H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
29-Information Center Configuration
29-Information Center Configuration 126.49 KB
Chapter 1  Information Center Configuration
When configuring information center, go to these sections for information you are interested in:
l           Information Center Overview
l           Configuring Information Center
l           Displaying and Maintaining Information Center
l           Information Center Configuration Examples
1.1  Information Center Overview
1.1.1  Introduction to Information Center
Acting as the system information hub, information center classifies and manages system information. Together with the debugging functionality, information center offers a powerful support for network administrators and developers in monitoring network performance and diagnosing network problems.
&  Note:
By default, the information center is enabled. An enabled information center affects the system performance in some degree due to information classification and output. Such impact becomes more obvious in the event that there is enormous information waiting for processing.
The information center of the system has the following features:
I. Classification of system information
The system is available with three types of information:
l           Log information
l           Trap information
l           Debugging information
II. Eight levels of system information
The information is classified into eight levels by severity and can be filtered by level. More emergent information has a smaller severity level.
Table 1-1 Severity description
Severity
Severity value
emergencies
0
The system is unavailable.
alerts
1
Information that demands prompt reaction
critical
2
Critical information
errors
3
Error information
warnings
4
Warnings
notifications
5
Normal information that needs to be noticed
informational
6
Informational information to be recorded
debugging
7
Information generated during debugging
Information filtering by severity works this way: information with the severity value greater than the configured threshold is not output during the filtering.
l           If the threshold is set to 0, only information with the severity being emergencies will be output;
l           If the threshold is set to 7, information of all severities will be output.
III. Ten channels and six output directions of system information
The system supports six information output directions, including the console, monitor, logbuffer, loghost, trapbuffer, and SNMP.
The system supports ten channels. The channels 0 through 5 have their default channel names and are associated with six output directions by default. Both the channel names and the associations between the channels and output directions can be changed through commands.
Table 1-2 Information channels and output directions
Information channel number
Default channel name
Default output direction
0
console
Console (Receives log, trap and debugging information)
1
monitor
Monitor terminal (Receives log, trap and debugging information, facilitating remote maintenance)
2
loghost
Log host (Receives log, trap and debugging information and information will be stored in files for future retrieval.)
3
trapbuffer
Trap buffer (Receives trap information, a buffer inside the router for recording information.)
4
logbuffer
Log buffer (Receives log information, a buffer inside the router for recording information.)
5
snmpagent
SNMP NMS (Receives trap information)
6
channel6
Not specified (Receives log, trap, and debugging information)
7
channel7
8
channel8
Not specified (Receives log, trap, and debug information)
9
channel9
&  Note:
Configurations for the six output directions function independently and take effect only after the information center is enabled.
IV. Outputting system information by source module
The system is composed of a variety of protocol modules, board drivers, and configuration modules. The system information can be classified, filtered, and output by source module. Some source module names and descriptions are shown in Table 1-3.
Table 1-3 Source module list
Module name
8021X
802.1X module
ACL
Access Control List module
ARP
Address Resolution Protocol module
BGP
Border Gateway Protocol module
CFM
Configuration File Management module
CLST
Cluster Configuration module
CMD
Command line module
default
Default setting of all modules
DEV
Device management module
DHCP
Dynamic Host Configuration Protocol module
DNS
Domain Name System module
ETH
Ethernet module
FTPS
FTP Server module
GARP
Generic Attribute Registration Protocol module
HABP
Huawei Authentication Bypass Protocol module
HWCM
Huawei Configuration Management MIB module
IFNET
Interface management module
IP
Internet Protocol module
ISIS
Intermediate System-to-Intermediate System intra-domain routing information exchange protocol module
LAGG
Link Aggregation module
LINE
Line module
MSDP
Multicast Source Discovery Protocol module
MSTP
Multiple Spanning Tree Protocol module
NAT
Network Address Translation module
NTP
Network Time Protocol module
PKI
Public Key Infrastructure module
OSPF
Open Shortest Path First module
QoS
Quality of Service module
RDS
Radius module
RM
Routing Management module
RMON
Remote monitor module
SHELL
User interface module
SNMP
Simple Network Management Protocol module
SOCKET
Socket module
SSH
Secure Shell module
SYSMIB
System MIB module
TAC
Terminal Access Controller module
TELNET
Telnet module
UDPH
UDP Helper module
VFS
Virtual File System module
VLAN
Virtual Local Area Network module
VOS
Virtual Operating System module
VRRP
Virtual Router Redundancy Protocol module
VTY
Virtual Type Terminal module
To sum up, the major task of the information center is to output the three types of information of the modules onto the ten channels in terms of the eight severity levels and according to the user’s settings, and then redirect the system information from ten channels to the six output directions.
