H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
18-ACL Command
18-ACL Command 246 KB
Chapter 1  IPv4 ACL Configuration Commands
1.1  Time Range Configuration Commands
1.1.1  display time-range
display time-range { all | time-name }
View
Parameter
time-name: Time range name comprising 1 to 32 characters. It is case insensitive and must start with an English letter. To avoid confusion, this name cannot be all.
all: All existing time ranges.
Use the display time-range command to display the configuration and state of a specified or all time ranges.
A time range is active if the system time falls into its range, and if otherwise, inactive.
Example
# Display the configuration and state of time range trname.
<Sysname> display time-range trname
Current time is 10:45:15 4/14/2005 Thursday
Time-range : trname ( Inactive )
from 08:00 12/1/2005 to 23:59 12/31/2100
Table 1-1 Description on the fields of the display time-range command
Current time
Current system time
Time-range
The configuration and state of time range, such as time range name, its activated state, and start time and ending time.
1.1.2  time-range
time-range time-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
undo time-range time-name [ start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 ]
View
Parameter
start-time: Start time of a periodic time range, in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 23:59.
end-time: End time of the periodic time range, in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 24:00. The end time must be greater than the start time.
days: Indicates on which day or days of the week the periodic time range is valid. You may specify multiple values, in words or in digits, separated by spaces, for this argument, but make sure that they do not overlap. These values can take one of the following forms:
l           A digit in the range 0 to 6, respectively for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
l           Week in words, that is, Mon, Tue, Wed, Thu, Fri, Sat, or Sun.
l           working-day for Monday through Friday.
l           off-day for Saturday and Sunday.
l           daily for seven days of a week.
from time1 date1: Indicates the start time and date of an absolute time range. The time1 argument specifies the time of the day in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 23:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format, where MM is the month of the year in the range 1 to 12, DD is the day of the month in the range 1 to 31, and YYYY is the year in the usual Gregorian calendar in the range 1970 to 2100. If not specified, the start time is the earliest time available from the system.
to time2 date2: Indicates the end time and date of the absolute time range. The format of the time2 argument is the same as that of the time1 argument, but its value ranges from 00:00 to 24:00. The format and value range of the date2 argument are the same as those of the date1 argument. The end time must be greater than the start time. If not specified, the end time is the maximum time available from the system.
Use the time-range command to create a time range.
Use the undo time-range command to remove a time range.
Note that:
l           Periodic time range created using the time-range time-name start-time to end-time days command. A time range thus created recurs periodically on the day or days of the week.
l           Absolute time range created using the time-range time-name { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. Unlike a periodic time range, a time range thus created does not recur. For example, to create an absolute time range that is active between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test from 00:00 01/01/2004 to 23:59 12/31/2004 command.
l           Compound time range created using the time-range time-name start-time to end-time days { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. A time range thus created recurs on the day or days of the week only within the specified period. For example, to create a time range that is active from 12:00 to 14:00 on Wednesdays between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test 12:00 to 14:00 wednesday from 00:00 01/01/2004 to 23:59 12/31/2004 command.
l           You may create individual time ranges identified with the same name. They are regarded as one time range whose active period is the result of ORing periodic ones, ORing absolute ones, and ANDing periodic and absolute ones.
l           If the start time is not specified, the time range starts on the earliest time available from the system and ends on the end date. If the end date is note specified, the time range is from the date of configuration till the largest time available from the system.
l            Up to 256 time ranges can be defined.
Example
# Create an absolute time range named test, setting it to become active since 00:00 on January 1, 2003.
[Sysname] time-range test from 0:0 2003/1/1
# Create a periodic time range named test, setting it to be active between 8:00 to 18:00 during working days.
[Sysname] time-range test 8:00 to 18:00 working-day
1.2  IPv4 ACL Configuration Commands
1.2.1  acl
acl number acl-number [ match-order { config | auto } ]
undo acl { number acl-number | all }
View
Parameter
number: Defines a numbered access control list (ACL).
acl-number: IPv4 ACL number in the range 2000 to 5999, where:
l           2000 to 2999 for basic IPv4 ACLs
l           3000 to 3999 for advanced IPv4 ACLs
l           4000 to 4999 for Ethernet frame header ACLs
l           5000 to 5999 for user-defined IPv4 ACLs
match-order: Sets the order in which ACL rules are matched. This keyword is not available for user-defined IPv4 ACLs.
l           config: Performs matching against rules in the order in which they are configured.
l           auto: Performs depth-first match.
all: All IPv4 ACLs.
