H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
08-IP Source Guard Configuration
08-IP Source Guard Configuration 100.86 KB
Chapter 1  IP Source Guard Configuration
When configuring IP Source Guard, go to these sections for information you are interested in:
l           IP Source Guard Overview
l           Configuring a Static Binding Entry
l           Configuring Port Filtering
l           Displaying IP Source Guard
l           IP Source Guard Configuration Examples
l           Troubleshooting
1.1  IP Source Guard Overview
By filtering packets on a per-port basis, IP source guard prevents packets with illegal IP addresses and MAC addresses from traveling through, improving the network security. IP source guard filters packets based on two types of binding entries:
l           IP-port binding entry: A port permits packets with source IP addresses among its IP-port binding entries.
l           MAC-IP-port binding entry: A port permits packets with source MAC address and source IP address pairs among its MAC-IP-port binding entries.
All other packets are denied.
  Caution:
IP source guard and aggregation group configuration are mutually exclusive.
1.2  Configuring a Static Binding Entry
Follow these steps to configure a static binding entry:
To do…
Use the command…
Remarks
Enter system view
Enter interface view
Configure a static binding entry
user-bind ip-address ip-address [ mac-address mac-address
Required
No static binding entry exists by default.
&  Note:
l      The system does not support repeatedly binding a binding entry to one port. A binding entry can be configured to multiple ports
l      In a valid binding entry, the MAC address cannot be all 0s, all Fs (a broadcast address), or a multicast address, and the IP address can only be a Class A, Class B, or Class C address and can be neither 127.x.x.x nor 0.0.0.0.
1.3  Configuring Port Filtering
Port filtering allows IP source guard to filter packets based on the MAC-IP-port binding entries created and maintained by DHCP snooping.
Follow these steps to configure port filtering:
To do…
Use the command…
Remarks
Enter system view
Configure port filtering
ip check source ip-address [ mac-address ]
Required
Not configured by default
1.4  Displaying IP Source Guard
To do…
Use the command…
Remarks
Display information about static binding entries
display user-bind [ interface interface-type interface-number | ip-address ip-address | mac-address mac-address ]
Available in any view
Display information about dynamic binding entries
display ip check source [ interface interface-type interface-number | ip-address ip-address | mac-address mac-address ]
1.5  IP Source Guard Configuration Examples
1.5.1  Static Binding Entry Configuration Example
I. Network requirements
As shown in Figure 1-1, switches A and B and Hosts A, B and C are on an Ethernet. Host A and Host B are connected to ports Ethernet 1/0/1 and Ethernet 1/0/2 of Switch B respectively, Host C is connected to port Ethernet 1/0/1 of Switch A, while Switch B is connected to port Ethernet 1/0/2 of Switch A.
Detailed requirements are as follows:
l           On port Ethernet 1/0/2 of Switch A, only IP packets with the source MAC address of 00-01-02-03-04-05 and the source IP address of 192.168.0.3 can pass.
l           On port Ethernet 1/0/1 of Switch A, only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 can pass.
l           On port Ethernet 1/0/1 of Switch B, only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 can pass.
l           On port Ethernet 1/0/2 of Switch B, only IP packets with the source MAC address of 00-01-02-03-04-07 and the source IP address of 192.168.0.2 can pass.
II. Network diagram
Figure 1-1 Network diagram for configuring static binding entries
III. Configuration procedure
1)         Configure Switch A
# Configure the IP addresses of various interfaces (omitted).
# Configure port Ethernet 1/0/2 of Switch A to allow only IP packets with the source MAC address of 00-01-02-03-04-05 and the source IP address of 192.168.0.3 to pass.
[SwitchA] interface ethernet 1/0/2
[SwitchA-Ethernet1/0/2] user-bind ip-address 192.168.0.3 mac-address 0001-0203-0405
[SwitchA-Ethernet1/0/2] quit
# Configure port Ethernet 1/0/1 of Switch A to allow only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 to pass.
[SwitchA] interface ethernet 1/0/1
[SwitchA-Ethernet1/0/1] user-bind ip-address 192.168.0.1 mac-address 0001-0203-0406
2)         Configure Switch B
# Configure port Ethernet 1/0/1 of Switch B to allow only IP packets with the source MAC address of 00-01-02-03-04-06 and the source IP address of 192.168.0.1 to pass.