1.1.2  System Information Format
System information has the following format:
<priority>timestamp sysname module/level/digest:content
&  Note:
l      The closing set of angel brackets < >, the space, the forward slash /, and the colon are all required in the above format.
l      Before the <priority> may have %, “#, or * followed with a space, indicating log, alarm, or debug information respectively.
Below is an example of the format of log information to be output to a log host:
% <188>Sep 28 15:33:46:235 2005 MyDevice SHELL/5/LOGIN: Console login from con0
What follows is a detailed explanation of the fields involved:
I. Priority
The priority is calculated using the following formula: facility*8+severity.
l           facility (device name) is local7 by default, and with the corresponding value being 23. (local6 corresponds to 22, and so on.)
l           severity (information level) ranges from 0 to 7. Table 1-1 details the value and meaning associated with each severity.
Note that there is no space between the priority and timestamp fields and that the priority takes effect only when the information has been sent to the log host.
II. Timestamp
Timestamp records the time when system information is generated to allow users to check and identify system events.
Note that there is a space between the timestamp and sysname (host name) fields.
III. Sysname
Sysname is the system name of the current host. You can use the sysname command to modify the system name. (Refer to System Maintaining and Debugging for details)
Note that there is a space between the sysname and module fields.
IV. Module
The module field represents the name of the module that generates system information. You can enter the info-center source ? command in system view to view the module list.
Refer to Table 1-3 for module name and description.
Between “module” and “level” is a “/”.
V. Level (Severity)
System information can be divided into eight levels based on its severity, from 0 to 7. Refer to Table 1-1 for definition and description of these severity levels. Note that there is a forward slash between the levels (severity) and digest fields.
VI. Digest
The digest field is a string of up to 32 characters, outlining the system information.
Note that there is a colon between the digest and content fields.
VII. Content
This field provides the content of the system information.
1.2  Configuring Information Center
1.2.1  Information Center Configuration Task List
Complete the following tasks to configure information center:
Remarks
Setting to Output System Information to the Console
Optional
Setting to Output System Information to a Monitor Terminal
Optional
Setting to Output System Information to a Log Host
Optional
Setting to Output System Information to the Trap Buffer
Optional
Setting to Output System Information to the Log Buffer
Optional
Setting to Output System Information to the SNMP NMS
Optional
Configuring Synchronous Information Output
Optional
1.2.2  Setting to Output System Information to the Console
I. Setting to output system information to the console
To do…
Use the command…
Remarks
Enter system view
Enable information center
info-center enable
Optional
Enabled by default
Name the channel with a specified channel number
info-center channel channel-number name channel-name
Optional
Refer to Table 1-2 for default channel names.
Configure the channel through which system information can be output to the console
info-center console channel { channel-number | channel-name }
Optional
System information is output to the console by default, with channel 0 as the default channel.
Configure the output rules of system information
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state } * | log { level severity | state state } * | trap { level severity | state state } * ] *
Optional
Refer to Table 1-4 for the default output rules of system information.
Configure the format of the time stamp
info-center timestamp { debugging | log | trap } { boot | date | none }
Optional
The time stamp for log, trap and debug information is date by default.
Table 1-4 Default output rules for different output directions
Output direction
Modules allowed
LOG
TRAP
DEBUG
Enabled/disabled
Severity
Enabled/disabled
Severity
Enabled/disabled
Severity
Console
default (all modules)
Enabled
warnings
Enabled
debugging
Enabled
debugging
Monitoring terminal
Enabled
warnings
Enabled
debugging
Enabled
debugging
Log host
Enabled
informational
Enabled
debugging
Disabled
debugging
Trap buffer
Disabled
informational
Enabled
warnings
Disabled
debugging
Log buffer
Enabled
warnings
Disabled
debugging
Disabled
debugging
SNMP NMS
Disabled
debugging
Enabled
warnings
Disabled
debugging
II. Enabling the display of system information on the console
After setting to output system information to the console, you need to enable the associated display function to display the output information on the console.
Follow these steps in user view to enable the display of system information on the console:
To do…
Use the command…
Remarks
Enable the monitoring of system information on the console
terminal monitor
Optional
Enabled on the console and disabled on the monitoring terminal by default.
