H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
11-IPv6 Routing Command
11-IPv6 Routing Command 679 KB
Table of Contents
Chapter 1 IPv6 Static Routing Configuration Commands. 1-1
1.1 IPv6 Static Routing Configuration Commands. 1-1
1.1.1 delete ipv6 static-routes all 1-1
1.1.2 ipv6 route-static. 1-2
Chapter 2 IPv6-RIPng Configuration Commands. 2-1
2.1 RIPng Configuration Commands. 2-1
2.1.1 checkzero. 2-1
2.1.2 default cost 2-2
2.1.3 display ripng. 2-2
2.1.4 display ripng database. 2-4
2.1.5 display ripng interface. 2-5
2.1.6 display ripng route. 2-6
2.1.7 filter-policy export 2-7
2.1.8 filter-policy import 2-8
2.1.9 import-route. 2-9
2.1.10 maximum load-balancing. 2-10
2.1.11 preference. 2-11
2.1.12 ripng. 2-11
2.1.13 ripng default-route. 2-12
2.1.14 ripng enable. 2-13
2.1.15 ripng metricin. 2-14
2.1.16 ripng metricout 2-14
2.1.17 ripng poison-reverse. 2-15
2.1.18 ripng split-horizon. 2-16
2.1.19 ripng summary-address. 2-16
2.1.20 timers. 2-17
Chapter 3 IPv6-OSPFv3 Configuration Commands. 3-1
3.1 OSPFv3 Configuration Commands. 3-1
3.1.1 abr-summary. 3-1
3.1.2 area. 3-2
3.1.3 default cost 3-3
3.1.4 default-cost 3-3
3.1.5 display debugging ospfv3. 3-4
3.1.6 display ospfv3. 3-5
3.1.7 display ospfv3 interface. 3-6
3.1.8 display ospfv3 lsdb. 3-8
3.1.9 display ospfv3 lsdb statistic. 3-11
3.1.10 display ospfv3 next-hop. 3-12
3.1.11 display ospfv3 peer 3-13
3.1.12 display ospfv3 peer statistic. 3-15
3.1.13 display ospfv3 request-list 3-16
3.1.14 display ospfv3 retrans-list 3-17
3.1.15 display ospfv3 routing. 3-19
3.1.16 display ospfv3 statistic. 3-20
3.1.17 display ospfv3 topology. 3-22
3.1.18 display ospfv3 vlink. 3-23
3.1.19 filter-policy export 3-24
3.1.20 filter-policy import 3-25
3.1.21 import-route. 3-26
3.1.22 maximum load-balancing. 3-27
3.1.23 ospfv3. 3-28
3.1.24 ospfv3 area. 3-29
3.1.25 ospfv3 cost 3-29
3.1.26 ospfv3 dr-priority. 3-30
3.1.27 ospfv3 mtu-ignore. 3-31
3.1.28 ospfv3 timer dead. 3-31
3.1.29 ospfv3 timer hello. 3-32
3.1.30 ospfv3 timer retransmit 3-33
3.1.31 ospfv3 trans-delay. 3-34
3.1.32 router-id. 3-34
3.1.33 silent-interface. 3-35
3.1.34 spf timers. 3-36
3.1.35 stub. 3-37
3.1.36 vlink-peer 3-38
Chapter 4 IPv6-IS-IS Configuration Commands. 4-1
4.1 IPv6-IS-IS Configuration Commands. 4-1
4.1.1 display isis route ipv6. 4-1
4.1.2 ipv6 default-route-advertise. 4-4
4.1.3 ipv6 enable. 4-5
4.1.4 ipv6 filter-policy export 4-6
4.1.5 ipv6 filter-policy import 4-7
4.1.6 ipv6 import-route. 4-8
4.1.7 ipv6 import-route isisv6 level-2 into level-1. 4-9
4.1.8 ipv6 maximum load-balancing. 4-10
4.1.9 ipv6 preference. 4-11
4.1.10 ipv6 summary. 4-11
4.1.11 isis ipv6 enable. 4-12
Chapter 5 IPv6-BGP4+ Configuration Commands. 5-1
5.1 BGP4+ Configuration Commands. 5-1
5.1.1 balance. 5-1
5.1.2 bestroute as-path-neglect 5-2
5.1.3 bestroute compare-med. 5-2
5.1.4 bestroute med-confederation. 5-3
5.1.5 compare-different-as-med. 5-4
5.1.6 dampening. 5-4
5.1.7 default local-preference. 5-5
5.1.8 default med. 5-6
5.1.9 default-route imported. 5-7
5.1.10 display bgp ipv6 group. 5-8
5.1.11 display bgp ipv6 network. 5-9
5.1.12 display bgp ipv6 paths. 5-10
5.1.13 display bgp ipv6 peer 5-11
5.1.14 display bgp ipv6 routing-table. 5-13
5.1.15 display bgp ipv6 routing-table as-path-acl 5-15
5.1.16 display bgp ipv6 routing-table community. 5-15
5.1.17 display bgp ipv6 routing-table community-list 5-16
5.1.18 display bgp ipv6 routing-table dampened. 5-17
5.1.19 display bgp ipv6 routing-table dampening parameter 5-18
5.1.20 display bgp ipv6 routing-table different-origin-as. 5-19
5.1.21 display bgp ipv6 routing-table flap-info. 5-20
5.1.22 display bgp ipv6 routing-table label 5-21
5.1.23 display bgp ipv6 routing-table peer 5-22
5.1.24 display bgp ipv6 routing-table regular-expression. 5-23
5.1.25 display bgp ipv6 routing-table statistic. 5-23
5.1.26 filter-policy export 5-24
5.1.27 filter-policy import 5-25
5.1.28 group. 5-26
5.1.29 import-route. 5-26
5.1.30 ipv6-family. 5-27
5.1.31 network. 5-28
5.1.32 peer advertise-community. 5-29
5.1.33 peer advertise-ext-community. 5-29
5.1.34 peer allow-as-loop. 5-30
5.1.35 peer as-number 5-31
5.1.36 peer as-path-acl 5-32
5.1.37 peer capability-advertise route-refresh. 5-32
5.1.38 peer connect-interface. 5-33
5.1.39 peer default-route-advertise. 5-34
5.1.40 peer description. 5-35
5.1.41 peer ebgp-max-hop. 5-35
5.1.42 peer fake-as. 5-36
5.1.43 peer filter-policy. 5-37
5.1.44 peer group. 5-38
5.1.45 peer ignore. 5-38
5.1.46 peer ipv6-prefix. 5-39
5.1.47 peer keep-all-routes. 5-40
5.1.48 peer log-change. 5-41
5.1.49 peer next-hop-local 5-41
5.1.50 peer preferred-value. 5-42
5.1.51 peer public-as-only. 5-43
5.1.52 peer reflect-client 5-43
5.1.53 peer route-limit 5-44
5.1.54 peer route-policy. 5-45
5.1.55 peer route-update-interval 5-46
5.1.56 peer substitute-as. 5-47
5.1.57 peer timer 5-47
5.1.58 preference. 5-48
5.1.59 reflect between-clients. 5-49
5.1.60 reflector cluster-id. 5-50
5.1.61 refresh bgp ipv6. 5-51
5.1.62 reset bgp ipv6. 5-51
5.1.63 reset bgp ipv6 dampening. 5-52
5.1.64 reset bgp ipv6 flap-info. 5-53
5.1.65 router-id. 5-53
5.1.66 synchronization. 5-54
5.1.67 timer 5-55
Chapter 6 Routing Policy Configuration Commands. 6-1
6.1 Public Routing Policy Configuration Commands. 6-1
6.2 IPv6 Routing Policy Configuration Commands. 6-1
6.2.1 apply ipv6 next-hop. 6-1
6.2.2 display ip ipv6-prefix. 6-2
6.2.3 if-match ipv6. 6-3
6.2.4 ip ipv6-prefix. 6-4
6.2.5 reset ip ipv6-prefix. 6-5
&  Note:
l      Verify that the system already operates in IPv4/IPv6 dual-stack mode before configuring IPv6 routing.
l      All the IPv6 routing related configuration mentioned in this manual assumes that the system already operates in IPv4/IPv6 dual-stack mode. For dual stack mode configuration, see the part covering dual stack in the IPv6 Configuration module.
View
Parameter
None
Use the delete ipv6 static-routes all command to delete all IPv6 static routes including the default route.
When using this command, you will be prompted whether to continue the deletion and only after you have confirmed the deletion will the static routes be deleted.
Related command: display ipv6 routing-table, ipv6 route-static.
Example
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all ipv6 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:y
ipv6 route-static ipv6-address prefix-length [ interface-type interface-number ] nexthop-address [ preference preference-value ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number ] [ nexthop-address ] [ preference preference-value ]
View
Parameter
ipv6-address prefix-length: IPv6 address and prefix length.
interface-type interface-number: The interface type and interface number of the output interface.
nexthop-address: Next hop IPv6 address.
preference-value: Route preference value, in the range of 1 to 255. Defaults to 60.
Use the ipv6 route-static command to configure an IPv6 static route.
Use the undo ipv6 route-static command to remove an IPv6 static route.
An IPv6 static route that has the destination address configured as “::/0” (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entries in the routing table, this default route will be used to forward the packet.
While configuring static routes, you can configure either the output interface or the next-hop address depending on the situations:
Related command: display ipv6 routing-table, delete ipv6 static-routes all.
Example
# Configure a static IPv6 route, with the destination address being 1:1:2::/24 and next hop being 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 24 1:1:3::1
&  Note:
2.1.1  checkzero
checkzero
undo checkzero
View
RIPng view
Parameter
None
Use the checkzero command to enable the zero field check for RIPng packet headers.
Use the undo checkzero command to disable the zero field check.
The zero field check is enabled by default.
Some fields in RIPng packet headers must be zero. These fields are called zero fields.  You can enable the zero field check for RIPng packet headers. If any such field contains a non-zero value, the entire RIPng packet will not be processed.
Example
# Enable the zero field check for RIPng packet headers.
[Sysname] ripng 100
[Sysname-ripng-100] checkzero
# Disable the zero field check for RIPng packet headers.
[Sysname-ripng-100] undo checkzero
2.1.2  default cost
default cost value
undo default cost
View
RIPng view
Parameter
value: Default metric of a redistributed route, in the range of 0 to 16.
Use the default cost command to define the default metric of a redistributed route.
Use the undo default cost command to restore the default metric defined in the above command.
By default, the default metric of redistributed routes is 0.
The metric of a redistributed route is determined by the default cost command when you use the import-route command, with value not specified, to redistribute other protocol routes
Related command: import-route.
Example
# Set the default metric of a redistributed route to 2.
[Sysname] ripng 100
[Sysname-ripng-100] default cost 2
2.1.3  display ripng
display ripng [ process-id ]
View
Parameter
process-id: RIPng process number, in the range of 1 to 65535.
Use the display ripng command to display the running status and configuration information of a RIPng process. If process-id is not specified, information of all RIPng processes will be displayed. Otherwise, only the information of the specified RIPng process will be displayed.
Example
# Display the information of all configured RIPng processes.
<Sysname> display ripng
    RIPng process : 1
       Preference : 100
       Checkzero : Enabled
       Default Cost : 0
       Maximum number of balanced paths : 3
       Update time   :   30 sec(s)  Timeout time           :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-Collect time :  240 sec(s)
       Number of periodic updates sent : 0
       Number of trigger updates sent : 0
Table 2-1 Description on the fields of the display ripng command
RIPng Process
Preference
RIPng route priority
Checkzero
Zero field check for RIPng packet headers
Default Cost
Default metric of a redistributed route.
Maximum number of equivalent routes
Update time
RIPng updating interval, in seconds
Timeout time
RIPng timeout interval, in seconds
Suppress time
RIPng suppress interval, in seconds
RIPng garbage collection interval, in seconds
Number of RIPng updates sent periodically
Number of RIPng updates triggered to be sent
display ripng process-id database
View
Parameter
Use the display ripng database command to display all active routes in the RIPng advertised database, which are sent in normal RIPng update messages.
Example
# Display the active routes in the database advertised by RIPng process 100.
<Sysname> display ripng 100 database
   2001:7B::2:2A1:5DE/64,
        cost 4, Imported
   1:13::/120,
        cost 4, Imported
   1:32::/120,
        cost 4, Imported
   1:33::/120,
        cost 4, Imported
   100::/32,
       via FE80::200:5EFF:FE04:3302, cost 2
   3FFE:C00:C18:1::/64,
       via FE80::200:5EFF:FE04:B602, cost 2
       via FE80::200:5EFF:FE04:B601, cost 2
   3FFE:C00:C18:2::/64,
   3FFE:C00:C18:3::/64,
   4000:1::/64,
   4000:2::/64,
Table 2-2 Description on fields of the display ripng database command
IPv6 destination address/prefix length
via
The next hop IPv6 address
cost
Route metric value
Imported
Routes learnt from other routing protocols
display ripng process-id interface [ interface-type interface-number ]
View
Parameter
interface-type interface-number: Interface type and interface number.
Use the display ripng interface command to display the RIPng interface information.
Example
# Display interface information of RIPng process 1.
<Sysname> display ripng 1 interface
Interface-name: Vlan-interface 100
         Link Local Address: FE80::200:5EFF:FE19:3E00
         Split-horizon: on            Poison-reverse: off
         MetricIn: 0                  MetricOut: 1
         Default route: off
Table 2-3 Description on the fields of the display ripng interface command
Interface-name
Name of an interface running RIPng.
Link Local Address
Link-local address of an interface running RIPng
Split-horizon
Indicates whether the split horizon function is enabled (on: Enabled    off: Disabled).
Poison-reverse
Indicates whether the poison reverse function is enabled (on: Enabled   off: Disabled).
MetricIn/MetricOut
Additional metric to incoming and outgoing routes
Default route
l      Default-route: only or Default-route: originate, indicates advertising default route. Only means that the interface only default route is advertised. Originate means that the default route and other RIPng routes are advertised.
l      Default-route: off, indicates that no default route is defined or the garbage-collect time expires after stopping the default route announcement.
l      Default-route: in garbage-collect status (in second), after default route announcement, the interface advertises the default route with metric 16 during the garbage-collect time.
display ripng process-id route
View
Parameter
Use the display ripng route command to display routing information of RIPng and timers associate to each route.
Example
# Display routing information of RIPng process 100.
<Sysname> display ripng 100 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::20F:E2FF:FE00:220A  on Vlan-interface100
 Dest 4:3::/64,
     via FE80::20F:E2FF:FE00:220A, cost  1, tag 0, A, 34 Sec
Table 2-4 Description on the fields of the display ripng route command
Peer
Neighbor connected to the interface
Dest
via
cost
Routing metric value
tag
Route tag
Sec
Time that a route entry stays in a particular state
“A”
The route is in the aging state
“S”
The route is in the suppressed state
“G”
The route is in the Garbage-collect state
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
View
RIPng view
Parameter
acl6-number: ACL number used to filter advertised routing information, in the range of 2000 to 3999.
ipv6-prefix-name: Prefix name of the destination IPv6 address which is used to filter routing information, a string of 1 to 19 characters.
protocol: Routing protocol of the filtered routing information, currently including bgp4+, direct, isisv6, ospfv3, ripng, and static
process-id: Process number of the routing protocol of the filtered routing information, in the range of 1 to 65535. This argument must be specified when the routing protocol is rip, ospf, or isisv6.
Use the filter-policy export command to define the export filtering policy. Only filtered routes can be announced in the update messages.
Use the undo filter-policy export command to remove the export filtering policy.
By default, RIPng does not filter any advertised routing information.
If the protocol argument is specified when this command is executed, routing information of the redistributed route of the specified routing protocol will be displayed. Otherwise, routing information of all advertised routing information will be displayed.
Example
# Use Filter 2 list to filter the advertised RIPng update messages.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter2 export
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
undo filter-policy import
View
RIPng view
Parameter
acl6-number: ACL number used to filter received routing information, in the range of 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Uses the prefix name of IPv6 addresses to filter routes. The ipv6-prefix-name argument represents the prefix name of the destination IPv6 address which is used to filter routing information and consists of 1 to 19 characters.
Use the filter-policy import command to filter received routing information. Only routes which meet the filtering policy can be received.
Use the undo filter-policy import command to remove the filtering policy.
By default, RIPng does not filter received routing information.