Use the acl command to enter ACL view. If the ACL does not exist, it is created first.
Use the undo acl command to remove a specified or all IPv4 ACLs.
By default, the match order is config.
You can also use this command to modify the match order of an existing ACL but only before rules are added into it.
The match-order argument is unavailable for user-defined ACLs. Their match order can only be config.
Example
# Create IPv4 ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000]
1.2.2  description (for IPv4)
View
Basic IPv4 ACL view, advanced IPv4 ACL view, Ethernet frame header ACL view, user-defined IPv4 ACL view
Parameter
text: ACL description with up to 127 case-sensitive characters.
Use the description command to create an ACL description, to describe the purpose of the ACL for example.
Use the undo description command to remove the ACL description.
By default, no description is defined for an ACL.
Example
# Define the description of IPv4 ACL 2000.
[Sysname-acl-basic-2000] description This acl is used in eth 0
# Define the description of IPv4 ACL 3000.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] description This acl is used in eth 0
# Define the description of IPv4 ACL 4000.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] description This acl is used in eth 0
# Define the description of IPv4 ACL 5000.
[Sysname] acl number 5000
[Sysname-acl-user-5000] description This acl is used in eth 0
1.2.3  display acl
display acl { all | acl-number }
View
Parameter
all: All IPv4 ACLs.
Use the display acl command to display information about the specified or all IPv4 ACLs.
This command displays ACL rules in the order in which the system compares a packet against them.
Example
# Display information about IPv4 ACL 2001.
<Sysname> display acl 2001
Basic ACL  2001, 1 rule,
ACL's step is 5
 rule 5 permit source 1.1.1.1 0 (0 times matched)
 rule 5 comment This rule is used in eth 1
Table 1-2 Description on the fields of the display acl command
Basic ACL 2001
The displayed information is about the basic IPv4 ACL 2001.
1 rule
The ACL contains one rule.
ACLs step is 5
The rules in this ACL are numbered in steps of 5.
0 times matched
No match for this rule. Only ACL matches performed by software are counted.
The description of ACL rule 5 is “This rule is used in eth 1.”
1.2.4  reset acl counter
reset acl counter { all | acl-number }
View
Parameter
all: All IPv4 ACLs except for user-defined IPv4 ACLs.
acl-number: IPv4 ACL number in the range 2000 to 4999, where:
Use the reset acl counter command to clear statistics about specified or all IPv4 ACLs except for user-defined ACLs.
Example
# Clear statistics about IPv4 ACL 2001.
1.2.5  rule (basic ACL view)
rule [ rule-id ] { permit | deny } [ rule-string ]
undo rule rule-id [ fragment | logging | source | time-range ] *
View
Basic IPv4 ACL view
Parameter
I. Parameters for the rule command
rule-id: ACL rule number in the range 0 to 65534.
deny: Defines a deny statement to drop matched packets.
permit: Defines a permit statement to allow matched packets to pass.
rule-string: Matching criteria and other rule information defined by combinations of the parameters described in the following table.
Table 1-3 Parameters for basic IPv4 ACL rules
Parameter
Function
source { sour-addr sour-wildcard | any }
Specifies a source address.
The sour-addr sour-wildcard argument specifies a source IP address in dotted decimal notation. Setting the wildcard to a zero indicates a host address. The any keyword indicates any source IP address.
logging
Specifies to log matched packets.
The log provides information about ACL rule number, whether packets are permitted or dropped, upper layer protocol that IP carries, source/destination address, source/destination port number, and number of packets.
fragment
Indicates that the rule applies only to non-tail fragments.
Specifies the time range in which the rule takes effect.
The time-name argument specifies a time range name with 1 to 32 characters.
&  Note:
sour-wildcard is the complement of the wildcard mask of the source subnet mask. For example, you need to input 0.0.255.255 to specify the subnet mask 255.255.0.0.
II. Parameters for the undo rule command
rule-id: Number of an existing ACL rule. If no other parameters are specified, the entire ACL rule is removed; if other parameters are specified, only the involved information is removed.
fragment: Removes the settings that take effect on non-first fragments from the rule.
logging: Removes the logging setting.
source: Removes the source address setting.
time-range: Removes the time range setting.
&  Note:
Currently, the logging argument is not supported on H3C S3610 and S5510 Series Ethernet Switches.
Use the rule command to create an IPv4 ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an ACL rule or parameters from the rule.
Before you can delete a rule, you need to specify the rule ID. If you do not know the rule ID, you can view it by the display acl command.
