- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Mulitcast Overview
- 02-Multicast Routing and Forwarding Configuration
- 03-IGMP Configuration
- 04-PIM Configuration
- 05-MSDP Configuration
- 06-MBGP Configuration
- 07-Multicast VPN Configuration
- 08-IGMP Snooping Configuration
- 09-Multicast VLAN Configuration
- 10-IPv6 Multicast Routing and Forwarding Configuration
- 11-MLD Configuration
- 12-IPv6 PIM Configuration
- 13-IPv6 MBGP Configuration
- 14-MLD Snooping Configuration
- 15-IPv6 Multicast VLAN Configuration
| 08-IGMP Snooping Configuration | 340.87 KB |
Basic Concepts in IGMP Snooping
Processing of Multicast Protocol Messages
IGMP Snooping Configuration Task List
Configuring Basic Functions of IGMP Snooping
Configuring the Version of IGMP Snooping
Configuring IGMP Snooping Port Functions
Configuring Aging Timers for Dynamic Ports
Configuring Fast Leave Processing
Configuring IGMP Snooping Querier
Enabling IGMP Snooping Querier
Configuring IGMP Queries and Responses
Configuring Source IP Address of IGMP Queries
Configuring an IGMP Snooping Policy
Configuring a Multicast Group Filter
Configuring Multicast Source Port Filtering
Configuring the Function of Dropping Unknown Multicast Data
Configuring IGMP Report Suppression
Configuring Maximum Multicast Groups that Can Be Joined on a Port
Configuring Multicast Group Replacement
Displaying and Maintaining IGMP Snooping
IGMP Snooping Configuration Examples
Configuring Group Policy and Simulated Joining
IGMP Snooping Querier Configuration
Troubleshooting IGMP Snooping Configuration
Switch Fails in Layer 2 Multicast Forwarding
Configured Multicast Group Policy Fails to Take Effect
When configuring IGMP Snooping, go to the following sections for information you are interested in:
l IGMP Snooping Configuration Task List
l Displaying and Maintaining IGMP Snooping
l IGMP Snooping Configuration Examples
l Troubleshooting IGMP Snooping Configuration
IGMP Snooping Overview
Internet Group Management Protocol Snooping (IGMP Snooping) is a multicast constraining mechanism that runs on Layer 2 devices to manage and control multicast groups.
Principle of IGMP Snooping
By analyzing received IGMP messages, a Layer 2 device running IGMP Snooping establishes mappings between ports and multicast MAC addresses and forwards multicast data based on these mappings.
As shown in Figure 1-1, when IGMP Snooping is not running on the switch, multicast packets are broadcast to all devices at Layer 2. When IGMP Snooping is running on the switch, multicast packets for known multicast groups are multicast to the receivers, rather than broadcast to all hosts, at Layer 2.
Figure 1-1 Before and after IGMP Snooping is enabled on the Layer 2 device
IGMP Snooping forwards multicast data to only the receivers requiring it at Layer 2. It brings the following advantages:
l Reducing Layer 2 broadcast packets, thus saving network bandwidth.
l Enhancing the security of multicast traffic.
l Facilitating the implementation of per-host accounting.
IGMP Snooping related ports
As shown in Figure 1-2, Router A connects to the multicast source, IGMP Snooping runs on Switch A and Switch B, Host A and Host C are receiver hosts (namely, multicast group members).
Figure 1-2 IGMP Snooping related ports
Ports involved in IGMP Snooping, as shown in Figure 1-2, are described as follows:
l Router port: A router port is a port on an Ethernet switch that leads switch towards a Layer 3 multicast device (DR or IGMP querier). In the figure, Ethernet 1/0/1 of Switch A and Ethernet 1/0/1 of Switch B are router ports. The switch registers all its local router ports in its router port list.
l Member port: A member port is a port on an Ethernet switch that leads the switch towards multicast group members. In the figure, Ethernet 1/0/2 and Ethernet 1/0/3 of Switch A and Ethernet 1/0/2 of Switch B are member ports. The switch registers all the member ports on the local device in its IGMP Snooping forwarding table.
l Whenever mentioned in this document, a router port is a port on the switch that leads the switch to a Layer 3 multicast device, rather than a port on a router.
l Unless otherwise specified, router/member ports mentioned in this document include static and dynamic ports.
l An IGMP-snooping-enabled switch deems that all its ports on which IGMP general queries with the source IP address other than 0.0.0.0 or PIM hello messages are received to be dynamic router ports. For details about PIM hello messages, see PIM Configuration of the IP Multicast Volume.
Aging timers for dynamic ports in IGMP Snooping and related messages and actions
Table 1-1 Aging timers for dynamic ports in IGMP Snooping and related messages and actions
Timer |
Message before expiry |
Action after expiry |
Dynamic router port aging timer |
For each dynamic router port, the switch sets a timer initialized to the dynamic router port aging time. |
IGMP general query of which the source address is not 0.0.0.0 or PIM hello |
The switch removes this port from its router port list. |
Dynamic member port aging timer |
When a port dynamically joins a multicast group, the switch sets a timer for the port, which is initialized to the dynamic member port aging time. |
IGMP membership report |
The switch removes this port from the IGMP Snooping forwarding table. |
The port aging mechanism of IGMP Snooping works only for dynamic ports; a static port will never age out.
