H3C S9500 Series Routing Switches Operation Manual-(V1.01)
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Series Routing Switches Operation Manual-(V1.01)
11-Reliability Operation
11-Reliability Operation 128 KB
Chapter 1  VRRP Configuration
1.1  Introduction to VRRP
Virtual Router Redundancy Protocol (VRRP) is a fault-tolerant protocol. In general, a default route (for example, 10.100.10.1 as shown in the following internetworking diagram) will be configured for every host on a network, so that the packets destined to some other network segment from the host will go through the default route to the Layer 3 Switch, implementing communication between the host and the external network. If Switch is down, all the hosts on this segment taking Switch as the next-hop on the default route will be disconnected from the external network.
Figure 1-1 Network diagram for LAN
VRRP, designed for LANs with multicast and broadcast capabilities (such as Ethernet) settles the above problem. The diagram below is taken as an example to explain the implementation principal of VRRP. VRRP combines a group of LAN switches (including a Master and several Backups) into a virtual router.
Figure 1-2 Network diagram for virtual router
This virtual router has its own IP address: 10.100.10.1 (which can be the interface address of a switch within the virtual router). The switches within the virtual router have their own IP addresses (such as 10.100.10.2 for the Master switch and 10.100.10.3 for the Backup switch). The host on the LAN only knows the IP address of this virtual router 10.100.10.1 (usually called as virtual IP address of virtual router), but not the specific IP addresses 10.100.10.2 of the Master switch and 10.100.10.3 of the Backup switch. They configure their own default routes as the IP address of this virtual router: 10.100.10.1. Therefore, hosts within the network will communicate with the external network through this virtual router. If a Master switch in the virtual group breaks down, another Backup switch will function as the new Master switch to continue serving the host with routing to avoid interrupting the communication between the host and the external networks.
1.2  Configuring VRRP
The following sections describe the VRRP configuration tasks:
l           Enabling/Disabling the Function to Ping the Virtual IP Address
l           Enabling/Disabling the Check of TTL Value of VRRP Packet
l           Setting Correspondence between Virtual IP Address and MAC Address
l           Adding/Deleting a Virtual IP Address
l           Configuring the Priority of Switches in the Virtual Router
l           Configuring Preemption and Delay for a Switch within a Virtual Router
l           Configuring Authentication Type and Authentication Key
l           Configuring Virtual Router Timer
l           Configuring Switch to Track a Specified Interface
1.2.1  Enabling/Disabling the Function to Ping the Virtual IP Address
This operation enables or disables the function to ping the virtual IP address of the virtual router. The standard protocol of VRRP does not support the ping function, then the user cannot judge with ping command whether an IP address is used by the virtual router. If the user configure the IP address for the host same as the virtual IP address of the virtual router, then all messages in this segment will be forwarded to the host.
So H3C S9500 Series Routing Switches (hereinafter referred to as S9500 series) provide the ping function to ping the virtual IP address of the virtual router.
Perform the following configuration in system view.
Table 1-1 Enable/disable the ping function
Operation
Enable to ping the virtual IP address
vrrp ping-enable
Disable to ping the virtual IP address
undo vrrp ping-enable
By default, the function to ping the virtual IP address is disabled.
You should set the ping function before configuring the virtual router. If a virtual router is already established on the switch, it is not allowed to use the vrrp ping-enable command and the undo vrrp ping-enable command to modify the configuration any more.
1.2.2  Enabling/Disabling the Check of TTL Value of VRRP Packet
This operation configures whether to check TTL value of VRRP packet on the Backup switch. The TTL value must be 225. If the Backup switch find TTL is not 225 when receiving VRRP packet, the packet will be discarded.
Perform the following configuration in VLAN interface view.
Table 1-2 Enable/disable the check of TTL value of VRRP packet
Operation
Disable the check of TTL value of VRRP packet
vrrp un-check ttl
Enable the check of TTL value of VRRP packet
undo vrrp un-check ttl
By default, the switch checks TTL value of VRRP packets.
1.2.3  Setting Correspondence between Virtual IP Address and MAC Address
This operation sets correspondence between the virtual lP address and the MAC address. In the standard protocol of VRRP, the virtual IP address of the virtual router corresponds to the virtual MAC address, to ensure correct data forwarding in the sub-net.
Due to the chips installed, some switches support matching one IP address to multiple MAC addresses.
S9500 series not only guarantee correct data forwarding in the sub-net, but also support such function: the user can choose to match the virtual IP address with the real MAC address or virtual MAC address of the routing interface.
The following commands can be used to set correspondence between the IP address and the MAC address.
