H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
05-Port Correlation Configuration Command
05-Port Correlation Configuration Command 238 KB
Table of Contents
Chapter 1 Ethernet Interface Configuration Commands. 1-1
1.1 General Ethernet Interface Configuration Commands. 1-1
1.1.1 broadcast-suppression. 1-1
1.1.2 copy configuration. 1-2
1.1.3 description. 1-3
1.1.4 display brief interface. 1-4
1.1.5 display interface. 1-7
1.1.6 display loopback-detection. 1-10
1.1.7 display port 1-11
1.1.8 display port combo. 1-12
1.1.9 display port-group manual 1-13
1.1.10 duplex. 1-13
1.1.11 flow-control 1-14
1.1.12 flow-interval 1-15
1.1.13 group-member 1-16
1.1.14 interface. 1-16
1.1.15 jumboframe enable. 1-17
1.1.16 loopback. 1-18
1.1.17 loopback-detection control enable. 1-19
1.1.18 loopback-detection enable. 1-20
1.1.19 loopback-detection interval-time. 1-21
1.1.20 loopback-detection per-vlan enable. 1-22
1.1.21 mdi 1-22
1.1.22 port link-type. 1-23
1.1.23 port-group. 1-24
1.1.24 reset counters interface. 1-25
1.1.25 shutdown. 1-25
1.1.26 speed. 1-26
1.1.27 virtual-cable-test 1-27
Chapter 2 Link Aggregation Configuration Commands. 2-1
2.1 Link Aggregation Configuration Commands. 2-1
2.1.1 display lacp system-id. 2-1
2.1.2 display link-aggregation interface. 2-1
2.1.3 display link-aggregation service-type. 2-3
2.1.4 display link-aggregation summary. 2-4
2.1.5 display link-aggregation verbose. 2-5
2.1.6 lacp enable. 2-7
2.1.7 lacp port-priority. 2-8
2.1.8 lacp system-priority. 2-9
2.1.9 link-aggregation group description. 2-9
2.1.10 link-aggregation group mode. 2-10
2.1.11 link-aggregation group service-type. 2-11
2.1.12 port link-aggregation group. 2-11
2.1.13 port-group aggregation. 2-12
2.1.14 reset lacp statistics. 2-13
Chapter 3 Port Isolation Configuration Commands. 3-1
3.1 Port Isolation Configuration Commands. 3-1
3.1.1 display port-isolate group. 3-1
3.1.2 port-isolate enable. 3-1
3.1.3 port-isolate uplink-port 3-2
broadcast-suppression ratio
undo broadcast-suppression
View
Ethernet interface view/port group view
Parameter
ratio: Maximal ratio of broadcast traffic to the total transmission capability of an Ethernet interface. It ranges between 1 to 100 and defaults to 100.
The smaller the ratio, the less broadcast traffic allowed through the interface.
Use the broadcast-suppression command to configure a broadcast storm suppression ratio.
Use the undo broadcast-suppression command to restore the default broadcast storm suppression ratio.
By default, all broadcast traffic is allowed to go through an Ethernet interface, that is, broadcast traffic is not suppressed.
If you execute this command in Ethernet interface view, the configurations take effect only on the current interface. If you execute this command in port-group view, the configurations take effect on all ports in the port group.
Note that when broadcast traffic exceeds the maximum value configured, the system will discard the extra packets so that the broadcast traffic ratio falls below the limit to ensure that the network functions properly.
&  Note:
If you set different suppression ratios in Ethernet interface view or port-group view for multiple times, the latest configuration takes effect.
Example
# Allow broadcast traffic equivalent to 20% of the total transmission capability of Ethernet1/0 to pass and suppress the excessive broadcast packets.
[Sysname] interface ethernet 1/0
[Sysname-Ethernet1/0] broadcast-suppression 20
copy configuration source interface-type interface-number destination  interface-list
View
Interface view
Parameter
interface-type interface-number: The interface type and interface number of the interface to be copied
interface-list: Destination Ethernet interface list, in the format of
interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges.
Use the copy configuration command to copy configurations on a specific interface to other interface(s). The configurations that can be copied include port configuration, GVRP, STP, port-isolate (port isolation configuration), VLAN, LACP, QoS and QING.
&  Note:
Neither the source port nor the destination port can be a uplink port of the isolated group when you copy port isolation configurations.
Example
# Copy configurations from Ethernet 1/0/1 to Ethernet 1/0/2.
[Sysname] copy configuration source Ethernet 1/0/1 destination Ethernet 1/0/2
 Copying speed/duplex configuration...
 Copying GVRP configuration...
 Copying STP configuration...
 Copying Port-isolate configuration...
 Copying VLAN configuration...
 Copying LACP configuration...
 Copying QoS configuration...
 Copying QINQ configuration...
1.1.3  description
View
Parameter
text: The description of an Ethernet interface, a string of 1 to 80 characters.
Use the description command to configure the description of an Ethernet interface.
Use the undo description command to remove the description.
Default to interface name followed by the “interface” string, for example, Ethernet1/0/1 Interface.
