- 01-Access Volume
- 00-Access Volume Organization
- 01-Ethernet Interface Commands
- 02-Link Aggregation Commands
- 03-Port Isolation Commands
- 04-Service Loopback Group Commands
- 05-DLDP Commands
- 06-Smart Link Commands
- 07-LLDP Commands
- 08-VLAN Commands
- 09-GVRP Commands
- 10-QinQ Commands
- 11-BPDU Tunneling Commands
- 12-VLAN Mapping Commands
- 13-Ethernet OAM Commands
- 14-Connectivity Fault Detection Commands
- 15-EPON OLT Commands
- 16-MSTP Commands
- 17-RRPP Commands
- 18-Mirroring Commands
| 13-Ethernet OAM Commands | 74.02 KB |
Table of Contents
1 Ethernet OAM Configuration Commands
oam errored-frame-period period
oam errored-frame-period threshold
oam errored-frame-seconds period
oam errored-frame-seconds threshold
display oam
display oam { local | remote } [ interface interface-type interface-number ]
View
Default Level
2: System level
local: Displays the Ethernet OAM connection information of the local end.
remote: Displays the Ethernet OAM connection information of the remote end..
interface interface-type interface-number: Specify a port by its type and number..
Use the display oam command to display the information about an Ethernet OAM connection, including connection status, information contained in Ethernet OAM packet header, and Ethernet OAM packet statistics.
If you do not specify the interface keyword, this command displays the information about all the Ethernet OAM connections.
Related commands: reset oam.
# Display the local Ethernet OAM connection information.
<Sysname> display oam local
Port : GigabitEthernet2/0/1
Link Status : Up
EnableStatus : Enable
Local_oam_mode : Active Local_pdu : ANY
Local_mux_action : FWD Local_par_action : DISCARD
Port : Ethernet1/2
Link Status : Down
Local_oam_mode : Active Local_pdu : LF_INFO
Local_mux_action : FWD Local_par_action : FWD
Table 1-1 display oam local command output description
Port |
Port index |
Link Status |
Link status |
EnableStatus |
Ethernet OAM state (enabled or disabled) |
Local_oam_mode |
Local Ethernet OAM mode, which can be: l Active, indicating the port operates in the active Ethernet OAM mode l Passive, indicating the port operates in the passive Ethernet OAM mode |
Local_pdu |
The way in which Ethernet OAMPDUs of different types are processed locally. This field can be: l RX_INFO, indicating the port only receives Information OAMPDUs and does not send Ethernet OAMPDUs. l LF_INFO, indicating the port only sends the Information OAMPDUs without Information TLV triplets and with their link error flag bits being set l INFO, indicating the port only sends and receives Information OAMPDUs l ANY, indicating the port sends and receives Ethernet OAMPDUs of any types |
Local_mux_action |
Local sending mode, which can be: l FWD, indicating the port can send any packets l DISCARD, indicating the port only sends Ethernet OAMPDUs |
Local_par_action |
Local receiving mode, which can be: l FWD, indicating the port can receive any packets l DISCARD, indicating the port only receives Ethernet OAMPDUs l LB, indicating Ethernet OAM loopback testing is enabled on the port. In this case, all the packets other than Ethernet OAMPDUs received are returned to their sources along the ways they come. |
