H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5303(V1.01)
14-IPv6 Routing Configuration
14-IPv6 Routing Configuration 674.25 KB
Table of Contents
Chapter 1 IPv6 Static Routing Configuration. 1-1
1.1 Introduction to IPv6 Static Routing. 1-1
1.1.1 Features of IPv6 Static Routes. 1-1
1.1.2 Default IPv6 Route. 1-1
1.2 Configuring an IPv6 Static Route. 1-2
1.2.1 Configuration prerequisites. 1-2
1.2.2 Configuring an IPv6 Static Route. 1-2
1.3 Displaying and Maintaining IPv6 Static Routes. 1-2
1.4 IPv6 Static Routing Configuration Example. 1-3
Chapter 2 IPv6 RIPng Configuration. 2-1
2.1 Introduction to RIPng. 2-1
2.1.1 RIPng Working Mechanism.. 2-1
2.1.2 RIPng Packet Format 2-2
2.1.3 RIPng Packet Processing Procedure. 2-3
2.1.4 Protocols and Standards. 2-4
2.2 Configuring RIPng Basic Functions. 2-4
2.2.1 Configuration Prerequisites. 2-4
2.2.2 Configuration Procedure. 2-4
2.3 Configuring RIPng Route Control 2-5
2.3.1 Configuring an Additional Routing Metric. 2-5
2.3.2 Configuring RIPng Route Summarization. 2-5
2.3.3 Advertising a Default Route. 2-6
2.3.4 Configuring a RIPng Route Filtering Policy. 2-6
2.3.5 Configuring a Priority for RIPng. 2-6
2.3.6 Configuring RIPng Route Redistribution. 2-7
2.4 Tuning and Optimizing the RIPng Network. 2-7
2.4.1 Configuring RIPng Timers. 2-8
2.4.2 Configuring Split Horizon and Poison Reverse. 2-8
2.4.3 Configuring Zero Field Check on RIPng Packets. 2-9
2.4.4 Configuring the Maximum Number of Equal Cost Routes for Load Balancing. 2-10
2.5 Displaying and Maintaining RIPng. 2-10
2.6 RIPng Configuration Example. 2-10
Chapter 3 IPv6 OSPFv3 Configuration. 3-1
3.1 Introduction to OSPFv3. 3-1
3.1.1 OSPFv3 Overview. 3-1
3.1.2 OSPFv3 Packets. 3-1
3.1.3 OSPFv3 LSA Types. 3-2
3.1.4 Timers of OSPFv3. 3-3
3.1.5 OSPFv3 Features Supported. 3-3
3.1.6 Related RFCs. 3-3
3.2 IPv6 OSPFv3 Configuration Task List 3-4
3.3 Configuring OSPFv3 Basic Functions. 3-4
3.3.1 Prerequisites. 3-4
3.3.2 Configuring OSPFv3 Basic Functions. 3-5
3.4 Configuring OSPFv3 Area Parameters. 3-5
3.4.1 Prerequisites. 3-5
3.4.2 Configuring an OSPFv3 Stub Area. 3-6
3.4.3 Configuring OSPFv3 Virtual Links. 3-6
3.5 Configuring OSPFv3 Routing Information Management 3-7
3.5.1 Prerequisites. 3-7
3.5.2 Configuring OSPFv3 Route Summarization. 3-7
3.5.3 Configuring OSPFv3 Inbound Route Filtering. 3-8
3.5.4 Configuring Link Costs for OSPFv3 Interfaces. 3-8
3.5.5 Configuring the Maximum Number of OSPFv3 Load-balanced Routes. 3-8
3.5.6 Configuring a Priority for OSPFv3. 3-9
3.5.7 Configuring OSPFv3 Route Redistribution. 3-9
3.6 Tuning and Optimizing an OSPFv3 Network. 3-10
3.6.1 Prerequisites. 3-10
3.6.2 Configuring OSPFv3 Timers. 3-10
3.6.3 Configuring the DR Priority for an Interface. 3-11
3.6.4 Ignoring MTU Check for DD Packets. 3-12
3.6.5 Disable Interfaces from Sending OSPFv3 Packets. 3-12
3.6.6 Enable the Logging on Neighbor State Changes. 3-13
3.7 Displaying and Maintaining OSPFv3. 3-14
3.8 OSPFv3 Configuration Examples. 3-15
3.8.1 Configuring OSPFv3 Areas. 3-15
3.8.2 Configuring OSPFv3 DR Election. 3-19
3.9 Troubleshooting OSPFv3 Configuration. 3-22
3.9.1 No OSPFv3 Neighbor Relationship Established. 3-22
3.9.2 Incorrect Routing Information. 3-23
Chapter 4 IPv6 IS-IS Configuration. 4-1
4.1 Introduction to IPv6 IS-IS. 4-1
4.2 Configuring IPv6 IS-IS Basic Functions. 4-2
4.2.1 Configuration Prerequisites. 4-2
4.2.2 Configuration Procedure. 4-2
4.3 Configuring IPv6 IS-IS Routing Information Control 4-3
4.3.1 Configuration Prerequisites. 4-3
4.3.2 Configuration Procedure. 4-3
4.4 Displaying and Maintaining IPv6 IS-IS. 4-4
4.5 IPv6 IS-IS Configuration Example. 4-5
Chapter 5 IPv6 BGP Configuration. 5-1
5.1 IPv6 BGP Overview. 5-1
5.2 Configuration Task List 5-2
5.3 Configuring IPv6 BGP Basic Functions. 5-3
5.3.1 Prerequisites. 5-3
5.3.2 Configuring an IPv6 Peer 5-3
5.3.3 Advertising a Local IPv6 Route. 5-4
5.3.4 Configuring a Preferred Value for Routes from a Peer/Peer Group. 5-4
5.3.5 Specifying the Source Interface for Establishing TCP Connections. 5-5
5.3.6 Allowing the establishment of a Non-Direct EBGP connection. 5-6
5.3.7 Configuring a Description for a Peer/Peer Group. 5-6
5.3.8 Disabling Session Establishment to a Peer/Peer Group. 5-7
5.3.9 Logging Peer State Changes. 5-7
5.4 Controlling Route Distribution and Reception. 5-8
5.4.1 Prerequisites. 5-8
5.4.2 Configuring IPv6 BGP Route Redistribution. 5-8
5.4.3 Advertising a Default Route to a Peer/Peer Group. 5-9
5.4.4 Configuring Route Distribution Policy. 5-9
5.4.5 Configuring Route Reception Policy. 5-10
5.4.6 Configuring IPv6 BGP and IGP Route Synchronization. 5-11
5.4.7 Configuring Route Dampening. 5-12
5.5 Configuring IPv6 BGP Route Attributes. 5-12
5.5.1 Prerequisites. 5-12
5.5.2 Configuring IPv6 BGP Preference and Default LOCAL_PREF and NEXT_HOP Attributes. 5-13
5.5.3 Configuring the MED Attribute. 5-14
5.5.4 Configuring the AS_PATH Attribute. 5-14
5.6 Tuning and Optimizing IPv6 BGP Networks. 5-15
5.6.1 Prerequisites. 5-15
5.6.2 Configuring IPv6 BGP Timers. 5-16
5.6.3 Configuring IPv6 BGP Soft Reset 5-16
5.6.4 Configuring the Maximum Number of Load-Balanced Routes. 5-17
5.7 Configuring a Large Scale IPv6 BGP Network. 5-18
5.7.1 Prerequisites. 5-18
5.7.2 Configuring IPv6 BGP Peer Group. 5-18
5.7.3 Configuring IPv6 BGP Community. 5-20
5.7.4 Configuring an IPv6 BGP Route Reflector 5-21
5.8 Displaying and Maintaining IPv6 BGP Configuration. 5-22
5.8.1 Displaying BGP. 5-22
5.8.2 Resetting IPv6 BGP Connections. 5-23
5.8.3 Clearing IPv6 BGP Information. 5-23
5.9 IPv6 BGP Configuration Examples. 5-24
5.9.1 IPv6 BGP Basic Configuration. 5-24
5.9.2 IPv6 BGP Route Reflector Configuration. 5-26
5.10 Troubleshooting IPv6 BGP Configuration. 5-28
5.10.1 No IPv6 BGP Peer Relationship Established. 5-28
Chapter 6 Routing Policy Configuration. 6-1
6.1 Introduction to Routing Policy. 6-1
6.1.1 Routing Policy. 6-1
6.1.2 Filters. 6-1
6.1.3 Routing Policy Application. 6-3
6.2 Defining Filtering Lists. 6-3
6.2.1 Prerequisites. 6-3
6.2.2 Defining an IPv6 Prefix List 6-3
6.2.3 Defining an AS Path List 6-4
6.2.4 Defining a Community List 6-4
6.2.5 Defining an Extended Community List 6-5
6.3 Configuring a Routing Policy. 6-5
6.3.1 Prerequisites. 6-5
6.3.2 Creating a Routing Policy. 6-6
6.3.3 Defining if-match Clauses for the Routing Policy. 6-6
6.3.4 Defining apply Clauses for the Routing Policy. 6-8
6.4 Displaying and Maintaining the Routing Policy. 6-9
6.5 Routing Policy Configuration Example. 6-9
6.5.1 Applying Routing Policy When Redistributing IPv6 Routes. 6-9
6.6 Troubleshooting Routing Policy Configuration. 6-11
6.6.1 IPv4 Routing Information Filtering Failure. 6-11
6.6.2 IPv6 Routing Information Filtering Failure. 6-12
&  Note:
l      The term “router” in this document refers to a Layer 3 switch running routing protocols.
l      Verify that the system already operates in IPv4/IPv6 dual-stack mode before configuring IPv6 routing.
l      All the IPv6 routing related configuration mentioned in this manual assumes that the system already operates in IPv4/IPv6 dual-stack mode. For dual stack mode configuration, see the part covering dual stack in the IPv6 Configuration module.
l      For a manually established tunnel, routing protocols can be employed on the tunnel interfaces successfully if the tunnel is configured to support expedite termination subnet addresses. While for tunnels of other types, routing protocols cannot be employed on the tunnel interfaces successfully.
Static routes are special routes that are manually configured by network administrators. They work well in simple networks. Configuring and using them properly can improve the performance of networks and guarantee enough bandwidth for important applications.
However, static routes also have shortcomings: any topology changes could result in unavailable routes, requiring the network administrator to manually configure and modify the static routes.
Similar to IPv4 static routes, IPv6 static routes work well in simple IPv6 network environments.
Their major difference lies in the destination and next hop addresses. IPv6 static routes use IPv6 addresses whereas IPv4 static routes use IPv4 addresses. Currently, IPv6 static routes do not support VPN instance.
The IPv6 static route that has the destination address configured as ::/0 (indicating a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route will be used to forward the packet.
In small IPv6 networks, IPv6 static routes can be used to forward packets. In comparison to dynamic routes, it helps to save network bandwidth.
l           Enabling IPv6 packet forwarding
l           Ensuring that the neighboring nodes are IPv6 reachable
Follow these steps to configure an IPv6 static route:
To do...
Use the commands…
Remarks
Enter system view
System-view
Configure an IPv6 static route
ipv6 route-static ipv6-address prefix-length [ interface-type interface-number ] nexthop-address [ preference preference-value ]
Required
The default preference of IPv6 static routes is 60.
To do...
Use the command...
Remarks
Display IPv6 static route information
display ipv6 routing-table protocol static [ inactive | verbose ]
Available in any view
Remove all IPv6 static routes
delete ipv6 static-routes all
Available in system view
&  Note:
Using the undo ipv6 route-static command can delete a single IPv6 static route, while using the delete ipv6 static-routes all command deletes all IPv6 static routes including the default route.
I. Network requirements
With IPv6 static routes configured, all hosts and switches can interact with each other.
II. Network diagram
Figure 1-1 Network diagram for static routes
III. Configuration procedure
1)         Configure the IPv6 addresses of all VLAN interfaces (Omitted)
2)         Configure IPv6 static routes.
