- 01-Access Volume
- 00-Access Volume Organization
- 01-Ethernet Interface Commands
- 02-Link Aggregation Commands
- 03-Port Isolation Commands
- 04-Service Loopback Group Commands
- 05-DLDP Commands
- 06-Smart Link Commands
- 07-LLDP Commands
- 08-VLAN Commands
- 09-GVRP Commands
- 10-QinQ Commands
- 11-BPDU Tunneling Commands
- 12-VLAN Mapping Commands
- 13-Ethernet OAM Commands
- 14-Connectivity Fault Detection Commands
- 15-EPON OLT Commands
- 16-MSTP Commands
- 17-RRPP Commands
- 18-Mirroring Commands
| 05-DLDP Commands | 54.08 KB |
Table of Contents
DLDP Configuration Commands
display dldp
display dldp [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Port type and port number.
Use the display dldp command to display the DLDP configuration of a port.
If you do not provide the interface-type or interface-number arguments, this command displays the DLDP configuration of all the DLDP-enabled ports.
# Display the DLDP configuration of all the DLDP-enabled ports.
<Sysname> display dldp
DLDP global status : enable
DLDP interval : 5s
DLDP work-mode : enhance
DLDP authentication-mode : simple, password is 123
DLDP unidirectional-shutdown : auto
DLDP delaydown-timer : 2s
The number of enabled ports is 2.
Interface GigabitEthernet2/0/1
DLDP port state : advertisement
DLDP link state : up
The neighbor number of the port is 1.
Neighbor mac address : 0000-0000-0100
Neighbor port index : 79
Neighbor state : two way
Neighbor aged time : 13
Interface GigabitEthernet2/0/2
Neighbor mac address : 0000-0000-1100
Neighbor port index : 81
Neighbor aged time : 12
# Display the DLDP configuration of GigabitEthernet2/0/1.
<Sysname> display dldp GigabitEthernet 2/0/1
Table 1-1 display dldp command output description
DLDP global status |
Global DLDP state (enable or disable) |
DLDP interval |
Interval for sending Advertisement packets (in seconds) |
DLDP work-mode |
DLDP mode (enhance or normal) |
DLDP authentication-mode |
DLDP authentication mode (none, simple, or md5) |
password |
Password for DLDP authentication |
DLDP unidirectional-shutdown |
Port shutdown mode (auto or manual) |
DLDP delaydown-timer |
Setting of the DelayDown timer |
The number of enabled ports |
Number of the DLDP-enabled ports |
Index of a DLDP-enabled port |
DLDP port state |
DLDP state on a port (initial, inactive, active, advertisement, probe, disable, or delaydown) |
DLDP link state |
Port state (up or down) |
The neighbor number of the port |
Number of the neighbors of a port |
Neighbor mac address |
MAC address of a neighbor |
Neighbor port index |
Neighbor state |
Neighbor state (unknown, one way, or two way) |
Neighbor aged time |
Neighbor aging time |
display dldp statistics
display dldp statistics [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display dldp statistics command to display the statistics on the DLDP packets passing through a port.
If you do not provide the interface-type or interface-number argument, this command displays the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Display the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> display dldp statistics
Packets sent : 6
Packets received : 5
Invalid packets received : 2
Loop packets received : 0
Authentication failed packets received : 0
Valid packets received : 3
Packets sent : 7
Packets received : 7
Invalid packets received : 3
Valid packets received : 4
# Display the statistics on the DLDP packets passing through GigabitEthernet 2/0/1.
<Sysname> display dldp statistics GigabitEthernet 2/0/1
Packets sent : 6
Table 1-2 display dldp statistics command output description
Port index |
Packets sent |
Total number of DLDP packets sent |
Packets received |
Total number of DLDP packets received |
Invalid packets received |
Number of the invalid packets received |
Loop packets received |
Number of the loopback packets received |
Authentication failed packets received |
Number of the received packets that failed to pass the authentication |
Valid packets received |
Number of the valid packets received |
dldp authentication-mode
dldp authentication-mode { md5 md5-password | none | simple simple-password }
undo dldp authentication-mode
View
Default Level
2: System level
md5 md5-password: Specifies to perform MD5 authentication and sets the password. The md5-password argument is the password, a string of 1 to 16 characters or a 24-bit string. The former indicates a plain text password and the latter indicates a cipher text password. Note that this argument is case-sensitive.
None: Specifies not to perform authentication.
simple simple-password: Specifies to perform plain text authentication and sets the password. The simple-password argument is the password, a case-sensitive string of 1 to 16 characters.
Use the dldp authentication-mode command to configure DLDP authentication.
Use the undo dldp authentication-mode command to restore the default.
By default, DLDP authentication is not performed.
To enable DLDP to operate properly, make sure the DLDP authentication modes and the passwords of the both sides of a link are the same.
# Configure to perform plain text authentication, setting the password as abc (assuming that Device A and Device B are connected by the DLDP link).
l Configuration on Device A
[DeviceA] dldp authentication-mode simple abc
l Configuration on Device B
[DeviceB] dldp authentication-mode simple abc
dldp delaydown-timer
dldp delaydown-timer time
undo dldp delaydown-timer
View
Default Level
2: System level
Time: Setting of the DelayDown timer, in the range 1 to 5 (in seconds).