Example
# Configure the description for interface Ethernet 1/0/1 to “lanswitch-interface”.
[Sysname-Ethernet1/0/1] description lanswitch-interface
display brief interface [ interface-type [ interface-number ] ] [ | { begin | include | exclude } regular-expression ]
View
Parameter
interface-type: Type of a specified interface.
interface-number: Number of a specified interface.
|: Uses a regular expression to filter output information.
begin: Displays information that begins with the specified string.
include: Displays information that contains the specified string.
exclude: Displays information that do not contain the specified string.
regular-expression: Regular expression, in the range of 1 to 256 characters, excluding spaces.
Table 1-1 Special characters in regular expressions
Special Characters
Special Meaning
Notes on Use
_
Underscore, similar to a wildcard character, can represent one of the following: (^|$|[,(){}])
a space, the beginning of the string, the end of the string
If the regular expression does not begin with an underscore (-), the number of underscores is not limited but is subject to the command line length.
If the regular expression begins with an underscore (-), then at most another four consecutive underscores can follow this underscore.
If the underscores (-) are not consecutive, then the first group of underscores (-) is used to filter the routing table. The subsequent underscores will be ignored.
Left paraphrase, represents a pull in stack.
Users are recommended not to use this character in a regular expression.
Full stop, wildcard character, matches any single character, including white space.
None
Star character, matches expressions with 0 or more single-character or multiple-character
 zo* matches z and zoo.
plus, matches expressions with 1 or more single-character or multiple-character
zo+ matches zo and zoo, but not z.
Use the display brief interface command to display brief interface information, including simple interface name, link state, protocol link state, protocol type, and main IP address.
l           If neither interface type nor interface number is specified, all interface information will be displayed;
l           If only interface type is specified, then only information of this particular type of interface will be displayed.
l           If both interface type and interface number are specified, then only information of the specified interface will be displayed.
Related command: interface.
Example
# Display brief information of interface(s).
<Sysname> display brief interface
The brief information of interface(s) under route mode:
Interface            Link      Protocol-link  Protocol type    Main IP
Aux1/0/0             UP        DOWN           --               11.1.1.1
NULL0                UP        UP(spoofing)   NULL
Vlan1                UP        UP             ETHERNET         192.168.0.36
Vlan2                DOWN      DOWN           ETHERNET
Vlan4                DOWN      DOWN           ETHERNET         20.1.1.1
Vlan5                DOWN      DOWN           ETHERNET
Vlan6                DOWN      DOWN           ETHERNET
Vlan8                DOWN      DOWN           ETHERNET
Vlan11               DOWN      DOWN           ETHERNET
Vlan200              DOWN      DOWN           ETHERNET
The brief information of interface(s) under bridge mode:
Interface            Link      Speed     Duplex   Link-type  PVID
Eth1/0/1             DOWN      auto      auto     access     1
Eth1/0/2             UP        100M(a)   full(a)  hybrid     1
Eth1/0/3             DOWN      auto      auto     access     1
Eth1/0/4             DOWN      auto      auto     access     1
Eth1/0/5             DOWN      auto      auto     access     1
Eth1/0/6             DOWN      auto      auto     access     1
Eth1/0/7             DOWN      auto      auto     access     1
Eth1/0/8             DOWN      auto      auto     access     1
Eth1/0/9             DOWN      auto      auto     access     1
Eth1/0/10            DOWN      auto      auto     access     1
Eth1/0/11            DOWN      auto      auto     access     1
Eth1/0/12            DOWN      auto      auto     access     1
GE1/1/1              DOWN      auto      auto     access     1
GE1/1/2              DOWN      auto      auto     access     1
GE1/1/3              DOWN      auto      auto     access     1
GE1/1/4              DOWN      auto      auto     access     1
# Display brief interface information that contains the string “UP”.
<Sysname> display brief interface | include DOWN
Table 1-2 Output description of the display brief interface command.
Brief information of interface(s) in route mode
Interface name
Link
 Interface physical link state, which can be up or down
Protocol-link
Interface protocol link state, which can be up or down
Protocol type
Interface protocol type
Main IP
Main IP
Brief information of interface(s) in bridge mode
Speed
 Interface rate, in bps
Duplex
Duplex mode, which can be half (half duplex), full (full duplex), or auto (auto-negotiation).
PVID
 Default VLAN ID
Table 1-3 Acronyms for different types of Interface
Interface name
Acronyms
Ethernet
Eth
GigabitEthernet
GE
Ten-GigabitEthernet
XGE
display interface [ interface-type [ interface-number ] ]
View
Parameter
Use the display interface command to display the current state of a specified interface and related information.
