- 01-Access Volume
- 00-Access Volume Organization
- 01-Ethernet Interface Commands
- 02-Link Aggregation Commands
- 03-Port Isolation Commands
- 04-Service Loopback Group Commands
- 05-DLDP Commands
- 06-Smart Link Commands
- 07-LLDP Commands
- 08-VLAN Commands
- 09-GVRP Commands
- 10-QinQ Commands
- 11-BPDU Tunneling Commands
- 12-VLAN Mapping Commands
- 13-Ethernet OAM Commands
- 14-Connectivity Fault Detection Commands
- 15-EPON OLT Commands
- 16-MSTP Commands
- 17-RRPP Commands
- 18-Mirroring Commands
| 01-Ethernet Interface Commands | 167.18 KB |
Table of Contents
1 Ethernet Interface Configuration Commands
loopback-detection control enable
loopback-detection interval-time
loopback-detection per-vlan enable
broadcast-suppression
broadcast-suppression { ratio | pps max-pps }
undo broadcast-suppression
View
Layer 2 Ethernet interface view, port group view
Default Level
2: System level
ratio: Maximum percentage of broadcast traffic to the total transmission capability of an Ethernet interface, in the range 1 to 100. The smaller the ratio, the less broadcast traffic is allowed to pass through the interface.
pps max-pps: Specifies the maximum number of broadcast packets that can be forwarded on the Ethernet interface(s) per second.
l For a 100-Mbps port, this value ranges from 1 to 148810 (in pps).
l For a 1-Gbps port, this value ranges from 1 to 1488100 (in pps).
l For a 10-Gbps port, this value ranges from 1 to 14881000 (in pps).
Note that:
l When a suppression granularity larger than 1 is specified on the device, the value of the pps keyword should be no smaller than and an integral multiple of the granularity. The broadcast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual broadcast suppression threshold value on an Ethernet interface, you can use the display interface command.
l When no suppression granularity is specified or the suppression granularity is set to 1, the value of the pps or keyword should be no smaller than 1, and the broadcast suppression threshold value is the one that actually takes effect on the Ethernet interface.
Use the broadcast-suppression command to set a broadcast traffic threshold on one or multiple Ethernet ports.
Use the undo broadcast-suppression command to restore the default.
By default, all broadcast traffic is allowed to pass through an Ethernet interface, that is, broadcast traffic is not suppressed.
If you execute this command in Ethernet interface, the configuration takes effect only on the current interface. If you execute this command in port-group view, the configuration takes effect on all the ports in the port group.
When broadcast traffic exceeds the broadcast traffic threshold, the system begins to discard broadcast packets until the broadcast traffic drops below the threshold to ensure operation of network services.
l If you set different suppression ratios in Ethernet interface view or port-group view for multiple times, the latest configuration takes effect.
l Do not use the broadcast-suppression command along with the storm-constrain command. Otherwise, the broadcast storm suppression ratio configured may get invalid.
l On an Ethernet port enabled with broadcast storm suppression ratio, this feature takes effect only in the inbound direction.
# For Ethernet interface Ethernet 2/0/1, allow broadcast traffic equivalent to 20% of the total transmission capability of Ethernet 2/0/1 to pass.
[Sysname] interface ethernet 2/0/1
[Sysname-Ethernet2/0/1] broadcast-suppression 20
# For all the ports of the manual port group named group1, allow broadcast traffic equivalent to 20% of the total transmission capability of each port to pass and suppress excessive broadcast packets.
[Sysname] port-group manual group1
[Sysname-port-group-manual-group1] group-member ethernet 2/0/1
[Sysname-port-group-manual-group1] group-member ethernet 2/0/2
[Sysname-port-group-manual-group1] broadcast-suppression 20
description
View
Default Level
2: System level
text: Description of an Ethernet interface, a string of 1 to 80 characters. Currently, the device supports the following types of characters or symbols: standard English characters (numbers and case-sensitive letters), special English characters, spaces, and other characters or symbols that conform to the Unicode standard.
l A port description can be the mixture of English characters and other Unicode characters. The mixed description cannot exceed the specified length.
l To use a type of Unicode characters or symbols in a port description, you need to install the corresponding Input Method Editor (IME) and log in to the device through remote login software that supports this character type.
l Each Unicode character or symbol (non-English characters) takes the space of two regular characters. When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two. As a result, garbled characters may be displayed at the end of a line.
Use the description command to set the description string of the current interface.
Use the undo description command to restore the default.
By default, the description of an interface is the interface name followed by the “interface” string, Ethernet2/0/1 Interface for example.
Related commands: display interface.
# Configure the description string of interface Ethernet 2/0/1 as lanswitch-interface.
[Sysname-Ethernet2/0/1] description lanswitch-interface
display brief interface
display brief interface [ interface-type [ interface-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
interface-type: Type of a specified interface.
interface-number: Number of a specified interface.
|: Uses a regular expression to filter output information. For detailed description on regular expression, refer to Basic System Configuration in the System Volume.
begin: Displays the line that matches the regular expression and all the subsequent lines.
exclude: Displays the lines that do not match the regular expression.
include: Displays the lines that match the regular expression.
regular-expression: Regular expression, a string of 1 to 256 characters. Note that this argument is case-sensitive.
