H3C S9500 Series Routing Switches Operation Manual-(V1.01)
HomeSupportSwitchesH3C S9500 Series SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Series Routing Switches Operation Manual-(V1.01)
01-Getting Started Operation
01-Getting Started Operation 393 KB
Table of Contents
Chapter 1 Product Overview.. 1-1
1.1 Product Overview. 1-1
1.2 Function Features. 1-2
Chapter 2 Logging in to Switch. 2-1
2.1 Setting Up Configuration Environment through the Console Port 2-1
2.2 Setting up Configuration Environment through Telnet 2-2
2.2.1 Connecting a PC to the Switch through Telnet 2-2
2.2.2 Accessing a Switch through another Switch via Telnet 2-4
2.3 Setting Up Configuration Environment through Modem Dial-up. 2-5
Chapter 3 Command Line Interface. 3-1
3.1 Command Line Interface. 3-1
3.2 Command Line View. 3-1
3.3 Features and Functions of Command Line. 3-9
3.3.1 Online Help of Command Line. 3-9
3.3.2 Displaying Characteristics of Command Line. 3-10
3.3.3 History Command of Command Line. 3-10
3.3.4 Common Command Line Error Messages. 3-11
3.3.5 Editing Characteristics of Command Line. 3-11
Chapter 4 User Interface Configuration. 4-1
4.1 User Interface Overview. 4-1
4.2 User Interface Configuration. 4-2
4.2.1 Entering User Interface View. 4-2
4.2.2 Define the Login Header 4-2
4.2.3 Configuring Asynchronous Port Attributes. 4-3
4.2.4 Configuring Terminal Attributes. 4-4
4.2.5 Managing Users. 4-6
4.2.6 Configuring Modem Attributes. 4-10
4.2.7 Configuring Redirection. 4-11
4.3 Displaying and Debugging User Interface. 4-12
Chapter 5 Management Interface Configuration. 5-1
5.1 Management Interface Overview. 5-1
5.2 Management Interface Configuration. 5-1
Chapter 6 Password Control Configuration. 6-1
6.1 Introduction to Password Control Configuration. 6-1
6.2 Password Control Configuration. 6-2
6.2.1 Configuration Prerequisites. 6-2
6.2.2 Configuration Tasks. 6-2
6.2.3 System Logging Function. 6-9
6.2.4 Password Control Configuration Example. 6-9
The H3C S9500 Series Routing Switches (hereinafter referred to as S9500 series) are a series of large capacity, modularized L2/L3 switches. They are mainly designed for broadband MAN, backbone, switching core and convergence center of large-sized enterprise network and campus network. They provide diverse services and can be used in constructing stable and high-performance IP network. The series include the following main models:
l           S9505 routing switch
l           S9508 routing switch
l           S9512 routing switch
S9500 series use integrated chassis, which can be subdivided into power supply area, board area, backplane and fan area.
For S9505, in the board area, there are seven slots: the top two (slot0, slot1) accommodate SRPU boards, which are in 1+1 redundancy; the remaining five accommodate LPU boards, which can be hybrid.
For S9508, in the board area, there are 10 slots: the two (slot4, slot5) in the middle accommodate SRPU boards, which are in 1+1 redundancy; the remaining 8 accommodate LPU boards, which can be hybrid.
For S9512, in the board area, there are 14 slots: the two (slot6, slot7) in the middle accommodate SRPU boards, which are in 1+1 redundancy; the remaining 12 accommodate LPU boards, which can be hybrid. For specific configurations of the hybrid boards, refer to the “BGP/MPLS VPN Configuration” section of the MPLS module.
S9500 series support the following services:
l           Internet broadband access
l           MAN, enterprise/campus networking
l           Providing multicast service and multicast routing and supporting multicast audio and video services.
Table 1-1 Function features
Features
Implementation
VLAN
Supports VLAN compliant with IEEE 802.1Q Standard
Supports port-based VLAN
Supports GARP VLAN Registration Protocol (GVRP)
Supports super VLAN
Supports guest VLAN
STP protocol
Supports Spanning Tree Protocol (STP) / Multiple Spanning Tree Protocol (MSTP), compliant with IEEE 802.1D/IEEE 802.1s Standard
Flow control
Supports IEEE 802.3x flow control (full-duplex)
Supports back-pressure based flow control (half-duplex)
Broadcast Suppression
Supports Broadcast Suppression
Multicast
Supports Internet Group Management Protocol Snooping (IGMP Snooping)
Supports Internet Group Management Protocol (IGMP)
Supports Protocol-Independent Multicast-Dense Mode (PIM-DM)
Supports Protocol-Independent Multicast-Sparse Mode (PIM-SM)
Supports Multicast Source Discovery Protocol (MSDP)
Supports Multiprotocol BGP (MBGP)
IP routing
Supports static routing
Supports Routing Information Protocol (RIP) v1/v2
Supports Open Shortest Path First (OSPF)
Supports Border Gateway Protocol (BGP)
Supports Intermediate System-to-Intermediate System intra-domain routing information exchange protocol (IS-IS)
Supports equivalent routes
Supports policy routing
Supports IP routing policy
DHCP
Supports dynamic host configuration protocol (DHCP) relay
Supports DHCP server
Link aggregation
Supports link aggregation, including manual aggregation and dynamic LACP (link aggregation control protocols) aggregation and static LACP aggregation.
Mirroring
Supports the port-based mirroring
Supports flow mirroring of copying messages to CPU
Quality of Service (QoS)
Supports traffic classification
Supports bandwidth control
Supports congestion control
Supports traffic shaping and traffic supervision
Supports queues of different priority on the port
Queue scheduling: supports Strict Priority Queuing (SP), Weighted Round Robin (WRR), and SP+WRR
Security features
Supports Multi-level user management and password protect
Supports 802.1X authentication
Supports Packet filtering
Supports AAA/RADIUS/HWTACACS
Supports IDS linkage
MPLS
Supports Multiprotocol Label Switching (MPLS) basic function
Supports MPLS L3 VPN
Supports VLL, including Martini, Kompella and CCC modes
Supports VPLS
Dedicated service processing
Supports NAT
Supports URPF
Management and Maintenance
Supports command line interface configuration
Supports local configuration via Console port and AUX port
Supports local and remote configuration through Telnet on Ethernet port
Supports remote configuration through modem dialup via the AUX port.
