- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Mulitcast Overview
- 02-Multicast Routing and Forwarding Configuration
- 03-IGMP Configuration
- 04-PIM Configuration
- 05-MSDP Configuration
- 06-MBGP Configuration
- 07-Multicast VPN Configuration
- 08-IGMP Snooping Configuration
- 09-Multicast VLAN Configuration
- 10-IPv6 Multicast Routing and Forwarding Configuration
- 11-MLD Configuration
- 12-IPv6 PIM Configuration
- 13-IPv6 MBGP Configuration
- 14-MLD Snooping Configuration
- 15-IPv6 Multicast VLAN Configuration
| 06-MBGP Configuration | 174.18 KB |
Table of Contents
Configuring MBGP Basic Functions
Controlling Route Advertisement and Reception
Configuring MBGP Route Redistribution
Configure Default Route Redistribution into MBGP
Configuring MBGP Route Summarization
Advertising a Default Route to an IPv4 MBGP Peer or Peer Group
Configuring Outbound MBGP Route Filtering
Configuring Inbound MBGP Route Filtering
Configuring MBGP Route Dampening
Configuring MBGP Route Attributes
Configuring MBGP Route Preferences
Configuring the Default Local Preference
Configuring the Next Hop Attribute
Configuring the AS-PATH Attribute
Tuning and Optimizing MBGP Networks
Configuring the Maximum Number of MBGP Routes for Load Balancing
Configuring a Large Scale MBGP Network
Configuring IPv4 MBGP Peer Groups
Configuring an MBGP Route Reflector
Displaying and Maintaining MBGP
The term “router” refers to a router or a Layer 3 switch in this document.
When configuring MBGP, go to these sections for information you are interested in:
l MBGP Configuration Task List
l Configuring MBGP Basic Functions
l Controlling Route Advertisement and Reception
l Configuring MBGP Route Attributes
l Tuning and Optimizing MBGP Networks
l Configuring a Large Scale MBGP Network
l Displaying and Maintaining MBGP
MBGP Overview
BGP-4 is capable of carrying routing information for IPv4 only. IETF defined multiprotocol BGP extensions to carry routing information for multiple network layer protocols.
For a network, the multicast topology may be different from the unicast topology. To meet the requirement, the multiprotocol BGP extensions enable BGP to carry the unicast Network Layer Reachability Information (NLRI) and multicast NLRI separately, and the multicast NLRI is used to perform reverse path forwarding (RPF) exclusively. In this way, route selection for a destination through the unicast routing table and through the multicast routing table will have different results, ensuring normal unicast and multicast routing.
Multi-protocol BGP is defined in RFC 2858 (Multiprotocol Extensions for BGP-4).
Multi-protocol BGP for IP multicast is referred to as Multicast BGP (MBGP) for short.
l This document covers configuration tasks related to multiprotocol BGP for IP multicast only. For information about BGP, refer to BGP Configuration in the IP Routing Volume.
l For information about RPF, refer to Multicast Routing and Forwarding in the IP Multicast Volume.
Protocols and Standards
l RFC2858: Multiprotocol Extensions for BGP-4
l RFC3392: Capabilities Advertisement with BGP-4
l draft-ietf-idmr-bgp-mcast-attr-00: BGP Attributes for Multicast Tree Construction
Complete the following tasks to configure MBGP:
Task |
Remarks |
Required |
Optional |
Optional |
Optional |
Advertising a Default Route to an IPv4 MBGP Peer or Peer Group |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Before configuring MBGP, make sure neighboring nodes can access each other at the network layer.
Configuration Procedure
Follow these steps to configure MBGP basic functions:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Specify a peer or peer group and its AS number |
peer { group-name | ip-address } as-number as-number |
Required Not specified by default. |
Enter IPv4 MBGP address family view |
ipv4-family multicast |
Required |
Enable a peer or peer group created in IPv4 unicast view |
Required Not enabled by default |
Specify a preferred value for routes from an IPv4 MBGP peer or peer group |
peer { group-name | ip-address } preferred-value value |
Optional The default preferred value is 0. |
You need to configure MBGP basic functions before configuring this task.