Use the display brief interface command to display brief interface information.
l If neither interface type nor interface number is specified, all interface information will be displayed.
l If only interface type is specified, then only information of this particular type of interface will be displayed.
l If both interface type and interface number are specified, then only information of the specified interface will be displayed.
Related commands: interface.
# Display the brief information of interfaces.
<Sysname> display brief interface
The brief information of interface(s) under route mode:
Interface Link Protocol-link Protocol type Main IP
Loop0 UP UP(spoofing) LOOP 2.2.2.9
Loop1 UP UP(spoofing) LOOP --
Loop2 UP UP(spoofing) LOOP --
M-E0/0/0 DOWN DOWN ETHERNET --
NULL0 UP UP(spoofing) NULL --
Tun3/0/20 DOWN DOWN TUNNEL --
Vlan1 UP UP ETHERNET 192.168.0.73
Vlan2 DOWN DOWN ETHERNET 10.1.1.2
Vlan3 DOWN DOWN ETHERNET 20.1.1.1
Vlan100 DOWN DOWN ETHERNET --
Vlan200 UP DOWN ETHERNET --
The brief information of interface(s) under bridge mode:
Interface Link Speed Duplex Link-type PVID
BAGG1 DOWN auto auto access 1
Eth3/0/1 UP 100M(a) full(a) access 100
Eth3/0/2 UP 100M(a) full(a) access 200
Eth3/0/3 DOWN auto auto hybrid 3
Eth3/0/4 DOWN auto auto access 1
Eth3/0/5 DOWN auto auto access 1
Eth3/0/6 DOWN auto auto access 1
Eth3/0/7 DOWN auto auto access 1
Eth3/0/8 DOWN auto auto access 1
Eth3/0/9 DOWN auto auto access 1
Eth3/0/10 DOWN auto auto access 1
# Display the information of interfaces beginning with the string “spoof”.
<Sysname> display brief interface | begin spoof
# Display the brief information of all UP interfaces.
<Sysname> display brief interface | include UP
Eth3/0/48 UP 100M(a) full(a) access 1
# Display the brief information of all interfaces excluding Ethernet interfaces.
<Sysname> display brief interface | exclude Eth
Table 1-1 display brief interface command output description
The brief information of interface(s) under route mode: |
Brief information of interface(s) in route mode |
Abbreviated interface name |
Link |
Interface physical link state, which can be up or down |
Protocol-link |
Interface protocol link state, which can be up or down |
Protocol type |
Interface protocol type |
Main IP |
Main IP |
The brief information of interface(s) under bridge mode: |
Brief information of interface(s) in bridge mode |
Speed |
Interface rate, in bps |
Duplex |
Duplex mode, which can be half (half duplex), full (full duplex), or auto (auto-negotiation). |
PVID |
Default VLAN ID |
display interface
display interface [ interface-type [ interface-number ] ]
View
Default Level
1: Monitor level
Use the display interface command to display the current state of a specified interface and related information.
# Display the current state of Layer 2 interface Ethernet 2/0/1 and related information.
<Sysname> display interface ethernet 2/0/1
Ethernet2/0/1 current state: DOWN
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e200-8048
Description: Ethernet2/0/1 Interface
Loopback is not set
Media type is twisted pair, port hardware type is 100_BASE_TX
Flow-control is not enabled
The Maximum Frame Length is 9022
Broadcast MAX-ratio: 100%
Unicast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Allow jumbo frame to pass
PVID: 100
Mdi type: auto
Link delay is 10(sec)
Port link-type: access
Tagged VLAN ID : none
Untagged VLAN ID : 100
Port priority: 0
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
0 broadcasts, 0 multicasts
Input (normal): 0 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
0 broadcasts, 0 multicasts, 0 pauses
Output (normal): 0 packets, - bytes
0 lost carrier, - no carrier
Table 1-2 display interface command output description
Ethernet2/0/1 current state |
Current physical link state of the Ethernet port |
IP Packet Frame Type |
Frame type of the Ethernet port |
Description of the interface |
Unknown-speed mode |
Unknown-speed mode, in which mode speed is negotiated between the current host and the peer. |
unknown-duplex mode |
Unknown-duplex mode, in which mode speed is negotiated between the current host and the peer. |
The Maximum Frame Length |
The maximum frame length allowed on an interface |
Broadcast MAX-ratio |
Broadcast storm suppression ratio (the maximum ratio of allowed number of broadcast packets to overall traffic through an interface) |
Unicast MAX-ratio |
Unicast storm suppression ratio (the maximum ratio of allowed number of unknown unicast packets to overall traffic over an interface) |
Multicast MAX-ratio |
Multicast storm suppression ratio (the maximum ratio of allowed number of multicast packets to overall traffic through an interface) |
PVID |
Default VLAN ID |
Mdi type |
Cable type |
Link delay |
The suppression time of physical-link-down-state changes |
Port link-type |
Interface link type, which could be access, trunk, and hybrid. |
Tagged VLAN ID |
VLANs whose packets are sent through the port with VLAN tag kept |
Untagged VLAN ID |
VLANs whose packets are sent through the port with VLAN tag stripped off |
Last 300 seconds input: 0 packets/sec 0 bytes/sec Last 300 seconds output: 0 packets/sec 0 bytes/sec |