Supports SNMP management (Supports RMON (remote monitoring) MIB Groups 1, 2, 3 and 9)
Supports system logging
Supports level alarms
Supports output of the debugging information
Supports Ping and Tracert
Supports remote maintenance via Telnet and Modem dialup
Supports SSH (secure shell) 2.0
Loading and updating
Supports to load and upgrade software via XModem protocol
Supports to load and upgrade software via File Transfer Protocol (FTP) and Trivial File Transfer Protocol (TFTP)
Step 1: As shown in the figure below, to set up the local configuration environment, connect the serial port of a PC (or a terminal) to the Console port of the switch with the Console cable.
Figure 2-1 Set up the local configuration environment through the Console port
Step 2: Run a terminal emulator (such as Terminal of Windows 3X or HyperTerminal of Windows 9X) on the computer. Set the terminal communication parameters as follows: Set “Bits per second” to “9600”, “Data bits” to “8”, “Parity” to “none”, “Stop bits” to “1”, and “Flow control” to “none”, and select the “VT100” as the terminal type..
Figure 2-2 Set up new connection
Figure 2-3 Configure the port for connection
Figure 2-4 Set communication parameters
Step 3: The switch is powered on. Display self-test information of the switch and prompt you to press Enter to show the command line prompt such as <H3C>.
Step 4: Input a command to configure the switch or view the operation state. Input a “?” for help. For details of specific commands, refer to the following chapters.
After you have correctly configured IP address of a VLAN interface for a switch via Console port (using ip address command in VLAN interface view), and added the port (that connects to a terminal) to this VLAN (using port command in VLAN view), you can telnet this switch and configure it.
Step 1: Before logging into the switch through telnet, you need to configure the Telnet user name and password on the switch through the console port.
&  Note:
By default, the password is required for authenticating the Telnet user to log in to the switch. If a user logs in via the Telnet without password, he will see the prompt “Login password has not been set !”.
<H3C> system-view
Enter system view , return user view with Ctrl+Z.
[H3C] user-interface vty 0
[H3C-ui-vty0] set authentication password simple xxxx (xxxx is the login password of Telnet user)
Step 2: To set up the configuration environment, connect the Ethernet port of the PC to that of the switch via the LAN, as shown in Figure 2-5.
Figure 2-5 Set up configuration environment through telnet
Step 3: Run Telnet on the PC and input the IP address of the VLAN connected to the PC port, as shown in Figure 2-6.
Figure 2-6 Run Telnet
Step 4: The terminal displays “Login authentication!” and prompts the user to input the logon password. After you input the correct password, it displays the command line prompt (such as <H3C>). If the prompt “All user interfaces are used, please try later! The connection was closed by the remote host!” appears, it indicates that the maximum number of Telnet users that can be accessed to the switch is reached at this moment. In this case, please reconnect later. At most 5 Telnet users are allowed to log on to the H3C series switches simultaneously.
Step 5: Use the corresponding commands to configure the switch or to monitor the running state. Enter “?” to get the immediate help. For details of specific commands, refer to the following chapters.
&  Note:
l      When configuring the switch via Telnet, do not modify the IP address of it unless necessary, for the modification might cut the Telnet connection.
l      By default, when a Telnet user passes the password authentication to log on to the switch, he can access the commands at Level 0.
After a user has logged in to a switch, he or she can configure another switch through the switch via Telnet. The local switch serves as Telnet client and the peer switch serves as Telnet server. If the ports connecting these two switches are in a same local network, their IP addresses must be configured in the same network segment. Otherwise, the two switches must establish a route that can reach each other.
As shown in the figure below, after you telnet to a switch, you can run telnet command to log in and configure another switch.
Figure 2-7 Provide Telnet Client service
Step 1: Configure the Telnet user name and password on the Telnet Server through the console port.
&  Note:
By default, the password is required for authenticating the Telnet user to log in to the switch. If a user logs in via the Telnet without password, he will see the prompt “Login password has not been set !.”.
<H3C> system-view
System View: return to User View with Ctrl+Z
Step 2: The user logs in the Telnet Client (switch). For the login process, refer to the section describing “Connecting a PC to the Switch through Telnet”.
Step 3: Perform the following operations on the Telnet Client:
<H3C> telnet xxxx (xxxx can be the hostname or IP address of the Telnet Server. If it is the hostname, you need to use the ip host command to specify.)
Step 4: Enter the preset login password and you will see the prompt such <H3C>. If the prompt “All user interfaces are used, please try later! The connection was closed by the remote host!” appears, it indicates that the maximum number of Telnet users that can be accessed to the switch is reached at this moment. In this case, please connect later.
Step 5: Use the corresponding commands to configure the switch or view it running state. Enter “?” to get the immediate help. For details of specific commands, refer to the following chapters.
Step 1: The modem user is authenticated via the Console port of the switch before he or she logs in to the switch through a dial-up Modem.
&  Note:
By default, the password is required for authenticating the Modem user to log in to the switch. If a user logs in via the Modem without password, he or she will see the prompt “Login password has not been set !.”.
<H3C> system-view
System View: return to User View with Ctrl+Z..
[H3C] user-interface aux 0
[H3C-ui-aux0] set authentication password simple xxxx (xxxx is the login password of the Modem user.)
Step 2: As shown in the figure below, to set up the remote configuration environment, connect the Modems to a PC (or a terminal) serial port and the switch AUX port respectively.
Figure 2-8 Set up remote configuration environment
Step 3: Dial for connection to the switch, using the terminal emulator and Modem on the remote end. The number dialed shall be the telephone number of the Modem connected to the switch. See the two figures below.
Figure 2-9 Set the dialed number
Figure 2-10 Dial on the remote PC
Step 4: Enter the preset login password on the remote terminal emulator and wait for the prompt such as <H3C>. Then you can configure and manage the switch. Enter “?” to get the immediate help. For details of specific commands, refer to the following chapters.
&  Note:
By default, when a Modem user logs in, he can access the commands at Level 0.
H3C series switches provide a series of configuration commands and command line interfaces for configuring and managing the switch. The command line interface has the following characteristics:
l           Local configuration via the Console port and AUX port.
l           Local or remote configuration via Telnet.
l           Remote configuration through dialing with modem via the AUX port.
l           Hierarchy command protection to avoid the unauthorized users accessing switch.
l           Enter a “?” to get immediate online help.
l           Provide network testing commands, such as Tracert and Ping, to fast troubleshoot the network.
l           Provide various detailed debugging information to help with network troubleshooting.
l           Log in and manage other switch directly, using the Telnet command.
l           Provide FTP service for the users to upload and download files.
l           Provide the function similar to Doskey to execute a history command.
l           The command line interpreter searches for target not fully matching the keywords. It is ok for you to key in the whole keyword or part of it, as long as it is unique and not ambiguous.