# Configure the default IPv6 static route on Switch A.
[SwitchA] ipv6
[SwitchA] ipv6 route-static :: 0 4::2
# Configure two IPv6 static routes on Switch B.
[SwitchB] ipv6
[SwitchB] ipv6 route-static 1:: 64 4::1
[SwitchB] ipv6 route-static 3:: 64 5::1
# Configure the default IPv6 static route on Switch C.
[SwitchC] ipv6
[SwitchC] ipv6 route-static :: 0 5::2
3)         Configure the IPv6 addresses of hosts and gateways.
Configure the IPv6 addresses of all the hosts based upon the network diagram, configure the default gateway of Host A as 1::1, that of Host B as 2::1, and that of Host C as 3::1.
4)         Display configuration information
# Display the IPv6 routing table of Switch A.
[SwitchA] display ipv6 routing-table
Routing Table :
         Destinations : 7        Routes : 7
Destination: ::/0                                        Protocol  : Static
NextHop    : 4::2                                        Preference: 60
Interface  : Vlan200                                     Cost      : 0
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 1::/64                                      Protocol  : Direct
NextHop    : 1::1                                        Preference: 0
Interface  : Vlan100                                     Cost      : 0
Destination: 1::1/128                                    Protocol  : Direct
Destination: 4::/64                                      Protocol  : Direct
NextHop    : 4::1                                        Preference: 0
Destination: 4::1/128                                    Protocol  : Direct
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : NULL0                                       Cost      : 0
# Verify the connectivity with the ping command.
[SwitchA] ping ipv6 3::1
  PING 3::1 : 56  data bytes, press CTRL_C to break
    Reply from 3::1
    bytes=56 Sequence=1 hop limit=254  time = 63 ms
    Reply from 3::1
    bytes=56 Sequence=2 hop limit=254  time = 62 ms
    Reply from 3::1
    bytes=56 Sequence=3 hop limit=254  time = 62 ms
    Reply from 3::1
    bytes=56 Sequence=4 hop limit=254  time = 63 ms
    Reply from 3::1
    bytes=56 Sequence=5 hop limit=254  time = 63 ms
  --- 3::1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 62/62/63 ms
&  Note:
RIP next generation (RIPng) is an extension of RIP-2 for IPv4. Most RIP concepts are applicable in RIPng.
RIPng for IPv6 made the following changes to RIP:
l           UDP port number: RIPng uses UDP port 521 for sending and receiving routing information.
l           Multicast address: RIPng uses FF02:9 as the link-local multicast address.
l           Destination Prefix: 128-bit destination address prefix.
l           Next hop: 128-bit IPv6 address.
l           Source address: RIPng uses FE80::/10 as the link-local source address
RIPng is a routing protocol based on the distance vector (D-V) algorithm. RIPng uses UDP packets to exchange routing information through port 521.
RIPng uses a hop count to measure the distance to a destination. The hop count is referred to as metric or cost. The hop count from a router to a directly connected network is 0. The hop count between two directly connected routers is 1. When the hop count is greater than or equal to 16, the destination network or host is unreachable.
By default, the routing update is sent every 30 seconds. If the router receives no routing updates from a neighbor after 180 seconds, the routes learned from the neighbor are considered as unreachable. After another 240 seconds, if no routing update is received, the router will remove these routes from the routing table.
RIPng supports Split Horizon and Poison Reverse to prevent routing loops, and route redistribution.
Each RIPng router maintains a routing database, including route entries of all reachable destinations. A route entry contains the following information:
l           Destination address: IPv6 address of a host or a network.
l           Next hop address: IPv6 address of a neighbor along the path to the destination.
l           Egress interface: Outbound interface that forwards IPv6 packets.
l           Metric: Cost from the local router to the destination.
l           Route time: Time that elapsed since a route entry is last changed. Each time a route entry is modified, the routing time is set to 0.
l           Route tag: Identifies the route, used in routing policy to control routing information.
I. Basic format
A RIPng packet consists of a header and multiple route table entries (RTEs). The maximum number of RTEs in a packet depends on the MTU of the sending interface.
Figure 2-1 shows the packet format of RIPng.
Figure 2-1 RIPng basic packet format
l           Command: Type of message. 0x01 indicates Request, 0x02 indicates Response.
l           Version: Version of RIPng. It can only be 0x01 currently.
l           RTE: Route table entry, 20 bytes for each entry.
II. RTE format
There are two types of RTE in RIPng.
l           Next hop RTE: Defines the IPv6 address of a next hop
l           IPv6 prefix RTE: Describes the destination IPv6 address, route tag, prefix length and metric in the RIPng routing table.
Figure 2-2 shows the format of the next hop RTE:
Figure 2-2 Next hop RTE format
IPv6 next hop address is the IPv6 address of the next hop.
Figure 2-3 shows the format of the IPv6 prefix RTE.
Figure 2-3 IPv6 prefix RTE format
l           IPv6 prefix: Destination IPv6 address prefix.
l           Route tag: Route tag.
l           Prefix len: Length of the IPv6 address prefix.
l           Metric: Cost of a route.
I. Request packet
When a RIPng router first starts or needs to update some entries in its routing table, generally a multicast request packet is sent to ask for needed routes from neighbors.
The receiving RIPng router processes RTEs in the request. If there is only one RTE with the IPv6 prefix and prefix length both being 0, and with a metric value of 16, the RIPng router will respond with the entire routing table information in response messages. If there are multiple RTEs in the request message, the RIPng router will examine each RTE, update its metric, and send the requested routing information to the requesting router in the response packet.
II. Response packet
The response packet containing the local routing table information is generated as:
l           A response to a request
l           An update periodically
l           A trigged update caused by route change
After receiving a response, a router checks the validity of the response before adding the route to its routing table, such as whether the source IPv6 address is the link-local address, whether the port number is correct. The response packet failed the check will be discarded.
l           RFC2080: RIPng for IPv6
l           RFC2081: RIPng Protocol Applicability Statement
l           RFC2453: RIP Version 2
In this section, you are presented with the information to configure the basic RIPng features.
You need to enable RIPng first before configuring other tasks, but it is not necessary for RIPng related interface configurations, such as assigning an IPv6 address.
Before the configuration, accomplish the following tasks first:
l           Enable IPv6 packet forwarding.
l           Configure an IP address for each interface, and make sure all nodes are reachable.
Follow these steps to configure the basic RIPng functions:
To do...
Use the command...
Remarks
Enter system view
Create a RIPng process and enter RIPng view
ripng [ process-id ]
Required
Not created by default
Return to system view
Enter interface view
Enable RIPng on the interface
ripng process-id enable
Required
Disabled by default
&  Note:
If RIPng is not enabled on an interface, the interface will not send and receive any RIPng route.
l           Configure an IPv6 address on each interface, and make sure all nodes are reachable.
l           Configure RIPng basic functions
l           Define an IPv6 ACL before using it for route filtering. Refer to ACL configuration for related information.
l           Define an IPv6 address prefix list before using it for route filtering. Refer to section 6.2.2  "Defining an IPv6 Prefix List" for related information.
An additional routing metric can be added to the metric of an inbound or outbound RIP route, namely, the inbound and outbound additional metric.
The outbound additional metric is added to the metric of a sent route, the route’s metric in the routing table is not changed.
The inbound additional metric is added to the metric of a received route before the route is added into the routing table, so the route’s metric is changed.
Follow these steps to configure an inbound/outbound additional routing metric:
To do...
Use the command...
Remarks
Enter system view
Specify an inbound routing additional metric
ripng metricin value
Optional
0 by default
Specify an outbound routing additional metric
ripng metricout value
Optional
1 by default
Follow these steps to configure RIPng route summarization:
To do...
Use the command...
Remarks
Enter system view
Advertise a summary IPv6 prefix
ripng summary-address ipv6-address prefix-length
Required
Follow these steps to advertise a default route:
To do...
Use the command...
Remarks
Enter system view
Advertise a default route
ripng default-route { only | originate } [ cost cost ]
Required
Not advertised by default
&  Note:
With this feature enabled, a default route is advertised via the specified interface regardless of whether the default route is available in the local IPv6 routing table.
You can reference a configured IPv6 ACL or prefix list to filter received/advertised routing information as needed. For filtering outbound routes, you can also specify a routing protocol from which to filter routing information redistributed.
Follow these steps to configure a RIPng route filtering policy:
To do...
Use the command...
Remarks
Enter system view
Enter RIPng view
Configure a filter policy to filter incoming routes
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
Required
By default, RIPng does not filter incoming routing information.
Configure a filter policy to filter outgoing routes
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
Required
By default, RIPng does not filter outgoing routing information.
Any routing protocol has its own protocol priority used for optimal route selection. You can set a priority for RIPng manually. The smaller the value is, the higher the priority is.
Follow these steps to configure a RIPng priority:
To do...
Use the command...
Remarks
Enter system view
Enter RIPng view
Configure a RIPng priority
preference [ route-policy route-policy-name ] preference
Optional
By default, the RIPng priority is 100.
Follow these steps to configure RIPng route redistribution:
To do...
Use the command...
Remarks
Enter system view
Enter RIPng view
Configure a default routing metric for redistributed routes
default cost cost
Optional
By default, the default metric of redistributed routes is 0.
Redistribute routes from another routing protocol
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | route-policy route-policy-name ] *
Required
No route redistribution is configured by default.
This section describes how to tune and optimize the performance of the RIPng network as well as applications under special network environments. Before tuning and optimizing the RIPng network, complete the following tasks:
l           Configure a network layer address for each interface
l           Configure the basic RIPng functions
This section covers the following topics:
l           Configuring RIPng Timers
l           Configuring Split Horizon and Poison Reverse
l           Configuring Zero Field Check on RIPng Packets
l           Configuring the Maximum Number of Equal Cost Routes for Load Balancing
You can adjust RIPng timers to optimize the performance of the RIPng network.
Follow these steps to configure RIPng timers:
To do...
Use the command...
Remarks
Enter system view
Enter RIPng view
Configure RIPng timers
Optional.
The RIPng timers have the following defaults:
l      30 seconds for the update timer
l      180 seconds for the timeout timer
l      120 seconds for the suppress timer
l      120 seconds for the garbage-collect timer
&  Note:
When adjusting RIPng timers, you should consider the network performance and perform unified configurations on routers running RIPng to avoid unnecessary network traffic increase or route oscillation.
&  Note:
If both the split horizon and poison reverse are configured, only the poison reverse function takes effect.
I. Configure the split horizon
The split horizon function disables a route learned from an interface from being advertised via the interface to prevent routing loops between neighbors.
Follow these steps to configure the split horizon:
To do...
Use the command...
Remarks
Enter system view
Enable the split horizon function
ripng split-horizon
Optional
Enabled by default
&  Note:
Generally, you are recommended to enable the split horizon to prevent routing loops.
II. Configuring the poison reverse function
The poison reverse function enables a route learned from an interface to be advertised via the interface. However, the metric of the route is set to 16. That is to say, the route is unreachable.
Follow these steps to configure poison reverse:
To do...
Use the command...
Remarks
Enter system view
Enable the poison reverse function
ripng poison-reverse
Required
Disabled by default
Some fields in the RIPng packet must be zero. These fields are called zero fields. With zero field check on RIPng packets enabled, if such a field contains a non-zero value, the entire RIPng packet will be discarded. If you are sure that all packets are trusty, you can disable the zero field check to save the CPU processing time.
Follow these steps to configure RIPng zero field check:
To do...
Use the command...
Remarks
Enter system view
Enter RIPng view
Enable the zero field check
checkzero
Optional
Enabled by default
Follow these steps to configure the maximum number of equal cost RIPng routes for load balancing:
To do...
Use the command...
Remarks
Enter system view
Enter RIPng view
Configure the maximum number of equal cost RIPng routes for load balancing
maximum load-balancing number
Optional
4 by default
To do...
Use the command...
Remarks
Display configuration information of a RIPng process
display ripng [ process-id ]
Display routes in the RIPng database
display ripng process-id database
Display the routing information of a specified RIPng process
display ripng process-id route
Display RIPng interface information
display ripng process-id interface [ interface-type interface-number ]
As shown in Figure 2-4, all switches run RIPng. Configure Switch B to filter the route (3::/64) learnt from Switch C, which means the route will not be added to the routing table of Switch B, and Switch B will not forward it to Switch A.
