H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
12-IPv6 Configuration Command
12-IPv6 Configuration Command 330 KB
Table of Contents
Chapter 1 IPv6 Configuration Commands. 1-1
1.1 Basic IPv6 Configuration Commands. 1-1
1.1.1 display dns ipv6 dynamic-host 1-1
1.1.2 display ipv6 fib. 1-1
1.1.3 display ipv6 fibcache. 1-3
1.1.4 display ipv6 host 1-3
1.1.5 display ipv6 interface. 1-4
1.1.6 display ipv6 neighbors. 1-6
1.1.7 display ipv6 neighbors count 1-7
1.1.8 display ipv6 pathmtu. 1-8
1.1.9 display ipv6 socket 1-9
1.1.10 display ipv6 statistics. 1-11
1.1.11 display tcp ipv6 statistics. 1-14
1.1.12 display tcp ipv6 status. 1-17
1.1.13 display udp ipv6 statistics. 1-18
1.1.14 dns server ipv6. 1-19
1.1.15 ipv6. 1-20
1.1.16 ipv6 address. 1-20
1.1.17 ipv6 address auto link-local 1-21
1.1.18 ipv6 address eui-64. 1-22
1.1.19 ipv6 address link-local 1-23
1.1.20 ipv6 fibcache. 1-23
1.1.21 ipv6 fib-loadbalance-type hash-based. 1-24
1.1.22 ipv6 host 1-25
1.1.23 ipv6 icmp-error 1-25
1.1.24 ipv6 nd autoconfig managed-address-flag. 1-26
1.1.25 ipv6 nd autoconfig other-flag. 1-27
1.1.26 ipv6 nd dad attempts. 1-27
1.1.27 ipv6 nd hop-limit 1-28
1.1.28 ipv6 nd ns retrans-timer 1-29
1.1.29 ipv6 nd nud reachable-time. 1-29
1.1.30 ipv6 nd ra halt 1-30
1.1.31 ipv6 nd ra interval 1-31
1.1.32 ipv6 nd ra prefix. 1-32
1.1.33 ipv6 nd ra router-lifetime. 1-33
1.1.34 ipv6 neighbor 1-33
1.1.35 ipv6 neighbors max-learning-num.. 1-34
1.1.36 ipv6 pathmtu. 1-35
1.1.37 ipv6 pathmtu age. 1-35
1.1.38 reset dns ipv6 dynamic-host 1-36
1.1.39 reset ipv6 fibcache. 1-37
1.1.40 reset ipv6 neighbors. 1-37
1.1.41 reset ipv6 pathmtu. 1-38
1.1.42 reset ipv6 statistics. 1-38
1.1.43 reset tcp ipv6 statistics. 1-39
1.1.44 reset udp ipv6 statistics. 1-39
1.1.45 tcp ipv6 timer fin-timeout 1-40
1.1.46 tcp ipv6 timer syn-timeout 1-40
1.1.47 tcp ipv6 window. 1-41
Chapter 2 IPv6 Application Configuration Commands. 2-1
2.1 IPv6 Application Configuration Commands. 2-1
2.1.1 ping ipv6. 2-1
2.1.2 telnet ipv6. 2-2
2.1.3 tftp ipv6. 2-3
2.1.4 tftp-server ipv6 acl 2-4
2.1.5 tracert ipv6. 2-5
Chapter 3 Dual Stack Configuration Commands. 3-1
3.1 Dual Stack Configuration Commands. 3-1
3.1.1 display switch-mode. 3-1
3.1.2 switch-mode. 3-1
Chapter 4 Tunneling Configuration Commands. 4-1
4.1 Tunnel Configuration Commands. 4-1
4.1.1 aggregation-group. 4-1
4.1.2 destination. 4-2
4.1.3 display interface Tunnel 4-3
4.1.4 display ipv6 interface Tunnel 4-4
4.1.5 expediting enable. 4-6
4.1.6 expediting subnet 4-7
4.1.7 interface Tunnel 4-8
4.1.8 peer enable. 4-8
4.1.9 source. 4-9
4.1.10 tunnel-protocol 4-10
View
Parameter
None
Use the display dns ipv6 dynamic-host command to display IPv6 dynamic domain name cache information.
Example
# Display IPv6 dynamic domain name cache information.
<Sysname> display dns ipv6 dynamic-host
No.  Domain-name     IPv6 Address        TTL
1        aaa             3001::2         6
Table 1-1 Description on fields of the display dns ipv6 dynamic-host command
No.
Sequence number
Domain-name
Domain name
IPv6 Address
IPv6 address corresponding to the domain name
TTL
Lifetime of a domain name cache information entry in seconds
display ipv6 fib [ ipv6-address ]
View
Parameter
ipv6-address: IPv6 address. An FIB entry whose destination address is this address will be displayed.
Use the display ipv6 fib command to display one specific FIB entry, or all FIB entries if no parameter is provided.
Example
# Display all FIB entries.
<Sysname> display ipv6 fib
 FIB Table:
 Total number of Routes : 1
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination: ::1                         PrefixLength    : 128
NextHop     :    ::1                         Flag            : HU
Label       :    NULL                            Tunnel ID   : 0
TimeStamp  : Date- 12/5/2004, Time- 9:15:18
Interface  : InLoopBack0
Table 1-2 Description on fields of the display ipv6 fib command
Total number of routes in the FIB
Destination
Destination address to which a packet is forwarded
PrefixLength
Prefix length of the destination address
NextHop
Next hop address when a packet is forwarded to the destination
Flag
Route flag:
“U” — Usable route
“G” — Gateway route
“H” — Host route
“B” — Blackhole route
“D” — Dynamic route
“S” — Static route
Label
Label
Tunnel ID
ID of a tunnel
TimeStamp
Generation time of an FIB entry
Interface from which a packet is forwarded
View
Parameter
None
Use the display ipv6 fibcache command to display the total number of routes in the FIB cache.
Example
# Display information in the FIB cache.
<Sysname> display ipv6 fibcache
FIB Cache:
 Total number of Routes : 0
display ipv6 host
View
Parameter
None
Use the display ipv6 host command to display the mapping between host name and IPv6 address.
Example
# Display the mapping between host name and IPv6 address.
<Sysname> display ipv6 host
Host                 Age           Flags  IPv6Address (es)
SWB                  0             static  2002::1
Table 1-3 Description on fields of the display ipv6 host command
Host
Host name
Age
Time for the entry to live, displayed as 0 in the case of static configuration.
Flags
Flag indicating whether the entry is configured statically or acquired dynamically
IPv6Address (es)
IPv6 address corresponding to a host name
display ipv6 interface [ interface-type interface-number | brief ]
View
Parameter
interface-type: Interface type.
interface-number: Interface number.
brief: Displays the brief IPv6 information of an interface.
Use the display ipv6 interface command to display the IPv6 information of a specified interface.
When neither the interface type nor the interface number is provided, the IPv6 information of all interfaces is displayed.