H3C series switches provide hierarchy protection for the command lines to avoid unauthorized user accessing illegally.
Commands are classified into four levels, namely visit level, monitoring level, configuration level and management level. They are introduced as follows:
l           Visit level: Commands of this level involve command of network diagnosis tool (such as ping and tracert), command of switch between different language environments of user interface (language-mode) and telnet command etc. The operation of saving configuration file is not allowed on this level of commands.
l           Monitoring level: Commands of this level, including the display command and the debugging command, are used to system maintenance, service fault diagnosis, etc. The operation of saving configuration file is not allowed on this level of commands.
l           Configuration level: Service configuration commands, including routing command and commands on each network layer, are used to provide direct network service to the user.
l           Management level: They are commands that influence basis operation of the system and system support module, which plays a support role on service. Commands of this level involve file system commands, FTP commands, TFTP commands, XModem downloading commands, user management commands, and level setting commands.
At the same time, login users are classified into four levels that correspond to the four command levels respectively. After users of different levels log in, they can only use commands at the levels that are equal to or lower than its own level.
In order to prevent unauthorized users from illegal intrusion, user will be identified when switching from a lower level to a higher level with super [ level ] command. User ID authentication is performed when users at lower level switch to users at higher level. In other words, user password of the higher level is needed (Suppose the user has set the super password [ level level ] { simple | cipher } password.) For the sake of confidentiality, on the screen the user cannot see the password that he entered. Only when correct password is input for three times, can the user switch to the higher level. Otherwise, the original user level will remain unchanged.
Different command views are implemented according to different requirements. They are related to one another. For example, after logging in the switch, you will enter user view, in which you can only use some basic functions such as displaying the running state and statistics information. In user view, key in system-view to enter system view, in which you can key in different configuration commands and enter the corresponding views.
The command line provides the following views:
l           User view
l           System view
l           Port view
l           VLAN view
l           VLAN interface view
l           Local-user view
l           User interface view
l           FTP Client command view
l           SFTP Client view
l           MST region view
l           PIM view
l           MSDP view
l           IPv4 multicast sub-address family view
l           RIP view
l           OSPF view
l           OSPF area view
l           BGP view
l           IS-IS view
l           Route policy view
l           Basic ACL view
l           Advanced ACL view
l           Layer-2 ACL view
l           Conform-level view
l           WRED index view
l           RADIUS server group view
l           ISP domain view
l           MPLS view
l           VPNv4 sub-address family view
l           VPN-instance sub-address family view
l           BGP-VPNv4 sub-address family view
l           MPLS L2VPN view
l           L2VPN address family view
l           Route-Policy view
l           vpn-instance view
l           OSPF protocol view
l           Remote-peer view
l           VSI-LDP view
l           VSI view
l           HWTACACS view
l           Port group view
l           Lanswitch view
l           HGMP view
The following table describes the function features of different views and the ways to enter or quit.
Table 3-1 Function feature of command view
Command view
Function
Prompt
Command to enter
Command to exit
Show the basic information about operation and statistics
<H3C>
Enter right after connecting the switch
Use quit to end the disconnection with the switch
Configure system parameters
[H3C]
Key in system-view in user view
Use quit or return to return to user view
Port view
Ethernet port view:
Configure Ethernet port parameters
[H3C-Ethernet2/1/1]
100M Ethernet port view
Key in interface ethernet 2/1/1 in system view
Use quit to return to system view
Use return to return to user view
[H3C-GigabitEthernet2/1/1]
GigabitEthernet port view
Key in interface gigabitethernet 2/1/1 in system view
10G Ethernet port view
POS port view:
Configure POS port parameters
[H3C-Pos2/1/1]
Key in interface pos 2/1/1 in system view
RPR logical port view: Configure RPR port parameters
[H3C-rpr2/1/1]
Key in interface rpr2/1/1 in system view
RPR POS physical port view: Configure physical parameters for RPR ports
[H3C-rpr2/1/1.1]
Key in interface rpr2/1/1.1 in system view
VLAN view
Configure VLAN parameters
[H3C-Vlan1]
Key in vlan 1 in system view
VLAN interface view
Configure IP interface parameters for a VLAN or a VLAN aggregation
[H3C-Vlan-interface1]
Key in interface vlan-interface 1 in system view
Local-user view
Configure local user parameters
[H3C-luser-user1]
Key in local-user user1 in system view
User interface view
Configure user interface parameters
[H3C-ui0]
Key in user-interface 0 in system view
FTP client command view
Configure FTP Client parameters
[ftp]
Key in ftp in user view
SFTP Client view
Configure SFTP Client parameters
<sftp-client>
Key in sftp ip-address in system view
MST region view
Configure MST region parameters
[H3C-mst-region]
Key in stp region-configuration in system view
PIM view
Configure PIM parameters
[H3C-PIM]
Key in pim in system view
MSDP view
Configure MSDP parameters
[H3C-msdp]
Key in msdp in system view
Enter the IPv4 multicast sub-address family view to configure MBGP multicast extension parameters
[H3C-bgp-af-mul]
Key in ipv4-family multicast in BGP view
Use quit to return to BGP view
RIP view
Configure RIP parameters
[H3C-rip]
Key in rip in system view
OSPF view
Configure OSPF parameters
[H3C-ospf]
Key in ospf in system view
OSPF area view
Configure OSPF area parameters
[H3C-ospf-0.0.0.1]
Key in area 1 in OSPF view
Use quit to return to OSPF view
BGP view
Configure BGP parameters
[H3C-bgp]
Key in bgp 100 in system view
IS-IS view
Configure IS-IS parameters
[H3C-isis]
Key in isis in system view
Route policy view
Configure route policy parameters
[H3C-route-policy]
Key in route-policy policy1 permit node 10 in system view
Basic ACL view
Define the rule of basic ACL
[H3C-acl-basic-2000]
Key in acl number 2000 in system view
Advanced ACL view
Define the rule of advanced ACL
[H3C-acl-adv-3000]
Key in acl number 3000 in system view
Layer-2 ACL view
Define the rule of layer-2 ACL
[H3C-acl-link-4000]
Key in acl number 4000 in system view
Conform-level view
Configure the "DSCP + Conform-level Service group" mapping table and”EXP + Conform-level- >service parameters”mapping table and "Local-precedence + Conform-level 802.1p priority" mapping table