II. Network diagram
Figure 2-4 Network diagram for RIPng configuration
1)         Configure the IPv6 address for each interface (omitted)
2)         Configure basic RIPng functions
# Configure Switch A.
[SwitchA] ipv6
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface100] ripng 1 enable
[SwitchA] interface vlan-interface 400
[SwitchA-Vlan-interface400] ripng 1 enable
[SwitchA-Vlan-interface400] quit
# Configure Switch B.
[SwitchB] ipv6
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface200] ripng 1 enable
[SwitchB-Vlan-interface100] ripng 1 enable
# Configure Switch C.
[SwitchC] ipv6
[SwitchC] ripng 1
[SwitchC-ripng-1] quit
[SwitchC-Vlan-interface200] ripng 1 enable
[SwitchC] interface Vlan-interface 500
[SwitchC-Vlan-interface500] ripng 1 enable
[SwitchC-Vlan-interface500] quit
[SwitchC] interface vlan-interface 600
[SwitchC-Vlan-interface600] ripng 1 enable
[SwitchC-Vlan-interface600] quit
# Display the routing table of Switch B.
[SwitchB] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::20F:E2FF:FE23:82F5  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 6 Sec
 Dest 2::/64,
 Peer FE80::20F:E2FF:FE00:100  on Vlan-interface200
 Dest 3::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 11 Sec
 Dest 4::/64,
 Dest 5::/64,
# Display the routing table of Switch A.
[SwitchA] display ripng 1 route
 Peer FE80::200:2FF:FE64:8904  on Vlan-interface100
 Dest 1::/64,
     via FE80::200:2FF:FE64:8904, cost  1, tag 0, A, 31 Sec
 Dest 4::/64,
     via FE80::200:2FF:FE64:8904, cost  2, tag 0, A, 31 Sec
 Dest 5::/64,
 Dest 3::/64,
3)         Configure Switch B to filter incoming and outgoing routes.
[SwitchB] acl ipv6 number 2000
[SwitchB-acl6-basic-2000] rule deny source 3::/64
[SwitchB-acl6-basic-2000] rule permit
[SwitchB-acl6-basic-2000] quit
[SwitchB] ripng 1
[SwitchB-ripng-1] filter-policy 2000 import
[SwitchB-ripng-1] filter-policy 2000 export
# Display routing tables of Switch B and Switch A.
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 2 Sec
 Dest 2::/64,
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 5 Sec
 Dest 5::/64,
 Peer FE80::20F:E2FF:FE00:1235  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE00:1235, cost  1, tag 0, A, 2 Sec
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:1235, cost  2, tag 0, A, 2 Sec
 Dest 5::/64,
OSPFv3 is OSPF (Open Shortest Path First) version 3 for short, supporting IPv6 and compliant with RFC2740 (OSPF for IPv6).
Identical parts between OSPFv3 and OSPFv2:
l           32 bits router ID and area ID
l           Packets: Hello, DD (Data Description), LSR (Link State Request), LSU (Link State Update), LSAck (Link State Acknowledgment)
l           Mechanisms for finding neighbors and establishing adjacencies
l           Mechanisms for LSA flooding and aging
Differences between OSPFv3 and OSPFv2:
l           OSPFv3 now runs on a per-link basis, instead of on a per-IP-subnet basis.
l           OSPFv3 supports multiple instances per link.
l           OSPFv3 identifies neighbors by Router ID, while OSPFv2 by IP address.
OSPFv3 has also five types of packets: hello, DD, LSR, LSU, and LSAck.
The five packets have the same packet header, which different from the OSPFv2 packet header is only 16 bytes in length, has no authentication field, but is added with an Instance ID field to support multi-instance per link.
Figure 3-1 gives the OSPFv3 packet header.
Figure 3-1 OSPFv3 packet header
Major fields:
l           Version #: Version of OSPF, which is 3 for OSPFv3.
l           Type: Type of OSPF packet, from 1 to 5 are hello, DD, LSR, LSU, and LSAck respectively.
l           Packet Length: Packet length in bytes, including header.
l           Instance ID: Instance ID for a link.
l           0: Reserved, which must be 0.
OSPFv3 sends routing information in LSAs, which as defined in RFC2740 have the following types:
l           Router-LSAs: Originated by all routers. This LSA describes the collected states of the router's interfaces to an area. Flooded throughout a single area only.
l           Network-LSAs: Originated for broadcast and NBMA networks by the Designated Router. This LSA contains the list of routers connected to the network. Flooded throughout a single area only.
l           Inter-Area-Prefix-LSAs: Similar to Type 3 LSA of OSPFv2, originated by ABRs (Area Border Routers), and flooded throughout the LSA's associated area. Each Inter-Area-Prefix-LSA describes a route with IPv6 address prefix to a destination outside the area, yet still inside the AS (an inter-area route).
l           Inter-Area-Router-LSAs: Similar to Type 4 LSA of OSPFv2, originated by ABRs and flooded throughout the LSA's associated area. Each Inter-Area-Router-LSA describes a route to ASBR (Autonomous System Boundary Router).
l           AS-external-LSAs: Originated by ASBRs, and flooded throughout the AS (except Stub and NSSA areas). Each AS-external-LSA describes a route to another Autonomous System. A default route can be described by an AS external LSA.
l           Link-LSAs: A router originates a separate Link-LSA for each attached link. Link-LSAs have link-local flooding scope. Each Link-LSA describes the IPv6 address prefix of the link and Link-local address of the router.
l           Intra-Area-Prefix-LSAs: Each Intra-Area-Prefix-LSA contains IPv6 prefix information on a router, stub area or transit area information, and has area flooding scope. It was introduced because Router-LSAs and Network-LSAs contain no address information now.
Timers in OSPFv3 include:
l           OSPFv3 packet timer
l           LSA delay timer
l           SPF timer
I. OSPFv3 packet timer
Hello packets are sent periodically between neighboring routers for finding and maintaining neighbor relationships, or for DR/BDR election. The hello interval must be identical on neighboring interfaces. The smaller the hello interval, the faster the network convergence speed and the bigger the network load.
If a router receives no hello packet from a neighbor after a period, it will declare the peer is down. The period is called dead interval.
After sending an LSA to its adjacency, a router waits for an acknowledgment from the adjacency. If no response is received after retransmission interval elapses, the router will send again the LSA. The retransmission interval must be longer than the round-trip time of the LSA in between.
II. LSA delay time
Each LSA has an age in the local LSDB (incremented by 1 per second), but an LSA is not aged on transmission. You need to add an LSA delay time into the age time before transmission, which is important for low speed networks.
III. SPF timer
Whenever LSDB changes, SPF recalculation happens. If recalculations become so frequent, a large amount of resources will be occupied, reducing operation efficiency of routers. You can adjust SPF calculation interval and delay time to protect networks from being overloaded due to frequent changes.
l           Basic features defined in RFC2740
l           OSPFv3 stub area
l           OSPFv3 multi-process, which enable a router to run multiple OSPFv3 processes
3.1.6  Related RFCs
l           RFC2740: OSPF for IPv6
l           RFC2328: OSPF Version 2
Complete the following tasks to configure OSPFv3:
Remarks
Required
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
3.3.1  Prerequisites
l           Make neighboring nodes accessible with each other at network layer.
Follow these steps to configure OSPFv3 basic functions:
To do...
Use the command...
Remarks
Enter system view
Enable OSPFv3 and enter its view
ospfv3 [ process-id ]
Required
Specify a router ID
router-id router-id
Required
Enable OSPFv3 on the interface
ospfv3 process-id area area-id [ instance instance-id ]
Required
Not enabled by default
&  Note:
l      Configure an OSPFv3 process ID when enabling OSPFv3. The process ID takes effect locally, without affecting packet exchange between routers.
l      When configuring a router ID, make sure each router has a unique ID. If a router runs multiple OSPFv3 processes, you need to specify a router ID for each process.
l      You need to specify a router ID manually, which is necessary to make OSPFv3 work.
The stub area and virtual link support of OSPFv3 has the same principle and application environments with OSPFv2.
Splitting an OSPFv3 AS into multiple areas reduces the number of LSAs on networks and extends OSPFv3 application. For those non-backbone areas residing on the AS boundary, you can configure them as Stub areas to further reduce the size of routing tables on routers in these areas and the number of LSAs.
Non-backbone areas exchange routing information via the backbone area. Therefore, the backbone and non-backbone areas, including the backbone itself must maintain connectivity. In practice, necessary physical links may not be available for connectivity. You can configure virtual links to address it.
3.4.1  Prerequisites
l           Configure OSPFv3 basic functions
Follow these steps to configure an OSPFv3 stub area:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Enter OSPFv3 area view
area area-id
Configure the area as a stub area
stub [ no-summary ]
Required
Not configured by default
Configure the default route cost of sending a packet to the stub area
default-cost value
Optional
Defaults to 1
&  Note:
l      Configurations on the OSPFv3 routers attached to the same area must be consistent. Otherwise, neighbor relationships cannot be established between adjacent routers.
l      You cannot delete an OSPFv3 area directly. Only when you remove all configurations in area view and all interfaces attached to the area become down, can the area be removed automatically.
l      All routers attached to a stub area must be configured with the stub command. The keyword no-summary is only available on the ABR.
l      If you use the stub command with the keyword no-summary on an ABR, the ABR distributes a default summary LSA into the area rather than generating an AS-external-LSA or Inter-Area-Prefix-LSA. The stub area of this kind is also known as totally stub area.
You can configure virtual links to maintain connectivity between non-backbone areas and the backbone, or in the backbone itself.
Follow these steps to configure a virtual link:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
area area-id
Create and configure a virtual link
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | instance instance-id ] *
Required
&  Note:
Both ends of a virtual link are ABRs that are configured with the vlink-peer command.
This section is to configure management of OSPF routing information advertisement and reception, and route redistribution from other protocols.
3.5.1  Prerequisites
Follow these steps to configure route summarization between areas:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
area area-id
Configure a summary route
abr-summary ipv6-address prefix-length [ not-advertise ]
Required
&  Note:
The abr-summary command is available on ABRs only. If contiguous network segments are available in an area, you can use the command to summarize them into one network segment on the ABR. The ABR will advertise only the summary route. Any LSA falling into the specified network segment will not be advertised, reducing the LSDB size in other areas.
You can configure OSPFv3 to filter routes that are computed from received LSAs according to some rules.
Follow these steps to configure inbound route filtering:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Configure inbound route filtering
filter-policy { acl-number | ipv6-prefix ipv6-prefix-name } import
Required
&  Note:
Use of the filter-policy import command can only filter routes computed by OSPFv3. Only routes not filtered can be added into the local routing table.
You can configure OSPFv3 link costs for interfaces to adjust routing calculation.
Follow these steps to configure the link cost for an OSPFv3 interface:
To do...
Use the command...
Remarks
Enter system view
Configure the cost for the interface
ospfv3 cost value [ instance instance-id ]
Optional
1 by default
If multiple routes to a destination are available, using load balancing to send IPv6 packets on these routes in turn can improve link utility.
Follow these steps to configure the maximum number of load-balanced routes:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Specify the maximum number of load-balanced routes
maximum load-balancing maximum
Optional
4 by default
A router may run multiple routing protocols. The system assigns a priority for each protocol. When these routing protocols find the same route, the route found by the protocol with the highest priority is selected.
Follow these steps to configure a priority for OSPFv3:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Configure a priority for OSPFv3
preference [ ase ] [ route-policy route-policy-name ] preference
Optional
By default, the priority of OSPFv3 interval routes is 10, and priority of OSPFv3 external routes is 150.
Follow these steps to configure OSPFv3 route redistribution:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Specify a default cost for redistributed routes
default cost value
Optional
Defaults to 1
Redistribute routes from another protocol, or another OSPFv3 process
import-route { isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ [ allow-ibgp ] | direct | static } [ cost value | type type | route-policy route-policy-name ] *
Required
Configure the filtering of outgoing redistributed routes
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static ]
Optional
&  Note:
l      Using the import-route command on a router makes the router become an ASBR.
l      Since OSPFv3 is a link state based routing protocol, it cannot directly filter LSAs to be advertised. Therefore, you need to configure filtering redistributed routes before advertising routes that are not filtered in LSAs into the routing domain.
l      Use of the filter-policy export command takes effect only on the local router. However, if the import-route command is not configured, executing the filter-policy export command does not take effect.