Average rate of input and output traffic in the last 300 seconds, in pps and Bps |
Input (total): 0 packets, 0 bytes 0 broadcasts, 0 multicasts |
Packet statistics on the inbound direction of the interface, including the statistics of normal packets, and abnormal packets, in packets and bytes Number of broadcast packets, and multicast packets on the inbound direction of the interface |
Input (normal): 0 packets, - bytes 0 broadcasts, 0 multicasts |
Normal packet statistics on the inbound direction of the interface, including the statistics of normal packets and pause frames, in packets and bytes Number of broadcast packets, and multicast packets on the inbound direction of the interface. |
input errors |
Input packets with errors |
runts |
Frames received that were shorter than 64 bytes, yet in correct formats, and contained valid CRCs |
giants |
Frames received that were longer than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags) |
throttles |
The number of times the receiver on the interface was disabled, possibly because of buffer or CPU overload |
CRC |
Total number of packets received that had a normal length, but contained checksum errors |
frame |
Total number of frames that contained checksum errors and a non-integer number of bytes |
- overruns |
Number of times the receive rate of the interface exceeded the capacity of the input queue, causing packets to be discarded |
aborts |
Total number of illegal packets received, including: l Fragment frames: Frames that were shorter than 64 bytes (with an integral or non-integral length) and contained checksum errors l Jabber frames: Frames that were longer than 1518 or 1522 bytes and contained checksum errors (the frame lengths in bytes may or may not be integers) l Symbol error frames: Frames that contained at least one undefined symbol l Unknown operation code frames: Frames that were MAC control frames but not pause frames l Length error frames: Frames whose 802.3 length fields did not match the actual frame lengths (46 bytes to 1500 bytes) |
- ignored |
Number of received packets ignored by the interface because the interface hardware ran low on internal buffers |
- parity errors |
Total number of frames with parity errors |
Output (total): 0 packets, 0 bytes 0 broadcasts, 0 multicasts, 0 pauses |
Packet statistics on the outbound direction of the interface, including the statistics of normal packets, abnormal packets, and normal pause frames, in packets and bytes Number of broadcast packets, multicast packets, and pause frames on the outbound direction of the interface |
Output (normal): 0 packets, - bytes 0 broadcasts, 0 multicasts, 0 pauses |
Normal packet statistics on the outbound direction of the interface, including the statistics of normal packets and pause frames, in packets and bytes Number of broadcast packets, multicast packets, and pause frames on the outbound direction of the interface. |
output errors |
Output packets with errors |
- underruns |
Number of times the transmit rate of the interface exceeded the capacity of the output queue, causing packets to be discarded. This is a very rare hardware-related problem. |
- buffer failures |
Number of packets dropped because the interface ran low on output buffers |
aborts |
Number of packets that failed to be transmitted due to causes such as Ethernet collisions |
deferred |
Number of frames whose first transmission attempt was delayed, due to traffic on the network media, and that were successfully transmitted later |
collisions |
Number of times frames were delayed due to Ethernet collisions detected during the transmission |
late collisions |
Number of times frames were delayed due to the detection of collisions after the first 512 bits of the frames were already on the network |
lost carrier |
Number of times the carrier was lost during transmission. This counter applies to serial WAN interfaces. |
- no carrier |
Number of times the carrier was not present in the transmission. This counter applies to serial WAN interfaces. |
“-“ indicates that the corresponding entry is not supported.
display loopback-detection
View
Default Level
1: Monitor level
None
Use the display loopback-detection command to display loopback detection information on a port.
If loopback detection is already enabled, this command will also display the detection interval and information on the ports currently detected with a loopback.
# Display loopback detection information on a port.
<Sysname> display loopback-detection
Loopback-detection is running
Detection interval time is 30 seconds
No port is detected with loopback
Table 1-3 display loopback-detection command output description
Loopback-detection is running |
Loopback-detection is running. |
Detection interval time is 30 seconds |
Detection interval is 30 seconds. |
No port is detected with loopback |
No port is currently being detected with a loopback. |
display port combo
display port combo
View
Default Level
1: Monitor level
None
Use the display port combo command to display the Combo ports of a device and the corresponding optical ports and electrical ports.
