Sets the port priority to high.
low: Sets the port priority to low.
Use the poe priority command to configure the PoE priority of a port.
Use the undo poe priority command to restore the default PoE priority.
By default, the PoE priority of a port is low.
When the available power of the PSE is too small, the PoE priority and the PoE management mode are used together to determine how to allocate PoE power for the new PDs.
1)        When the manual PoE management mode is adopted:
The device will not supply power to the new PDs if the available power of the PSE is less than 28 W.
2)        When the auto PoE management mode is adopted:
l          If a PD is plugged into the port with higher priority when the available power of the PSE is less than 28 W, the power supply to the port with the biggest number in the port group with the lowest priority is turned off, so that a part of power is released for the new PD.
l          If the available power of the whole device is less than 28 W and there is no port with low priority, the port with the inserted PD cannot supply power.
# Set the PoE priority of GigabitEthernet 1/0/3 to critical.
[device-GigabitEthernet1/0/3] poe priority critical
poe update
poe update { refresh | full } filename
View
refresh: The refresh update mode is used when the PSE processing software is available. The refresh update mode is to upgrade the original processing software in the PSE.
full: The full update mode is used when the PSE processing software is damaged. The full update mode is to delete the original damaged software in the PSE completely and then reload the PoE processing software.
filename: Update file name, with a length of 1 to 64 characters and with the extension .s19.
Use the poe update command to update the PSE processing software online.
l          Use the full mode only when the refresh mode fails. In normal cases, use the refresh mode.
l          When the PSE processing software is damaged (that is, all the PoE commands cannot be successfully executed), you can use the full mode to update and restore the software.
l          When the online upgrading procedure is interrupted for some unexpected reason, for example, the device is restarted due to some errors. If the upgrade in full mode fails after restart, you must upgrade in full mode after power-off and restart of the device, and then restart the device manually. In this way, the former PoE configuration is restored.
# Update the PSE processing software online.
[device] poe update refresh 0400_001.S19
Update PoE  board successfully
PoE Profile Configuration Commands
apply poe-profile
In system view use the following commands:
apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
undo apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
In Ethernet port view use the following commands:
View
System view, Ethernet port view
profile-name: Name of a PoE profile, a string of 1 to 15 characters. It starts with a letter from a to z or from A to Z, and it cannot be any of reserved keywords like all, interface, user, undo, and mode.
Use the apply poe-profile command to apply the existing PoE profile configuration to the specified Ethernet port.
Use the undo apply poe-profile command to cancel the PoE profile configuration for the specified Ethernet port.
Only one PoE profile can be in use at any time for each Ethernet port.
PoE profile is a set of PoE configurations. One PoE profile can contain multiple PoE features. When the apply poe-profile command is used to apply a PoE profile to a port, some PoE features can be applied successfully while some cannot. PoE profiles are applied to the devices according to the following rules:
l          When the apply poe-profile command is used to apply a PoE profile to a port, the PoE profile is applied successfully only if one PoE feature in the PoE profile is applied properly. When the display current-configuration command is used for query, it is displayed that the PoE profile is applied properly to the port.
l          If one or more features in the PoE profile are not applied properly on a port, the device will prompt explicitly which PoE features in the PoE profile are not applied properly on which ports.
l          The display current-configuration command can be used to query which PoE profile is applied to a port. However, the command cannot be used to query which PoE features in a PoE profile are applied successfully.
# Apply the existing PoE profile (profile-test) configuration to GigabitEthernet1/0/1 through GigabitEthernet1/0/9 ports of the device.
[device] apply poe-profile profile-test interface GigabitEthernet1/0/1 to GigabitEthernet1/0/9
display poe-profile
display poe-profile { all-profile | interface interface-type interface-number | name profile-name }
View
all-profile: Displays all PoE profiles.
profile-name: Name of a specified PoE profile.
Use the display poe-profile command to display detailed configuration information of the created PoE profile for the device.
# Display detailed configuration information for the PoE profile by the name of profile-test.
[device] display poe-profile name profile-test
Poe-profile: profile-test, 3 action
poe enable
poe max-power 5000
poe-profile
undo poe-profile profile-name
View
profile-name: Name of PoE profile, a string with 1 to 15 characters. It starts with a letter from a to z or from A to Z, and it cannot be any of reserved keywords like all, interface, user, undo, and mode.
Use the poe-profile command to create a PoE profile and then enter PoE profile view. If the PoE profile is already created, you will enter PoE profile view directly.
Use the undo poe-profile command to delete an existing PoE profile.
The following PoE features can be configured in the PoE profile mode:
poe enable
The maximum number of PoE profiles that can be configured for the device is 100.
# Create a PoE profile by the name of profile-test.
[device] poe-profile profile-test
