H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
00-2Product Overview
00-2Product Overview 311.44 KB
Table of Contents
Chapter 1 Obtaining the Documentation. 1-1
1.1 CD-ROM.. 1-1
1.2 H3C Website. 1-1
1.3 Software Release Notes. 1-2
Chapter 2 Documentation and Software Version. 2-1
2.1 Software Version for the Manual 2-1
2.2 Document List 2-1
Chapter 3 Product Overview.. 3-1
3.1 Preface. 3-1
3.2 Switch Models. 3-1
3.3 Software Features. 3-3
Chapter 4 Networking Applications. 4-1
4.1 H3C S3610 Series Ethernet Switches Networking Applications. 4-1
4.1.1 Broadband Ethernet Access for Residential Communities. 4-1
4.1.2 Application in Networks of Branches or Small- to Medium-Sized Enterprises. 4-1
4.1.3 Application in Large Enterprise and Campus Networks. 4-2
4.1.4 IPv4/IPv6 Hybrid Networking. 4-3
4.2 H3C S5510 Series Ethernet Switches Networking Applications. 4-4
4.2.1 Broadband Ethernet Access for Residential Communities. 4-4
4.2.2 Application in Networks of Branches or Small/Medium-Sized and Large Enterprises. 4-5
4.2.3 Application in Large Enterprise and Campus Networks. 4-6
4.2.4 IPv4/IPv6 Hybrid Networking. 4-7
H3C Technology Co., Ltd. provides various ways for you to obtain documentation, through which you can obtain the product documentations and those concerning newly added new features. The documentations are available in one of the following ways:
l           CD-ROMs shipped with the devices
l           H3C website
l           Software release notes
1.1  CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete product document set, including the operation manual and command manual. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
1.2  H3C Website
To query and download the documentation for this version, go to the website of H3C with reference of the following Table.
Table 1-1 Acquire product documentation from the H3C website
How to apply for an account
Access the homepage of H3C at http:// www.h3c.com and click on Registration at the top right. In the displayed page, provide your information and click on Submit to register.
How to get documentation
Approach 1:
In the homepage of H3C at http:// www.h3c.com, select Technical Support & Document > Technical Documents from the navigation menu at the top. Then select a product for its documents.
Approach 2:
In the homepage of H3C at http:// www.h3c.com, select Support > Technical Documents. Then select a product for its documents.
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
H3C S3610&S5510 Series Ethernet Switches  Operation Manual Release 5303 and H3C S3610&S5510 Series Ethernet Switches  Command Manual Release 5303 correspond to the following software version of the S3610&S5510 series switches: Release 5303.
Compared with Release 5301, many new features are added in Release 5303. For details, refer to Table 2-1
Table 2-1 Added features in Release 5303
Features
Location
VLAN check
02-VLAN
MAC Address Synchronization
04-QinQ-BPDU Tunneling
VLAN ignore
09-MSTP
Transparent BPDU Transmission
BPDU Tagging Function
EAD Fast Deployment Configuration
16-802.1x-HABP-MAC Authentication
Configure burst-traffic in port group view
21-QoS
Traffic mirroring to CPU
2.2  Document List
Table 2-2 Document list
Name
Version
H3C S3610 Series Ethernet Switches  Installation Manual
(V1.07)
H3C S5510 Series Ethernet Switches  Installation Manual
(V1.05)
H3C S3610&S5510 Series Ethernet Switches  Operation Manual – Release 5303
(V1.01)
H3C S3610&S5510 Series Ethernet Switches  Command Manual – Release 5303
(V1.01)
3.1  Preface
H3C S3610&S5510 Series Ethernet Switches are wire speed L2/L3 Ethernet switches developed by H3C Technology. They are intelligent network management switches intended for a network environment where high performance, dense port distribution, and ease of installation are required.
The H3C S3610&S5510 series are designed to accommodate the convergence on Intranets and metropolitan area networks (MANs) and to meet the requirements at the access layer. Supporting IPv4/IPv6 double stack, they offer abundant service features and routing functionalities.