This section describes configurations of OSPFv3 timers, interface DR priority, MTU check ignorance for DD packets, disabling interfaces from sending OSPFv3 packets.
OSPFv3 timers:
l           Packet timer: Specified to adjust topology convergence speed and network load
l           LSA delay timer: Specified especially for low speed links
l           SPF timer: Specified to protect networks from being over consumed due to frequent network changes.
For a broadcast network, you can configure DR priorities for interfaces to affect DR/BDR election.
By disabling an interface from sending OSPFv3 packets, you can make other routers on the network obtain no information from the interface.
3.6.1  Prerequisites
Follow these steps to configure OSPFv3 timers:
To do...
Use the command...
Remarks
Enter system view
Configure the hello interval
ospfv3 timer hello seconds [ instance instance-id ]
Optional
10 seconds by default
Configure the dead interval
ospfv3 timer dead seconds [ instance instance-id ]
Optional
40 seconds by default
Configure the LSA retransmission interval
ospfv3 timer retransmit interval [ instance instance-id ]
Optional
Defaults to 5 seconds
Configure the LSA transmission delay
ospfv3 trans-delay seconds [ instance instance-id ]
Optional
Defaults to 1 second
Enter OSPFv3 view
Configure the SPF timer
spf timers delay-interval hold-interval
Optional
By default, delay-interval is 5 seconds, and hold-interval is 10 seconds
&  Note:
l      The dead interval set on neighboring interfaces cannot be so short. Otherwise, a neighbor is easily considered down.
l      The LSA retransmission interval cannot be so short; otherwise, unnecessary retransmissions occur.
Follow these steps to configure the DR priority for an interface:
To do...
Use the command...
Remarks
Enter system view
Configure the DR priority
ospfv3 dr-priority priority [ instance instance-id ]
Optional
Defaults to 1
&  Note:
The DR priority of an interface determines the interface’s qualification in DR election. Interfaces having the priority 0 cannot become a DR or BDR.
When LSAs are few in DD packets, it is unnecessary to check MTU in DD packets in order to improve efficiency.
Follow these steps to ignore MTU check for DD packets:
To do...
Use the command...
Remarks
Enter system view
Ignore MTU check for DD packets
ospfv3 mtu-ignore [ instance instance-id ]
Required
Not ignored by default
Follow these steps to disable interfaces from sending OSPFv3 packets:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Disable interfaces from sending OSPFv3 packets
Required
Not disabled by default
&  Note:
l      Multiple processes can disable the same interface from sending OSPFv3 packets. Using the silent-interface command disables only the interfaces associated with the current process rather than interfaces associated with other processes.
l      After an OSPF interface is set to silent, direct routes of the interface can still be advertised in Intra-Area-Prefix-LSAs via other interfaces, but other OSPFv3 packets cannot be advertised. Therefore, no neighboring relationship can be established on the interface. This feature can enhance the adaptability of OSPFv3 networking.
Follow these steps to enable the logging on neighbor state changes:
To do...
Use the command...
Remarks
Enter system view
Enter OSPFv3 view
Enable the logging on neighbor state changes
log-peer-change
Required
Enabled by default
To do...
Use the command...
Remarks
Display OSPFv3 debugging state information
display debugging ospfv3
Display OSPFv3 process brief information
display ospfv3 [ process-id ]
Display OSPFv3 interface information
display ospfv3 interface [ interface-type interface-number | statistic ]
Display OSPFv3 LSDB information
display ospfv3 [ process-id ] lsdb [ [ external | inter-prefix | inter-router | intra-prefix | link | network | router ] [ link-state-id ] [ originate-router router-id ] | total ]
Display LSA statistics in OSPFv3 LSDB
display ospfv3 lsdb statistic
Display OSPFv3 neighbor information
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id ]
Display OSPFv3 neighbor statistics
display ospfv3 peer statistic
Display OSPFv3 routing table information
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length | ipv6-address/prefix-length | abr-routes | asbr-routes | all | statistics ]
Display OSPFv3 area topology information
display ospfv3 [ process-id ] topology [ area area-id ]
Display OSPFv3 virtual link information
display ospfv3 [ process-id ] vlink
Display OSPFv3 next hop information
display ospfv3 [ process-id ] next-hop
Display OSPFv3 link state request list information
display ospfv3 [ process-id ] request-list [ statistics ]
Display OSPFv3 link state retransmission list information
display ospfv3 [ process-id ] retrans-list [ statistics ]
Display OSPFv3 statistics
display ospfv3 statistic
In the following figure, all switches run OSPFv3. The AS is split into three areas, in which, Switch B and Switch C act as ABRs to forward routing information between areas.
It is required to configure Area 2 as a stub area, reducing LSAs into the area without affecting route reachability.
II. Network diagram
Figure 3-2 Network diagram for OSPFv3 area configuration
1)         Configure IPv6 addresses for interfaces (omitted)
2)         Configure OSPFv3 basic functions
[SwitchA] ipv6
[SwitchA] ospfv3
[SwitchA-ospfv3-1] router-id 1.1.1.1
[SwitchA-ospfv3-1] quit
[SwitchA] interface vlan-interface 300
[SwitchA-Vlan-interface300] ospfv3 1 area 1
[SwitchA-Vlan-interface300] quit
[SwitchA-Vlan-interface200] ospfv3 1 area 1
[SwitchB] ipv6
[SwitchB] ospfv3
[SwitchB-ospf-1] router-id 2.2.2.2
[SwitchB-ospf-1] quit
[SwitchB-Vlan-interface100] ospfv3 1 area 0
[SwitchB-Vlan-interface200] ospfv3 1 area 1
[SwitchC] ipv6
[SwitchC] ospfv3
[SwitchC-ospfv3-1] router-id 3.3.3.3
[SwitchC-ospfv3-1] quit
[SwitchC-Vlan-interface100] ospfv3 1 area 0
[SwitchC] interface vlan-interface 400
[SwitchC-Vlan-interface400] ospfv3 1 area 2
[SwitchC-Vlan-interface400] quit
# Configure Switch D
<SwitchD> system-view
[SwitchD] ipv6
[SwitchD] ospfv3
[SwitchD-ospfv3-1] router-id 4.4.4.4
[SwitchD-ospfv3-1] quit
[SwitchD] interface Vlan-interface 400
[SwitchD-Vlan-interface400] ospfv3 1 area 2
# Display OSPFv3 neighbor information on Switch B.
[SwitchB] display ospfv3 peer
            OSPFv3 Area ID 0.0.0.0 (Process 1)
Neighbor ID    Pri   State          Dead Time   Interface      Instance ID
3.3.3.3        1     Full/DR        00:00:39    Vlan100        0
            OSPFv3 Area ID 0.0.0.1 (Process 1)
1.1.1.1         1     Full/Backup   00:00:38    Vlan200        0
# Display OSPFv3 neighbor information on Switch C.
[SwitchC] display ospfv3 peer
2.2.2.2        1     Full/Backup    00:00:39    Vlan100        0
            OSPFv3 Area ID 0.0.0.2 (Process 1)
4.4.4.4         1     Full/DR       00:00:38    Vlan400        0
# Display OSPFv3 routing table information on Switch D.
[SwitchD] display ospfv3 routing
E1 - Type 1 external route,    IA - Inter area route,    I  - Intra area route
E2 - Type 2 external route,    *  - Seleted route
            OSPFv3 Router with ID (4.4.4.4) (Process 1)
 *Destination: 2001::/64
  Type       : IA                                       Cost     : 2
  NextHop    : FE80::F40D:0:93D0:1                      Interface: Vlan400
 *Destination: 2001:1::/64
  Type       : IA                                       Cost     : 3
 *Destination: 2001:2::/64
  Type       : I                                        Cost     : 1
  NextHop    : directly-connected                       Interface: Vlan400
 *Destination: 2001:3::/64
  Type       : IA                                       Cost     : 4
3)         Configure Area 2 as a stub area
[SwitchD] ospfv3
[SwitchD-ospfv3-1] area 2
[SwitchD-ospfv3-1-area-0.0.0.2] stub
# Configure Switch C, and specify the cost of the default route sent to the stub area as 10.
[SwitchC] ospfv3
[SwitchC-ospfv3-1] area 2
[SwitchC-ospfv3-1-area-0.0.0.2] stub
[SwitchC-ospfv3-1-area-0.0.0.2] default-cost 10
# Display OSPFv3 routing table information on Switch D. You can find a default route is added, whose cost is the cost of the directly connected route plus the configured cost.
 *Destination: ::/0
  Type       : IA                                       Cost     : 11
  Type       : IA                                       Cost     : 2
  Type       : IA                                       Cost     : 3
  Type       : I                                        Cost     : 1
  Type       : IA                                       Cost     : 4
4)         Configure Area 2 as a totally stub area
# Configure Switch C, the ABR, to make Area 2 as a totally stub area.
[SwitchC-ospfv3-1-area-0.0.0.2] stub no-summary
# Display OSPFv3 routing table information on Switch D. You can find route entries are reduced. All non direct routes are removed except the default route.
 *Destination: ::/0
  Type       : IA                                       Cost     : 11
  Type       : I                                        Cost     : 1
In the following figure:
l           The priority of Switch A is 100, the highest priority on the network, so it will be the DR.
l           The priority of Switch C is 2, the second highest priority on the network, so it will be the BDR.
l           The priority of Switch B is 0, so it cannot become the DR.
l           RouterD has the default priority 1.
II. Network diagram
Figure 3-3 Network diagram for OSPFv3 DR election configuration
[SwitchA] ipv6
[SwitchA] ospfv3
[SwitchA-Vlan-interface100] ospfv3 1 area 0
[SwitchB] ipv6
[SwitchB] ospfv3
[SwitchB-ospfv3-1] router-id 2.2.2.2
[SwitchB-ospfv3-1] quit
[SwitchB-Vlan-interface200] ospfv3 1 area 0
[SwitchC] ipv6
[SwitchC] ospfv3
[SwitchD] ipv6
[SwitchD] ospfv3
[SwitchD] interface vlan-interface 200
[SwitchD-Vlan-interface200] ospfv3 1 area 0
[SwitchD-Vlan-interface200] quit
# Display neighbor information on Switch A. You can find the switches have the same default DR priority 1. In this case, the switch with the highest Router ID is elected as the DR. Therefore, Switch D is the DR, and Switch C is the BDR.
 [SwitchA] display ospfv3 peer
2.2.2.2        1     2-Way/DROther   00:00:36    Vlan200        0
3.3.3.3        1     Full/Backup     00:00:35    Vlan100        0
4.4.4.4        1     Full/DR         00:00:33    Vlan200        0
# Display neighbor information on Switch D. You can find the neighbor states between Switch D and other switches are all full.
 [SwitchD] display ospfv3 peer
1.1.1.1        1     Full/DROther    00:00:30    Vlan100        0
2.2.2.2        1     Full/DROther    00:00:37    Vlan200        0
3.3.3.3        1     Full/Backup     00:00:31    Vlan100        0
3)         Configure DR priorities for interfaces.
# Configure the DR priority of VLAN-interface 100 as 100 on Switch A.
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ospfv3 dr-priority 100
# Configure the DR priority of VLAN-interface 200 as 0 on Switch B.
[SwitchB-Vlan-interface200] ospfv3 dr-priority 0
#Configure the DR priority of Switch C as 2.
[SwitchC] interface Vlan-interface 100
[SwitchC-Vlan-interface100] ospfv3 dr-priority 2
# Display neighbor information on Switch A. You can find DR priorities have been updated, but DR and BDR are not changed.
2.2.2.2        0     2-Way/DROther   00:00:38    Vlan200        0
3.3.3.3        2     Full/Backup     00:00:32    Vlan100        0
4.4.4.4        1     Full/DR         00:00:36    Vlan200        0
#Display neighbor information on Switch D. You can find Switch D is still the DR.