Example
# Display the current state of Layer 2 interface Ethernet1/0 and related information.
<Sysname> display interface Ethernet 1/0/1
 Ethernet1/0/1 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e200-2200
 Description: Ethernet1/0/1 Interface
 Loopback is not set
 Media type is twisted pair, Port hardware type is 100_BASE_TX
 Flow-control is not enabled
 The Maximum Frame Length is 1552
 Broadcast MAX-ratio: 100%
 PVID: 1
 Mdi type: auto
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Port priority: 0
 Last 300 seconds input:  0 packets/sec 0 bytes/sec
 Last 300 seconds output:  0 packets/sec 0 bytes/sec
 Input (total):  - packets, - bytes
          - broadcasts, - multicasts
 Input (normal):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, 0 frame, 0 overruns, 0 aborts
          - ignored, - parity errors
 Output (total): - packets, - bytes
          - broadcasts, - multicasts, - pauses
 Output (normal): 0 packets, 0 bytes
          0 broadcasts, 0 multicasts, 0 pauses
          - lost carrier, - no carrier
Table 1-4 Description on fields of the display interface command (in bridge mode)
Current physical link state of the Ethernet interface
Frame type of the Ethernet interface
Hardware address
Hardware address
Description of the interface
Loopback is not set
Loopback is not configured
The media type is twisted pair cable
Port hardware type
The hardware type of port
Unknown-speed mode
Unknown-speed mode, in which mode speed is negotiated between the current host and the peer
unknown-duplex mode
unknown-duplex mode, in which mode speed is negotiated between the current host and the peer
Link duplex type is autonegotiation
The maximum frame length allowed on an interface
Broadcast-suppression ratio(%)
Broadcast storm suppression ratio (the maximum ratio of allowed number of broadcast packets to overall traffic through an interface)
Allow jumbo frame to pass
Allow jumbo frame to pass through
PVID
Default VLAN ID
Mdi type
Cable type
Port link-type
Interface link type, which could be access, trunk, and hybrid.
Tagged   VLAN ID
Identify the VLANs that need Tag markers
Untagged VLAN ID
Identify the VLANs that do not need Tag markers
Port priority
The port priority
Average input rate over the last 300 seconds
Average output rate over the last 300 seconds
Statistics on the total incoming packets ( including normal packets, error packets ) on the port
The “-” indicates that the statistical item is not supported.
Statistics on the normal incoming packets on the port
Statistics on the abnormal incoming packets on the port
Statistics on the total outgoing packets ( including normal packets, error packets ) on the port
Statistics on the normal outgoing packets on the port
Statistics on the abnormal outgoing packets on the port
View
Parameter
None
Use the display loopback-detection command to display loopback detection information on a port
If loopback detection is already enabled, this command will also display the detection interval and information on the ports currently detected with a loopback.
Example
# Display loopback detection information on a port.
<Sysname> display loopback-detection
 Loopback-detection is running
 Detection interval time is 30 seconds
 There is no port existing loopback link
Table 1-5 Output description of the display loopback-detection command.
Detection interval is 30 seconds
No port is currently being detected with a loopback
1.1.7  display port
display port { hybrid | trunk I combo }
View
Parameter
hybrid: Displays the current Hybrid port(s).
trunk: Displays the current Trunk port(s).
combo: Displays the current Combo port(s) and the corresponding optical and electrical ports.
Use the display port command to display information on the current ports of a specified type, including port name, default VLAN ID, and the VLAN ID of VLANs that the ports can pass through.
Example
# Display the current Hybrid port(s).
<Sysname> display port hybrid
Interface            PVID  VLAN passing
Eth1/0/2             1     Tagged:  1-2
                           Untagged:none
# Display the current Trunk port(s).
<Sysname> display port trunk
Eth1/0/3             2     1-4
Table 1-6 Output description of the display port command.
Interface name
PVID
 Default VLAN ID of the interface
VLAN passing
display port combo
View
Parameter
None.
Use the display port combo command to display information of combo port on the current device.
&  Note:
Currently, only S5510 series Ethernet switches support combo port.
Example
# Display the current combo port(s).
<Sysname> display port combo
  Combo-group         Active                      Inactive
       1         GigabitEthernet1/0/21       GigabitEthernet1/0/25
       2         GigabitEthernet1/0/22       GigabitEthernet1/0/26
       3         GigabitEthernet1/0/23       GigabitEthernet1/0/27
       4         GigabitEthernet1/0/24       GigabitEthernet1/0/28
display port-group manual [all | name port-group-name ]
View
Parameter
all: All manual port groups.
name port-group-name: Name of a specified manual port group, a string of 1 to 32 characters.
Use the display port-group manual command to display information on a specified manual port group.
l           port-group-name: Displays the details for a specified manual port group, including its name and the Ethernet interface ports included.
l           all: Displays the details for all manual port groups, including their names and the Ethernet interface ports included.
l           Absence of parameters indicates that the names of all port groups will be displayed.
Example
# Display details for all manual port groups.
<Sysname> display port-group manual all
 Member of group1:
    Ethernet1/0/1            Ethernet1/0/2            Ethernet1/0/3
1.1.10  duplex
duplex { auto | full | half }
undo duplex
View
Parameter
auto: Indicates that the interface is in an auto-negotiation state.
full: Indicates that the interface is in a full-duplex state.
half: Indicates that the interface is in a half-duplex state. Gigabit Ethernet interfaces do not support half duplex.