# Display the information about the Ethernet OAM connection established on the local port GigabitEthernet 2/0/1.
<Sysname> display oam local interface GigabitEthernet 2/0/1
Link Status : Up
OAMLocalFlagsField :
Link Fault : 0 Dying Gasp : 0
Critical Event : 0 Local Evaluating : COMPLETE
Remote Evaluating : COMPLETE
Packets statistic :
Packets Send Receive
OAMPDU 645 648
OAMInformation 645 648
OAMEventNotification 0 --
OAMUniqueEventNotification -- 0
OAMDuplicateEventNotification -- 0
Table 1-2 display oam local interface command output description
Port |
Port index |
Link Status |
Link status |
EnableStatus |
Local_oam_mode |
Local Ethernet OAM mode. Refer to Table 1-1 for more. |
Local_pdu |
The way in which Ethernet OAMPDUs of different types are processed locally. Refer to Table 1-1 for more. |
Local_mux_action |
Local sending mode. Refer to Table 1-1 for more. |
Local_par_action |
Local receiving mode. Refer to Table 1-1 for more. |
OAMLocalFlagsField |
Local flags inserted in the local flag fields of the Ethernet OAMPDUs sent |
Link Fault |
Indicates whether Ethernet OAM link error events occurred. A value of 0 indicates no Ethernet OAM error event occurs; a value of 1 indicates Ethernet OAM error event occurrences. |
Dying Gasp |
Indicate whether Dying Gasp events occurred. A value of 0 indicates no Dying Gasp event occurs; a value of 1 indicates Dying Gasp event occurrences. |
Critical Event |
Indicates whether Critical Events occurred. A value of 0 indicates no Critical event occurs; a value of 1 indicates Critical event occurrences. |
Local Evaluating |
Indicates whether the local-to-remote configuration negotiation is complete. |
Remote Evaluating |
Indicates whether the remote-to-local configuration negotiation is complete. |
Packets statistic |
Statistics on Ethernet OAMPDUs sent and received |
OAMPDU |
Total number of the Ethernet OAMPDUs sent and received |
OAMInformation |
Number of the Information OAMPDUs sent and received |
OAMEventNotification |
Number of the Event notification OAMPDUs sent and received |
OAMUniqueEventNotification |
Number of the unduplicated Event notification OAMPDUs sent or received uniquely |
OAMDuplicateEventNotification |
Number of the duplicate Event notification OAMPDUs sent or received |
# Display the peer Ethernet OAM connection information.
<Sysname> display oam remote
Port :GigabitEthernet2/0/1
Link Status :Up
Information of the latest received OAM packet:
OAMRemoteMACAddress : 00e0fc003552
OAMRemotePDUConfiguration : 1500
Remote_mux_action : FWD Remote_par_action : FWD
Table 1-3 display oam remote command output description
Port |
Port index |
Link Status |
Link status |
Information of the latest received OAM packet |
Information about the latest received Ethernet OAMPDU |
OAMRemoteMACAddress |
MAC address of the Ethernet OAM peer |
OAMRemotePDUConfiguration |
Maximum Ethernet OAMPDU size allowed |
Remote_mux_action |
Peer sending mode. Refer to Table 1-1 for more. |
Remote_par_action |
Peer receiving mode. Refer to Table 1-1 for more. |
# Display the Ethernet OAM information about the peer port GigabitEthernet 2/0/1.
<Sysname> display oam remote interface GigabitEthernet 2/0/1
Link Status : Up
OAMRemoteMACAddress : 00e0-fd73-6502
OAMRemoteState :
OAMRemoteConfiguration :
OAM Mode : Active Unidirectional Support : YES
Loopback Support : YES Link Events : YES
Variable Retrieval : NO
OAMRemoteFlagsField :
Table 1-4 display oam remote interface command output description
Port |
Port index |
Link Status |
Link status |
OAMRemoteState |
State of the Ethernet OAM peer |
Remote_mux_action |
Remote_par_action |
OAMRemoteConfiguration |
Configuration of the peer Ethernet OAM entity |
OAM Mode |
Ethernet OAM mode |
Unidirectional Support |
Indicates whether unidirectional transmission is supported (YES or NO) |
Loopback Support |
Indicates whether Ethernet OAM loopback testing is supported (YES or NO) |
Link Events |
Indicates whether Ethernet OAM link error events are supported (YES or NO) |
Variable Retrieval |
Indicates whether MIB variable retrieval is supported (YES or NO) |
OAMRemoteFlagsField |
Values of the peer Ethernet OAM flag fields in OAM packets |
Link Fault |
Indicates whether Ethernet OAM link error events occurred. Refer to Table 1-2 for more. |
Dying Gasp |
Indicate whether Dying Gasp events occurred. Refer to Table 1-2 for more. |
Critical Event |
Indicate whether Critical events occurred. Refer to Table 1-2 for more. |
Local Evaluating |
Remote Evaluating |
display oam configuration
View
Default Level
2: System level
None
Use the display oam configuration command to display global Ethernet OAM configuration, including the periods and thresholds for Ethernet OAM link error event detection.
Related commands: oam errored-frame period, oam errored-frame threshold, oam errored-frame-period period, oam errored-frame-period threshold, oam errored-frame-seconds period, oam errored-frame-seconds threshold.