MBGP can advertise routing information in the local AS to neighboring ASs. It redistributes such routing information from IGP into its routing table rather than learns the information by itself.
Follow these steps to configure MBGP route redistribution:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Redistribute routes from another routing protocol |
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ] |
At least one of these approaches is required. No route redistribution is configured by default. |
Inject a network into the MBGP routing table |
network ip-address [ mask | mask-length ] [ short-cut | route-policy route-policy-name ] |
l The Origin attribute of routes redistributed into the MBGP routing table with the import-route command is Incomplete.
l The Origin attribute of routes injected into the MBGP routing table with the network command is IGP.
l The networks to be injected must exist in the local IP routing table, and using a route policy makes route control more flexible.
You cannot use the import-route command to configure MBGP to redistribute default routes from other protocols. Instead, use the following commands:
Follow these steps to configure MBGP to redistribute default routes from other protocols
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Enter MBGP address family view |
Required No route redistribution is configured by default. |
Enable default route redistribution into the MBGP routing table |
default-route imported |
To reduce the routing table size on medium and large MBGP networks, you need to configure route summarization on peers. MBGP supports two summarization modes: automatic and manual.
l Automatic summarization: Summarizes subnets redistributed from IGP. With the feature configured, MBGP advertises only summary natural networks rather than subnets. The default routes and routes injected with the network command are not summarized.
l Manual summarization: Summarizes MBGP local routes. A manual summary route has a higher priority than an automatic one.
Follow these steps to configure MBGP route summarization:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure MBGP route summarization |
Enable automatic route summarization |
summary automatic |
Required No route summarization is configured by default. Choose either as needed; if both are configured, the manual route summarization takes effect. |
Configure manual route summarization |
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] * |
Follow these steps to advertise a default route to an MBGP peer or peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Advertise a default route to an MBGP peer or peer group |
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ] |
Required Not advertised by default |
With the peer default-route-advertise command executed, the router sends a default route with the next hop being itself to the specified MBGP peer or peer group, regardless of whether the default route is available in the routing table.
If several filtering policies are configured, they are applied in the following sequence:
l filter-policy export
l peer filter-policy export
l peer as-path-acl export
l peer ip-prefix export
l peer route-policy export
Only the routes that have passed all the configured policies can be advertised.
Follow these steps to configure BGP route distribution filtering policies:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure the filtering of redistributed routes |
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ] |
At least one of these approaches is required. No outbound route filtering is configured by default |
Apply a route policy to advertisements to an IPv4 MBGP peer/peer group |
peer { group-name | peer-address } route-policy route-policy-name export |
Reference an ACL to filter advertisements to an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } filter-policy acl-number export |
Reference an AS path ACL to filer route advertisements to an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } as-path-acl as-path-acl-number export |
Reference an IP prefix list to filer route advertisements to an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } ip-prefix ip-prefix-name export |
By configuring MBGP route reception filtering policies, you can filter out unqualified routes from an MBGP peer or peer group.
l filter-policy import
l peer filter-policy import
l peer as-path-acl import
l peer ip-prefix import
l peer route-policy import
Follow these steps to configure MBGP route reception filtering policies:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Filter incoming routes using an ACL or IP prefix list |
filter-policy { acl-number | ip-prefix ip-prefix-name } import |
At least one of these approaches is required. No inbound route filtering is configured by default. |
Reference a route policy to routes from an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } route-policy policy-name import |
Reference an ACL to filter routing information from an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } filter-policy acl-number import |
Reference an AS path ACL to filter routing information from an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } as-path-acl as-path-acl-number import |
Reference an IP prefix list to filter routing information from an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } ip-prefix ip-prefix-name import |
Specify the maximum number of routes that can be received from an IPv4 MBGP peer/peer group |
peer { group-name | ip-address } route-limit limit [ percentage ] |
Optional The number is unlimited by default. |
Members of a peer group can have different route reception filtering policies from the peer group.