# Display the Combo ports of the device and the corresponding optical ports and electrical ports.
<Sysname> display port combo
Combo-group Active Inactive
1 GigabitEthernet0/0/25 GigabitEthernet0/0/18
2 GigabitEthernet0/0/26 GigabitEthernet0/0/17
3 GigabitEthernet0/0/27 GigabitEthernet0/0/20
4 GigabitEthernet0/0/28 GigabitEthernet0/0/19
5 GigabitEthernet0/0/29 GigabitEthernet0/0/22
6 GigabitEthernet0/0/30 GigabitEthernet0/0/21
7 GigabitEthernet0/0/31 GigabitEthernet0/0/24
8 GigabitEthernet0/0/32 GigabitEthernet0/0/23
Table 1-4 display port combo command output description
Combo-group |
Combo ports of the device, represented by Combo port number, which is generated by the system. |
Active |
Ports of the Combo ports that are active |
Inactive |
Ports of the Combo ports that are inactive |
As for the optical port and the electrical port of a Combo port, the one with the smaller port number is active by default. The port number varies with device models. You can determine whether a port is an optical port or an electrical port by checking the “Media type is” field of the display interface command.
display port-group manual
display port-group manual [ all | name port-group-name ]
View
Default Level
2: System level
all: Specifies all the manual port groups.
name port-group-name: Specifies the name of a manual port group, a string of 1 to 32 characters.
Use the display port-group manual command to display the information about a manual port group or all the manual port groups.
l If you provide the port-group-name argument, this command displays the details for a specified manual port group, including its name and the Ethernet interface ports included.
l If you provide the all keyword, this command displays the details for all manual port groups, including their names and the Ethernet interface ports included.
l Absence of parameters indicates that the names of all the port groups will be displayed.
# Display the names of all the port groups.
<Sysname> display port-group manual
The following manual port group exist(s):
1 2
# Display details of all the manual port groups.
<Sysname> display port-group manual all
Member of 1:
Ethernet2/0/1 Ethernet2/0/2 Ethernet2/0/3
Member of 2:
None
# Display details of the port group named group1.
Member of 1:
Table 1-5 display port-group manual command output description
Member of group |
Member of the manual port group |
display storm-constrain
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
broadcast: Displays the information about storm constrain for broadcast packets.
multicast: Displays the information about storm constrain for multicast packets.
unicast: Displays the information about storm constrain for unicast packets.
Use the display storm-constrain command to display the information about storm constrain.
If you provide no argument or keyword, this command displays the information about storm constrain for all types of packets on all the interfaces.
# Display the information about storm constrain for all types of packets on all the interfaces.
<Sysname> display storm-constrain
Flow Statistic Interval: 10(second)
PortName StormType LowerLimit UpperLimit Ctr-mode Status Trap Log Swi-num
Eth2/0/5 broadcast 10 500 N/A normal on on 0
Table 1-6 display storm-constrain command output description
Flow Statistic Interval |
Interval for generating storm constrain statistics |
PortName |
Abbreviated port name |
StormType |
Type of the packets for which storm constrain function is enabled, which can be broadcast (for broadcast packets), multicast (for multicast packets), and unicast (for unicast packets). |
LowerLimit |
Lower threshold (in pps) |
UpperLimit |
Upper threshold (in pps) |
Ctr-mode |
Action to be taken when the upper threshold is reached, which can be block, shutdown, and N/A. |
Status |
Interface state, which can be normal (indicating the interface operates properly), control (indicating the interface is blocked or shut down). |
Trap |
State of trap messages sending. “on” indicates trap message sending is enabled; “off” indicates trap message sending is disabled. |
Log |
State of log sending. “on” indicates log sending is enabled; “off” indicates log sending is disabled. |
Swi-num |
Number of the forwarding state switching. This field is numbered modulo 65,535. |
duplex
duplex { auto | full | half }
undo duplex
View
Default Level
2: System level
auto: Indicates that the interface is in auto-negotiation state.
full: Indicates that the interface is in full-duplex state.
half: Indicates that the interface is in half-duplex state. The optical interface of a Combo port does not support the half keyword.
Use the duplex command to configure the duplex mode for an Ethernet interface.
Use the undo duplex command to restore the duplex mode for an Ethernet interface to the default.
By default, the duplex mode for an Ethernet interface is auto.
Related commands: speed.
# Configure the interface Ethernet 2/0/1 to work in full-duplex mode.
[Sysname-Ethernet2/0/1] duplex full
flow-control
flow-control
undo flow-control
View
Default Level
2: System level
None
Use the flow-control command to enable flow control on an Ethernet interface.
Use the undo flow-control command to disable flow control on an Ethernet interface.
By default, flow control on an Ethernet interface is disabled.
The flow control function takes effect on the local Ethernet interface only when it is enabled on both the local and peer devices.
# Enable flow control on interface Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] flow-control
flow-interval
flow-interval interval
undo flow-interval
View
Default Level
2: System level
interval: Time interval at which interface statistics are collected, in the range of 5 to 300 seconds, a multiple of 5. The default value is 300 seconds.