# Display global Ethernet OAM configuration.
<Sysname> display oam configuration
Configuration of the link event window/threshold :
Errored-symbol Event period(in seconds) : 1
Errored-symbol Event threshold : 1
Errored-frame Event period(in seconds) : 1
Errored-frame Event threshold : 1
Errored-frame-period Event period(in ms) : 1000
Errored-frame-period Event threshold : 1
Errored-frame-seconds Event period(in seconds) : 60
Errored-frame-seconds Event threshold : 1
Table 1-5 display oam configuration command output description
Configuration of the link event window/threshold |
Detection intervals and triggering thresholds configured for link events |
Errored-symbol Event period (in seconds) |
Errored symbol detection interval, which defaults to one second. |
Errored-symbol Event threshold |
Errored symbol event triggering threshold, which defaults to 1. |
Errored-frame Event period (in seconds) |
Errored frame detection interval, which defaults to one second. |
Errored-frame Event threshold |
Errored frame event triggering threshold, which defaults to 1. |
Errored-frame-period Event period (in ms) |
Errored frame period detection interval, which defaults to 1000 milliseconds. |
Errored-frame-period Event threshold |
Errored frame period event triggering threshold, which defaults to 1. |
Errored-frame-seconds Event period (in seconds) |
Errored frame seconds detection interval, which defaults to 60 seconds. |
Errored-frame-seconds Event threshold |
Errored frame seconds event triggering threshold, which defaults to 1. |
display oam critical-event
display oam critical-event [ interface interface-type interface-number]
View
Default Level
2: System level
interface interface-type interface-number: Specifies a port by its type and number.
Use the display oam critical-event command to display the statistics on critical Ethernet OAM link events occurred on a port.
If you do not specify the interface keyword, this command displays the statistics on the critical Ethernet OAM link events occurred on all the ports of the switch.
# Display the statistics on critical Ethernet OAM link events occurred on all the ports.
<Sysname> display oam critical-event
Link Status : Up
Event statistic :
Link Fault :0 Dying Gasp : 0 Critical Event : 0
Table 1-6 display oam critical-event command output description
Port |
Port index |
Link Status |
Link status |
Event statistic |
Statistics on critical Ethernet OAM link events |
Link Fault |
Dying Gasp |
Indicates whether Dying Gasp events occurred. Refer to Table 1-2 for more. |
Critical Event |
Indicates whether Critical events occurred. Refer to Table 1-2 for more. |
display oam link-event
display oam link-event { local | remote } [ interface interface-type interface-number ]
View
Default Level
2: System level
local: Displays the statistics on the local Ethernet OAM link error events.
remote: Displays the statistics on the peer Ethernet OAM link error events.
Use the display oam link-event command to display the statistics on Ethernet OAM link error events occurred on a local port or a peer port. Ethernet OAM link error events include errored symbol events, errored frame events, errored frame period events, and errored frame seconds events.
If you do not specify the interface keyword, this command displays the statistics on the Ethernet OAM link error events occurred on all the local/peer ports.
Related commands: display oam configuration.
# Display the statistics on Ethernet OAM link error events occurred on all the local ports.
<Sysname> display oam link-event local
Link Status : Up
OAMLocalErrFrameEvent : (ms = milliseconds)
Event Time Stamp : 3539 Errored Frame Window : 10(100ms)
Errored Frame Threshold : 5 Errored Frame : 1488111
Error Running Total : 260908758 Event Running Total : 307
OAMLocalErrFramePeriodEvent :
Event Time Stamp : 3539 Errored Frame Window : 976500
Errored Frame Threshold : 1 Errored Frame : 1042054
Error Running Total : 260909151 Event Running Total : 471
OAMLocalErrFrameSecsSummaryEvent : (ms = milliseconds)
Event Time Stamp : 3389
Errored Frame Second Summary Window : 600(100ms)
Errored Frame Second Summary Threshold : 1
Errored Frame Second Summary : 60
Error Running Total : 292 Event Running Total : 5
Table 1-7 display oam link-event local command output description
Port |
Port index |
Link Status |
Link status |
OAMLocalErrFrameEvent : (ms = milliseconds) |
Information about local errored frame events. l Event Time Stamp: time when an errored frame event occurred (in 100 milliseconds). l Errored Frame Window: Error frame detection interval (in 100 milliseconds). l Errored Frame Threshold: error threshold that triggers an errored frame event. l Errored Frame: the number of detected error frames over the specific detection interval. l Error Running Total: the total number of error frames. l Event Running Total: the total number of errored frame events that have occurred. |
OAMLocalErrFramePeriodEvent |
Information about local error frame period events: l Event Time Stamp: time when an errored frame event occurred (in 100 milliseconds). l Errored Frame Window: maximum number of 64-byte frames that can be transmitted through an Ethernet port over the configured error frame period detection interval. See oam errored-frame-period period command for more information. l Errored Frame Threshold: error threshold that triggers an error frame period event. l Errored Frame: the number of detected error frames over a detection interval. l Error Running Total: the total number of error frames that have detected. l Event Running Total: the total number of error frame period events. |
OAMLocalErrFrameSecsSummaryEvent : (ms = milliseconds) |
Information about local errored frame seconds events: l Event Time Stamp: time when an error frame seconds event occurred (in terms of 100 milliseconds). l Errored Frame Second Summary Window: error frame second detection interval (in 100 milliseconds). l Errored Frame Second Summary Threshold: error threshold that triggers an error frame seconds event. l Errored Frame Second Summary: the number of detected error frame seconds over a detection interval. l Error Running Total: the total number of error frame seconds. l Event Running Total: the total number of error frame seconds events that have occurred. |
oam enable
oam enable
undo oam enable
View
Ethernet port view
Default Level
2: System level
None
Use the oam enable command to enable Ethernet OAM on an the Ethernet port.