By configuring MBGP route dampening, you can suppress unstable routes from being added to the MBGP routing table or being advertised to MBGP peers.
Follow these steps to configure BGP route dampening:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure BGP route dampening parameters |
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] * |
Required Not configured by default |
You can modify MBGP route attributes to affect route selection.
Before configuring this task, you need to configure MBGP basic functions.
You can reference a route policy to set preferences for routes matching it. Routes not matching it use the default preferences.
Follow these steps to configure MBGP route preferences:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure preferences for external, internal, local MBGP routes |
preference { external-preference internal-preference local-preference | route-policy route-policy-name } |
Optional The default preferences of multicast MBGP eBGP, MBGP iBGP, and local MBGP routes are 255, 255, and 130 respectively. |
Follow these steps to configure the default local preference:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure the default local preference |
default local-preference value |
Optional 100 by default. |
Configuring the MED Attribute
When other conditions of routes to a destination are identical, the route with the smallest MED is selected.
Follow these steps to configure the MED attribute:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure the MED attribute |
Configure the default MED value |
default med med-value |
Optional 0 by default. |
Enable the comparison of the MED of routes from different ASs |
compare-different-as-med |
Optional Not enabled by default |
Enable the comparison of the MED of routes from each AS |
bestroute compare-med |
Enable the comparison of the MED of routes from confederation peers |
bestroute med-confederation |
You can use the peer next-hop-local command to specify the local router as the next hop of routes sent to a MBGP iBGP peer/peer group. If load balancing is configured, the router specifies itself as the next hop of route advertisements to the multicast iBGP peer/peer group regardless of whether the peer next-hop-local command is configured.
In a “third party next hop" network, that is, the local router has two multicast eBGP peers in a broadcast network, the router does not specify itself as the next hop of routing information sent to the eBGP peers unless the peer next-hop-local command is configured.
Follow these steps to specify the router as the next hop of routes sent to a peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Specify the router as the next hop of routes sent to a peer/peer group |
peer { group-name | ip-address } next-hop-local |
Optional By default, the next hop of routes sent to a MBGP eBGP peer/peer group is the advertising router, while that of routes sent to a MBGP iBGP peer/peer group is not. |
In general, MBGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
Follow these steps to configure the AS-PATH attribute:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure the AS_PATH attribute |
Specify the maximum number of times the local AS number can appear in routes from the peer/peer group |
peer { group-name | ip-address } allow-as-loop [ number ] |
Optional By default, the local AS number can not appear in routes from a peer/peer group. |
Disable BGP from considering the AS_PATH during best route selection |
bestroute as-path-neglect |
Optional By default, BGP considers AS_PATH during best route selection. |
Configure updates to a peer/peer group to not keep private AS numbers |
peer { group-name | ip-address } public-as-only |
Optional By default, BGP updates carry private AS numbers. |
This task involves resetting MBGP connections and configuring load balancing.
You need to configure BGP basic functions before configuring this task.
Configuring MBGP Soft Reset
After modifying a route selection policy, you have to reset MBGP connections to make it take effect, causing short time disconnections.
After the route-refresh capability is enabled on all MBGP routers in a network, when a route selection policy is modified on a router, the local router can perform dynamic route updates without tearing down MBGP connections.
If the peer does not support route-refresh, you can save all route updates from the peer. When the route selection policy changes, you can refresh the MBGP routing table and apply the new policy without tearing down MBGP connections.
Soft reset through route-refresh
If the peer is enabled with route-refresh, when the MBGP route selection policy is modified on a router, the router advertises a route-refresh message to its MBGP peers, which resend their routing information to the router after receiving the message. Therefore, the local router can perform dynamic route update and apply the new policy without tearing down MBGP connections.