1.1.1.1        100   Full/DROther    00:00:33    Vlan100        0
2.2.2.2        0     Full/DROther    00:00:36    Vlan200        0
3.3.3.3        2     Full/Backup     00:00:40    Vlan100        0
4)         Restart DR/BDR election
# Use the shutdown and undo shutdown commands on interfaces to restart DR/BDR election (omitted).
# Display neighbor information on Switch A. You can find Switch C becomes the BDR.
2.2.2.2        0     Full/DROther    00:00:31    Vlan200        0
3.3.3.3        2     Full/Backup     00:00:39    Vlan100        0
4.4.4.4        1     Full/DROther    00:00:37    Vlan200        0
# Display neighbor information on Switch D. You can find Switch A becomes the DR.
1.1.1.1        100   Full/DR         00:00:34    Vlan100        0
2.2.2.2        0     2-Way/DROther   00:00:34    Vlan200        0
I. Symptom
No OSPF neighbor relationship can be established.
II. Analysis
If the physical link and lower protocol work well, check OSPF parameters configured on interfaces. The two neighboring interfaces must have the same parameters, such as the area ID, network segment and mask, network type. If the network type is broadcast, at least one interface must have a DR priority higher than 0.
III. Process steps
1)         Display neighbor information using the display ospfv3 peer command.
2)         Display OSPFv3 interface information using the display ospfv3 interface command.
3)         Ping the neighbor router’s IP address to check connectivity.
4)         Check OSPF timers. The dead interval on an interface must be at least four times the hello interval.
5)         On a broadcast network, at least one interface must have a DR priority higher than 0.
I. Symptom
OSPFv3 cannot find routes to other areas.
II. Analysis
The backbone area must maintain connectivity to all other areas. If a router connects to more than one area, at least one area must be connected to the backbone. The backbone cannot be configured as a Stub area.
In a Stub area, all routers cannot receive external routes, and all interfaces connected to the Stub area must be associated with the Stub area.
III. Solution
1)         Use the display ospfv3 peer command to display OSPFv3 neighbors.
2)         Use the display ospfv3 interface command to display OSPFv3 interface information.
3)         Use the display ospfv3 lsdb command to display Link State Database information to check integrity.
4)         Display information about area configuration using the display current-configuration configuration command. If more than two areas are configured, at least one area is connected to the backbone.
5)         In a Stub area, all routers are configured with the stub command.
6)         If a virtual link is configured, use the display ospf vlink command to check the neighbor state.
&  Note:
l      IPv6 IS-IS supports all the features of IPv4 IS-IS except that it advertises IPv6 routing information instead. This document describes only IPv6 IS-IS exclusive configuration tasks. For other configuration tasks, refer to the part discussing IPv4 routing.
When configuring IPv6 IS-IS, go to these sections for information you are interested in:
l           Introduction to IPv6 IS-IS
l           Configuring IPv6 IS-IS Basic Functions
l           Configuring IPv6 IS-IS Routing Information Control
l           Displaying and Maintaining IPv6 IS-IS
l           IPv6 IS-IS Configuration Example
The IS-IS routing protocol (Intermediate System-to-Intermediate System intra-domain routing information exchange protocol) supports multiple network protocols, including IPv6. IS-IS with IPv6 support is called IPv6 IS-IS dynamic routing protocol. The international engineer task force (IETF) defines two type-length-values (TLVs) and a new network layer protocol identifier (NLPID) to enable IPv6 support for IS-IS.
TLV is a variable field in the link state PDU or link state packet (LSP). The two TLVs are:
l           IPv6 Reachability: Defines the prefix, metric of routing information to indicate the network reachability, with a type value of 236 (0xEC).
l           IPv6 Interface Address: Similar with the “IP Interface Address” TLV of IPv4, it transforms the 32-bit IPv4 address to the 128-bit IPv6 address.
NLPID is an 8-bit field with a value of 142 (0x8E), which indicates the network layer protocol packet. If the IS-IS router supports IPv6, the advertised routing information must be marked with the NLPID.
&  Note:
You can implement IPv6 inter-networking through configuring IPv6 IS-IS in IPv6 network environment.
l           Enable IPv6 globally
l           Configure IP addresses for interfaces, and make sure all neighboring nodes are reachable.
l           Enable IS-IS
Follow these steps to configure the basic functions of IPv6 IS-IS:
To do...
Use command to…
Remarks
Enter system view
Enable an IS-IS process and enter IS-IS view
Required
Configure the network entity title for the IS-IS process
network-entity net
Required
Enable IPv6 for the IS-IS process
ipv6 enable
Required
Disabled by default
Enable IPv6 for an IS-IS process on the interface
isis ipv6 enable [ process-id ]
Required
Disabled by default
You need to complete the IPv6 IS-IS basic function configuration before configuring this task.
Follow these steps to configure IPv6 IS-IS routing information control:
To do...
Use command to…
Remarks
Enter system view
Enter IS-IS view
Define the priority for IPv6 IS-IS routes
ipv6 preference { route-policy route-policy-name | preference } *
Optional
15 by default
Configure an IPv6 IS-IS summary route
ipv6 summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
Optional
Generate an IPv6 IS-IS default route
ipv6 default-route-advertise [ [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name ]*
Optional
No IPv6 default route is defined by default.
Configure IPv6 IS-IS to filter incoming routes
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
Optional
No filtering policy is defined by default
Configure IPv6 IS-IS to redistribute routes from another routing protocol
ipv6 import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost-value | [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name | tag tag-value ] *
Optional
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Optional
Enable route leaking
ipv6 import-route isisv6 level-2 into level-1 [ filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } | tag tag ]*
Optional
Specify the maximum number of equal-cost load balanced routes
ipv6 maximum load-balancing number
Optional
4 by default
&  Note:
The ipv6 filter-policy export command, usually used in combination with the ipv6 import-route command, filters redistributed routes when advertising them to other routers. If no protocol is specified, routes redistributed from all routing protocols are filtered before advertisement. If a protocol is specified, only routes redistributed from the routing protocol are filtered for advertisement.
To do...
Use the command...
Remarks
Display brief IPv6 IS-IS information
display isis brief
Display the status of the debug switches
display isis debug-switches { process-id | vpn-instance vpn-instance-name }
Display IS-IS enabled interface information
display isis interface [ verbose ] [ process-id | vpn-instance vpn-instance-name ]
Display IS-IS license information
display isis license
Display LSDB information
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ [ lsp-id lsp-id | lsp-name lspname | local ] | verbose ] * ] * [ process-id | vpn-instance vpn-instance-name ]
Display IS-IS mesh group information
display isis mesh-group [ process-id | vpn-instance vpn-instance-name ]
Display the mapping table between the host name and system ID
display isis name-table [ process-id | vpn-instance vpn-instance-name ]
Display IS-IS neighbor information
display isis peer [ verbose ] [ process-id | vpn-instance vpn-instanc-name]
Display IPv6 IS-IS routing information
display isis route ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display SPF log information
display isis spf-log [ process-id | vpn-instance vpn-instance-name ]
Display the statistics of the IS-IS process
display isis statistics [ level-1 | level-2 | level-1-2 ]  [ process-id | vpn-instance vpn-instance-name ]
Clear all IS-IS data structure information
reset isis all [ process-id | vpn-instance vpn-instance-name ]
Available in user view
Clear the IS-IS data information of a neighbor
reset isis peer system-id  [ process-id | vpn vpn-instance-name ]
As shown in Figure 4-1, Switch A, Switch B, Switch C and Switch D reside in the same autonomous system, and all are enabled with IPv6.
Switch A and Switch B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch. Switch A, Switch B, and Switch C are in area 10, while Switch D is in area 20.
II. Network diagram
Figure 4-1 Network diagram for IPv6 IS-IS basic configuration
2)         Configure IPv6 IS-IS
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] ipv6 enable
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis ipv6 enable 1
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] ipv6 enable
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis ipv6 enable 1
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] ipv6 enable
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis ipv6 enable 1
[SwitchC-Vlan-interface200] isis ipv6 enable 1
[SwitchC-Vlan-interface300] isis ipv6 enable 1
[SwitchC-Vlan-interface300] quit
# Configure Switch D.
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] ipv6 enable
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis ipv6 enable 1
[SwitchD-Vlan-interface300] quit
[SwitchD] interface vlan-interface 301
[SwitchD-Vlan-interface301] isis ipv6 enable 1
[SwitchD-Vlan-interface301] quit
&  Note:
l      This chapter describes only configuration for IPv6 BGP. For other related information, refer to the part discussing IPv4 routing.
When configuring IPv6 BGP, go to these sections for information you are interested in:
l           IPv6 BGP Overview
l           Configuration Task List
l           Configuring IPv6 BGP Basic Functions
l           Controlling Route Distribution and Reception
l           Configuring IPv6 BGP Route Attributes
l           Tuning and Optimizing IPv6 BGP Networks
l           Configuring a Large Scale IPv6 BGP Network
l           Displaying and Maintaining IPv6 BGP Configuration
l           IPv6 BGP Configuration Examples
l           Troubleshooting IPv6 BGP Configuration
BGP-4 manages only IPv4 routing information, thus other network layer protocols such as IPv6 are not supported.
To support multiple network layer protocols, IETF extended BGP-4 by introducing IPv6 BGP that is defined in RFC 2858 (multiprotocol extensions for BGP-4).
To implement IPv6 support, IPv6 BGP puts IPv6 network layer information into the attributes of network layer reachable information (NLRI) and NEXT_HOP.
NLRI attribute of IPv6 BGP involves:
l           MP_REACH_NLRI: Multiprotocol Reachable NLRI, for advertisement of next hop information of reachable routes.
l           MP_UNREACH_NLRI: Multiprotocol Unreachable NLRI, for withdrawal of unreachable routes.
The NEXT_HOP attribute of IPv6 BGP is identified by an IPv6 unicast address or IPv6 local link address.
IPv6 BGP utilizes BGP multiprotocol extensions for application in IPv6 networks. The original messaging and routing mechanisms of BGP are not changed.
Complete the following tasks to configure IPv6 BGP:
Remarks
Required
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
5.3.1  Prerequisites
Before configuring this task, you need to:
l           Specify IP addresses for interfaces.
l           Enable IPv6.
&  Note:
You need create a peer group before configuring basic functions for it. For related information, refer to Configuring IPv6 BGP Peer Group.
Follow these steps to configure an IPv6 peer:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
Specify a router ID
router-id router-id
Optional
Required if no IP addresses configured for Loopback interface and other interfaces
Enter IPv6 address family view
ipv6-family
Specify an IPv6 peer and its AS number
Required
Follow these steps to configure advertise a local route into the routing table:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Add a local route into IPv6 BGP routing table
network ipv6-address prefix-length [ short-cut | route-policy route-policy-name ]
Required
Not added by default
Follow these steps to configure a preferred value for routes received from a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure a preferred value for routes received from a peer/peer group
peer { ipv6-group-name | ipv6-address } preferred-value value
Optional
By default, the preferred value is 0.
&  Note:
If you both reference a routing policy and use the command peer { ipv6-group-name | ipv6-address } preferred-value value to set a preferred value for routes from a peer, the routing policy sets a non-zero preferred value for routes matching it. Other routes not matching the routing policy uses the value set with the command. If the preferred value in the routing policy is zero, the routes matching it will also use the value set with the command. For information about using a routing policy to set a preferred value, refer to the peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export } command and the apply preferred-value preferred-value command.
Follow these steps to specify the source interface for establishing TCP connections to a BGP peer or peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Specify the source interface for establishing TCP connections to a BGP peer or peer group
peer { ipv6-group-name | ipv6-address } connect-interface interface-type interface-number
Required
By default, BGP uses the outbound interface of the best route to the BGP peer as the source interface for establishing a TCP connection.
&  Note:
l      To improve stability and reliability, you can specify a loopback interface as the source interface for establishing TCP connections to a BGP peer. By doing so, a connection failure upon redundancy availability will not affect TCP connection establishment.
l      To establish multiple BGP connections to a BGP router, you need to specify on the local router the respective source interfaces for establishing TCP connections to the peers on the peering BGP router; otherwise, the local BGP router may fail to establish TCP connections to the peers when using the outbound interfaces of the best routes as the source interfaces.
5.3.6  Allowing the establishment of a Non-Direct EBGP connection
Follow these steps to allow the establishment of EBGP connection to a non-directly connected peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Allow the establishment of EBGP connection to a non directly connected peer/peer group
peer { ipv6-group-name | ipv6-address } ebgp-max-hop [ hop-count ]
Required
  Caution:
In general, direct links should be available between EBGP peers. If not, you can use the peer ebgp-max-hop command to establish a multi-hop TCP connection in between. However, you need not use this command for direct EBGP connection with loopback interfaces.
