H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
03-IP Address and Performance Command
03-IP Address and Performance Command 191 KB
Chapter 1  IP Address Configuration Commands
1.1  IP Address Configuration Commands
1.1.1  display ip interface
display ip interface [ interface-type interface-number ]
View
Parameter
Use the display ip interface command to display the information about a Layer 3 interface. If no parameter is specified, the related information of all Layer 3 interfaces will be displayed.
Example
# Display information about interface VLAN interface 1.
<Sysname> display ip interface Vlan-interface 1
Vlan-interface1 current state : UP
Line protocol current state : UP
Internet Address is 192.168.0.36/24 Primary
Broadcast address : 192.168.0.255
The Maximum Transmit Unit : 1500 bytes
input packets : 5028, bytes : 234508, multicasts : 388
output packets : 4544, bytes : 263776, multicasts : 0
ARP packet input number:       19819
  Request packet:              19808
  Reply packet:                   11
  Unknown packet:                  0
TTL invalid packet number:         0
ICMP packet input number:        165
  Echo reply:                      0
  Unreachable:                   165
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
DHCP packet deal mode:  global
Table 1-1 Description on the fields of the display ip interface command
current state
Current physical state of an interface
Current state of the Line protocol
Internet Address
IP address of an interface. Primary behind an IP address indicates the IP address is a primary one, and Sub indicates the IP address is a secondary one
Broadcast address
Broadcast address of the subnet attached to an interface
Max transmit unit
Unicast packets, bytes, and multicast packets received on an interface
Unicast packets, bytes, and multicast packets sent on an interface
  Reply packet:                               11
  Unknown packet:                           0
Total number of ARP packets received on an interface, including
l      ARP request packets
l      ARP reply packets
l      Unknown packets
Number of received invalid TTL packets
  Echo reply:                                 0
  Unreachable:                           165
  Source quench:                          0
  Routing redirect:                         0
  Echo request:                             0
  Router advert:                            0
  Router solicit:                             0
  Time exceed:                              0
  IP header bad:                            0
  Timestamp reply:                       0
  Netmask request:                       0
  Netmask reply:                           0
  Unknown type:                           0
Total number of ICMP packets received on an interface, including the following packets:
l      Echo reply packet
l      Unreachable packets
l      Source quench packets
l      Routing redirect packets
l      Echo request packets
l      Router advertisement packets
l      Router solicitation packets
l      Time exceed packets
l      IP header bad packets
l      Timestamp request packets
l      Timestamp reply packets
l      Information request packets
l      Information reply packets
l      Netmask request packets
l      Netmask reply packets
l      Unknown type packets
Mode to process DHCP packets, which can be:
l      global: The DHCP server with the global address pool is enabled on the interface.
l      relay: The DHCP relay agent is enabled on the interface.
1.1.2  display ip interface brief
display ip interface brief [ interface-type interface-number ]
View
Parameter
Use the display ip interface brief command to display brief information about the basic IP configuration on the specified or all interfaces.
If no interface is specified, the basic IP configuration information of all Layer 3 interfaces will be displayed.
Related command: display ip interface.
Example
# Display brief information about the basic IP configuration for VLAN interface 1.
<Sysname> display ip interface brief Vlan-interface 1
*down: administratively down
(s): spoofing
Interface                              Physical   Protocol   IP Address
Vlan-interface1                          up         up       192.168.0.36
Table 1-2 Description on the fields of the display ip interface brief command
*down
The interface is shut down with the shutdown command.
(s)
Spoofing attribute of the interface. It indicates that an interface whose link layer is displayed up may have no link present or the link is set up only on demand.
Interface name
Physical
Physical state of interface
Protocol
Link layer state protocol of interface
IP Address
IP address of interface (if no IP address is configured, “unassigned” is displayed.)
1.1.3  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
Interface view
Parameter
ip-address: IP address of interface, in dotted decimal notation.
mask: Subnet mask in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask.
sub: Secondary IP address for the interface. The availability of this keyword varies by device.
Use the ip address command to assign an IP address and mask to the interface.
Use the undo ip address command to remove all IP addresses.
Use the undo ip address [ ip-address { mask | mask-length } ] command to remove the IP address.
By default, no IP address is assigned to any interface.
The relationship between the primary address and the secondary addresses is as follows:
l           When you configure a primary IP address for an interface that already has a primary IP address, the new address will replace the old one.
l           The primary and secondary IP addresses can belong to the same network segment.
l           Before deleting the primary IP address, you must delete all the corresponding secondary IP addresses first.