Use the dldp delaydown-timer command to set the DelayDown timer.
Use the undo dldp delaydown-timer command to restore the default.
By default, the setting of the DelayDown timer is 1 second.
Note that these two commands apply to all the DLDP-enabled ports.
# Set the DelayDown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
dldp enable
dldp enable
undo dldp enable
View
System view, Ethernet port view, port group view
Default Level
2: System level
None
Use the dldp enable command to enable DLDP.
Use the undo dldp enable command to disable DLDP.
When executed in system view, these two commands enables/disables DLDP globally; when executed in Ethernet port view, these two commands enables/disables DLDP on the current port; when executed in port group view, these two commands enables/disables DLDP on all the ports in the port group.
By default, DLDP is disabled globally or on a port.
l These two commands are applicable to Layer 2 Ethernet ports, including optical ports and electrical ports.
l DLDP can take effect only when it is enabled both globally and on a port.
# Enable DLDP globally.
[Sysname] dldp enable
# Enable DLDP on GigabitEthernet 2/0/1.
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] dldp enable
# Enable DLDP for all the ports in port group 1.
[Sysname] port-group manual 1
[Sysname-port-group-manual-1] group-member GigabitEthernet 2/0/1 to GigabitEthernet 2/0/3
[Sysname-port-group-manual-1] dldp enable
dldp interval
dldp interval time
undo dldp interval
View
Default Level
2: System level
time: Interval for sending Advertisement packets, in the range 1 to 100 (in seconds).
Use the dldp interval command to set the interval for sending Advertisement packets.
Use the undo dldp interval command to restore the default.
By default, the interval for sending Advertisement packets is 5 seconds.
Note that:
l These two commands apply to all the DLDP-enabled ports.
l Set the interval for sending Advertisement packets to a value not longer than one-third of the STP convergence time. If the interval is too long, STP loops may occur before unidirectional links are torn down; if the interval is too short, network traffic may increase in vain due to excessive Advertisement packets.
# Set the interval for sending Advertisement packets to 20 seconds.
[Sysname] dldp interval 20
dldp reset
dldp reset
View
Default Level
2: System level
None
Use the dldp reset command to reset DLDP state for ports shut down by DLDP to enable them to perform unidirectional link detect.
When executed in system view, this command applies to all the ports shut down by DLDP; when executed in Ethernet port view, this command applies to the current port; when executed in port group view, this command applies to all the ports in the port group shut down by DLDP.
Related commands: dldp enable, dldp unidirectional-shutdown.
# Reset DLDP state for all the ports shut down by DLDP.
[Sysname] dldp reset
# Reset DLDP state for GigabitEthernet 2/0/1 (assuming that GigabitEthernet 2/0/1 is shut down by DLDP).
[Sysname-GigabitEthernet2/0/1] dldp reset
# Reset DLDP state for all the ports in port group 1 shut down by DLDP.
[Sysname-port-group-manual-1] dldp reset
dldp unidirectional-shutdown { auto | manual }
undo dldp unidirectional-shutdown
View
Default Level
2: System level
auto: Sets the port shutdown mode as auto mode, where, when a unidirectional link is detected, the port involved is shut down by DLDP.
manual: Sets the port shutdown mode as manual mode, where, when a unidirectional link is detected, DLDP prompts you to shut down the involved port instead of doing so automatically.
Use the dldp unidirectional-shutdown command to set the port shutdown mode.
Use the undo dldp unidirectional-shutdown command to restore the default.
By default, the port shutdown mode is auto mode.
Related commands: dldp work-mode.
# Set the port shutdown mode as auto mode.
[Sysname] dldp unidirectional-shutdown auto
dldp work-mode
dldp work-mode { enhance | normal }
undo dldp work-mode
View
Default Level
2: System level
enhance: Specifies the enhanced DLDP mode. When a device operates in this mode and a neighbor entry it maintains expires, the device detects the neighbor before removing the neighbor entry.
normal: Specifies the normal DLDP mode. When a device operates in this mode and a neighbor entry it maintains expires, the device removes the neighbor entry directly.
Use the dldp work-mode command to set the DLDP mode.
Use the undo dldp work-mode command to restore the default DLDP mode.
By default, a device operates in normal DLDP mode.
Note that:
l In normal DLDP mode, only fiber cross-connected unidirectional links can be detected.
l In enhanced DLDP mode, two types of unidirectional links can be detected. One is fiber cross-connected links. The other refers to fiber pairs with one fiber not connected or disconnected.
The support for these two commands varies with device models.
# Configure the device to operate in enhanced DLDP mode.
[Sysname] dldp work-mode enhance
reset dldp statistics
reset dldp statistics [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the reset dldp statistics command to clear the statistics on DLDP packets passing through a port.
If you do not provide the interface-type or interface-number argument, this command clears the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Clear the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> reset dldp statistics