How IGMP Snooping Works
A switch running IGMP Snooping performs different actions when it receives different IGMP messages, as follows:
The description about adding or deleting a port in this section is only for a dynamic port. Static ports can be added or deleted only through the corresponding configurations. For details, see Configuring Static Ports.
When receiving a general query
The IGMP querier periodically sends IGMP general queries to all hosts and routers (224.0.0.1) on the local subnet to find out whether active multicast group members exist on the subnet.
Upon receiving an IGMP general query, the switch forwards it through all ports in the VLAN except the receiving port and performs the following to the receiving port:
l If the receiving port is a dynamic router port existing in its router port list, the switch resets the aging timer of this dynamic router port.
l If the receiving port is not a dynamic router port existing in its router port list, the switch adds it into its router port list and sets an aging timer for this dynamic router port.
When receiving a membership report
A host sends an IGMP report to the IGMP querier in the following circumstances:
l Upon receiving an IGMP query, a multicast group member host responds with an IGMP report.
l When intended to join a multicast group, a host sends an IGMP report to the IGMP querier to announce that it is interested in the multicast information addressed to that group.
Upon receiving an IGMP report, the switch forwards it through all the router ports in the VLAN, resolves the address of the reported multicast group, and performs the following:
l If no forwarding table entry exists for the reported group, the switch creates an entry, adds the port as a dynamic member port to the outgoing port list, and starts a member port aging timer for that port.
l If a forwarding table entry exists for the reported group, but the port is not included in the outgoing port list for that group, the switch adds the port as a dynamic member port to the outgoing port list, and starts an aging timer for that port.
l If a forwarding table entry exists for the reported group and the port is included in the outgoing port list, which means that this port is already a dynamic member port, the switch resets the aging timer for that port.
A switch does not forward an IGMP report through a non-router port. The reason is as follows: Due to the IGMP report suppression mechanism applied on hosts, if the switch forwards a report message through a member port, all the attached hosts listening to the reported multicast address will suppress their own reports upon receiving this report, and this will prevent the switch from knowing whether the reported multicast group still has active members attached to that port.
For the description of IGMP report suppression mechanism applied on hosts, refer to IGMP Configuration in the IP Multicast Volume.
When receiving a leave message
When an IGMPv1 host leaves a multicast group, the host does not send an IGMP leave message, so the switch cannot know immediately that the host has left the multicast group. However, as the host stops sending IGMP reports as soon as it leaves a multicast group, the switch deletes the forwarding entry for the dynamic member port corresponding to the host from the forwarding table when its aging timer expires.
When an IGMPv2 or IGMPv3 host leaves a multicast group, the host sends an IGMP leave message to the multicast router.
When the switch receives an IGMP leave message on a dynamic member port, the switch first checks whether a forwarding table entry for the group address in the message exists, and, if one exists, whether the outgoing port list contains the port.
l If the forwarding table entry does not exist or if the outgoing port list does not contain the port, the switch discards the IGMP leave message instead of forwarding it to any port.
l If the forwarding table entry exists and the outgoing port list contains the port, the switch forwards the leave message to all router ports in the native VLAN. Because the switch does not know whether any other hosts attached to the port are still listening to that group address, the switch does not immediately remove the port from the outgoing port list of the forwarding table entry for that group; instead, it resets the aging timer for the port.
Upon receiving the IGMP leave message from a host, the IGMP querier resolves the multicast group address in the message and sends an IGMP group-specific query to that multicast group through the port that received the leave message. Upon receiving the IGMP group-specific query, the switch forwards it through all its router ports in the VLAN and all member ports for that multicast group, and performs the following to the port on which it received the IGMP leave message:
l If any IGMP report in response to the group-specific query is received on the port (suppose it is a dynamic member port) before its aging timer expires, this means that some host attached to the port is receiving or expecting to receive multicast data for that multicast group. The switch resets the aging timer of the port.
l If no IGMP report in response to the group-specific query is received on the port before its aging timer expires, this means that no hosts attached to the port are still listening to that group address: the switch removes the port from the outgoing port list of the forwarding table entry for that multicast group when the aging timer expires.
With Layer 3 multicast routing enabled, an IGMP Snooping switch processes multicast protocol messages differently under different conditions, specifically as follows:
1) If only IGMP is enabled, or both IGMP and PIM are enabled on the switch, the switch handles multicast protocol messages in the normal way.
2) In only PIM is enabled on the switch:
l The switch broadcasts IGMP messages as unknown messages in the VLAN.
l Upon receiving a PIM hello message, the switch will maintain the corresponding dynamic router port.
3) When IGMP is disabled on the switch:
l If PIM is disabled, the switch deletes all its dynamic member ports and dynamic router ports.
l If PIM is enabled, the switch deletes only its dynamic member ports without deleting its dynamic router ports.