Use the duplex command to configure the duplex mode for an Ethernet interface.
Use the undo duplex command to restore the duplex mode for an Ethernet interface to the default.
By default, the duplex mode for an Ethernet interface is auto.
Related command: speed.
Example
# Configure the interface Ethernet 1/0/1 to work in full-duplex mode.
[Sysname-Ethernet1/0/1] duplex full
1.1.11  flow-control
flow-control
undo flow-control
View
Parameter
None
Use the flow-control command to turn on flow control on an Ethernet interface.
 Use the undo flow-control command to turn off flow control on an Ethernet interface.
By default, flow control on an Ethernet interface is turned off.
&  Note:
The flow control can be implemented on the local Ethernet interface only when the flow control function is enabled on both the local and peer devices.
Example
# Turn on flow control on interface Ethernet1/0/1.
[Sysname-Ethernet1/0/1] flow-control
flow-interval interval
undo flow-interval
View
Parameter
interval: Time interval at which interface statistics is collected, in the range of 5 to 300 seconds, a multiple of 5. The default value is 300 seconds.
Use the flow-interval command to configure the time interval for collecting interface statistics. Use the undo flow-interval command to restore the default interval.
When you use the display interface interface-type interface-number command to display the information of a port, the system performs statistical analysis on the traffic flow passing through the port during the specified interval and displays the average rates in the interval. For example, if you set the interval to 100 seconds, the displayed information is as follows:
 Last 100 seconds input:  0 packets/sec 0 bytes/sec
 Last 100 seconds output:  0 packets/sec 0 bytes/sec
Related command: display interface.
Example
# Set the time interval for collecting interface statistics to 100 seconds.
[Sysname-Ethernet1/0/1] flow-interval 100
1.1.13  group-member
group-member interface-list
undo group-member interface-list
View
port group view
Parameter
interface-list: Ethernet interface list, in the format of
Use the group-member command to add an Ethernet interface to a specified manual port group.
Use the undo group-member command to remove a specified Ethernet interface from a manual port group.
By default, a manual port group is empty, that is, there is no Ethernet interface in it.
Example
# Add the interface Ethernet 1/0/1 to Ethernet 1/0/3 to the manual port group 1.
[Sysname] port-group manual group1
[Sysname-port-group-manual-group1] group-member Ethernet 1/0/1 to Ethernet 1/0/3
1.1.14  interface
View
Parameter
interface-type interface-number: The type and number of a specified interface.
&  Note:
l      Interface is identified by slot number/subslot number/interface number, for example, Ethernet 1/0/1 can be represented as 1/0/1.
l      For ease of user input, interface type can be abbreviated so long as it does not cause any confusion, for example, interface Ethernet 1/0/1 can be abbreviated as e1/0/1.
Use the interface command to enter the related interface view.
Example
# Enter interface view of the interface Ethernet 1/0/1.
jumboframe enable
undo jumboframe enable
View
Parameter
None
Use the jumboframe enable command to enable jumbo frames to pass through Ethernet interface. Use the undo jumboframe enable command to disable jumbo frames to pass through Ethernet interface.
By default, the device allows jumbo frames to pass through Ethernet interfaces.
The length of jumbo frames is 1552 bytes for 100M port, and is 10240 bytes for 1000M port.
The max length of frames is 1522 bytes when you disable jumbo frames to pass through Ethernet interface.
Example
# Enable jumbo frames to pass through all Ethernet interfaces.
[Sysname] jumboframe enable
1.1.16  loopback
undo loopback
View
Parameter
external: Enables external loopback testing on an Ethernet interface.
internal: Enables internal loopback testing on an Ethernet interface.
Use the loopback command to enable Ethernet interface loopback testing.
Use the undo loopback command to disable Ethernet interface loopback testing.
By default, Ethernet interface loopback testing is disabled.
&  Note:
l      Ethernet interface loopback testing should be enabled while testing certain functionalities, such as during the initial identification of any network failure.
l      While enabled, Ethernet interface loopback testing will work in a full-duplex mode. The interface will return to its original state upon completion of the loopback testing.
Example
# Configure to enable loopback testing on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] loopback internal
undo loopback-detection control enable
View
Parameter
None
Use the loopback-detection control enable command to enable loopback detection for a Trunk port or Hybrid port.
Use the undo loopback-detection control enable command to disable loopback detection for a Trunk port or Hybrid port.
l           When the loopback detection is enabled, if a port has been detected with loopback, it will be shutdown. A Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
l           When the loopback detection is disabled, if a port has been detected with loopback, a Trap message will be sent to the terminal. The port is still working properly.
By default, loopback detection for Trunk port and Hybrid port is disabled.
Note that this command is inapplicable to an Access port as its loopback detection is enabled by default.
Example
# Enable loopback detection for the Trunk port Ethernet 1/0/1.
[Sysname] loopback-detection enable
[Sysname-Ethernet1/0/1] port link-type trunk
[Sysname-Ethernet1/0/1] loopback-detection enable
[Sysname-Ethernet1/0/1] loopback-detection control enable
undo loopback-detection enable
View
System view/Ethernet interface view
Parameter
None
Use the loopback-detection enable command to enable loopback detection globally or on a specified port.
