H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
29-FTP-SFTP-TFTP Command
29-FTP-SFTP-TFTP Command 172.8 KB
FTP and SFTP Configuration Commands
FTP Server Configuration Commands
display ftp-server
display ftp-server
View
None
Use the display ftp-server command to display the FTP server-related settings of the device when it operates as an FTP server.
You can use this command to verify FTP server-related configurations.
# Display the FTP server-related settings of the device (FTP must be enabled).
<device> display ftp-server
   FTP server is running
   Max user number       1
   User count            0
   Timeout value(in minute)       30
Table 1-1 display ftp-server command output description
The FTP server is started.
Max user number       1
The FTP server can accommodate up to one user.
User count                 0
The current login user number is 0.
Timeout value (in minute)       30
The connection idle time is 30 minutes.
display ftp-server source-ip
View
None
Use the display ftp-server source-ip command to display the source IP address set for an FTP server. If a source interface is specified for the FTP server, the IP address of the source interface will be displayed. If neither source interface nor source IP address is specified, 0.0.0.0 will be displayed.
# Display the source IP address set for the FTP server.
<device> display ftp-server source-ip
The source IP you specified is 192.168.0.1
display ftp-user
display ftp-user
View
None
Use the display ftp-user command to display the settings of the current FTP user, including the user name, host IP address, port number, connection idle time, and authorized directory.
# Display FTP user settings.
<device> display ftp-user
  UserName             HostIP    Port    Idle              HomeDir
admin           192.168.0.152    1029       0               flash:
# If the user name exceeds ten characters, characters behind the tenth will be displayed in the second line with a left-aligning mode. Take username username@test for example, the result is:
administrator   192.168.0.152    1031    0                 flash:
ftp disconnect
ftp disconnect user-name
View
user-name: Name of the user to be disconnected from the FTP server. Note that the host name can be a string comprising 1 to 184 characters.
Use the ftp disconnect command to terminate the connection between a specified user and the FTP server.
With the device acting as the FTP server, if you attempt to disconnect a user that is uploading/downloading data to/from the FTP server, the device will disconnect the user after the data transmission is completed.
# Display the current online FTP users.
# Disconnect the user named “admin” from the FTP server.
<device> system-view
[device] ftp disconnect admin
%Apr  2 01:06:14:915 2000 device FTPS/5/USEROUT:- 1 -User admin(192.168.0.152) logged out
ftp server enable
ftp sever enable
undo ftp sever
View
None
Use the ftp server enable command to enable the FTP server for users to log in.
Use the undo ftp server command to disable the FTP server.
By default, the FTP server is disabled to avoid potential security risks.
To protect unused sockets from being attacked by malicious users, the device provides the following functions:
l          TCP 21 is enabled only when you start the FTP server.
l          TCP 21 is disabled after you shut down the FTP server.
# Enable the FTP server.
[device] ftp server enable
% Start FTP server
ftp timeout
ftp timeout minutes
undo ftp timeout
View
minutes: Connection idle time (in minutes) in the range 1 to 35,791.
Use the ftp timeout command to set the connection idle time.
Use the undo ftp timeout command to restore the default connection idle time.
By default, the connection idle time is 30 minutes.
If an FTP connection between an FTP server and an FTP client breaks down abnormally, the FTP server is not acknowledged with this and will keep this connection as usual.
You can set a connection idle time, so that the FTP server considers a FTP connection to be invalid and terminates it if no data exchange occurs on it in a specific period known as connection idle time.
# Set the connection idle time to 36 minutes.
[device] ftp timeout 36
ftp-server source-interface
ftp-server source-interface interface-type interface-number
undo ftp-server source-interface
View
interface-type: Type of the source interface.
interface-number: Number of the source interface.
Use the ftp-server source-interface command to specify the source interface for an FTP server. If the specified interface does not exist, a prompt appears to show the configuration fails.
Use the undo ftp-server source-interface command to cancel the source interface setting. After you execute this command, the FTP server system decides which interface will be used for being accessed by FTP clients.
# Specify Vlan interface1 as the source interface of the FTP server.
[device] ftp-server source-interface Vlan-interface 1
ftp-server source-ip ip-address
undo ftp-server source-ip
View
ip-address: IP address that is to be specified as the source IP address.