Note that:
l           If you execute the undo ip address command without any parameter, the switch deletes all IP addresses of the interface.
l           The undo ip address ip-address { mask | mask-length } command is used to delete the primary IP address.
l           The undo ip address ip-address { mask | mask-length } sub command is used to delete a specified secondary IP address.
l           If you configure an interface to obtain an IP address through BOOTP, DHCP, you cannot configure secondary IP addresses for this interface.
&  Note:
You can configure IP addresses for VLAN interface, Tunnel interface and Loopback interface on S3610&S5510 Series Ethernet Switches.
Example
# Assign VLAN interface 1 a primary IP address and a secondary IP address, with subnet masks being 255.255.255.0.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
Chapter 2  IP Performance Configuration Commands
2.1  IP Performance Configuration Commands
2.1.1  display fib
display fib [ | { begin | include | exclude } text | acl acl-number | ip-prefix ip-prefix-name ]
View
Parameter
| { begin | include | exclude } text: Specifies to display FIB information in the buffer related to a specified string according to a regular expression.
l           The begin keyword specifies to display from the first FIB item that contains the specified string text.
l           The include keyword specifies to display only the FIB items that include the specified string text.
l           The exclude keyword specifies to display only the FIB items that do not include the specified string text.
l           The text argument is a string.
acl acl-number: Specifies to display FIB messages filtered through a specific ACL, in the range 2000 to 2999.
ip-prefix ip-prefix-name: Specifies to display FIB information filtered through a specific prefix name, in the range 1 to 19 characters.
Use the display fib command to display FIB forward information. If no parameters are specified, all FIB forward information will display.
Example
# Display all FIB information.
<Sysname> display fib
 FIB Table:
 Total number of Routes : 2
 Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Reject   L:Generated by ARP or ESIS
Destination/Mask Nexthop     Flag    TimeStamp      Interface
127.0.0.0/8      127.0.0.1   U   t[1141138116]  InLoop0
127.0.0.1/32     127.0.0.1   HU  t[1141138116]  InLoop0
Table 2-1 Description on the fields of the display fib command
Total number of routes in the FIB table
Destination/Mask
Destination address/length of mask
Nexthop
Address of next hop
Flag
Signs of routers:
l      “U”—Router is available
l      “G”—Gateway is available
l      “H”—Host router
l      “B”—Black hole router
l      “D”—Dynamic router
l      “S”—Static router
l      “R”—Refused router, which is not available
l      “L”—Router created by ARP or ESIS
TimeStamp
Time stamp
Forward interface
# Display FIB forward information filtered through ACL 2000
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.2.0.0 0.0.255.255
[Sysname-acl-basic-2000] display fib acl 2000
Route entry matched by access-list 2000:
  Summary counts: 2
 Flag:
# Display all lines from the one that contains string “127”
<Sysname> display fib | begin 127
 Flag:
# Display FIB forward information filtered through the abc0 prefix list
<Sysname> display fib ip-prefix abc0
Route Entry matched by prefix-list abc0:
  Summary count: 2
 Flag:
2.1.2  display fib ip-address
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
View
Parameter
ip-address1, ip-address2: Destination IP address, in dotted decimal notation. ip-address1 and ip-address2 together determine an address range for the FIB items to be displayed.
mask1, mask2: IP address mask.
mask-length1, mask-length2: Length of IP address mask, namely, the number of “1” in succession in the masks.
longer: Displays FIB entries that match the specified address/mask and have masks longer than or equal to the mask that a user enters. If no masks are specified, FIB entries that match the natural network address and have the masks longer than or equal to the natural mask will be displayed.
Use the display fib ip-address command to display FIB items that match the specified destination IP address. Each line in the export information stands for a FIB item.
Example
# Display the FIB items whose destination address match 10.1.0.0 in the range of natural masks.
<Sysname> display fib 10.1.0.0 longer
  Route Entry Count: 2
 Flag:
10.0.0.0/8       10.1.1.1        U   t[1141140133]  Vlan1
10.1.1.1/32      127.0.0.1   HU  t[1141140133]  InLoop0
For explanation about the information above, refer to Table 2-1.
2.1.3  display fib statistics
View
Parameter
None
Use the display fib statistics command to display statistics about the FIB items.
Example
# Display statistics about the FIB items.
<Sysname> display fib statistics
Route Entry Count          : 2
Table 2-2 Description on the fields of the display fib statistics command
Route Entry Count
Number of FIB items
2.1.4  display icmp statistics
View
Parameter
None
Use the display icmp statistics command to display statistics of ICMP flows.
Related command: display ip interface and reset ip statistics.
