H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
23-ARP Command
23-ARP Command 51.95 KB
ARP Configuration Commands
arp check enable
arp check enable
undo arp check enable
View
None
Use the arp check enable command to enable the ARP entry checking function on a device.
Use the undo arp check enable command to disable the ARP entry checking function.
With the ARP entry checking function enabled, the device cannot learn any ARP entry with a multicast MAC address. Configuring such a static ARP entry is not allowed either; otherwise, the system prompts error information.
After the ARP entry checking function is disabled, the device can learn the ARP entry with a multicast MAC address, and you can also configure such a static ARP entry on the device.
By default, the ARP entry checking function is enabled.
# Disable the ARP entry checking function.
<device> system-view
[device] undo arp check enable
arp detection enable
undo arp detection enable
View
VLAN view
None
Use the arp detection enable command to enable the ARP attack detection function on all ports in the specified VLAN. When receiving an ARP packet from a port in this VLAN, the device will check the source IP address, source MAC address, number of the receiving port, and the VLAN of the port. If the mapping of the source IP address and source MAC address is not included in the DHCP snooping entries or IP static binding entries, or the number of the receiving port and the VLAN of the port do not match the DHCP snooping entries or IP static binding entries, the ARP packet will be discarded.
Use the undo arp detection enable command to disable the ARP attack detection function on all ports in the specified VLAN.
By default, ARP attack detection is disabled on the device.
# Enable ARP attack detection on all ports in VLAN 1.
[device] vlan 1
[device-vlan1] arp detection enable
arp detection trust
arp detection trust
undo arp detection trust
View
Ethernet port view
None
Use the arp detection trust command to specify the current port as a trusted port, that is, ARP packets received on this port are regarded as legal ARP packets and will not be checked.
Use the undo arp detection trust command to specify the current port as an untrusted port in ARP detection.
By default, a port is an untrusted port in ARP detection.
# Specify GigabitEthernet 1/0/11 as the trusted port in ARP detection.
[device] interface gigabitethernet 1/0/11
[device-GigabitEthernet1/0/11] arp detection trust
undo arp restricted-forwarding enable
View
VLAN view
None
Use the arp restricted-forwarding enable command to enable ARP restricted forwarding so that the legal ARP requests received from the specified VLAN are forwarded through configured trusted ports only, and the legal ARP responses are forwarded according to the MAC addresses in the packets, or through trusted ports if the MAC address table contains no such destination MAC addresses.
Use the undo arp restricted-forwarding enable command to disable ARP restricted forwarding.
By default, ARP restricted forwarding is disabled. The device forwards legal ARP packets through all its ports.
Related commands: arp detection enable, arp detection trust
# Enable ARP restricted forwarding in VLAN 1.
[device] vlan 1
[device-vlan1] arp restricted-forwarding enable
arp static
arp static ip-address mac-address [ vlan-id interface-type interface-number ]
arp static ip-address mac-address vlan-id (in Ethernet port view)
undo arp ip-address
View
System view/Ethernet port view
ip-address: IP address contained in the ARP mapping entry to be created/removed.
mac-address: MAC address contained in the ARP mapping entry to be created, in the format of H-H-H.
vlan-id: ID of the VLAN to which the static ARP entry belongs, in the range of 1 to 4,094.
interface-type: Type of the port to which the static ARP entry belongs.
interface-number: Number of the port to which the static ARP entry belongs.
Use the arp static command to create a static ARP entry.
Use the undo arp command to remove an ARP entry.
By default, the system ARP mapping table is empty and the address mapping entries are obtained by ARP dynamically.
Note that:
l          Static ARP entries are valid as long as the device operates normally. But some operations, such as removing a VLAN, or removing a port from a VLAN, will make the corresponding ARP entries invalid and therefore removed automatically.
l          As for the arp static command, the value of the vlan-id argument must be the ID of an existing VLAN, and the port identified by the interface-type and interface-number arguments must belong to the VLAN.
l          Currently, static ARP entries cannot be configured on the ports of an aggregation group.
Related commands: reset arp, display arp.
# Create a static ARP mapping entry, with the IP address of 202.38.10.2, the MAC address of 000f-e20f-0000. The ARP mapping entry belongs to GigabitEthernet 1/0/1 which belongs to VLAN 1.
[device] arp static 202.38.10.2 000f-e20f-0000 1 gigabitethernet 1/0/1
arp timer aging
arp timer aging aging-time
undo arp timer aging
View
aging-time: Aging time (in minutes) of the dynamic ARP entries. This argument ranges from 1 to 1,440.
Use the arp timer aging command to configure the aging time for dynamic ARP entries.
Use the undo arp timer aging command to restore the default.
By default, the aging time for dynamic ARP entries is 20 minutes.
Related commands: display arp timer aging.
# Configure the aging time to be 10 minutes for dynamic ARP entries.
[device] arp timer aging 10
display arp
display arp [ dynamic | static | ip-address ]
View
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
ip-address: IP address. ARP entries containing the IP address are to be displayed.
Use the display arp command to display specific ARP mapping entries.
If you execute this command with no keyword/argument specified, all the ARP entries are displayed.
Related commands: arp static, reset arp.