Example
# Use Filter 1 list to filter the received RIPng update messages.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter1 import
2.1.9  import-route
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name ] *
undo import-route protocol [ process-id ]
View
RIPng view
Parameter
protocol: Routing protocols that RIPng can redistribute, currently including bgp4+, direct, isisv6, ospfv3, ripng, and static.
process-id: Process number of the redistributed routing protocol, in the range of 1 to 65535, valid for isisv6, ospfv3, and ripng.
cost-value: Routing metric of a redistributed route, in the range of 0 to 16. If cost value is not specified, the metric is the default defined by the default cost command.
route-policy route-policy-name: Specifies a route policy name consisting of 1 to 19 characters.
allow-ibgp: The keyword allow-ibgp is only available when the protocol is bgp4+. The command import-route bgp4+ means only EBGP routes are redistributed. The command import-route bgp4+ allow-ibgp means IBGP routes are also included.
Use the import-route command to redistribute routes learnt from other routing protocols.
Use the undo import-route command to remove the redistributed routes.
You can filter the redistributed routes and define the route attribute through the route policy.
By default, RIPng does not redistribute other routes.
l           You can specify route-policy to configure a route policy so that specific routes can be redistributed.
l           You can specify cost to configure a routing metric for a redistributed route.
Related command: default cost.
Example
# Redistribute an IPv6-IS-IS route (process 7) and define the metric as 7.
[Sysname] ripng 100
[Sysname-ripng-100] import-route isisv6 7 cost 7
maximum load-balancing number
undo maximum load-balancing
View
RIPng view
Parameter
number: Maximum number of equivalent routes in load sharing mode. in the range of 1 to 4
Use the maximum load-balancing command to define the maximum number of equivalent routes in load sharing mode.
Use the undo maximum load-balancing command to restore the default maximum number of equivalent routes.
By default, the Maximum number of equivalent routes is 4.
&  Note:
Configure the maximum number of equivalent routes according to the memory size.
Example
# Set the maximum number of equivalent routes in load sharing mode to 2.
[Sysname] ripng 100
[Sysname-ripng-100] maximum load-balancing 2
# Restore the default maximum number of equivalent routes.
[Sysname-ripng-100] undo maximum load-balancing
2.1.11  preference
preference [ route-policy route-policy-name ] value
undo preference [ route-policy ]
View
RIPng view
Parameter
route-policy-name: Name of a route policy, consisting of 1 to 19 characters. A priority level is set for routes satisfying specific conditions.
value: Route priority level, in the range of 1 to 255.
Use the preference command to define the RIPng route priority.
Use the undo preference route-policy command to restore the default route priority.
By default, the priority of a RIPng route is 100.
You can apply a route policy to set a priority for a specific route by assigning a value to the route-policy keyword:
l           If a priority is set for a matched route in the route policy, the priority of the matched route is the one set in the route policy while the priorities of other routes are those set by the preference command.
l           If no priority is set for a matched route in the route policy, the priorities of all routes are set by the preference command.
Example
# Set the RIPng route priority to 120.
[Sysname] ripng 100
[Sysname-ripng-100] preference 120
# Restore the default RIPng route priority.
[Sysname-ripng-100] undo preference
2.1.12  ripng
undo ripng [ process-id ]
View
Parameter
process-id: RIPng process number, in the range of 1 to 65535. The default value is 1.
Use the ripng command to create a RIPng process and enter RIPng view.
Use the undo ripng command to stop running a RIPng process.
By default, the system does not run any RIPng process.
Example
# Create RIPng process 100 and enter RIPng view.
[Sysname] ripng 100
[Sysname-ripng-100]
# Stop running RIPng process 100.
[Sysname] undo ripng 100
ripng default-route { only | originate } [ cost value ]
undo ripng default-route
View
Interface view
Parameter
only: Indicates that only IPv6 default route (::/0) is advertised.
originate: Indicates that the IPv6 default route (::/0) is advertised without suppressing other routes.
value: Metric of the advertised default route, in the range of 1 to 15, with a default value of 1.
Use the ripng default-route command to advertise a default route with the specified routing metric to a RIPng neighbor.
Use the undo ripng default-route command to stop advertising and forwarding the default route.
By default, a RIP process does not advertise the default route.
After you execute this command, the generated RIPng default route is advertised via a route update message over the specified interface. This IPv6 default route is advertised without considering whether it already exists in IPv6 routing table.
Example
# Configure RIPng on Vlan-interface100 to advertise only the default route in an update message from this interface.
[Sysname-Vlan-interface100] ripng default-route only
Configure RIPng on Vlan-interface101 to advertise the default route together with other routes in an update message from this interface.
[Sysname] interface vlan-interface 101
[Sysname-Vlan-interface101] ripng default-route originate
2.1.14  ripng enable
ripng process-id enable
undo ripng
View
Interface view
Parameter
Use the ripng enable command to enable RIPng on the specified interface.
Use the undo ripng command to disable RIPng on the specified interface.
By default, RIPng is disabled on an interface.
Example
# Enable RIPng100 on Vlan-interface100.
[Sysname-Vlan-interface100] ripng 100 enable
ripng metricin value
undo ripng metricin
View
Interface view
Parameter
value: Additional metric to a received route, in the range of 0 to 16.
Use the ripng metricin command to define an additional metric for a received RIPng route.
Use the undo ripng metricin command to restore the default additional metric.
By default, the additional metric to a received route is 0.
Related command: ripng metricout.
Example
# Define the additional routing metric as 12 for a RIPng route received by Vlan-interface100.
[Sysname-Vlan-interface100] ripng metricin 12
ripng metricout value
undo ripng metricout
View
Interface view
Parameter
value: Additional metric to an advertised route, in the range of 1 to 16, with a default value of 1.
Use the ripng metricout command to configure an additional metric for a RIPng route advertised by an interface.
Use the undo rip metricout command to restore the default additional metric.
By default, the additional routing metric to a RIPng route advertised by an interface is 1.
Related command: ripng metricin.
Example
# Set the additional metric to 12 for routes advertised by Vlan-interface100.
[Sysname-Vlan-interface100] ripng metricout 12
undo ripng poison-reverse
View
Interface view
Parameter
None
Use the rip poison-reverse command to enable the poison reverse function.
Use the undo rip poison-reverse command to disable the poison reverse function.
By default, the poison reverse function is disabled.
Example
# Enable the poison reverse function for RIPng update messages on Vlan-interface100.
[Sysname-Vlan-interface100] ripng poison-reverse
ripng split-horizon
undo ripng split-horizon
View
Interface view
Parameter
None
Use the rip split-horizon command to enable the split horizon function.
Use the undo rip split-horizon command to disable the split horizon function.
By default, the split horizon function is enabled.
Note that:
l           The split horizon function is necessary for preventing routing loops. Therefore, you are not recommended to disable it.
l           In special cases, make sure that it is necessary to disable the split horizon function before doing so.
&  Note:
Only the poison reverse function takes effect if both the poison reverse and split horizon functions are enabled.
Example
#Enable the split horizon function on Van-interface100.
[Sysname-Vlan-interface100] ripng split-horizon
ripng summary-address ipv6-address prefix-length
undo ripng summary-address ipv6-address prefix-length
View
Interface view
Parameter
ipv6-address: IPv6 network address for the summarized routes.
prefix-length: IPv6 prefix length, in the range of 0 to 128. It indicates the number of consecutive bits of the significant part of the prefix, which defines the network.
Use the ripng summary-address command to assign a summary IPv6 address and the prefix.
Use the undo ripng summary-address command to remove the summary IPv6 address.
If the prefix and the prefix length of a route match the IPv6 prefix, the IPv6 prefix will be advertised instead. Thus, one route can be advertised on behalf of many routes with the same prefix. After summarization, the route cost is the lowest cost of those summarized routes.
Example
# Assign an IPv6 address with a 64-bit prefix on Vlan-interface100 and configure a summary IPv6 address.
[Sysname-Vlan-interface100] ipv6 address 2001:200::3EFF:FE11:6770/64
[Sysname-Vlan-interface100] ripng summary-address 2001:200:: 35
2.1.20  timers
timers { garbage-collect garbage-collect-value | suppress suppress-value | timeout timeout-value | update update-value }*
undo timers { garbage-collect | suppress | timeout | update }*
View
RIPng view
Parameter
garbage-collect-value: Length of the garbage-collect timer in seconds, in the range of 1 to 86400.
suppress-value: Length of the suppress timer in seconds, in the range of 0 to 86,400.
timeout-value: Length of the timeout timer in seconds, in the range of 1 to 86,400.
update-value: Length of the update timer in seconds, in the range of 1 to 86,400.
Use the timers command to configure RIPng timers.
Use the undo timers command to restore the default timer lengths.
By default, the length of the garbage-collect timer is 240 seconds, that of the suppress timer 120 seconds, that of the timeout timer 180 seconds, and that of the update timer 30 seconds.
RIPng is controlled by the above four timers.
l           The update timer defines the interval between sending update messages.
l           The timeout timer defines the route aging time. If no update message related to a route is received within the aging time, the metric of the route is set to 16 in the routing table.
l           The suppress timer defines how long a RIPng route stays in the suppressed state. When the metric of a route is 16, the route enters the suppressed state. In the suppressed state, only routes which come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
l           The garbage-collect timer defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIPng advertises the route with the routing metric set to 16. If no update message is announced for that route before the garbage-collect timer expires, the route will completely be deleted from the routing table.
Note that:
l           You are not recommended to change the default values of these timers under normal circumstances.
l           The lengths of these timers must be kept consistent on all routers and access servers in the network
Example
# Configure the update, timeout, suppress, and garbage-collect timers as 5s, 15s, 15s and 30s.
[Sysname] ripng 100
[Sysname-ripng-100] timers update 5
[Sysname-ripng-100] timers timeout 15
[Sysname-ripng-100] timers suppress 15
[Sysname-ripng-100] timers garbage-collect 30
&  Note:
3.1.1  abr-summary
abr-summary ipv6-address prefix-length [ not-advertise ]
undo abr-summary ipv6-address prefix-length
View
OSPFv3 area view
Parameter
ipv6-address: Destination IPv6 address prefix of the summary route.
prefix-length: The length of the prefix, in the range 0 to 128.
not-advertise: Specifies not to advertise the summary IPv6 route.
Use the abr-summary command to configure an IPv6 summary route.
Use the undo abr-summary command to remove an IPv6 summary route.
By default, no route summarization is available.
You can use this command only on an ABR to configure a summary route for the area. The ABR advertises only the summary route to other areas. Multiple contiguous networks may be available in an area, where you can summarize them into one route for advertisement.
After the undo abr-summary command is executed, the aggregated routes will be advertised again.
Example
# Summarize networks 2000:1:1:1::/64 and 2000:1:1:2::/64 in Area 1 into 2000:1:1::/48 for advertisement to other areas.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] abr-summary 2000:1:1:: 48
3.1.2  area
area area-id
View
OSPFv3 view
Parameter
area-id: The ID of an area, a decimal integer (in the range of 0 to 4294967295 and changed to IPv4 address format by the system) or an IPv4 address.
Use the area command to enter OSPFv3 area view.
&  Note:
The undo form of the command is not available. An area is removed automatically if there is no configuration and no interface is up in the area.
Example
# Enter OSPFv3 Area 0 view.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0]
3.1.3  default cost
default cost value
undo default cost
View
OSPFv3 view
Parameter
value: Specifies the default cost for redistributed routes, in the range of 1 to 16777214.
Use the default cost command to configure the default cost for redistributed routes.
Use the undo default cost command to restore the default.
By default, the default cost is 1.
You need to configure the default cost value for redistributed routes to advertise them throughout the whole AS.
If multiple OSPFv3 processes available, use of this command takes effect for the current process only.
Example
# Specify the default cost for redistributed routes as 10.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default cost 10
3.1.4  default-cost
default-cost value
undo default-cost
View
OSPFv3 area view
Parameter
value: Specifies the default route cost of send a packet to the stub area, in the range of 0 to 65535, which defaults to 1.
Use the default-cost command to specify the cost of the default route to the stub area.
Use the undo-default-cost command to restore the default value.
Use of this command is only available on the ABR that is connected to a stub area.
You have two commands to configure a stub area: stub, defaulted-cost. You need to use the stub command on routers attached to a stub area to configure the area as stub.
If multiple OSPFv3 processes running, use of this command takes effect only for the current process.
Related command: stub.
Example
# Configure Area1 as a stub area, and specify the cost of the default route to the stub area as 60.
[Sysname] ospfv3
[Sysname-ospfv3-1-area-0.0.0.1] stub
[Sysname-ospfv3-1-area-0.0.0.1] default-cost 60
View
Parameter
None
Use the display debugging ospfv3 command to display global OSPFv3 debugging state information.
Example
# Display the global OSPFv3 debugging state information.
<Sysname> display debugging ospfv3
display ospfv3 [ process-id ]
View
Parameter
process-id: Specifies the ID of an OSPFv3 process, ranging from 1 to 65535.
Use the display ospfv3 command to display OSPFv3 brief information. If no process ID is specified, OSPFv3 brief information about all processes will be displayed.
Example
# Display brief information about all OSPFv3 processes.
<Sysname> display ospfv3
Routing Process "OSPFv3 (1)" with ID 1.1.1.1
 SPF schedule delay 5 secs, Hold time between SPFs 10 secs
 Minimum LSA interval 5 secs, Minimum LSA arrival 1 secs
 Number of external LSA 0. These external LSAs’ checksum Sum 0x0000
 Number of AS-Scoped Unknown LSA 0
 Number of LSA originated 3
 Number of LSA received 0
 Number of areas in this router is 1
  Area 0.0.0.1
       Number of interfaces in this area is 1
       SPF algorithm executed 1 times
       Number of LSA 2. These LSAs’ checksum Sum 0x20C8
       Number of Unknown LSA 0
Table 3-1 Description on the fields of the display isofv3 command
OSPFv3 process is 1, and router ID is 1.1.1.1.
SPF schedule delay
Delay interval of SPF calculation
Hold time between SPF calculations
Minimum interval for generating LSAs
Minimum LSA arrival
Minimum LSA repeat arrival interval
Number of ASEs
Sum of all the ASEs’ checksum
Number of LSAs with unknown flooding scope
Number of LSAs originated
Number of LSAs received
Number of areas this router attached to
Area
Area ID
Number of interfaces attached to this area
SPF algorithm is executed 1 time
Number of LSA
Number of LSAs
Sum of all LSAs’ checksum
Number of unknown LSAs
display ospfv3 interface [ interface-type interface-number | statistic ]
View
Parameter
statistic: Displays the interface statistics.
Use the display ospfv3 interface command to display OSPFv3 interface information.
Example
# Display OSPFv3 interface information.
<Sysname > display ospfv3 interface Vlan-interface 200
Vlan-interface200 is up, line protocol is up
  Interface ID 11665607
  IPv6 Prefixes
    FE80::20F:E2FF:FE00:5 (Link-Local Address)
    2001:1::2
  OSPFv3 Process (1), Area 0.0.0.1, Instance ID 0
    Router ID: 1.1.1.1, Network Type: BROADCAST, Cost: 1
    Transmit Delay is 1 sec, State: DR, Priority: 1
    Designated Router (ID) 1.1.1.1
      Interface Address: FE80::20F:E2FF:FE00:5
    Backup Designated Router (ID): 2.2.2.2
      Interface Address: FE80::20F:E2FF:FE00:2205
    Timer interval configured, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
      Hello due in 00:00:08
    Neighbor Count is 1, Adjacent neighbor count is 1
Table 3-2 Description on the fields of the display ospfv3 interface command
Interface ID
Interface ID
IPv6 Prefixes
IPv6 Prefix
OSPFv3 Process
OSPFv3 Process
Area
Area ID
Instance ID
Instance ID
Router ID
Router ID
Network Type
Network type of the interface
Cost
Cost value of the interface
Transmit Delay
Transmission delay of the interface
Interface state
Priority
DR priority of the interface
The configured OSPFv3 timers are defined as follows:
Hello
Interval at which the interface sends Hello packets
Dead
Dead time for neighbor
Wait
The interface exits the Waiting state after this timer expires.