When configuring a rule, note that:
l           You will fail to create or modify a rule if its permit/deny statement is exactly the same as another rule. In addition, if the ACL match order is set to auto rather than config, you cannot modify ACL rules.
l           When defining ACL rules, you are not necessarily to assign them IDs. The system can automatically assign rule IDs starting with 0 and increasing in certain rule numbering steps. A rule ID thus assigned is greater than the current highest rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the next rule will be numbered 30.
l           A newly defined rule cannot be identical with any existing rule, otherwise the rule cannot be successfully created (the system will prompt the rule already exists)
l           Rules created with the auto keyword specified are sorted according to the “depth first” principle regardless of the order they are created. However, the ID of each rule does not change.
Example
# Create a rule to deny packets with the source IP address 1.1.1.1.
[Sysname-acl-basic-2000] rule deny source 1.1.1.1 0
1.2.6  rule (advanced IPv4 ACL view)
rule [ rule-id ] { permit | deny } protocol [ rule-string ]
undo rule rule-id [ destination | destination-port | dscp | fragment | icmp-type | logging | precedence | reflective | source | source-port | time-range | tos ]*
View
Advanced IPv4 ACL view
Parameter
protocol: Protocol carried by IP. It can be a number in the range 1 to 255, or in words, gre, icmp, igmp, ip, ipinip, ospf, tcp, or udp.
rule-string: Match criteria and other rule information defined by combinations of the parameters described in the following table.
Table 1-4 Parameters for advanced IPv4 ACL rules
Parameter
Function
destination { dest-addr dest-wildcard | any }
Specifies a destination address.
The dest-addr dest-wildcard argument specifies a destination IP address in dotted decimal notation. Setting the dest-wildcard to a zero indicates a host address. The any keyword indicates any destination IP address.
precedence precedence
Specifies an IP precedence value.
The precedence argument can be a number in the range 0 to 7, or in words, routine, priority, immediate, flash, flash-override, critical, internet, or network.
tos tos
Specifies a ToS preference.
The tos argument can be a number in the range 0 to 15, or in words, max-reliability, max-throughput, min-delay, min-monetary-cost, or normal.
dscp dscp
Specifies a DSCP priority.
The dscp argument can be a number in the range 0 to 63, or in words, af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
logging
reflective
Specifies the rule to be reflective.
A rule with the reflective keyword can be defined only for TCP, UDP, or ICMP packets and its statement can only be permit.
fragment
Specifies the time range in which the rule can take effect.
The time-name argument comprises 1 to 32 characters.
&  Note:
The sour-wildcard/dest-wildcard argument is the complement of the wildcard mask of the source/destination subnet mask. For example, you need to input 0.0.255.255 to specify the subnet mask 255.255.0.0.
If the protocol argument is set to TCP or UDP, you may define the parameters in the following table in addition.
Table 1-5 TCP/UDP-specific parameters for advanced IPv4 ACL rules
Parameter
Function
source-port operator port1 [ port2 ]
Defines a UDP or TCP source port against which UDP or TCP packets are matched.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), and range (inclusive range).
port1, port2: TCP or UDP port number, represented by a number in the range 0 to 65535 or represented in words.
You need to define the port2 argument only when the range keyword is used.
destination-port operator port1 [ port2 ]
established
Defines the rule for TCP connection packets.
A keyword specific to TCP.
When using port name to specify TCP/UDP ports, you can define the following information.
Table 1-6 TCP/UDP port values
Protocol type
Value
TCP
CHARgen (19), bgp (179), cmd (514), daytime (13), discard (9), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), www (80)
UDP
biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (139), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), xdmcp (177)
If the protocol argument is set to ICMP, you may define the parameters in the following table.
Table 1-7 Parameters for advanced IPv4 ACL rules
Parameter
Function
icmp-type { icmp-type icmp-code | icmp-message }
Specifies the ICMP message type and code.
The icmp-type argument ranges from 0 to 255.
The icmp-code argument ranges from 0 to 255.
The icmp-message argument specifies a message name. For available ICMP messages, see Table 1-8.
The following table provides the ICMP messages that you can specify in advanced IPv4 ACL rules.
