- 01-Access Volume
- 00-Access Volume Organization
- 01-Ethernet Interface Commands
- 02-Link Aggregation Commands
- 03-Port Isolation Commands
- 04-Service Loopback Group Commands
- 05-DLDP Commands
- 06-Smart Link Commands
- 07-LLDP Commands
- 08-VLAN Commands
- 09-GVRP Commands
- 10-QinQ Commands
- 11-BPDU Tunneling Commands
- 12-VLAN Mapping Commands
- 13-Ethernet OAM Commands
- 14-Connectivity Fault Detection Commands
- 15-EPON OLT Commands
- 16-MSTP Commands
- 17-RRPP Commands
- 18-Mirroring Commands
| 12-VLAN Mapping Commands | 45.98 KB |
l On the S7500E series switches, VLAN mapping is achieved mainly through QoS policies. This chapter introduces part of the commands for ports involved in many-to-one VLAN mapping. For QoS policy configuration commands, refer to QoS Commands in the QoS Volume.
l Only SC boards support many-to-one VLAN mapping. For detailed introduction to boards, refer to the Installation Manual.
VLAN Mapping Configuration Commands
qinq enable downlink
undo qinq enable
View
Ethernet interface view, port group view, Layer-2 aggregate interface view
Default Level
2: System level
None
Use the qinq enable downlink command to enable customer-side QinQ on the current Ethernet port(s).
Use the undo enable downlink command to disable customer-side QinQ on the current Ethernet port(s).
By default, customer-side QinQ is disabled on Ethernet ports.
Configuration made in Ethernet interface view takes effect on the current port only, while configuration made in port group view takes effect on all ports in the port group.
# Enable customer-side QinQ on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qinq enable downlink
# Enable customer-side QinQ on port group 1.
[Sysname] port-group manual 1
[Sysname-port-group-manual-1] group-member gigabitethernet 2/0/1 to gigabitethernet 2/0/6
[Sysname-port-group-manual-1] qinq enable downlink
qinq enable uplink
qinq enable uplink
undo qinq enable
View
Default Level
2: System level
None
Use the qinq enable uplink command to enable service provider-side QinQ on the current Ethernet port(s).
Use the undo enable downlink command to disable service provider-side QinQ on the current Ethernet port(s).
By default, service provider-side QinQ is disabled on Ethernet ports.
# Enable service provider-side QinQ on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qinq enable uplink
# Enable service provider-side QinQ on port group 1.
[Sysname-port-group-manual-1] qinq enable uplink