[H3C-conform-level-0]
Key in qos conform-level 0 in system view
WRED index view
Configure WRED parameters
[H3C-wred-0]
Key in wred 0 in system view
Configure radius parameters
[H3C-radius-1]
Key in radius scheme 1 in system view
ISP domain view
Configure ISP domain parameters
[H3C-isp-H3C163.net]
Key in domain H3C163.net in system view
Use to return to system view
MPLS view
Configure MPLS parameters
[H3C-mpls]
Key in mpls in system view
Configure VPNv4 address family parameters
[H3C-bgp-af-vpn]
Key in ipv4-family vpnv4 in BGP view
Configure VPN instance sub-address family parameters
[H3C-bgp-af-vpn-instance]
Key in ipv4-family vpn-instance vpna in BGP/RIP view
Configure BGP-VPNv4 sub-address family parameters
[H3C-bgp-af-vpn]
Key in ipv4-family vpn-instance in BGP/RIP view
MPLS L2VPN view
Configure MPLS L2VPN service parameters
[H3C-mpls-l2vpn-vpna]
Key in mpls l2vpn vpna encapsulation Ethernet in system view
Configure L2VPN service parameters
[H3C-bgp-af-l2vpn]
Key in l2vpn-family in BGP view
Route-Policy view
Configure Route-Policy service parameters
[H3C-route-policy]
Key in route-policy route-policy-name { permit | deny } node node-number in system view
vpn-instance view
Configure vpn-instance parameters
[H3C-vpn-vpn-instance_blue]
Key in ip vpn-instance vpn-instance_ vpna in system view
OSPF protocol view
Configure OSPF protocol parameters
[H3C-ospf-100]
Key in ospf process-id [ router-id router-id-number ] [ vpn-instance vpn-instance-name ] in system view
Remote-peer view
Configure MPLS peer group parameters
[H3C-mpls-remote1]
Key in mpls remote1
VSI-LDP view
Configure some VPLS features
[9500-vsi-H3C-ldp]
Key in vsi H3C in system view
Key in pwsignal ldp in vsi view
Use quit to return to vsi view
VSI view
Specify VPLS mode
[9500-vsi-H3C]
HWTACACS view
Configure HWTACACS protocol parameters
[9500-hwtacacs-H3C]
Key in hwtacacs scheme H3C in system view
Port group view
Combine the ports with the same configuration, omitting repeated configuration procedure
[9500-port-group X]
Key in port-group X in system view
HGMP view
Configure some HGMP features
[H3C-hgmp]
Key in hgmpserver enable in system view
Lanswitch view
Enter lanswitch view.
After entering the specified lanswitch view, you can use the specified Ethernet switch.
[H3C-lanswitchX/X/X-/]
Key in lanswitch X/X/X-/ in HGMP view
Use quit to return to HGMP view
The command line interface provides the following online help modes.
l           Full help
l           Partial help
You can get the help information through these online help commands, which are described as follows.
1)         Input “?” in any view to get all the commands in it and corresponding descriptions.
<H3C> ?
User view commands:
  language-mode  Specify the language environment
  ping           Ping function
  quit           Exit from current command view
  super          Privilege current user a specified priority level
  telnet         Establish one TELNET connection
  tracert            Trace route function
2)         Input a command with a “?” separated by a space. If this position is for keywords, all the keywords and the corresponding brief descriptions will be listed.
<H3C> language-mode ?
  chinese  Chinese environment
  english  English environment
3)         Input a command with a “?” separated by a space. If this position is for parameters, all the parameters and their brief descriptions will be listed.
[H3C] garp timer leaveall ?
  INTEGER<65-32765>  Value of timer in centiseconds
                     (LeaveAllTime > (LeaveTime [On all ports]))
                     Time must be multiple of 5 centiseconds
[H3C] garp timer leaveall 300 ?
  <cr>
<cr> indicates no parameter in this position. The next command line repeats the command, you can press <Enter> to execute it directly.
4)         Input a character string with a “?”, then all the commands with this character string as their initials will be listed.
<H3C> p?
ping   pwd
5)         Input a command with a character string and “?”, then all the key words with this character string as their initials in the command will be listed.
<H3C> display ver?
  version
6)         Input the first letters of a keyword of a command and press <Tab> key. If no other keywords are headed by this letters, then this unique keyword will be displayed automatically.
7)         To switch to the Chinese display for the above information, perform the language-mode command.
Command line interface provides the following display characteristics:
l           For users’ convenience, the instruction and help information can be displayed in both English and Chinese.
l           For the information to be displayed exceeding one screen, pausing function is provided. In this case, users can have three choices, as shown in the table below.
Table 3-2 Functions of displaying
Key or Command
Function
Press <Ctrl+C> when the display pauses
Stop displaying and executing command.
Enter a space when the display pauses
Continue to display the next screen of information.
Press <Enter> when the display pauses
Continue to display the next line of information.
Command line interface provides the function similar to that of DosKey. The commands entered by users can be automatically saved by the command line interface and you can invoke and execute them at any time later. History command buffer is defaulted as 10. The operations are shown in the table below.
Table 3-3 Retrieve history command
Operation
Key
Result
Display history command
display history-command
Display history command by user inputting
Retrieve the previous history command
Up cursor key <↑> or <Ctrl+P>
Retrieve the previous history command, if there is any.
Retrieve the next history command
Down cursor key <↓> or <Ctrl+N>
Retrieve the next history command, if there is any.
&  Note:
Cursor keys can be used to retrieve the history commands in Windows 3.X Terminal and Telnet. However, in Windows 9X HyperTerminal, the cursor keys ↑ and ↓ do not work, because Windows 9X HyperTerminal defines the two keys differently. In this case, use the combination keys <Ctrl+P> and <Ctrl+N> instead for the same purpose.
All the input commands by users can be correctly executed, if they have passed the grammar check. Otherwise, error messages will be reported to users. The common error messages are listed in the following table.
Table 3-4 Common command line error messages
Error messages
Causes
Unrecognized command
Cannot find the command.
Cannot find the keyword.
Wrong parameter type.
The value of the parameter exceeds the range.
Incomplete command
The input command is incomplete.
Too many parameters
Enter too many parameters.
Ambiguous command
The parameters entered are not specific.
Command line interface provides the basic command editing function and supports to edit multiple lines. A command cannot longer than 256 characters. See the table below.
Table 3-5 Editing functions
Key
Function
Common keys
Insert from the cursor position and the cursor moves to the right, if the edition buffer still has free space.
Backspace
Delete the character preceding the cursor and the cursor moves backward.
Leftwards cursor key <←> or <Ctrl+B>
Move the cursor a character backward
Rightwards cursor key <→> or <Ctrl+F>
Move the cursor a character forward
Retrieve the history command.