Example
# Display the IPv6 information of a VLAN interface.
<Sysname> display ipv6 interface Vlan-interface 1
Vlan-interface1 current state : UP ,
Line protocol current state : UP
IPv6 is enabled, link-local address is FE80::200:1FF:FE04:5D00
  Global unicast address(es):
    2001::1, subnet is 2001::/64
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF04:5D00
    FF02::2
    FF02::1
  MTU is 1500 bytes
Table 1-4 Description on fields of the display ipv6 interface command
Physical state of an interface
Link layer protocol state of an interface
IPv6 is enabled
IPv6 forwarding state of an interface (IPv6 is enabled in the example)
link-local address
Link-local address configured on an interface
Aggregatable global unicast address configured on an interface
Address of the multicast group that an interface joins
MTU
Maximum transmission unit of an interface
Number of duplicate address detection (DAD) attempts, with DAD enabled
ND reachable time
Neighbor reachable time
Interval for retransmitting a neighbor solicitation (NS) message
Hosts use stateless auto-configuration mode to acquire IPv6 addresses
#: View the brief IPv6 information of all interfaces.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                          Physical   Protocol       IPv6 Address
LoopBack0                            up          up(s)       Unassigned
Vlan-interface1                     up          up           2001::1
Table 1-5 Description on fields of the display ipv6 interface brief command
*down
The interface is down, that is, the interface is disabled by using the shutdown command.
(s)
Spoofing attribute of the interface, that is, the link protocol state of the interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Name of the interface
Physical
Physical state of the interface
Protocol
Link protocol state of an interface
IPv6 Address
IPv6 address of the interface (If no address is configured for the interface, “Unassigned” will be displayed.)
display ipv6 neighbors { ipv6-address | all | dynamic | static | interface interface-type interface-number | vlan vlan-id } [ | { begin | exclude | include } text ]
View
Parameter
ipv6-address: IPv6 address whose neighbor information is to be displayed.
all: Displays information of all neighbors, including neighbors acquired dynamically and configured statically.
dynamic: Displays information of all neighbors acquired dynamically.
interface interface-type interface-number: Displays information of the neighbors of a specified interface.
static: Displays information of all neighbors configured statically.
vlan vlan-id: Displays information of the neighbors of a specified VLAN, in the range of 1 to 4094.
|: Enables output information filtering.
begin: Displays the neighbor entries beginning with the specified character string.
include: Displays the neighbor entries containing the specified character string.
exclude: Displays the neighbor entries without the specified character string.
text: Character string.
Use the display ipv6 neighbors command to display neighbor information.
Example
# View all neighbor information.
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address             Link-layer      VID Interface   State   T   Age
FE80::200:5EFF:FE32:B800 0000-5e32-b800  1   Eth1/0/1        REACH   S   -
Table 1-6 Description on fields of the display ipv6 neighbors command
IPv6 Address
IPv6 address
Link-layer
Link layer address (MAC address of a neighbor)
VID
VLAN ID
Interface connected with a neighbor
State of a neighbor
T
Type of neighbor information, including static configuration and dynamic acquisition.
Age
For a static entry, “-“ is displayed. For a dynamic entry, the time (in seconds) since it is reachable last time is displayed, and if it is never reachable, “#” is displayed (for a dynamic neighbor only).
display ipv6 neighbors { all | dynamic | static | interface interface-type interface-number | vlan vlan-id } count
View
Parameter
all: Displays the total number of all neighbor entries, including neighbor entries acquired dynamically and configured statically.
dynamic: Displays the total number of all neighbor entries acquired dynamically.
interface interface-type interface-number: Displays the total number of neighbor entries of a specified interface.
static: Displays the total number of all neighbor entries configured statically.
vlan vlan-id: Displays the total number of neighbor entries of a specified VLAN, in the range of 1 to 4094.
count: The number of neighbor entries.
Use the display ipv6 neighbors count command to display the total number of neighbor entries satisfying the specified condition.
Example
# Display the total number of neighbor entries acquired dynamically.
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 pathmtu { ipv6-address | all | dynamic | static }
View
Parameter
ipv6-address: IPv6 address whose PMTU information is to be displayed.
all: Displays all PMTU information.
dynamic: Displays all dynamic PMTU information.
static: Displays all static PMTU information.
Use the display ipv6 pathmtu command to display the PMTU information of IPv6 addresses.
Example
# Display all PMTU information.
<Sysname> display ipv6 pathmtu all
Ipv6 Destination Address ZoneID  PathMTU     Age     Type
 fe80::12                    0       1300            40      Dynamic
 2222::3                 0       1280            --      Static
Table 1-7 Description on fields of the display ipv6 pathmtu command
Destination IPv6 address
ZoneID
Address zone, currently invalid
PathMTU
PMTU of an IPv6 address
Age
Lifetime of a PMTU. For a static PMTU, “--“ is displayed.
Indicates the PMTU is dynamically negotiated or statically configured.
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ]
View
Parameter
socket-type: Type of a socket, in the range of 1 to 3. The value “1” represents a TCP socket, “2” a UDP socket, and “3” a raw IP socket.
task-id: ID of a task, in the range of 1 to 100.
socket-id: ID of a socket, in the range of 0 to 3072.
Use the display ipv6 socket command to display information related to a specified socket.
With no argument specified, this command displays the information about all the sockets.
Example
# Display information related to a specified socket.
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
SOCK_RAW:
Table 1-8 Description on fields of the display ipv6 socket command
SOCK_STREAM
Socket type of TCP
SOCK_DGRAM
Socket type of UDP
SOCK_RAW
Socket type of raw IP
Task ID of the created socket
socketid
ID assigned by the kernel to the created socket
Proto
Protocol ID
LA
Local address and local port number
FA
Remote address and remote port number
sndbuf
Size of the sending buffer
rcvbuf
Size of the receiving buffer
sb_cc
Number of bytes sent by the sending buffer
rb_cc
Number of bytes received by the receiving buffer
socket option
Socket option set by the application
socket state
State of the socket
View
Parameter
None
Use the display ipv6 statistics command to display statistics of IPv6 packets and ICMPv6 packets.