Enable the display of debug information on the console
terminal debugging
Required
Disabled by default
Enable the display of log information on the console
terminal logging
Optional
Enabled by default
Enable the display of trap information on the console
terminal trapping
Optional
Enabled by default
1.2.3  Setting to Output System Information to a Monitor Terminal
System information can also be output to a monitor terminal, which is a user terminal that has login connections through the AUX, or VTY user interface.
I. Setting to output system information to a monitor terminal
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure the channel through which system information can be output to a monitor terminal
info-center monitor channel { channel-number | channel-name }
Optional
System information is output to the monitor terminal by default with channel 1 as the default channel.
Configure the output rules of the system information
Optional
Refer to Table 1-4 for the default output rules of the system information.
Optional
By default, the time stamp for log, trap and debug information is date.
II. Enabling the display of system information on a monitor terminal
After setting to output system information to a monitor terminal, you need to enable the associated display function in order to display the output information on the monitor terminal.
Follow these steps to enable the display of system information on a monitor terminal:
To do…
Use the command…
Remarks
Enable the monitoring of system information on a monitor terminal
terminal monitor
Required
Enabled on the console disabled on the monitoring terminal by default.
Enable the display of debug information on a monitor terminal
terminal debugging
Required
Disabled by default
Enable the display of log information on a monitor terminal
terminal logging
Optional
Enabled by default
Enable the display of trap information on a monitor terminal
terminal trapping
Optional
Enabled by default
1.2.4  Setting to Output System Information to a Log Host
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Specify a log host and configure the parameters when system information is output to the log host
info-center loghost host-ip [ channel { channel-number | channel-name } ] [ facility local-number ] *
Required
Disabled by default with channel 2 as the default channel when enabled.
Configure the source interface through which log information can be output to a log host
Optional
No source interface is configured by default, and the system selects an interface as the source interface.
Optional
Refer to Table 1-4 for the output rules of the system information.
Configure the format of the time stamp for log information
info-center timestamp loghost { date | no-year-date | none }
Optional
date by default.
1.2.5  Setting to Output System Information to the Trap Buffer
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure the channel through which system information can be output to the trap buffer and specify the buffer size
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] *
Optional
System information is output to the trap buffer by default with channel 3 (known as trapbuffer) as the default channel and a default buffer size of 256.
Optional
Optional
1.2.6  Setting to Output System Information to the Log Buffer
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default.
Optional
Configure the channel through which system information can be output to the log buffer and specify the buffer size
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ] *
Optional
System information is output to the log buffer by default with channel 4 (known as logbuffer) as the default channel and a default buffer size of 512.
Optional
Configure the format of the timestamp
Optional
1.2.7  Setting to Output System Information to the SNMP NMS
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure the channel through which system information can be output to the SNMP NMS
info-center snmp channel { channel-number | channel-name }
Optional
System information is output to the SNMP NMS by default with channel 5 (known as snmpagent) as the default channel.
Optional
Optional
&  Note:
To ensure that system information can be output to the SNMP NMS, you need to make the necessary configurations on the SNMP agent and the NMS. For detailed information on SNMP, refer to the SNMP-RMON Configuration part of the manual.
1.2.8  Configuring Synchronous Information Output
Synchronous information output refers to the feature that if the user’s input is interrupted by system output such as log, trap, or debugging information, then after the completion of system output the system will display a command line prompt (in command editing mode a prompt, or a [Y/N] string in interaction mode) and your input so far.
This command is used in the case that your input is interrupted by a large amount of system output. With this feature enabled, you can continue your operations from where you were stopped.
Follow these steps to enable synchronous information output:
To do…
Use the command…
Remarks
Enter system view
Enable synchronous information output
info-center synchronous
Required
Disabled by default
&  Note:
l      If you do not input any information following the current command line prompt, the system does not display any command line prompt after system information output.
l      In the interaction mode, you are prompted for some information input. If the input is interrupted by system output, no system prompt will be made, rather only your input will be displayed in a new line.
1.3  Displaying and Maintaining Information Center
To do…
Use the command…
Remarks
Display channel information for a specified channel
display channel [ channel-number | channel-name ]
Available in any view
Display the configurations for all information channels except channel 6 to 9
display info-center
Display the state of the log buffer and the log information recorded
display logbuffer [ level severity | size buffersize ] * [ | { begin | exclude | include } text ]
Display a summary of the log buffer
display logbuffer summary [ level severity ]
Display the state of the trap buffer and the trap information recorded
display trapbuffer [ size buffersize ]
Reset the log buffer
reset logbuffer
Available in user view
Reset the trap buffer
reset trapbuffer
&  Note:
Support for the display logfile buffer and display logfile summary commands varies with devices.