Use the ftp-server source-ip command to specify the source IP address for an FTP server. The value of argument ip-address must be an IP address on the device where the configuration is performed. Otherwise, a prompt appears to show the configuration fails.
Use the undo ftp-server source-ip command to cancel the source IP address setting. After you execute this command, the FTP server system decides which IP address on it will be used for being accessed by FTP clients.
# Specify 192.168.1.1 as the source IP address of the FTP server.
[device] ftp-server source-ip 192.168.1.1
FTP Client Configuration Commands
ascii
ascii
View
FTP client view
None
Use the ascii command to specify that files be transferred in ASCII mode. That is, data is transferred in ASCII characters.
By default, files are transferred in ASCII mode.
# Enter FTP client view.
<device> ftp 2.2.2.2
Trying ...
Press CTRL+K to abort
Connected.
220 FTP service ready.
User(none):admin
331 Password required for admin.
Password:
230 User logged in.
[ftp]
# Specify to transfer text files in ASCII mode.
[ftp] ascii
200 Type set to A.
binary
binary
View
FTP client view
None
Use the binary command to specify that program files be transferred in binary mode.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Specify to transfer files in binary mode.
[ftp] binary
200 Type set to I.
bye
bye
View
FTP client view
None
Use the bye command to terminate the control connection and data connection with the remote FTP server and return to user view.
This command has the same effect as that of the quit command.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Terminate the connections with the remote FTP server and return to user view.
[ftp] bye
221 Service closing control connection
<device>
cd
cd pathname
View
FTP client view
pathname: Path name
Use the cd command to change the working directory on the remote FTP server.
Note that you can use this command to enter only authorized directories.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Change the working directory to flash:/temp.
[ftp] cd flash:/temp
# Display the current working directory.
[ftp] pwd
257 "flash:/temp" is current directory.
cdup
cdup
View
FTP client view
None
Use the cdup command to exit the current working directory and enter the parent directory.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
250 CWD command successful
# Change the working directory to the parent directory.
[ftp] cdup
# Display the current directory.
[ftp] pwd
257 "flash:" is current directory.
close
close
View
FTP client view
None
Use the close command to terminate an FTP connection without quitting FTP client view.
This command has the same effect as that of the disconnect command.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Terminate the FTP connection without quitting FTP client view.
[ftp] close
221 Server closing.
[ftp]
delete
delete remotefile
View
FTP client view
remotefile: File name
Use the delete command to delete a specified remote file.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Delete the file named temp.c.
[ftp] delete temp.c
250 DELE command successful.
dir
dir [ filename [ localfile ] ]
View
FTP client view
filename: Name of the file to be queried.
localfile: Name of the local file where the query result is to be saved.
Use the dir command to query specified files on a remote FTP server, or to display file information in the current directory. The output information, which includes the name, size and creation time of files, will be saved in a local file.
If you do not specify the filename argument, the information about all the files in the current directory is displayed.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Display the information about all the files in the current directory on the remote FTP server.
[ftp] dir
227 Entering Passive Mode (192,168,0,152,4,0).
125 ASCII mode data connection already open, transfer starting for *.
-rwxrwxrwx   1 noone    nogroup      2833 May 11 17:58 config.cfg
-rwxrwxrwx   1 noone    nogroup    225295 Apr 26 12:21 default.diag
drwxrwxrwx   1 noone    nogroup         0 Apr 28 11:41 test
-rwxrwxrwx   1 noone    nogroup      2145 Apr 28 13:13 test.txt
-rwxrwxrwx   1 noone    nogroup        13 Apr 28 13:21 mytest.bak
-rwxrwxrwx   1 noone    nogroup         9 Apr 28 13:24 a.txt
-rwxrwxrwx   1 noone    nogroup       142 Sep 10  2006 myopenssh
-rwxrwxrwx   1 noone    nogroup        15 Apr 26 17:45 public
-rwxrwxrwx   1 noone    nogroup        15 Apr 26 17:56 temp.c
-rwxrwxrwx   1 noone    nogroup       306 May 13 11:17 swithc001
226 Transfer complete.
FTP: 1025 byte(s) received in 0.019 second(s) 53.00K byte(s)/sec.