Example
# View the statistics of IPv6 packets and IPv6 ICMP packets.
<Sysname> display ipv6 statistics
  IPv6 Protocol:
    Sent packets:
      Total:       0
        Local sent out:          0       orwarded:           0
        raw packets:         0       discarded:          0
        routing failed:          0       fragments:          0
        fragments failed:        0
    Received packets:
      Total:       0
        local host:              0       hopcount exceeded:  0
        format error:            0       option error:       0
        protocol error:          0       fragments:          0
        reassembled:         0       reassembly failed:  0
        reassembly timeout:      0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        unreached:               0       too big:                0
        hopcount exceeded:       0       reassembly timeout: 0
        parameter problem:       0
        echo request:            0       echo replied:       0
        neighbor solicit:        0       neighbor advert:        0
        router solicit:          0       router advert:      0
        redirected:              0
      Send failed:
        ratelimited:         0       other errors:       0
    Received packets:
      Total:      0
        checksum error:          0       too short:          0
        bad code:                0
        parameter problem:       0       unknown error type: 0
        echoed:              0       echo replied:       0
        redirected:              0       router renumbering: 0
        unknown info type:       0
      Deliver failed:
        bad length:              0       ratelimited:            0
Table 1-9 Description on fields of the display ipv6 statistics command
IPv6 Protocol:
Statistics of IPv6 packets
Sent packets:
 Total:      0
  Local sent out:  0   forwarded:    0
  fragments failed: 0
Statistics of sent IPv6 packets, including:
Total number of sent packets
Number of packets sent locally
Number of forwarded packets
Number of packets sent via raw socket
Number of discarded packets
Number of packets with routing failure
Number of sent fragment packets
Number of fragment sending failures
Received packets:
 Total:      0
Statistics of received IPv6 packets, including
Total number of received packets
Number of packets received locally
Number of packets exceeding the hops
Number of packets in an incorrect format
Number of packets with incorrect options
Number of packets with incorrect protocol
Number of received fragment packets
Number of reassembled packets
Number of packets whose reassembly fails
Number of packets whose reassembly times out
ICMPv6 protocol:
Statistics of ICMPv6 packets
Sent packets:
 Total:      0
  router solicit:      0  router advert        0
  redirected:        0
 Send failed:
Statistics of sent ICMPv6 packets, including
Number of packets whose destination is unreachable
Number of too large packets
Number of packets exceeding the hop limit
Number of packets whose fragmentation and reassembly time out
Number of packets with parameter errors
Number of request packets
Number of response packets
Number of neighbor solicitation packets
Number of neighbor advertisement packets
Number of router solicit packets
Number of router advertisement packets
Number of redirected packets
Number of packets failing to be sent because of rate limitation
Number of packets with other errors
Received packets:
 Total:      0
  bad code:          0
  redirected:        0  router renumbering  0
  Deliver failed:
Statistics of received ICMPv6 packets, including
Number of packets with checksum errors
Number of too small packets
Number of packets with error codes
Number of packets with unknown errors
Number of neighbor solicitation messages
Number of router solicitation packets
Number of packets  recounted by the router
Number of unknown information type of packets
Number of packets with a incorrect size
Number of packets failing to be received because of rate limitation
View
Parameter
None
Use the display tcp ipv6 statistics command to display statistics of IPv6 TCP packets.
Example
# View the statistics of received and sent IPv6 TCP packets.
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Table 1-10 Description on fields of the display tcp ipv6 statistics command
Received packets:
     Total: 0
Statistics of received packets, including
Number of packets received in sequence
Number of  window probe packets
Number of  window size update packets
Number of packets with offset errors
Number of packets whose total length is less than that specified by the packet header
Number of duplicate packets
Number of partially duplicate packets
Number of out-of-order packets
Number of packets exceeding the receiving window size
Number of packets after the connection is closed
Number of  ACK packets
Number of duplicate ACK packets/excessive ACK packets
Sent packets:
     Total: 0
     urgent packets: 0
Statistics of sent packets, including
Total number of packets
Number of packets containing an urgent indicator
Number of control packets
Number of window update packets
Number of data packets
Number of retransmitted packets
Number of ACK only packets
Number of packets whose retransmission times out
Number of connections dropped because of retransmission timeout
Keepalive timeout
Number of keepalive timeouts
Keepalive probe
Number of keepalive probes
Number of connections dropped because of keepalive response timeout
Number of initiated connections
Number of accepted connections
Number of established connections
Closed connections
Number of closed connections
dropped
Number of dropped connections (after receiving SYN from the peer)
initiated dropped
Number of connection failures (before receiving SYN from the peer)
View
Parameter
None
Use the display tcp ipv6 status command to display the IPv6 TCP connection status.
Example
# View the IPv6 TCP connection status.
<Sysname> display tcp ipv6 status
TCP6CB       Local Address       Foreign Address      State
045d8074    ::->21                ::->0                  Listening
Table 1-11 Description on fields of the display tcp ipv6 status command
TCP6CB
IPv6 address of the TCP control block (hexadecimal)
Local Address
Local IPv6 address
Foreign Address
Remote IPv6 address
TCP connection status, including
Closed
Listening
Syn_Sent
Syn_Rcvd
Established
Close_Wait
Fin_Wait1
Closing
Last_Ack
Fin_Wait2
Time_Wait
View
Parameter
None
Use the display udp ipv6 statistics command to display statistics of IPv6 UDP packets.
Example
# View statistics of IPv6 UDP packets.
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 1-12 Description on fields of the display udp ipv6 statistics command
Total
Total number of received/sent packets
checksum error
Total number of packets with an invalid checksum
shorter than header
Total number of IPv6 UDP packets whose total length is less than that specified by the packet header
Total number of packets whose data length exceeds that specified by the packet header
Total number of received unicast packets without any socket on a port
Total number of received broadcast/multicast packets without any socket on a port
Number of packets not handled because of the receiving buffer being full
input packet missing pcb cache
Number of packets that do not match any entry in the PCB cache
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
View
Parameter
ipv6-address: IPv6 address of a DNS server.
interface-type interface-number: Interface type and interface number when the IPv6 address of the specified DNS server is a link-local address.
Use the dns server ipv6 command to configure an IPv6 address for a DNS server.
Use the undo dns server ipv6 command to remove the configured DNS server.
By default, no DNS server is configured.
Example
# Configure the IPv6 address 2002::1 for a DNS server.
[Sysname] dns server ipv6 2002::1
1.1.15  ipv6
ipv6
undo ipv6
View
Parameter
None
Use the ipv6 command to enable the IPv6 function.
Use the undo ipv6 command to disable the IPv6 function.
By default, the IPv6 function is disabled.
Example
# Enable the IPv6 function.
[Sysname] ipv6
1.1.16  ipv6 address
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
View
Interface view
Parameter
prefix-length: Prefix length of an IPv6 address, in the range of 1 to 128.
Use the ipv6 address command to configure a site-local address or global unicast address manually for an interface.
Use the undo ipv6 address command to remove the manually configured interface address.
By default, no site-local address or global unicast address is configured for an interface.
Note that:
l           Up to five aggregatable global unicast address(es) or site-local address(es) can be configured on an interface at a time.
l           The prefix length can only be 128 bits when the aggregatable global unicast address(es) or site-local address(es) is configured in the LoopBack interface view.
l           You will remove all IPv6 addresses except the automatically configured link-local address if you carry out the undo ipv6 address command without any parameter,
Example
# Set the aggregatable global IPv6 unicast address of the VLAN 100 interface to 2001::1/64.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
undo ipv6 address auto link-local
View
Interface view
Parameter
None
Use the ipv6 address auto link-local command to automatically generate a link-local address for an interface.
Use the undo ipv6 address auto link-local command to remove the automatically generated link-local address for an interface.
