H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
00-1Cover
00-1Cover 78.82 KB
H3C S3610&S5510 Series Ethernet Switches
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 20081229-C-1.01
Product Version: Release 5303
Copyright ? 2006-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3610&S5510 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3610&S5510 Series Ethernet Switches  Command Manual-Release 5303
It is used for assisting the users in using various commands.
H3C S3610 Series Ethernet Switches  Installation Manual
It provides information for the system installation.
H3C S5510 Series Ethernet Switches  Installation Manual
Organization
H3C S3610&S5510 Series Ethernet Switches Operation Manual Release 5303 is organized as follows:
Part
0 Product Overview
Introduces the system features, service features, and network application of the switches.
1 Login
Introduces the ways to log into an Ethernet switch.
2 VLAN
Introduces VLAN, Voice VLAN, GVRP fundamental and the related configuration.
3 IP Addressing and Performance
Introduces IP address and IP performance fundamental and the related configuration.
4 QinQ-BPDU Tunneling
Introduces QinQ, BPDU Tunnel and the related configuration.
5 Port Correlation Configuration
Introduces basic port configuration and port isolation configuration.
6 Link Aggregation
Introduces link aggregation configuration, including manual link aggregation and static LACP link aggregation.
7 MAC Address Table Management
Introduces MAC address forwarding table and the related configuration.
8 IP Source Guard
Introduces IP Source Guard configuration.
9 MSTP
Introduces STP, BRDU tunnel and the related configurations.
10 IPv6
Introduces IPv6 basic configuration and application, IPv6 tunneling, and so on.
11 Routing Overview
Introduces the basic routing information and the classification of routing protocols
12 IPv4 Routing
Introduces IPv4 routing related configurations, such as static routing, RIP, OSPF, IS-IS, BGP, and route policy.
13 BFD-GR
Introduces BFD configuration and GR configuration
14 IPv6 Routing
Introduces IPv6 routing related configurations, such as static routing, RIPng, OSPFv3, IPv6 IS-IS, and IPv6 BGP.
15 Multicast Protocol
Introduces the multicast protocol-related configurations.
16 802.1x-HABP-MAC Authentication
Introduces 802.1x, HABP and MAC related configurations.
17 AAA-RADIUS-HWTACACS
Introduces AAA, RADIUS, HWTACACS, and the related configurations.
18 ARP
Introduces ARP and the related configuration.
19 DHCP
Introduces DHCP and the related configuration.
20 ACL
Introduces IPv4&IPv6-based ACL and the related configuration.
21 QoS
Introduces QoS and the related configuration.
22 Port Mirroring
Introduces port mirroring and the related configuration.
23 Cluster Management
Introduces cluster and the related configuration.
24 UDP Helper
Introduces UDP Helper and the related configuration.
25 SNMP-RMON
Introduces the configuration to manage network devices through SNMP and RMON.
26 NTP
Introduces NTP and the related configuration.
27 DNS
Introduces DNS and the related configuration.
28 File System Management
Introduces basic configuration for file system management.
29 Information Center
Introduces the configuration to analyze and diagnose networks using the information center.
30 System Maintaining and Debugging
Introduces daily system maintenance and debugging.
31 NQA
Introduces NQA and the related configuration.
32 VRRP
Introduces VRRP and the related configuration.
33 SSH
Introduces SSH and the related configurations.
34 MCE
Introduces MCE and the related configuration.
35 OAM
Introduces ethernet OAM configuration.
36 DLDP
Introduces DLDP and the related configuration.
37 RRPP
Introduces RRPP and the related configuration.
38 SSL-HTTPS
Introduces SSL and HTTPS configuration.
39 PKI
Introduces PKI and related configuration.
40 Appendix
Lists the acronyms used in this manual.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
