H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
00-Preface
00-Preface 64.46 KB
Preface
The H3C WX3000 Series Unified Switches Switching Engine Command Reference describes the commands and command syntax options available for the H3C WX3000 series unified switches switching engine.
This preface includes:
l          Audience
l          Document Organization
l          Conventions
l          About the H3C WX3000 Series Documentation Set
l          Obtaining Documentation
l          Documentation Feedback
Audience
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the H3C WX3000 series unified switches switching engine
The H3C WX3000 Series Unified Switches Switching Engine Command Reference comprises these parts:
Content
CLI
Login
Configuration File Management
VLAN
Auto Detect
Voice VLAN
GVRP
Basic Port Configuration
Link Aggregation
Port Isolation
Port Security-Port Binding
DLDP
MAC Address Table Management
MSTP
802.1x and System Guard
AAA
MAC Address Authentication
IP Address and Performance
DHCP
ACL
QoS-QoS Profile
Mirroring
ARP
SNMP-RMON
Multicast
NTP
SSH
File System Management
FTP-SFTP-TFTP
Information Center
System Maintenance and Debugging
VLAN-VPN
HWPing
DNS
Smart Link-Monitor Link
PoE-PoE Profile
Routing Protocol
UDP Helper
Conventions
This section describes the conventions used in this documentation.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
The H3C WX3000 series documentation set also includes:
Manual
H3C WX3000 Series Unified Switches  Installation Manual
It introduces the installation process, startup, hardware and software maintenance of WX3000 Series unified switches.
H3C WX3000 Series Unified Switches Switching Engine Operation Manual
Provides a guide to the operation on WX3000 series unified switches switching engines. It covers configurations of CLI, login, VLAN, GVRP, basic port configurations, MAC address table management, MSTP, 802.1x, AAA, ACL, QoS, SNMP, RMON, NTP, and SSH.
H3C WX Series Access Controllers User Manual
Provides a guide to the operation of H3C series access controllers. It covers configurations of CLI, VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, description of the acronyms used throughout the manual, and a command index.
H3C WX Series Access Controllers  Web-Based Configuration Manual
Introduces the Web-based functions of the access control engine of WX3000 series unified switches.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
We appreciate your comments.