By default, a link-local address is generated automatically after a site-local IPv6 address or global unicast address is configured for the interface.
Example
# Configure the VLAN 100 interface to automatically generate a link-local address.
[Sysname] interface Vlan-interface 100
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address ipv6-address/prefix-length eui-64
undo ipv6 address ipv6-address/prefix-length eui-64
View
Interface view
Parameter
ipv6-address/prefix-length: IPv6 address and IPv6 prefix. The ipv6-address and prefix-length arguments jointly specify the prefix of an IPv6 address in the EUI-64 format. The prefix length of an EUI-64 address cannot be greater than 64.
Use the ipv6 address eui-64 command to configure a site-local address or global unicast address in the EUI-64 format for an interface.
Use the undo ipv6 address eui-64 command to remove the configured site-local address or global unicast address in the EUI-64 format for an interface.
By default, no site-local address or global unicast address in the EUI-64 format is configured on the interface.
Note that:
l           The prefix length should not be more than 64 bits when the aggregatable global unicast address(es) or site-local address(es) in the EUI-64 format is configured in the VLAN interface view.
l           The prefix length can only be 128 bits when the aggregatable global unicast address(es) or site-local address(es) in the EUI-64 format is configured in the LoopBack interface view.
Example
# Configure an IPv6 address in the EUI-64 format for the VLAN 100 interface.
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
View
Interface view
Parameter
ipv6-address: IPv6 link-local address. The first ten bits of an address must be 1111111010 (binary), that is, the first group of hexadecimals in the address must be FE80 to FEBF.
Use the ipv6 address link-local command to configure a link-local address manually for a specified interface.
Use the undo ipv6 address link-local command to remove the configured link-local address for an interface.
Example
# Configure a link-local address for the VLAN 100 interface.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
ipv6 fibcache
undo ipv6 fibcache
View
Parameter
None
Use the ipv6 fibcache command to enable the IPv6 FIB caching function.
Use the undo ipv6 fibcache command to disable the IPv6 FIB caching function.
By default, the IPv6 FIB caching function is disabled.
Note that the FIB caching function valid only for forwarded packets.
Example
# Enable the IPv6 FIB caching function.
[Sysname] ipv6 fibcache
undo ipv6 fib-loadbalance-type hash-based
View
Parameter
None
Use the ipv6 fib-loadbalance-type hash-based command to specify the load sharing mode based on the HASH algorithm for packet forwarding so that packets from the same source address can be forwarded from the same next-hop address.
Use the undo ipv6 fib-loadbalance-type hash-based command to restore the load sharing mode to the default load sharing based on polling.
By default, the load sharing based on polling is adopted, that is, each equivalent route is used in turn to forward packets.
Example
# Specify packets from the same source address to be forwarded out of the same next-hop address.
[Sysname] ipv6 fib-loadbalance-type hash-based
1.1.22  ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
View
Parameter
hostname: Host name, a string of up to 20 characters. The character string can contain letters, numerals, “_”, “-“, or “.” and must contain at least one letter.
Use the ipv6 host command to configure the mapping between host name and IPv6 address.
Use the undo ipv6 host command to remove the mapping between host name and IPv6 address.
Each host name can correspond to at most eight IPv6 addresses.
Example
# Configure the mapping between host name and IPv6 address.
[Sysname] ipv6 host aaa 2001::1
ipv6 icmp-error { bucket bucket-size | ratelimit interval }*
undo ipv6 icmp-error
View
Parameter
bucket-size: Number of tokens in a token bucket, in the range of 1 to 200. The default value is 10.
interval: Update period of the token bucket in milliseconds, in the range of 0 to 2,147,483,647.
Use the ipv6 icmp-error command to configure the maximum number of IPv6 ICMP error packets sent within a specified time.
Use the undo ipv6 icmp-error command to restore the update period and the capacity of the token bucket to the defaults.
By default, the size is 10 and the update period is 100 milliseconds. That is, at most 10 IPv6 ICMP error packets can be sent within 100 milliseconds.
Example
# Set the capacity of the token bucket to 50 and the update period to 100 milliseconds. That is, at most 50 IPv6 ICMP error packets can be sent within 100 milliseconds.
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
undo ipv6 nd autoconfig managed-address-flag
View
Interface view
Parameter
None
Use the ipv6 nd autoconfig managed-address-flag command to set the M flag (configuration flag of the managed address) to 1 so that the host can acquire an IPv6 address through stateful auto-configuration (for example, DHCP server).
Use the undo ipv6 nd autoconfig managed-address-flag command to restore the M flag to the default value “0” so that the host can acquire an IPv6 address through stateless auto-configuration.
By default, the M flag is set to 0.
Example
# Configure the host to acquire an IPv6 address through stateful auto-configuration.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
undo ipv6 nd autoconfig other-flag
View
Interface view
Parameter
None
Use the ipv6 nd autoconfig other-flag command to set the O flag (configuration flag of other information) to 1 so that the host can acquire information other than IPv6 address through stateful auto-configuration (for example, DHCP server).
Use the undo ipv6 nd autoconfig other-flag command to remove the setting so that the host can acquire other information through stateless auto-configuration.
By default, the O flag is set to 0.
Example
# Configure the host to acquire information other than IPv6 address through stateless auto-configuration.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
View
Interface view
Parameter
value: Number of attempts to send a neighbor solicitation message for duplicate address detection, in the range of 0 to 600. The default value is “1”.When it is set to 0, the duplicate address detection is disabled.
Use the ipv6 nd dad attempts command to configure the attempts to send a neighbor solicitation message for duplicate address detection.
Use the undo ipv6 nd dad attempts command to restore the attempts to send a neighbor solicitation message for duplicate address detection to the default.
By default, the number of attempts to send a neighbor solicitation message for duplicate address detection is 1.
Example
# Set the attempts to send a neighbor solicitation message for duplicate address detection to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
View
Parameter
value: Number of hops, in the range of 0 to 255. The default value is 64.When it is set to 0, the Hop Limit field in RA messages sent by the device is 0, that is, no host is designated.
Use the ipv6 nd hop-limit command to configure the hop limit issued by the device.
Use the undo ipv6 nd hop-limit command to restore the hop limit to the default.
By default, the hop limit issued by the device is 64.
Example
# Set the hop limit issued by the device to 100.
[Sysname] ipv6 nd hop-limit 100
undo ipv6 nd ns retrans-timer
View
Interface view
Parameter
value: Interval for retransmitting an NS message in milliseconds, in the range of 1,000 to 3,600,000.
Use the ipv6 nd ns retrans-timer command to set the interval for retransmitting an NS message. The local interface retransmits an NS message at intervals of this value. Furthermore, the Retrans Timer field in RA messages sent by the local interface is equal to this value.
Use the undo ipv6 nd ns retrans-timer command to restore the interval for retransmitting an NS message to the default and specify the value of the Retrans Timer field to 0 so that no host can be designated.