On a switch with Layer-3 multicast routing enabled, use the display igmp group port-info command to view Layer-2 port information.
For details about the display igmp group port-info command, refer to IGMP Commands in the IP Multicast Volume.
4) When PIM is disabled on the switch:
l If IGMP is disabled, the switch deletes all its dynamic router ports.
l If IGMP is enabled, the switch maintains all its dynamic member ports and dynamic router ports.
Protocols and Standards
IGMP Snooping is documented in:
l RFC 4541: Considerations for Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping Switches
Complete these tasks to configure IGMP Snooping:
Task |
Remarks |
Required |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Configuring Maximum Multicast Groups that Can Be Joined on a Port |
Optional |
Optional |
l Configurations made in IGMP Snooping view are effective for all VLANs, while configurations made in VLAN view are effective only for ports belonging to the current VLAN. For a given VLAN, a configuration made in IGMP Snooping view is effective only if the same configuration is not made in VLAN view.
l Configurations made in IGMP Snooping view are effective for all ports; configurations made in Ethernet interface view are effective only for the current port; configurations made in Layer 2 aggregate interface view are effect only for the current interface; configurations made in port group view are effective only for all the ports in the current port group. For a given port, a configuration made in IGMP Snooping view is effective only if the same configuration is not made in Ethernet interface view, Layer 2 aggregate interface view or port group view.
l For IGMP Snooping, configurations made on a Layer 2 aggregate interface do not interfere with configurations made on its member ports; nor do they take part in aggregation calculations.
Configuration Prerequisites
Before configuring the basic functions of IGMP Snooping, complete the following task:
l Configure the corresponding VLANs.
Before configuring the basic functions of IGMP Snooping, prepare the following data:
l Version of IGMP Snooping.
Follow these steps to enable IGMP Snooping:
To do... |
Use the command... |
Remarks |
Enter system view |
system-view |
Enable IGMP Snooping globally and enter IGMP-Snooping view |
igmp-snooping |
Required Disabled by default |
Return to system view |
quit |
Enter VLAN view |
vlan vlan-id |
Enable IGMP Snooping in the VLAN |
igmp-snooping enable |
l IGMP Snooping must be enabled globally before it can be enabled in a VLAN.
l After enabling IGMP Snooping in a VLAN, you cannot enable IGMP and/or PIM on the corresponding VLAN interface.
l When you enable IGMP Snooping in a specified VLAN, this function takes effect for the ports in this VLAN only.
By configuring an IGMP Snooping version, you actually configure the version of IGMP messages that IGMP Snooping can process.
l IGMP Snooping version 2 can process IGMPv1 and IGMPv2 messages, but not IGMPv3 messages, which will be flooded in the VLAN.
l IGMP Snooping version 3 can process IGMPv1, IGMPv2 and IGMPv3 messages.
Follow these steps to configure the version of IGMP Snooping:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
Configure the version of IGMP Snooping |
igmp-snooping version version-number |
Optional Version 2 by default |
If you switch IGMP Snooping from version 3 to version 2, the system will clear all IGMP Snooping forwarding entries from dynamic joins, and will:
l Keep forwarding entries for version 3 static (*, G) joins;
l Clear forwarding entries from version 3 static (S, G) joins, which will be restored when IGMP Snooping is switched back to version 3.
For details about static joins, Refer to Configuring Static Ports.
Before configuring IGMP Snooping port functions, complete the following tasks:
l Enable IGMP Snooping in the VLAN or enable IGMP on the VLAN interface
l Configure the corresponding port groups.
Before configuring IGMP Snooping port functions, prepare the following data:
l Aging time of dynamic router ports,
l Aging time of dynamic member ports, and
l Multicast group and multicast source addresses
If the switch receives no IGMP general queries or PIM hello messages on a dynamic router port, the switch removes the port from the router port list when the aging timer of the port expires.
If the switch receives no IGMP reports for a multicast group on a dynamic member port, the switch removes the port from the outgoing port list of the forwarding table entry for that multicast group when the aging timer of the port for that group expires.
If multicast group memberships change frequently, you can set a relatively small value for the dynamic member port aging timer, and vice versa.
Configuring aging timers for dynamic ports globally
Follow these steps to configure aging timers for dynamic ports globally:
To do... |
Remarks |
Enter system view |
system-view |
Enter IGMP Snooping view |
igmp-snooping |
Configure dynamic router port aging time |
router-aging-time interval |
Optional 105 seconds by default |
Configure dynamic member port aging time |
host-aging-time interval |
Optional 260 seconds by default |
Configuring aging timers for dynamic ports in a VLAN
Follow these steps to configure aging timers for dynamic ports in a VLAN:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
igmp-snooping router-aging-time interval |
igmp-snooping host-aging-time interval |
If all the hosts attached to a port are interested in the multicast data addressed to a particular multicast group or the multicast data that a particular multicast source sends to a particular group, you can configure static (*, G) or (S, G) joining on that port, namely configure the port as a group-specific or source-and-group-specific static member port.
You can configure a port of a switch to be a static router port, through which the switch can forward all the multicast traffic it received.