Table 1-8 ICMP messages and their codes
ICMP message
Code
echo
8
0
echo-reply
0
0
fragmentneed-DFset
3
4
host-redirect
5
1
host-tos-redirect
5
3
host-unreachable
3
1
information-reply
16
0
information-request
15
0
net-redirect
5
0
net-tos-redirect
5
2
net-unreachable
3
0
parameter-problem
12
0
port-unreachable
3
3
protocol-unreachable
3
2
reassembly-timeout
11
1
source-quench
4
0
source-route-failed
3
5
timestamp-reply
14
0
timestamp-request
13
0
ttl-exceeded
11
0
destination: Removes the destination address setting.
destination-port: Removes the destination port setting. This keyword is available only for TCP and UDP.
dscp: Removes the DSCP setting.
icmp-type: Removes the ICMP type and code settings. This keyword is available only for ICMP.
precedence: Removes the precedence setting.
reflective: Removes the reflective attribute of the rule. This keyword is only valid for TCP, UDP, and ICMP.
source-port: Removes the source port setting. This keyword is only valid for TCP and UDP.
tos: Removes the ToS setting.
&  Note:
Currently, the logging, reflective and established arguments are not supported on H3C S3610 and S5510 Series Ethernet Switches.
Use the rule command to define or modify an ACL rule. If the rule does not exist, it is created first.
Example
# Define a rule to permit the TCP packets to pass with the destination port 80 sent from 129.9.0.0 to 202.38.160.0.
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
1.2.7  rule (Ethernet frame header ACL view)
undo rule rule-id
View
Parameter
Table 1-9 Parameters for Ethernet frame header ACL rules
Parameter
Function
type type-code type-wildcard
Defines a link layer protocol.
The type-code argument is a 16-bit hexadecimal number indicating frame type. It is corresponding to the type-code field in Ethernet_II and Ethernet_SNAP frames.
The type-wildcard argument is a 16-bit hexadecimal number indicating the wildcard.
lsap lsap-code lsap-wildcard
Defines the DSAP and SSAP fields in the LLC encapsulation.
The lsap-code argument is a 16-bit hexadecimal number indicating frame encapsulation.
The lsap-wildcard argument is a 16-bit hexadecimal number indicating the wildcard of the LSAP code.
source-mac sour-addr source-mask
Specifies a source MAC address range.
The sour-addr and sour-mask arguments indicate a source MAC address and mask in xxxx-xxxx-xxxx format.
dest-mac dest-addr dest-mask
Specifies a destination MAC address range.
The dest-addr and dest-mask arguments indicate a destination MAC address and mask in xxxx-xxxx-xxxx format.
cos vlan-pri
Defines a 802.1p priority
The vlan-pri argument take a value in the range 0 to 7; or its equivalent in words, best-effort, background, spare, excellent-effort, controlled-load, video, voice, or network-management.
&  Note:
l      Currently, the lsap argument is not supported on H3C S3610 and S5510 Series Ethernet Switches.
l      When the type argument is used in defining a rule, if the result of ANDing the type-code and type-wildcard is the same as that of ADNing 8100 and type-wildcard, tagged packets will match this rule.
Use the rule command to create an ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an ACL rule.
Example
# Create a rule to deny packets with the 802.1p priority of 3.
[Sysname-acl-ethernetframe-4000] rule deny cos 3
1.2.8  rule (user-defined IPv4 ACL view)
rule [ rule-id ] { permit | deny } [ [  start | ipv4 | ipv6 | l2 | l4 ] { rule-string rule-mask offset }&<1-8> ] [ time-range time-name ]
undo rule rule-id
View
User-defined IPv4 ACL view
Parameter
start: Sets the offset from the beginning of the outmost header.
ipv4: Sets the offset from the beginning of the IPv4 header.
ipv6: Sets the offset from the beginning of the IPv6 header.
l2: Sets the offset from the beginning of the Layer 2 frame header.
l4: Sets the offset from the beginning of the Layer 4 header.
rule-string: Defines a match pattern in hexadecimal format. Its length must be a multiple of two.
rule-mask: Defines a match pattern mask in hexadecimal format. Its length must be the same as that of the match pattern.
offset: The offset in bytes at which the match operation begins.
&<1-8>: Indicates that up to eight match patterns can be defined in the rule.
time-range time-name: References the time range in which the rule can take effect. The time-name argument comprises 1 to 32 characters.
Use the rule command to create an ACL rule.