# Display the information about the file named config.cfg and save the output information in the file named temp1.
[ftp] dir config.cfg temp1
227 Entering Passive Mode (192,168,0,152,4,3).
125 ASCII mode data connection already open, transfer starting for config.cfg.
.....226 Transfer complete.
FTP: 67 byte(s) received in 5.818 second(s) 11.00 byte(s)/sec.
disconnect
disconnect
View
FTP client view
None
Use the disconnect command to terminate a FTP connection without quitting FTP client view.
This command has the same effect as that of the close command.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
[ftp] disconnect
221 Server closing.
[ftp]
display ftp source-ip
View
None
Use the display ftp source-ip command to display the source IP address that the FTP client uses every time it connects to an FTP server. If a source interface is specified for the FTP client, the IP address of the source interface will be displayed. If neither a source IP address nor source interface is specified for the FTP client, 0.0.0.0 will be displayed.
# Display the source IP address that the FTP client uses every time it connects to an FTP server.
<device> display ftp source-ip
ftp
ftp [ cluster | remote-server [ port-number ] ]
View
cluster: FTP server of a cluster.
ip-address: Host name or the IP address of an FTP server. Note that the host name can be a string comprising 1 to 20 characters.
port-number: Port number of the FTP server, in the range 0 to 65535. The default is 21.
Use the ftp command to establish a control connection with an FTP server and enter FTP client view.
# Connect to the FTP server whose IP address is 2.2.2.2.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
ftp { cluster | remote-server } source-interface
ftp { cluster | remote-server } source-interface interface-type interface-number
View
cluster: Specifies to connect to a cluster FTP server.
remote-server: IP address or host name of the FTP server.
Use the ftp { cluster | remote-server } source-interface command to connect to an FTP server through the specified source interface. This command will fail to be executed if the specified interface does not exist.
# Connect to the FTP server whose IP address is 192.168.8.8 through the source interface Vlan interface1.
<device> ftp 192.168.8.8 source-interface Vlan-interface 1
ftp { cluster | remote-server } source-ip
ftp { cluster | remote-server } source-ip ip-address
View
ip-address: Source IP address.
Use the ftp { cluster | remote-server } source-ip command to connect to an FTP server through the specified source IP address. This command will fail to be executed if the specified source IP address does not exist.
# Connect to the FTP server whose IP address is 192.168.8.8 through the source IP address 192.168.0.1.
<device> ftp 192.168.8.8 source-ip 192.168.0.1
ftp source-interface
ftp source-interface interface-type interface-number
undo ftp source-interface
View
Use the ftp source-interface command to specify a source interface as the source interface the FTP client uses every time it connects to an FTP server. The system prompts that the configuration fails if the specified interface does not exist.
Use the undo ftp source-interface command to cancel the source interface setting. After you execute this command, the FTP client system decides which interface will be used for accessing FTP servers.
# Specify Vlan interface1 as the source interface to be used in each connection between the FTP client and an FTP server.
[device] ftp source-interface Vlan-interface 1
ftp source-ip
ftp source-ip ip-address
undo ftp source-ip
View
Use the ftp source-ip command to specify the source IP address of an FTP client that the FTP client uses every time it connects to an FTP server. The value of argument ip-address must be an IP address on the device where the configuration is performed. Otherwise, a prompt appears to show the configuration fails.
Use the undo ftp source-ip command to cancel the source IP address setting. After you execute this command, the FTP client system decides which IP address on it will be used for accessing FTP servers.
# Specify 192.168.0.1 as the source IP address that the FTP client uses every time it connects to an FTP server.
[device] ftp source-ip 192.168.0.1
get
get remotefile [ localfile ]
View
FTP client view
remotefile: Name of a file on an FTP server.
localfile: Name of a local file.
Use the get command to download a remote file and save it as a local file.
If you do not specify the localfile argument, the downloaded file is saved with its original name.
When using the get command to download files from a remote FTP server, note to limit the length of file path and file name within the following ranges regulated for the device.
l          A directory name should be no more than 91 characters.
l          A file name plus its local path name should be no more than 127 characters.
l          A device name should be no more than 14 characters.
l          A file name plus its complete path name should be no more than 142 characters.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Download the file named temp.c.
[ftp] get temp.c
227 Entering Passive Mode (2,2,2,2,4,12).
125 ASCII mode data connection already open, transfer starting for temp.c.
FTP: 15 byte(s) received in 2.568 second(s) 0.00 byte(s)/sec.
lcd
lcd
View
FTP client view
None
Use the lcd command to display the local working directory on the FTP client.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Display the local working directory.