Retransmit
Interval at which the interface retransmits LSAs
Hello packet will be sent in 8 seconds
Neighbor Count
Number of Neighbors on the interface
Number of Adjacencies on the interface
display ospfv3 [ process-id ] lsdb [ [ external | inter-prefix | inter-router | intra-prefix | link | network | router ] [ link-state-id ] [ originate-router router-id ] | total ]
View
Parameter
process-id: Specifies ID of an OSPFv3 process, ranging from 1 to 65535.
external: Specifies to display information about AS-external LSAs.
inter-prefix: Specifies to display information about Inter-area-prefix LSAs.
inter-router: Specifies to display information about Inter-area-router LSAs.
intra-prefix: Specifies to display information about Intra-area-prefix LSAs.
link: Specifies to display information about Link-LSAs.
network: Specifies to display information about Network-LSAs.
router: Specifies to display information about Router-LSAs.
link-state-id: Link state ID, an IPv4 address.
originate-router router-id: The ID of the advertising router .
total: Specifies to display all information in the LSDB.
Use the display ospfv3 lsdb command to display OSPFv3 LSDB information.
Example
# Display OSPFv3 LSDB information.
<Sysname> display ospfv3 lsdb
            OSPFv3 Router with ID (5.5.5.5) (Process 1)
               Link-LSA (Interface Vlan-interface100)
Link State ID   Origin Router    Age   SeqNum     CkSum  Prefix
0.15.0.9        5.5.5.5          0304  0x80000001 0x5b6a      1
0.15.0.9        6.6.6.6          0311  0x80000001 0x6956      1
               Router-LSA (Area 0.0.0.0)
Link State ID   Origin Router    Age   SeqNum     CkSum    Link
0.0.0.0         5.5.5.5          0263  0x80000002 0x823f      1
0.0.0.0         6.6.6.6          0264  0x80000003 0x625a      1
               Network-LSA (Area 0.0.0.0)
0.15.0.9        6.6.6.6          0264  0x80000001 0x3498
               Intra-Area-Prefix-LSA (Area 0.0.0.0)
Link State ID  Origin Router   Age   SeqNum     CkSum  Prefix  Reference
0.0.0.2        6.6.6.6         0263  0x80000001 0x95c4      1  Network-LSA
Table 3-3 Description on the fields of the display isofv3 lsdb command
Link-LSA
Link-LSA
Link State ID
Link State ID
Origin Router
Originating Router
Age
Age of LSAs
SeqNum
LSA sequence number
CkSum
LSA Checksum
Prefix
Number of Prefixes
Router-LSA
Router-LSA
Link
Number of links
Network-LSA
Network-LSA
Reference
Type of referenced LSA
# Display Link-local LSA information in the LSDB.
<Sysname> dis ospfv3 lsdb link
            OSPFv3 Router with ID (4.4.4.4) (Process 1)
                Link-LSA (Interface Vlan-interface400)
  LS age            : 1536
  LS Type           : Link-LSA
  Link State ID     : 0.178.1.143
  Originating Router: 3.3.3.3
  LS Seq Number     : 0x80000003
  Checksum          : 0x22A7
  Length            : 56
  Priority          : 1
  Options           : 0x000011 (-|R|-|-|-|V6)
  Link-Local Address: FE80::2E0:FCFF:FE00:242A
  Number of Prefixes: 1
      Prefix        : 2001:2::/64
      Prefix Options: 0 (-|-|-|-)
  LS age            : 1558
  LS Type           : Link-LSA
  Originating Router: 4.4.4.4
  Checksum          : 0x4A6A
  Length            : 56
  Priority          : 1
  Link-Local Address: FE80::2E0:FCFF:FE00:550A
Table 3-4 Description on the fields of the display ospfv3 lsdb command
LS age
Age of LSA
LS Type
Type of LSA
Originating Router
Originating Router
LS Seq Number
LSA Sequence Number
Checksum
LSA Checksum
Length
LSA Length
Priority
Router Priority
Options
Options
Link-Local Address
Link-Local Address
Number of Prefixes
Number of Prefixes
Prefix
Address prefix
Prefix Options
Prefix options
View
Parameter
None
Use the display ospfv3 lsdb statistic command to display LSA statistics in the OSPFv3 LSDB.
Example
# Display OSPFv3 LSDB statistics.
<System> display ospfv3 lsdb statistic
            OSPFv3 Router with ID (1.1.1.1) (Process 1)
                           LSA Statistics
Area ID         Router   Network  InterPre InterRou IntraPre Link     ASE
0.0.0.0         2        1        1        0        1
0.0.0.1         1        0        1        0        1
Total           3        1        2        0        2        3        0
Table 3-5 Descriptions on the fields of the display ospfv3 lsdb statistic command
Area ID
Area ID
Router
Router-LSA number
Network
Network-LSA number
InterPre
Inter-Area-Prefix-LSA number
InterRou
Inter-Area-Router-LSA number
IntraPre
Intra-Area-Prefix-LSA number
Link
Link-LSA number
ASE
AS-external-LSA number
Total
Total LSA number
display ospfv3 [ process-id ] next-hop
View
Parameter
Use the display ospfv3 next-hop command to display OSPFv3 next hop information.
If no process is specified, next hop information of all OSPFv3 processes is displayed.
Example
# Display OSPFv3 next hop information.
<Sysname> display ospfv3 next-hop
            OSPFv3 Router with ID (2.2.2.2) (Process 1)
Neighbor-Id     Next-Hop                              Interface   RefCount
1.1.1.1         FE80::20F:E2FF:FE00:1                 vlan100      1
Table 3-6 Description on the fields of the display ospfv3 next-hop command
Neighbor-Id
Neighboring router ID
Next-hop
Next-hop address
Outbound interface
RefCount
Reference count
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id ]
View
Parameter
area: Specifies to display neighbor information of the specified area.
area-id: The ID of an area, a decimal integer that is translated into IPv4 address format by the system (in the range of 0 to 4294967295) or an IPv4 address.
statistic: Specifies to display the statistics of all neighbors.
interface-type interface-number: interface type and number.
verbose: Display detailed neighbor information.
peer-router-id: Router-ID of the specified neighbor.
Use the display ospfv3 peer command to display OSPFv3 neighbor information.
l           If no area-id is specified, the neighbor information of all areas is displayed.
l           If no process-id is specified, the information of all processes is displayed.
l           If no interface or neighbor Router-ID is specified, the neighbor information of all interfaces is displayed.
Example
# Display the neighbor information of OSPFv3 process 1 of an interface.
<Sysname> display ospfv3 1 peer Vlan-interface 400
                      OSPFv3 Process (1)
OSPFv3 Area (0.0.0.2)
Neighbor ID     Pri   State            Dead Time   Interface  Instance ID
3.3.3.3         1     Full/Backup      00:00:38    Vlan400        0
Table 3-7 Description on the fields of the display isofv3 peer command
Neighbor ID
Neighbor ID
Pri
Priority of neighbor router
Neighbor state
Dead Time
Dead time remained
Interface connected to the neighbor
Instance ID
Instance ID
# Display detailed neighbor information of OSPFv3 process 1 of an interface.
<H3C> display ospfv3 1 peer Vlan-interface 400 verbose
                      OSPFv3 Process (1)
 Neighbor: 3.3.3.3, interface address: FE80::2E0:FCFF:FE00:242A
    In the area 0.0.0.2 via interface Vlan-interface400
    DR is 4.4.4.4 BDR is 3.3.3.3
    Options is 0x000011 (-|R|-|-|-|V6)
    Dead timer due in 00:00:35
    Database Summary List 0
    Link State Request List 0
    Link State Retransmission List 0
Table 3-8 Description on the fields of the display isofv3 peer verbose command
Neighbor
Neighbor ID
interface address
Interface address
In the area 0.0.0.2 via interface vlan-interface 400
Interface vlan-interface 400 belongs to area 2
DR is 4.4.4.4, BDR is 3.3.3.3
The option is 0x000011 (-|R|-|-|-|V6)
Number of LSAs sent in DD packet
Number of LSAs in the link state request list
Number of LSAs in the link state retransmission list
View
Parameter
None
Use the display ospfv3 peer statistic command to display information about all OSPFv3 neighbors on the router, that is, numbers of neighbors in different states.
Example
# Display information about all OSPFv3 neighbors.
<Sysname> display ospfv3 peer statistic
                           Neighbor Statistics
Area ID         Down     Init     2-way    ExStar   Exchange Loading  Full
0.0.0.0         0        0        0        0        0        0        1
Total           0        0        0        0        0        0        1
Table 3-9 Description on the fields of the display ospfv3 peer statistic command
Area ID
Area ID
Down
In this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time.
Init
In this state, the router received a Hello packet from the neighbor but the packet gives no ID of the router. Mutual communication is not available.
2-Way
Indicates mutual communication between the router and its neighbor is available. DR/BDR election is finished under this state (or higher).
ExStar
In this state, the router decides on the initial DD sequence number and master/slave relationship of the two parties.
Exchange
In this state, the router exchanges DD packets with the neighbor.
Loading
In this state, the router sends LSRs to request the neighbor for needed LSAs.
Full
Indicates LSDB synchronization has been accomplished between neighbors.
Total
Total number of neighbors under the same state
display ospfv3 [ process-id ] request-list [ statistic ]
View
Parameter
process-id: OSPFv3 process ID, in the range 1 to 65535.
statistic: Statistics of link state request list.
Use the display ospfv3 request-list command to display OSPFv3 link state request list.
If no process is specified, link state request list information of all OSPFv3 processes is displayed.
Example
# Display the information of OSPFv3 link state request list.
<Sysname> display ospfv3 request-list
             Interface  Vlan100    Area-ID   0.0.0.1
                          Nbr-ID   2.2.2.2
LS-Type               LS-ID           AdvRouter       SeqNum       Age
AS-External-LSA       0.0.16.66       2.2.2.2         0x80000001   98
AS-External-LSA       0.0.16.67       2.2.2.2         0x80000001   98
AS-External-LSA       0.0.16.68       2.2.2.2         0x80000001   98
Table 3-10 Description on the fields of the display ospfv3 request-list command
Interface name
Area-ID
Area ID
Nbr-ID
Neighbor router ID
LS-Type
Type of LSA
LS-ID
Link state ID
AdvRouter
Advertising router
SeqNum
LSA sequence number
Age
Age of LSA
# Display the statistics of OSPFv3 link state request list.
<Sysname> display ospfv3 request-list statistics
Interface  Neighbor        LSA-Count
Vlan100    2.2.2.2         0
Table 3-11 Description on the fields of the display ospfv3 request-list statistics command
Interface name
Neighbor
Neighbor router ID
LSA-Count
Number of LSAs in the request list
display ospfv3 [ process-id ] retrans-list [ statistics ]
View
Parameter
statistics: Displays link state retransmission list statistics.
Use the display ospfv3 retrans-list command to display OSPFv3 link state retransmission list.
If no process is specified, link state retransmission list information of all OSPFv3 processes is displayed.
Example
# Display the information of OSPFv3 link state retransmission list.
<Sysname> display ospfv3 retrans-list
                          Nbr-ID   2.2.2.2
Router-LSA             0.0.0.0         2.2.2.2         0x80000006   0
Network-LSA            0.15.0.8        2.2.2.2         0x80000001   0
Intra-Area-Prefix-LSA  0.0.0.1         2.2.2.2         0x80000006   0
Table 3-12 Description on the fields of the display ospfv3 retrans-list command
Interface name
Area-ID
Area ID
Nbr-ID
Neighbor router ID
LS-Type
Type of LSA
LS-ID
Link state ID
AdvRouter
Advertising Router
SeqNum
LSA sequence Number
Age
Age of LSA
# Display the statistics of OSPFv3 link state retransmission list.
<Sysname>display ospfv3 retrans-list statistics
            OSPFv3 Router with ID (3.3.3.3) (Process 1)
Vlan100     1.1.1.1           0
Table 3-13 Description on the fields of the display ospfv3 retrans-list statistics command
Interface name
Neighbor
Neighbor ID
LSA-Count
Number of LSAs in the retransmission request list
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length | ipv6-address/prefix-length | abr-routes | asbr-routes | all | statistics ]
View
Parameter
ipv6-address: IPv6 address prefix.
prefix-length: Prefix length, in the range 0 to 128.
abr-routes: Specifies to display routes to ABR.
asbr-routes: Specifies to display routes to ASBR.
all: Specifies to display all routes.
statistics: Specifies to display the statistics of OSPFv3 routing table.
Use the display ospfv3 routing command to display OSPFv3 routing table information.
If no process is specified, routing table information of all OSPFv3 processes is displayed.
Example
# Display OSPFv3 routing table information.
<Sysname> display ospfv3 routing
 E1 - Type 1 external route,    IA - Inter area route,    I  - Intra area route
 E2 - Type 2 external route,    *  - Selected route
 *Destination: 2001::/64
  Type       : I                                        Cost     : 1
  NextHop    : directly-connected                       Interface: Vlan100
Table 3-14 Description on the fields of the display ospfv3 routing command
Destination
Destination network segment
Route type
Cost
Route cost value
Next-hop
Next hop address
Outbound interface
# Display the statistics of OSPFv3 routing table.
<Sysname> display ospfv3 routing statistics
                           OSPFv3 Routing Statistics
 Intra-area-routes   :   1
 Inter-area-routes   :   0
 External-routes     :   0
Table 3-15 Description on the fields of the display ospfv3 routing statistics command
Intra-area-routes
Number of Intra-area-routes
Inter-area-routes
Number of inter-area routes
External-routes
Number of external routes
View
Parameter
None
Use the display ospfv3 statistic command to display outbound/inbound OSPFv3 packet statistics on associated interface(s).
Example
# Display outbound/inbound OSPFv3 packet statistics on associated interfaces.
<Sysname> display ospfv3 statistic
                       OSPFv3 Statistics
Interface Vlan-interface100 Instance 0
 Type              Input       Output
 Hello             189         63
 DB Description    10          8
 Ls Req            2           1
 Ls Upd            16          6
 Ls Ack            10          6
Table 3-16 Description on the fields of the display ospfv3 statistics command
Interface name
Instance
Instance number
Type of packet
Input
Number of packets received by the interface
Output
Number of packets sent by the interface
Hello
Hello packet
DB Description
Database description packet
Ls Req
Link state request packet
Ls Upd
Link state update packet
Ls Ack
Link state acknowledgement packet
display ospfv3 [ process-id ] topology [ area area-id ]
View
Parameter
process-id: Specifies the ID of an OSPFv3 process of which to display topology information, ranging from 1 to 65535.
area: Display the topology information of the specified area.
area-id: The ID of an area, a decimal integer (in the range of 0 to 4294967295) that is translated into IPv4 address format by the system or an IPv4 address.
Use the display ospfv3 topology command to display OSPFv3 topology information. If no process is specified, topology information of all OSPFv3 processes is displayed.
Example
# Display OSPFv3 area 1 topology information.
<Sysname> display ospfv3 topology area 1
                      OSPFv3 Process (1)
OSPFv3 Area (0.0.0.1) topology
Type  ID(If-Index)       Bits      Metric    Next-Hop        Interface
Rtr   1.1.1.1                      --
Rtr   2.2.2.2                      1         2.2.2.2         Vlan100
Table 3-17 Description on the fields of the display ospfv3 topology command
Type of node
ID(If-Index)
Router ID
Bits
Flag bit
Metric
Cost value
Next-Hop
Next hop
Outbound interface
display ospfv3 [ process-id ] vlink
View
Parameter
Use the display ospfv3 vlink command to display OSPFv3 virtual link information. If no process is specified, virtual link information of all OSPFv3 processes is displayed.
Example
# Display OSPFv3 virtual link information.
<Sysname> display ospfv3 vlink
     Virtual Link VLINK1 to router 1.1.1.1 is up
       Transit area :0.0.0.1 via interface Vlan-interface100, instance ID: 0
       Local address: 2000:1::1
       Remote address: 2001:1:1::1
       Transmit Delay is 1 sec, State: P-To-P,
       Timer intervals configured, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
         Hello due in 00:00:02
         Adjacency state :Full
Table 3-18 Description on the fields of the display ospfv3 vlink command
The virtual link VLINK1 to router 1.1.1.1 is up
Transit area 0.0.0.1 via interface Vlan-interface100
Interface Vlan-interface100 in transit area 0.0.0.1.
instance ID
Instance ID
Local address
Local IPv6 address
Remote address
Remote IPv6 address
Transmit Delay
Transmit delay of sending LSAs
Interface state
Timer intervals in seconds, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
Send hello packets in 2 seconds.