Follow these steps to configure static ports:
To do... |
Remarks |
Enter system view |
system-view |
Enter Ethernet interface/Layer 2 aggregate interface view or port group view |
Required Use either approach |
port-group manual port-group-name |
Configure the port(s) as static member port(s) |
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id |
Required No static member ports by default |
Configure the port(s) as static router port(s) |
igmp-snooping static-router-port vlan vlan-id |
Required No static router ports by default |
l A static member port does not respond to queries from the IGMP querier; when static (*, G) or (S, G) joining is enabled or disabled on a port, the port does not send an unsolicited IGMP report or an IGMP leave message.
l If IGMP is enabled on the virtual interface of a VLAN on a switch that supports both IGMP Snooping and IGMP and you want a port in that VLAN to be a static multicast group or source-group member port, in addition to configuring the port as a static member port, you need to use the igmp static-group command to configure the VLAN interface to be a static member of the multicast group or source and group. For details of the igmp static-group command, refer to IGMP Commands in the IP Multicast Volume.
l Static member ports and static router ports never age out. To remove such a port, you need to use the corresponding undo command.
Configuring Simulated Joining
Generally, a host running IGMP responds to IGMP queries from the IGMP querier. If a host fails to respond due to some reasons, the multicast router may deem that no member of this multicast group exists on the network segment, and therefore will remove the corresponding forwarding path.
To avoid this situation from happening, you can enable simulated joining on a port of the switch, namely configure the port as a simulated member host for a multicast group. When receiving an IGMP query, the simulated host gives a response. Thus, the switch can continue receiving multicast data.
A simulated host acts like a real host, as follows:
l When a port is configured as a simulated member host, the switch sends an unsolicited IGMP report through that port.
l After a port is configured as a simulated member host, the switch responds to IGMP general queries by sending IGMP reports through that port.
l When the simulated joining function is disabled on a port, the switch sends an IGMP leave message through that port.
Follow these steps to configure simulated joining:
To do... |
Remarks |
Enter system view |
system-view |
Configure simulated (*, G) or (S, G) joining |
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id |
l Each simulated host is equivalent to an independent host. For example, when receiving an IGMP query, the simulated host corresponding to each configuration responds respectively.
l Unlike a static member port, a port configured as a simulated member host will age out like a dynamic member port.
In VLANs where only one host is attached to each port, fast leave processing helps improve bandwidth and resource usage.
Configuring fast leave processing globally
Follow these steps to configure fast leave processing globally:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Enable fast leave processing |
fast-leave [ vlan vlan-list ] |
Configuring fast leave processing on a port or a group of ports
Follow these steps to configure fast leave processing on a port or a group of ports:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping fast-leave [ vlan vlan-list ] |
If fast leave processing is enabled on a port to which more than one host is attached, when one host leaves a multicast group, the other hosts attached to the port and interested in the same multicast group will fail to receive multicast data for that group.
Before configuring IGMP Snooping querier, complete the following task:
l Enable IGMP Snooping in the VLAN.
Before configuring IGMP Snooping querier, prepare the following data:
l IGMP general query interval,
l IGMP last-member query interval,
l Maximum response time to IGMP general queries,
l Source address of IGMP general queries, and
l Source address of IGMP group-specific queries.
However, a Layer 2 multicast switch does not support IGMP, and therefore cannot send general queries by default. By enabling IGMP Snooping on a Layer 2 switch in a VLAN where multicast traffic needs to be Layer-2 switched only and no multicast routers are present, the Layer 2 switch will act as the IGMP Snooping querier to send IGMP queries, thus allowing multicast forwarding entries to be established and maintained at the data link layer.
Follow these steps to enable IGMP Snooping querier:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
Enable IGMP Snooping querier |
igmp-snooping querier |
It is meaningless to configure an IGMP Snooping querier in a multicast network running IGMP. Although an IGMP Snooping querier does not take part in IGMP querier elections, it may affect IGMP querier elections because it sends IGMP general queries with a low source IP address.
For details about IGMP querier, see IGMP Configuration of the IP Multicast Volume.
You can tune the IGMP general query interval based on actual condition of the network.
Upon receiving an IGMP query (general query or group-specific query), a host starts a timer for each multicast group it has joined. This timer is initialized to a random value in the range of 0 to the maximum response time (the host obtains the value of the maximum response time from the Max Response Time field in the IGMP query it received). When the timer value comes down to 0, the host sends an IGMP report to the corresponding multicast group.
An appropriate setting of the maximum response time for IGMP queries allows hosts to respond to queries quickly and avoids bursts of IGMP traffic on the network caused by reports simultaneously sent by a large number of hosts when the corresponding timers expire simultaneously.
l For IGMP general queries, you can configure the maximum response time to fill their Max Response time field.
l For IGMP group-specific queries, you can configure the IGMP last-member query interval to fill their Max Response time field. Namely, for IGMP group-specific queries, the maximum response time equals to the IGMP last-member query interval.