Use the undo loopback-detection enable command to disable loopback detection globally or on a specified port.
l           If an Access port has been detected with loopback, it will be shutdown. A Trap message will be sent to the terminal and the corresponding MAC address If a Trunk port or Hybrid port has been detected with loopback, a Trunk message will be sent to the terminal. They will be shutdown if the loopback testing function is enabled on them. In addition, a Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
By default, loopback detection is disabled for an Access, Trunk, or Hybrid port.
Related command: loopback-detection control enable.
  Caution:
l      Loopback detection on a given port is enabled only after the loopback-detection enable command has been issued in both system view and the interface view of the port.
l      Loopback detection on all ports will be disabled after the issuing of the undo loopback-detection enable command under system view.
Example
# Enable loopback detection on the interface Ethernet 1/0/1.
loopback-detection interval-time time
undo loopback-detection interval-time
View
Parameter
time: Time interval for port loopback detection, in the range of 5 to 300 seconds and defaults to 30.
Use the loopback-detection interval-time command to configure time interval for port loopback detection.
Use the undo loopback-detection interval-time command to restore the default time interval for port loopback detection.
Related command: display loopback-detection.
Example
# Set the time interval for port loopback detection to 10 seconds.
[Sysname] loopback-detection interval-time 10
undo loopback-detection per-vlan enable
View
Parameter
None
Use the loopback-detection per-vlan enable command to enable loopback detection in all VLANs with Trunk ports or Hybrid ports.
Use the undo loopback-detection per-vlan enable command to enable loopback detection in the default VLAN with Trunk ports or Hybrid ports.
By default, loopback detection is only enabled in the default VLAN(s) with Trunk ports or Hybrid ports.
Note that the loopback-detection per-vlan enable command is not applicable to access ports.
Example
# Enable loopback detection in all VLANs to which the Hybrid port Ethernet 1/0/1 belong.
[Sysname-Ethernet1/0/1] loopback-detection per-vlan enable
1.1.21  mdi
mdi { across | auto | normal }
undo mdi
View
Parameter
across: Specifies an Ethernet interface to use a cross-over cable.
auto: Specifies an Ethernet interface to identify the cable type automatically.
normal: Specifies an Ethernet interface to use a straight-through cable.
Use the mdi command to configure the cable type for an Ethernet interface.
Use the undo mdi command to restore the cable type for an Ethernet interface.
By default, an Ethernet interface uses auto-detection cable.
&  Note:
l      The Combo optical port does not support this command.
l      The GE port of S3610 Series Ethernet Switches only supports the mdi auto configuration.
Example
# Configure the interface Ethernet 1/0/1 to use cross over cable.
[Sysname-Ethernet1/0/1] mdi across
undo port link-type
View
Parameter
access: Specifies the link type of a port as Access.
hybrid: Specifies the link type of a port as Hybrid.
trunk: Specifies the link type of a port as Trunk.
Use the port link-type command to configure Ethernet port link type.
Use the undo port link-type command to restore Ethernet port link type to Access.
The above commands apply to the current port only while executed under Ethernet interface view, or to all ports in a port group while executed under port group view.
By default, link type for all Ethernet interfaces is Access.
Example
# Configure the interface Ethernet 1/0/1 to be Trunk port.
1.1.23  port-group
port-group { manual port-group-name | aggregation agg-id }
undo port-group manual port-group-name
View
Parameter
manual port-group-name: Name of a specified manual port group, a string of 1 to 32 characters.
aggregation agg-id: Number of the specified port aggregation group. The specified port aggregation group must already exist. You can use the display link-aggregation summary command to display brief information of all existing port aggregation groups.
l           Use the port-group manual command to enter a specified manual port group view. If the manual port group does not exist, you need to create it first before entering its view.
l           Use the port-group aggregation command to enter a port group aggregation view.
l           Use the undo port-group manual command to delete a specified manual port group.
By default, no manual port group is configured.
Example
# Create a manual port group 1.
reset counters interface [ interface-type [ interface-number ] ]
View
Parameter
interface-type: Interface type.
interface-number: Interface number.
Use the reset counters interface command to reset statistics for a specified interface.
To sample network traffic within a period of time for an interface, you need to reset the original interface statistics.
l           If neither interface type nor interface number is specified, all interface information will be reset;
l           If only interface type is specified, then only information of this particular type of interface will be reset.
l           If both interface type and interface number are specified, then only information of the specified interface will be reset.
Example
# Clear the statistics of Ethernet 1/0/1.
<Sysname> reset counters interface ethernet 1/0/1
1.1.25  shutdown
shutdown
View
Parameter
None
Use the shutdown command to shut down an Ethernet interface.
Use the undo shutdown command to turn on Ethernet interface.
In certain circumstances, modification to the interface parameters does not immediately take effect, and therefore, you need to shut down the relative interface to make the modification work.