# Display all the ARP entries.
<device> display arp
            Type: S-Static   D-Dynamic
IP Address       MAC Address     VLAN ID  Port Name / AL ID      Aging Type
10.2.72.162      000a-000a-0aaa  N/A      N/A                    N/A   S
192.168.0.77     0000-e8f5-6a4a  1        GigabitEthernet1/0/2        13    D
192.168.0.2      000d-88f8-4e88  1        GigabitEthernet1/0/2        14    D
192.168.0.200    0014-222c-9d6a  1        GigabitEthernet1/0/2        14    D
192.168.0.45     000d-88f6-44c1  1        GigabitEthernet1/0/2        15    D
192.168.0.110    0011-4301-991e  1        GigabitEthernet1/0/2        15    D
192.168.0.32     0000-e8f5-73ee  1        GigabitEthernet1/0/2        16    D
192.168.0.3      0014-222c-aa69  1        GigabitEthernet1/0/2        16    D
192.168.0.17     000d-88f6-379c  1        GigabitEthernet1/0/2        17    D
192.168.0.115    000d-88f7-9f7d  1        GigabitEthernet1/0/2        18    D
192.168.0.43     000c-760a-172d  1        GigabitEthernet1/0/2        18    D
192.168.0.33     000d-88f6-44ba  1        GigabitEthernet1/0/2        20    D
192.168.0.35     000f-e20f-2181  1        GigabitEthernet1/0/2        20    D
192.168.0.5      000f-3d80-2b38  1        GigabitEthernet1/0/2        20    D
---   14 entries found   ---
Table 1-1 display arp command output description
IP Address
IP address contained in an ARP entry
MAC Address
MAC address contained in an ARP entry
VLAN ID
ID of the VLAN which an ARP entry corresponds to
Port Name / AL ID
Name of the port which an ARP entry corresponds to
Aging
Aging time (in minutes) of a dynamic ARP entry
Type of an ARP entry
display arp |
display arp [ dynamic | static] | { begin | exclude | include } text
View
|: Specifies the ARP entries to be displayed using regular expression.
begin: Displays the ARP entries from the first ARP entry that contains the specified string given by the text argument.
exclude: Displays the ARP entries that do not contain the specified string given by the text argument.
include: Displays the ARP entries that contain the specified string given by the text argument.
text: String used to filter ARP entries.
Use the display arp | command to display the ARP entries related to string in a specified way.
# Display all the ARP entries that contain the string “77”.
<device> display arp | include 77
192.168.0.77     0000-e8f5-6a4a  1        GigabitEthernet1/0/2        12    D
---   1 entry found   ---
# Display all the ARP entries that do not contain the string “68”.
<device> display arp | exclude 68
Refer to Table 1-1 for the description on the above output information.
display arp count
display arp count [ [ dynamic | static ] [ | { begin | exclude | include } text ] | ip-address ]
View
dynamic: Counts the dynamic ARP entries.
static: Counts the static ARP entries.
|: Specifies the ARP entries to be counted using regular expression.
begin: Counts the ARP entries from the first ARP entry that contains the string given by the text argument.
exclude: Counts the ARP entries that do not contain the string given by the text argument.
include: Counts the ARP entries that contain the string given by the text argument.
ip-address: IP address. The ARP entries containing the IP address are to be displayed.
Use the display arp count command to display the number of the specified ARP entries. If no parameter is specified, the total number of ARP entries is displayed.
# Display the total number of ARP entries.
<device> display arp count
 14 entries found
display arp detection statistics interface
display arp detection statistics interface interface-type interface-number
View
interface-type interface-number: Type and number of a port.
Use the display arp detection statistics interface command to display the statistics about untrusted ARP packets dropped by the specified port.
# Display the statistics about untrusted ARP packets dropped by GigabitEthernet 1/0/10 on the device.
[device] display arp detection statistics interface gigabitethernet 1/0/10
 ARP DETECTION : ENABLE
 ARP PORT TRUST : DISABLE
 INVALID ARP PACKETS  : 31
Table 1-2 display arp detection statistics interface command output description
ARP DETECTION
ARP attack detection state: enabled/disabled
ARP PORT TRUST
ARP trusted port function: enabled/disabled
INVALID ARP PACKETS
Number of untrusted ARP packets
View
None
Use the display arp timer aging command to display the setting of the ARP aging time.
Related commands: arp timer aging.
# Display the setting of the ARP aging time.
<device> display arp timer aging
Current ARP aging time is 20 minute(s)(default)
The displayed information shows that the ARP aging time is set to 20 minutes.
gratuitous-arp-learning enable
undo gratuitous-arp-learning enable
View
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the gratuitous ARP packet learning function.
By default, the gratuitous ARP packet learning function is enabled.
# Enable the gratuitous ARP packet learning function on a device.
[device] gratuitous-arp-learning enable
reset arp
reset arp [ dynamic | static | interface interface-type interface-number ]
View
dynamic: Clears dynamic ARP entries.
static: Clears static ARP entries.
interface-type: Port type.
interface-number: Port number.
Use the reset arp command to clear specific ARP entries.
Related commands: arp static, display arp.
# Clear static ARP entries.
<device> reset arp static