Use the flow-interval command to configure the time interval for collecting interface statistics.
Use the undo flow-interval command to restore the default interval.
# Set the time interval for collecting interface statistics to 100 seconds.
[Sysname-Ethernet2/0/1] flow-interval 100
group-member
group-member interface-list
undo group-member interface-list
View
Port group view
Default Level
2: System level
interface-list: Ethernet interface list, in the form of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 port or port ranges.
Use the group-member command to add an Ethernet interface to a specified manual port group.
Use the undo group-member command to remove a specified Ethernet interface from a manual port group.
By default, there is no Ethernet interface in a manual port group.
# Add interface Ethernet 2/0/1 to the manual port group named group1.
interface
View
Default Level
2: System level
interface-type interface-number : Interface type and interface number.
Use the interface command to enter interface.
# Enter Ethernet 2/0/1 interface view (assuming that the interface is a Layer 2 Ethernet interface).
jumboframe enable
jumboframe enable [ value ]
undo jumboframe enable
View
Default Level
2: System level
value: Maximum length of Ethernet frames that are allowed to pass through. The effective range is 1,536 to 9,216 (in bytes).
Use the jumboframe enable command to allow jumbo frames with the specified length to pass through an Ethernet interface.
Use the undo jumboframe enable command to prevent jumbo frames from passing through an Ethernet interface. That is, the maximum length of the frames allowed to pass through an Ethernet interface is 1518 bytes.
By default, the device allows frames no larger than 1536 bytes to pass through an Ethernet interface.
You can configure length of jumbo frames in global configuration mode (in system view) or on a port (in Ethernet interface view, port-group view) to allow them to pass through Ethernet interfaces.
l Execution of this command under Ethernet interface view will only apply the configurations to the current Ethernet interface.
l Execution of this command under port group view will apply the configurations to the Ethernet interface(s) in the port group.
The latest configuration takes effect if you configure the value argument for multiple times in Ethernet interface view or port-group view.
# Enable jumbo frames to pass through all the Ethernet interfaces in the manual port group named group1.
[Sysname-port-group manual group1] group-member ethernet 2/0
[Sysname-port-group manual group1] jumboframe enable
# Enable jumbo frames to pass through Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] jumboframe enable
link-delay
link-delay delay-time
undo link-delay
View
Default Level
2: System level
delay-time: Up/down suppression time for the physical connection of the Ethernet interface (in seconds), in the range 0 to 30.
Use the link-delay command to configure the suppression time of physical-link-state changes on the Ethernet Interface.
Use the undo link-delay command to restore the default suppression time.
By default, the suppression time is 0 second, that is, the physical layer will report physical-link-state changes without delay.
# Set the up/down suppression time of the physical connection of interface Ethernet 2/0/1 to 8 seconds.
[Sysname-Ethernet2/0/1] link-delay 8
loopback
undo loopback
View
Default Level
2: System level
external: Enables external loopback testing on an Ethernet interface.
internal: Enables internal loopback testing on an Ethernet interface.
Use the loopback command to enable Ethernet interface loopback testing.
Use the undo loopback command to disable Ethernet interface loopback testing.
By default, Ethernet interface loopback testing is disabled.
l Ethernet interface loopback testing should be enabled while testing certain functionalities, such as during the initial identification of any network failure.
l While enabled, Ethernet interface loopback testing will work in full-duplex mode. The interface will return to its original state upon completion of the loopback testing.
# Enable loopback testing on Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] loopback internal
undo loopback-detection control enable
View
Default Level
2: System level
None
Use the loopback-detection control enable command to enable loopback detection for a Trunk port or Hybrid port.
Use the undo loopback-detection control enable command to restore the default.
By default, loopback detection for a Trunk port or Hybrid port is disabled.
Note that this command is inapplicable to an Access port as its loopback detection is enabled by default.
# Enable loopback detection for the trunk port Ethernet 2/0/1.
[Sysname] loopback-detection enable
[Sysname-Ethernet2/0/1] port link-type trunk
[Sysname-Ethernet2/0/1] loopback-detection enable
[Sysname-Ethernet2/0/1] loopback-detection control enable
undo loopback-detection enable
View
System view, Layer 2 Ethernet interface view
Default Level
2: System level
None
Use the loopback-detection enable command to enable loopback detection globally or on a specified port.
Use the undo loopback-detection enable command to disable loopback detection globally or on a specified port.
By default, loopback detection is disabled for an Access, Trunk, or Hybrid port.
With loopback detection enabled on a port (whose link type may be Access, Trunk, or Hybrid):
l If an Access port has been detected with loopback, it will transit to the loopback detection control state, where the incoming packets of the port are dropped and the outgoing packets of the port are forwarded normally. A Trap message will be sent to the terminal and the corresponding MAC address.
l If a Trunk port or Hybrid port has been detected with loopback, a Trunk message will be sent to the terminal. If the loopback detection control function is enabled on the port, the port will transit to the loopback detection control state, where the incoming packets of the port are dropped and the outgoing packets of the port are forwarded normally. In addition, a Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
Related commands: loopback-detection control enable.
l Loopback detection on a given port is enabled only after the loopback-detection enable command has been configured in both system view and interface view of the port.
l Loopback detection on all ports will be disabled after the configuration of the undo loopback-detection enable command in system view.