Configuring IGMP queries and responses globally
Follow these steps to configure IGMP queries and responses globally:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Configure the maximum response time to IGMP general queries |
max-response-time interval |
Optional 10 seconds by default |
Configure the IGMP last-member query interval |
last-member-query-interval interval |
Optional 1 second by default |
Configuring IGMP queries and responses in a VLAN
Follow these steps to configure IGMP queries and responses in a VLAN:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
Configure IGMP general query interval |
igmp-snooping query-interval interval |
Optional 60 seconds by default |
igmp-snooping max-response-time interval |
igmp-snooping last-member-query-interval interval |
In the configuration, make sure that the IGMP general query interval is larger than the maximum response time for IGMP general queries. Otherwise, multicast group members may be deleted by mistake.
Upon receiving an IGMP query whose source IP address is 0.0.0.0 on a port, the switch does not enlist that port as a dynamic router port. This may prevent multicast forwarding entries from being correctly created at the data link layer and cause multicast traffic forwarding failure in the end. When a Layer 2 device acts as an IGMP-Snooping querier, to avoid the aforesaid problem, you are commended to configure a non-all-zero IP address as the source IP address of IGMP queries.
Follow these steps to configure source IP address of IGMP queries:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
Configure the source address of IGMP general queries |
igmp-snooping general-query source-ip { current-interface | ip-address } |
Optional 0.0.0.0 by default |
Configure the source IP address of IGMP group-specific queries |
igmp-snooping special-query source-ip { current-interface | ip-address } |
The source address of IGMP query messages may affect IGMP querier selection within the segment.
Before configuring an IGMP Snooping policy, complete the following task:
l Enable IGMP Snooping in the VLAN or enable IGMP on the desired VLAN interface
Before configuring an IGMP Snooping policy, prepare the following data:
l ACL rule for multicast group filtering
l The maximum number of multicast groups that can pass the ports
On an IGMP Snooping–enabled switch, the configuration of a multicast group allows the service provider to define restrictions on multicast programs available to different users.
In an actual application, when a user requests a multicast program, the user’s host initiates an IGMP report. Upon receiving this report message, the switch checks the report against the configured ACL rule. If the port on which the report was received can join this multicast group, the switch adds an entry for this port in the IGMP Snooping forwarding table; otherwise the switch drops this report message. Any multicast data that has failed the ACL check will not be sent to this port. In this way, the service provider can control the VOD programs provided for multicast users.
Configuring a multicast group filter globally
Follow these steps to configure a multicast group filter globally:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Configure a multicast group filter |
group-policy acl-number [ vlan vlan-list ] |
Required No group filter is configured by default. |
Configuring a multicast group filter on a port or a group of ports
Follow these steps to configure a multicast group filter on a port or a group of ports:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping group-policy acl-number [ vlan vlan-list ] |
With the multicast source port filtering feature enabled on a port, the port can be connected with multicast receivers only rather than with multicast sources, because the port will block all multicast data packets while it permits multicast protocol packets to pass.
If this feature is disabled on a port, the port can be connected with both multicast sources and multicast receivers.
Configuring multicast source port filtering globally
Follow these steps to configure multicast source port filtering globally:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Enable multicast source port filtering |
source-deny port interface-list |
Configuring multicast source port filtering on a port or a group of ports
Follow these steps to configure multicast source port filtering on a port or a group of ports:
To do... |
Remarks |
Enter system view |
system-view |
Enter Ethernet interface view or port group view |
igmp-snooping source-deny |
When you enable the switch to filter IPv4 multicast data based on the source ports, the switch is automatically enabled to filter IPv6 multicast data based on the source ports.
Unknown multicast data refers to multicast data for which no entries exist in the IGMP Snooping forwarding table. When receiving such multicast traffic, the switch floods it in the VLAN, incurring network bandwidth waste and low forwarding efficiency.
With the function of dropping unknown multicast data enabled, the switch forwards unknown multicast data to its router ports instead of flooding it in the VLAN. If no router ports exist, the switch drops the unknown multicast data
Configuring globally the function of dropping unknown multicast data
Follow these steps to configure globally the function of dropping unknown multicast data:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Enable the function of dropping unknown multicast data |
drop-unknown |
Configuring the function of dropping unknown multicast data in a VLAN
Follow these steps to configure the function of dropping unknown multicast data in a VLAN:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN view |
vlan vlan-id |
igmp-snooping drop-unknown |
l The configuration made in IGMP Snooping view and the configuration made in VLAN view are mutually exclusive. Namely, after this function is enabled in IGMP Snooping view, it cannot be enabled or disabled in VLAN view, and vice versa.
l When enabled to drop unknown IPv4 multicast data, the S7500E series switches are automatically enabled to drop unknown IPv6 multicast data.
When a Layer 2 device receives an IGMP report from a multicast group member, the device forwards the message to the Layer 3 device directly connected with it. Thus, when multiple members of a multicast group are attached to the Layer 2 device, the Layer 3 device directly connected with it will receive duplicate IGMP reports from these members.