Follow these steps to configure MBGP soft reset through route-refresh:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Enable BGP route refresh for a peer/peer group |
peer { group-name | ip-address } capability-advertise route-refresh |
Optional Enabled by default |
Perform a manual soft reset
If the peer does not support route-refresh, you can use the peer keep-all-routes command to save all the route updates from the peer, and then use the refresh bgp ipv4 multicast command to soft-reset MBGP connections to refresh the MBGP routing table and apply the new policy without tearing down MBGP connections.
Follow these steps to configure MBGP manual soft reset
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Disable BGP route-refresh and multi-protocol extensions for a peer/peer group |
peer { group-name | ip-address } capability-advertise conventional |
Keep all original routes from a peer/peer group regardless of whether they pass the inbound filtering policies |
peer { group-name | ip-address } keep-all-routes |
Required Not kept by default |
Return to user view |
return |
Soft-reset MBGP connections manually |
refresh bgp ipv4 multicast { all | ip-address | group group-name | external | internal } { export | import } |
Optional |
Follow these steps to configure the number of MBGP routes for load balancing:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure the maximum number of MBGP routes for load balancing |
balance number |
Required Not configured by default. |
Before configuring this task, you need to make peering nodes accessible to each other at the network layer.
Follow these steps to configure an IPv4 MBGP peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Create a BGP peer group |
group group-name [ external | internal ] |
Required Not created by default. |
Add a peer into the peer group |
peer ip-address group group-name [ as-number as-number ] |
Required No peer is added by default. |
Enable the IPv4 unicast peer group |
peer group-name enable |
Required |
Add an IPv4 MBGP peer to the peer group |
peer ip-address group group-name |
l To configure an MBGP peer group, you need to enable the corresponding IPv4 BGP unicast peer group in IPv4 MBGP address family view.
l Before adding an MBGP peer to an MBGP peer group, you need to add the corresponding IPv4 unicast peer to the IPv4 BGP peer group.
Configuring MBGP Community
The community attribute can be advertised between MBGP peers in different ASs. Routers in the same community share the same policy.
You can reference a route policy to modify the community attribute for routes sent to a peer. In addition, you can define extended community attributes as needed.
Follow these steps to configure MBGP community:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Advertise the community attribute to an MBGP peer/peer group |
peer { group-name | ip-address } advertise-community |
Advertise the extended community attribute to an MBGP peer/peer group |
peer { group-name | ip-address } advertise-ext-community |
Apply a route policy to routes advertised to an MBGP peer/peer group |
peer { group-name | ip-address } route-policy route-policy-name export |
l When configuring MBGP community, you need to reference a route policy to define the specific community attributes, and apply the route policy for route advertisement.
l For route policy configuration, refer to Route Policy Configuration in the IP Routing Volume.
To guarantee the connectivity between multicast iBGP peers in an AS, you need to make them fully meshed. But this becomes unpractical when there are large numbers of multicast iBGP peers. Configuring route reflectors can solve this problem.
Follow these steps to configure an MBGP route reflector:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Configure the router as a route reflector and specify an MBGP peer/peer group as its client |
peer { group-name | peer-address } reflect-client |
Enable route reflection between clients |
reflect between-clients |
Optional Enabled by default. |
Configure the cluster ID of the route reflector |
reflector cluster-id cluster-id |
Optional By default, a route reflector uses its router ID as the cluster ID. |
l In general, it is not required that clients of a route reflector be fully meshed. The route reflector forwards routing information between clients. If clients are fully meshed, you can disable route reflection between clients to reduce routing costs.
l In general, a cluster has only one route reflector, and the router ID of the route reflector is used to identify the cluster. You can configure multiple route reflectors to improve network stability. In this case, you need to specify the same cluster ID for these route reflectors to avoid routing loops.