By default, the local interface sends NS messages at intervals of 1,000 milliseconds and the Retrans Timer field in RA messages sent by the local interface is equal to 0.
Example
# Specify the VLAN 100 interface to send an NS message at intervals of 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
View
Interface view
Parameter
value: Neighbor reachable time in milliseconds, in the range of 1 to 3,600,000.
Use the ipv6 nd nud reachable-time command to configure the neighbor reachable time on an interface. This time value serves as not only the neighbor reachable time on the local interface, but also the value of the Reachable Timer field in RA messages sent by the local interface.
Use the undo ipv6 nd nud reachable-time command to restore the neighbor reachable time to the default and to specify the value of the Reachable Timer field in RA messages to 0 so that no host can be designated.
By default, the neighbor reachable time on the local interface is 30,000 milliseconds and the Reachable Timer field in RA messages is 0.
Example
# Set the neighbor reachable time on the VLAN-interface100 to 10,000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
undo ipv6 nd ra halt
View
Interface view
Parameter
None
Use the ipv6 nd ra halt command to suppress RA messages.
Use the undo ipv6 nd ra halt command to disable the RA message suppression.
By default, RA messages are suppressed.
Example
# Suppress RA messages on the VLAN 100 interface.
[Sysname-Vlan-interface100] ipv6 nd ra halt
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
View
Interface view
Parameter
max-interval-value: Maximum interval for sending RA messages in seconds, in the range of 4 to 1,800.
min-interval-value: Minimum interval for sending RA messages in seconds, in the range of 3 to 1,350.
Use the ipv6 nd ra interval command to set the maximum and the minimum interval for sending RA messages. The device sends RA messages at intervals of a random value between the maximum interval and the minimum interval.
Use the undo ipv6 nd ra interval command to restore the maximum and the minimum interval to the default.
By default, the maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Note that:
l           The configured minimum interval must be less than or equal to 0.75 times of the maximum interval.
l           The actual maximum interval to send RA messages must be less than or equal to the keepalive time of RA messages.
Example
# Set the maximum interval for sending RA messages to 1,000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra prefix { ipv6-address prefix-length | ipv6-address/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ]*
undo ipv6 nd ra prefix ipv6-address
View
Interface view
Parameter
ipv6-address: IPv6 address or IPv6 address prefix.
prefix-length: Prefix length of an IPv6 address, a number ranging from 1 to 128.
ipv6-prefix: IPv6 address prefix to be specified.
valid-lifetime: Valid lifetime of a prefix in seconds, in the range of 0 to 4,294,967,295.
preferred-lifetime: Preferred lifetime of a prefix used for stateless auto-configuration in seconds, in the range of 0 to 4,294,967,295.
no-autoconfig: Specifies a prefix not be used for stateless auto-configuration. If this keyword is not provided, the prefix is used for stateless auto-configuration.
off-link: Specifies the address with the prefix not to be directly reachable on the link. If this keyword is not provided, the address with the prefix is directly reachable on the link.
Use the ipv6 nd ra prefix command to configure the prefix information in RA messages.
Use the undo ipv6 nd ra prefix command to remove the prefix information from RA messages.
By default, no prefix information is configured in RA messages and the IPv6 address of the interface sending RA messages is used as the prefix information.
Example
# Configure the prefix information for RA messages on the VLAN 100 interface.
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
View
Interface view
Parameter
value: Lifetime of RA messages in seconds, in the range of 0 to 9,000. The default value is 1800. When it is set to 0, the device does not serve as a default router.
Use the ipv6 nd ra router-lifetime command to configure the lifetime of RA messages.
Use the undo ipv6 nd ra router-lifetime command to restore the configuration to the default.
Note that the lifetime of RA messages should be greater than or equal to the sending interval.
Example
# Set the lifetime of RA messages on the VLAN 100 interface to 1,000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
View
Parameter
ipv6-address: IPv6 address in a static neighbor entry.
mac-address: Link layer address in a static neighbor entry (48 bits long, in the format of H-H-H).
vlan-id: VLAN ID corresponding to a static neighbor entry, in the range of 1 to 4094.
port-type port-number: Layer 2 port corresponding to a static neighbor entry.
interface-type interface-number: Layer 3 interface corresponding to a static neighbor entry.
Use the ipv6 neighbor command to configure a static neighbor entry.
Use the undo ipv6 neighbor command to remove a static neighbor entry.
Note that the corresponding VLAN interface must exist when you carry out the command with the vlan-id port-type port-number argument. After you carry out the command, the device relates the VLAN interface to an IPv6 address to uniquely identify a static neighbor entry. You only need to specify the corresponding VLAN interface before removing a static neighbor entry.
Example
# Configure a static neighbor entry for Ethernet1/0/1 of VLAN 100.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 100 Ethernet 1/0/1
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
View
Interface view
Parameter
number: Maximum number of neighbors that can be dynamically learned by an interface, in the range of 1 to 2,560.
Use the ipv6 neighbors max-learning-num command to configure the maximum number of neighbors that can be dynamically learned on a specified interface.
Use the undo ipv6 neighbors max-learning-num command to restore the configuration to the default.
By default, the maximum number is 2,560.
Example
# Set the maximum number of neighbors that can be dynamically learned on the VLAN 100 interface to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
1.1.36  ipv6 pathmtu
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu ipv6-address
View
Parameter
ipv6-address: Specified IPv6 address.
value: PMTU of a specified IPv6 address in bytes, in the range of 1,280 to 10,000. The default value is 1500. If this argument is not provided, the default value is adopted.
Use the ipv6 pathmtu command to configure a static PMTU for a specified IPv6 address.
Use the undo ipv6 pathmtu command to remove the PMTU configuration for a specified IPv6 address.
By default, no static PMTU is configured.
Example
# Configure a static PMTU for a specified IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
View
Parameter
age-time: Aging time for PMTU in minutes, in the range of 10 to 100.
Use the ipv6 pathmtu age command to configure the aging time for dynamic PMTU.
Use the undo ipv6 pathmtu age command to restore the aging time for dynamic PMTU to the default.
By default, the aging time is 10 minutes.
Note that the aging time is invalid for static PMTU.
Related command: display ipv6 pathmtu.
Example
# Set the aging time for dynamic PMTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
View
Parameter
None
Use the reset dns ipv6 dynamic-host command to clear IPv6 dynamic domain name cache information.
Example
# Clear IPv6 dynamic domain name cache information.
<Sysname> reset dns ipv6 dynamic-host
reset ipv6 fibcache
View
Parameter
None
Use the reset ipv6 fibcache command to clear FIB cache entries.
Example
# Clear FIB cache entries.
<Sysname> reset ipv6 fibcache
reset ipv6 neighbors [ all | dynamic | interface interface-type interface-number | static ]
View
Parameter
all: Clears the static and dynamic neighbor information on all interfaces.
dynamic: Clears the dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears all neighbor information of a specified interface.
static: Clears the static neighbor information on all interfaces.