# Enable loopback detection on the interface Ethernet 2/0/1.
loopback-detection interval-time time
undo loopback-detection interval-time
View
Default Level
2: System level
time: Time interval for performing port loopback detection, in the range 5 to 300 (in seconds).
Use the loopback-detection interval-time command to configure time interval for performing port loopback detection.
Use the undo loopback-detection interval-time command to restore the default time interval for port loopback detection, which is 30 seconds.
Related commands: display loopback-detection.
# Set the time interval for performing port loopback detection to 10 seconds.
[Sysname] loopback-detection interval-time 10
undo loopback-detection per-vlan enable
View
Default Level
2: System level
None
Use the loopback-detection per-vlan enable command to enable loopback detection in all VLANs with Trunk ports or Hybrid ports.
Use the undo loopback-detection per-vlan enable command to enable loopback detection in the default VLAN with Trunk ports or Hybrid ports.
By default, loopback detection is only enabled in the default VLAN(s) with Trunk ports or Hybrid ports.
Note that the loopback-detection per-vlan enable command is not applicable to Access ports.
# Enable loopback detection in all the VLANs to which the Hybrid port Ethernet 2/0/1 belongs.
[Sysname-Ethernet2/0/1] loopback-detection per-vlan enable
mdi
mdi { across | auto | normal }
undo mdi
View
Default Level
2: System level
across: Specifies the MDI mode as across.
auto: Specifies the MDI mode as auto.
normal: Specifies the MDI mode as normal.
Use the mdi command to configure the MDI mode for an Ethernet interface.
Use the undo mdi command to restore the system default.
By default, the MDI mode of an Ethernet interface is auto, that is, the Ethernet interface determines the physical pin roles (transmit or receive) through negotiation.
The command is not applicable to Combo ports operating as optical ports.
# Set the MDI mode of Ethernet 2/0/1 to across.
[Sysname-Ethernet2/0/1] mdi across
multicast-suppression
multicast-suppression { ratio | pps max-pps }
undo multicast-suppression
View
Default Level
2: System level
ratio: Maximum percentage of multicast traffic to the total transmission capability of an Ethernet interface, in the range 1 to 100. The smaller the ratio is, the less multicast traffic is allowed to pass through the interface.
pps max-pps: Specifies the maximum number of multicast packets allowed on the Ethernet interface(s) per second...
Note that:
Use the multicast-suppression command to configure multicast storm suppression ratio on an interface.
Use the undo multicast-suppression command to restore the default multicast suppression ratio.
By default, all multicast traffic is allowed to go through an Ethernet interface, that is, multicast traffic is not suppressed.
If you execute this command in Ethernet interface, the configurations take effect only on the current interface. If you execute this command in port-group view, the configurations take effect on all ports in the port group.
Note that when multicast traffic exceeds the maximum value configured, the system will discard the extra packets so that the multicast traffic ratio can drop below the limit to ensure that the network functions properly.
l Do not use the multicast-suppression command along with the storm-constrain command. Otherwise, the multicast storm suppression ratio configured may get invalid.
l On an Ethernet port enabled with multicast storm suppression ratio, this feature takes effect only in the inbound direction.
# For Ethernet interface Ethernet 2/0/1, allow multicast traffic equivalent to 20% of the total transmission capability of Ethernet 2/0/1 to pass.
[Sysname-GigabitEthernet2/0/1] multicast-suppression 20
# For all the ports of the manual port group group1, allow multicast traffic equivalent to 20% of the total transmission capability of each port to pass.
[Sysname-port-group-manual-group1] multicast-suppression 20
port-group manual
port-group manual port-group-name
undo port-group manual port-group-name
View
Default Level
2: System level
port-group-name: Specifies name of a manual port group, a string of 1 to 32 characters.
Use the port-group manual command to create a manual port group and enter manual port group view.
Use the undo port-group manual command to remove a manual port group.
By default, no manual port group is created.
# Create a manual port group named group1.
reset counters interface
reset counters interface [ interface-type [ interface-number ] ]
View
Default Level
2: System level
interface-type: Interface type.
interface-number: Interface number.
Use the reset counters interface command to clear the statistics of an interface.
Before sampling network traffic within a specific period of time on an interface, you need to clear the existing statistics.
l If neither interface type nor interface number is specified, this command clears the statistics of all the interfaces.
l If only the interface type is specified, this command clears the statistics of the interfaces that are of the interface type specified.
l If both the interface type and interface number are specified, this command clears the statistics of the specified interface.
# Clear the statistics of Ethernet 2/0/1.
<Sysname> reset counters interface ethernet 2/0/1
shutdown
shutdown
View
Default Level
2: System level
None
Use the shutdown command to shut down an Ethernet interface.