Example
# Shut down the interface Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] shutdown
# Turn on the interface Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] undo shutdown
1.1.26  speed
speed { 10 | 100 | 1000 | auto }
undo speed
View
Parameter
10: Indicates that the interface rate is 10 Mbps.
100: Indicates that the interface rate is 100 Mbps.
1000: Indicates that the interface rate is 1000 Mbps.
auto: Indicates that the interface rate is in the auto-negotiation state.
Use the speed command to configure Ethernet interface data rate.
Use the undo speed command to restore Ethernet interface data rate.
By default, Ethernet interface data rate is automatically negotiated between peer Ethernet interfaces.
Note that the following:
l           The Combo port does not support the speed command.
l           The speed 1000 command is only applicable to Gigabit Ethernet interface.
Related command: duplex.
Example
# Configure data rate for the interface Ethernet 1/0/1 to 100 Mbps.
[Sysname-Ethernet1/0/1] speed 100
virtual-cable-test
View
Parameter
None
Use the virtual-cable-test command to enable the virtual cable test for an Ethernet interface and to display the testing result. The tested items include:
l           Cable status: Could be normal, abnormal, abnormal-open, abnormal-short, and failure;
l           Cable length;
l           Pair Impedance mismatch;
l           Pair skew;
l           Pair swap;
l           Pair polarity;
l           Insertion loss;
l           Return loss;
l           Near-end crosstalk.
By default, virtual cable test is disabled.
Note:
l           When the cable is functioning properly, the cable length in the test result represents no meaning;
l           When the cable is not functioning properly, the cable length in the test result represents the length from the current interface to the failed position.
l           For the 100M port, current device does not support getting the total cable length when the cable under normal status.
&  Note:
The virtual-cable-test command is not supported on a Combo optical port.
Example
# Enable the virtual cable test for the interface Ethernet 1/0/1.
[Sysname-Ethernet1/0] virtual-cable-test
Cable status: abnormal(open), 7 metres
Pair Impedance mismatch: yes
Pair skew: 4294967294 ns
Pair swap: swap
Pair polarity: normal
Insertion loss: 7 db
Return loss: 7 db
Near-end crosstalk: 7 db
View
Parameter
None
Use the display lacp system-id command to display the local system ID, which comprises system LACP priority and system MAC address.
Example
# Display the local system ID.
<Sysname> display lacp system-id
 Actor System ID: 0x8000, 00e0-fc00-0100
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
Parameter
interface interface-type interface-number [ to interface-type interface-number ]: Specifies an interface range or an interface if the to keyword and the second interface are not specified.
Use the display link-aggregation interface command to display detailed information about link aggregation on the specified port or ports.
You may find that information about the remote system is replaced by 0 and no statistics about LACPDUs are provided for manual link aggregation groups. This is normal because this type of aggregation group has no knowledge of its partner and does not use LACPDUs for maintaining link aggregation.
Example
# Display detailed information about link aggregation for port Ethernet 1/0/1 in a manual aggregation group.
<Sysname> display link-aggregation interface ethernet1/0/1
Flags:  A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
 Ethernet1/0/1:
   Selected AggID: 3
   Local:
     Port-Priority: 32768, Oper key: 1, Flag: {}
   Remote:
     System ID: 0x0, 0000-0000-0000
     Port Number: 0, Port-Priority: 0 , Oper-key: 0, Flag: {}
# Display detailed information about link aggregation for port Ethernet 1/0/1 in a dynamic aggregation group.
<Sysname> display link-aggregation interface ethernet1/0/2
 Ethernet1/0/2:
   Selected AggID: 0
   Local:
     Port-Priority:    0, Oper key: 2, Flag: {ACG}
   Remote:
     System ID: 0x8000, 0000-0000-0000
     Port Number: 0, Port-Priority: 32768 , Oper-key: 0, Flag: {EF}
   Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 0 packet(s)
Table 2-1 Description on the fields of display link-aggregation interface
Flags
One-octet LACP flags field indicates the actor state variables for the port. From the least to the most significant bit, they are represented by A through H as follows:
A –– Enabling/disabling of LACP, 1 for enabled and 0 for disabled
B –– Timeout control value, 1 for short timeout, and 0 for long timeout
C –– Whether the system considers this link to be aggregatable, 1 for true, and 0 for false
D –– Whether the system considers that this link is synchronized, 1 for true, and 0 for false
E –– Whether collection of incoming frames is enabled on the link, 1 for true and 0 for false
F –– Whether distribution of outgoing frames is enabled on the link, 1 for true and 0 for false
G –– Whether the receive state machine of the actor is using default operational partner information, 1 for true and 0 for false
H –– Whether the receive state machine of the actor is in the expired state, 1 for true and 0 for false
If a flag bit is set to 1, the corresponding English letter that otherwise is not output displays.