[ftp] lcd
% Local directory now flash:/temp
ls
ls [ remotefile [ localfile ] ]
View
FTP client view
remotefile: Name of the remote file to be queried.
localfile: Name of the local file where the querying result is to be saved.
Use the ls command to display the information about a specified file on a remote FTP server.
If you do not specify the remotefile argument, names of all the files in the current remote directory are displayed.
The ls command only displays file names, while the dir command displays file information in more detail, including file size, creation date and so on.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Display the names of all the files in the current directory on the remote FTP server.
[ftp] ls
227 Entering Passive Mode (2,2,2,2,4,4).
config.cfg
default.diag
test
test.txt
mytest.bak
a.txt
myopenssh
public
temp.c
swithc001
FTP: 200 byte(s) received in 0.145 second(s) 1.00Kbyte(s)/sec.
mkdir
mkdir pathname
View
FTP client view
pathname: Path name.
Use the mkdir command to create a directory on an FTP server.
This command is available only to the FTP clients that are assigned the permission to create directories on FTP servers.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Create the directory flash:/lanswitch on the FTP server.
[ftp] mkdir flash:/lanswitch
257 "flash:/ lanswitch" new directory created.
open
open { ip-address | server-name } [ port ]
View
FTP client view
ip-address: IP address of an FTP server.
server-name: Host name of the FTP server, a string of 1 to 20 characters.
port: Port number on the remote FTP server, in the range 0 to 65535. The default value is 21.
Use the open command to establish a control connection with an FTP server.
Related commands: close.
<device> ftp
[ftp]
# Establish a control connection with the FTP server whose IP address is 1.1.1.1.
[ftp]open 1.1.1.1
Trying ...
Connected.
User(none):abc
331 Password required for abc
Password:
230 User logged in.
passive
passive
undo passive
View
FTP client view
None
Use the passive command to set the data transfer mode to the passive mode.
Use the undo passive command to set the data transfer mode to the active mode.
By default, the passive mode is adopted.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Set the data transfer mode to the passive mode.
[ftp] passive
% Passive is on
put
put localfile [ remotefile ]
View
FTP client view
remotefile: File name, which the local file is to be saved as on the remote FTP server.
Use the put command to upload a local file to an FTP server.
If you do not specify the remotefile argument, the local file is saved on the FTP server with its original name.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Upload the local file named temp.c to the FTP server.
[ftp] put temp.c
227 Entering Passive Mode (2,2,2,2,4,13).
FTP: 15 byte(s) sent in 7.549 second(s) 1.00byte(s)/sec.
pwd
pwd
View
FTP client view
None
Use the pwd command to display the work directory on an FTP server.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Display the work directory on the FTP server.
[ftp] pwd
View
FTP client view
None
Use the quit command to terminate FTP control connection and FTP data connection and quit to user view.
This command has the same effect as that of the bye command.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Terminate the FTP control connection and FTP data connection and quit to user view.
[ftp] quit
221 Server closing.
<device>
remotehelp
remotehelp [ protocol-command ]
View
FTP client view
protocol-command: FTP protocol command.
Use the remotehelp command to display the help information about an FTP protocol command.
This command works only when the FTP server provides the help information about FTP protocol commands.
l          This command is always valid when a device operates as the FTP server.
l          If you use other FTP server software, refer to related instructions to know whether the FTP server provides help information about FTP protocol commands.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Display the syntax of the user command.
[ftp]remotehelp user
214-USER Enter user name
PASS     Send Password
CWD      Change working directory
CDUP     Go to parent directory
QUIT     Exit FTP server
REIN     Reinitialize server
PORT     Set port for data transfer
TYPE     Set file transfer type
STRU     Set file transfer structure
MODE     Set file transfer mode
RETR     Retrieve file
STOR     Store file
APPE     Append to existing file
REST     Restart file transfer
RNFR     Rename from
RNTO     Rename to
ABOR     Abort transfer
DELE     Delete file
RMD      Remove directory
rename
rename remote-source remote-dest
View
FTP client view
remote-source: Name of a file on a remote host.
remote-dest: Destination file name.
