- 01-Access Volume
- 00-Access Volume Organization
- 01-Ethernet Interface Commands
- 02-Link Aggregation Commands
- 03-Port Isolation Commands
- 04-Service Loopback Group Commands
- 05-DLDP Commands
- 06-Smart Link Commands
- 07-LLDP Commands
- 08-VLAN Commands
- 09-GVRP Commands
- 10-QinQ Commands
- 11-BPDU Tunneling Commands
- 12-VLAN Mapping Commands
- 13-Ethernet OAM Commands
- 14-Connectivity Fault Detection Commands
- 15-EPON OLT Commands
- 16-MSTP Commands
- 17-RRPP Commands
- 18-Mirroring Commands
| 09-GVRP Commands | 57.18 KB |
Table of Contents
1 GARP/GVRP Configuration Commands
display gvrp local-vlan interface
display gvrp vlan-operation interface
GARP Configuration Commands
display garp statistics
display garp statistics [ interface interface-list ]
View
Default Level
1: Monitor level
interface interface-list: Defines one or multiple Ethernet ports for which the GARP statistics will be displayed. You can provide up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1. If no ports are specified, this command displays the GARP statistics for all ports.
Use the display garp statistics command to display the GARP statistics of the specified port(s) or all ports if no ports are specified.
This command displays the statistics about GVRP packets received, transmitted, and dropped on GVRP-enabled ports. When the system is restarted or after you perform the reset garp statistics command, the existing packet statistics are cleared and the system starts to collect new GARP statistics. With the statistics, you can judge whether a GVRP-enabled port is operating normally.
l If the number of received and transmitted GVRP packets on the port is the same as that on the remote port, it indicates that the two ends are transmitting and receiving GVRP packets normally and no registration information is lost.
l If there are dropped GVRP packets on the port, check its registration mode. GVRP packets are likely to be dropped if the registration mode is fixed or forbidden, because dynamic VLANs cannot be registered in either of the modes.
# Display statistics about GARP for port GigabitEthernet 2/0/1.
<Sysname> display garp statistics interface GigabitEthernet2/0/1
GARP statistics on port GigabitEthernet2/0/1
Number of GVRP Frames Received : 0
Number of GVRP Frames Transmitted : 0
Number of Frames Discarded : 0
display garp timer
display garp timer [ interface interface-list ]
View
Default Level
1: Monitor level
interface interface-list: Defines one or multiple Ethernet ports. You can provide up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1. If no ports are specified, this command displays the GARP timer settings on all ports.
Use the display garp timer command to display GARP timer settings of specific ports.
Note that:
l If the interface interface-list keyword-argument combination is not specified, this command displays the GARP timer settings of all the ports.
l If the interface interface-list keyword-argument combination is specified, this command displays the GARP timer settings of the specified ports.
Related commands: garp timer, garp timer leaveall.
# Display GARP timers on port GigabitEthernet 2/0/1.
<Sysname> display garp timer interface GigabitEthernet 2/0/1
GARP timers on port GigabitEthernet2/0/1
Garp Join Time : 20 centiseconds
Garp Leave Time : 60 centiseconds
Garp LeaveAll Time : 1000 centiseconds
Garp Hold Time : 10 centiseconds
garp timer
garp timer { hold | join | leave } timer-value
undo garp timer { hold | join | leave }
View
Ethernet interface view, Layer-2 aggregate interface view, port group view
Default Level
2: System level
hold: Sets the hold timer.
join: Sets the join timer.
leave: Sets the leave timer.
timer-value: Timer setting (in centiseconds), which must be a multiple of 5.
Use the garp timer command to set a GARP timer for an Ethernet port or all ports in a port group in compliance with the timer setting dependencies shown in Table 1-1.
Use the undo garp timer command to restore the default of a GARP timer. This may fail if the default does not satisfy the dependencies shown in Table 1-1.
By default, the hold timer, the join timer, and the leave timer are set to 10 centiseconds, 20 centiseconds, and 60 centiseconds.