5.3.7  Configuring a Description for a Peer/Peer Group
Follow these steps to configure description for a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure a description for a peer/peer group
peer { ipv6-group-name | ipv6-address } description description-text
Optional
&  Note:
The peer group to be configured with a description must have been created.
5.3.8  Disabling Session Establishment to a Peer/Peer Group
Follow these steps to disable session establishment to a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Disable session establishment to a peer/peer group
peer { ipv6-group-name | ipv6-address } ignore
Optional
5.3.9  Logging Peer State Changes
Follow these steps to configure to log on the session and event information of a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
Enable logging of peer changes globally
log-peer-change
Optional
Enabled by default
ipv6-family
Enable the state change logging for a peer or peer group
peer { ipv6-group-name | ipv6-address } log-change
Optional
Enabled by default
&  Note:
Refer to the part discussing IPv4 routing commands for information about the log-peer-change command.
5.4  Controlling Route Distribution and Reception
The task includes routing information filtering, routing policy application and route dampening.
5.4.1  Prerequisites
Before configuring this task, you have:
l           Enabled the IPv6 function
l           Configured the IPv6 BGP basic functions
5.4.2  Configuring IPv6 BGP Route Redistribution
Follow these steps to configure IPv6 BGP route redistribution and filtering:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
ipv6-family
Enable default route redistribution into the IPv6 BGP routing table
default-route imported
Optional
Enable route redistribution from another routing protocol
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ]*
Required
&  Note:
If the default-route imported command is not configured, using the import-route command cannot redistribute any IGP default route.
5.4.3  Advertising a Default Route to a Peer/Peer Group
Follow these steps to configure to advertise default route to a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Advertise a default route to a peer/peer group
peer { ipv6-group-name | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
Required
&  Note:
With the peer default-route-advertise command used, the local router advertises a default route with itself as the next hop to the specified peer/peer group, regardless of whether the default route is available in the routing table.
5.4.4  Configuring Route Distribution Policy
Follow these steps to configure policies for route distribution:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure outbound route filtering
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol process-id ]
Required
Apply a routing policy to routes advertised to a peer/peer group
peer { ipv6-group-name | ipv6-address } route-policy route-policy-name export
Required
Not applied by default
Specify an IPv6 ACL to filer routes advertised to a peer/peer group
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number export
Required
Not specified by default
Specify an AS path ACL to filer routes advertised to a peer/peer group
peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number export
Required
Specify an IPv6 prefix list to filer routes advertised to a peer/peer group
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name export
Required
&  Note:
l      Members of a peer group must have the same outbound route policy with the peer group.
l      IPv6 BGP advertises routes passing the specified policy to peers. Using the protocol argument can filter only the specified protocol routes. If no protocol specified, IPv6 BGP filters all routes to be advertised, including redistributed routes and routes imported using the network command.
5.4.5  Configuring Route Reception Policy
Follow these steps to configure route reception policy:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
ipv6-family
Required
Apply a routing policy to routes from a peer/peer group
peer { ipv6-group-name | ipv6-address } route-policy route-policy-name import
Required
Specify an ACL to filter routes imported from a peer/peer group
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number import
Required
Specify an AS path ACL to filter routing information imported from a peer/peer group
peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number import
Required
Specify an IPv6 prefix list to filter routing information imported from a peer/peer group
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name import
Required
Specify the upper limit of address prefixes imported from a peer/peer group
peer { ipv6-group-name | ipv6-address } route-limit limit [ percentage ]
Optional
By default, no limit on prefixes
&  Note:
l      Only routes passing the specified policy can be added into the local IPv6 BGP routing table.
l      Members of a peer group can have different inbound route policies.
5.4.6  Configuring IPv6 BGP and IGP Route Synchronization
With this feature enabled and when a non-BGP router is responsible for forwarding packets in an AS, IPv6 BGP speakers in the AS cannot advertise routing information to outside ASs unless all routers in the AS know the latest routing information.
By default, when a BGP router receives an IBGP route, it only checks the reachability of the route’s next hop before advertisement. If the synchronization feature is configured, only the IBGP route is advertised by IGP can the route be advertised to EBGP peers.
Follow these steps to configure IPv6 BGP and IGP route synchronization:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Enable route synchronization between IPv6 BGP and IGP
synchronization
Required
5.4.7  Configuring Route Dampening
Follow these steps to configure BGP route dampening:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure IPv6 BGP route dampening parameters
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ]*
Optional
5.5  Configuring IPv6 BGP Route Attributes
This section describes how to use IPv6 BGP route attributes to modify BGP routing policy. These attributes are:
l           IPv6 BGP protocol preference
l           Default LOCAL_PREF attribute
l           MED attribute
l           NEXT_HOP attribute
l           AS_PATH attribute
5.5.1  Prerequisites
l           Enabled IPv6 function
l           Configured IPv6 BGP basic functions
5.5.2  Configuring IPv6 BGP Preference and Default LOCAL_PREF and NEXT_HOP Attributes
Follow these steps to perform this configuration:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure preference values for IPv6 BGP external, internal, local routes
Optional
The default preference values of external, internal and local routes are 255, 255, 130 respectively
Configure the default value for local preference
Optional
The value defaults to 100
Advertise routes to a peer/peer group with the local router as the next hop
peer { ipv6-group-name | ipv6-address } next-hop-local
Required
By default, the feature is available for routes advertised to the EBGP peer/peer group, but not available to the IBGP peer/peer group
&  Note:
l      To make sure an IBGP peer can find the correct next hop, you can configure routes advertised to the peer to use the local router as the next hop. If BGP load balancing is configured, the local router specifies itself as the next hop of outbound routes to a peer/peer group regardless of whether the peer next-hop-local command is configured.
l      In a “third party next hop" network, that is, the two EBGP peers reside in a common broadcast subnet, the router does not specify itself as the next hop for routes to the EBGP peer by default, unless the peer next-hop-local command is configured.
5.5.3  Configuring the MED Attribute
Follow these steps to configure the MED attribute:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure a default MED value
default med med-value
Optional
Defaults to 0
Enable to compare MED values of routes from different EBGP peers
compare-different-as-med
Optional
Prioritize MED values of routes from each AS
bestroute compare-med
Optional
Prioritize MED values of routes from confederation peers
bestroute med-confederation
Optional
5.5.4  Configuring the AS_PATH Attribute
Follow these steps to configure the AS_PATH attribute:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Allow the local AS number to appear in AS_PATH of routes from a peer/peer group and specify the repeat times
peer { ipv6-group-name | ipv6-address } allow-as-loop [ number ]
Optional
Not allowed by default
Specify a fake AS number for a peer/peer group
peer { ipv6-group-name | ipv6-address } fake-as as-number
Optional
Neglect the AS_PATH attribute for best route selection
bestroute as-path-neglect
Optional
Not neglected by default
Configure to carry only the public AS number in updates sent to a peer/peer group
peer { ipv6-group-name | ipv6-address } public-as-only
Optional
By default, BGP updates carry private AS number
Substitute local AS number for the AS number of a peer/peer group indicated in the AS_PATH attribute
peer { ipv6-group-name | ipv6-address } substitute-as
Optional
Not substituted by default
5.6  Tuning and Optimizing IPv6 BGP Networks
This section describes configurations of IPv6 BGP timers, IPv6 BGP connection soft reset and the maximum number of load balanced routes.
l           IPv6 BGP timers
After establishing an IPv6 BGP connection, two routers send keepalive messages periodically to each other to keep the connection. If a router receives no keepalive message from the peer after the holdtime elapses, it tears down the connection.
When establishing an IPv6 BGP connection, the two parties compare their holdtime values, taking the shorter one as the common holdtime. If the holdtime is 0, neither keepalive massage is sent, nor holdtime is checked.
l           IPv6 BGP connection soft reset
After modifying a route selection policy, you have to reset IPv6 BGP connections to make the new one take effect, causing a short time disconnection. The current IPv6 BGP implementation supports the route-refresh feature that enables dynamic IPv6 BGP routing table refresh without needing to disconnect IPv6 BGP links.
With this feature enabled on all IPv6 BGP routers in a network, when a routing policy modified on a router, the router advertises a route-refresh message to its peers, which then send their routing information back to the router. Therefore, the local router can perform dynamic routing information update and apply the new policy without tearing down connections.
If a router not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command on the router to save all route updates, and then use the refresh bgp ipv6 command to soft-reset IPv6 BGP connections.
5.6.1  Prerequisites
Before configuring IPv6 BGP timers, you have:
5.6.2  Configuring IPv6 BGP Timers
Follow these steps to configure IPv6 BGP timers:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure IPv6 BGP timers
Specify keepalive interval and holdtime
Optional
The keepalive interval defaults to 60 seconds, holdtime defaults to 180 seconds.
Configure keepalive interval and holdtime for a peer/peer group
peer { ipv6-group-name | ipv6-address } timer keepalive keepalive hold holdtime
Configure the interval for sending the same update to a peer/peer group
peer { ipv6-group-name | ipv6-address } route-update-interval seconds
Optional
The interval for sending the same update to an IBGP peer or an EBGP peer defaults to 15 seconds or 30 seconds
&  Note:
l      Timers configured using the timer command have lower priority than timers configured using the peer timer command.
l      The holdtime interval must be at least three times the keepalive interval.
5.6.3  Configuring IPv6 BGP Soft Reset
I. Enable route refresh
Follow these steps to enable route refresh:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
peer { ipv6-group-name | ipv6-address } capability-advertise route-refresh
Optional
Enabled by default
II. Perform manual soft-reset
Follow these steps to perform manual soft reset:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Save all routes from a peer/peer group, not letting them go through the inbound policy
peer { ipv6-group-name | ipv6-address } keep-all-routes
Optional
Not saved by default.
Return to user view
return
Required
Soft-reset BGP connections manually
refresh bgp ipv6 { all | ipv6-address | group ipv6-group-name | external | internal } { export | import }
&  Note:
If the peer keep-all-routes command is used, all routes from the peer/peer group will be saved regardless of whether the filtering policy is available. These routes will be used to generate IPv6 BGP routes after soft-reset is performed.
5.6.4  Configuring the Maximum Number of Load-Balanced Routes
Follow these steps to configure the maximum number of load balanced routes:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure the maximum number of load balanced routes
balance number
Required
By default, no load balancing is enabled.
5.7  Configuring a Large Scale IPv6 BGP Network
In a large-scale IPv6 BGP network, configuration and maintenance become no convenient due to too many peers. In this case, configuring peer groups makes management easier and improves route distribution efficiency. Peer group includes IBGP peer group, where peers belong to the same AS, and EBGP peer group, where peers belong to different ASs. If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group, and if not, a mixed EBGP peer group.
In a peer group, all members enjoy a common policy. Using the community attribute can make a set of IPv6 BGP routers in multiple ASs enjoy the same policy, because sending of community between IPv6 BGP peers is not limited by AS.
To guarantee connectivity between IBGP peers, you need to make them fully meshed, but it becomes unpractical when there are too many IBGP peers. Using route reflectors or confederation can solve it. In a large-scale AS, both of them can be used.
Confederation configuration of IPv6 BGP is identical to that of BGP4, so it is not mentioned here. The following describes:
l           Configuring IPv6 BGP peer group
l           Configuring IPv6 BGP community
l           Configuring IPv6 BGP route reflector
5.7.1  Prerequisites
Before configuring IPv6 BGP peer group, you have:
l           Made peer nodes accessible at network layer
l           Enabled BGP and configured router ID.
5.7.2  Configuring IPv6 BGP Peer Group
I. Create an IBGP peer group
Follow these steps to create an IBGP group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
group ipv6-group-name [ internal ]
Required
Add a peer into the group
peer ipv6-address group ipv6-group-name [ as-number as-number ]
Required
II. Create a pure EBGP peer group
Follow these steps to configure a pure EBGP group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Create an EBGP peer group
group ipv6-group-name external
Required
Configure the AS number for the peer group
peer ipv6-group-name as-number as-number
Required
Add an IPv6 peer into the peer group
Required
&  Note:
l      To create a pure EBGP peer group, you need to specify an AS number for the peer group.
l      If a peer was added into an EBGP peer group, you cannot specify any AS number for the peer group.