Use the reset ipv6 neighbors command to clear IPv6 neighbor information.
Example
# Clear all neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
reset ipv6 pathmtu { all | static | dynamic }
View
Parameter
all: Clears all PMTUs.
static: Clears all static PMTUs.
dynamic: Clears all dynamic PMTUs.
Use the reset ipv6 pathmtu the command to clear the corresponding PMTU.
Example
# Clear all PMTUs.
<Sysname> reset ipv6 pathmtu all
View
Parameter
None
Use the reset ipv6 statistics command to clear the statistics of IPv6 packets.
Example
# Clear the statistics of IPv6 packets.
<Sysname> reset ipv6 statistics
View
Parameter
None
Use the reset tcp ipv6 statistics command to clear the statistics of all IPv6 TCP packets.
Example
# Clear the statistics of all IPv6 TCP packets.
<Sysname> reset tcp ipv6 statistics
View
Parameter
None
Use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
Example
# Clear the statistics of all IPv6 UDP packets.
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
View
Parameter
wait-time: Length of the finwait timer of IPv6 TCP packets in seconds, in the range of 76 to 3,600.
Use the tcp ipv6 timer fin-timeout command to set the finwait timer of IPv6 TCP packets
Use the undo tcp ipv6 timer fin-timeout command to restore the finwait timer length to the default.
By default, the length of the finwait timer is 675 seconds.
Example
# Set the finwait timer length of IPv6 TCP packets to 800 seconds.
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
View
Parameter
wait-time: Length of the synwait timer of IPv6 TCP packets in seconds, in the range of 2 to 600.
Use the tcp ipv6 timer syn-timeout command to set the synwait timer of IPv6 TCP packets
Use the undo tcp ipv6 timer syn-timeout command to restore the synwait timer length to the default.
By default, the length of the synwait timer of IPv6 TCP packets is 75 seconds.
Example
# Set the synwait timer length of IPv6 TCP packets to 100 seconds.
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window size
undo tcp ipv6 window
View
Parameter
size: size of IPv6 TCP receiving/sending buffer in KB (kilobyte), in the range of 1 to 32.
Use the tcp ipv6 window command to set the size of IPv6 TCP receiving/sending buffer.
Use the undo tcp ipv6 window command to restore the size of IPv6 TCP receiving/sending buffer to the default.
By default, the size of the IPv6 TCP packet buffer is 8 KB.
Example
# Set the size of IPv6 TCP receiving/sending buffer to 4 KB.
[Sysname] tcp ipv6 window 4
2.1.1  ping ipv6
ping ipv6 [ -a source-ipv6-address | -c count | -m interval | -s packet-size | -t timeout ]* remote-system [ -i interface-type interface-number ]
View
Parameter
-a source-ipv6-address: Specifies source IPv6 address.
-c count: Specifies the number of packets sent for requesting ICMPv6 echo, ranging from 1 to 4294967295, with the default of 5.
-m interval: Specifies the time intervals in milliseconds to send packets for ICMPv6 echo, ranging from 1 to 65,535, with the default of 200 milliseconds.
l           If a response from the destination is received within the timeout time, the interval to send the next ECHO-REQUEST equals to the actual response period plus the value of interval.
l           If no response from the destination is received within the timeout time, the interval to send the next ECHO-REQUEST equals to the timeout value plus the value of interval.
-s packet-size: Specifies the size in bytes of packets sent for requesting ICMPv6 echo, ranging from 20 to 8,100, with the default of 56 bytes.
-t timeout: Specifies the timeout in milliseconds of receiving ICMPv6 echoes, ranging from 0 to 65,535, with the default of 2,000 milliseconds.
remote-system: IPv6 address or host name (a string a 1 to 46 characters) of the destination device.
-i interface-type interface-number: Specifies the type and number of an outgoing interface. This argument takes effect only when the destination address is a link-local address and the specified outgoing interface has a link-local address.
Use the ping ipv6 command to test whether the destination is accessible.
Example
# Test whether destination 2001::1 is accessible.
<Sysname> ping ipv6 2001::1
  PING 2001::1 : 56  data bytes, press CTRL_C to break
    Reply from 2001::1
    bytes=56 Sequence=1 hop limit=64  time = 20 ms
    Reply from 2001::1
    bytes=56 Sequence=2 hop limit=64  time = 0 ms
    Reply from 2001::1
    bytes=56 Sequence=3 hop limit=64  time = 0 ms
    Reply from 2001::1
    bytes=56 Sequence=4 hop limit=64  time = 0 ms
    Reply from 2001::1
    bytes=56 Sequence=5 hop limit=64  time = 0 ms
  --- 2001::1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 0/4/20 ms
The “hop limit” field in this prompt information has the same meaning as the “ttl” field in the prompt information displayed by the IPv4 ping command, indicating the TTL value in the ICMPv6 ECHO-REQUEST packets.
2.1.2  telnet ipv6
telnet ipv6 remote-system [ -i interface-type interface-number ] [ port-number ]
View
Parameter
port-number: Specifies the port number linked with a Telnet server, ranging from 0 to 65535, with the default of 23.
Use the telnet ipv6 command to log onto another device for remote management from the local device. You can break Telnet logging-in by entering <Ctrl+K>.
Example
# Connect to a remote Telnet server with IPv6 address of 3001::1,
<Sysname> telnet ipv6 3001::1
Trying 3001::1 ...
Press CTRL+K to abort
Connected to 3001::1 ...
* Copyright(c) 2004-2006 Hangzhou H3C Technologies Co., Ltd.     *
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                *
<Sysname>
2.1.3  tftp ipv6
tftp ipv6 remote-system [ -i interface-type interface-number ] { get | put } source-filename [ destination-filename ]
View
Parameter
-i interface-type interface-number: Specifies the type and number of an interface. This argument takes effect only when the address of the TFTP server is a link-local address and the specified outgoing interface has a link-local address.
get: Specifies to download a file.
put: Specifies to upload a file.
source-filename: Specifies the name of a source file with a string of 1 to 135 letters.
destination-filename: Specifies the name of a destination file with a string of 1 to 135 letters. If no such parameters are specified, then the destination file’s name will be the same as the source file’s.
Use the tftp ipv6 command to perform the following operations:
l           Download a file: Download a specified source file from TFTP server to local.
l           Upload a file: Upload a specified source file from local to TFTP server.
Example
# Download a file from TFTP server.
<Sysname> tftp ipv6 fe80::250:daff:fe91:e058 -i Vlan-interface 300 get filetoget
  File will be transferred in binary mode
  Downloading file from remote tftp server, please wait....
  TFTP:       13 bytes received in 0 second(s)
  File downloaded successfully.
tftp-server ipv6 acl acl-number
undo tftp-server ipv6 acl
View
Parameter
acl-number: ACL number of IPv6, in the range of 2000 to 2999.
Use the tftp-server ipv6 acl command to configure the relation of ACL to TFTP application. You can use the rules configured in IPv6 ACL to enable or disable a specific TFTP server.