With the IGMP report suppression function enabled, within each query cycle, the Layer 2 device forwards only the first IGMP report per multicast group to the Layer 3 device and will not forward the subsequent IGMP reports from the same multicast group to the Layer 3 device. This helps reduce the number of packets being transmitted over the network.
Follow these steps to configure IGMP report suppression:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Enable IGMP report suppression |
report-aggregation |
Optional Enabled by default |
By configuring the maximum number of multicast groups that can be joined on a port, you can limit the number of multicast programs on-demand available to users, thus to regulate traffic on the port.
Follow these steps to configure the maximum number of multicast groups allowed on a port or ports:
To do... |
Remarks |
Enter system view |
system-view |
Configure the maximum number of multicast groups allowed on the port(s) |
igmp-snooping group-limit limit [ vlan vlan-list ] |
Optional 1000 by default. |
l When the number of multicast groups a port has joined reaches the maximum number configured, the system deletes all the forwarding entries persistent to that port from the IGMP Snooping forwarding table, and the hosts on this port need to join the multicast groups again.
l If you have configured static or simulated joins on a port, however, when the number of multicast groups on the port exceeds the configured threshold, the system deletes all the forwarding entries persistent to that port from the IGMP Snooping forwarding table and applies the static or simulated joins again, until the number of multicast groups joined by the port comes back within the configured threshold.
For some special reasons, the number of multicast groups that can be joined on the current switch or port may exceed the number configured for the switch or the port. In addition, in some specific applications, a multicast group newly joined on the switch needs to replace an existing multicast group automatically. A typical example is “channel switching”, namely, by joining a new multicast group, a user automatically switches from the current multicast group to the new one.
To address such situations, you can enable the multicast group replacement function on the switch or certain ports. When the number of multicast groups joined on the switch or a port has joined reaches the limit:
l If the multicast group replacement feature is enabled, the newly joined multicast group automatically replaces an existing multicast group with the lowest address.
l If the multicast group replacement feature is not enabled, new IGMP reports will be automatically discarded.
Configuring multicast group replacement globally
Follow these steps to configure multicast group replacement globally:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping |
Enable multicast group replacement |
overflow-replace [ vlan vlan-list ] |
Configuring multicast group replacement on a port or a group of ports
Follow these steps to configure multicast group replacement on a port or a group of ports:
To do... |
Remarks |
Enter system view |
system-view |
igmp-snooping overflow-replace [ vlan vlan-list ] |
Be sure to configure the maximum number of multicast groups allowed on a port which cannot be the default value 1000 (refer to Configuring Maximum Multicast Groups that Can Be Joined on a Port) before enabling multicast group replacement. Otherwise, the multicast group replacement functionality will not take effect.
To do... |
Remarks |
View IGMP Snooping multicast group information |
display igmp-snooping group [ vlan vlan-id ] [ slot slot-number ] [ verbose ] |
Available in any view |
View the statistics information of IGMP messages learned by IGMP Snooping |
display igmp-snooping statistics |
Clear IGMP Snooping multicast group information |
reset igmp-snooping group { group-address | all } [ vlan vlan-id ] |
Available in user view |
Clear the statistics information of all kinds of IGMP messages learned by IGMP Snooping |
reset igmp-snooping statistics |
l The reset igmp-snooping group command works only on an IGMP Snooping–enabled VLAN, but not on a VLAN with IGMP enabled on its VLAN interface.
l The reset igmp-snooping group command cannot clear the IGMP Snooping multicast group information for static joins.
Network requirements
l As shown in Figure 1-3, Router A connects to the multicast source through Ethernet 1/0/2 and to Switch A through Ethernet 1/0/1.
l IGMPv2 is required on Router A, IGMP Snooping version 2 is required on Switch A, and Router A will act as the IGMP querier on the subnet.
l It is required that the receivers, Host A and Host B, attached to Switch A can receive multicast traffic addressed to multicast group 224.1.1.1 only.
l It is required that multicast data for group 224.1.1.1 can be forwarded through Ethernet 2/0/3 and Ethernet 2/0/4 of Switch A even if Host A and Host B accidentally, temporarily stop receiving multicast data.
Network diagram
Figure 1-3 Network diagram for group policy simulated joining configuration
Configuration procedure
Configure an IP address and subnet mask for each interface as per Figure 1-3. The detailed configuration steps are omitted.
2) Configure Router A
# Enable IP multicast routing, enable PIM-DM on each interface, and enable IGMP on Ethernet 1/0/1.
[RouterA] multicast routing-enable
[RouterA] interface Ethernet 1/0/1
[RouterA-Ethernet1/0/1] igmp enable
[RouterA-Ethernet1/0/1] pim dm
[RouterA-Ethernet1/0/1] quit
[RouterA] interface Ethernet 1/0/2
[RouterA-Ethernet1/0/2] pim dm
[RouterA-Ethernet1/0/2] quit
3) Configure Switch A
# Enable IGMP Snooping globally.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Create VLAN 100, assign Ethernet 2/0/1 through Ethernet 2/0/4 to this VLAN, and enable IGMP Snooping and the function of dropping unknown multicast traffic in the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 2/0/1 to Ethernet 2/0/4
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] igmp-snooping drop-unknown