Example
# Display statistics of ICMP flows.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                   information reply       0
         time exceeded 0
Table 2-3 Description on the fields of the display icmp statistics command
bad formats
Number of import packets of incorrect format.
bad checksum
Number of import packets of incorrect check sum.
echo
Number of import/export packets answering request.
Number of packets with input/output destination unreachable
source quench
Number of import/export packets with source quenched.
redirects
Number of import/export packets to be redirected
echo reply
Number of import/export packets echoing reply.
parameter problem
Number of import/export packets with incorrect parameter
timestamp
Number of import/export packets for time stamp
information request
Number of import packets for information request
mask requests
Number of import/export packets with mask request
mask replies
Number of import/export packets for mask replies
information reply
Number of export packets for information reply
time exceeded
Number of import/export expiration packets
2.1.5  display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ]
View
Parameter
sock-type: Type of socket, in the range of 1 to 3, corresponding to TCP, UDP and raw IP respectively.
task-id: Identification of a task, ranging from 1 to 100
socket-id: Identification of a socket, ranging from 0 to 3072
Use the display ip socket command to display socket information.
Example
# Display all socket information.
<Sysname> display ip socket
SOCK_STREAM:
Task = VTYD(36), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_REUSEPORT SO_SENDVPNID(3073) SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = HTTP(34), socketid = 1, Proto = 6,
LA = 0.0.0.0:80, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO
Task = VTYD(36), socketid = 3, Proto = 6,
LA = 192.168.0.236:23, FA = 192.168.0.10:1306,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 483, rb_cc = 0,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_REUSEPORT SO_SENDVPNID(0) SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
SOCK_DGRAM:
Task = AGNT(49), socketid = 1, Proto = 17,
LA = 0.0.0.0:161, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 41600, sb_cc = 0, rb_cc = 0,
socket option = SO_UDPCHECKSUM,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = RDSO(56), socketid = 1, Proto = 17,
LA = 0.0.0.0:1024, FA = 0.0.0.0:0,
Task = TRAP(50), socketid = 1, Proto = 17,
LA = 0.0.0.0:1038, FA = 0.0.0.0:0,
socket option = SO_UDPCHECKSUM SO_SETSRCADDR,
Task = LSSO(54), socketid = 1, Proto = 17,
LA = 0.0.0.0:1645, FA = 0.0.0.0:0,
Task = LSSO(54), socketid = 2, Proto = 17,
LA = 0.0.0.0:1646, FA = 0.0.0.0:0,
Task = RDSO(56), socketid = 2, Proto = 17,
LA = 0.0.0.0:1812, FA = 0.0.0.0:0,
Task = CLST(25), socketid = 1, Proto = 17,
LA = 0.0.0.0:40000, FA = 0.0.0.0:0,
SOCK_RAW:
Task = ROUT(63), socketid = 5, Proto = 89,
LA = 0.0.0.0, FA = 0.0.0.0,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = 0,
Task = ROUT(63), socketid = 3, Proto = 103,
sndbuf = 65536, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
socket option = SO_SENDVPNID(0),
Task = ROUT(63), socketid = 2, Proto = 65,
sndbuf = 32767, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
socket option = 0,
Task = ROUT(63), socketid = 1, Proto = 2,
Table 2-4 Description on the fields of the display ip socket command
SOCK_STREAM
Socket type of TCP
SOCK_DGRAM
Socket type of UDP
SOCK_RAW
Socket type of raw IP
Task number
socketid
Socket ID
Proto
Protocol used by the socket
LA
Local address and local port number
FA
Remote address and remote port number
sndbuf
Size of socket sending buffer
rcvbuf
Size of socket receiving buffer
sb_cc
Current data size in the sending buffer (It is available only when TCP can buffer the data)
rb_cc
Data size currently in the receiving buffer
socket option
Socket option
socket state
Socket state
2.1.6  display ip statistics
View
Parameter
None
Use the display ip statistics command to display statistics on IP traffics.
Example
# Display statistics on IP traffics.
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Table 2-5 Description on the fields of the display ip statistics command
Input:
sum
Total number of packets received
local
Total number of packets with destination being local
bad protocol
Total number of packets with unknown protocol
bad format
Total number of packets with incorrect format
bad checksum
Total number of packets with incorrect checksum .
bad options
Total number of packets with incorrect options
Output:
forwarding
Total number of packets forwarded
local
Total number of packets sent from local
dropped
Total number of packets lost while transmitting
no route
Can’t find out the total number of packets routered
compress fails
Total number of packets whose compression fails
Fragment:
input
Total number of fragment packets received
output
Total number of fragment packets sent
dropped
Total number of fragment packets dropped
fragmented
Total number of packets successfully fragmented
couldn't fragment
Total number of packets that can’t be fragmented
Reassembling:
sum
Total number of packets reassembled
timeouts
Total number of fragment packets that timeout in reassembling
2.1.7  display tcp statistics
View
Parameter
None
Use the display tcp statistics command to display statistics of TCP connection flows. Related command: display tcp status and reset tcp statistics.