1.4  Information Center Configuration Examples
1.4.1  Outputting Log Information to a Unix Log Host
I. Network requirements
l           Send log information to a Unix log host with an IP address of 1.2.0.1/16;
l           Log information with severity higher than informational will be output to the log host;
l           The source modules are ARP and IP.
II. Network diagram
Figure 1-1 Network diagram for outputting log information to a Unix log host
III. Configuration procedure
1)         Configuring the device
# Enable information center.
[Sysname] info-center enable
# Specify the channel to output log information to the log host (loghost by default, optional).
[Sysname] info-center loghost 1.2.0.1 channel loghost
# Disable the output of log, trap, and debug information of all modules to the log host.
[Sysname] info-center source default channel loghost debug state off log state off trap state off
  Caution:
l      As the default system configurations for different channels vary, ensure that the output of log, trap, and debug information for the specified channel (loghost in this example) of all modules is disabled before the system information can be output to meet the current network requirements.
l      Use the display channel command to display the state of a channel.
# Set the host with an IP address of 1.2.0.1/16 to be the log host, set the severity to informational, and the source modules to ARP and IP.
[Sysname] info-center loghost 1.2.0.1 facility local4
[Sysname] info-center source arp channel loghost log level informational
[Sysname] info-center source ip channel loghost log level informational
2)         Configuring the log host
The following configurations were performed on SunOS 4.0 which has similar configurations to the Unix operating systems implemented by other vendors.
Step 1: issue the following commands as a root user.
# mkdir /var/log/MyDevice
# touch /var/log/MyDevice/information
Step 2: Edit the file /etc/syslog.conf as a root user and add the following selector/action pair.
# MyDevice configuration messages
local4.info    /var/log/MyDevice/information
&  Note:
Be aware of the following issues while editing the /etc/syslog.conf file:
l      Comments must be on a separate line and must begin with the # sign.
l      The selector/action pair must be separated with a tab key, rather than a space.
l      No redundant spaces are allowed in the file name.
l      The device name and the accepted severity of log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost or info-center source command; otherwise the log information may not be output properly to the log host.
Step three: after the log file information has been created and the configuration file /etc/syslog.conf has been modified, ensure that the configuration file /etc/syslog.conf is reread:
# ps -ae | grep syslogd
147
# kill -HUP 147
After the above configurations, the system will be able to keep log information in the related file.
1.4.2  Outputting Log Information to a Linux Log Host
l           Send log information to a Linux log host with an IP address of 1.2.0.1/16;
l           All modules can output log information.
II. Network diagram
Figure 1-2 Network diagram for outputting log information to a Linux log host
# Specify the channel to output log information to the log host (optional, loghost by default).
  Caution:
# Set the host with an IP address of 1.2.0.1/16 to be the log host, set the severity to informational, and the source modules to be all modules.
[Sysname] info-center loghost 1.2.0.1 facility local7
[Sysname] info-center source default channel loghost log level informational
local7.info    /var/log/MyDevice/information
&  Note:
l      The device name and the accepted severity of the log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost or info-center source command; otherwise the log information may not be output properly to the log host.
Step three: after the log file information has been created and the /etc/syslog.conf file has been modified, issue the following commands to display the process ID of syslogd, terminate a syslogd process, and to restart syslogd using the -r option.
147
# kill -9 147
# syslogd -r &
&  Note:
Ensure that the syslogd process is started with the -r option on a Linux log host.
1.4.3  Outputting Log Information to the Console
l           Log information with a severity higher than informational will be output to the console;
II. Network diagram
Figure 1-3 Network diagram for sending log information to the console
# Specify the channel to output log information to the console (optional, Console by default).
[Sysname] info-center console channel console
[Sysname] info-center source default channel console debug state off log state off trap state off
  Caution:
l      As the default system configurations for different channels vary, ensure that the output of log, trap, and debug information for the specified channel (console in this example) of all modules is disabled before the system information can be output to meet the current network requirements.
# Enable system information output for the ARP and IP modules, with information severity ranging from emergencies to informational.
[Sysname] info-center source arp channel console log level informational
[Sysname] info-center source ip channel console log level informational
[Sysname] quit
# Enable the display of log information on a monitor terminal.
<Sysname> terminal monitor
% Current terminal monitor is on
<Sysname> terminal logging
% Current terminal logging is on
After the above configuration takes effect, if the specified module generates log information, the information center automatically sends the log information to the Console and displays it on the console.