If you do not specify the offset type, start is adopted by default. That is, the offset begins from the outmost header.
l           If the ACL rule identified by the rule-id argument already exists, the settings specified in the rule command overwrite the corresponding settings of the existing rule. And the existing settings remain unchanged if the corresponding settings are not specified in the command.
l           If the ACL rule identified by the rule-id argument does not exist, you will create a new ACL rule.
l           The content of a modified or created ACL rule cannot be identical with the content of any existing ACL rules; otherwise the ACL rule modification or creation will fail, and the system prompts that the rule already exists.
l           If you do not specify a rule ID, a new rule will be defined and created, and the system will automatically assign the following ID to the rule: the smallest multiple of step-value that is greater than the largest ID of existing rules. For example, suppose the step-value is 5 and the largest ID of existing rules is 28; if you do not specify an ID when defining a rule, the system will automatically assign ID 30 to the rule.
l           For user-defined IPv4 ACLs, the match order can only be config.
Example
# Create a user-defined IPv4 ACL rule, to match ARP packets.
[Sysname] acl number 5005
[Sysname-acl-user-5005] rule permit l2 0806 ffff 12
1.2.9  rule comment (for IPv4)
rule rule-id comment text
undo rule rule-id comment
View
Parameter
text: ACL rule description with up to 127 case sensitive characters.
Use the rule comment command to create or modify an ACL rule description, for example to describe the purpose of the ACL rule or the parameters it contains.
Use the undo rule comment command to remove the ACL rule description.
By default, no rule description is created.
You will fail to do that if the specified rule does not exist.
For a rule without any description information, the rule comment command adds description information; for a rule already having description information, the rule comment command modifies its description information with the new one.
Example
# Create a rule in ACL 2000 and define the rule description.
[Sysname-acl-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-basic-2000] rule 0 comment This rule is used in eth 1
1.2.10  step (for IPv4)
step step-value
undo step
View
Parameter
step-value: ACL rule numbering step, in the range 1 to 20.
Use the step command to set a rule numbering step.
Use the undo step command to restore the default.
By default, rule numbering step is five.
When defining rules in an ACL, you do not necessarily assign them numbers. The system can do this automatically in steps. For example, if the default step applies, rules you created are automatically numbered 0, 5, 10, 15, and so on. One benefit of rule numbering step is that it allows you to insert new rules between existing ones as needed. For example, after creating four rules numbered 0, 5, 10, 15 in an ACL configured with the step of five, you can still insert a rule numbered 1.
Any step change can result in renumbering. For example, after you change the step in the above example from five to two, the rules are renumbered 0, 2, 4, 6, and 8.
Note that even if the current step is the default, performing the undo step command can still result in rule renumbering. Suppose that ACL 3001 adopts the default numbering step and contains two rules numbered 0 and 5. After you insert rule 1 and rule 3, the rules are numbered 0, 1, 3, and 5. If you perform the undo step command, they will be renumbered 0, 5, 10, and 15.
Example
# Set the rule numbering step to 2 for IPv4 ACL 2000.
[Sysname-acl-basic-2000] step 2
# Set the rule numbering step to 2 for IPv4 ACL 3000.
[Sysname-acl-adv-3000] step 2
# Set the rule numbering step to 2 for IPv4 ACL 4000.
[Sysname-acl-ethernetframe-4000] step 2
Chapter 2  IPv6 ACL Configuration Commands
2.1  IPv6 ACL Configuration Commands
2.1.1  acl ipv6
acl ipv6 number acl6-number [ match-order { config | auto } ]
undo acl ipv6 { number acl6-number | all }
View
Parameter
acl6-number: IPv6 ACL number. It is a value in one of the following ranges:
l           2000 to 2999 for basic IPv6 ACLs
l           3000 to 3999 for advanced IPv6 ACLs
all: All IPv6 ACLs.
Use the acl ipv6 command to enter IPv6 ACL view. If the ACL does not exist, it is created first.
Use the undo acl ipv6 command to remove a specified or all IPv6 ACLs.
You can also use this command to modify the match order of an existing IPv6 ACL but only before rules are added into it.
Example
# Create IPv6 ACL 2000.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000]
2.1.2  description (for IPv6)
View
Basic IPv6 ACL view, advanced IPv6 ACL view
Parameter
text: ACL description with up to case sensitive 127 characters.
Use the description command to create an IPv6 ACL description, to describe the purpose of the ACL for example.
Use the undo description command to remove the IPv6 ACL description.
Example
# Create a description for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] description This acl is used in eth 0
# Create a description for IPv6 ACL 3000.
[Sysname-acl6-adv-3000] description This acl is used in eth 0
2.1.3  display acl ipv6
display acl ipv6 { all | acl6-number }
View
Parameter
all: All IPv6 ACLs.
Use the display acl ipv6 command to display information about specified or all IPv6 ACLs.