Table 1-3 Set correspondence between virtual IP address and MAC address
Operation
Set correspondence between the virtual IP address and the MAC address
vrrp method { real-mac | virtual-mac }
Set the correspondence to the default value
undo vrrp method
By default, the virtual IP address of the virtual router corresponds to the virtual MAC address.
You should set correspondence between the virtual IP address of the virtual router and the MAC address before configuring the virtual router. Otherwise, you cannot configure the correspondence.
If you set correspondence between the IP address of the virtual router and the real MAC address, you can configure only one virtual router on VLAN interface.
1.2.4  Adding/Deleting a Virtual IP Address
The following command is used for assigning a virtual IP address of the local segment to a virtual router or removing an assigned virtual IP address of a virtual router from the virtual address list.
Table 1-4 Add/delete a virtual IP address
Operation
Add a virtual IP address
vrrp vrid virtual-router-ID virtual-ip virtual-address
Delete a virtual IP address
undo vrrp vrid virtual-router-ID [ virtual-ip virtual-address ]
The virtual-router-ID covers the range from 1 to 255.
The virtual-address can be an unused address in the network segment where the virtual router resides, or the IP address of an interface in the virtual router. If the IP address is of the switch in the virtual router, it can also be configured as virtual-address. In this case, the switch will be called an IP Address Owner. When adding the first IP address to a virtual router, the system will create a new virtual router accordingly. When adding a new address to this virtual router thereafter, the system will directly add it into the virtual IP address list.
After the last virtual IP address is removed from the virtual router, the whole virtual router will also be removed. That is, there is no more virtual router on the interface any more and any configuration of it is invalid accordingly.
1.2.5  Configuring the Priority of Switches in the Virtual Router
The status of each switch in the virtual router will be determined by its priority in VRRP. The switch with the highest priority will become the Master.
Table 1-5 Configure the priority of switches in the virtual router.
Operation
vrrp vrid virtual-router-ID priority priority
Clear the priority of switches in the virtual router.
undo vrrp vrid virtual-router-ID priority
The priority ranges from 0 to 255. The greater the number, the higher the priority. However the value can only be taken from 1 to 254. The priority 0 is reserved for special use and 255 is reserved for the IP address owner by the system.
By default, the priority is 100.
&  Note:
The priority for IP address owner is always 255, which cannot be configured otherwise.
1.2.6  Configuring Preemption and Delay for a Switch within a Virtual Router
Once a switch in the virtual router becomes the Master switch, so long as it still functions properly, other switches, even configured with a higher priority later, cannot become the Master switch unless they are configured to work in preemption mode. The switch in preemption mode will become the Master switch, when it finds its own priority is higher than that of the current Master switch. Accordingly, the former Master switch will become the Backup switch.
Together with preemption settings, a delay can also be set. In this way, a Backup will wait for a period of time before becoming a Master. In an unstable network if the Backup switch has not received the packets from the Master switch punctually, it will become the Master switch. However, the failure of Backup to receive the packets may be due to network congestion, instead of the malfunction of the Master switch. In this case, the Backup will receive the packet after a while. The delay settings can thereby avoid the frequent status changing.
Table 1-6 Configure preemption and delay for a switch within a virtual router
Operation
Enable the preemption mode and configure a period of delay.
vrrp vrid virtual-router-ID preempt-mode [ timer delay delay-value ]
Disable the preemption mode.
undo vrrp vrid virtual-router-ID preempt-mode
The delay ranges from 0 to 255, measured in seconds. By default, the preemption mode is preemption with a delay of 0 second.
&  Note:
If preemption mode is cancelled, the delay time will automatically become 0 second.
1.2.7  Configuring Authentication Type and Authentication Key
VRRP provides following authentication types:
l           simple: Simple character authentication
l           md5: MD5 authentication
In a network under possible security threat, the authentication type can be set to simple. Then the switch will add the authentication key into the VRRP packets before transmitting it. The receiver will compare the authentication key of the packet with the locally configured one. If they are the same, the packet will be taken as a true and legal one. Otherwise it will be regarded as an illegal packet to be discarded. In this case, an authentication key not exceeding 8 characters should be configured.
In a totally unsafe network, the authentication type can be set to md5. The switch will use the authentication type and MD5 algorithm provided by the Authentication Header to authenticate the VRRP packets. In this case an authentication key not exceeding 8 characters should be configured.
Those packets failing to pass the authentication will be discarded and a trap packet will be sent to the network management system.
Table 1-7 Configure authentication type and authentication key
Operation
vrrp authentication-mode authentication-type authentication-key
Remove authentication type and authentication key
undo vrrp authentication-mode
The authentication key is case sensitive.