3.2  Switch Models
Table 3-1 lists the models in the H3C S3610 series:
Table 3-1 Models in the H3C S3610 series
Model
Power supply unit (PSU)
Number service ports
Number of 100 Mbps ports
Number of 1,000 Mbps uplink ports
Console port
S3610-28P
AC-input, DC-input
28
24 10/100 Mbps (electrical)
4 (SFP)
1
S3610-28TP
AC-input, DC-input
28
2 (SFP)
2 × 10/100/1,000 Mbps (electrical)
1
S3610-28F
AC-input, DC-input
28
24 × 100M SFP ports
2 (SFP)
1
S3610-52P
AC-input, DC-input
52
48 10/100 Mbps (electrical)
4 (SFP)
1
S3610-52M-AC
AC-input
Up to 48×10/100 Mbps electrical ports or 48×100 Mbps SFP ports (depending on the modules installed)
4×1000 Mbps SFP ports and 4×10/100/1000 Mbps electrical ports on the rear panel
1
S3610-52M-DC
DC-input
1
Table 3-2 Combo ports and the corresponding ports on S3610 series
Model
Combo port
Corresponding port
S3610-52M-AC/S3610-52M-DC
49
53
50
54
51
55
52
56
Table 3-3 lists the models in the S5510 series:
Table 3-3 Models in the S5510 series
Model
Number of service ports
Port
Console port
H3C S5510-24P-AC
AC-input
28
24 × 10/100/1000 Mbps (electrical)
4 Gigabit SFP Combo port
1
H3C S5510-24P-DC
DC-input
28
4 Gigabit SFP Combo ports
1
H3C S5510-24F-AC
AC-input
28
24 Gigabit SFP ports
4 × 10/100/100 Mbps Combo (electrical)
1
H3C S5510-24F-DC
DC-input
28
4 × 10/100/1000 Mbps Combo ports
1
There are two power slots on the rear panel of an S5510 Ethernet switch. An S5510
Ethernet switch is shipped with a power supply module installed in the power supply slot PWR1 only. The power supply slot PWR2 is covered by a blank panel. You can optionally install an AC/DC power supply module in PWR2 slot as a backup of PWR1.
Table 3-4 Combo ports and the corresponding ports on S5510 series
Specification
Combo ports
Matching ports
S5510-24P/S5510-24F
25
22
26
24
27
21
28
23
H3C S3610&S5510 series Ethernet switches provide abundant software features to meet different requirements of users. The following table lists the features of each part.
Table 3-5 Features of S3610&S5510 series Ethernet switches
Part
Feature
01-Login
l      Logging into a switch through the Console port
l      Logging into a switch by using Telnet through an Ethernet port
l      Logging into a switch by using Modem through the Console port
l      Logging into a switch through Web or NMS
02-VLAN
l      IEEE 802.1Q-compliant virtual local area network (VLAN).
l      Port-based VLAN
l      VLAN check
l      Protocol-based VLAN
l      Voice VLAN
l      GARP VLAN Registration Protocol (GVRP)
03- IP Addressing and Performance
l      Configuring an IP address for a switch
l      Configuring TCP attributes for a switch
04-QinQ-BPDU Tunnelling
l      QinQ
l      Flexible QinQ
l      MAC Address Synchronization
l      BPDU Tunnel
05-Port Correlation Configuration
l      Three port states: Access, Trunk, and Hybrid.
l      Setting broadcast suppression ratio globally.
l      Loopback detection
l      Cable test
l      Link aggregation control protocol (LACP)
l      Configuring port isolation group
06-Link Aggregation
l      Static link aggregation using LACP (Link Aggregation Control Protocol)
l      Manually created link aggregation group
07-MAC Address Table Management
l      Configuring dynamic, static, and blackhole MAC addresses
l      Configuring aging time for MAC addresses
l      Configuring MAC address learning limit on each port
08- IP Source Guard
l      Configuring MAC address-IP address-port binding
09-MSTP
l      STP/RSTP/MSTP
l      BPDU guard
l      Root guard
l      Loop guard
l      TC-BPDU attack guard
l      VLAN Ignore
l      Transparent BPDU transmission
l      BPDU Tagging Function
10-IPv6
l      IPv6 basic configuration
l      Ping IPv6/Traceroute IPv6
l      Manual IPv6 tunnel
l      Configuring IPv4 compatible with the IPv6 tunnel
l      6to4 tunnel
l      ISATAP tunnel
l      IPv4/IPv6 double protocol stacks
11-Routing Overview
Provide an overview of IPv4/IPv6 routing and routing table display and maintenance.