Use the undo oam enable command to disable Ethernet OAM on the Ethernet port.
By default, Ethernet OAM is disabled on all Ethernet ports.
After you enable Ethernet OAM for an Ethernet port, the port attempts to establish an OAM connection to the peer in the predetermined mode.
Related commands: oam mode.
# Enable OAM on GigabitEthernet 2/0/1.
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] oam enable
oam errored-frame period period-value
undo oam errored-frame period
View
Default Level
2: System level
period-value: Errored frame detection interval, ranging from 1 to 60 (in seconds).
Use the oam errored-frame period command to set the errored frame detection interval.
Use the undo oam errored-frame period command to restore the default.
By default, the errored frame detection interval is one second.
An error frame event occurs when a errored frame detection interval expires and the number of the frame errors occurred on an Ethernet port is larger than (or equal to) the errored frame event triggering threshold.
The errored frame detection interval applies to all the Ethernet ports on which OAM connections are established.
Related commands: oam errored-frame threshold, display oam link-event, display oam configuration.
# Set the errored frame detection interval to 10 seconds.
[Sysname] oam errored-frame period 10
oam errored-frame threshold threshold-value
undo oam errored-frame threshold
View
Default Level
2: System level
threshold-value: Errored frame event triggering threshold, ranging from 0 to 4294967295.
Use the oam errored-frame threshold command to set the errored frame event triggering threshold.
Use the undo oam errored-frame threshold command to restore the default.
By default, the errored frame event triggering threshold is 1.
An errored frame event occurs when a errored frame detection interval expires and the number of the frame errors occurred on an Ethernet port is larger than (or equal to) the errored frame event triggering threshold.
The errored frame event triggering threshold configured applies to all the Ethernet ports on which Ethernet OAM connections are established.
Related commands: oam errored-frame period, display oam link-event, display oam configuration.
# Set the errored frame event triggering threshold to 100.
[Sysname] oam errored-frame threshold 100
oam errored-frame-period period period-value
undo oam errored-frame-period period
View
Default Level
2: System level
period-value: Errored frame period detection interval, ranging from 100 to 60,000 (in milliseconds).
Use the oam errored-frame-period period command to set the errored frame period detection interval.
Use the undo oam errored-frame-period period command to restore the default.
By default, the errored frame period detection interval is 1000 milliseconds.
As for errored frame period event detection, the system first uses the following expression to convert the errored frame period detection interval to the maximum number of 64-byte frames that can be transmitted through an Ethernet port in the period:
bandwidth * period / (64 * 8 * 1000),
where bandwidth is the port bandwidth (in bps) and “period” is the configured period (in milliseconds).
A errored frame period event occurs when a errored frame period detection interval expires and the number of the frame errors occurred on an Ethernet port is larger than (or equal to) the errored frame period event triggering threshold.
The errored frame period detection interval configured applies to all the Ethernet ports on which OAM connections are established.
Related commands: oam errored-frame-period threshold, display oam link-event, display oam configuration.
# Set the errored frame period detection interval to 10 seconds.
[Sysname] oam errored-frame-period period 10000
oam errored-frame-period threshold threshold-value
undo oam errored-frame-period threshold
View
Default Level
2: System level
threshold-value: Errored frame period event triggering threshold, ranging from 0 to 4294967295.
Use the oam errored-frame-period threshold command to set the errored frame period event triggering threshold.
Use the undo oam errored-frame-period threshold command to restore the default.
By default, the errored frame period event triggering threshold is 1.