Selected AggID
ID of the link aggregation group of which this port is a member
Local:
Port-Priority, Oper key, Flag
Local port LACP priority, operational key, LACP state flag
Remote:
System ID, Port Number, Port-Priority, Oper-key, Flag
Remote system ID, port number, port LACP priority, operational key, and LACP state flag
Received LACP Packets, Illegal, Sent LACP Packets
Statistics about received, invalid, and sent LACP packets
display link-aggregation service-type [ agg-id ]
View
Parameter
agg-id: Service loop group ID, same as its associated aggregation group.
Use the display link-aggregation service-type command to display information about the specified or all service loop groups.
Example
# Display information about service loop group 1.
<Sysname> display link-aggregation service-type 1
 Service-Loop         Service                    Quote
   Group ID            Type                      Number
     1                ipv6                          0
Table 2-2 Description on the fields of display link-aggregation service-type
Service-Loop Group ID
Service Type
Service type supported by the group
Quote Number
Reference count for the service loop group. Only after it decreases to zero can you remove the group.
View
Parameter
None
Use the display link-aggregation summary command to display a summary for all link aggregation groups.
You may find that information about the remote system for a manual link aggregation group is either replaced by none or not displayed at all. This is normal because this type of aggregation group has no knowledge of its partner.
Example
# Display the link aggregation group summary.
<Sysname> display link-aggregation summary
 Aggregation Group Type: D -- Dynamic, S -- Static, M -- Manual
Loadsharing Type: Shar – Loadsharing, NonS – Non-Loadsharing
Actor ID: 0x8000, 00e0-fcff-ff04
 AL  AL  Partner ID           Select    Unselected  Share   Master
 ID  Type                          Ports Ports       Type        Port
 1   D   0x8000,00e0-fcff-ff01 1        0           NonS        Ethernet1/1
 10  M   none                  1        0           NonS        Ethernet1/2
 20  S   0x8000,00e0-fcff-ff01 1        0           NonS        Ethernet1/3
Table 2-3 Description on the fields of display link-aggregation summary
Actor ID
Local system ID
AL ID
Link aggregation group ID
AL Type
Link aggregation type: manual, static LACP, or dynamic LACP
Partner ID
Remote system ID
Select Ports
Number of selected ports
Unselected Ports
Number of unselected ports
Share Type
Load sharing type
Master Port
Master port number
display link-aggregation verbose [ agg-id ]
View
Parameter
agg-id: ID of an existing link aggregation group. Its value range varies by device.
Use the display link-aggregation verbose command to display detailed information about the specified or all link aggregation groups.
Example
# Display detailed information about link aggregation group 1.
<Sysname> display link-aggregation verbose
Aggregation ID: 1,  AggregationType: Static,   Loadsharing Type: Shar
Aggregation Description:
System ID: 0x8000, 00e0-fc00-0001
Port Status: S -- Selected,  U -- Unselected
Local:
  Port             Status  Priority  Oper-Key  Flag
  Eth1/0          S       32768     1         {ACDEFG}
  Eth1/1          U       32768     1         {ACG}
  Eth1/2          U       32768     2         {ACG}
Remote:
  Actor            Partner Priority  Oper-Key  SystemID               Flag
  Eth1/0          0       32768     0         0x8000,0000-0000-0000  {DEF}
  Eth1/1          0       32768     0         0x8000,0000-0000-0000  {DEF}
  Eth1/2          0       32768     0         0x8000,0000-0000-0000  {EF}
Table 2-4 Description on the fields of display link-aggregation verbose
Loadsharing Type
Load sharing type, either shar for loadsharing or NonS for non-load sharing
Flags
Aggregation ID
AggregationType
Link aggregation group name
System ID
Local system ID
Port State
Port state in a link aggregation group: selected or unselected
Local:
Port, Status, Priority, Oper-key, Flag
Other information about the local end, including member ports, port state, port LACP priority, operational key, and flags
Remote:
Actor, Partner, Priority, Oper-key, SystemID, Flag
Detailed information about the remote end, including corresponding local port, port ID, port LACP priority, operational key, system ID, and flags
2.1.6  lacp enable
lacp enable
undo lacp enable
View
Ethernet interface view, port-group view
Parameter
None
Use the lacp enable command to enable LACP on the port or ports in the port group.
Use the undo lacp enable command to disable LACP on the port or ports in the port group.
Example
# Enable LACP on port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] lacp enable
lacp port-priority port-priority
undo lacp port-priority
View
Parameter
port-priority: Port LACP priority, in the range 0 to 65,535. It defaults to 32,768.
Use the lacp port-priority command to assign an LACP priority to the port or ports in the port group.
Use the undo lacp port-priority command to restore the default.
Related command: display link-aggregation interface, display link-aggregation verbose.
Example
# Assign LACP priority 64 to a port.
[Sysname-Ethernet1/0/1] lacp port-priority 64
lacp system-priority system-priority
undo lacp system-priority
View
Parameter
system-priority: System LACP priority, in the range 0 to 65,535. It defaults to 32,768.
Use the lacp system-priority command to assign an LACP priority to the local system.
Use the undo lacp system-priority command to restore the default.
Example
# Assign LACP priority 64 to the local system.
[Sysname] lacp system-priority 64
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
Parameter
agg-id: Link aggregation group ID. Its value range varies by device.
agg-name: Link aggregation group name, in the range 1 to 32 characters.