[SwitchA-vlan100] quit
# Configure a multicast group filter so that the hosts in VLAN 100 can join only the multicast group 224.1.1.1.
[SwitchA] acl number 2001
[SwitchA-acl-basic-2001] rule permit source 224.1.1.1 0
[SwitchA-acl-basic-2001] quit
[SwitchA-igmp-snooping] group-policy 2001 vlan 100
# Configure Ethernet 2/0/3 and Ethernet 2/0/4 as simulated hosts for multicast group 224.1.1.1.
[SwitchA] interface Ethernet 2/0/3
[SwitchA-Ethernet2/0/3] igmp-snooping host-join 224.1.1.1 vlan 100
[SwitchA-Ethernet2/0/3] quit
[SwitchA] interface Ethernet 2/0/4
[SwitchA-Ethernet2/0/4] igmp-snooping host-join 224.1.1.1 vlan 100
[SwitchA-Ethernet2/0/4] quit
4) Verify the configuration
# View the detailed IGMP Snooping multicast groups information in VLAN 100 on Switch A.
[SwitchA] display igmp-snooping group vlan 100 verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, C-Copy port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):100.
Router port unit board: Mask(0x8 3)
Router port(s):total 1 port.
Eth2/0/1 (D)
IP group(s):the following ip group(s) match to one mac group.
IP group address:224.1.1.1
(0.0.0.0, 224.1.1.1):
Attribute: Host Port
Host port unit board: Mask(0x8 3)
Host port(s):total 2 port.
Eth2/0/3 (D)
Eth2/0/4 (D)
MAC group(s):
MAC group address:0100-5e01-0101
Eth2/0/3
Eth2/0/4
As shown above, Ethernet 2/0/3 and Ethernet 2/0/4 of Switch A has joined multicast group 224.1.1.1.
Static Port Configuration
l As shown in Figure 1-4, Router A connects to a multicast source (Source) through Ethernet 1/0/2, and to Switch A through Ethernet 1/0/1.
l IGMPv2 is to run on Router A, and IGMPv2 Snooping is to run on Switch A, Switch B and Switch C, with Router A acting as the IGMP querier.
l Host A and host C are permanent receivers of multicast group 224.1.1.1. Ethernet 2/0/3 and Ethernet 2/0/5 on Switch C are required to be configured as static member ports for multicast group 224.1.1.1 to enhance the reliability of multicast traffic transmission.
l Suppose STP runs on the network. To avoid data loops, the forwarding path from Switch A to Switch C is blocked under normal conditions, and multicast traffic flows to the receivers attached to Switch C only along the path of Switch A—Switch B—Switch C.
l It is required to configure Ethernet 2/0/3 that connects Switch A to Switch C as a static router port, so that multicast traffic can flow to the receivers nearly uninterruptedly along the path of Switch A—Switch C in the case that the path of Switch A—Switch B—Switch C gets blocked.
If no static router port is configured, when the path of Switch A—Switch B—Switch C gets blocked, at least one IGMP query-response cycle must be completed before the multicast data can flow to the receivers along the new path of Switch A—Switch C, namely multicast delivery will be interrupted during this process.
For details about the Spanning Tree Protocol (STP), refer to MSTP Configuration in the Access Volume.
Network diagram
Figure 1-4 Network diagram for static port configuration
1) Configure IP addresses
Configure an IP address and subnet mask for each interface as per Figure 1-4. The detailed configuration steps are omitted.
# Create VLAN 100, assign Ethernet 2/0/1 through Ethernet 2/0/3 to this VLAN, and enable IGMP Snooping in the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 2/0/1 to Ethernet 2/0/3
# Configure Ethernet 2/0/3 to be a static router port.
[SwitchA-Ethernet2/0/3] igmp-snooping static-router-port vlan 100
4) Configure Switch B
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
# Create VLAN 100, assign Ethernet 2/0/1 and Ethernet 2/0/2 to this VLAN, and enable IGMP Snooping in the VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port Ethernet 2/0/1 Ethernet 2/0/2
[SwitchB-vlan100] igmp-snooping enable
[SwitchB-vlan100] quit
5) Configure Switch C
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
# Create VLAN 100, assign Ethernet 2/0/1 through Ethernet 2/0/5 to this VLAN, and enable IGMP Snooping in the VLAN.
[SwitchC] vlan 100
[SwitchC-vlan100] port Ethernet 2/0/1 to Ethernet 2/0/5
[SwitchC-vlan100] igmp-snooping enable
[SwitchC-vlan100] quit
# Configure Ethernet 2/0/3 and Ethernet 2/0/5 as static member ports for multicast group 224.1.1.1.
[SwitchC] interface Ethernet 2/0/3
[SwitchC-Ethernet2/0/3] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchC-Ethernet2/0/3] quit
[SwitchC] interface Ethernet 2/0/5
[SwitchC-Ethernet2/0/5] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchC-Ethernet2/0/5] quit
6) Verify the configuration
# View the detailed IGMP Snooping multicast group information in VLAN 100 on Switch A.
Vlan(id):100.