<Tab>
Press <Tab> after typing the incomplete key word and the system will execute the partial help: If the key word matching the typed one is unique, the system will replace the typed one with the complete key word and display it in a new line; if there is not a matched key word or the matched key word is not unique, the system will do no modification but display the originally typed word in a new line.
To facilitate system management, the switches support user interface based configuration for the configuration and management of port attributes. Presently, the S9500 series switches support the following user interface based configuration methods:
l           Local and remote configuration through Telnet on Ethernet port
According to the above-mentioned configuration methods, there are three types of user interfaces:
l           Console user interface
Console user interface is used to log in to the switch via the Console port. A switch can only have one Console user interface.
l           AUX user interface
AUX user interface is used to log in to the switch locally or remotely with a modem via the AUX port. A switch can only have one AUX user interface. The local configuration for it is similar to that for the Console user interface.
l           VTY user interface
VTY user interface is used to telnet the switch. A switch can have up to five VTY user interface.
User interface is numbered in the following two ways: absolute number and relative number.
I. Absolute number
The user interfaces of the S9500 routing switch include three types, which are sequenced as follows: console interface (CON), auxiliary interface (AUX) and virtual interface (VTY). A switch has one CON, one AUX and multiple VTYs. The first absolute number is designated as 0; the second one is designated as 1; and so on. This method can specify a unique user interface or a group of interfaces.
It follows the rules below.
l           Console user interface is numbered as the first interface designated as user interface 0.
l           AUX user interface is numbered as the second interface designated as user interface 1.
l           VTY is numbered after AUX user interface. The absolute number of the first VTY is incremented by 1 than the AUX user interface number.
II. Relative number
The relative number is in the format of “user interface type” + “number”. The “number” refers to the internal number for each user interface type. This method can only specify one interface or one group of interfaces for a user interface type instead of different user interface types.
 It follows the rules below:
l           Number of Console user interface: console 0.
l           Number of AUX user interface: AUX 0.
l           Number of VTY: The first VTY interface is designated as VTY 0; the second one is designated as VTY 1, and so on.
The following sections describe the user interface configuration tasks.
l           Entering User Interface View
l           Define the Login Header
l           Configuring Asynchronous Port Attributes
l           Configuring Terminal Attributes
l           Managing Users
l           Configuring Modem Attributes
l           Configuring Redirection
The following command is used for entering a user interface view. You can enter a single user interface view or multi user interface view to configure one or more user interfaces respectively.
Perform the following configuration in system view.
Table 4-1 Enter user interface view
Operation
Enter a single user interface view or multi user interface views
user-interface [ type ] first-number [ last-number ]
The following command is used for configuring the displayed header when user login.
When the users log in to the switch, if a connection is activated, the login header will be displayed. After the user successfully logs in the switch, the shell header will be displayed.
Table 4-2 Configure the login header.
Operation
header [ shell | incoming | login ] text
Remove the login header configured
undo header [ shell | incoming | login ]
Note that if you press <Enter> after typing any of the three keywords shell, login and incoming in the command, then what you type after the word header is the contents of the login information, instead of identifying header type.
The following commands can be used for configuring the attributes of the asynchronous port in asynchronous interactive mode, including speed, flow control, parity, stop bit and data bit.
Perform the following configurations in user interface (Console and AUX user interface only) view.
I. Configuring the transmission speed
Table 4-3 Configure the transmission speed
Operation
speed speed-value
Restore the default transmission speed
undo speed
By default, the transmission speed on an asynchronous port is 9600bps.
II. Configuring flow control
Table 4-4 Configure flow control
Operation
Configure the flow control
Restore the default flow control mode
undo flow-control
By default, the flow control on an asynchronous port is none, that is, no flow control will be performed.
III. Configuring parity
Table 4-5 Configure parity
Operation
Configure parity mode
Restore the default parity mode
undo parity
By default, the parity on an asynchronous port is none, that is, no parity bit.
IV. Configuring the stop bit
Table 4-6 Configure the stop bit
Operation
stopbits { 1 | 1.5 | 2 }
Restore the default stop bit
undo stopbits
By default, an asynchronous port supports 1 stop bit.
Note that setting 1.5 stop bits is not available on S9500 series at present.
V. Configuring the data bit
Table 4-7 Configure the data bit
Operation
databits { 7 | 8 }
Restore the default data bit
undo databits
By default, an asynchronous port supports 8 data bits.
The following commands can be used for configuring the terminal attributes, including enabling/disabling terminal service, disconnection upon timeout, lockable user interface, configuring terminal screen length and history command buffer size.
Perform the following configuration in user interface view. Perform lock command in user view.
I. Enabling/disabling terminal service
After the terminal service is disabled on a user interface, you cannot log in to the switch through the user interface. However, the user logged in through the user interface before disabling the terminal service can continue his operation. After such user logs out, he cannot log in again. In this case, a user can log in to the switch through the user interface only when the terminal service is enabled again.
Table 4-8 Enable/disable terminal service
Operation
Enable terminal service
shell
Disable terminal service
undo shell
By default, terminal service is enabled on all the user interfaces.
Note the following points:
l           For the sake of security, the undo shell command can only be used on the user interfaces other than Console user interface.
l           You cannot use this command on the user interface via which you log in.
l           You will be asked to confirm before using undo shell on any legal user interface.
II. Configuring idle-timeout
Table 4-9 Configure idle-timeout
Operation
Restore the default idle-timeout
undo idle-timeout
By default, idle-timeout is enabled and set to 10 minutes on all the user interfaces. That is, the user interface will be disconnected automatically after 10 minutes without any operation.
idle-timeout 0 means disabling idle-timeout.
III. Locking user interface
This configuration is to lock the current user interface and prompt the user to enter the password. This makes it impossible for others to operate in the interface after the user leaves.
Table 4-10 Lock user interface
Operation
Lock user interface
lock
IV. Setting the screen length
If a command displays more than one screen of information, you can use the following command to set how many lines to be displayed in a screen, so that the information can be separated in different screens and you can view it more conveniently.
Table 4-11 Set the screen length
Operation
screen-length screen-length
Restore the default screen length
undo screen-length
Note that the number of lines that can be displayed in each screen remains the same when screen-length is set to 1 or 2.
By default, 24 lines (including the multi-screen identifier lines) are displayed in one screen when the multi-screen display function is enabled .
Use screen-length 0 to disable the multi-screen display function.
V. Setting the history command buffer size
Table 4-12 Set the history command buffer size
Operation
history-command max-size value
Restore the default history command buffer size
undo history-command max-size
By default, the size of the history command buffer is 10, that is, 10 history commands can be saved.