Use the undo shutdown command to bring up an Ethernet interface.
By default, an Ethernet interface is in the up state.
In certain circumstances, modification to the interface parameters does not immediately take effect, and therefore, you need to shut down the relative interface to make the modification work.
Note that in case of a double Combo port, only one interface (either the optical port or the electrical port) is active at a time. That is, once the optical port is active (after you execute the undo shutdown command), the electrical port will be inactive automatically, and vice versa.
# Shut down interface Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] shutdown
# Bring up interface Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] undo shutdown
speed
speed { 10 | 100 | 1000 | auto }
undo speed
View
Default Level
2: System level
10: Specifies the interface rate as 10 Mbps. The optical interface of a Combo port does not support the 10 keyword.
100: Specifies the interface rate as 100 Mbps. The optical interface of a Combo port does not support the 100 keyword.
1000: Specifies the interface rate as 1,000 Mbps.
auto: Specifies to determine the interface rate through auto-negotiation.
Use the speed command to configure Ethernet interface data rate.
Use the undo speed command to restore Ethernet interface data rate.
By default, the port speed is in the auto-negotiation mode.
Related commands: duplex, speed auto.
You are recommended to configure the same port rate and duplex mode on two ports connected to each other, for example, set the duplex mode of both ports to auto negotiation or full/half duplex, so as to avoid packet loss.
# Configure the interface rate as 100 Mbps for interface Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] speed 100
speed auto
speed auto [ 10 | 100 | 1000 ] *
undo speed
View
100MB or Gigabit Layer 2 Ethernet interface view
Default Level
2: System level
10: Specifies the interface auto-negotiation rate as 10 Mbps.
100: Specifies the interface auto-negotiation rate as 100 Mbps.
1000: Specifies the interface auto-negotiation rate as 1000 Mbps.
Use the speed auto command to configure the auto-negotiation rate of the current interface.
Use the undo speed command to restore the default.
If you repeatedly use the speed command and the speed auto command to configure the rate of an interface, only the latest configuration takes effect. For example, if you configure speed 100 after configuring speed auto 100 1000 on an interface, the rate is 100 Mbps by force, with no negotiation performed between the interface and the peer end; if you configure speed auto 100 1000 after configuring speed 100 on the interface, the rate through negotiation can be either 100 Mbps or 1000 Mbps only.
Note that:
l When the auto-negotiation rate ranges set on the local and peer ends do not intersect, for example, 10 and 100 Mbps on one end and 1000 Mbps on the other, the rate negotiation will fail.
l When the auto-negotiation rate ranges set on the local and peer ends intersect, for example, 10 and 100 Mbps on one end and 100 and 1000 Mbps on the other, the negotiation rate range is the intersection, 100 Mbps.
l When the auto-negotiation rate ranges set on the local and peer ends are the same, for example, 100 and 1000 Mbps, the maximum value of the auto-negotiation rate is 1000 Mbps.
l This function is available for auto-negotiation-capable 100 MB or Gigabit Layer-2 Ethernet interfaces only. For a Combo port, only the electrical port supports this function.
l If you repeatedly use the speed and the speed auto commands to configure the transmission rate on an interface, only the latest configuration takes effect.
# Set the auto-negotiation rate of interface GigabitEthernet 2/0/1 to 10 Mbps or 1000 Mbps.
[Sysname-GigabitEthernet2/0/1] speed auto 10 1000
storm-constrain
storm-constrain { broadcast | multicast } pps max-pps-values min-pps-values
undo storm-constrain { all | broadcast | multicast }
View
Default Level
2: System level
all: Disables the storm constrain function for all types of packets (that is, unicast packets, multicast packets, and broadcast packets).
broadcast: Enables/Disables the storm constrain function for broadcast packets.
multicast: Enables/Disables the storm constrain function for multicast packets.
pps: Specifies that the thresholds to be configured.
max-pps-values: Upper threshold to be set, in pps.
l For a 100-Mbps port, this value ranges from 1 to 148810.
l For a 1-Gbps port, this value ranges from 1 to 1488100.
l For a 10-Gbps port, this value ranges from 1 to 14881000.
min-pps-values: Lower threshold to be set, in pps. The range of this argument is 1 to max-pps-values.
Use the storm-constrain command to enable the storm constrain function for specific type of packets and set the upper and lower thresholds.
Use the undo storm-constrain command to disable the storm constrain function for specific type of packets.
By default, the storm constrain function is not enabled.
l Do not use the storm-constrain command along with the multicast-suppression command or the broadcast-suppression command. Otherwise, traffics may be suppressed in an unpredictable way.
l An upper threshold cannot be less than the corresponding lower threshold. Besides, do not configure the two thresholds as the same value.
# Enable the storm constrain function for unicast packets on Ethernet 2/0/1, setting the upper and lower threshold to 200 pps and 150 pps.