Adjacency state
Adjacency state
filter-policy { acl-number | ipv6-prefix ipv6-prefix-name } export [ isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static]
undo filter-policy export [ isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static ]
View
OSPFv3 view
Parameter
acl-number: Specifies the ACL number, ranging from 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list, a string of up to 19 characters.
isisv6 process-id: Specifies to filter the IPv6-IS-IS routes with a specified process-id, which is in the range of 1 to 65535.
ospfv3 process-id: Specifies to filter the ospfv3 routes with a specified process-id, which is in the range of 1 to 65535.
ripng process-id: Specifies to filter the ripng routes with a specified process-id, which in the range of 1 to 65535.
bgp4+: Specifies to filter bgp4+ routes.
direct: Specifies to filter direct routes.
static: Specifies to filter static routes.
Use the filter-policy export command to filter redistributed routes.
Use the undo filter-policy export command to remove the configuration.
By default, IPv6 OSPFv3 does not filter redistributed routes.
If no protocol is specified, all redistributed routes will be filtered.
&  Note:
Using the filter-policy export command filters only routes redistributed by the import-route command. If the import-route command is not configured to redistribute routes from other protocols and other OSPFv3 processes, use of the filter-policy export command does not take effect.
Example
# Filter all redistributed routes using IPv6 ACL 2001.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2002:1:: 64
[Sysname-acl6-basic-2001] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 2001 export
View
OSPFv3 view
Parameter
acl6-number: Specifies an ACL number, ranging from 2000 to 3999.
Use the filter-policy import command to filter received routes.
Use the undo filter-policy import command to remove the configuration.
No received routes are filtered by default.
&  Note:
Using the filter-policy import command only filters routes computed by OSPFv3. The routes that fail to pass are not added to the routing table.
Example
# Filter received routes using the IPv6 prefix list abc.
[Sysname] ip ipv6-prefix abc permit 2002:1:: 64
[Sysname] ospfv3 1
[Sysname-ospfv3-1] filter-policy ipv6-prefix abc import
3.1.21  import-route
import-route { isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ [ allow-ibgp ] | direct | static } [ cost value | type type | route-policy route-policy-name ]*
undo import-route  { isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static }
View
OSPFv3 view
Parameter
isisv6 process-id: Specifies a process ID of ISISv6 to redistribute ISISv6 routes with the process ID, in the range 1 to 65535.
ospfv3 process-id: Specifies a process ID of OSPFv3 to redistribute OSPFv3 routes with the process ID, in the range 1 to 65535.
ripng process-id: Specifies a process ID of ripng to redistribute ripng routes with the process ID, in the range 1 to 65535.
bgp4+: Specifies to redistribute bgp4+ routes.
allow-ibgp: Allows redistributing IBGP route.
direct: Specifies to redistribute direct routes.
static: Specifies to redistributes static routes.
cost value: Specifies the cost for redistributed routes, ranging from 1 to 16777214. It defaults to 1.
type type: Specifies the type for redistributed routes, 1 or 2. It defaults to 2.
route-policy route-policy-name: Specifies to redistribute only the routes that match the specified route-policy. route-policy-name is a string of up to 19 characters.
  Caution:
Use the import-route bgp4+ command to redistribute EBGP routes only, while use the import-route bgp4+ allow-ibgp command to redistribute both EBGP and IBGP routes. The redistributed IBGP routes may cause routing loops. Therefore, use this command with caution.
Use the import-route command to redistribute routes.
Use the undo import-route command to disable routes redistribution.
IPv6 OSPFv3 does not redistribute routes from other protocols by default.
Example
# Configure to redistribute routes from RIPng and specify the type as type 2 and cost as 50.
[Sysname] ospfv3
[Sysname-ospfv3-1] import-route ripng 10 type 2 cost 50
# Configure OSPFv3 process 100 to redistribute the routes found by OSPFv3 process 160.
[Sysname] ospfv3 100
[Sysname-ospfv3-100] import-route ospfv3 160
maximum load-balancing maximum
View
OSPFv3 view
Parameter
maximum: The maximum number of load-balanced routes. in the range of 1 to 4, which defaults to 4.
Use the maximum load-balancing command to configure the maximum number of load-balanced routes.
Use the undo maximum load-balancing command to  restore the default.
Example
# Configure the maximum load-balancing routes as 2.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] maximum load-balancing 2
3.1.23  ospfv3
undo ospfv3 [ process-id ]
View
Parameter
process-id: Specifies the ID of an OSPFv3 process, ranging from 1 to 65535. The process ID defaults to 1.
Use the ospfv3 command to enable an OSPFv3 process and enter OSPFv3 view.
Use the undo ospfv3 command to disable an OSPFv3 process.
The system runs no OSPFv3 process by default.
Related command: router-id.
&  Note:
An OSPFv3 process can run normally only when Router ID is configured in OSPFv3 view. Otherwise, you can find the process, but which cannot generate any LSA.
Example
# Enable the OSPFv3 process with process ID as 120 and configure the Router ID as 1.1.1.1.
[Sysname] ospfv3 120
[Sysname-ospfv3-120] router-id 1.1.1.1
3.1.24  ospfv3 area
ospfv3 process-id area area-id [ instance instance-id ]
undo ospfv3 process-id area area-id [ instance instance-id ]
View
Interface view
Parameter
instance-id: The instance ID of an interface, in the range of 0 to 255, which defaults to 0.
Use the ospfv3 area command to enable an OSPFv3 process on the interface and specify the area for the process.
Use the undo ospfv3 area command to disable an OSPFv3 process.
OSPFv3 is not enabled on an interface by default.
Example
# Enable OSPFv3 process 1 on an interface that belongs to instance 1 and specify area 1 for the process.
[Sysname-Vlan-interface10] ospfv3 1 area 1 instance 1
3.1.25  ospfv3 cost
ospfv3 cost value [ instance instance-id ]
undo ospfv3 cost [ instance instance-id ]
View
Interface view
Parameter
value: OSPFv3 cost of the interface, in the range 1 to 65535.
Use the ospfv3 cost command to configure the OSPFv3 cost on an interface of an instance.
Use the undo ospfv3 cost command to restore the default OSPFv3 cost on an interface of an instance.
By default, the cost value defaults to 1.
Example
# Specifies the OSPFv3 cost as 33 on an interface of instance 1.
[Sysname-Vlan-interface10] ospfv3 cost 33 instance 1
ospfv3 dr-priority priority [ instance instance-id ]
undo ospfv3 dr-priority [ instance instance-id ]
View
Interface view
Parameter
priority: DR priority, in the range 0 to 255.
instance-id: ID of the instance an interface belongs to, in the range 0 to 255, which defaults to 0.
Use the ospfv3 dr-priority command to set the DR priority for an interface of an instance.
Use the undo ospfv3 dr-priority command to restore the default value.
The DR priority on an interface defaults to 1
An interface’s DR priority determines its privilege for DR/BDR selection, and the interface with the highest priority is considered first.
Example
# Set the DR priority for an interface of instance 1 to 8 .
[Sysname-Vlan-interface10] ospfv3 dr-priority 8 instance 1
ospfv3 mtu-ignore [ instance instance-id ]
undo ospfv3 mtu-ignore [ instance instance-id ]
View
Interface view
Parameter
instance-id: Instance ID, in the range 0 to 255, which defaults to 0.
Use the ospfv3 mtu-ignore command to configure an interface to ignore MTU when sending DD packets.
Use the undo ospfv3 mtu-ignore command to restore the default configuration.
MTU is not ignored by default.
Example
# Configure an interface that belongs to instance 1 to ignore MTU.
[Sysname-Vlan-interface10] ospfv3 mtu-ignore instance 1
ospfv3 timer dead seconds [ instance instance-id ]
undo ospfv3 timer dead [ instance instance-id ]
View
Interface view
Parameter
seconds: Dead time in seconds, ranging from 1 to 2,147,483,647,
Use the ospfv3 timer dead command to configure the OSPFv3 neighbor dead time for an interface that belongs to a specified instance.
Use the undo ospfv3 timer dead command to restore the default.
By default, the OSPFv3 neighbor dead time is 40 seconds.
OSPFv3 neighbor dead time: if an interface receives no hello packet from a neighbor after dead time elapses, the interface will considers the neighbor is dead.
The dead seconds value is at least four times the Hello seconds value and must be identical on interfaces attached to the same network segment.
Related command: ospfv3 timer hello.
Example
# Configure the OSPFv3 neighbor dead time as 80 seconds for an interface with instance 1.
[Sysname-Vlan-interface10] ospfv3 timer dead 80 instance 1
ospfv3 timer hello seconds [ instance instance-id ]
undo ospfv3 timer hello [ instance instance-id ]
View
Interface view
Parameter
seconds: Interval between hello packets, ranging from 1 to 65,535.
Use the ospfv3 timer hello command to configure the hello interval for an interface that belongs to an instance.
Use the undo ospfv3 timer hello command to restore the default.
By default, the hello interval is 10 seconds.
Related command: ospfv3 timer dead.
Example
# Configure the hello interval as 20 seconds for an interface of instance 1.
[Sysname-Vlan-interface10] ospfv3 timer hello 20 instance 1
ospfv3 timer retransmit interval [ instance instance-id ]
undo ospfv3 timer retransmit [ instance instance-id ]
View
Interface view
Parameter
interval: Specifies LSA retransmission interval in seconds for an interface, ranging from 1 to 65535.
Use the ospfv3 timer retransmit command to configure the LSA retransmission interval for an interface of an instance.
Use the undo ospfv3 timer retransmit command to restore the default.
The interval defaults to 5 seconds.
When a router sends a LSA to its neighbor, it waits for an acknowledgement. If receiving no acknowledgement after retransmission interval elapses, it will retransmit the LSA.
The LSA retransmission interval should not be too small for avoidance of unnecessary retransmissions.
Example
# Configure the LSA retransmission interval on an interface of instance 1 as 12 seconds.
[Sysname-Vlan-interface10] ospfv3 timer retransmit 12 instance 1
ospfv3 trans-delay seconds [ instance instance-id ]
undo ospfv3 trans-delay [ instance instance-id ]
View
Interface view
Parameter
seconds: Transmission delay time in seconds, ranging from 1 to 65,535.
instance-id: The instance ID of an interface, in the range of 0 to 255, with the default as 0.
Use the ospfv3 trans-delay command to configure the transmission delay for an interface with an instance ID.
Use the undo ospfv3 trans-delay command to restore the default.
The transmission delay defaults to 1s.
As LSAs are aged in the LSDB (incremented 1 by each second) but not aged on transmission, it is necessary to add a delay time to the age time before sending a LSA. This configuration is important for low-speed networks.
Example
# Configure the transmission delay as 3 seconds for an interface of instance 1.
[Sysname-Vlan-interface10] ospfv3 trans-delay 3 instance 1
3.1.32  router-id
router-id router-id
undo router-id
View
OSPFv3 view
Parameter
router-id: A 32-bit router ID, in IPv4 address format.
Use the router-id command to configure the OSPFv3 router ID .
Use the undo router-id command to remove a configured router ID.
Router ID is the unique identification of an OSPF process in an autonomous system. An OSPFv3 process cannot run without a Router ID.
Make sure that different processes have different Router IDs.
Related command: ospfv3.
&  Note:
By configuring different router IDs for different processes, you can run multiple OSPFv3 processes on a router.
Example
# Configure the Router ID as 10.1.1.3 for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] router-id 10.1.1.3
3.1.33  silent-interface
View
OSPFv3 view
Parameter
interface-type interface-number: Interface type and number
all: Specifies all interfaces.
Use the silent-interface command to disable the specified interface from sending OSPFv3 packets.
Use the undo silent-interface command to restore the default.
An interface is able to send OSPFv3 packets by default.
Multiple processes can disable the same interface from sending OSPFv3 packets, but use of the silent-interface command takes effect only on interfaces enabled with the current process.
Example
# Disable an interface under OSPFv3 processes 100 and 200 from sending OSPFv3 packets.
[Sysname-ospfv3-100] router-id 10.110.1.9
[Sysname-ospfv3-100] silent-interface vlan-interface 10
[Sysname-ospfv3-100] quit
[Sysname] ospfv3 200
[Sysname-ospfv3-200] router-id 20.18.0.7
[Sysname-ospfv3-200] silent-interface vlan-interface 10
3.1.34  spf timers
spf timers delay-interval hold-interval
undo spf timers
View
OSPFv3 view
Parameter
delay-interval: The interval in seconds between when OSPFv3 receives a topology change and when it starts SPF calculation, in the range 1 to 65,535.
hold-interval: The hold interval in seconds between two SPF calculations, in the range 1 to 65,535.
Use the spf timers command to configure the delay interval and hold interval for OSPFv3 SPF calculation.
Use the undo spf timers command to restore the default.
The delay interval and hold interval default to 5s and 10s.
An OSPFv3 router works out a shortest path tree with itself as root based on the LSDB, and decides on the next hop to a destination network according the tree. Adjusting the SPF calculation interval can restrain bandwidth and router resource from over consumption due to frequent network changes.
Example
# Configure the delay interval and hold interval as 6 seconds for SPF calculation.
[Sysname]ospfv3 1
[Sysname-ospfv3-1] spf timers 6 6
3.1.35  stub
stub [ no-summary ]
undo stub
View
OSPFv3 area view
Parameter
no-summary: This argument is only applicable to the ABR of a stub area. With it configured, the ABR advertises only a default route in a Summary-LSA to the stub area (such an area is called a totally stub area).
Use the stub command to configure an area as a stub area.
Use the undo stub command to remove the configuration.
By default, an area is not configured as a stub area.
When an area is configured as a stub area, all the routers attached to the area must be configured with the stub command.
Related command: default-cost.
Example
# Configure OSPFv3 area 1 as a stub area.
[Sysname] ospfv3 1
3.1.36  vlink-peer
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | instance instance-id ] *
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead ]*
View
OSPFv3 area view
Parameter
router-id: Router ID for a virtual link neighbor.
hello seconds: Specifies the interval in seconds of sending Hello packets, ranging from 1 to 8,192, with the default as 10. This value must equal to the hello seconds configured on the virtual link peer router.
retransmit seconds: Specifies the interval in seconds of retransmitting LSA packets, ranging from 1 to 3,600, with the default as 5.
trans-delay seconds: Specifies the delay interval in seconds of sending LSA packets, ranging from 1 to 3,600, with the default as 1.
dead seconds: Specifies the neighbor dead time in seconds, ranging from 1 to 32,768, with the default as 40. This value must equal to the dead seconds configured on the virtual link peer router, and at least four times the value of hello seconds.
instance Instance-id: The instance ID of an virtual link, in the range of 0 to 255, with the default as 0.
Use the vlink-peer command to create and configure a virtual link.
Use the undo vlink-peer command to remove a virtual link.
For a non-backbone area without direct connection with the backbone area or for a backbone area that cannot maintain connectivity, you can use the vlink-peer command to create logical connectivity. A virtual link can be considered as an interface with OSPFv3 enabled, because parameters such as hello, dead, retransmit and trans-delay are configured in the similar way.
Both ends of a virtual link are ABRs that are configured with the vlink-peer command.
Example
# Create a virtual link to 10.110.0.3.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 10.0.0.0
[Sysname-ospfv3-1-area-10.0.0.0] vlink-peer 10.110.0.3
Chapter 4  IPv6-IS-IS Configuration Commands
4.1  IPv6-IS-IS Configuration Commands
&  Note:
l      This chapter covers only the configuration commands specific to IPv6-IS-IS. For other related commands, see the IS-IS configuration part in the IPv4 Routing module.
l      Verify that the system already operates in IPv4/IPv6 dual-stack mode before configuring IPv6 routing.
l      All the IPv6 routing related configuration mentioned in this manual assumes that the system already operates in IPv4/IPv6 dual-stack mode. For dual stack mode configuration, see the part covering dual stack in the IPv6 Configuration module.
4.1.1  display isis route ipv6
display isis route ipv6 [ [ level-1 | level-2 ] | verbose ]* [ process-id ]
View
Parameter
verbose: Specifies to display detailed routing information.
process-id: Species an IPv6-IS-IS process ID.
level-1: Specifies to display Level-1 IPv6-IS-IS route.
level-2: Specifies to display Level-2 IPv6-IS-IS route.
&  Note:
If no level is specified, both Level-1 and Level-2 (namely Level-1-2) routing information will be displayed by default.
Use the display isis route ipv6 command to display IPv6-IS-IS routing information.