Use the rename command to rename a file on a remote FTP server.
If the destination file name conflicts with the name of an existing file or directory, you will fail to rename the file.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Rename the file named temp.c as forever.c.
[ftp] rename temp.c forever.c
350 Requested file action pending further information
250 Requested file action OK, completed
rmdir
rmdir pathname
View
FTP client view
pathname: Name of a directory on an FTP server.
Use the rmdir command to remove a specified directory on an FTP server.
Note that you can only use this command to remove directories that are empty.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Remove the directory flash:/temp1 on the FTP server. (Assume that the directory is empty.)
[ftp] rmdir flash:/temp1
user
user username [ password ]
View
FTP client view
username: User name used to log in to an FTP server.
password: Password used to log in to an FTP server.
Use the user command to log in to an FTP server with the specified user name and password.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Log into the FTP server using the user account with the user name being tom and the password being 111.
[ftp] user tom 111
331 User name ok, need password
230 User logged in
verbose
verbose
undo verbose
View
FTP client view
None
Use the verbose command to enable the verbose function, which displays execution and response information of other related commands.
Use the undo verbose command to disable the verbose function.
The verbose function is enabled by default.
Trying ...
Connected.
User(none):admin
Password:
230 User logged in.
[ftp]
# Enable the verbose function.
[ftp] verbose
SFTP Server Configuration Commands
sftp server enable
sftp server enable
undo sftp server
View
None
Use the sftp server enable command to enable the SFTP server.
Use the undo sftp server command to disable the SFTP server.
By default, the SFTP server is disabled.
# Enable the SFTP server.
[device] sftp server enable
sftp timeout
sftp timeout time-out-value
undo sftp timeout
View
time-out-value: Timeout time, in the range 1 to 35,791, in minutes. The default value is 10.
Use the sftp timeout command to set the idle timeout time on an SFTP server.
Use the undo sftp timeout command to restore the idle timeout time to the default value.
If the idle timeout time exceeds the specified threshold, the system disconnects the SFTP user automatically.
# Set the idle timeout time to 500 minutes.
[device] sftp timeout 500
SFTP Client Configuration Commands
bye
bye
View
SFTP client view
None
Use the bye command to terminate a connection with the remote SFTP server and return to system view.
This command has the same effect as that of the commands exit and quit.
# Terminate the connection with the remote SFTP server.
sftp-client> bye
Bye
[device]
cd
cd [ remote-path ]
View
SFTP client view
remote-path: Name of the working path on the remote server.
Use the cd command to change the working path on the remote SFTP server. If no remote path is specified, this command displays the current working path.
l          Use the cd .. command to return to the parent directory.
l          Use the cd / command to return to the root directory.
# Change the working path to new1.
sftp-client>cd new1
Received status: Success
Current Directory is:
/new1
sftp-client>
cdup
cdup
View
SFTP client view
None
Use the cdup command to change the working path on the remote SFTP server and return to the parent directory.
# Change the working path and return to the parent directory.
sftp-client>cdup
delete
delete remote-file&<1-10>
View
SFTP client view
remote-file&<1-10>: Name of a file on the server. &<1-10> indicates that up to ten file names can be input. These file names should be separated by spaces.
Use the delete command to delete a specified file from the remote SFTP server.
This command has the same effect as that of the remove command.
# Delete the file named test.txt on the server.
sftp-client> delete test.txt
The following files will be deleted:
/test.txt
Are you sure to delete it?(Y/N):y
This operation may take a long time.Please wait...
File successfully Removed
dir
View
SFTP client view
-a: Displays the file and folder names in a specified directory.
-l: Displays the details about files and folders in a specified directory in a list.
remote-path: Name of the path where the file and folders to be queried reside.
Use the dir command to query a specified directory on the remote SFTP server.
If -a or -l is not specified, the command displays details about the files and folders in the specified directory in a list.
If no remote path is specified, this command displays the files in the current working directory.
This command has the same effect as that of the Is command.
# Display the files in the current directory.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
Received status: End of file
display sftp source-ip
View
None
Use the display sftp source-ip command to display the source IP address specified for the current SFTP client.
If you have specified a source interface for the SFTP client, this command displays the IP address of the source interface; otherwise, this command displays the IP address 0.0.0.0.