Displaying MBGP
To do… |
Use the command… |
Remarks |
Display the IPv4 MBGP routing table |
display ip multicast routing-table [ verbose] |
Available in any view |
Display the IPv4 MBGP routing information matching the specified destination IP address |
display ip multicast routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ] |
Display MBGP peer group information |
display bgp multicast group [ group-name ] |
Display the advertised networks |
display bgp multicast network |
Display AS path information |
display bgp multicast paths [ as-regular-expression ] |
Display MBGP peer/peer group information |
display bgp multicast peer [ ip-address { log-info | verbose } | group-name log-info | verbose ] |
Display MBGP routing information |
display bgp multicast routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ] |
Display MBGP routing information matching the AS path ACL |
display bgp multicast routing-table as-path-acl as-path-acl-number |
Display MBGP CIDR routing information |
display bgp multicast routing-table cidr |
Display MBGP routing information matching the specified BGP community |
display bgp multicast routing-table community[ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] |
Display MBGP routing information matching an MBGP community list |
display bgp multicast routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16> |
Display MBGP dampened routing information |
display bgp multicast routing-table dampened |
Display MBGP dampening parameter information |
display bgp multicast routing-table dampening parameter |
Display MBGP routing information originating from different ASs |
display bgp multicast routing-table different-origin-as |
Display IPv4 MBGP routing flap statistics |
display bgp multicast routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ] |
Display IPv4 MBGP routing information sent to or received from an MBGP peer |
display bgp multicast routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ] |
Display IPv4 MBGP routing information matching an AS regular expression |
display bgp multicast routing-table regular-expression as-regular-expression |
Display IPv4 MBGP routing statistics |
display bgp multicast routing-table statistic |
Resetting MBGP Connections
To do… |
Use the command… |
Remarks |
Reset specified MBGP connections |
reset bgp ipv4 multicast { all | as-number | ip-address | group group-name | external | internal } |
Available in user view |
Clearing MBGP Information
To do… |
Use the command… |
Remarks |
Clear dampened routing information and release suppressed routes |
reset bgp ipv4 multicast dampening [ ip-address [ mask | mask-length ] ] |
Clear MBGP route flap statistics |
reset bgp ipv4 multicast flap-info [ regexp as-path-regexp | as-path-acl as-path-acl-number | ip-address [ mask | mask-length ] ] |
MBGP Configuration Example
Network requirements
As shown in the following figure:
l PIM-SM 1 is in AS 100 and PIM-SM 2 is in AS 200. OSPF is the IGP in the two ASs, and MBGP runs between the two ASs to exchange multicast route information.
l The multicast source belongs to PIM-SM 1, and the receiver belongs to PIM-SM 2.
l It is required that the respective Loopback 0 of Switch A and Switch B be configured as the C-BSR and C-RP of the respective PIM-SM domains.
l Router A and Router B establishes an MSDP peer relationship through MBGP.
Network diagram
Figure 1-1 Network diagram for MBGP configuration
Device |
IP address |
Device |
IP address |
Source |
10.110.1.100/24 |
Switch C |
Vlan-int200 |
10.110.2.1/24 |
Switch A |
Vlan-int100 |
10.110.1.1/24 |
Vlan-int102 |
192.168.2.2/24 |
Vlan-int101 |
192.168.1.1/24 |
Vlan-int104 |
192.168.4.1/24 |
Loop0 |
1.1.1.1/32 |
Loop0 |
3.3.3.3/32 |
Switch B |
Vlan-int101 |
192.168.1.2/24 |
Switch D |
Vlan-int103 |
192.168.3.2/24 |
Vlan-int102 |
192.168.2.1/24 |
Vlan-int104 |
192.168.4.2/24 |
Vlan-int103 |
192.168.3.1/24 |
Loop0 |
4.4.4.4/32 |
Loop0 |
2.2.2.2/32 |
Configuration procedure
1) Configure IP addresses for interfaces as shown in the above figure (omitted).
2) Configure OSPF (omitted).