Example
# Display IPv6-IS-IS routing information.
<Sysname> display isis route ipv6
                         Route information for ISIS(1)
                     ISIS(1) IPv6 Level-1 Forwarding Table
 Destination: 2001::                              PrefixLen: 64
 Flag       : R/L/-                               Cost     : 10
 Next Hop   : Direct                              Interface: Vlan100
 Destination: 2002::                              PrefixLen: 64
 Flag       : R/L/-                               Cost     : 20
 Next Hop   : FE80::20F:E2FF:FE1D:A65B            Interface: Vlan100
      Flags: R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
Table 4-1 Description on the fields of the display isis route ipv6 command
Destination
PrefixLen
Length of a prefix
Flag/Flags
Flag of routing information status
R: The route has been recorded in the routing table.
L: The route has been advertised through LSP.
U: The flag of routing penetration status, indicating the Level-1 route is from the Level-2 one. You can avoid returning the Level-2 LSP that is sent to Level-1 back to Level-2.
Cost
Value of cost
Next Hop
Next hop
Exit interface
# Display detailed IPv6-IS-IS routing information.
<Sysname> display isis route ipv6 verbose
 IPV6 Dest  : 2001:1::/64                    Cost : 10       Flag : R/L/-
 Preference : 15                        Admin Tag : -
 Interface  : Vlan100                    Next Hop : Direct
 IPV6 Dest  : 2001:2::/64                 Cost : 20      Flag : R/-/-
 Interface  : Vlan100                    Next Hop : FE80::2E0:FCFF:FE00:242A
 IPV6 Dest  : 2001:3::/64                    Cost : 20            Flag : R/-/-
 IPV6 Dest  : ::/0                           Cost : 10            Flag : R/-/-
Table 4-2 Description on the fields of the display isis route ipv6 verbose command
IPV6 Dest
Cost
Value of cost
Flag/Flags
Preference
Preference of protocols
Admin Tag
Administration tag
Exit interface
Next Hop
Next hop
4.1.2  ipv6 default-route-advertise
ipv6 default-route-advertise [ [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name ]*
undo ipv6 default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
Parameter
route-policy-name: Specifies the route policy name with a string of 1 to 19 characters.
level-1: Specifies the default route as Level-1.
level-2: Specifies the default route as Level-2.
level-1-2: Specifies the default route as Level-1-2.
&  Note:
If no level is specified, the Level-2 routes are taken as the default routes.
Use the ipv6 default-route-advertise command to specify a router to generate Level-1 or Level-2 default routes.
Use the undo ipv6 default-route-advertise command to disable this function.
This function is disabled by default.
With a routing policy, you can specify IPv6-IS-IS to generate default routes only when there is matching routing entries in the routing table. You can use the apply isis level-1 command in routing policy view to generate default route in L1 LSP, use the apply isis level-2 command in routing policy view to generate default route in L2 LSP, and use the apply isis level-1-2 in routing policy view to generate default route in L1 LSP and L2 LSP respectively.
Example
# Configure the router to generate a default route in Level-2 LSPs..
[Sysname] isis
[Sysname-isis-1] ipv6 default-route-advertise
4.1.3  ipv6 enable
ipv6 enable
undo ipv6 enable
View
IS-IS view
Parameter
None
Use the ipv6 enable command to enable IPv6 in an IS-IS process.
Use the undo ipv6 enable command to disable this configuration.
IPv6 is disabled in the IS-IS process by default.
To run IPv6-IS-IS protocol normally, you need enable IPv6 globally, and use the isis command to enable the IS-IS process, use the network–entity to configure a network entity title (NET) for the router, use the ipv6 enable command to enable IPv6, and then use the isis ipv6 enable command to enable each interface that needs to run IPv6-IS-IS process (ipv6 address is required).
Only after finishing these configurations, can you enable an IPv6-IS-IS protocol.
Example
# Establish IS-IS routing process 1, and enable IPv6 for the process.
[Sysname] ipv6
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] ipv6 enable
4.1.4  ipv6 filter-policy export
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol process-id ]
undo ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol process-id ]
View
IS-IS view
Parameter
acl-number: Number of a basic or advanced IPv6 ACL used to filter redistributed routes before advertisement, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter the redistributed routes before advertisement, a string of 1 to 19 characters.
route-policy-name: Name of a routing policy used to filter the redistributed routes before advertisement, a string of 1 to 19 characters.
protocol: Specifies the imported routing information to be filtered at the time of advertising, including the information of processes such as bgp4+, direct, isisv6, ospfv3, ripng and static at present. If no parameter is specified, the system will filter all the routing information advertised.
process-id: Specifies a process id for a routing protocol, ranging from 1 to 65535. This parameter is available when the protocol is isisv6, ospfv3 or ripng.
Use the ipv6 filter-policy export command to configure IPv6-IS-IS to filter redistributed routes before advertisement..
Use the undo ipv6 filter-policy export command to disable the filtering.
The filtering is disabled by default.
In some circumstances, only the routing information satisfying certain conditions will be advertised. You can configure the filtering condition by configuring the ipv6 filter-policy parameters.
You can use the ipv6 filter-policy export command, which filter the imported routes only when they are advertised to other routers, together with the ipv6 import-route command.
l           If no protocol parameter is specified, routes imported from all protocols are filtered.
l           If the protocol parameter is specified, only the routes imported from the specific protocols are filtered.
Related command: ipv6 filter-policy import.
Example
# Reference the ACL6 2006 to filter all the redistributed routes before advertisement.
[Sysname] isis
[Sysname-isis-1] ipv6 filter-policy 2006 export
4.1.5  ipv6 filter-policy import
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
undo ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
View
IS-IS view
Parameter
acl-number: Number of a basic or advanced IPv6 ACL used to filter incoming routes, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter incoming routes, a string of 1 to 19 characters.
route-policy-name: Name of a routing policy used to filter incoming routes, a string of 1 to 19 characters.
Use the ipv6 filter-policy import command to enable IPv6-IS-IS filter the received routes.
Use the undo ipv6 filter-policy import command to disable filter the received routes.
IPv6-IS-IS does not filter the received routing information by default.
In some circumstances, only the routing information satisfying certain conditions will be received. You can configure the filtering condition by setting the ipv6 filter-policy parameters.
Related command: ipv6 filter-policy export.
Example
# Reference the IPv6 ACL 2003 to filter the received routes.
[Sysname] isis
[Sysname-isis-1] ipv6 filter-policy 2003 import
4.1.6  ipv6 import-route
ipv6 import-route protocol [ process-id | allow-ibgp ] [ cost cost-value | [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name | tag tag-value ]*
undo ipv6 import-route protocol [ process-id ]
View
IS-IS view
Parameter
protocol: Specifies the routing protocol to be imported, including direct, static, ripng, isisv6, bgp4+ and ospfv3.
process-id: Process ID of the routing protocol of ripng, isisv6 or ospfv3, in the range of 1 to 65535. The default is 1.
cost value: Specifies the routing cost of the imported routes, ranging from 0 to 4261412864.
level-1: Specifies to import routes to Level-1 routing table.
level-2: Specifies to import routes to Level-2 routing table. If no level is specified, the routes are imported to Level-2 routing table by default.
level-1-2: Specifies to import routes to Level-1-2 routing table.
route-policy-name: Name of a routing policy used to filter routes when they are being redistributed, a string of 1 to 19 characters.
tag-value: Specifies a administration tag number for the imported routes, in the range of 1 to 4294967295.
allow-ibgp: Allows to redistribute IBGP routes. This keyword is optional when the protocol is bgp4+.
Use the ipv6 import-route command to enable IPv6-IS-IS import routing information from other protocols.
Use the undo ipv6 import-route command to disable IPv6-IS-IS import routing information from other protocols.
IPv6-IS-IS does not import routing information from other protocols by default.
For IPv6-IS-IS, the routes found by other routing protocol are dealt as routes outside of the routing domain. When importing IPv6 routes from other protocol, you can also specify the default cost for the imported routes.
When IPv6-IS-IS imports routes, you can specify the routes to be imported to Level-1, Level-2 or Level-1-2.
  Caution:
Using the import-route bgp4+ allow-ibgp command will redistribute both EBGP and IBGP routes. The redistributed IBGP routes may cause routing loops. Therefore, use this command with caution.
Example
# IPv6–IS-IS imports static routes and sets the cost value as 15.
[Sysname] isis
[Sysname-isis-1]ipv6 import-route static cost 15
4.1.7  ipv6 import-route isisv6 level-2 into level-1
ipv6 import-route isisv6 level-2 into level-1 [ filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } | tag tag-value ]*
undo ipv6 import-route isisv6 level-2 into level-1
View
IS-IS view
Parameter
acl6-number: Number of a basic or advanced ACL6 used to filter routes when they are leaking from Level-2 to Level-1, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter routes when they are leaking from Level-2 to Level-1, a string of 1 to 19 characters.
route-policy-name: Name of a routing policy used to filter routes when they are leaking from Level-2 to Level-1, a string of 1 to 19 characters.
Use the ipv6 import-route isisv6 level-2 into level-1 to enable IPv6-IS-IS route leaking from Level-2 to Level-1.
Use the undo ipv6 import-route isisv6 level-2 into level-1 command to disable the leaking.
The leaking is disabled by default.
The route leaking feature enables a Level-1-2 router to advertise routes destined to the Level-2 area and other Level-1 areas to the Level-1 and Level-1-2 routers in the local area.
Example
# Set the router to penetrate routes from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1] ipv6 import-route isisv6 level-2 into level-1
4.1.8  ipv6 maximum load-balancing
ipv6 maximum load-balancing number
undo ipv6 maximum load-balancing
View
IS-IS view
Parameter
number: Specifies the number of equivalent routes under load-balancing mode, ranging from 1 to 4, with the default as 4.
Use the ipv6 maximum load-balancing command to configure the maximum number of equivalent routes under load-balancing mode. Use the undo ipv6 maximum load-balancing command to resume the default number of load-balancing routing.
&  Note:
Configure the maximum number of equivalent routes according to memory capacity.
Example
# Configure the maximum number of load-balancing routing as 2.
[Sysname] isis 100
[Sysname-isis-100] ipv6 maximum load-balancing 2
4.1.9  ipv6 preference
ipv6 preference { route-policy route-policy-name | preference-value }*
undo ipv6 preference
View
IS-IS view
Parameter
preference-value: Preference for IPv6-IS-IS, ranging from 1 to 255..
route-policy-name: Name of a routing policy, a string of 1 to 19 characters..
Use the ipv6 preference command to configure the preference for IPv6-IS-IS protocol.
Use the undo ipv6 preference command to configure the default preference for IPv6-IS-IS protocol.
The default preference is 15.
When a router runs multiple dynamic routing protocols at the same time, the system will configure a preference for each routing protocol. If several protocols find routes to the same destination, the one with the highest preference dominates.
Example
# Configure the preference of IPv6-IS-IS protocol as 20.
[Sysname] isis
[Sysname-isis-1] ipv6 preference 20
4.1.10  ipv6 summary
ipv6 summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag-value ] *
undo ipv6 summary ipv6-prefix prefix-length [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Parameter
ipv6-prefix: IPv6 prefix of the summary route.
prefix-length: Length of the IPv6 prefix, in the range of 0 to 128.
avoid-feedback: Specifies to avoid learning summary routes via routing calculation.
generate_null0_route: Generates the NULL 0 route to avoid routing loops.
level-1: Specifies to summarize only the routes redistributed to Level-1 area.
level-1-2: Specifies to summarize all the routes redistributed to Level-1 and Level-2 areas.
level-2: Specifies to summarize only the routes redistributed to Level-2 area.
tag-value: Value of a administrative tag, in the range of 1 to 4294967295.
&  Note:
If no level is specified in the command, the default is level-2.
Use the ipv6 summary command to configure an IPv6-IS-IS summary route.
Use the undo ipv6 summary command to remove the summary route.
Route summarization is disabled by default.
Configuring summary routes can reduce the size of the route table, LSPs and LSDB. Routes to be summarized can be IS-IS routes or redistributed routes. The cost of a summary route is the smallest cost among all summarized routes.
Example
# Configure a summary route of 2002::/32.
[Sysname] isis
[Sysname-isis-1] ipv6 summary 2002:: 32
4.1.11  isis ipv6 enable
isis ipv6 enable [ process-id ] [ silent ]
undo isis ipv6 enable
View
Interface view
Parameter
silent: Specifies to restrain the interface to send or receive IS-IS hello packets.
process-id: Specifies a IS-IS process id, ranging from 1 to 65535. If no value is specified, the default process 1 is enabled.
Use the isis ipv6 enable command to enable IPv6 for IS-IS routing process on a interface and specify the related IS-IS process ID. After the command is performed successfully, the interface will be related with the IS-IS process. Use the undo isis ipv6 enable command to disable this configuration.
IPv6 is disabled in the IS-IS process of the interface by default.
To run IPv6-IS-IS protocol, you need to enable IPv6 globally, and use the isis command to enable the IS-IS process, use the network–entity command to configure a Network Entity Title (NET) for the router, use the ipv6 enable command to enable IPv6 for the process, and then use the isis ipv6 enable command to enable IPv6 on each interface that needs to run the IS-IS process. (IPv6 addresses should be configured for interfaces.)
Example
# Create IS-IS routing process 1 to enable IPv6 on the VLAN 100 interface.
[Sysname] ipv6
[Sysname] isis 1
[Sysname-isis-1] quit
[Sysname] interface Vlan-interface 100
[Sysname--Vlan-interface100] ipv6 address 2002::1/64
[Sysname--Vlan-interface100] isis ipv6 enable 1
Chapter 5  IPv6-BGP4+ Configuration Commands
&  Note:
5.1  BGP4+ Configuration Commands
5.1.1  balance
balance number
undo balance
View
IPv6 address family view
Parameter
number: Number of BGP4+ routes participating in load balancing. in the range 1 to 4 . When it is set to 1, load balancing is disabled.
Use the balance command to configure the number of routes participating in BGP4+ load balancing.
Use the undo balance command to restore the default.
The feature is not available by default.
Unlike IGP, BGP4+ has no explicit metric for making load balancing decision. Instead, it implements load balancing by defining its routing rule.
Related command: display ipv6 routing-table.
Example
# Set the number of routes participating in BGP4+ load balancing to 2.
[Sysname] bgp 100
[Sysname-bgp] ipv6-family
[Sysname-bgp-af-ipv6] balance 2
5.1.2  bestroute as-path-neglect
undo bestroute as-path-neglect
View
Parameter
None
Use the bestroute as-path-neglect command to ignore AS_PATH in route selection.
Use the undo bestroute as-path-neglect command to use AS_PATH in route selection.
By default, the router takes AS_PATH as a factor when selecting a route.
Example
# Ignore AS_PATH in route selection.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] bestroute as-path-neglect
5.1.3  bestroute compare-med
undo bestroute compare-med
View
Parameter
None
Use the bestroute compare-med command to prioritize MED values of paths from each AS for best path selection.
Use the undo bestroute compare-med command to disable this function.
This function is not available by default.
Example
# Prioritize MED values of routes from each AS for selecting the best route.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] bestroute compare-med
5.1.4  bestroute med-confederation
undo bestroute med-confederation
View
Parameter
None
Use the bestroute med-confederation command to prioritize MED values of routes from confederation peers.
Use the undo bestroute med-confederation command to disable the function.
By default, this function is not available.
The system only prioritizes MED values of routes from peers within the confederation. Routes from external ASs are advertised throughout the confederation without MED comparison.
Example
# Prioritize MED values of routes from peers within the confederation.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] bestroute med-confederation
5.1.5  compare-different-as-med
undo compare-different-as-med
View
Parameter
None
Use the compare-different-as-med command to enable comparison of MED values of routes from peers in different ASs when determining the best route.
Use the undo compare-different-as-med command to disable the comparison.
The comparison is disabled by default.
If there are several paths available for one destination, the path with the smallest MED value is selected.
Do not use this command unless associated ASs adopt the same IGP protocol and routing method.
Example
# Compare MED values of routes from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] compare-different-as-med
5.1.6  dampening
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ]*
undo dampening
View
Parameter
half-life-reachable: Specifies the half-life for reachable routes, in the range 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies the half-life for unreachable routes, in the range 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies the reuse threshold value for suppressed routes, in the range 1 to 20,000. Penalty value of a suppressed route decreasing under the value is reused. By default, its value is 750.
suppress: Specifies the suppression threshold for routes in the range 1 to 20,000, which should be bigger than reuse. Routes with penalty value bigger than the threshold are suppressed. By default, it is 2,000.
ceiling: Specifies the ceiling penalty value, in the range 1001 to 20,000. The value must be bigger than suppress value. By default, the value is 16,000.
route-policy-name: Routing policy name, a string of 1 to 19 characters.
half-life-reachable, half-life-unreachable, reuse, suppress and ceiling are mutually dependent. Once any one is configured, all others should also be specified accordingly.