Example
# Display statistics of TCP connection flows.
<Sysname> display tcp statistics
Received packets:
     Total: 753
     packets in sequence: 412 (11032 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
     out-of-order packets: 0 (0 bytes)
     packets of data after window: 0 (0 bytes)
     packets received after close: 0
     ACK packets: 481 (8776 bytes)
     duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
     Total: 665
     urgent packets: 0
     control packets: 5 (including 1 RST)
     window probe packets: 0, window update packets: 2
     data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
     ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections:0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 2-6 Description on the fields of the display tcp statistics command
Received packets:
Total
packets in sequence
Number of packets arriving in a sequence, with size in bytes in brackets
Number of window probe packets received
Number of window update packets received
checksum error
Number of checksum error packets received
offset error
Number of offset error packets received
short error
Number of packets received with length being too small
duplicate packets
Completely duplicate packets received, with size in bytes in brackets
Partially duplicate packets received, with size in bytes in brackets
Out-of-order packets received, with size in bytes in brackets
Number of packets loaded out of receiving window, with size in bytes in brackets
Number of packets arriving after connection closes
ACK packets
ACK packets received, with size in bytes in brackets
Duplicate ACK packets received
Number of ACK packets received that sent no data
Sent packets:
Total
urgent packets
Number of urgent packets sent
control packets
Number of control packets sent, with number of packets containing double sent data in brackets
Number of window probe packets sent
Number of window update packets sent
data packets
Number of packets sent, with size in bytes in brackets
Number of packets double sent, with size in bytes in brackets
ACK-only packets
Number of ACK packets sent, with number of delayed ACK packets in brackets
Retransmit a timer’s timeout
Number of connections dropped due to retransmission timeout
Keepalive timeout
Times of timeout of a keepalive timer
keepalive probe
Number of keepalive probe packets sent
Number of connections dropped due to failure of keepalive probe timer
Number of connections initiated
Number of connections accepted
Number of connections established
Closed connections
Number of connections closed with number of connections dropped by accident (before receiving SYN) or failed (before receiving remote end’s SYN) in the brackets
Number of packets with MD5 authentication dropped
Number of packets with MD5 authentication permitted
2.1.8  display tcp status
display tcp status
View
Parameter
None
Use the display tcp status command to display status of all TCP connection and thus allow a user to monitor TCP connections at all times
Example
# Display status of all TCP connections
<Sysname> display tcp status
 *: TCP MD5 Connection
TCPCB            Local Add:port      Foreign Add:port        State
03e37dc4     0.0.0.0:4001            0.0.0.0:0           Listening
04217174     100.0.0.204:23      100.0.0.253:65508   Established
Table 2-7 Description on the fields of the display tcp status command
A connection with this mark is an MD5 encrypted TCP connection
TCPCB
TCP control block
Local Add:port
Local address and port number
Foreign Add:port
Remote IP address and port number
State of TCP connections
2.1.9  display udp statistics
View
Parameter
None
Use the display udp statistics command to display statistics of UDP flows.
Related command: reset udp statistics.
Example
# Display statistics of UDP flows.
<Sysname> display udp statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 2-8 Description on the fields of the display udp statistics command
Received packets:
Total
Total number of UDP packets received
checksum error
shorter than header
Number of packets with body shorter than head
Number of packets with data longer than body
Number of unicast packets with no socket on port
Number of broadcast/multicast packets without socket on port
Number of packets not delivered to upper layer due to socket buffer being full
Number of packets without matching PCB cache
Sent packets:
Total
Total number of UDP packets sent
2.1.10  ip forward-broadcast
undo ip forward-broadcast
View
Parameter
None
Use the ip forward-broadcast command to enable the device to receive directed broadcast packets.
Use the undo ip forward-broadcast command to disable the device to receive directed broadcast packets.
By default, it is disabled to receive directed broadcast packets.
Example
# Enable the device to receive directed broadcast packets.
[Sysname] ip forward-broadcast
2.1.11  ip redirects enable
ip redirects enable
undo ip redirects
View
Parameter
None
Use the ip redirects enable command to enable sending a device’s ICMP redirection packet.