[SwitchB] interface ethernet 1/0/1
[SwitchB-Ethernet1/0/1] user-bind ip-address 192.168.0.1 mac-address 0001-0203-0406
[SwitchB-Ethernet1/0/1] quit
# Configure port Ethernet 1/0/2 of Switch B to allow only IP packets with the source MAC address of 00-01-02-03-04-07 and the source IP address of 192.168.0.2 to pass.
[SwitchB] interface ethernet 1/0/2
[SwitchB-Ethernet1/0/2] user-bind ip-address 192.168.0.2 mac-address 0001-0203-0407
3)         Verify the configuration
# On Switch A, static binding entries are configured successfully.
<SwitchA> display user-bind
The Following User address bind have been configured:
  Mac                   IP                  Port                    Status
  0001-0203-0405        192.168.0.3         Ethernet1/0/2             Static
  0001-0203-0406        192.168.0.1         Ethernet1/0/1             Static
-------------2 bind entries queried, 2 listed------------
# On Switch B, static binding entries are configured successfully.
<SwitchB> display user-bind
  Mac                   IP                  Port                    Status
  0001-0203-0407        192.168.0.2         Ethernet1/0/2             Static
1.5.2  Port Filtering Configuration Example
Switch A connects to Client A and the DHCP Server through Ethernet 1/0/1 and Ethernet 1/0/2 respectively. DHCP Snooping is enabled on Switch A.
l           Client A with the MAC address of 00-01-02-03-04-06 obtains an IP address through the DHCP Server.
l           On Switch A, create the DHCP Snooping entry of Client A.
l           Enable IP filtering on port Ethernet 1/0/1 of Switch A to prevent attacks from clients using fake source IP addresses to the DHCP server.
&  Note:
For detailed configuration of DHCP Server, refer to DHCP Configuration in this manual.
II. Network diagram
Figure 1-2 Network diagram for configuring port filtering
# Configure port filtering on port Ethernet 1/0/1.
[SwitchA] interface ethernet1/0/1
[SwitchA-Ethernet1/0/1] ip check source ip-address mac-address
[SwitchA-Ethernet1/0/1] quit
# Enable DHCP snooping on Switch A.
[SwitchA] dhcp-snooping
# Configure port Ethernet 1/0/2 connected to the DHCP server as a trusted port.
[SwitchA] interface ethernet1/0/2
[SwitchA-Ethernet1/0/2] dhcp-snooping trust
2)         Verify the configuration
# Port filtering is configured successfully on port Ethernet 1/0/1.
[SwitchA-Ethernet1/0/1] display this
interface Ethernet1/0/1
return
# Display the dynamic binding entries that port Ethernet 1/0/1 has obtained from DHCP Snooping.
<SwitchA> display ip check source
 Mac                   IP                    Port              Status
0001-0203-0406         192.168.0.1           Ethernet 1/0/1    Dynamic
 -------------1 bind entries queried, 1 listed------------
# Display the dynamic entries of DHCP Snooping and check it is identical with the dynamic entries that port Ethernet 1/0/1 has obtained.
<SwitchA> display dhcp-snooping
DHCP Snooping is enabled.
The client binding table for all untrusted ports.
Type : D--Dynamic , S--Static
Type IP Address      MAC Address    Lease        VLAN Interface
D    192.168.0.1     0001-0203-0406 86335        1    Ethernet1/0/1
As you see, port Ethernet 1/0/1 has obtained the dynamic entries generated by DHCP Snooping after it is configured with port filtering.
1.6  Troubleshooting
1.6.1  Failed to Configure Static Binding Entries and Port Filtering
I. Symptom
Configuring static binding entries and port filtering fails on a port.
II. Analysis
IP Source Guard is not supported on the port which has joined an aggregation group. Neither static binding entries nor port filtering can be configured on the port which has joined an aggregation group.
III. Solution
Remove the port from the aggregation group.