Use the undo tftp-server ipv6 acl command to disable the relation of ACL to TFTP application.
ACL is not related to TFTP application by default.
Example
# Associate IPv6 ACL 2000 with TFTP application, which permits the accesses sourced from 2030:5060::9050/64.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] quit
[Sysname] tftp-server ipv6 acl 2000
2.1.5  tracert ipv6
tracert ipv6 [ -f first-ttl | -m max-ttl | -p port | -q packet-num | -w timeout ]* remote-system
View
Parameter
-f first-ttl: Specifies the first TTL, that is, the allowed number of hops for the first packet. Ranges from 1 to 255, defaults to 1, and must be less than the maximum TTL.
-m max-ttl: Specifies the maximum TTL, that is, the maximum allowed number of hops for a packet. The value ranges from 1 to 255, defaults to 30. It must be greater than the first TTL.
-p port: Specifies the port number of the destination UDP, ranging from 1 to 65535, with the default of 33434.
-q packet-num: Specifies the maximum number of packets sent to a hop, ranging from 1 to 65535, with the default of 3.
-w timeout: Specifies the timeout in milliseconds of waiting ICMPv6 echoes, ranging from 1 to 65,535, with the default of 5,000 milliseconds.
Use the tracert ipv6 command to trace the route of the IPv6 packets from source to destination.
Example
# Trace the route of the IPv6 packets from source to destination 3002::1.
<Sysname> tracert ipv6 3002::1
 traceroute to 3002::1  30 hops max,60 bytes packet
 1 3003::1 30 ms  0 ms  0 ms
 2 3002::1 10 ms 10 ms 0 ms
For dual stack configuration commands, see section 1.1.16  “ipv6 address”, 1.1.17  “ipv6 address auto link-local”, 1.1.18  “ipv6 address eui-64”, and 1.1.19  “ipv6 address link-local”.
display switch-mode
View
Parameter
None
Use the display switch-mode command to display the information about the current system operating mode, the system operating mode after the device reboots the next time, and related system information
Example
# Display the information about the current system operating mode, the system operating mode after the device reboots the next time, and related system information.
<Sysname> display switch-mode
3.1.2  switch-mode
switch-mode { default | dual-ipv4-ipv6 }
View
Parameter
default: Configures the device to support only IPv4.
dual-ipv4-ipv6: Configures the device to support IPv4/IPv6 dual-stack. When operating in this mode, a device supports both IPv4 and IPv6 packet forwarding.
Use the switch-mode command to configure the protocol stack mode supported. Be default, a device supports only IPv4 protocol stack.
&  Note:
l      The configuration performed by this command takes effect only after the device is restarted.
l      Before enabling dual-stack, you need to configure the device to operate in the IPv4/IPv6 dual-stack mode by using the switch-mode dual-ipv4-ipv6 command. Otherwise, IPv6 packets cannot be forwarded on the device even if dual-stack is enabled.
Example
# Configure the device to operate in IPv4/IPv6 dual-stack mode.
[Sysname] switch-mode dual-ipv4-ipv6
aggregation-group aggregation-group-id
undo aggregation-group
View
Tunnel interface view
Parameter
aggregation-group-id: Link aggregation group ID.
Use the aggregation-group command to configure a service-loop group for a tunnel.
Use the undo aggregation-group command to remove the service-loop group configured for a tunnel.
By default, a tunnel does not reference any service-loop group.
Before configuring a service-loop group for a tunnel in tunnel interface view, you need to a configure link aggregation group in system view and set the service type of the link aggregation group to tunnel.
One tunnel interface can reference only one service-loop group.
For related configuration, refer to the link-aggregation group command. For details, refer to Port Correlation Configuration module.
Example
# Before configuring a service-loop group for a tunnel in tunnel interface view, create and configure link aggregation groups in system view. For example, create link aggregation group 1, and set the configuration mode to manual and the service type to tunnel.
[Sysname] link-aggregation group 1 mode manual
[Sysname] link-aggregation group 1 service-type tunnel
# Add a layer 2 Ethernet interface to service-loop group 1. (Note that to add a port to a service-loop group, you need to disable STP on the port.)
[Sysname-Ethernet1/0/1] stp disable
[Sysname-Ethernet1/0/1] port link-aggregation group 1
[Sysname-Ethernet1/0/1] quit
# Configure the tunnel to reference service-loop group 1 in tunnel interface view.
[Sysname] interface Tunnel 2
[Sysname-Tunnel2] aggregation-group 1
4.1.2  destination
destination { ip-address | ipv6-address }
undo destination
View
Parameter
ip-address: Destination IPv4 address to be specified for the tunnel interface.
ipv6-address: Destination IPv6 address to be specified for the tunnel interface. Currently, you cannot configure the destination address of a tunnel interface as an IPv6 address on an S3610&S5510 switch.
Use the command destination to specify the destination address of the tunnel interface.
Use the undo destination command to remove the configured destination IP address.
By default, no destination address is configured for the tunnel interface.
Note that:
l           You can configure destination addresses for manually established tunnels only.
l           The destination address of a tunnel interface is the address of the peer interface receiving packets and is usually the source address of the peer tunnel interface.
l           Two or more tunnel interfaces using the same encapsulation protocol must have different source addresses and destination addresses.
Related command: interface Tunnel and source.
Example
# Set VLAN1 (193.101.1.1) of Sysname1 to the source interface and destination interface of a tunnel between two devices, respectively.
<Sysname1> system-view
[Sysname1] interface Tunnel 0
[Sysname1-Tunnel0] source 193.101.1.1
[Sysname1-Tunnel0] destination 192.100.1.1
# Set VLAN1 (192.100.1.1) of Sysname2 to the source interface and destination interface of a tunnel between two devices, respectively.
<Sysname2> system-view
[Sysname2] interface Tunnel 1
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
display interface Tunnel number
View
Parameter
number: Tunnel interface number.
Use the display interface Tunnel command to display related information of a specified tunnel interface, such as source address, destination address, and encapsulation mode.
Related command: interface Tunnel, source, destination, and tunnel-protocol.
Example
# Display information of the interface Tunnel 0.
<Sysname> display interface Tunnel 0
Tunnel0 current state: DOWN
Line protocol current state: DOWN
The Maximum Transmit Unit is 64000
Internet protocol processing : disabled
Encapsulation is TUNNEL, aggregation ID not set
Tunnel source unknown, destination unknown
Tunnel mode is IPv6 over IPv4(config)
    Last 300 seconds input:  0 bytes/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 packets/sec
    0 packets input,  0 bytes
    0 input error
    0 packets output,  0 bytes
    0 output error
Table 4-1 Description on fields of the display interface Tunnel command
The physical layer of the tunnel interface is reachable.
The link layer of the tunnel interface is reachable.