&  Note:
The same authentication type and authentication key should be configured for all VLAN interfaces that belong to the virtual router.
1.2.8  Configuring Virtual Router Timer
The Master switch advertises its normal operation state to the switches within the VRRP virtual router by sending them VRRP packets regularly (at adver-interval). And the backup switch only receives VRRP packets. If the Backup has not received any VRRP packet from the Master after a period of time (specified by master-down-interval), it will consider the Master as down, and then take its place and become the Master.
You can use the following command to set a timer and adjust the interval, adver-interval, between Master transmits VRRP packets. The master-down-interval of the Backup switch is three times that of the adver-interval. The excessive network traffic or the differences between different switch timers will result in master-down-interval timing out and state changing abnormally. Such problems can be solved through prolonging the adver-interval and setting delay time. adver-interval is measured in seconds.
Table 1-8 Configure virtual router timer
Operation
vrrp vrid virtual-router-ID timer advertise adver-interval
Clear virtual router timer
undo vrrp vrid virtual-router-ID timer advertise
By default, adver-interval is configured to be 1.
1.2.9  Configuring Switch to Track a Specified Interface
VRRP interface track function has expanded the backup function. Backup is provided not only to the interface where the virtual router resides, but also to some other malfunctioning switch interface. By implementing the following command you can track some interface.
If the interface which is tracked is Down, the priority of the switch including the interface will reduce automatically by the value specified by value-reduced, thus resulting in comparatively higher priorities of other switches within the virtual router, one of which will turn to Master switch so as to track this interface.
Table 1-9 Configure switch to track a specified interface
Operation
Configure the switch to track a specified interface
vrrp vrid virtual-router-ID track vlan-interface interface-number [ reduced value-reduced ]
Stop tracking the specified interface
undo vrrp vrid virtual-router-ID track [ vlan-interface interface-number ]
By default, value-reduced is taken 10.
&  Note:
l      When the switch is an IP address owner, its interfaces cannot be tracked.
l      If the interface tracked is up again, the corresponding priority of the switch, including the interface, will be restored automatically
l      You can only track up to eight interfaces in one virtual router.
1.3  Displaying and debugging VRRP
After the above configuration, execute display command in any view to display the running of the VRRP configuration, and to verify the configuration. Execute debugging command in user view to debug VRRP configuration.
Table 1-10 Display and debug VRRP
Operation
Display VRRP state information
display vrrp [ interface vlan-interface interface-number [ virtual-router-ID ] ]
Display VRRP statistics information
display vrrp statistics [ vlan-interface interface-number [ virtual-router-ID ]
Display VRRP summary information
display vrrp summary
Clear the statistics information about VRRP
reset vrrp statistics [ vlan-interface interface-number [ virtual-router-ID ] ]
Enable VRRP debugging.
debugging vrrp { state | packet | error }
Disable VRRP debugging.
undo debugging vrrp { state | packet | error }
You can enable VRRP debugging to check its running. You may choose to enable VRRP packet debugging (option as packet), VRRP state debugging (option as state), and/or VRRP error debugging (option as error). By default, VRRP debugging is disabled.
1.4  VRRP Configuration Example
1.4.1  VRRP Single Virtual Router Example
I. Networking requirements
Host A uses the VRRP virtual router which combines switch A and switch B as its default gateway to access host B on the Internet.
VRRP virtual router information includes: virtual router ID1, virtual IP address 202.38.160.111, switch A as the Master and switch B as the Backup allowed preemption.
II. Networking diagram
Figure 1-3 Network diagram for VRRP configuration
III. Configuration Procedure
Configure switch A
# Configure VLAN 2.
[LSW-A] vlan 2
[LSW-A-vlan2] interface vlan 2
[LSW-A-vlan-interface2] ip address 202.38.160.1 255.255.255.0
[LSW-A-vlan-interface2] quit
# Configure VRRP.
[LSW-A] vrrp ping-enable
[LSW-A] interface vlan 2
[LSW_A-vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
[LSW_A-vlan-interface2] vrrp vrid 1 priority 110
[LSW-A-vlan-interface2] vrrp vrid 1 preempt-mode
Configure switch B
# Configure VLAN2.
[LSW-B] vlan 2
[LSW-B-vlan2] interface vlan 2
[LSW-B-vlan-interface2] ip address 202.38.160.2 255.255.255.0
[LSW-B-vlan-interface2] quit
# Configure VRRP.
[LSW-B] vrrp ping-enable
[LSW-B] interface vlan 2
[LSW-B-vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
[LSW-B-vlan-interface2] vrrp vrid 1 preempt-mode
The virtual router can be used soon after configuration. Host A can configure the default gateway as 202.38.160.111.