III. Create a mixed EBGP peer group
Follow these steps to create a mixed EBGP peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Required
Specify the AS number of an IPv6 peer
Required
Add the IPv6 peer into the peer group
Required
&  Note:
When creating a mixed EBGP peer group, you need to create a peer and specify its AS number that can be different from AS numbers of other peers, but you cannot specify AS number for the EBGP peer group.
5.7.3  Configuring IPv6 BGP Community
I. Advertise community attribute to a peer/peer group
Follow these steps to advertise community attribute to a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
peer { ipv6-group-name | ipv6-address } advertise-community
Required
Not advertised by default
Advertise extended community attribute to a peer/peer group
peer { ipv6-group-name | ipv6-address } advertise-ext-community
Required
II. Apply a routing policy to routes advertised to a peer/peer group
Follow these steps to apply a routing policy to routes advertised to a peer/peer group:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Required
&  Note:
When configuring IPv6 BGP community, you need to configure a routing policy to define the community attribute, and apply the routing policy to route advertisement.
5.7.4  Configuring an IPv6 BGP Route Reflector
Follow these steps to configure an IPv6 BGP route reflector:
To do...
Use the command...
Remarks
Enter system view
Enter BGP view
bgp as-number
Required
ipv6-family
Configure the router as a route reflector and specify a peer/peer group as a client
peer { ipv6-group-name | ipv6-address } reflect-client
Required
Enable route reflection between clients
reflect between-clients
Optional
Enabled by default
 Configure the cluster ID of the route reflector
reflector cluster-id cluster-id
Optional
 By default, a route reflector uses its router ID as the cluster ID
&  Note:
l      In general, since the route reflector forwards routing information between clients, it is not required to make clients of a route reflector fully meshed. If clients are fully meshed, it is recommended to disable route reflection between clients to reduce routing costs.
l      If a cluster has multiple route reflectors, you need to specify the same cluster ID for these route reflectors to avoid routing loops.
5.8  Displaying and Maintaining IPv6 BGP Configuration
5.8.1  Displaying BGP
To do...
Use the command...
Remarks
Display IPv6 BGP peer group information
display bgp ipv6 group [ ipv6-group-name ]
Available in any view
Display IPv6 BGP advertised routing information
display bgp ipv6 network
Display IPv6 BGP AS path information
display bgp ipv6 paths [ as-regular-expression ]
Display IPv6 BGP peer/peer group information
display bgp ipv6 peer [ ipv6-group-name log-info | ipv6-address { log-info | verbose } ]
Display IPv6 BGP routing table information
display bgp ipv6 routing-table [ ipv6-address prefix-length ]
Display IPv6 BGP routing information matching an AS path ACL
display bgp ipv6 routing-table as-path-acl as-path-acl-number
Display IPv6 BGP community routing information
display bgp ipv6 routing-table community [ aa:nn<1-13> ] [ no-advertise | no-export | no-export-subconfed ]* [ whole-match ]
Display IPv6 BGP routing information matching an IPv6 BGP community list
display bgp ipv6 routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
Display dampened IPv6 BGP routing information
display bgp ipv6 routing-table dampened
Display IPv6 BGP dampening parameter information
display bgp ipv6 routing-table dampening parameter
Display IPv6 BGP routing information originated from different ASs
display bgp ipv6 routing-table different-origin-as
Display IPv6 BGP routing flap statistics
display bgp ipv6 routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | network-address [ prefix-length [ longer-match ] ] ]
Display BGP routing information  to or from an IPv4 or IPv6 peer
display bgp ipv6 routing-table peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistic ]
Display IPv6 BGP routing information matching a regular expression
display bgp ipv6 routing-table regular-expression as-regular-expression
Display IPv6 BGP routing statistics
display bgp ipv6 routing-table statistic
5.8.2  Resetting IPv6 BGP Connections
To do...
Use the command...
Remarks
Perform soft reset on IPv6 BGP connections
refresh bgp ipv6 { ipv6-address | all | external | group ipv6-group-name | internal } { export | import }
Reset IPv6 BGP connections
reset bgp ipv6 { as-number | ipv6-address [ flap-info ] | all | group ipv6-group-name | external | internal }
5.8.3  Clearing IPv6 BGP Information
To do...
Use the command...
Remarks
Clear dampened IPv6 BGP routing information and release suppressed routes
reset bgp ipv6 dampening [ ipv6-address prefix-length ]
Clear IPv6 BGP route flap information
reset bgp ipv6 flap-info [ ipv6-address/prefix-length | regexp as-path-regexp | as-path-acl as-path-acl-number ]
5.9  IPv6 BGP Configuration Examples
&  Note:
Some examples for IPv6 BGP configuration are similar to those of BGP-4, so refer to the sections covering BGP in the IPv4 routing part for related information.
5.9.1  IPv6 BGP Basic Configuration
I. Network requirements
In the following figure are all IPv6 BGP switches. Between Switch A and Switch B is an EBGP connection. Switch B, Switch C and Switch D are IBGP fully meshed.
II. Network diagram
Figure 5-1 IPv6 BGP basic configuration network diagram
III. Configuration procedure
2)          Configure IBGP connections
# Configure Switch B.
[SwitchB] ipv6
[SwitchB] bgp 65009
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] ipv6-family
[SwitchB-bgp-af-ipv6] peer 9:1::2 as-number 65009
[SwitchB-bgp-af-ipv6] peer 9:3::2 as-number 65009
[SwitchB-bgp-af-ipv6] quit
[SwitchB-bgp] quit
# Configure Switch C.
[SwitchC] ipv6
[SwitchC] bgp 65009
[SwitchC-bgp] router-id 3.3.3.3
[SwitchC-bgp] ipv6-family
[SwitchC-bgp-af-ipv6] peer 9:3::1 as-number 65009
[SwitchC-bgp-af-ipv6] peer 9:2::2 as-number 65009
[SwitchC-bgp-af-ipv6] quit
[SwitchC-bgp] quit
[SwitchD] ipv6
[SwitchD] bgp 65009
[SwitchD-bgp] router-id 4.4.4.4
[SwitchD-bgp] ipv6-family
[SwitchD-bgp-af-ipv6] peer 9:1::1 as-number 65009
[SwitchD-bgp-af-ipv6] peer 9:2::1 as-number 65009
[SwitchD-bgp-af-ipv6] quit
[SwitchD-bgp] quit
3)         Configure the EBGP connection
# Configure Switch A.
[SwitchA] ipv6
[SwitchA] bgp 65008
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] ipv6-family
[SwitchA-bgp-af-ipv6] peer 10::1 as-number 65009
[SwitchA-bgp-af-ipv6] quit
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp-af-ipv6] peer 10::2 as-number 65008
# Display IPv6 peer information on Switch B.
[SwitchB] display bgp ipv6 peer
 BGP local router ID : 2.2.2.2
 Local AS number : 65009
 Total number of peers : 3                 Peers in established state : 3
  Peer       V    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  10::2      4 65008        3        3     0       0 00:01:16 Established
  9:3::2     4 65009        2        3     0       0 00:00:40 Established
  9:1::2     4 65009        2        4     0       0 00:00:19 Established
# Display IPv6 peer information on Switch C.
[SwitchC] display bgp ipv6 peer
 BGP local router ID : 3.3.3.3
 Total number of peers : 2                 Peers in established state : 2
  9:3::1     4 65009        4        4     0       0 00:02:18 Established
  9:2::2     4 65009        4        5     0       0 00:01:52 Established
Switch A and B established an EBGP connection; Switch B, C and D established IBGP connections with each other.
5.9.2  IPv6 BGP Route Reflector Configuration
Switch B receives an EBGP update and sends it to Switch C, which is configured as a route reflector with two clients: Switch B and Switch D.
Switch B and Switch D need not establish an IBGP connection because Switch C reflects updates between them.
II. Network diagram
Figure 5-2 Network diagram for IPv6 BGP route reflector configuration
1)         Configure IPv6 addresses for VLAN interfaces (omitted)
2)         Configure IPv6 BGP basic functions
[SwitchA] ipv6
[SwitchA] bgp 100
[SwitchA-bgp-af-ipv6] peer 100::2 as-number 200
[SwitchA-bgp-af-ipv6] network 1:: 64
#Configure Switch B.
[SwitchB] ipv6
[SwitchB] bgp 200
[SwitchB-bgp-af-ipv6] peer 100::1 as-number 100
[SwitchB-bgp-af-ipv6] peer 101::1 as-number 200
[SwitchB-bgp-af-ipv6] peer 101::1 next-hop-local
[SwitchC] ipv6
[SwitchC] bgp 200
[SwitchC-bgp-af-ipv6] peer 101::2 as-number 200
[SwitchC-bgp-af-ipv6] peer 102::2 as-number 200
[SwitchD] ipv6
[SwitchD] bgp 200
[SwitchD-bgp-af-ipv6] peer 102::1 as-number 200
3)         Configure route reflector
# Configure Switch C as a route reflector, Switch B and Switch D as its clients.
[SwitchC-bgp-af-ipv6] peer 101::2 reflect-client
[SwitchC-bgp-af-ipv6] peer 102::2 reflect-client
Use the display bgp ipv6 routing-table command on Switch B and Switch D respectively, you can find both of them have learned the network 1::/64.
5.10  Troubleshooting IPv6 BGP Configuration
5.10.1  No IPv6 BGP Peer Relationship Established
I. Symptom
Display BGP peer information using the display bgp ipv6 peer command. The state of the connection to the peer cannot become established.
II. Analysis
To become IPv6 BGP peers, any two routers need to establish a TCP session using port 179 and exchange open messages successfully.
III. Processing steps
1)         Use the display current-configuration command to verify the peer’s AS number.
2)         Use the display bgp ipv6 peer command to verify the peer’s IPv6 address.
3)         If the loopback interface is used, check whether the peer connect-interface command is configured.
4)         If the peer is not directly connected, check whether the peer ebgp-max-hop command is configured.
5)         Check whether a route to the peer is available in the routing table.
6)         Use the ping command to check connectivity.
7)         Use the display tcp ipv6 status command to check the TCP connection.
8)         Check whether an ACL for disabling TCP port 179 is configured.
Chapter 6  Routing Policy Configuration
l      Verify that the system already operates in IPv4/IPv6 dual-stack mode before configuring IPv6 routing policy.
l      All the IPv6 routing policy related configuration mentioned in this manual assumes that the system already operates in IPv4/IPv6 dual-stack mode. For dual stack mode configuration, see the part covering dual stack in the IPv6 Configuration module.
6.1  Introduction to Routing Policy
6.1.1  Routing Policy
A routing policy is used on the router for route inspection, filtering, attributes modifying when routes are received, advertised, or redistributed.
When distributing or receiving routing information, a router can use a routing policy to filter routing information. For example, a router receives or advertises only routing information that matches the criteria of a routing policy; a routing protocol redistributes routes from another protocol only routes matching the criteria of a routing policy and modifies some attributes of these routes to satisfy its needs using the routing policy.
To implement a routing policy, you need to define a set of match criteria according to attributes in routing information, such as destination address, advertising router’s address and so on. The match criteria can be set beforehand and then apply them to a routing policy for route distribution, reception and redistribution.
6.1.2  Filters
Routing protocols can use six filters: ACL, IP prefix list, AS path ACL, community list, extended community list and routing policy.
I. ACL
When defining an ACL, you can specify IP addresses and prefixes to match destinations or next hops of routing information.
For ACL configuration, refer to the part discussing ACL operation.
II. IP prefix list
IP prefix list plays a role similar to ACL, but it is more flexible than ACL and easier to understand. When an IP prefix list is applied to filtering routing information, its matching object is the destination address of routing information.
An IP prefix list is identified by name. Each IP prefix list can comprise multiple items, and each item, which is identified by an index number, can specify a matching range in the network prefix format. The index number indicates the matching sequence of items in the IP prefix list.
During matching, the router compares the packet with the items in the ascending order. If one item is matched, the IP prefix list filter is passed, and the packet will not go to the next item.
III. AS-path
AS path is only applicable to IPv6 BGP. There is an AS-path field in the IPv6 BGP packet. An AS path list specifies matching conditions according to the AS-path field.
