H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
07-MAC-IP-Port Binding Command
07-MAC-IP-Port Binding Command 37 KB
Chapter 1  MAC-IP-Port Binding Configuration Commands
1.1  MAC-IP-Port Binding Configuration Commands
1.1.1  display user-bind
display user-bind
View
Parameter
None
Use the display user-bind command to display the MAC-IP-port binding entries configured on all ports.
Example
# Display the MAC-IP-port binding entries configured on all ports.
<Sysname> display user-bind
The Following User address bind have been configured:
  Mac                   IP                    Port
  0007-0001-0005        200.201.202.205       Ethernet1/0/4
  0007-0001-0005        200.201.202.205       Ethernet1/0/5
  0007-0001-0005        200.201.202.205       Ethernet1/0/7
 -------------3 bind entries queried, 3 listed------------
1.1.2  display user-bind interface
display user-bind interface interface-list
View
Parameter
interface-list: Ethernet interface list, in the format of { interface-num [ to interface-num ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges. A port range defined without the to interface-type interface-num portion comprises only one port.
Use the display user-bind interface command to display the MAC-IP-port binding entries configured on specified ports.
Example
# Display the MAC-IP-port binding entries configured on port Ethernet 1/0/4.
<Sysname> display user-bind interface Ethernet 1/0/4
  Mac                   IP                    Port
 -------------1 bind entries queried, 1 listed------------
# Display the MAC-IP-port binding entries configured on ports Ethernet 1/0/4, Ethernet 1/0/5, and Ethernet 1/0/9.
<Sysname> display user-bind interface Ethernet 1/0/4 Ethernet 1/0/5 Ethernet 1/0/9
  Mac                   IP                    Port
  0007-0001-0005        200.201.202.205       Ethernet1/0/9
 -------------3 bind entries queried, 3 listed ------------
# Display the MAC-IP-port binding entries configured on ports Ethernet 1/1 to Ethernet 1/5 and ports Ethernet 1/0/10 to Ethernet 1/0/15.
<Sysname> display user-bind interface Ethernet 1/0/10 to Ethernet 1/0/15
  Mac                   IP                    Port
  0007-0001-0005        200.201.202.205       Ethernet1/0/10
  0007-0001-0005        200.201.202.205       Ethernet1/0/11
  0007-0001-0005        200.201.202.205       Ethernet1/0/12
1.1.3  display user-bind ip-addr
display user-bind ip-addr ip-address
View
Parameter
ip-address: IP address, in dotted decimal notation.
Use the display user-bind ip-addr command to display the MAC-IP-port binding entries configured on all ports for a specified IP address.
Example
# Display the MAC-IP-port binding entries configured on all ports for IP address 192.168.0.2.
<Sysname> display user-bind ip-addr 192.168.0.2
  Mac                   IP                    Port
  0007-0001-0001        192.168.0.2           Ethernet1/0/22
1.1.4  display user-bind mac-addr
display user-bind mac-addr mac-address
View
Parameter
mac-address: MAC address, in the format of H-H-H.
Use the display user-bind mac-addr command to display the MAC-IP-port binding entries configured on all ports for a specified MAC address.
Example
# Display the MAC-IP-port binding entries configured on all ports for MAC address 0001-0002-0003.
<Sysname> display user-bind mac-addr 0001-0002-0003
  Mac                   IP                    Port
  0001-0002-0003        1.1.1.1               Ethernet1/0/30
1.1.5  user-bind
user-bind mac-addr mac-address ip-addr ip-address [ interface interface-list ]
undo user-bind mac-addr mac-address ip-addr ip-address [ interface interface-list ]
View
System view/Ethernet port view
Parameter
interface interface-list: Ethernet interface list, in the format of { interface-num [ to interface-num ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges. A port range defined without the to interface-type interface-num portion comprises only one port.
Use the user-bind mac-addr ip-addr command to bind a MAC-IP address pair to multiple ports in system view or to the current port in Ethernet port view.
Use the undo user-bind mac-addr ip-addr command to remove the configuration.
Note:
l           The option interface interface-list is required in system view, but must not be included in Ethernet port view.
l           S3610&S5510 Series Ethernet Switches differentiate binding through “MAC address + IP address + port”. You can bind a MAC address with only one IP address and vice versa. However, you can bind a MAC-IP pair to multiple ports.
l           MAC-IP-port binding is on a per-port basis, that is, a port with MAC-IP-port binding enabled filters packets independently; it does not affect any other port.
l           The MAC address to be bound cannot be all 0s, all Fs, or a multicast address. The IP address can only be a Class A, Class B, or Class C address and can neither be 127.x.x.x nor 0.0.0.0.
Example
# Bind a MAC-IP pair to port Ethernet 1/0/2 in system view.
[Sysname] user-bind mac-addr 0001-0001-0001 ip-addr 192.168.0.1 interface Ethernet 1/0/2