Use the link-aggregation group description command to configure a name for the specified link aggregation group.
Use the undo link-aggregation group description command to remove the name of the specified link aggregation group.
Note that the configuration of dynamic LACP link aggregation groups including their group names cannot survive a reboot even if you have saved configuration with the save command before that.
Related command: display link-aggregation verbose.
Example
# Name link aggregation group 22 as abc.
[Sysname] link-aggregation group 22 description abc
link-aggregation group agg-id mode { manual | static }
View
Parameter
manual: Manual link aggregation mode.
static: Static LACP link aggregation mode.
Use the link-aggregation group mode command to create a manual or static LACP link aggregation group.
Use the undo link-aggregation group command to remove a link aggregation group. If the group is functioning as a service loop group, this can result in the removal of the service loop group.
You can use the undo form of the command to remove a dynamic LACP link aggregation group even though you cannot manually create one. After that, the member ports in the group form another group with an ID that can be the same as or different than the old one.
Related command: display link-aggregation summary.
Example
# Create manual link aggregation group 22.
[Sysname] link-aggregation group 22 mode manual
link-aggregation group agg-id service-type
undo link-aggregation group agg-id service-type
View
Parameter
Tunnel: Sets/modifies the service type to tunnel.
Use the link-aggregation group service-type command to create a service loop group or modify the service supported by an existing service loop group.
Use the link-aggregation group mode command to remove a service loop group.
You can only use a manual link aggregation group to create a service loop group. This group can support MPLS or any service combinations of IPv6, IPv6 multicast, and tunnel. If another service loop group is providing the intended service, however, your creation or service-type modification attempt will fail.
Example
# Configure link aggregation group 5 as a tunnel service loop group.
<Sysname>system-view
[Sysname] link-aggregation group 5 service-type tunnel
port link-aggregation group agg-id
undo port link-aggregation group
View
Parameter
Use the port link-aggregation group command to assign the Ethernet port to the specified link aggregation group (manual or static LACP) or service loop group.
Use the undo port link-aggregation group command to remove the Ethernet port from the specified aggregation group or service loop group.
Note that this command and its undo form cannot work with the ports in a dynamic LACP link aggregation group.
Example
# Assign port Ethernet 1/0/1 to link aggregation group 22.
[Sysname-Ethernet1/0/1] port link-aggregation group 22
port-group aggregation agg-id
View
Parameter
agg-id: Aggregation port group ID, same as the ID of its corresponding link aggregation group. Its value range varies by device.
Use the port-group aggregation command to enter aggregation port group view.
Instead of being created administratively, an aggregation port group is created automatically upon the creation of a link aggregation group and assigned the ID of the link aggregation group.
In aggregation port group view, you can configure aggregation related settings such as MSTP, VLAN, QoS, GVRP, QinQ, BPDU tunnel, and multicast, but cannot add or remove member ports.
Example
# Enter aggregation port group view.
[Sysname] port-group aggregation 10
[Sysname-port-group-aggregation-10]
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Parameter
Use the reset lacp statistics command to clear statistics about LACP on specified or all ports.
Related command: display link-aggregation interface.
Example
# Clear statistics about LACP on all ports.
<Sysname> reset lacp statistics
View
Parameter
None
Use the display port-isolate group command to display information of default Isolation Group 1.
Example
# Display the isolation group and its information.
<Sysname> display port-isolate group
 Port-isolate group information:
 Uplink port support: YES
 Group ID: 1
Uplink port: Ethernet1/0/4
port-isolate enable
undo port-isolate enable
View
Ethernet interface view or interface group view
Parameter
None
Use the port-isolate enable command to add a port to the isolation group as ordinary port only.
Use the undo port isolate command to remove the port from the isolation group.
Note: Current device only support one Isolation Group.
Configured in Ethernet interface view, the setting is effective on the current port only; configured in port group view, the setting is effective on all ports in the port group.
&  Note:
For the same port, only one of the port-isolate enable command and the port-isolate uplink-port command is available, that is, a port cannot be configured as an ordinary port and an uplink port at the same time in the isolation group.
Example
# Add port Ethernet 1/0/1 to the isolation group.
[Sysname-Ethernet1/0/1] port-isolate enable
undo port-isolate uplink-port
View
Parameter
group-number: Specifies an isolation group number. The range available varies with devices. Refer to the specific requirement of your device.
Use the port-isolate uplink-port command to add the specified port as the uplink port of the isolation group.
Use the undo port-isolate uplink-port command to remove the specified port as the uplink port of the isolation group.
  Caution:
l      This command is used to configure the uplink port of Isolation Group 1.
l      For the same port, only one of the port-isolate enable command and the port-isolate uplink-port command is available, that is, a port cannot be configured as an ordinary port and an uplink port at the same time in the isolation group.
Example
# Configure the port Ethernet1/0/1 as a uplink port of the isolation group.
[Sysname-Ethernet1/0/1] port-isolate uplink-port