# Display the source IP address for the current SFTP client.
<device> display sftp source-ip
The source IP you specified is 192.168.1.1
exit
exit
View
SFTP client view
None
Use the exit command to terminate a connection with the remote SFTP server and return to system view.
This command has the same effect as that of the commands bye and quit.
# Terminate a connection with the remote SFTP server.
sftp-client> exit
Bye
[device]
get
View
SFTP client view
remote-file: Name of a file on the remote SFTP server.
local-file: Name of a local file.
Use the get command to download a file from the remote server.
By default, the remote file name is used for the file saved locally if no local file name is specified.
# Download the file tt.bak and save it with the name tt.txt.
sftp-client>get tt.bak tt.txt....
This operation may take a long time, please wait...
Remote  file:tt.bak --->  Local file: tt.txt..
Downloading file successfully ended
help
help [ all |command ]
View
SFTP client view
all: Displays all the command names.
command: Command name.
Use the help command to display the help information about SFTP client commands.
If no command is specified, this command displays all the command names.
# View the help information about the get command.
sftp-client> help get
get remote-path [local-path]  Download file.Default local-path is the same
                              with remote-path
ls
View
SFTP client view
remote-path: Name of the path where the files and folders to be queried reside.
Use the Is command to display files in a specified directory on the remote SFTP server.
This command has the same effect as that of the dir command.
sftp-client> ls
mkdir
mkdir remote-path
View
SFTP client view
remote-path: Name of a directory on the remote SFTP server.
Use the mkdir command to create a directory on the remote SFTP server.
# Create a directory named hj on the remote SFTP server.
sftp-client>mkdir hj
New directory created
put
View
SFTP client view
Use the put command to upload a local file to the remote SFTP server.
By default, the local file name is used for the remote file if no remote file name is specified.
# Upload the file named config.cfg to the remote SFTP server and save it as 1.txt.
sftp-client>put config.cfg 1.txt
Local file:config.cfg --->  Remote file: /1.txt
Uploading file successfully ended
pwd
pwd
View
SFTP client view
None
Use the pwd command to display the working directory on the remote SFTP server.
# Display the working directory on the remote SFTP server.
sftp-client> pwd
View
SFTP client view
None
Use the quit command to terminate a connection with the remote SFTP server and return to system view.
This command has the same effect as that of the commands bye and exit.
sftp-client> quit
Bye
[device]
remove
remove remote-file&<1-10>
View
SFTP client view
Use the remove command to delete a specified file from the remote SFTP server.
This command has the same effect as that of the delete command.
# Delete the file named temp.c from the server.
sftp-client> remove temp.c
The followed File will be deleted:
/temp.c
rename
rename oldname newname
View
SFTP client view
oldname: Old file name.
newname: New file name.
Use the rename command to rename a specified file on the remote SFTP server.
# Change the file name temp.bat to temp.txt.
sftp-client> rename temp.bat temp.txt
File successfully renamed
rmdir
rmdir remote-path&<1-10>
View
SFTP client view
remote-path&<1-10>: Name of a directory on the remote SFTP server. &<1-10> indicates that up to ten file names can be input. These file names should be separated by spaces.
Use the rmdir command to remove a specified directory from the remote SFTP server.
# Remove the hello directory on the SFTP server.
sftp-client>rmdir hello
The followed directory will be deleted
/hello
Are you sure to remove it?(Y/N):y
Directory successfully removed
sftp
sftp { host-ip | host-name } [ port-num ] [identity-key { dsa | rsa } | prefer_kex { dh_group1 | dh_exchange_group } | prefer_ctos_cipher { des | aes128 } | prefer_stoc_cipher { des | aes128 } | prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } | prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ] *
View
host-ip: IP address of the server.
host-name: Host name of the server, a string of 1 to 20 characters.
port-num: Port number of the server, in the range of 0 to 65,535. The default value is 22.
identity-key: The public key algorithm of the publickey authentication used.
l          Dsa: The public key algorithm is DSA.
l          Rsa: The public key algorithm is RSA.
prefer_kex: Specifies a preferred key exchange algorithm. You can select either of the two algorithms.
l          dh_group1: Key exchange algorithm diffie-hellman-group1-sha1. It is the default key exchange algorithm.
l          dh_exchange_group: Key exchange algorithm diffie-hellman-group-exchange-sha1.