12-IPv4 Routing
l      Static route
l      Routing information protocol (RIP) v1/v2
l      Open shortest path first (OSPF)
l      Intermediate System-to-Intermediate System intra-domain routing information exchange protocol (IS-IS)
l      Border gateway protocol (BGP)
l      Routing policy
13-BFD-GR
l      Configuring static route-based BFD (Bidirectional Forwarding Detection)
l      Configuring OSPF-/BGP-/IS-IS-based GR
14-IPv6 Routing
l      IPv6 static route
l      RIPng
l      OSPFv3
l      IPv6 IS-IS
l      IPv6 BGP
l      IPv6 routing policy
15-Multicast Protocol
l      Internet group management protocol (IGMP) Snooping
l      Multicast listener discovery (MLD)-Snooping
l      Protocol-independent multicast-dense mode (PIM-DM)
l      Protocol-independent multicast-sparse mode (PIM-SM)
l      Multicast source discovery protocol (MSDP)
l      802.1x authentication
l      Guest VLAN
l      EAD fast deployment
l      Huawei authentication bypass protocol (HABP)
l      MAC address authentication
17-AAA-RADIUS-HWTACACS
l      Authentication, authorization, and accounting (AAA)
l      Remote authentication dial-in user service (RADIUS)
l      Huawei terminal access controller access control system (HWTACACS)
18-ARP
l      Configuring ARP entries manually
l      Gratuitous ARP
l      ARP source suppression
l      Proxy ARP
19-DHCP
l      DHCP server
l      DHCP relay
l      DHCP Snooping
l      Applying option184 in DHCP server function
l      Applying option82 in DHCP server/DHCP relay function
20-ACL
l      IPv4 basic ACLs
l      IPv4 advanced ACLs
l      Layer 2 ACLs
l      IPv4 user-defined ACLs
l      IPv6 basic ACLs
l      IPv6 advanced ACLs
l      Flow template
21-QoS
l      Traffic classification, traffic policing, and traffic shaping
l      QoS policy
l      Congestion management
l      Priority mapping
l      Congestion avoidance
l      Aggregated CAR
l      VLAN policy
l      Traffic mirroring
22-Port Mirroring
l      Local port mirroring
l      Remote port mirroring
23- Cluster Management
l      Huawei group management protocol (HGMP) v2
l      Neighbor discovery protocol (NDP)
l      Neighbor topology discovery protocol (NTDP)
24-UDP Helper
l      Forwarding UDP broadcast packets by using UDP Helper
25- SNMP-RMON
l      Simple network management protocol (SNMP) v3, compatible with SNMP v1/v2
l      Remote monitoring (RMON)
26-NTP
l      Network time protocol (NTP)
27-DNS
l      Static DNS
l      Dynamic DNS
28-File System Management
l      File system management
l      Configuration file management
l      Configuring a switch as an FTP server/FTP client
l      Configuring a switch as a TFTP client
29-Information Center
l      System logs
l      Alarms in different severities
l      Debugging information output
30- System Maintaining and Debugging
l      Configuring command levels
l      Configuring online help for command lines
l      Configuring system time
l      Displaying and configuring system device state
31-NQA
l      Network Quality Analyzer (NQA)
32-VRRP
l      IPv4-based Virtual Router Redundancy Protocol (VRRP)
l      IPv6-based VRRP
33-SSH
l      Secure shell (SSH)
34-MCE
l      Multi-CE (MCE)
35-OAM
l      Ethernet OAM (operation, administration, and maintenance)
36-DLDP
l      Device Link Detection Protocol (DLDP)
37-RRPP
l      Rapid Ring Protection Protocol (RRPP)
38-SSL-HTTPS
l      Secure Socket Layer (SSL)
l      HTTP Security (HTTPS)
39-PKI
l      Public Key Infrastructure (PKI)
On the broadband access network of a residential community, an H3C S3610 switch is located in the center. It is downlinked to Layer 2 switches (such as S3100 series) to reach the Ethernet users and uplinked to a core Layer 3 switch through a GE extension module to connect to the MAN backbone.