Use the dampening command to enable BGP4+ route dampening or/and configure dampening parameters.
Use the undo dampening command to disable route dampening.
By default, no route dampening is configured.
Related command: reset bgp ipv6 dampening, reset bgp ipv6 flap-info, display bgp ipv6 routing-table dampened, display bgp ipv6 routing-table dampening parameter and display bgp ipv6 routing-table flap-info.
Example
# Enable BGP4+ route dampening and configure route dampening parameters.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] dampening 10 10 1000 2000 3000
5.1.7  default local-preference
undo default local-preference
View
Parameter
value: Default local preference, in the range 0 to 4294967295. The larger the value is, the higher the preference is.
Use the default local-preference command to configure default local preference.
Use the undo default local-preference command to restore the default value.
By default, the default local preference is 100.
Use this command to affect BGP4+ route selection.
Example
# Two devices A and B in the same AS are connected to another AS. Change the local preference of B from default value 100 to 180, making the route via B preferred.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] default local-preference 180
5.1.8  default med
default med med-value
undo default med
View
Parameter
med-value: Default MED value, in the range 0 to 4294967295.
Use the default med command to configure the default MED value.
Use the undo default med command to restore the default.
By default, the med-value is 0.
Multi-exit discriminator (MED) is an external metric for routes. Different from local preference, MED is exchanged between ASs and will stay in the AS once it enters the AS. The smaller an MED is, the better a route is. So the route with a lower MED is preferred. When a router running BGP obtains several routes with identical destination address and different next-hops from various external peers, it will select the best route depending on the MED value. In the case that all other conditions are the same, the system first selects the route with the smaller MED value as the external route of the autonomous system.
Example
# Devices A and B belong to AS100 and device C belongs to AS200. C is A and B’s peer. Configure the MED of A as 25 to make C select the path from B first.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] default med 25
5.1.9  default-route imported
undo default-route imported
View
Parameter
None
Use the default-route imported command to redistribute local default routes into the BGP4+ routing table.
Use the undo default-route imported command to disable the redistribution.
By default, local default routes are not redistributed into BGP4+ routing table.
Example
# Redistribute default routes from OSPFv3 into BGP4+.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] default-route imported
[Sysname-bgp-af-ipv6] import-route ospfv3 1
5.1.10  display bgp ipv6 group
display bgp ipv6 group [ ipv6-group-name ]
View
Parameter
ipv6-group-name: Peer group name, a string of 1 to 47 characters.
Use the display bgp ipv6 group command to display IPv6 peer group information.
If no ipv6-group-name specified, information about all peer groups is displayed.
Example
# Display the information of the IPv6 peer group "aaa".
<Sysname> display bgp ipv6 group aaa
 BGP peer-group is aaa
 remote AS number not specified
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Peer Preferred Value: 0
  Members:
  Peer         V    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  20:20::20:1  4   200       170       141      0        2 02:13:35 Established
Table 5-1 Description on the fields of the display bgp ipv6 group command
BGP peer-group
Name of the peer group
remote AS
AS number of the peer group
Type of the  peer group
Threshold
Threshold  value
hold timer value
Holdtime
Keepalive interval
Minimum interval between advertisements
Preferred value of the routes from the peer
No routing policy is configured for the peer
Members
Group members
Peer
IPv6 address of the peer
V
Peer BGP version
AS
AS number
MsgRcvd
Number of messages received
MsgSent
Number of messages sent
OutQ
Number of messages to be sent
PrefRcv
Number of prefixes received
Up/Down
The lasting time of a session/the lasting time of present state (when no session is established)
State machine of peer
5.1.11  display bgp ipv6 network
View
Parameter
None
Use the display bgp ipv6 network command to display IPv6 routing information advertised by BGP4+ using the network command.
Example
# Display the IPv6 routing information advertised by BGP4+ using the network command..
<Sysname> display bgp ipv6 network
  BGP Local Router ID is 1.1.1.1.
  Local AS Number is 100.
  Network          Prefix             Route-policy        Short-cut
  1::              64
Table 5-2 Description on the fields of the display bgp ipv6 network command
BGP Local Router ID
BGP Local Router ID
Local AS Number
Local AS Number
Network
Network address
Prefix
Prefix length
Route-policy
Routing policy
Short-cut
Shortcut route
5.1.12  display bgp ipv6 paths
display bgp ipv6 paths [ as-regular-expression ]
View
Parameter
as-regular-expression: Matched AS path regular expression.
Use the display bgp ipv6 paths command to display AS_PATH attribute information of BGP4+ routes.
If no parameter specified, all AS_PATH information will be displayed.
Example
# Display AS_PATH attribute information of BGP4+ routes.
<Sysname> display bgp ipv6 paths
    Address       Hash    Refcount  MED         Path/Origin
    0x5917098     1       1          0            i
    0x59171D0     9       2          0            100i
Table 5-3 Description on the fields of the display bgp ipv6 paths command
Address
Route address in local database, in dotted hexadecimal notation
Hash
Hash index
Refcount
Count of routes that referenced the path
MED
MED of the route
Path
AS_PATH attribute of a route, recording the ASs a route has passed, for avoiding routing loops
Origin
Origin attribute of the route, which can take on one of the following values:
i
Indicates the route is interior to the AS.
Summary routes and routes defined using the network command are considered IGP routes.
e
Indicates that a route is learned from the exterior gateway protocol (EGP).
Short for INCOMPLETE. It indicates that the origin of a route is unknown and the route is learned by other means. BGP sets Origin attribute of routes learned from other IGP protocols to INCOMPLETE.
5.1.13  display bgp ipv6 peer
display bgp ipv6 peer [ ipv6-address { log-info | verbose } | ipv6-group-name log-info | verbose ]
View
Parameter
ipv6-address: Specifies the IPv6 address of a peer to be displayed.
Ipv6-group-name: Name of a peer group to be displayed, a string of 1 to 47 characters.
log-info: Displays log information of the specified peer.
verbose: Displays the detailed information of the peer.
Use the display bgp ipv6 peer command to display peer/peer group information.
If no parameter specified, information about all peers and peer groups is displayed.
Example
# Display all IPv6 peer information.
<Sysname> display bgp ipv6 peer
 BGP local router ID : 200.1.3.1
 Local AS number : 10
 Total number of peers : 3                 Peers in established state : 0
  1::1            4    10        0        0     0       0 04:23:22 Active
  1::2            4     1        0        0     0       0 04:21:51 Active
  1::4            4    10        0        0     0       0 04:06:29 Active
Table 5-4 Description on the fields of the display bgp ipv6 peer command
Peer
V
Peer BGP version
AS
AS number
MsgRcvd
Messages received
MsgSent
Messages sent
OutQ
Messages to be sent
PrefRcv
Up/Down
Peer state
5.1.14  display bgp ipv6 routing-table
display bgp ipv6 routing-table [ ipv6-address prefix-length ]
View
Parameter
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length of the IPv6 address, in the range 0 to 128.
Use the display bgp ipv6 routing-table command to display BGP4+ routing table information.
Example
# Display BGP4+ routing table information.
<Sysname> display bgp ipv6 routing-table
 Total Number of Routes: 2
 BGP Local router ID is 30.30.30.1
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 *>  Network : 30:30::                                  PrefixLen : 64
     NextHop : 30:30::30:1                              LocPrf    :
     PrefVal : 0                                        Label     : NULL
     MED      : 0
     Path/Ogn: i
 *>  Network : 40:40::                                  PrefixLen : 64
     NextHop : 40:40::40:1                              LocPrf    :
     MED     : 0
     Path/Ogn: i
Table 5-5 Description on the fields of the display bgp ipv6 routing-table command
Local router ID
Local router ID
Status codes
Status codes:
* – valid
> – best
d – damped
h – history
i – internal (IGP)
s – summary suppressed (suppressed)
S – Stale
Origin
i – IGP (originated in the AS)
e – EGP (learned through EGP)
? – incomplete (learned by other means)
Network
Destination network address
PrefixLen
Prefix length
NextHop
Next Hop
MED
MULTI_EXIT_DISC attribute
LocPrf
Local preference value
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops
PrefVal
Preferred value
Label
Label
Ogn
i
Indicates that a route is interior to the AS.
Summary routes and the routes configured using the network command are considered IGP routes.
e
5.1.15  display bgp ipv6 routing-table as-path-acl
display bgp ipv6 routing-table as-path-acl as-path-acl-number
View
Parameter
as-path-acl-number: Number of an AS path ACL matched by which to display routing information, ranging from 1 to 256.
Use the display bgp ipv6 routing-table as-path-acl command to view routes that match an AS path ACL.
Example
# Display routes that match the AS path ACL 20.
<Sysname> display bgp ipv6 routing-table as-path-acl 20
     MED     : 0
     Path/Ogn: i
Refer to Table 5-5 for description on the fields above.
5.1.16  display bgp ipv6 routing-table community
display bgp ipv6 routing-table community [ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ]* [ whole-match ]
View
Parameter
aa:nn: Specifies a community number, both aa and nn are in the range 0 to 65535.
&<1-13>: Specifies the argument before it can be entered up to 13 times.
no-advertise: Displays routes that are not advertised to any peer.
no-export: Displays routes that are not advertised outside the AS, if there is a confederation, then not advertised outside the confederation, but to other sub ASs in the confederation.
no-export-subconfed: Displays routes that are neither advertised outside the AS nor to other sub ASs if confederation configured.
whole-match: Displays the exactly matched routes.
Use the display bgp ipv6 routing-table community command to display specified community routing information in the routing table.
Example
# Display no-export community routing information.
<Sysname> display bgp ipv6 routing-table community no-export
     MED      : 0
     Path/Ogn: i
5.1.17  display bgp ipv6 routing-table community-list
display bgp ipv6 routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
View
Parameter
basic-community-list-number: Specifies a basic community-list number, in the range 1 to 99.
adv-community-list-number: Specifies an advanced community-list number, in the range 100 to 199.
whole-match: Displays routes exactly matching the specified basic-community-list-number.
&<1-16>: Specifies to allow entering the argument before it up to 16 times.
Use the display bgp ipv6 routing-table community-list command to view the routing information matching the specified BGP4+ community list.
Example
# Display the routing information matching the specified BGP4+ community list.
<Sysname> display bgp ipv6 routing-table community-list 99
     MED      : 0
     Path/Ogn: i
5.1.18  display bgp ipv6 routing-table dampened
View
Parameter
None
Use the display bgp ipv6 routing-table dampened command to view BGP4+ dampened routes.
Example
# Display BGP4+ dampened routes.
<Sysname> display bgp ipv6 routing-table dampened
 *d  Network : 111::                                  PrefixLen : 64
     From    : 122::1                                    Reuse     : 00:29:34
     Path/Ogn: 200?
Table 5-6 Description on the fields of the display bgp ipv6 routing-table dampened command
From
Source IP address of a route
Reuse
Reuse time value
5.1.19  display bgp ipv6 routing-table dampening parameter
View
Parameter
None
Use the display bgp ipv6 routing-table dampening parameter command to display BGP4+ route dampening parameters.
Related command: dampening.
Example
# Display BGP4+ route dampening parameters.
<Sysname> display bgp ipv6 routing-table dampening parameter
 Maximum Suppress Time(in second)     : 3069
 Ceiling Value                        : 16000
 Reuse Value                          : 750
 HalfLife Time(in  second)            : 900
 Suppress-Limit                       : 2000
Table 5-7 Description on the above fields
Ceiling Value
Upper limit of penalty value
Reuse Value
Reuse Value
HalfLife Time
Half life Time
Suppress-Limit
Limit for a route to be suppressed
5.1.20  display bgp ipv6 routing-table different-origin-as
View
Parameter
None
Use the display bgp ipv6 routing-table different-origin-as command to view routes originating from different autonomous systems.
Example
# Display routes from different ASs.
<Sysname> display bgp ipv6 routing-table different-origin-as
BGP Local router ID is 2.2.2.2
 *>  Network : 222::                                    PrefixLen : 64
     NextHop : 122::2                                   LocPrf    :
     MED      : 0
     Path/Ogn: 100 ?
5.1.21  display bgp ipv6 routing-table flap-info
display bgp ipv6 routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | ipv6-address [ prefix-length [ longer-match ] ] ]
View
Parameter
as-regular-expression: AS path regular expression to be matched.
as-path-acl-number: Number of the specified AS path ACL to be matched, ranging from 1 to 256.
ipv6-address: IPv6 address of a route to be displayed.
prefix-length: Prefix length of the IPv6 address, in the range 1 to 128.
longer-match: Matches the longest prefix.
Use the display bgp ipv6 routing-table flap-info command to display BGP4+ route flap statistics.
Example
# Display BGP4+ route flap statistics.
<Sysname> display bgp ipv6 routing-table flap-info
     From     : 122::1                                Flaps     : 3
     Duration : 00:13:47                              Reuse     : 00:16:36
     Path/Ogn : 200?
Table 5-8 Description on the fields of the display bgp ipv6 routing-table flap-info command
Flaps
Number of flaps
Duration
Flap duration
Reuse
Reuse time of the route
5.1.22  display bgp ipv6 routing-table label
View
Parameter
None
Use the display bgp ipv6 routing-table label command to display BGP4+ IPv6 label routing information.
&  Note:
Currently, the S3610&S5510 series do not support this command.
Example
5.1.23  display bgp ipv6 routing-table peer
display bgp ipv6 routing-table peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistic ]
View
Parameter
ipv6-address: Specifies the peer to be displayed.
advertised-routes: Routing information advertised to the specified peer.
received-routes: Routing information received from the specified peer.
network-address prefix-length: IPv6 address, with prefix length ranging from 0 to 128.
statistic: Displays route statistics.
Use the display bgp ipv6 routing-table peer command to view the routing information advertised to or received from specified BGP peer.
Example
# Display the routing information advertised to the specified BGP peer.
<Sysname> display bgp ipv6 routing-table peer 10:10::10:1 advertised-routes
 BGP Local router ID is 20.20.20.1
 *>  Network : 20:20::                                  PrefixLen : 64
     NextHop : 20:20::20:1                              LocPrf    :
     MED     : 0
     Path/Ogn: i
     MED     : 0
     Path/Ogn: 300 i
5.1.24  display bgp ipv6 routing-table regular-expression
display bgp ipv6 routing-table regular-expression as-regular-expression
View
Parameter
as-regular-expression: Matched AS regular expression.
Use the display bgp ipv6 routing-table regular-expression command to display the routing information matching specified AS regular expression.
Example
# Display the routing information matching the specified AS regular expression.
<Sysname> display bgp ipv6 routing-table regular-expression ^100
 *>  Network : 50:50::                                  PrefixLen : 64
     NextHop : 10:10::10:1                              LocPrf    :
     MED     : 0
     Path/Ogn: 100 i
5.1.25  display bgp ipv6 routing-table statistic
View
Parameter
None
Use the display bgp ipv6 routing-table statistic command to display statistics about BGP4+ routes.
Example
# Display statistics about BGP4+ routes.
<Sysname> display bgp ipv6 routing-table statistic
 Total Number of Routes: 1
5.1.26  filter-policy export
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol  process-id ]
undo filter-policy export [ protocol process-id ]
View
Parameter
acl6-number: Specifies the number of an IPv6 ACL matching against the destination address field of routing information, ranging from 2000 to 3999.
ipv6-prefix-name: Specifies the name of an IPv6 prefix list matching against the destination address field of routing information, a string of 1 to 19 characters.
protocol: Specifies the routing protocol from which to filter routes. It can be direct, isisv6, ospfv3, ripng, and static at present. If no protocol specified, all routes will be filtered when advertised.
process-id: Process ID of routing protocol, in the range 1 to 65535. It is available only when the protocol is isisv6, ospfv3 or ripng.
Use the filter-policy export command to filter advertised routes and only the routes passing the filter can be advertised by BGP4+.
Use the undo filter-policy export command to cancel filtering advertised routes.
By default, advertised routing information is not filtered.
If protocol specified, only routes redistributed from the specified protocol are filtered. If protocol is not specified, routes redistributed from any protocol will be filtered.
Example
# Use ACL6 2001 to filter all routes advertised by BGP4+.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] filter-policy 2001 export
5.1.27  filter-policy import
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
View
Parameter
Use the filter-policy import command to filter received routing information, only routes not filtered are imported.