Use the undo ip redirects command to disable sending a device’s ICMP redirection packet.
Sending a device’s ICMP redirection packet is enabled by default.
Example
# Disable sending a device’s ICMP redirection packet.
[Sysname] undo ip redirects
 The function is disabled!
2.1.12  ip ttl-expires enable
undo ip ttl-expires
View
Parameter
None
Use the ip ttl-expires enable command to enable sending a device’s ICMP timeout packet.
Use the undo ip ttl-expires command to disable sending a device’s ICMP timeout packet.
Sending a device’s ICMP timeout packet is enabled by default.
Note: The device stops sending “TTL timeout” ICMP error packets after sending ICMP timeout packets is disabled. But “reassembly timeout” error packets will be sent normally.
Example
# Disable sending a device’s ICMP timeout packet.
[Sysname] undo ip ttl-expires
2.1.13  ip unreachables enable
undo ip unreachables
View
Parameter
None
Use the ip unreachables enable command to enable sending a device’s ICMP destination unreachable packet.
Use the undo ip unreachables command to disable sending a device’s ICMP destination unreachable packet.
Sending a device’s ICMP destination unreachable packet is enabled by default.
Note: The device stops sending “network unreachable” and “source route unsuccessful” ICMP error packets after sending ICMP destination unreachable packets is disabled. But other destination unreachable packets will be sent normally.
Example
# Disable sending a device’s ICMP destination unreachable packet.
[Sysname] undo ip unreachables
2.1.14  reset ip statistics
reset ip statistics
View
Parameter
None
Use the reset ip statistics command to clear statistics of IP packets.
Related command: display ip interface and display ip statistics.
Example
# Clear statistics of IP packets.
<Sysname> reset ip statistics
2.1.15  reset tcp statistics
View
Parameter
None
Use the reset tcp statistics command to clear statistics of TCP connection flows.
Related configuration command: display tcp statistics.
Example
<Sysname> reset tcp statistics
2.1.16  reset udp statistics
View
Parameter
None
Use the reset udp statistics command to clear statistics of UDP flows.
Example
<Sysname> reset udp statistics
2.1.17  tcp mss
tcp mss value
undo tcp mss
View
Tunnel interface view
Parameter
value: Maximum segment size of a specified TCP packet in byte, ranging from 128 to 2048.
Use the tcp mss command to configure the maximum segment size of TCP packets. Use the undo tcp mss command to restore the default configuration.
The maximum segment size of TCP packets is 1460 bytes by default.
As the default MTU of the interface is 1500 bytes, and there are link layer cost and IP packet head, so the recommended TCP MSS is configured as about 1200 bytes.
&  Note:
Currently S3610&S5510 series Ethernet switches only support the configuration of the maximum segment size of TCP packets for a Tunnel interface.
Example
# Configure the maximum segment size of TCP packets to 300 bytes on Tunnel interface 1.
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] tcp mss 300
2.1.18  tcp timer fin-timeout
undo tcp timer fin-timeout
View
Parameter
time-value: TCP finwait timer value in seconds, ranging from 76 to 3600.
Use the tcp timer fin-timeout command to configure the TCP finwait timer.
Use the undo tcp timer fin-timeout command to resume the default TCP finwait timer value.
TCP finwait timer is 675 seconds by default.
Related command: tcp timer syn-timeout and tcp window.
Example
# Configure the value of TCP finwait timer as 800 seconds.
[Sysname] tcp timer fin-timeout 800
2.1.19  tcp timer syn-timeout
undo tcp timer syn-timeout
View
Parameter
time-value: TCP finwait timer value in seconds, ranging from 2 to 600.
Use the tcp timer syn-timeout command to configure the TCP synwait timer.
Use the undo tcp timer syn-timeout command to resume the default TCP synwait timer value.
TCP synwait timer is 75 seconds by default.
Related command: tcp timer fin-timeout and tcp window.
Example
# Configure the value of TCP synwait timer as 80 seconds.
[Sysname] tcp timer syn-timeout 80
2.1.20  tcp window
tcp window window-size
undo tcp window
View
Parameter
window-size: The receiving/sending buffer size of TCP connection in KB, ranging from 1 to 32.
Use the tcp window command to configure the receiving/sending buffer size of TCP connection.
Use the undo tcp window command to resume the default receiving/sending buffer size of TCP connection.
The TCP receiving/sending buffer is 8 KB by default.
Related command: tcp timer fin-timeout and tcp timer syn-timeout.
Example
# Configure the receiving/sending buffer of TCP connection as 3 KB.
[Sysname] tcp window 3