Figure 4-1 Community Ethernet access networking with H3C S3610 series
For small-to medium-sized enterprises or branches of a large enterprise, the H3C S3610 series can serve as the backbone switches on their networks and can be connected to the headquarters or other branches through routers.
Figure 4-2 H3C S3610 series application in branch network of midsize/large enterprise
In a large enterprise or campus network, the H3C S3610 series are located at the convergence layer. They are downlinked to Layer 2 switches, S3100 Series for example; and uplinked to a layer 3 switch through GE interfaces. These switches together provide a network-wide intranet solution that covers gigabit-to-backbone and 100 Mbps-to-desktop.
Figure 4-3 H3C S3610 series application in large enterprise and campus network
Full IPv4 networking and full IPv6 networking are similar. At the early stage of IPv6 implementation, however, IPv4/IPv6 hybrid networks are common. This gives full play to the IPv4/IPv6 dual-stack and IPv6 over IPv4 tunneling features provided by the H3C S3610 series and enables flexible networking.
Figure 4-4 Application in a large enterprise and campus IPv4/IPv6 hybrid network
An H3C S5510 series Ethernet switch can operate on the distribution layer of a broadband MAN. You can connect it to a backbone router or Layer 3 switch in the uplink direction through its GigabitEthernet optical ports, and connect it to Layer 2/Layer 3 devices operating as the portal devices of community networks through its GigabitEthernet optical ports. Additionally, you can use multiple GigabitEthernet ports to form GigabitEthernet trunk ports so as to broaden the uplink and downlink bandwidth.
Figure 4-5 Network diagram for using H3C S5510 series Ethernet switches in broadband MAN
In the branches of a small-/medium-sized or large enterprises, you can use H3C S5510 series Ethernet switches as the backbone layer devices. In this case, network devices can connect to an S5510 Ethernet switch in the following ways.
l           Connecting the Layer 2/Layer 3 Ethernet switches (such as S3026/3526 Ethernet switches) of workgroups to GigabitEthernet optical ports or electrical interfaces
l           Connecting to the other floors/buildings through long-/short-haul GigabitEthernet optical ports
l           Connecting to the server directly through GigabitEthernet/100 Mbps electrical ports or connecting to the server group through the Layer 2/Layer 3 Ethernet switches in the workgroup through GigabitEthernet/100 Mbps electrical ports
l           Connecting to routers through 10/100 Mbps electrical ports
Figure 4-6 Network diagram for using H3C S5510 series Ethernet switches in networks of small-/medium-sized and large enterprises
H3C S5510 series Ethernet switches can operate as the distribution layer devices in the networks of large enterprises and campus networks. In this case, you can connect an S5510 Ethernet switch to a backbone router or Layer 3 switches through its GigabitEthernet optical ports or electrical ports, and connect Layer 2 or Layer 3 devices in workgroups to the GigabitEthernet optical ports or electrical ports of the S5510 Ethernet switch.
Figure 4-7 H3C S5510 series application in large enterprise and campus network
Full IPv4 networking and full IPv6 networking are similar. At the early stage of IPv6 implementation, however, IPv4/IPv6 hybrid networks are common. This gives full play to the IPv4/IPv6 dual-stack and IPv6 over IPv4 tunneling features provided by the H3C S5510 series and enables flexible networking.
Figure 4-8 Network diagram for using H3C S5510 series in the IPv4/IPv6 hybrid network of large enterprises and campuses