Under normal conditions, switch A functions as the gateway, but when switch A is turned off or malfunctioning, switch B will function as the gateway instead.
Configure preemption mode for switch A, so that it can resume its gateway function as the Master after recovery.
1.4.2  VRRP Tracking Interface Example
Even when switch A is still functioning, it may want switch B to function as gateway when the Internet interface connected with it does not function properly. This can be implemented by configuration of tracking interface.
In simple language, the virtual router ID is set as 1 with additional configurations of authorization key and timer.
See Figure 1-3.
Configure switch A
# Configure VLAN2.
[LSW-A] vlan 2
# Enable the function to ping the virtual IP address of virtual router.
[LSW-A ] vrrp ping-enable
# Create a virtual router.
# Set the priority for the virtual router.
# Set the authentication key for the virtual router.
[LSW_A-vlan-interface2] vrrp authentication-mode md5 switch
# Set Master to send VRRP packets every 5 seconds.
[LSW_A-vlan-interface2] vrrp vrid 1 timer advertise 5
# Track an interface.
[LSW_A-vlan-interface2] vrrp vrid 1 track vlan-interface 3 reduced 30
Configure switch B
# Configure VLAN2.
[LSW-B] vlan 2
[LSW_B-vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
[LSW_B-vlan-interface2] vrrp authentication-mode md5 switch
[LSW_B-vlan-interface2] vrrp vrid 1 timer advertise 5
Under normal conditions, switch A functions as the gateway, but when the interface vlan-interface 3 of switch A is down, its priority will be reduced by 30, lower than that of switch B so that switch B will preempt the Master for gateway services instead.
When vlan-interface3, the interface of switch A, recovers, this switch will resume its gateway function as the Master.
1.4.3  Multiple Virtual Routers Example
A Switch can function as the backup switch for many virtual routers.
Such a multi-backup configuration can implement load balancing. For example, switch A as the Master switch of virtual router 1 can share the responsibility of the backup switch for virtual router 2 and vice versa for switch B. Some hosts employ virtual router 1 as the gateway, while others employ virtual router 2 as the gateway. In this way, both load balancing and mutual backup are implemented.
Refer to Figure 1-3.
Configure switch A
# Configure VLAN2.
[LSW-A] vlan 2
# Create virtual router 1.
[LSW_A-vlan-interface2] vrrp vrid 1 priority 150
# Create virtual router 2.
[LSW_A-vlan-interface2] vrrp vrid 2 virtual-ip 202.38.160.112
Configure switch B
# Configure VLAN2.
[LSW-B] vlan 2
[LSW_B-vlan-interface2] vrrp vrid 2 virtual-ip 202.38.160.112
[LSW_B-vlan-interface2] vrrp vrid 2 priority 110
&  Note:
Multiple virtual routers are often used in actual network applications.
1.5  Troubleshooting VRRP
As the configuration of VRRP is not very complicated, almost all the malfunctions can be found through viewing the configuration and debugging information. Here are some possible failures you might meet and the corresponding troubleshooting methods.
I. Fault 1: Frequent prompts of configuration errors on the console
This indicates that an incorrect VRRP packet has been received. It may be because of the inconsistent configuration of another switch within the virtual router, or the attempt of some devices to send out illegal VRRP packets. The first possible fault can be solved through modifying the configuration. And as the second possibility is caused by the malicious attempt of some devices, non-technical measures should be resorted to.
II. Fault 2: More than one Masters existing within the same virtual router
There are also 2 reasons. One is short time coexistence of many Master switches, which is normal and needs no manual intervention. Another is the long time coexistence of many Master switches, which may be because switches in the virtual router cannot receive VRRP packets from each other, or receive some illegal packets.
To solve such problems, an attempt should be made to ping among the many Master switches, and if such an attempt fails, check the device connectivity. If they can be pinged, check the VRRP configuration. For the configuration of the same VRRP virtual router, complete consistence for the number of virtual IP addresses, each virtual IP address, timer duration and authentication type must be guaranteed.
III. Fault 3: Frequent switchover of VRRP state
Such problem occurs when the virtual router timer duration is set too short. So the problem can be solved through prolonging this duration or configuring the preemption delay.
Chapter 2  HA Configuration
2.1  Introduction to HA
HA (high availability) is to achieve a high availability of the system and to recover the system as soon as possible in the event of SRPU failures so as to shorten the MTBF (Mean Time Between Failure) of the system.