prefer_ctos_cipher: Preferred client-to-server encryption algorithm. The default algorithm is aes128.
prefer_stoc_cipher: Preferred server-to-client encryption algorithm. The default algorithm is aes128.
l          des: des_cbc encryption algorithm.
l          aes128: aes_128 encryption algorithm.
prefer_ctos_hmac: Preferred client-to-server HMAC algorithm. The default algorithm is sha1_96.
prefer_stoc_hmac: Preferred server-to-client HMAC algorithm. The default algorithm is sha1_96.
l          sha1: HMAC algorithm hmac-sha1.
l          sha1_96: HMAC algorithm hmac-sha1-96.
l          md5: HMAC algorithm hmac-md5.
l          md5_96: HMAC algorithm hmac-md5-96.
Use the sftp command to establish a connection with the remote SFTP server and enter SFTP client view.
If you specify to authenticate a client through public key on the server, the client needs to read the local private key when logging in to the SFTP server. Since both RSA and DSA are available for public key authentication, you need to use the identity-key key word to specify the algorithms to get correct local private key; otherwise you will fail to log in.
# Connect the SFTP server with the IP address 10.1.1.2. Use the default encryption algorithm.
<device>system-view
[device]sftp 10.1.1.2
Input Username: kk
Trying 10.1.1.2...
Connected to 10.1.1.2 ...
The Server is not authenticated. Do you continue access it?(Y/N):y
Do you want to save the server's public key?(Y/N):y
Enter password:
sftp-client>
sftp source-interface
sftp source-interface interface-type interface-number
undo sftp source-interface
View
interface-type: Type of a source interface. It can be loopback or VLAN interface.
interface-number: Number of a source interface.
Use the sftp source-interface command to specify a source interface for the SFTP client. If the specified interface does not exist, the system prompts that the configuration fails.
Use the undo sftp source-interface command to remove the specified source interface. Then the client accesses the SFTP server with the local device address determined by the system.
# Specify Vlan interface 1 as the source interface of the SFTP client.
[device] sftp source-interface Vlan-interface 1
sftp source-ip
sftp source-ip ip-address
undo sftp source-ip
View
ip-address: Source IP address to be set.
Use the sftp source-ip command to specify a source IP address for the SFTP client. If the specified IP address is not the IP address of the local device, the system prompts that the configuration fails.
Use the undo sftp source-ip command to remove the specified source IP address. Then the client accesses the SFTP server with the local device address determined by the system.
# Specify 192.168.0.1 as the source IP address of the SFTP client.
[device] sftp source-ip 192.168.0.1
TFTP Configuration Commands
display tftp source-ip
View
None
Use the display tftp source-ip display the source IP address that the TFTP client uses every time it connects to a TFTP server. If a source interface is specified for the TFTP client, the IP address of the source interface is displayed. If neither source IP address nor source interface is specified for the TFTP client, 0.0.0.0 is displayed.
# Display the source IP address that the TFTP client uses every time it connects to a TFTP server.
<device> display tftp source-ip
tftp
tftp { ascii | binary }
View
ascii: Transfers data in ASCII mode.
binary: Transfers data in binary mode.
Use the tftp { ascii | binary } command to set the TFTP data transfer mode.
By default, the binary mode is adopted.
# Specify to adopt the ASCII mode.
[device] tftp ascii
TFTP transfer mode changed to ASCII.
tftp get
tftp tftp-server get source-file [ dest-file ]
View
tftp-server: IP address or the host name of a TFTP server.
source-file: Name of the file to be downloaded from the TFTP server.
dest-file: File name which the downloaded file is to be saved as.
Use the tftp get command to download a file from a TFTP server to the local device.
Related commands: tftp put.
# Download the file named abc.txt from the TFTP server whose IP address is 1.1.1.1 and save it as efg.txt (suppose free space of the flash memory is sufficient).
<device> tftp 1.1.1.1 get abc.txt efg.txt
  File will be transferred in binary mode.
  Downloading file from remote tftp server, please wait......
  TFTP:       35 bytes received in 0 second(s).
  File downloaded successfully.
# Download the file temp.txt from the TFTP server (1.1.1.1) and save it as test1.txt (suppose that free space of the flash memory is insufficient and the TFTP server does not support file size negotiation).