The management of users includes the setting of user logon authentication method, level of command which a user can use after logging on, level of command which a user can use after logging on from the specifically user interface, and command level.
I. Configuring the authentication method
The following command is used for configuring the user login authentication method to deny the access of an unauthorized user.
Table 4-13 Configure the authentication method
Operation
authentication-mode { password | scheme | none }
By default, terminal authentication is not required for local users log in via the Console port. However, password authentication is required for local users and remote Modem users to log in via the AUX port, and for Telnet users and the VTY users to log in through Ethernet port.
Note: If the Console port is configured for local password authentication, the user can directly log in to the system even without a password configured; if other user interfaces, such as the AUX port and VTY interface, are configured for local password authentication, users cannot log in to the system without a password.
1)         Perform local password authentication to the user interface
Using authentication-mode password command, you can perform local password authentication. That is, you need use the command below to configure a login password in order to login successfully.
Table 4-14 Configure the local authentication password
Operation
set authentication password { cipher | simple }password
Remove the local authentication password
undo set authentication password
# Configure for password authentication when a user logs in through a VTY 0 user interface and set the password to H3C.
[H3C-ui-vty0] authentication-mode password
[H3C-ui-vty0] set authentication password simple H3C
2)         Perform local or remote authentication of username and password to the user interface
Using authentication-mode scheme command, you can perform local or remote authentication of username and password. The type of the authentication depends on your configuration. For detailed information, see “Security” section.
In the following example, local username and password authentication are configured.
# Perform username and password authentication when a user logs in through VTY 0 user interface and set the username and password to zbr and H3C respectively.
[H3C-ui-vty0] authentication-mode scheme
[H3C-ui-vty0] quit
[H3C] local-user zbr
[H3C-luser-zbr] password simple H3C
[H3C-luser-zbr] service-type telnet
3)         No authentication
[H3C-ui-vty0] authentication-mode none
&  Note:
By default, password is required to be set for authenticating local users and remote Modem users log in via the AUX port, and Telnet users log in through Ethernet port. If no password has been set, the following prompt will be displayed “Login password has not been set !.”
If the authentication-mode none command is used, the local and Modem users via the AUX port and Telnet users will not be required to input password.
II. Setting the command level used after a user logging in
The following command is used for setting the command level used after a user logging in.
Perform the following configuration in local-user view.
Table 4-15 Set the command level used after a user logging in
Operation
Set command level used after a user logging in
service-type telnet [ level level ]
Restore the default command level used after a user logging in
undo service-type telnet
By default, the specified logon user can access the commands at Level 2.
III. Setting the command level used after a user logs in from a user interface
You can use the following command to set the command level after a user logs in from a specific user interface, so that a user is able to execute the commands at such command level.
Table 4-16 Set the command level used after a user logging in from a user interface
Operation
Set command level used after a user logging in from a user interface
user privilege level level
Restore the default command level used after a user logging in from a user interface
undo user privilege level
By default, you can access the commands at Level 3 after logging in through the Console user interface, and the commands at Level 0 after logging in through the AUX or VTY user interface.
&  Note:
When a user logs in the switch, the command level that it can access depends on two points. One is the command level that the user itself can access, the other is the set command level of this user interface. If the two levels are different, the former will be taken. For example, the command level of VTY 0 user interface is 1, however, you have the right to access commands of level 3; if you log in from VTY 0 user interface, you can access commands of level 3 and lower.
IV. Setting the command priority
The following command is used for setting the priority of a specified command in a certain view. The command levels include visit, monitoring, configuration, and management, which are identified with 0 through 3 respectively. An administrator assigns authorities as per user requirements.
Table 4-17 Set the command priority
Operation
Set the command priority in a specified view.
command-privilege level level view view command
Restore the default command level in a specified view.
Undo command-privilege view view command
V. Setting input protocol for a user terminal
You can use the following command to set input protocol for a user terminal. The input protocol type can be TELNET, SSH or all.
Table 4-18 Set input protocol for a user terminal
Operation
protocol inbound { all | telnet | ssh }
By default, the input protocol type for a user terminal is all.
When logging in the switch via the Modem, you can use the following commands to configure these parameters.
Perform the following configuration in AUX user interface view.
Table 4-19 Configure Modem attributes
Operation
Set the interval since the system receives the RING until CD_UP
modem timer answer seconds
Restore the default interval since the system receives the RING until CD_UP
undo modem timer answer
Configure auto answer
modem auto-answer
Configure manual answer
undo modem auto-answer
Configure to allow call-in
modem call-in
Configure to bar call-in
undo modem call-in
Configure to permit call-in and call-out.
modem both
Configure to disable call-in and call-out
undo modem both
I. Send command
The following command can be used for sending messages between user interfaces.
Perform the following configuration in user view.
Table 4-20 Configure to send messages between different user interfaces.
Operation
send { all | number | type number }
II. Auto-execute command
The following command is used to automatically run a command after you log in. After a command is configured to be run automatically, it will be automatically executed when you log in again.
This command is usually used to automatically execute telnet command on the terminal, which will connect the user to a designated device automatically.
Table 4-21 Configure to automatically run the command
Operation
auto-execute command text
Configure not to automatically run the command
undo auto-execute command
l           After executing this command, the user interface can no longer be used to carry out the routine configurations for the local system. Use this command with caution.
l           Make sure that you will be able to log in to the system in some other way and cancel the configuration, before you use the auto-execute command command and save the configuration.
# Telnet 10.110.100.1 after the user logs in through VTY0 automatically.
[H3C-ui-vty0] auto-execute command telnet 10.110.100.1
When a user logs on via VTY 0, the system will run telnet 10.110.100.1 automatically.
After the above configuration, execute display command in any view to display the running of the user interface configuration, and to verify the effect of the configuration.
Execute free command in user view to release the user interface connection.
Table 4-22 Display and debug user interface
Operation
Release a specified user interface connection
free user-interface [ type ] number
Display the user application information of the user interface
display users [ all ]
Display the physical attributes and some configurations of the user interface
display user-interface [ type number | number ] [ summary ]
Query history commands selectively
display history-command { Command-Number } { | { begin | include | exclude } Match-string }
S9500 series provide a 10/100Base-TX management interface on their SRPU board. The management interface can connect a background PC for software loading and system debugging, or a remote network management station for remote system management.
The following sections describe management interface configuration tasks.
l           Configuring interface IP address
l           Enabling/disabling the interface
l           Setting interface description
l           Displaying current system information
l           Test network connectivity (ping,tracert)
See the Port and System Management parts of this manual for details.
  Caution:
Only the management interface configured with an IP address can run normally.