3) Enable IP multicast routing, PIM-SM and IGMP, and configure a PIM-SM domain border.
# Enable IP multicast routing on Switch A, and enable PIM-SM on each interface.
[SwitchA] multicast routing-enable
The configuration on Switch B and Switch D is similar to the configuration on Switch A.
# Enable IP multicast routing on Switch C, enable PIM-SM on each interface, and enable IGMP on the host-side interface VLAN-interface 200.
[SwitchC] multicast routing-enable
[SwitchC] interface vlan-interface 104
[SwitchC-Vlan-interface104] pim sm
[SwitchC-Vlan-interface104] quit
[SwitchC-Vlan-interface200] pim sm
# Configure a PIM domain border on Switch A.
[SwitchA-Vlan-interface101] pim bsr-boundary
# Configure a PIM domain border on Switch B.
[SwitchB-Vlan-interface101] pim bsr-boundary
4) Configure Loopback 0 and the position of C-BSR, and C-RP.
# Configure Loopback 0 and configure it as the C-BSR and C-RP on Switch A.
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] pim sm
[SwitchA-LoopBack0] quit
[SwitchA] pim
[SwitchA-pim] c-bsr loopback 0
[SwitchA-pim] c-rp loopback 0
[SwitchA-pim] quit
# Configure Loopback 0 and configure it as the C-BSR and C-RP on Switch B.
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] pim sm
[SwitchB-LoopBack0] quit
[SwitchB] pim
[SwitchB-pim] c-bsr loopback 0
[SwitchB-pim] c-rp loopback 0
[SwitchB-pim] quit
5) Configure BGP, specify the MBGP peer and enable direct route redistribution.
# On Switch A, configure the MBGP peer and enable direct route redistribution.
[SwitchA] bgp 100
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] peer 192.168.1.2 as-number 200
[SwitchA-bgp] import-route direct
[SwitchA-bgp] ipv4-family multicast
[SwitchA-bgp-af-mul] peer 192.168.1.2 enable
[SwitchA-bgp-af-mul] import-route direct
[SwitchA-bgp-af-mul] quit
[SwitchA-bgp] quit
# On Switch B, configure the MBGP peer and enable route redistribution from OSPF.
[SwitchB] bgp 200
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] peer 192.168.1.1 as-number 100
[SwitchB-bgp] import-route ospf 1
[SwitchB-bgp] ipv4-family multicast
[SwitchB-bgp-af-mul] peer 192.168.1.1 enable
[SwitchB-bgp-af-mul] import-route ospf 1
[SwitchB-bgp-af-mul] quit
[SwitchB-bgp] quit
6) Configure MSDP peer
# Specify the MSDP peer on Switch A.
[SwitchA] msdp
[SwitchA-msdp] peer 192.168.1.2 connect-interface vlan-interface 101
[SwitchA-msdp] quit
# Specify the MSDP peer on Switch B.
[SwitchB] msdp
[SwitchB-msdp] peer 192.168.1.1 connect-interface vlan-interface 101
[SwitchB-msdp] quit
7) Verify the configuration
You can use the display bgp multicast peer command to display MBGP peers on a switch. For example, display MBGP peers on Switch B.
[SwitchB] display bgp multicast peer
BGP local router ID : 2.2.2.2
Local AS number : 200
Total number of peers : 3 Peers in established state : 3
Peer V AS MsgRcvd MsgSent OutQ PrefRcv Up/Down State
192.168.1.1 4 100 56 56 0 0 00:40:54 Established
You can use the display msdp brief command to display MSDP peers on a switch. For example, display brief information about MSDP peers on Switch B.
[SwitchB] display msdp brief
MSDP Peer Brief Information of VPN-Instance: public net
Configured Up Listen Connect Shutdown Down
1 1 0 0 0 0
Peer's Address State Up/Down time AS SA Count Reset Count
192.168.1.1 Up 00:07:17 100 1 0