Note that:
l In Ethernet/Layer-2 aggregate interface view, these two commands apply to the current port only; in port group view, these two commands apply to all the ports in the port group.
l The GVRP configuration made on a link aggregation member port can take effect only after the port is removed from the group. For more information about link aggregation, refer to Link Aggregation Configuration in the Access Volume.
l When restoring the default GARP timers, you are recommended to do that on the timers in the order of hold, join, leave, and leaveall.
l When configuring GARP timers, note that their values are dependent on each other and must be a multiplier of five centiseconds. If the value range for a timer is not desired, you may change it by tuning the value of another timer as shown in the following table:
Table 1-1 Dependencies of GARP timers
Timer |
Lower limit |
Upper limit |
Hold |
10 centiseconds |
Not greater than half of the join timer setting |
Join |
Not less than two times the hold timer setting |
Less than half of the leave timer setting |
Leave |
Greater than two times the join timer setting |
Less than the leaveall timer setting |
Leaveall |
Greater than the leave timer setting |
32765 centiseconds |
Related commands: display garp timer.
# Set the GARP join timer to 25 centiseconds, assuming that both the hold timer and the leave timer are using the default.
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] garp timer join 25
garp timer leaveall
garp timer leaveall timer-value
undo garp timer leaveall
View
Default Level
2: System level
timer-value: Leaveall timer setting, in the range 65 to 32765 (in centiseconds), Note that the setting of the leaveall timer must be a multiple of 5 centiseconds and must be greater than the leave timer settings of all the ports.
Use the garp timer leaveall command to set the leaveall timer of GARP.
Use the undo garp timer leaveall command to restore the default. This may fail if the default is less than the setting of the current leave timer.
By default, the setting of the leaveall timer is 1000 centiseconds (that is, 10 seconds).
A leaveall timer starts upon the start of a GARP application entity. When this timer expires, the entity sends a LeaveAll message so that other entities can re-register its attribute information and starts another leaveall timer at the same time.
Each time a device on the network receives a LeaveAll message, it resets its leaveall timer. Therefore, a GARP application entity may send LeaveAll messages at the interval set by its leaveall timer or the leaveall timer on another device on the network, whichever is smaller.
# Set the leaveall timer to 100 centiseconds, assuming that the leave timer is 60 centiseconds.
[Sysname] garp timer leaveall 100
reset garp statistics [ interface interface-list ]
View
2: System level
interface interface-list: Defines one or multiple Ethernet ports for which the GARP statistics are to be cleared. You can provide up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1.
Use the reset garp statistics command to clear the GARP statistics of the specified ports or all ports if no ports are specified.
The cleared statistics include the statistics about GVRP packets received, sent and dropped.
Related commands: display gvrp statistics.
# Clear statistics about GARP on all ports.
<Sysname> reset garp statistics
display gvrp local-vlan interface interface-type interface-number
View
Default Level
0: Visit level
interface interface-type interface-number: Displays the local VLAN information maintained by GVRP on the port specified by its type and number.
Use the display gvrp local-vlan interface command to display the local VLAN information maintained by GVRP on the specified port.
# Display the local VLAN information maintained by GVRP on GigabitEthernet 2/0/1.
<Sysname> display gvrp local-vlan interface GigabitEthernet 2/0/1
Following VLANs exist in GVRP local database:
1(default),2-500
// The information above shows that GVRP maintains the information about VLAN 1, VLAN 2 through VLAN 500, which GigabitEthernet 2/0/1 belongs to.
display gvrp state
display gvrp state interface interface-type interface-number vlan vlan-id
View
Default Level
0: Visit level
vlan vlan-id: Specifies a VLAN ID, in the range of 1 to 4094.
Use the display gvrp state command to display the current GVRP state.
# Display the GVRP state of VLAN 1, which GigabitEthernet 2/0/1 belongs to.
<Sysname> display gvrp state interface GigabitEthernet 2/0/1 vlan 1
GVRP state of VLAN 1 on port GigabitEthernet2/0/1
Applicant state machine : VP
Registrar state machine : MTR
display gvrp statistics [ interface interface-list ]
View
Default Level
1: Monitor level
interface interface-list: Defines one or multiple Ethernet ports. You can provide up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1. If no ports are specified, this command displays the GVRP statistics for all trunk ports.
Use the display gvrp statistics command to display the GVRP statistics of specified or all trunk ports.
Note that if the interface interface-list is not provided, the GVRP statistics of all trunk ports will be displayed. Otherwise, only the GVRP statistics of all the specified trunk port will be displayed.
