H3C S9500 Series Routing Switches Operation Manual-(V1.01)
HomeSupportSwitchesH3C S9500 Series SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Series Routing Switches Operation Manual-(V1.01)
00-1Cover
00-1Cover 53 KB
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08163E-20071125-C-1.01
Product Version: S9500-CMW310-R1278
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
The related manuals are listed in the following table.
Manual
H3C S9500 Series Routing Switches  Installation Manual
It provides information for the system installation, booting, hardware/software maintenance & monitoring.
H3C S9500 Series Routing Switches  Command Manual
It introduces all commands available in the S9500, as well as a command index.
Organization
H3C S9500 Series Routing Switches  Operation Manual consists of the following parts:
Part
1 Getting Started
This module profiles the access types and steps to the S9500 series
2 Port
This module focuses on the configuration on Ethernet ports, POS ports, RPR ports, link aggregation, and IDS cooperation.
3 VLAN-QinQ
This module elaborates on the configuration on VLAN, GARP, GVRP, super VLAN and QinQ.
4 Network Protocol
This module details the configuration on network protocols, including IP address configuration, ARP configuration, DHCP relay configuration, DNS configuration and IP performance configuration
5 Routing Protocol
This module concentrates on the configuration on routing protocols, including static route configuration, RIP configuration, OSPF configuration, IS-IS configuration, BGP configuration and IP routing policy configuration
6 Multicast Protocol
This module presents the configuration on IGMP-Snooping, IGMP, multicast VLAN, PIM-DM, PIM-SM, MSDP and MBGP
7 QACL
This module introduces the configuration on QoS/ACL feature.
8 MPLS
This module introduces the configuration on MPLS and BGP/MPLS VPN features..
9 STP
This module introduces the configuration on STP feature.
10 Security
This module presents the configuration on 802.1x, AAA and RADIUS protocols, HABP, and HWTACACS protocol.
11 Reliability
This module focuses on VRRP and HA configurations.
12 System Management
This module details the configuration involved in system management and maintenance, including file management, system maintenance, SNMP, RMON, NTP protocol, SSH terminal services, and network management.
13 PoE
This module focuses on power over Ethernet (PoE) configuration.
14 NAT-URPF-VPLS
This module presents the configurations on NAT, URPF, and VPLS.
15 Integrated Management
This module introduces the configuration on HGMP V1
16 Appendix
This appendix offers the acronyms in this manual
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means be extremely careful; the risk of bodily injury is present.
  Caution
Means be careful. The risk of data loss and damage to equipment is present.
&  Note
Means a complementary description.