<device> tftp 1.1.1.1 get temp.txt test1.txt
  Not enough space; Writing to device failed; Downloaded data will be deleted.............
  Deleting file successful.
# Download the file temp.txt from the TFTP server (1.1.1.1) and save it as test2.txt (suppose that free space of the flash memory is insufficient and the TFTP server supports file size negotiation).
<device> tftp 1.1.1.1 get temp.txt test2.txt
  Not enough space; Quit writing to device; Created file will be deleted.............
tftp put
tftp tftp-server put source-file [ dest-file ]
View
source-file: Name of the file to be uploaded to the TFTP server.
dest-file: File name which the uploaded file is to be saved as.
Use the tftp put command to upload a file to a specified directory on a TFTP server.
Related commands: tftp get.
# Upload the file named config.cfg to the TFTP server whose IP address is 1.1.1.1 and save it as temp.cfg.
<device> tftp 1.1.1.1 put config.cfg temp.cfg
  Copying file to remote tftp server. Please wait... /
  TFTP:      962 bytes sent in 0 second(s).
  File uploaded successfully.
tftp tftp-server source-interface
tftp tftp-server source-interface interface-type interface-number { get source-file [ dest-file ] | put source-file-url [ dest-file ] }
View
tftp-server: IP address or host name of the TFTP server to be connected to.
get: Specifies to download a file from the TFTP server.
source-file: Name of the file to be downloaded.
dest-file: Name of the downloaded file to be saved locally.
put: Specifies to upload a file to the TFTP server.
source-file-url: Path and name of the file to be uploaded.
dest-file: Name of the uploaded file to be saved on the TFTP server.
Use the tftp tftp-server source-interface command to connect to a TFTP server through the specified source interface, and perform download or upload operations. If the specified source interface does not exist, a prompt appears to show the command fails to be executed.
# Connect to the remote TFTP server whose IP address is 192.168.8.8 through the source interface VLAN-interface1, and download the file named config.cfg from it.
<device> tftp 192.168.8.8 source-interface Vlan-interface 1 get config.cfg
tftp tftp-server source-ip
tftp tftp-server source-ip ip-address { get source-file [ dest-file ] | put source-file-url [ dest-file ] }
View
ip-address: IP address to be set as the source IP address.
Use the tftp tftp-server source-ip command to connect to a TFTP server through the specified source IP address, and perform download or upload operations. If the specified source IP address does not exist, a prompt appears to show the command fails to be executed.
# Connect to the remote TFTP server whose IP address is 192.168.8.8 through the source IP address 192.168.0.1, and download the file named config.cfg from it.
<device> tftp 192.168.8.8 source-ip 192.168.0.1 get config.cfg
tftp source-interface
tftp source-interface interface-type interface-number
undo tftp source-interface
View
Use the tftp source-interface command to specify the source interface of a TFTP client that the TFTP client uses every time it connects to a TFTP server. The system prompts that the configuration fails if the specified interface does not exist.
Use the undo tftp source-interface command to cancel the source interface setting. After you execute this command, the TFTP client system decides which interface will be used for accessing TFTP servers.
# Specify Vlan interface1 as the source interface that the TFTP client uses every time it connects to a TFTP server.
[device] tftp source-interface Vlan-interface 1
tftp source-ip
tftp source-ip ip-address
undo tftp source-ip
View
Use the tftp source-ip command to specify the source IP address of a TFTP client that the TFTP client uses every time it connects with a TFTP server. The value of argument ip-address must be an IP address on the device where the configuration is performed. Otherwise, a prompt appears to show the configuration fails.
Use the undo tftp source-ip command to cancel the source IP address setting. After you execute this command, the TFTP client system decides which IP address on it will be used for accessing TFTP servers.
# Specify 192.168.0.1 as the source IP address that the TFTP client uses every time it connects to a TFTP server.
[device] tftp source-ip 192.168.0.1
tftp-server acl
tftp-server acl acl-number
undo tftp-server acl
View
acl-number: Basic ACL number, in the range 2000 to 2999.
Use the tftp-server acl command to specify the ACL adopted for the connection between a TFTP client and a TFTP server.
Use the undo tftp-server acl command to cancel all ACLs adopted.
# Specify to adopt ACL 2000 on the TFTP client.
[device] tftp-server acl 2000