Use the undo filter-policy import command to cancel filtering received routing information.
By default, the received routing information is not filtered.
Example
# Use ACL6 2001 to filter all routes received by BGP4+.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] filter-policy 2001 import
5.1.28  group
group ipv6-group-name [ internal | external ]
undo group ipv6-group-name
View
Parameter
ipv6-group-name: Specifies the name of an IPv6 peer group, a string of 1 to 47 characters.
internal: Creates an IBGP peer group.
external: Creates an EBGP peer group, including groups of other sub ASs in confederation.
Use the group command to create a peer group.
Use the undo group command to delete a peer group.
An IBGP peer group will be created if neither internal nor external is selected.
The members of a peer group must be configured the same routing update policy as the peer group, but can be configured with different inbound policies.
Example
# Create an IBGP peer group "test".
[Sysname] bgp 100
[Sysname] ipv6-family
[Sysname-bgp-af-ipv6] group test
5.1.29  import-route
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ]*
undo import-route protocol [ process-id ]
View
Parameter
protocol: Specifies the routing protocol from which to redistribute routes, it can be direct, isisv6, ospfv3, ripng and static at present.
process-id: Process ID, in the range 1 to 65535. It is available only when the protocol is isisv6, ospfv3 or ripng.
med-value: Specifies the MED value to be applied to redistributed routes, ranging from 0 to 4294967295. If not specified, the cost of a redistributed route is the route’s MED in BGP4+.
route-policy-name: Specifies the name of a routing policy used to filter redistributed routes, a string of 1 to 19 characters.
Use the import-route command to redistribute routes from other protocols.
Use the undo import-route command to remove the configuration.
By default, BGP4+ does not redistribute routes from other protocols.
The routes redistributed to the BGP4+ routing table using the import-route command has the ORIGIN attribute as incomplete.
Example
# Redistribute routes from RIPng 1.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] import-route ripng 1
5.1.30  ipv6-family
ipv6-family
undo ipv6-family
View
BGP view
Parameter
None
Use the ipv6-family command to enter IPv6 address family view.
Use the undo ipv6-family command to remove all configurations from the view.
BGP IPv4 unicast view is the default.
Example
# Enter IPv6 address family view.
[Sysname] bgp 100
5.1.31  network
network ipv6-address prefix-length [ short-cut | route-policy route-policy-name ]
undo network ipv6-address prefix-length [ short-cut ]
View
Parameter
ipv6-address: IPv6 address to advertise.
prefix-length: Prefix length of the address, in the range 0 to 128.
short-cut: Specifies an EBGP route to use local routing managing value, reducing the preference of the route in general.
route-policy-name:  Name of Route-policy applied to the route, a string of 1 to 19 characters.
Use the network command to advertise a network route the BGP4+ routing table.
Use the undo network command to remove the existing configuration.
By default, no route is advertised.
Note that:
l           The network route to be advertised must be in the local IP routing table, and using a routing policy makes route management more flexible.
l           The route advertised to the BGP4+ routing table using the network command has the ORIGIN attribute as IGP.
Example
# Advertise the route 2002::/16.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] network 2002:: 16
5.1.32  peer advertise-community
peer { ipv6-group-name | ipv6-address } advertise-community
undo peer { ipv6-group-name | ipv6-address } advertise-community
View
Parameter
ipv6-group-name: Specifies the name of a peer group, in the range 1 to 47 characters.
ipv6-addres: IPv6 address of a peer.
Use the peer advertise-community command to advertise community attribute to a peer/peer group.
Use the undo peer advertise-community command to cancel the existing configuration.
By default, no community attribute is advertised to any peer group/peer.
Example
# Advertise community attribute to the peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 advertise-community
5.1.33  peer advertise-ext-community
peer { ipv6-group-name | ipv6-address } advertise-ext-community
undo peer { ipv6-group-name | ipv6-address } advertise-ext-community
View
Parameter
ipv6-group-name: Name of a peer group, a string of 1 to 47 characters.
Use the peer advertise-ext-community command to advertise extended community attribute to a peer/peer group.
Use the undo peer advertise-ext-community command to remove the configuration.
By default, no extended community attribute is advertised to a peer/peer group.
&  Note:
Example
5.1.34  peer allow-as-loop
peer { ipv6-group-name | ipv6-address } allow-as-loop [ number ]
undo peer { ipv6-group-name | ipv6-address } allow-as-loop
View
Parameter
ipv6-address: IPv6 address of a peer.
number: Specifies the repeating times of the local AS number, in the range 1 to 10, which defaults to 1.
Use the peer allow-as-loop command to allow local AS number in the AS_PATH attribute of routes from a peer/peer group, and to configure the repeating times of the local AS number.
Use the undo peer allow-as-loop command to cancel the function.
Local AS number is not allowed by default.
Example
# Configure the repeating times of the local AS number as 2 for routes from peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1::1 allow-as-loop 2
5.1.35  peer as-number
peer { ipv6-group-name | ipv6-address } as-number as-number
undo peer ipv6-group-name as-number
undo peer ipv6-address
View
Parameter
as-number: AS number of the peer/peer group, in the range 1 to 65535.
Use the peer as-number command to specify an AS number for a peer/peer group.
Use the undo peer as-number command to delete the AS number of a peer.
Use the undo peer command to delete a peer.
By default, no AS number is configured for a peer/peer group.
Example
# Specify the AS number of the peer group test as 100.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] group test external
[Sysname-bgp-af-ipv6] peer test as-number 100
5.1.36  peer as-path-acl
peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number { import | export }
undo peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number { import | export }
View
Parameter
as-path-acl-number: Number of an AS path ACL, in the range 1 to 256.
import: Filters received routes.
export: Filters advertised routes.
Use the peer as-path-acl command to specify an AS path list to filter routes received from or advertised to a peer/peer group.
Use the undo peer as-path-acl command to cancel the existing configuration.
By default, no AS path list is specified for filtering.
Example
# Specify the AS path ACL 3 to filter routes advertised to the peer 1:2::3:4.
[Sysname] ip as-path-acl 3 permit ^200
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-path-acl 3 export
5.1.37  peer capability-advertise route-refresh
peer { ipv6-group-name | ipv6-address } capability-advertise route-refresh
undo peer { ipv6-group-name | ipv6-address } capability-advertise route-refresh
View
Parameter
Use the peer capability-advertise route-refresh command to enable BGP4+ route-refresh.
Use the undo peer capability-advertise route-refresh command to disable the function.
By default, route-refresh is enabled.
Example
# Disable route-refresh of peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-number 100
[Sysname-bgp-af-ipv6] undo peer 1:2::3:4 capability-advertise route-refresh
5.1.38  peer connect-interface
peer { ipv6-group-name | ipv6-address } connect-interface interface-type interface-number
undo peer { ipv6-group-name | ipv6-address } connect-interface
View
Parameter
interface-type interface-number: Specifies the type and name of the interface.
Use the peer connect-interface command to specify the source interface of updates to a peer/peer group.
Use the undo peer connect-interface command to restore the best source interface.
By default, BGP4+ uses the best source interface.
For updates to be forwarded in case the interface experiences a failure, you can configure to use the Loopback interface for forwarding route updates.
Example
# Specify loopback0 as the source interface for route updates to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test connect-interface loopback 0
5.1.39  peer default-route-advertise
peer { ipv6-group-name | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { ipv6-group-name | ipv6-address } default-route-advertise
View
Parameter
route-policy-name: Route-policy name, a string of 1 to 19 characters.
Use the peer default-route-advertise command to advertise a default route to a peer/peer group.
Use the undo peer default-route-advertise command to disable advertising default route.
By default, no default route is advertised to a peer/peer group.
For this command, no default route is required in the routing table. A default route is sent unconditionally to a peer/peer group with the next hop being itself.
Example
# Advertise a default route to peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 default-route-advertise
5.1.40  peer description
peer { ipv6-group-name | ipv6-address } description description-text
undo peer { ipv6-group-name | ipv6-address } description
View
Parameter
description-text: Description information for the peer/peer group, a string of 1 to 79 characters.
Use the peer description command to configure the description information for a peer/peer group.
Use the undo peer description command to remove the description information of a peer/peer group.
By default, no description information is configured for a peer (group).
Create a peer/peer group before configuring description information for it.
Example
# Configure the description information of the peer group “test” as ISP1.
<Sysname] system-view
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test description ISP1
5.1.41  peer ebgp-max-hop
peer { ipv6-group-name | ipv6-address } ebgp-max-hop [ hop-count ]
undo peer { ipv6-group-name | ipv6-address } ebgp-max-hop
View
Parameter
hop-count: Maximum hop count, in the range 1 to 255. By default, the value is 64.
Use the peer ebgp-max-hop command to allow establishing EBGP connection with a peer/peer group on an indirectly connected network.
Use the undo peer ebgp-max-hop command to cancel the existing configuration.
You can use the argument hop-count to specify the maximum route count of the EBGP connection.
Example
# Allow establishing the EBGP connection with the peer group "test" on an indirectly connected network.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test ebgp-max-hop
5.1.42  peer fake-as
peer { ipv6-group-name | ipv6-address } fake-as as-number
undo peer { ipv6-group-name | ipv6-address } fake-as
View
Parameter
as-number: Local autonomous system number, in the range 1 to 65535.
Use the peer fake-as command to configure a fake local AS number for a peer or peer group.
Use the undo peer fake-as command to remove the configuration.
By default, no fake local AS number is configured for a peer or peer group.
Example
# Configure a fake AS number 200 for the peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test fake-as 200
5.1.43  peer filter-policy
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number { import | export }
undo peer { ipv6-group-name | ipv6-address } filter-policy acl6-number { import | export }
View
Parameter
acl6-number: IPv6 ACL number, in the range 2000 to 3999.
import: Applies the filter-policy to routes received from the peer/peer group.
export: Applies the filter-policy to routes advertised to the peer/peer group.
Use the peer filter-policy command to configure an ACL-based filter policy for a peer or peer group.
Use the undo peer filter-policy command to remove the configuration.
By default, no ACL-based filter policy is configured for a peer or peer group.
Example
# Apply the ACL6 2000 to filter routes advertised to the peer 1:2::3:4.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2001:1:: 64
[Sysname-acl6-basic-2000] quit
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 filter-policy 2000 export
5.1.44  peer group
peer ipv6-address group ipv6-group-name [ as-number as-number ]
undo peer ipv6-address group ipv6-group-name
View
Parameter
as-number: Specifies the AS number of the peer/peer group, in the range 1 to 65535.
Use the peer group command to add a peer to a peer group.
Use the undo peer group command to delete a specified peer from a peer group.
No peer is added by default.
Example
# Create a peer group “test” and add the peer 1:2::3:4 to the peer group.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-number 200
[Sysname-bgp-af-ipv6] peer 1:2::3:4 group test
5.1.45  peer ignore
peer { ipv6-group-name | ipv6-address } ignore
undo peer { ipv6-group-name | ipv6-address } ignore
View
Parameter
Use the peer ignore command to terminate session with a peer or peer group.
Use the undo peer ignore command to remove the configuration.
By default, a router can establish sessions with a peer or peer group.
After the peer ignore command is executed, the system terminates session with the specified peer or peer group and clears all the related routing information. For a peer group, this means all sessions with the peer group will be tore down.
Example
# Terminate session with the peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 ignore
5.1.46  peer ipv6-prefix
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name { import | export }
undo peer { ipv6-group-name | ipv6-address } ipv6-prefix { import | export }
View
Parameter
ipv6-prefix-name: Specifies an IPv6 prefix list name, a string of 1 to 19 characters.
import: Applies the filtering policy to routes received from the specified peer/peer group.
export: Applies the filtering policy to routes advertised to the specified peer/peer group.
Use the peer ipv6-prefix command to use an IPv6 prefix list to filter routes received from or advertised to a peer or peer group.
Use the undo peer ipv6-prefix command to remove the configuration.
By default, no IPv6 prefix list is specified.
Example
# Use the IPv6 prefix list “list 1” to filter routes advertised to the peer group “test”.
[Sysname] ip ipv6-prefix list1 permit 2002:: 64
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test ipv6-prefix list1 export
5.1.47  peer keep-all-routes
peer { ipv6-group-name | ipv6-address } keep-all-routes
undo peer { ipv6-group-name | ipv6-address } keep-all-routes
View
Parameter
Use the peer keep-all-routes command to save the original routing information from a peer or peer group, even routes that failed to pass the inbound policy.
Use the undo peer keep-all-routes command to disable this function.
By default, the function is not available.
Example
# Save the routing information from peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 keep-all-routes
5.1.48  peer log-change
peer { ipv6-group-name | ipv6-address } log-change
undo peer { ipv6-group-name | ipv6-address } log-change
View
Parameter
Use the peer log-change command to record the session state and event information for a specified peer or peer group.
Use the undo peer log-change command to remove the configuration.
By default, the session state and event information are recorded for a peer or peer group.
Example
# Record the session state and event information for peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 log-change
5.1.49  peer next-hop-local
peer { ipv6-group-name | ipv6-address } next-hop-local
undo peer { ipv6-group-name | ipv6-address } next-hop-local
View
Parameter
Use the peer next-hop-local command to set the next hop of routes advertised to a peer/peer group to the local router.
Use the undo peer next-hop-local command to remove the configuration.
By default, the feature is available for routes advertised to the EBGP peer/peer group, but not available to the IBGP peer/peer group
Example
# Set the next hop of routes advertised to EBGP peer group “test” to the router itself.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test next-hop-local
5.1.50  peer preferred-value
peer { ipv6-group-name | ipv6-address } preferred-value value
undo peer { ipv6-group-name | ipv6-address } preferred-value
View
Parameter
value: Preferred value, in the range 0 to 65535.
Use the peer preferred-value command to assign a preferred value to routes received from a peer or peer group.
Use the undo peer preferred-value command to restore the default value.
By default, routes received from a peer or peer group have a preferred value of 0.
The routes learned from peers each have an initial preferred value. The route with the biggest value is selected as the route to a specified network.
Example
# Configure the preferred value as 50 for routes from peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 preferred-value 50
5.1.51  peer public-as-only
peer { ipv6-group-name | ipv6-address } public-as-only
undo peer { ipv6-group-name | ipv6-address } public-as-only
View
Parameter
Use the peer public-as-only command to carry no private AS number in BGP4+ updates sent to a peer/peer group.
Use the undo peer public-as-only command to carry the private AS number in BGP4+ updates sent to a peer/peer group.
By default, private AS number is carried in BGP4+ updates.
The command does not take effect if the BGP4+ update has both public AS number and private AS number. The range of private AS number is from 64512 to 65535.
Example
# Carry no private AS number in BGP4+ updates sent to the peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 public-as-only
5.1.52  peer reflect-client
peer { ipv6-group-name | ipv6-address } reflect-client
undo peer { ipv6-group-name | ipv6-address } reflect-client
View
Parameter
Use the peer reflect-client command to configure the router as a router reflector and specify a peer/peer group as a client.
Use the undo peer reflect-client command to cancel the existing configuration.
By default, neither route reflector nor client is configured.
Related command: reflect between-clients and reflector cluster-id.
Example
# Configure the local device as a router reflector and specify the peer group "test" as a client.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test reflect-client
5.1.53  peer route-limit
peer { ipv6-group-name | ipv6-address } route-limit limit [ percentage ]
undo peer { ipv6-group-name | ipv6-address } route-limit
View
Parameter
limit: Specifies the upper limit of address prefixes received from the peer or peer group. a string of 1 to 4096 characters.
percentage: Specifies the percentage of routes to generate alarm information, ranging from 1 to 100, with the default as 75.
Use the peer route-limit command to set the maximum number of prefixes allowed to receive from a peer/peer group.
Use the undo peer route-limit command to restore the default.
By default, the router has no prefix number limit.
The local router will end peer relation when the number of address prefixes received exceeds the limit.
Example
# Set the number of prefixes allowed to receive from the peer 1:2::3:4 to 1000.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 route-limit 1000
5.1.54  peer route-policy
peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export }
undo peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export }
View
Parameter
route-policy-name: Specifies route-policy name, a string of 1 to 19 characters.
import: Applies the route-policy to routes received from the peer (group).
export: Applies the route-policy to routes advertised to the peer (group).
Use the peer route-policy command to apply a routing policy to routes received from or advertised to a peer or peer group.
Use the undo peer route-policy command to remove the configuration.
By default, the peer (group) has no route-policy associated.