# Display statistics about GVRP for trunk port GigabitEthernet 2/0/1.
<Sysname> display gvrp statistics interface GigabitEthernet 2/0/1
GVRP statistics on port GigabitEthernet2/0/1
GVRP Status : Enabled
GVRP Running : YES
GVRP Failed Registrations : 0
GVRP Last Pdu Origin : 0000-0000-0000
GVRP Registration Type : Normal
Table 1-2 display gvrp statistics command output description
GVRP Status |
Indicates whether GVRP is enabled or disabled. |
GVRP Running |
Indicates whether GVRP is running. |
GVRP Failed Registrations |
Indicates the number of GVRP registration failures. |
GVRP Last Pdu Origin |
Indicates the source MAC address in the last GVRP PDU. |
GVRP Registration Type |
Indicates the GVRP registration type on the port. |
display gvrp status
display gvrp status
View
Default Level
1: Monitor level
None
Use the display gvrp status command to display the global enable/disable state of GVRP.
# Display the global GVRP enable/disable state.
<Sysname> display gvrp status
GVRP is enabled
display gvrp vlan-operation interface interface-type interface-number
View
Default Level
0: Visit level
interface interface-type interface-number: Displays the information about dynamic VLAN operations on the port specified by its type and number.
Use the display gvrp vlan-operation interface command to display the information about dynamic VLAN operations performed on a port.
# Display the information about dynamic VLAN operations performed on GigabitEthernet 2/0/1.
<Sysname> display gvrp vlan-operation interface GigabitEthernet 2/0/1
Dynamic VLAN operations on port GigabitEthernet2/0/1
Operations of creating VLAN : 2-100
Operations of deleting VLAN : none
Operations of adding VLAN to TRUNK : 2-100
Operations of deleting VLAN from TRUNK : none
gvrp
gvrp
undo gvrp
View
System view, Ethernet interface view, Layer-2 aggregate interface view, port group view
Default Level
2: System level
None
Use the gvrp command to enable GVRP globally (in system view), on a port (in Ethernet or Layer-2 aggregate interface view), or on all ports in a port group (in port group view).
Use the undo gvrp command to disable GVRP globally, on a port, or on all ports in a port group depending on the view the command is executed.
By default, GVRP is disabled.
Note that:
l To enable GVRP on a port, you need to enable it globally first.
l The port where you enable/disable GVRP must be a trunk port.
l GVRP is mutually exclusive with service loopback.
l In an MSTP network, GVRP can run on only the CIST. In addition, blocked ports on the CIST cannot receive/send GVRP packets.
l Enabling GVRP on a Layer-2 aggregate interface enables both the aggregate interface and all selected member ports in the corresponding link aggregation group to participate in dynamic VLAN registration and deregistration. In addition, the GVRP configuration made on a link aggregation member port can take effect only after the port is removed from the group. For more information about link aggregation, refer to Link Aggregation Configuration in the Access Volume.
Related commands: display gvrp status.
# Enable GVRP globally.
[Sysname] gvrp
GVRP is enabled globally.
gvrp registration
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
Default Level
2: System level
fixed: Sets the registration type to fixed.
forbidden: Sets the registration type to forbidden.
normal: Sets the registration type to normal.
Use the gvrp registration command to configure the GVRP registration type on a port (in Ethernet or Layer-2 aggregate interface view) or all ports in a port group (in port group view).
Use the undo gvrp registration command to restore the default on a port, or on all ports in a port group depending on the view the command is executed.
The default GVRP registration type is normal.
GVRP provides the following three registration types on a port:
l Normal –– Enables the port to dynamically register/deregister VLANs, and to propagate both dynamic and static VLAN information.
l Fixed –– Disables the port from dynamically registering/deregistering VLANs or propagating information about dynamic VLANs, but allows the port to propagate information about static VLANs. A trunk port with fixed registration type thus allows only manually configured VLANs to pass through even though it is configured to carry all VLANs.
l Forbidden –– Disables the port from dynamically registering/deregistering VLANs or propagating VLAN information except information about VLAN 1. A trunk port with forbidden registration type thus allows only VLAN 1 to pass through even though it is configured to carry all VLANs.
Note that:
l This command is only available on trunk ports.
l The GVRP configuration type configuration made on a link aggregation member port can take effect only after the port is removed from the group. For more information about link aggregation, refer to Link Aggregation Configuration in the Access Volume.
Related commands: display garp statistics.
# Set the GVRP registration type to fixed on port GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] port link-type trunk
[Sysname-GigabitEthernet2/0/1] gvrp registration fixed
