- 01-Access Volume
- 00-Access Volume Organization
- 01-Ethernet Interface Commands
- 02-Link Aggregation Commands
- 03-Port Isolation Commands
- 04-Service Loopback Group Commands
- 05-DLDP Commands
- 06-Smart Link Commands
- 07-LLDP Commands
- 08-VLAN Commands
- 09-GVRP Commands
- 10-QinQ Commands
- 11-BPDU Tunneling Commands
- 12-VLAN Mapping Commands
- 13-Ethernet OAM Commands
- 14-Connectivity Fault Detection Commands
- 15-EPON OLT Commands
- 16-MSTP Commands
- 17-RRPP Commands
- 18-Mirroring Commands
| 03-Port Isolation Commands | 27.23 KB |
Port Isolation Configuration Commands
display port-isolate group
View
Default Level
1: Monitor level
None
Use the display port-isolate group command to display information about the default isolation group (isolation group 1).
# On a single-isolation-group device, display information about the isolation group.
<Sysname> display port-isolate group
Port-isolate group information:
Uplink port support: NO
Group ID: 1
Ethernet2/0/4 Ethernet2/0/5
Table 1-1 display port-isolate group command output description
Port-isolate group information |
Display the information of a port-isolation group |
Uplink port support |
Indicates whether the uplink port is supported. |
Group ID |
Isolation group number |
Ethernet2/0/4 Ethernet2/0/5 |
Isolated ports in the isolation group |
port-isolate enable
port-isolate enable
undo port-isolate enable
View
Ethernet interface view, Layer-2 aggregate interface view, port group view
Default Level
2: System level
group group-number: Specifies the ID of the group to which the ports are to be added. The value range varies with devices.
Use the port-isolate enable command to add a port in Ethernet interface view or a group of ports in port group view to an isolation group as isolated ports.
Use the undo port-isolate enable command to remove the port or ports from the isolation group.
l In Ethernet interface view, the configuration applies to the current port.
l In port group view, the configuration applies to all ports in the port group.
l In Layer-2 aggregate interface view, the configuration applies to the Layer-2 aggregate interface and all its member ports. After you make the configuration, the system starts applying the configuration to the aggregate interface and its aggregation member ports. If the system fails to do that on the aggregate interface, it stops applying the configuration to the aggregation member ports. If it fails to do that on an aggregation member port, it simply skips the port and moves to the next port. For detailed information about Layer-2 aggregate interfaces, refer to Link Aggregation Configuration in the Access Volume.
Note that: This command adds a port to the default isolation group (isolation group 1).
# Assign ports Ethernet 2/0/1 to the isolation group.
[Sysname] interface ethernet 2/0/1
[Sysname-Ethernet2/0/1] port-isolate enable
# Assign all the ports within port group aa to the isolation group.
[Sysname] port-group manual aa
[Sysname-port-group-manual-aa] group-member ethernet 2/0/2
[Sysname-port-group-manual-aa] group-member ethernet 2/0/3
[Sysname-port-group-manual-aa] group-member ethernet 2/0/4
[Sysname-port-group-manual-aa] port-isolate enable
# Assign Layer-2 aggregate interface Bridge-aggregation 1 and its member ports to the isolation group.
[Sysname-Bridge-Aggregation1] quit
[Sysname] interface Ethernet 2/0/1
[Sysname-Ethernet2/0/1] port link-aggregation group 1
[Sysname-Ethernet2/0/1] quit
[Sysname] interface Ethernet 2/0/2
[Sysname-Ethernet2/0/2] port link-aggregation group 1
[Sysname-Ethernet2/0/2] quit
[Sysname-Bridge-Aggregation1] port-isolate enable
