02-IP Services Volume
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E Series Ethernet Switches Operation Manual(Release 6300 series V1.03)02-IP Services Volume
06-UDP Helper Configuration
06-UDP Helper Configuration 57.95 KB
When configuring UDP Helper, go to these sections for information you are interested in:
l          Introduction to UDP Helper
l          Configuring UDP Helper
l          Displaying and Maintaining UDP Helper
l          UDP Helper Configuration Examples
UDP Helper can be currently configured on VLAN interfaces only.
Sometimes, a host needs to forward broadcasts to obtain network configuration information or request the names of other devices on the network. However, if the server or the device to be requested is located in another broadcast domain, the host cannot obtain such information through broadcast.
To solve this problem, the device provides the UDP Helper function to relay specified UDP packets. In other words, UDP Helper functions as a relay agent that converts UDP broadcast packets into unicast packets and forwards them to a specified destination server.
With UDP Helper enabled, the device decides whether to forward a received UDP broadcast packet according to the UDP destination port number of the packet.
l          If the destination port number of the packet matches the one pre-configured on the device, the device modifies the destination IP address in the IP header, and then sends the packet to the specified destination server.
l          If not, the device sends the packet to the upper layer protocol for processing.
Follow these steps to configure UDP Helper:
To do…
Use the command…
Remarks
Enter system view
Enable UDP Helper
udp-helper enable
Required
Disabled by default.
Enable the forwarding of packets with the specified UDP destination port number(s)
Required
No UDP port number is specified by default.
Enter interface view
Specify the destination server to which UDP packets are to be forwarded
udp-helper server ip-address
Required
No destination server is specified by default.
l          The UDP Helper enabled device cannot forward DHCP broadcast packets. That is to say, the UDP port number cannot be set to 67 or 68.
l          For the dns, netbios-ds, netbios-ns, tacacs, tftp, and time keywords, you can specify port numbers or the corresponding parameters. For example, udp-helper port 53 and udp-helper port dns specify the same UDP port number.
l          The configuration of all UDP ports is removed if you disable UDP Helper.
l          You can configure up to 256 UDP port numbers to enable the forwarding of packets with these UDP port numbers.
l          You can configure up to 20 destination servers on an interface.
To do…
Use the command…
Remarks
Displays the information of forwarded UDP packets
display udp-helper server [ interface interface-type interface-number ]
Available in any view
Clear statistics about packets forwarded
reset udp-helper packet
Available in user view
Network requirements
On Switch A, configure UDP helper to forward broadcast packets (with UDP destination port number 55 and destination IP address 255.255.255.255 or 10.110.255.255 to the destination server 10.2.1.1/16.
Network diagram
Figure 1-1 Network diagram for UDP Helper configuration
Configuration procedure
The following configuration assumes that a route from Switch A to the network segment 10.2.0.0/16 is available.
# Enable UDP Helper.
[SwitchA] udp-helper enable
# Enable the forwarding broadcast packets with the UDP destination port 55.
[SwitchA] udp-helper port 55
# Specify the destination server 10.2.1.1 on VLAN-interface 1.
[SwitchA-Vlan-interface1] ip address 10.110.1.1 16
[SwitchA-Vlan-interface1] udp-helper server 10.2.1.1