The functions of HA are mainly implemented by the application running on master and slave boards. The two boards are working in the master-slave mode: one board works in master mode, the other work in slave mode. If the master-slave system detects a fault in the master board, a hot master-slave switchover will be performed automatically. The slave board will try to connect and control the system bus while the original master board will try to disconnect from the bus. Thus, the master-slave switchover of the active system is completed, and at the same time the original master board is reset to recover as soon as possible and then function as the slave board. Even if the master board fails, the slave board can also take its role to ensure the normal operation, and the system can recover as soon as possible.
S9500 series support hot swap of master and slave boards. The hot swap of master boards will cause master-slave switchover.
S9500 series support manual master-slave switchover. You can change the current board state manually by executing command.
The configuration file of slave is copied from master board at the same time. This can ensure that the slave system continues to operate in the same configuration as that of the original active system after the slave system has taken place of the active system. S9500 series support automatic synchronization. The active system stores its configuration file and backup the configuration file to the slave system simultaneously when the master's configuration file is modified, ensuring the consistency of the configurations of the active system and slave system.
Besides, the system can monitor the power supply and the working environment of the system and give timely alarms to avoid the escalation of failures and ensure safe operations of the system.
  Caution:
The S9500 active and standby boards must both be in position and run the same version of program. Otherwise, the switch cannot operate normally.
2.2  Configuring HA
The following sections describe the HA configuration tasks:
l           Restarting the Slave System Manually
l           Starting the Master-Slave Switchover Manually
l           Enabling/Disabling Automatic Synchronization
l           Synchronizing the Configuration File Manually
l           Configuring the Load Mode of the
2.2.1  Restarting the Slave System Manually
In the environment in which the slave system is available, the user can restart the slave system manually.
Perform the following configuration in user view.
Table 2-1 Restart the slave system manually
Operation
slave restart
2.2.2  Starting the Master-Slave Switchover Manually
In the environment in which the slave board is available and master in real-time backup state, the user can inform the slave board of a master-slave switchover by using a command if he expects the slave board to operate in place of the master board. After the switchover, the slave board will control the system and the original master board will be forced to reset.
Table 2-2 Start the master-slave switchover manually
Operation
slave switchover
The switchover manually will be ineffective if user set the system forbid master-slave switchover manually.
2.2.3  Enabling/Disabling Automatic Synchronization
You can enable/disable automatic synchronize of S9500 series.
Table 2-3 Enable/Disable automatic synchronization
Operation
Enable automatic synchronization
slave auto-update config
undo slave auto-update config
By default, the automatic synchronization of system is enabled.
2.2.4  Synchronizing the Configuration File Manually
Although the system can perform the synchronization automatically, the synchronization can occur only when the master board saves its configuration file. If the user expects to determine the backup of the configuration file by himself, he can do it manually to backup the configuration file saved in the master board.
Table 2-4 Synchronize the configuration file manually
Operation
slave update configuration
This operation can backup the configuration file to the slave board only if a slave system is available. The configuration file will be fully copied once at every time the operation is executed.
2.2.5  Configuring the Load Mode of the Master and Slave boards
S9500 series support two kinds of load modes (balance and single) between the master and slave boards. You can use the xbar command to configure XBar (cross bar) load mode.
Table 2-5 Configure the XBar load mode
Operation
Configure the load mode of the master and slave boards
xbar [ load-balance | load-single ]
By default, the load mode of the master and slave boards is load-single.
  Caution:
When a single SRPU is in position, the load-balance mode is not effective and the SRPU changes to the load-single mode automatically.
2.3  Displaying and Debugging HA Configuration
After the above configuration, execute display command in relevant view to display the running of the ACL configuration, and to verify the configuration. Execute debugging command in user view to enable HA module debugging function.
Perform the following configuration in relevant view.
Table 2-6 Display and debug HA configuration
Operation
Display the status of the master and slave boards(any view)
display switchover state [ slot-id ]
Display the load mode of the master and slave boards(system view)
display xbar
Enable the debugging information output of the HA module(user view)
debugging ha { all | event | message | state }
Disable the debugging information output of the HA module(user view)
undo debugging ha { all | event | message | state }
2.4  HA Configuration Example
I. Network requirements
Take the master board out and make the slave board take over the work of the master to ensure the normal operation.
II. Configuration procedure
# Synchronize the configuration file manually.
<H3C>slave update configuration
# Display the switchover state.
<H3C>display switchover state
# Start the master-slave switchover manually after you confirm and press <Enter>.
<H3C>slave switchover
Caution!!! Confirm to switch slave to master[Y/N]?y