The Ethernet switch provides the password control function. Before a user can log in to the Ethernet switch, a system login password must be configured. After a password is configured, the user must enter the password each time he or she wants to log in to the switch. The user and can successfully log in to the switch and proceed with operations only if he or she passes the authentication. If the password authentication fails, the user will not be able to log in to the switch.
The user can either use the default password configuration, or perform his or her own password control configuration. When conducting password control, the user must follow the steps below:
1)         Configuring system login password
If password authentication is required for a user to log in to the system, the system will protect the password, instead of displaying the input password in the command line. The password must not be displayed in plain text either in the system configuration file or on the terminal: the password must be encrypted be being stored.
When a user inputs the password, “******”, rather than the plain text of the user’s password, will appear on the terminal. When configuring a password, the user needs to input the password twice for confirmation. During password configuration, the password appears as “******” in the command line, and it appears in the form of encrypted text in the configuration file.
2)         Enabling password control
After password configuration, the user can conduct password control, which includes the following aspects:
l           Enabling password aging
l           Enabling limitation of minimum password length
l           Enabling history password recording
When a login password expires, the system will require the user to input a new password and will save the old password automatically. By recording the history passwords, the system can prevent the user from using a single password or repeated passwords when modifying a password, thus to enhance the security.
The system stores the history password records in a private file in the flash memory. This file is not accessible to any user. In addition, the system automatically backs up the history password records and blacklist records, specifically as follows:
l           When adding or deleting a history password record, the system requests the standby card to perform backup.
l           When purging all history records or the history records of a certain user, the system requests the standby card to perform backup.
l           When adding a user to or deleting a user from the blacklist, the system requests the standby card to perform backup.
l           The flash memory on the active card and that on the standby keeps the same copies of history password records and blacklist records.
3)         Configuring system password parameters
After password confirmation, the administrator can modify the password at the next login. Password parameters include:
l           Password aging time
l           Alert time before the password expires
l           Minimum password length
l           Maximum the number of attempts of entering a password and the processing mode for failed login attempts
l           Maximum number of history password records
l           Timeout time for user authentication
4)         Configuring super password parameters
User levels are configured by the administrator during user configuration. The command super is used to change user levels. For example, a user of level 3 is allowed to log in to the system. After logging in, if the user wants to change his or her user level, the user needs to use the command super and pass the super password authentication. Password control, namely password aging and minimum password length limitation, must be enabled for this password.
5)         Deleting history password records
After the history password record of a user is deleted, the configuration of a new password will not be restricted by the previously configured history password records. The system allows the deletion of the history password records of all users or a specific user.
A PC is connected with an S9500 switch, and both devices work normally.
The basic configuration tasks of password control are as follows:
l           Configuring system login password
l           Enabling password control
l           Configuring system password parameters
l           Configuring super password parameters
l           Deleting history password records
After the configuration, you can carry out display password-control in any view to view the password control information for all users, including the enabled/disabled state of password aging, the aging time, the enabled/disabled state of the minimum password length limitation and the configured minimum password length, the enabled/disabled state of history password recording, the alert time before password expiration, the timeout time for password authentication, the maximum number of password input attempts, the maximum number of history password records, the processing mode after failed password input attempts, the time when the password history was last cleared, and so on.
If a user fails to provide the correct password after the allowed number of attempts, the system adds the user to the blacklist. To view the names and the IP addresses of such users, carry out display password-control blacklist in any view.
Table 6-1 Basic configuration tasks of password control
Operation
Enter system view
Enter local user view
local-user username
Configure system login password
password
Input the password twice as prompted by the system, ensuring the same password is inputted at both time
Enable password control
password-control { aging | length | history } enable
By default, password control is enabled
Configure system password parameters
password-control { aging aging-time | length length | login-attempt login-times | history max-record-num | alert-before-expire alert-time | authentication-timeout authentication-timeout | exceed { lock | unlock | locktime time } }
Refer to the detailed description in the following paragraphs about the configuration of system password parameters
The commands password-control aging aging-time and
password-control length length can also be used in the local user mode
Configure super password parameters
password-control super { aging aging-time | length length }
By default, the aging time of the super password is 90 days, and the minimum length of the super password is 10 characters.
Delete history password records of one or all users
reset password-control history-record [ username username ]
Delete history records of super password
reset password-control history-record super [ level level-value ]
Display password control information for all users
Display can be carried out in any view
Display super password control information
display password-control super
display can be carried out in any view
To cancel an operation, use the undo form of the corresponding command.
  Caution:
l      If the history password recording function is not enabled, the password clearing command reset password-control history-record can also clear the history password records of a specific user or all users.
l      If the password control function is not enabled, the password aging parameters can be configured, but will not take effect.
The following paragraphs will describe the configuration of password parameters;
I. Configuring the aging time of system password
After the password aging function is enabled, when a user goes through authentication to log in, the system reads the creation time of the user’s password and compares the password creation time with the password aging time of the user. There can be the following three cases:
1)         If the password has not expired but is within the alert time range, the system will remind the user of the remaining days before the password will expire, and ask the user whether he or she wants to change the password. The prompt message is as follows:
     Your password will expire in  2 days ,Will you  change it ? [Y/N]
l           If the user chooses to change the password, after the password is successfully changed, the system will record the new password and record the time when the new password is set, and will allow the user to log in.
l           If the user chooses not to change the password or fails to change the password, the user can still log in normally before the password expires.
2)         If the user password has expired, the system will notify the user about the expiration of the password, as follows:
your password has  expired ,please enter a  new password  :
password: **********
confirm :**********
Namely, the user must enter a new password. After entering a new password, the user needs to confirm it by entering it again. If the password is not appropriate, or if the second input is different from the first input, the system will ask the user to enter a password again; otherwise the user cannot log in successfully.
3)         If the user’s password has not expired and the gap between the aging time and the expiration time is not in the range of alert time, the user can normally log in.
After the user successfully changes his or her password, the current password is saved into the file in the flash memory.
The password for super commands is processed in a similar way. However, no pre-expiration alert is given when the super password is to expire; the user is only notified whether the password has expired or not.
For an FTP user, no pre-expiration alert is given either when the password is to expire. The user is only notified about password errors but cannot change the password. Only the administrator can change the password.
Table 6-2 Configuring system password aging time
Operation
Enter system view
Configure password aging time
The value range of password aging time is 1 to 365 days. By default, the password aging time is 90 days.
This command can also be carried out in user view
The configuration command for password aging time can be used either in the system view or in the user view. In the system view, this command is used to configure global parameters; in the user view, this command is used to configure the parameters for the user. When user parameters conflict with system parameters, the parameters configured in the user view will prevail.