The errored frame period event triggering threshold configured applies to all the Ethernet ports on which OAM connections are established.
Related commands: oam errored-frame-period period, display oam link-event, display oam configuration.
# Set the errored frame period event triggering threshold to 100.
[Sysname] oam errored-frame-period threshold 100
oam errored-frame-seconds period period-value
undo oam errored-frame-seconds period
View
Default Level
2: System level
period-value: Errored frame seconds detection interval, ranging from 10 to 900 (in seconds).
Use the oam errored-frame-seconds period command to set the errored frame seconds detection interval.
Use the undo oam errored-frame-seconds period command to restore the default.
By default, the errored frame seconds detection interval is 60 seconds.
A errored frame seconds event occurs when a errored frame seconds detection interval expires and the number of the error seconds of an Ethernet port is larger than (or equal to) the errored frame seconds event triggering threshold. (A second is called an error second if error frames occur in the second.)
The errored frame seconds detection interval configured applies to all the Ethernet ports on which Ethernet OAM connections are established.
Related commands: oam errored-frame-seconds threshold, display oam link-event, display oam configuration.
# Set the errored frame seconds detection interval to 100 seconds.
[Sysname] oam errored-frame-seconds period 100
oam errored-frame-seconds threshold threshold-value
undo oam errored-frame-seconds threshold
View
Default Level
2: System level
threshold-value: Errored frame seconds event triggering threshold, ranging from 0 to 900.
Use the oam errored-frame-seconds threshold command to set the errored frame seconds event triggering threshold.
Use the undo oam errored-frame-seconds threshold command to restore the default.
By default, the errored frame seconds event triggering threshold is 1.
The errored frame seconds event triggering threshold configured applies to all the Ethernet ports on which Ethernet OAM connections are established.
Related commands: oam errored-frame-seconds period, display oam link-event, display oam configuration.
# Set the errored frame seconds event triggering threshold to 100.
[Sysname] oam errored-frame-seconds threshold 100
oam loopback
oam loopback
undo oam loopback
View
Ethernet port view
Default Level
2: System level
None
Use the oam loopback command to enable Ethernet OAM loopback testing on an Ethernet port.
Use the undo loopback command to disable Ethernet OAM loopback testing.
By default, Ethernet OAM loopback testing is disabled.
Note that:
l Ethernet OAM loopback testing is available only after the Ethernet OAM connection is established.
l Ethernet OAM loopback testing can be performed by Ethernet OAM entities operating in the active Ethernet OAM mode only.
l Ethernet OAM loopback testing is available only when it is supported on both the local port and the peer port.
l Enabling Ethernet OAM loopback testing interrupts data communications. After Ethernet OAM loopback testing is disabled, all the ports involved will be shut down and then brought up.
l Ethernet OAM loopback testing is disabled when you execute the undo oam enable command to disable Ethernet OAM, when you execute the undo oam loopback command to disable Ethernet OAM loopback testing, or when the Ethernet OAM connection is timed out.
Related commands: oam enable, oam mode.
# Enable Ethernet OAM loopback testing on GigabitEthernet2/0/1.
[Sysname-GigabitEthernet2/0/1] oam mode active
[Sysname-GigabitEthernet2/0/1] oam loopback
oam mode
oam mode { active | passive }
View
Ethernet port view
Default Level
2: System level
active: Specifies the active Ethernet OAM mode.
passive: Specifies the passive Ethernet OAM mode.
Use the oam mode command to set the Ethernet OAM operating mode for an Ethernet port. By default, an Ethernet OAM-enabled Ethernet port operates in the active Ethernet OAM mode.
Note that:
l No Ethernet OAM connection can be established between two Ethernet ports operating in the passive Ethernet OAM mode.
l For an Ethernet OAM-enabled Ethernet port, the Ethernet OAM operating mode cannot be changed. To do this, you need to disable Ethernet OAM on the port first.
Related commands: oam enable.
# Configure GigabitEthernet 2/0/1 to operate in the active Ethernet OAM mode.
reset oam
reset oam [ interface interface-type interface-number ]
View
Default Level
2: System level
Use the reset oam command to clear the statistics on Ethernet OAM packets and Ethernet OAM link error events of an Ethernet port.
If you do not specify the interface keyword, this command clears the statistics on Ethernet OAM packets and Ethernet OAM link error events of all the ports.
Related commands: display oam, display oam link-event.
# Clear the statistics on Ethernet OAM packets and Ethernet OAM link error events of all the ports.
<Sysname> reset oam