Example
# Display information about IPv6 ACL 2001.
<Sysname> display acl ipv6 2001
Basic IPv6 ACL  2001, 1 rule,
ACL's step is 5
 rule 0 permit source 1::2/128 (0 times matched)
Table 2-1 Description on the fields of the display acl ipv6 command
Basic IPv6 ACL 2001
1 rule
ACL's step is 5
0 times matched
2.1.4  reset acl ipv6 counter
reset acl ipv6 counter { all | acl6-number }
View
Parameter
all: All basic and advanced IPv6 ACLs.
Use the reset acl ipv6 counter command to clear statistics about specified or all basic and advanced IPv6 ACLs.
Example
# Clear the statistics about IPv6 ACL 2001.
<Sysname> reset acl ipv6 counter 2001
2.1.5  rule (basic IPv6 ACL view)
undo rule rule-id [ fragment | logging | source | time-range ]*
View
Basic IPv6 ACL view
Parameter
rule-id: IPv6 ACL rule number in the range 0 to 65534.
Table 2-2 Match criteria and rule information for basic IPv6 ACL rules
Parameter
Function
source { ipv6-address prefix-length | ipv6-address/prefix-length | any }
Specifies a source IPv6 address.
The ipv6-address and prefix-length arguments specify a source IPv6 address, and its address prefix length in the range 1 to 128.
The any keyword indicates any IPv6 source address.
logging
The log provides information about ACL rule number, whether packets are permitted or denied, upper layer protocol that IP carries, source/destination address, source/destination port number, and number of packets.
fragment
rule-id: Number of an existing IPv6 ACL rule. If no other parameters are specified, the entire ACL rule is removed; if other parameters are specified, only the involved information is removed.
&  Note:
Use the rule command to create an IPv6 ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an IPv6 ACL rule or parameters from the rule.
Example
# Create rules in IPv6 ACL 2000, to permit packets with source address being 2030:5060::9050/64 to pass.
[Sysname-acl6-basic-2000] rule permit source 2030:5060::9050/64
2.1.6  rule (advanced IPv6 ACL view)
undo rule rule-id [ destination | destination-port | dscp | fragment | icmpv6-type | logging | source | source-port | time-range ] *
View
Advanced IPv6 ACL view
Parameter
protocol: Protocol carried on IP. It can be a number in the range 1 to 255, or in words, gre, icmpv6, ipv6, ipv6-ah, ipv6-esp, ospf, tcp, or udp.
Table 2-3 Match criteria and other rule information for advanced IPv6 ACL rules
Parameter
Function
source { source source-prefix | source/source-prefix | any }
The source and source-prefix arguments specify an IPv6 source address and its prefix length in the range 1 to 128.
destination { dest dest-prefix | dest/dest-prefix | any }
Specifies a destination IPv6 address.
The dest and dest-prefix arguments specify a destination IPv6 address, and its prefix length in the range 1 to 128.
The any keyword indicates any IPv6 destination address.
dscp dscp
Specifies a DSCP preference
logging
The log provides information about ACL rule number, whether packets are permitted or denied, protocol that IP carries, source/destination IPv6 address, source/destination port number, and number of packets.
fragment
If the protocol argument is set to TCP or UDP, you may define the parameters in the following table.
Table 2-4 TCP/UDP-specific match criteria for advanced IPv6 ACL rules
Parameter
Function
Defines the source port in the UDP/TCP packet.
The port1 and port2 arguments each specify a TCP or UDP port, represented by a number in the range 0 to 65535 or represented in words.
Defines the destination port in the UDP/TCP packet.
Table 2-5 TCP/UDP port values
Protocol type
Value
TCP
UDP
If the protocol argument is set to ICMPv6, you may define the parameters in the following table.
Table 2-6 ICMPv6-specific match criteria for advanced IPv6 ACL rules
Parameter
Function
icmpv6-type { icmpv6-type icmpv6-code | icmpv6-message }
Specifies the ICMPv6 message type and code
The icmpv6-type argument ranges from 0 to 255.
The icmpv6-code argument ranges from 0 to 255.
The icmpv6-message argument specifies a message name. For available ICMPv6 messages, see Table 2-7.
The following table provides the ICMPv6 messages that you can specify in advanced IPv6 ACL rules.