Router port(s):total 2 port.
Eth2/0/1 (D)
Eth2/0/3 (S)
Host port(s):total 1 port.
Eth2/0/2 (D)
MAC group(s):
Eth2/0/2
As shown above, Ethernet 2/0/3 of Switch A has become a static router port.
# View the detailed IGMP Snooping multicast group information in VLAN 100 on Switch C.
[SwitchC] display igmp-snooping group vlan 100 verbose
Vlan(id):100.
Eth2/0/2 (D)
Eth2/0/3 (S)
Eth2/0/5 (S)
MAC group(s):
Eth2/0/3
Eth2/0/5
As shown above, Ethernet 2/0/3 and Ethernet 2/0/5 on Switch C have become static member ports for multicast group 224.1.1.1.
l As shown in Figure 1-5, in a Layer 2–only network environment, two multicast sources Source 1 and Source 2 send multicast data to multicast groups 224.1.1.1 and 225.1.1.1 respectively, Host A and Host C are receivers of multicast group 224.1.1.1, while Host B and Host D are receivers of multicast group 225.1.1.1.
l All the receivers are running IGMPv2, and all the switches need to run IGMP Snooping version 2. Switch A, which is close to the multicast sources, is chosen as the IGMP-Snooping querier.
l To prevent flooding of unknown multicast traffic within the VLAN, it is required to configure all the switches to drop unknown multicast data packets.
l Because a switch does not enlist a port that has heard an IGMP query with a source IP address of 0.0.0.0 (default) as a dynamic router port, configure a non-all-zero IP address as the source IP address of IGMP queries to ensure normal creation of Layer 2 multicast forwarding entries.
Network diagram
Figure 1-5 Network diagram for IGMP Snooping querier configuration
1) Configure switch A
# Create VLAN 100 and assign Ethernet 2/0/1 through Ethernet 2/0/3 to the VLAN.
[SwitchA] vlan 100
# Enable IGMP Snooping and the function of dropping unknown multicast traffic in VLAN 100.
# Enable the IGMP-Snooping querier function in VLAN 100
[SwitchA-vlan100] igmp-snooping querier
# Set the source IP address of IGMP general queries and group-specific queries to 192.168.1.1 in VLAN 100.
[SwitchA-vlan100] igmp-snooping general-query source-ip 192.168.1.1
[SwitchA-vlan100] igmp-snooping special-query source-ip 192.168.1.1
2) Configure Switch B
# Create VLAN 100, and assign Ethernet 2/0/1 through Ethernet 2/0/4 to the VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port Ethernet 2/0/1 to Ethernet 2/0/4
[SwitchB-vlan100] igmp-snooping drop-unknown
Configurations on Switch C and Switch D are similar to the configuration on Switch B.
3) Verify the configuration
After the IGMP Snooping querier starts to work, all the switches but the querier can receive IGMP general queries. By using the display igmp-snooping statistics command, you can view the statistics information about the IGMP messages received. For example:
# View the IGMP message statistics on Switch B.
[SwitchB] display igmp-snooping statistics
Received IGMP general queries:3.
Received IGMPv1 reports:0.
Received IGMPv2 reports:12.
Received IGMP leaves:0.
Received IGMPv2 specific queries:0.
Sent IGMPv2 specific queries:0.
Received IGMPv3 reports:0.
Received IGMPv3 reports with right and wrong records:0.
Received IGMPv3 specific queries:0.
Received IGMPv3 specific sg queries:0.
Sent IGMPv3 specific queries:0.
Sent IGMPv3 specific sg queries:0.
Received error IGMP messages:0.
Symptom
A switch fails to implement Layer 2 multicast forwarding.
Analysis
IGMP Snooping is not enabled.
Solution
1) Enter the display current-configuration command to view the running status of IGMP Snooping.
2) If IGMP Snooping is not enabled, use the igmp-snooping command to enable IGMP Snooping globally, and then use igmp-snooping enable command to enable IGMP Snooping in VLAN view.
3) If IGMP Snooping is disabled only for the corresponding VLAN, just use the igmp-snooping enable command in VLAN view to enable IGMP Snooping in the corresponding VLAN.
Symptom
Although a multicast group policy has been configured to allow hosts to join specific multicast groups, the hosts can still receive multicast data addressed to other multicast groups.
Analysis
l The ACL rule is incorrectly configured.
l The multicast group policy is not correctly applied.
l The function of dropping unknown multicast data is not enabled, so unknown multicast data is flooded.
Solution
1) Use the display acl command to check the configured ACL rule. Make sure that the ACL rule conforms to the multicast group policy to be implemented.
2) Use the display this command in IGMP Snooping view or in the corresponding interface view to check whether the correct multicast group policy has been applied. If not, use the group-policy or igmp-snooping group-policy command to apply the correct multicast group policy.
3) Use the display current-configuration command to check whether the function of dropping unknown multicast data is enabled. If not, use the drop-unknown or igmp-snooping drop-unknown command to enable the function of dropping unknown multicast data.