II. Configuring alert time before password expires
Within the set period of time before the user password expires, the system will automatically give the following reminder information:  Your password will expire in  2 days ,Will you  change it ? [Y/N], to remind the user of the remaining number of days in which the password will expire, and ask the user whether to change the password.
Table 6-3 Configuring alert time before password expiration
Operation
Enter system view
Configure alert time before password expires
The range of pre-expiration alert time is 1 to 30 days. By default, the alert time is 7 days.
III. Configuring minimum length of password
There is a limitation for the minimum length of user-configured passwords. When a user configures a password, the system checks the password length. If the length of the password entered by the user is impropriate, the system will give a prompt message to the user and ask the user to enter a new password.
If the password entered by the user is shorter than the set minimum length, the system will refuse this password, and will give the following prompt message: Password is too short. Please enter minimum length password.
The password for super commands is processed in the same way.
Table 6-4 Configuring minimum password length
Operation
Enter system view
Configure the minimum password length
The value range of the minimum password length is 4 to 32 characters. The default value is 10 characters.
The configuration of minimum password length involves two situations: the global configuration command can be used in the system view to configure the minimum length of all user passwords, and the minimum password length can be configure for a certain user in the user view. Similar to the password aging time configuration, when the two types of parameters conflict, the parameters configured in the user view will prevail.
IV. Configuring the maximum number of attempts of entering a password and the processing mode for failed login attempts
There is a limitation of the number of entering a password. When the number of attempts exceeds the configured maximum number of attempts, the system will have three options:
l           The system will add the user to the blacklist and lock the user for a period of time by putting the user name + IP address and the lock time into the blacklist. Each time when the user logs in, the system will search in the blacklist. If the user name and IP address appear in the blacklist, the system will directly prohibit the user from going into password authentication. After a preset period of time, the system will remove the user from the backlist and re-activate the user. The lock time is specified by the system administrator. The value range is 3 to 360 minutes, and the default value is 120 minutes.
l           The system will permanently lock the user. In this case, the user can log in again only if he or she is removed from the blacklist and unlocked by the administrator manually. The blacklist can contain a maximum of 1024 entries.
l           The system will allow the user to log in again instead of locking him or her.
Once the system administrator manually removes locked users from the blacklist, these user are unlocked and can log in to the switch again.
Table 6-5 Configuring the maximum number of attempts and the processing mode for failed login attempts
Operation
Enter system view
Configure the maximum number of attempts of entering a password
password-control login-attempt login-times
The value range of the maximum attempts of entering a password is 2 to 10; the default value is 3
Configure the processing mode for failed login attempts
password-control login-attempt attempt-time exceed { lock | unlock | locktime time }
By default, the system will lock the user and allow him/her to log in again a period of time later
View information of users added to the blacklist
Remove a user or users from the blacklist
reset password-control blacklist [ username username ]
If the command is carried out without username, all users will be removed from the blacklist
If the command is carried out with username, the specified user will be removed from the blacklist
V. Configuring the maximum number of history password records
When a password used to log in to the system expires, the system will ask the user to enter a new password and will automatically save the password. You can configure the maximum number of history records allowable for each user. The purpose is to prevent users from using a single password or repeated passwords, thus enhancing the security.
Table 6-6 Configuring the maximum number of history password records
Operation
Enter system view
Configure the maximum number of history password records
password-control history max-record-num
The value range of maximum number of history password records is 2 to 10, and the default value is 4
  Caution:
l      When a new password is added but the number of the recorded history passwords has reached the configured maximum number, the system replaces the oldest record with the new one.
l      When you configure the maximum number of history password records, if the number of history password records is larger than the configured value, the system will give a prompt and allow you to make configuration for the user.
l      When changing a password, do not use any recorded history password; otherwise, the system will give the following prompt: The system failed to assign password. It has been used previously. In this case, the change to the password will not take effect, and you need to configure another password.
VI. Configuring the timeout time for password authentication
An authentication process for a user starts when the server obtains the user name and ends when the password authentication is completed for the user.
If the password authentication is not completed before the authentication times out, the authentication fails, and the system will terminate the user connection and record the log information; if the password authentication is completed before the authentication times out, the user will log in to the switch normally.
Table 6-7 Configuring the timeout time for password authentication
Operation
Enter system view
Configure password timeout time
password-control authentication-timeout authentication-timeout
The value range of password authentication timeout time is 30 to 120 seconds, and the default value is 60 seconds
6.2.3  System Logging Function
The system can automatically log related information in case of the following events:
l           When a user logs in successfully, the system will log the user name, IP address, and VTY number
l           When a user is prohibited by the ACL rule, the system will log the user’s IP address
l           When a user fails in authentication, the system will log the user name, IP address, VTY number, and failure cause
l           When a user changes his or her password that has expired, the system will log the password change event
The administrator can query the login information of users based on these log records.
6.2.4  Password Control Configuration Example
I. Network requirements
A PC is connected with an S9500 switch. You can either use the default configuration or configure the password control parameters as required.
II. Network diagram
Figure 6-1 Network diagram for password control configuration
III. Configuration procedure
# Configure the system login password:
<H3C> system-view
[H3C] local-user test
[H3C-luser-test] password
Password:**********
confirm:**********
# Change the system login password to 0123456789:
Password:**********
Confirm :**********
Updating  password-file  ,please waiting ...
# Enable password aging:
[H3C] password-control aging enable
Password aging enabled for all users. Default: 90 days.
# Enable limitation of the minimum password length:
[H3C] password-control length  enable
Password minimum length enabled for all users. Default: 10 characters.
# Enable history password recording:
[H3C] password-control history enable
Password history enabled for all users.
# Set the aging time of super passwords to 10 days:
[H3C] password-control super aging 10
# Display the password control information of all users:
[H3C] display password-control
Global password settings for all users:
 Password aging:                      Enabled(90 days)
 Password length:                     Enabled(10 Characters)
 Password history:                    Enabled(Max history records:4)
 Password alert-before-expire :       7 days
 Password authentication-timeout :    60 seconds
 Password attempt times :             3 times
 Password attempt-failed action :     Lock for 120 minutes
# Display the user names and the corresponding IP addresses added to the blacklist because of password attempt failure:
[H3C] display password-control blacklist
USERNAME                        IP
The number of users in blacklist is :0
# Delete the history password records of all users:
<H3C> reset password-control history-record
Are you sure to delete all  the  history record?[Y/N]
If you type "Y", the system will delete the history records of all users and gives the following prompt:
Updating the password file, please wait...
 All historical passwords have been cleared.