Table 2-7 Available ICMPv6 messages
ICMPv6 message
Code
redirect
137
0
echo-request
128
0
echo-reply
129
0
err-Header-field
4
0
frag-time-exceeded
3
1
hop-limit-exceeded
3
0
host-admin-prohib
1
1
host-unreachable
1
3
neighbor-advertisement
136
0
neighbor-solicitation
135
0
network-unreachable
1
0
packet-too-big
2
0
port-unreachable
1
4
router-advertisement
134
0
router-solicitation
133
0
unknown-ipv6-opt
4
2
unknown-next-hdr
4
1
destination: Removes the destination address setting from the rule.
destination-port: Removes the destination port setting from the rule. This keyword is available only for TCP and UDP.
dscp: Removes the DSCP setting from the rule.
icmpv6-type: Removes the ICMPv6 type and code settings from the rule. This keyword is available only for ICMPv6.
logging: Removes the logging setting from the rule.
source: Removes the source IPv6 address setting from the rule.
source-port: Removes the source port setting from the rule. This keyword is available only for TCP and UDP.
time-range: Removes the time range setting from the rule.
&  Note:
l      The protocol number you specified is only used to match the Next Header field of an IPv6 header instead of the real Layer 4 protocol number.
l      Currently, the logging argument is not supported on H3C S3610 and S5510 Series Ethernet Switches.
Example
# Create a rule in IPv6 ACL 3000 to permit the TCP packets with the source address 2030:5060::9050/64 to pass.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::9050/64
2.1.7  rule comment (for IPv6)
View
Parameter
text: IPv6 ACL rule description with up to 127 case sensitive characters.
Use the rule comment command to create or modify a description for an existing IPv6 ACL rule, for example to describe the purpose of the ACL rule or its attributes.
Use the undo rule comment command to remove the IPv6 ACL rule description.
Example
# Define a rule in IPv6 ACL 2000 and create a description for the rule.
[Sysname-acl6-basic-2000] rule 0 permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] rule 0 comment This rule is used in eth 1
# Define a rule in IPv6 ACL 3000 and create a description for the rule.
[Sysname-acl6-adv-3000] rule 0 permit tcp source 2030:5060::9050/64
[Sysname-acl6-adv-3000] rule 0 comment This rule is used in eth 1
2.1.8  step (for IPv6)
step step-value
undo step
View
Parameter
step-value: The step in which the rules in the IPv6 ACL is numbered, in the range 1 to 20.
Use the step command to set a rule numbering step for the IPv6 ACL.
By default, the rule numbering step is five.
When defining rules in an IPv6 ACL, you do not necessarily assign them numbers. The system can do this automatically in steps. For example, if the default step applies, rules you created are numbered 0, 5, 10, 15, and so on automatically.
One benefit of rule numbering step is that it allows you to insert new rules between existing ones as needed. For example, after creating four rules numbered 0, 5, 10, 15 in an ACL configured with the step of 5, you can still insert a rule numbered 1.
Any step change can result in renumbering. For example, after you change the step in the above example from 5 to 2, the rules are renumbered 0, 2, 4, 6, and 8.
Note that even if the current step is the default, performing the undo step command can still result in rule renumbering. Suppose that IPv6 ACL 3001 adopts the default numbering step and contains two rules numbered 0 and 5. After you insert rule 1 and rule 3, the rules are numbered 0, 1, 3, and 5. If you perform the undo step command, they will be renumbered 0, 5, 10, and 15.
Example
# Set the rule numbering step to 2 for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] step 2
# Set the rule numbering step to 2 for IPv6 ACL 3000.
[Sysname-acl6-adv-3000] step 2
Chapter 3  Flow Template Configuration Commands
3.1  Flow Template Configuration Commands
3.1.1  display flow-template
display flow-template { user-defined [ flow-template-name ] | interface [ interface-type interface-number ] }
View
Parameter
flow-template-name: Flow template name that comprises 1 to 31 characters.
interface-type interface-number: Specifies a port by its type and number.
Use the display flow-template command to display the configuration of the specified or all user-defined flow templates.
Executing the command without the flow-template-name argument will display configuration information about all user-defined flow templates. Executing the command without interface-type interface-number will display configuration information about flow templates on all ports.