[Sysname-Ethernet2/0/1] storm-constrain unicast pps 200 150
storm-constrain control
undo storm-constrain control
View
Default Level
2: System level
block: Blocks the traffic of a specific type on a port when the traffic detected exceeds the upper threshold.
shutdown: Shuts down a port when a type of traffic exceeds the corresponding upper threshold. A port shut down by the storm constrain function stops forwarding all types of packets.
Use the storm-constrain control command to set the action to be taken when a type of traffic exceeds the corresponding upper threshold.
Use the undo storm-constrain control command to restore the default.
By default, no action is taken when a type of traffic exceeds the corresponding threshold.
# Configure to block interface Ethernet 2/0/1 when a type of traffic reaching it exceeds the corresponding upper threshold.
[Sysname-Ethernet2/0/1] storm-constrain control block
storm-constrain enable log
undo storm-constrain enable log
View
Default Level
2: System level
None
Use the storm-constrain enable log command to enable log sending. With log sending enabled, the system sends log when traffic reaching a port exceeds the corresponding threshold or the traffic drops down below the lower threshold after exceeding the upper threshold.
Use the undo storm-constrain enable log command to disable log sending.
By default, log sending is enabled.
# Disable log sending for Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] undo storm-constrain enable log
storm-constrain enable trap
undo storm-constrain enable trap
View
Default Level
2: System level
None
Use the storm-constrain enable trap command to enable trap message sending. With trap message sending enabled, the system sends trap messages when traffic reaching a port exceeds the corresponding threshold or the traffic drops down below the lower threshold after exceeding the upper threshold.
Use the undo storm-constrain enable trap command to disable trap message sending.
By default, trap message sending is enabled.
# Disable trap message sending for Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] undo storm-constrain enable trap
storm-constrain interval
storm-constrain interval seconds
undo storm-constrain interval
View
Default Level
2: System level
seconds: Interval for generating traffic statistics, in the range 1 to 300 (in seconds).
Use the storm-constrain interval command to set the interval for generating traffic statistics.
Use the undo storm-constrain interval command to restore the default.
By default, the interval for generating traffic statistics is 10 seconds.
l The interval set by the storm-constrain interval command is specifically for the storm constrain function. It is different form that set by the flow-interval command.
l For network stability consideration, configure the interval for generating traffic statistics to a value that is not shorter than the default.
# Set the interval for generating traffic statistics to 60 seconds.
[Sysname] storm-constrain interval 60
unicast-suppression
unicast-suppression { ratio | pps max-pps }
undo unicast-suppression
View
Default Level
2: System level
ratio: Maximum percentage of unicast traffic to the total transmission capability of an Ethernet interface, in the range of 1 to 100. The smaller the ratio is, the less unicast traffic is allowed through the interface.
pps max-pps: Specifies the maximum number of unknown unicast packets passing through an Ethernet interface per second.
Note that:
Use the unicast-suppression command to configure a unicast storm suppression ratio.
Use the undo unicast-suppression command to restore the default unicast suppression ratio.
By default, all unicast traffic is allowed to go through an Ethernet interface, that is, unicast traffic is not suppressed.
Note that when unicast traffic exceeds the maximum value configured, the system will discard the extra packets so that the unknown unicast traffic ratio can drop below the limit to ensure that the network functions properly.
l If you set different suppression ratios in Ethernet interface view or port-group view repeatedly, the latest configuration takes effect.
l Do not use the unicast-suppression command along with the storm-constrain command. Otherwise, the unicast storm suppression ratio configured may get invalid.
l On an Ethernet port enabled with unicast storm suppression ratio, this feature takes effect only in the inbound direction.
# For Ethernet interface Ethernet 2/0/1, allow unknown unicast traffic equivalent to 20% of the total transmission capability of the interface to pass and suppress the excessive unknown unicast packets.
[Sysname-Ethernet2/0/1] unicast-suppression 20
# For all the ports of the manual port group group1, allow unknown unicast traffic equivalent to 20% of the total transmission capability of each port to pass and suppress excessive unknown unicast packets.
[Sysname-port-group-manual-group1] unicast-suppression 20
virtual-cable-test
virtual-cable-test
View
Default Level
2: System level
None
Use the virtual-cable-test command to test the cable connected to the Ethernet interface once and to display the testing result. The tested items include:
Note that:
l When the cable is functioning properly, the cable length in the test result represents the total cable length;
l When the cable is not functioning properly, the cable length in the test result represents the length from the current interface to the failed position.
l The optical interface of a Combo port does not support this command. The support of other Ethernet interfaces for this command varies with device models.
l A link in the up state goes down and then up automatically if you execute this command on one of the Ethernet interfaces forming the link.
l The test result is for your information only. The maximum error in the tested cable length is 5 m. A hyphen “-” indicates that the corresponding test item is not supported.
# Enable the virtual cable test for the interface Ethernet 2/0/1.
[Sysname-Ethernet2/0/1] virtual-cable-test
Cable status: normal, 1 metres
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