IV. Community list
Community list only applies to IPv6 BGP. The IPv6 BGP packet contains a community attribute field to identify a community. A community list specifies matching conditions based on the community attribute.
V. Extended community list
Extended community list (extcommunity-list) applies to IPv6 BGP only. It is used for Route-Target extcommunity for VPN.
VI. Routing policy
A routing policy is used to match against some attributes in given routing information and modify the attributes of the information if match conditions are satisfied. It can reference the above mentioned filters to define its own match criteria.
A routing policy can comprise multiple nodes, which are in logic OR relationship. Each node is a match unit, and the system compares each node to a packet in the order of node sequence number. Once a node is matched, the routing policy is passed and the packet will not go through the next node.
Each node comprises a set of if-match and apply clauses. The if-match clauses define the match criteria. The matching objects are some attributes of routing information. The different if-match clauses on a node is in logical AND relationship. Only when the matching conditions specified by all the if-match clauses on the node are satisfied, can routing information pass the node. The apply clauses specify the actions to be performed after the node is passed, concerning the attribute settings for routing information.
6.1.3  Routing Policy Application
A routing policy is applied in two ways:
l           When redistributing routes from other routing protocols, a routing protocol accepts only routes passing the routing policy.
l           When receiving or advertising routing information, a routing protocol uses the routing policy to filter routing information.
6.2  Defining Filtering Lists
6.2.1  Prerequisites
Before configuring this task, you need to decide on:
l           IP-prefix list name
l           Matching address range
l           Extcommunity list sequence number
6.2.2  Defining an IPv6 Prefix List
Identified by name, each IPv6 prefix list can comprise multiple items. Each item specifies a matching address range in the form of network prefix, which is identified by index number.
During matching, the system compares the route to each item in the ascending order of index number. If one item is matched, the route passes the IP-prefix list, without needing to match the next item.
Follow these steps to define an IPv6 prefix list:
To do...
Use the command...
Remarks
Enter system view
Define an IPv6 prefix list
ip ipv6-prefix ipv6-prefix-name [ index index-number ] { deny | permit } ipv6-address prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ]
Required
Not defined by default
&  Note:
If all items are set to the deny mode, no routes can pass the IPv6 prefix list. Therefore, you need to define the permit :: 0 less-equal 128 item following multiple deny mode items to allow other IPv6 routing information to pass.
For example, the following configuration filters routes 2000:1::/48, 2000:2::/48 and 2000:3::/48, but allows other routes to pass.
[Sysname] ip ipv6-prefix abc index 10 deny 2000:1:: 48
[Sysname] ip ipv6-prefix abc index 20 deny 2000:2:: 48
[Sysname] ip ipv6-prefix abc index 30 deny 2000:3:: 48
[Sysname] ip ipv6-prefix abc index 40 permit :: 0 less-equal 128
6.2.3  Defining an AS Path List
You can define multiple items for an AS path ACL that is identified by number. During matching, the relation between items is logical OR, that is, if the route matches one of these items, it passes the AS path ACL.
Follow these steps to define an AS path ACL:
To do...
Use the command...
Remarks
Enter system view
Define an AS path ACL
ip as-path as-path-number { deny | permit } regular-expression
Required
6.2.4  Defining a Community List
You can define multiple items for a community list that is identified by number. During matching, the relation between items is logic OR, that is, if routing information matches one of these items, it passes the community list.
Follow these steps to define a community list:
To do...
Use the command...
Remarks
Enter system view
Define a community list
Define a basic community list
ip community-list basic-comm-list-num { deny | permit } [ community-number-list ] [ internet | no-advertise | no-export | no-export-subconfed ] *
Required to define either;
Define an advanced community list
ip community-list adv-comm-list-num { deny | permit } regular-expression
6.2.5  Defining an Extended Community List
You can define multiple items for an extended community list that is identified by number. During matching, the relation between items is logic OR, that is, if routing information matches one of these items, it passes the extended community list.
Follow these steps to define an extended community list:
To do...
Use the command...
Remarks
Enter system view
Define an extended community list
ip extcommunity-list ext-comm-list-number { deny | permit } { rt route-target }&<1-16>
Required
6.3  Configuring a Routing Policy
A routing policy is used to filter routing information according to some attributes, and modify some attributes of the routing information that matches the routing policy. Match criteria can be configured using filters above mentioned.
A routing policy can comprise multiple nodes, each node contains:
l           if-match clauses: Define the match criteria that routing information must satisfy. The matching objects are some attributes of routing information.
l           apply clauses: Specify the actions performed after specified match criteria are satisfied, concerning attribute settings for passed routing information.
6.3.1  Prerequisites
Before configuring this task, you have completed:
l           Filtering list configuration
l           Routing protocol configuration
You also need to decide on:
l           Name of the routing policy, node sequence numbers
l           Match criteria
l           Attributes to be modified
6.3.2  Creating a Routing Policy
Follow these steps to create a routing policy:
To do...
Use the command...
Remarks
Enter system view
Create a routing policy and enter its view
route-policy route-policy-name { permit | deny } node node-number
Required
&  Note:
l      If a node has the permit keyword specified, routing information meeting the node’s conditions will be handled using the apply clauses of this node, without needing to match against the next node. If routing information does not meet the node’s conditions, it will go to the next node for a match.
l      If a node is specified as deny, the apply clauses of the node will not be executed. When routing information matches all if-match clauses of the node, it can neither pass the node, nor go to the next node. If route information cannot match any if-match clause of the node, it will go to the next node for a match.
l      When a routing policy is defined with more than one node, at least one node should be configured with the permit keyword. If the routing policy is used to filter routing information, routing information that does not meet any node’s conditions cannot pass the routing policy. If all nodes of the routing policy are set using the deny keyword, no routing information can pass it.
6.3.3  Defining if-match Clauses for the Routing Policy
Follow these steps to define if-match clauses for a route-policy:
To do...
Use the command...
Remarks
Enter system view
Enter routing policy view
Required
Match IPv6 routes having the next hop or source specified in the ACL or IP prefix list
if-match ipv6 { address | next-hop | route-source } { acl acl-number | prefix-list ipv6-prefix-name }
Optional
Not configured by default
Match IPv6 BGP routes having AS path attributes specified in the AS path list (s)
if-match as-path as-path-number&<1-16>
Optional
Match IPv6 BGP routes having community attributes in the specified community list(s)
if-match community { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
Optional
Match routes having the specified cost
if-match cost value
Optional
Match BGP routes having extended attributes contained in the extended community list(s)
if-match extcommunity ext-comm-list-number&<1-16>
Optional
Match routes having specified outbound interface(s)
Optional
Match routes having the specified route type
if-match route-type { internal | external-type1 | external-type2 | external-type1or2 | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type2 | nssa-external-type1or2 } *
Optional
Match the routes having the specified tag value
if-match tag value
Optional
&  Note:
l      The if-match clauses of a route-policy are in logic AND relationship, namely, routing information has to satisfy all if-match clauses before being executed with apply clauses.
l      You can specify no or multiple if-match clauses for a routing policy. If no if-match clause is specified, and the routing policy is in permit mode, all routing information can pass the node; if in deny mode, no routing information can pass.
l      A routing policy should use a non VPN ACL for filtering.
6.3.4  Defining apply Clauses for the Routing Policy
Follow these steps to define apply clauses for a route-policy:
To do...
Use the command...
Remarks
Enter system view
Required
Not created by default
Set AS_Path attribute for IPv6 BGP routes
apply as-path as-number&<1-10> [ replace ]
Optional
Not set by default
Specify a community list according to which to delete community attributes of IPv6 BGP routing information
apply comm-list comm-list-number delete
Optional
Set community attribute for IPv6 BGP routes
apply community { none | additive | { community-number&<1-16> | aa:nn&<1-16> | internet | no-export-subconfed | no-export | no-advertise } * [ additive ] }
Optional
Not set by default
Set a cost for routes
apply cost [ + | - ] value
Optional
Not set by default
Set a cost type for routes
apply cost-type { external | internal | type-1 | type-2 }
Optional
Not set by default
Set the extended community attribute for IPv6 BGP routes
apply extcommunity { rt { as-number:nn | ip-address:nn } }&<1-16> [ additive ]
Optional
Not set by default
Set a next hop for IPv6 routes
Optional
Not set by default
Redistribute routes to a specified ISIS level
Optional
Set a local preference for IPv6 BGP routes
Optional
Not set by default
Set an origin attribute for IPv6 BGP routes
apply origin { igp | egp as-number | incomplete }
Optional
Not set by default
Set a preference for the matched routing protocol
apply preference preference
Optional
Not set by default
Set a preferred value for IPv6 BGP routes
Optional
Not set by default
Set a tag value for the routes
apply tag value
Optional
Not set by default
&  Note:
The apply ipv6 next-hop commands do not apply to redistributed IPv6 routes respectively.
6.4  Displaying and Maintaining the Routing Policy
To do...
Use the command...
Remarks
Display IPv6 BGP AS path ACL information
display ip as-path [ as-path-number ]
Display IPv6 BGP community list information
display ip community-list [ basic-community-list-number | adv-community-list-number ]
Display IPv6 BGP extended community list information
Display IPv6 prefix list statistics
display ip ipv6-prefix [ ipv6-prefix-name ]
Display routing policy information
display route-policy [ route-policy-name ]
Clear IPv6 prefix statistics
reset ip ipv6-prefix [ ipv6-prefix-name ]
6.5  Routing Policy Configuration Example
6.5.1  Applying Routing Policy When Redistributing IPv6 Routes
l           Enable RIPng on Switch A and Switch B.
l           Configure three static routes on Switch A and apply a routing policy when redistributing static routes, making routes 20::0/32 and 40::0/32 pass, routes in 30::0/32 filtered out.
l           Display RIPng routing table information on Switch B to verify the configuration.
II. Network diagram
Figure 6-1 Network diagram for routing policy application to route redistribution
1)         Configure Switch A
# Configure IPv6 addresses for VLAN-interface 100 and VLAN-interface 200.
[SwitchA] ipv6
[SwitchA-Vlan-interface100] ipv6 address 10::1 32
[SwitchA-Vlan-interface200] ipv6 address 11::1 32
# Enable RIPng on VLAN-interface 100.
[SwitchA-Vlan-interface100] ripng 1 enable
# Configure three static routes.
[SwitchA] ipv6 route-static 20:: 32 11::2
[SwitchA] ipv6 route-static 30:: 32 11::2
[SwitchA] ipv6 route-static 40:: 32 11::2
# Configure routing policy.
[SwitchA] ip ipv6-prefix a index 10 permit 30:: 32
[SwitchA] route-policy static2ripng deny node 0
[SwitchA-route-policy] if-match ipv6 address prefix-list a
[SwitchA-route-policy] quit
[SwitchA] route-policy static2ripng permit node 10
# Enable RIPng and redistribute static routes.
[SwitchA] ripng
[SwitchA-ripng-1] import-route static route-policy static2ripng
2)         Configure Switch B.
# Configure the IPv6 address for VLAN-interface 100.
[SwitchB] ipv6
[SwitchB-Vlan-interface100] ipv6 address 10::2 32
[SwitchB-Vlan-interface100] ripng 1 enable
# Enable RIPng.
[SwitchB] ripng
# Display RIPng routing table information.
[SwitchB-ripng-1] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::7D58:0:CA03:1  on Vlan-interface 100
 Dest 10::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 18 Sec
 Dest 20::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 8 Sec
 Dest 40::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 3 Sec
6.6  Troubleshooting Routing Policy Configuration
6.6.1  IPv4 Routing Information Filtering Failure
I. Symptom
Filtering routing information failed, while routing protocol runs normally.
II. Analysis
At least one item of the IP prefix list should be configured as permit mode, and at least one node in the Route-policy should be configured as permit mode.
III. Processing procedure
1)         Use the display ip ip-prefix command to display IP prefix list information.
2)         Use the display route-policy command to display routing policy information.
6.6.2  IPv6 Routing Information Filtering Failure
I. Symptom
II. Analysis
At least one item of the IPv6 prefix list should be configured as permit mode, and at least one node of the Route-policy should be configured as permit mode.
1)         Use the display ip ipv6-prefix command to display IP prefix list information.