Example
# Display the configuration of all user-defined flow templates.
<Sysname> display flow-template user-defined
user-defined flow template: basic
 name:f1, index:1, total reference counts:1
 fields: ip-protocol fragments ip-precedence
user-defined flow template: extend
 name:f2, index:2, total reference counts:0
 fields: start 22 33 l2 55 66
Table 3-1 Description on the fields of display flow-template
Type of the user-defined flow template: basic or extend
name
Name of the flow template
index
Index of the flow template
Total number of the times that the flow template is referenced.
fields
Fields included in the flow template
# Display information about the flow templates applied to all ports.
<Sysname> display flow-template interface
Interface: Ethernet1/0/1
Interface: Ethernet1/0/2
 name:f3, index:3, total reference counts:1
 fields: tos
Table 3-2 Description on the fields of display flow-template interface
Port where the flow template is referenced
name
index
Reference count for the flow templates
fields
3.1.2  flow-template
flow-template flow-template-name
undo flow-template
View
Ethernet port view, port group view
Parameter
Use the flow-template command to reference a flow template on current port.
Use the undo flow-template command to remove the referenced flow template from the port.
Note that on a port you can reference only one flow template.
&  Note:
l      The user-defined ACLs are used in conjunction with the extended user-defined flow template. When a port applies the extended flow template, you cannot apply policies including the basic and advanced ACLs on the port.
l      Before applying a user-defined template on a port, make sure the user-defined template is already configured. A port can be configured with only one flow template.
l      Before you can apply a flow template on a port, make sure the following functions are disabled on the port: 802.1x, cluster (NDP, NTDP, HABP, and Cluster), DHCP Snooping, port isolation, MAC+IP+port binding, selective Q-in-Q, and voice VLAN. And also, you are not recommended to use these functions after you apply a flow template on the port.
Example
# Reference flow template f1 on port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] flow-template f1
# Remove the referenced flow template from port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] undo flow-template
3.1.3  flow-template basic
flow-template flow-template-name basic { customer-cos | customer-vlan-id | dip | dipv6 | dmac | dport | dscp | ethernet-protocol | fragments | icmp-code | icmp-type | icmpv6-code | icmpv6-type | ip-precedence | ip-protocol | ipv6-dscp | ipv6-fragment | ipv6-protocol |service-cos | service-vlan-id | sip | sipv6 | smac | sport | tcp-flag | tos } *
undo flow-template { all | name flow-template-name }
View
Parameter
basic: Sets the type of the flow template to basic.
customer-cos: Customer 802.1p COS field, that is, VLAN priority.
customer-vlan-id: Customer VLAN ID.
dip: Destination IP address.
dipv6: Destination IPv6 address.
dmac: Destination MAC address.
dport: Destination service port.
dscp: Differentiated service code point (DSCP) field in the IP header.
ethernet-protocol: Protocol type field in the Ethernet frame header.
fragments: Fragments field in the IP header.
icmp-code: ICMP code field.
icmp-type: ICMP type field.
icmpv6-code: ICMPv6 code field.
Icmpv6-type: ICMPv6 type field.
ip-precedence: Specifies the precedence field in the IP header.
ip-protocol: Protocol type field in the IP header.
ipv6-dscp: Specifies the DSCP field in the IPv6 header.
ipv6-fragments: IPv6 fragments flag.
ipv6-protocol: Next header field in the IPv6 header.
service-cos: Specifies the service provider 802.1p COS field.
service-vlan-id: Service provider VLAN ID.
sip: Specifies the source IP address.
sipv6: Specifies the source IPv6 address.
smac: Specifies the source MAC address.
sport: Specifies the source service port.
tcp-flag: Specifies the flags field in the TCP header.
tos: Specifies the ToS field in the IP header.
all: Specifies to removes all flow templates.
Use the flow-template basic command to create a basic flow template.
Use the undo flow-template command to remove the specified or all flow templates.
When removing templates, make sure that they are not referenced on ports. Otherwise, your removing attempt will fail.
Example
# Create a basic flow template.
[Sysname] flow-template f1 basic dip smac
# Remove the flow template named f1.
[Sysname] undo flow-template name f1
# Remove all flow templates.
[Sysname] undo flow-template all
3.1.4  flow-template extend
flow-template flow-template-name extend { [ start ] offset-max-value length-max-value | ipv4 offset-max-value length-max-value | ipv6 offset-max-value length-max-value | l2 offset-max-value length-max-value | l4 offset-max-value length-max-value } *
View
Parameter
extend: Sets the type of the flow template to extend.
offset-max-value: The maximum offset relative to the referential location, in the range of 0 to 79.
length-max-value: The maximum comparing length. This maximum value of this argument is 16, that is, the maximum comparing length is 16 bytes.
all: Specifies to remove all flow templates.
Use the flow-template extend command to create an extended flow template.
For the extended flow template, the offset type is start by default if you do not specify any.
Example
# Create an extended flow template.
[Sysname] flow-template f2 extend l2 3 10 ipv4 5 8