Descriptive information of a tunnel interface
Tunnel0 Interface
Maximum transmission unit in a tunnel
The encapsulation protocol is tunnel.
aggregation ID
Service-loop group ID referenced by a tunnel. If the device supports link aggregation groups, the link aggregation group ID configured in tunnel interface view is displayed. If device does not support, “aggregation ID not set” is displayed.
Tunnel source
Address of the tunnel source.
destination
Address of the tunnel destination.
Tunnel protocol/transport
Tunnel protocol and transport protocol.
Number of bytes and packets input per second in the last five minutes.
Number of bytes and packets output per second in the last five minutes.
packets input
Total number of input packets.
input error
Number of error packets among all input packets.
packets output
Total number of output packets.
output error
Number of error packets in all output packets
display ipv6 interface Tunnel number
View
Parameter
Use the display ipv6 interface Tunnel command display related IPv6 information of a specified tunnel interface, including link state, IPv6 protocol state, and IPv6 address.
Example
<Sysname> display ipv6 interface Tunnel 0
Tunnel0 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::101:101
    2002:101:101::1, subnet is 2002::/16
    FF02::1:FF01:101
    FF02::1:FF00:1
    FF02::2
    FF02::1
  MTU is 1500 bytes
Table 4-2 Description on fields of the display interface Tunnel command
IPv6 is enabled
Enables IPv6 on a tunnel interface
link-local address
Link-local address of a tunnel interface
Aggregatable global unicast address of a tunnel interface.
Multicast address of a tunnel interface.
MTU is 1500 bytes
Size of the MTU in a tunnel. The MTU in this example is 1500 bytes.
ND reachable time
Interval for retransmitting a neighbor discovery packet.
Hosts use the stateless auto-configuration mode to acquire IPv6 addresses.
expediting enable
undo expediting enable
View
Parameter
None
Use the expediting enable command to enable the expedite termination function.
Use the expediting enable command to disable the expedite termination function.
By default, the expedite termination function is disabled.
The expedite termination function must be enabled if you need to run a dynamic routing protocol (such as OSPFv3) on a manually established tunnel, ping a link-local address configured on a tunnel interface, or automatically obtain a global IPv6 address through an ISATAP tunnel.
Example
# Enable the expedite termination function
[Sysname] interface Tunnel 0
[Sysname-Tunnel0] expediting enable
expediting subnet ip-address mask
undo expediting subnet
View
Parameter
ip-address: Address of the expedite termination subnet of a tunnel
mask: Mask of the expedite termination subnet of a tunnel
Use the expediting subnet command to set an IP address and mask for the expedite termination subnet.
Use the undo expediting subnet command to remove the configuration.
By default, no expedite termination subnet is configured for a tunnel.
Note that:
l           You must enable the expedite termination before configuring an expedite termination subnet in tunnel interface view.
l           The expediting subnet is not applicable to a manual tunnel (for example, IPv6 manually configured tunnel). After the expedite termination function is enabled, the system will automatically consider the destination address of a tunnel as the address of the expedite termination subnet, and the subnet mask as 255.255.255.255.
l           For automatic tunnels (for example, automatic IPv4-compatible IPv6 tunnel, automatic 6to4 tunnel, and ISATAP tunnel), you must carry out the expediting subnet command to designate an IP address and subnet for the expedite termination subnet after carrying out the expediting enable command.
Example
# Configure an expedite termination subnet for an automatic 6to4 tunnel: First enable the expedite termination, and then set the address of the expedite termination subnet to 1.1.1.2 and the subnet mask to 255.255.255.0.
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] tunnel-protocol ipv6-ipv4 6to4
[Sysname-Tunnel1] expediting enable
The expediting subnet needs to be configured, or else the expediting is not available.
[Sysname-Tunnel1] expediting subnet 1.1.1.2 255.255.255.0
undo interface Tunnel number
View
Parameter
number: Tunnel interface number, in the range of 0 to 1023.
Use the interface Tunnel command to create a tunnel interface and enter tunnel interface view.
Use the undo interface Tunnel command to remove a specified tunnel interface.
By default, there is no tunnel interface on the device.
Note that:
l           Carry out the interface Tunnel command to enter interface view of a specified tunnel. If the tunnel interface is not created, you must create it before entering tunnel interface view.
l           A tunnel interface number has only local significance, and therefore, the same or different interface numbers can be set at both ends of a tunnel.
Related command: source, destination, and tunnel-protocol.
Example
# Create the interface Tunnel 3.
[Sysname] interface Tunnel 3
[Sysname-Tunnel3]
4.1.8  peer enable
peer ip-address enable
undo peer ip-address enable
View
IPv6 address family view
Parameter
ip-address: IPv4 address of the 6PE peer to be specified.
Use the peer enable command to enable a 6PE peer.
Use the undo peer enable command to cancel the configuration.
&  Note:
Currently, the S3610&S5510 series switches do not support these two commands.
Example
4.1.9  source
source { ip-address | ipv6-address | interface-type interface-number }
undo source
View
Parameter
ip-address: Source IPv4 address of a tunnel interface.
ipv6-address: Source IPv6 address to be specified for the tunnel interface. Currently, you cannot assign an IPv6 address to the source interface of a tunnel on an S3610&S5510 switch.
interface-type interface-number: Interface type and interface number. The interface types include loopback and vlan-interface.
Use the source command to specify a source address for a tunnel interface.
Use the undo source command to remove the configured source IP address.
By default, no source address is configured for a tunnel interface.
Note that:
l           The source address of a tunnel interface is the address of the interface sending packets and is usually the destination address of the peer tunnel interface.
Related command: interface Tunnel and destination.
Example
# Configure the interface Tunnel 5. The actual outgoing interface encapsulating packets is LoopBack1(192.100.1.1).
[Sysname] interface Tunnel 5
[Sysname-Tunnel5] source 192.100.1.1
Or
[Sysname-Tunnel5] source LoopBack 1
4.1.10  tunnel-protocol
tunnel-protocol ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ]
undo tunnel-protocol
View
Parameter
ipv6-ipv4: Sets the tunnel to IPv6 over IPv4 manually configured.
ipv6-ipv4 6to4: Sets the tunnel mode to IPv6 over IPv4 6to4.
ipv6-ipv4 auto-tunnel: Sets the tunnel mode to automatic IPv6 over IPv4.
ipv6-ipv4 isatap: Sets the tunnel mode to IPv6 over IPv4 isatap.
Use the tunnel-protocol command to configure the tunnel mode.
Use the undo tunnel-protocol to restore the tunnel mode to the default.
By default, the tunnel is an IPv6 over IPv4 manually configured tunnel.
Note that:
l           A proper tunnel mode can be selected for packet encapsulation according to the network topology and application. The same tunnel mode should be configured at both ends of the tunnel. Otherwise, packet delivery will fail.
l           Only one tunnel can automatically be configured at the same tunnel source.
Example
# Configure the tunnel mode as IPv6 over IPv4 manually configured tunnel.
[Sysname-Tunnel2] tunnel-protocol ipv6-ipv4