The peer route-policy command does not use the if-match interface clause in the route-policy.
Example
# Apply routing policy test-policy to routes received from the peer group test.
[Sysname] route-policy test-policy permit node 10
[Sysname-route-policy] if-match cost 10
[Sysname-route-policy] apply cost 65535
[Sysname-route-policy] quit
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test route-policy test-policy import
5.1.55  peer route-update-interval
peer { ipv6-group-name | ipv6-address } route-update-interval seconds
undo peer { ipv6-group-name | ipv6-address } route-update-interval
View
Parameter
seconds: Specifies the minimum interval for sending the same update to a peer (group), in the range 5 to 600 seconds.
Use the peer route-update-interval command to specify the interval for sending the same update to a peer/peer group.
Use the undo peer route-update-interval command to restore the default value.
By default, the interval is 15 seconds for the IBGP peer, and 30 seconds for the EBGP peer.
Example
# Specify the interval for sending the same update to the peer 1:2::3:4 as 10 seconds.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 route-update-interval 10
5.1.56  peer substitute-as
peer { ipv6-group-name | ipv6-address } substitute-as
undo peer { ipv6-group-name | ipv6-address } substitute-as
View
Parameter
Use the peer substitute-as command to substitute the local AS number for AS number in the AS_PATH attribute of a peer/peer group.
Use the undo peer substitute-as command to remove the configuration.
By default, the local AS number is not substituted for AS number in the AS_PATH attribute of a peer/peer group.
Example
# Substitute local AS number for AS number of peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 substitute-as
5.1.57  peer timer
peer { ipv6-group-name | ipv6-address } timer keepalive keepalive hold holdtime
undo peer { ipv6-group-name | ipv6-address } timer
View
Parameter
keepalive: Specifies the keepalive interval in seconds, ranging from 1 to 21,845.
holdtime: Specifies the holdtime in seconds, ranging from 3 to 65,535.
Use the peer timer command to configure keepalive interval and holdtime interval for a peer or peer group.
Use the undo peer timer command to restore the default.
keepalive interval defaults to 60 seconds, and holdtime interval defaults to 180 seconds
Note that:
l           The timer configured by this command is preferred to the timer configured by the timer command.
l           The holdtime interval must be at least three times the keepalive interval.
Related command: timer.
Example
# Configure the keepalive interval and holdtime interval for the peer group test as 60 seconds and 180 seconds.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test timer keep-alive 60 hold 180
5.1.58  preference
undo preference
View
Parameter
external-preference: Preference of EBGP route that is learned from an EBGP peer, in the range 1 to 255.
internal-preference: Preference of IBGP route that is learned from an IBGP peer, in the range 1 to 255.
local-preference: Preference of local route, in the range 1 to 255.
route-policy-name: Route policy name, a string of 1 to 19 characters. You can set preference for routes passing the routing policy. For the routes not matched, the default value applies.
Use the preference command to configure preferences for EBGP, IBGP, and local routes.
Use the undo preference command to restore the default.
For external-preference, internal-preference and local-preference, the bigger the preference value is, the lower the preference is, and the default values are 255, 255 and 130.
Example
# Configure preferences for EBGP, IBGP, and local routes as 20, 20 and 200.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] preference 20 20 200
5.1.59  reflect between-clients
undo reflect between-clients
View
Parameter
None
Use the reflect between-clients command to enable route reflection between clients.
Use the undo reflect between-clients command to disable this function.
By default, route reflection between clients is enabled.
After a route reflector is configured, it reflects routes between clients. If the clients of a route reflector are fully connected, disable route reflection between clients to reduce costs.
Related command: reflector cluster-id and peer reflect-client.
Example
# Enable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] reflect between-clients
5.1.60  reflector cluster-id
reflector cluster-id cluster-id
undo reflector cluster-id
View
Parameter
cluster-id: Specifies the cluster ID of the route reflector, in integer (1 to 4294967295) or IPv4 address format.
Use the reflector cluster-id command to configure the cluster ID of the route reflector.
Use the undo reflector cluster-id command to remove the configured cluster ID.
By default, each route reflector uses its router ID as the cluster ID.
Usually, there is only one route reflector in a cluster. Router ID of the reflector identifies the cluster. You can configure multiple route reflectors to improve the stability of the network, and use this command to configure the identical cluster ID for all the reflectors to avoid routing loops.
Related command: reflect between-clients and peer reflect-client.
Example
# Set cluster ID for local router to 50.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] reflector cluster-id 50
5.1.61  refresh bgp ipv6
refresh bgp ipv6 { all | ipv6-address | group ipv6-group-name | external | internal } { export | import }
View
Parameter
all: Soft-reset all BGP4+ connections.
Ipv6-group-name: Name of a peer group, a string of 1 to 47 characters.
external: EBGP connection.
internal: IBGP connection.
export: Outbound direction on which to perform soft reset.
import: Inbound direction on which to perform soft reset.
Use the refresh bgp ipv6 command to perform soft reset on specified BGP4+ connections. Using this function can refresh the BGP4+ routing table without disconnecting BGP4+ connections and apply a new available policy.
To perform BGP4+ soft reset, all routers in the network should support Route-refresh. If a router not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command on the local router to save all route updates before performing soft reset.
Example
# Perform BGP4+ soft reset.
<Sysname> refresh bgp ipv6 all import
5.1.62  reset bgp ipv6
reset bgp ipv6 { all | as-number | ipv6-address [ flap-info ] | group ipv6-group-name | external | internal }
View
Parameter
all: Resets all BGP4+ connections.
as-number: Specifies an AS number with which to reset connections to peers.
ipv6-address: Specifies the IP address of a peer with which to reset the connection.
flap-info: Clears history information of routing flap.
group ipv6-group-name: Specifies to reset connections with the specified peer group.
external: Resets all the EBGP connections.
internal: Resets all the IBGP connections.
Use the reset bgp ipv6 command to reset specified BGP4+ connections.
Example
# Reset all the BGP4+ connections.
<Sysname> reset bgp ipv6 all
5.1.63  reset bgp ipv6 dampening
reset bgp ipv6 dampening [ ipv6-address prefix-length ]
View
Parameter
Use the reset bgp ipv6 dampening command to clear route dampening information and release suppressed routes.
If no ipv6-address prefix-length specified, all IPv6 route dampening information will be cleared.
Example
# Clear route damping information of route 2345::/64 and release suppressed routes.
<Sysname> reset bgp ipv6 dampening 2345:: 64
5.1.64  reset bgp ipv6 flap-info
reset bgp ipv6 flap-info [ ipv6-address/prefix-length | regexp as-path-regexp | as-path-acl as-path-acl-number ]
View
Parameter
ipv6-address: Specifies an IPv6 address of which to clear flap information.
prefix-length: Prefix length of the address, in the range 1 to 128.
as-path-regexp: Clears flap information of routes matching an AS path regular expression.
as-path-acl-number: Clears flap information of routes matching an AS path ACL, number of which is in the range 1 to 256.
Use the reset bgp ipv6 flap-info command to clear the flap statistics of matched routes.
The flap statistics of all the routes will be cleared if no parameter or keyword is specified.
Example
# Clear the flap statistics of all routes matching AS path ACL 10.
[Sysname] ip as-path-acl 10 permit ^100.*200$
[Sysname] quit
<Sysname> reset bgp ipv6 flap-info as-path-acl 10
5.1.65  router-id
router-id router-id
undo router-id
View
BGP view
Parameter
router-id: Router ID in IP address format.
Use the router-id command to specify a router ID. Each router ID identifies only one router in an AS.
Use the undo router-id command to remove a router ID.
To run BGP4+ protocol, a router must have a router ID, which is an unsigned 32-bit integer as the router’s only identification in an AS.
Router ID can be configured manually. The system will acquire a router ID automatically from the current interfaces’ IPv4 addresses if no router ID is specified. To acquire the router ID, the system finds the maximum IPv4 address first from Loopback interface addresses, then from other interfaces addresses if there is no Loopback interface.
Only when the interface of the Router ID is removed or the manually configured Router ID is removed, will the system select another Router ID. To improve network reliability, configure the IPv4 address of a loopback interface as the Router ID.
Example
# Specifies Router ID as 10.18.4.221.
[Sysname] bgp 100
[Sysname-bgp] router-id 10.18.4.221
5.1.66  synchronization
synchronization
undo synchronization
View
Parameter
None
Use the synchronization command to synchronize the BGP4+ and IGP routes.
Use the undo synchronization command to disable synchronization.
The feature is disabled by default.
With this feature enabled and when a non-BGP4+ router is responsible for forwarding packets in an AS, BGP4+ speakers in the AS cannot advertise routing information to outside ASs unless all routers in the AS know the latest routing information.
When a BGP4+ router receives an IBGP route, it checks only whether the next hop is reachable before advertisement by default. If synchronization is enabled, the IBGP route is synchronized and advertised to EBGP peers only when the route is also advertised by IGP. Otherwise, the IBGP route cannot be advertised to EBGP peers.
Example
# Synchronize BGP4+ and IGP routes.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] synchronization
5.1.67  timer
undo timer
View
Parameter
holdtime: Specifies the holdtime interval in seconds, ranging from 3 to 65,535.
Use the timer command to configure BGP4+ keepalive interval and holdtime interval.
Use the undo timer command to restore the default.
By default, the keepalive and holdtime intervals are 60s and 180s.
Note that:
l           Timer configured using the peer timer command is preferred to the timer configured using this command.
l           The configured timer applies to all the BGP4+ peers. It becomes valid only after the corresponding BGP4+ connections are reset.
Related command: peer timer.
Example
# Configure keepalive interval and holdtime interval as 60 and 180 seconds.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] timer keepalive 60 hold 180
Chapter 6  Routing Policy Configuration Commands
&  Note:
l      Verify that the system already operates in IPv4/IPv6 dual-stack mode before configuring IPv6 routing policy.
l      All the IPv6 routing policy related configuration mentioned in this manual assumes that the system already operates in IPv4/IPv6 dual-stack mode. For dual stack mode configuration, see the part covering dual stack in the IPv6 Configuration module.
6.1  Public Routing Policy Configuration Commands
For public routing policy configuration commands, see IPv4 Routing module in the command manual for information related to routing policy.
6.2  IPv6 Routing Policy Configuration Commands
6.2.1  apply ipv6 next-hop
undo apply ipv6 next-hop
View
Routing policy view
Parameter
ipv6-address: Next hop IPv6 address.
Use the apply ipv6 next-hop command to set the next hop for IPv6 routing information to the specified address.
Use the undo apply ipv6 next-hop command to remove the clause configuration.
No next hop address is set for IPv6 routing information by default.
You cannot use the apply ipv6 next-hop command to set next hop address for redistributed routes.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If routing information matches AS path ACL 1, set the next hop address to 3ff3:506::1.
[Sysname-route-policy] if-match as-path-acl 1
[Sysname-route-policy] apply ipv6 next-hop 3ffe:506::1
6.2.2  display ip ipv6-prefix
display ip ipv6-prefix [ ipv6-prefix-name ]
View
Parameter
ipv6-prefix-name: IPv6 prefix list name, a string of 1 to 19 characters.
Use the display ip ipv6-prefix command to display the statistics of the specified IPv6 prefix list. If no IPv6 prefix list name is specified, the statistics of all the IPv6 prefix lists will be displayed.
Example
# Display the statistics of all the IPv6 address prefix lists.
<Sysname> display ip ipv6-prefix
Prefix-list6 abc
Permitted 0
Denied 0
         index:   10            permit  ::/0
         index:   20             permit  ::/1                 ge  1   le  128
Table 6-1 Description on the fields of the display ip ipv6-prefix command
Prefix-list6
Name of IPv6 prefix list
Permitted
Number of routes satisfying the matching condition
Denied
Number of routes not satisfying the matching condition
index
Internal serial number of address prefix list
permit
Matching mode: permit, deny
::/1
IPv6 address and its prefix length for matching
ge
greater-equal, the minimum length of matched IPv6 prefix
le
less-equal, the maximum length of matched IPv6 prefix
6.2.3  if-match ipv6
if-match ipv6 { address | next-hop | route-source } { acl acl6-number | prefix-list ipv6-prefix-name }
undo if-match ipv6 { address | next-hop | route-source } [ acl | prefix-list ]
View
Routing policy view
Parameter
address: Matches the destination address of IPv6 routing information.
next-hop: Matches the next hop of IPv6 routing information.
route-source: Matches the source address of IPv6 routing information.
acl acl6-number: Specifies the number of an IPv6 ACL for filtering, in the range 2000 to 3999 for address, and 2000 to 2999 for next-hop and route-source.
prefix-list ipv6-prefix-name: Specifies the name of a IPv6 prefix list for filtering, a string of 1 to 19 characters.
Use the if-match ipv6 command to match IPv6 routing information (destination, next hop or source address).
Use the undo if-match ipv6 command to remove the matching condition.
The matching condition is not configured by default.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass the routing information whose next hop address matches IPv6 prefix list p1.
[Sysname-route-policy] if-match ipv6 next-hop prefix-list p1
6.2.4  ip ipv6-prefix
ip ipv6-prefix ipv6-prefix-name [ index index-number ] { deny | permit } ipv6-address prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ]
undo ip ipv6-prefix ipv6-prefix-name [ index index-number ]
View
Parameter
ipv6-prefix-name: IPv6 prefix list name, a string of 1 to 19 characters, for uniquely specifying an IPv6 prefix list.
index-number: Index number, in the range 1 to 65535, for uniquely specifying an IPv6 prefix list item. The item with smaller index-number will be tested first.
permit: Specifies the matching mode for the IPv6 prefix list as permit, that is, when a route to be filtered is in the range of the IPv6 prefix list, the route passes the IPv6 prefix list without needing to enter the next item for testing. If the route to be filtered is not in the prefix range, it will enter the next item test.
deny: Specifies the matching mode for the IPv6 prefix list as deny, that is, when a route to be filtered is in the IPv6 prefix list range, the route neither passes the filter nor enters the next node for testing. If not in the range, the route will enter the next item test.
ipv6-address prefix-length: Specifies IPv6 prefix and prefix length, with prefix-length in the range 0 to 128. When specified as :: 0, it matches all IP addresses.
min-prefix-length, max-prefix-length: Specifies the range of IPv6 prefix if IPv6 address and prefix length are matched. greater-equal means “greater than or equal to” and less-equal means “less than or equal to”. The range relation is mask-length <= min-mask-length <= max-mask-length <= 32. If only min-prefix-length is specified, the prefix length range is [ min-prefix-length, 128 ]. If only max-prefix-length is specified, the prefix length range is [ prefix-length, max-prefix-length ]. If both min-prefix-length and max-prefix-length are specified, the prefix length range is [ min-prefix-length, max-prefix-length ].
Use the ip ipv6-prefix command to configure an IPv6 address prefix list or an item.
Use the undo ip ipv6-prefix command to remove an IPv6 address prefix list or an item.
No IPv6 address prefix list is configured by default.
The IPv6 address prefix list is used to filter IPv6 addresses. It may have multiple items, each of which specifies a range of IPv6 prefix. The filtering relation among items is logic OR, namely, it requires passing an item to pass the prefix list.
The IPv6 prefix range is determined by prefix-length and [ min-prefix-length, max-prefix-length ]. If both mask-length and [ min-mask-length, max-mask-length ] are specified, then the IPv6 addresses to be filtered must satisfy both of them.
If ipv6-address prefix-length is specified as :: 0, then only the default routes will be matched.
If you want to match all the routes, configure it as :: 0 less-equal 128.
Example
# Let pass the IPv6 addresses with mask length between 32 bits and 64 bits.
[Sysname] ip ipv6-prefix abc permit :: 0 greater-equal 32 less-equal 64
# Refuse to let pass the IPv6 addresses with prefix as 3FFE:D00::/32, prefix length greater than or equal to 32 bits.
[Sysname] ip ipv6-prefix abc deny 3FEE:D00:: 32 less-equal 128
6.2.5  reset ip ipv6-prefix
reset ip ipv6-prefix [ ipv6-prefix-name ]
View
Parameter
ipv6-prefix-name: Unique IPv6 prefix list, a string of 1 to 19 characters.
Use the reset ip ipv6-prefix command to clear the statistics of the specified IPv6 prefix list. If no name specified, the statistics of all IPv6 prefix lists will be cleared.
Example
# Specify to delete statistics of the specified IPv6 prefix list.
<Sysname> reset ip ipv6-prefix abc
