H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
02-VLAN Command
02-VLAN Command 216 KB
Table of Contents
Chapter 1 VLAN Configuration Commands. 1-1
1.1 VLAN Configuration Commands. 1-1
1.1.1 description. 1-1
1.1.2 display interface Vlan-interface. 1-2
1.1.3 display vlan. 1-3
1.1.4 interface Vlan-interface. 1-4
1.1.5 ip address. 1-5
1.1.6 shutdown. 1-6
1.1.7 vlan. 1-7
1.2 Port-Based VLAN Configuration Commands. 1-8
1.2.1 port 1-8
1.2.2 port access vlan. 1-9
1.2.3 port hybrid pvid vlan. 1-10
1.2.4 port hybrid vlan. 1-11
1.2.5 port link-type. 1-12
1.2.6 port trunk permit vlan. 1-13
1.2.7 port trunk pvid vlan. 1-14
1.3 Protocol-Based VLAN Configuration Commands. 1-15
1.3.1 display protocol-vlan interface. 1-15
1.3.2 display protocol-vlan vlan. 1-15
1.3.3 port hybrid protocol-vlan vlan. 1-16
1.3.4 protocol-vlan. 1-17
1.4 IP-Subnet-Based VLAN Configuration Commands. 1-20
1.4.1 display ip-subnet-vlan interface. 1-20
1.4.2 display ip-subnet-vlan vlan. 1-20
1.4.3 ip-subnet-vlan. 1-21
1.4.4 port hybrid ip-subnet-vlan vlan. 1-22
Chapter 2 Voice VLAN Configuration Commands. 2-1
2.1 Voice VLAN Configuration Commands. 2-1
2.1.1 display voice vlan oui 2-1
2.1.2 display voice vlan state. 2-2
2.1.3 voice vlan. 2-3
2.1.4 voice vlan aging. 2-4
2.1.5 voice vlan enable. 2-5
2.1.6 voice vlan mac-address. 2-5
2.1.7 voice vlan mode auto. 2-7
2.1.8 voice vlan security enable. 2-7
Chapter 3 GVRP Configuration Commands. 3-1
3.1 GARP Configuration Commands. 3-1
3.1.1 display garp statistics. 3-1
3.1.2 display garp timer 3-1
3.1.3 garp timer 3-2
3.1.4 garp timer leaveall 3-4
3.1.5 reset garp statistics. 3-4
3.2 GVRP Configuration Commands. 3-5
3.2.1 display gvrp statistics. 3-5
3.2.2 display gvrp status. 3-6
3.2.3 gvrp. 3-7
3.2.4 gvrp registration. 3-7
1.1.1  description
View
VLAN view/VLAN interface view
Parameter
text: A string that describes the current VLAN or VLAN interface (Space can be included), case sensitive.
l           Under VLAN view, this is a string of 1 to 32 characters, defaults to the VLAN ID of the current VLAN, for example, “VLAN 0001".
l           Under VLAN interface view, this is a string of 1 to 80 characters, defaults to the interface name of the current VLAN interface, for example, “Vlan-interface1 Interface”.
Use the description command to configure the descriptive string of the current VLAN or VLAN interface.
Use the undo description command to restore the default descriptive string of a specified VLAN or VLAN interface.
For a VLAN, the default descriptive string is the VLAN ID, for example, “VLAN 0001"; for a VLAN interface, the default descriptive string is the VLAN interface name, for example, “Vlan-interface1 Interface”
Example
# Assign a descriptive string “RESEARCH” for VLAN 1.
[Sysname] vlan 1
[Sysname-vlan1] description RESEARCH
# Assign a descriptive string “VLAN-INTERFACE-2” for VLAN interface 2
[Sysname-Vlan-interface2] description VLAN-INTERFACE-2
display interface Vlan-interface [ vlan-interface-id ]
View
Parameter
vlan-interface-id: VLAN interface ID.
Use the display interface vlan-interface command to display the information of a VLAN interface.
Execution of the command with the parameter included will display the information of a specified VLAN interface; otherwise, information on all created VLAN interfaces will be displayed.
Related command: interface Vlan-interface.
Example
# Display the information of VLAN-interface 2.
<Sysname> display interface vlan-interface 2
Vlan-interface2 current state: DOWN
Line protocol current state: DOWN
Description: Vlan-interface2 Interface
The Maximum Transmit Unit is 1500
Internet Address is 10.1.1.1/24 Primary
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e200-0001
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e200-0001
Table 1-1 Description on the fields of the display interface Vlan-interface interface
The physical state of a VLAN interface
The link layer protocol state of a VLAN interface
The description of a VLAN interface
The MTU of a VLAN interface
Internet Address
IP address of the VLAN interface. “Primary” indicates the address is the primary IP address of the current interface.
IPv4 outgoing frame format
Hardware Address
MAC address corresponding to a VLAN interface
IPv6 outgoing frame format
1.1.3  display vlan
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | static | reserved]
View
Parameter
vlan-id1: Displays information of a VLAN specified by the VLAN ID, which is in the range of 1 to 4,094.
vlan-id1 to vlan-id2: Displays the information of a range of VLANs specified by a VLAN ID range. vlan-id1 and vlan-id2 are VLAN IDs, in the range of 1 to 4094.
all: Displays all current VLAN information except for the reserved VLAN.
dynamic: Displays the information of dynamically created VLANs
static: Displays statically created VLAN information.
reserved: Displays information of the reserved VLANs. Protocol modules determine reserved VLANs according to function implementation, and reserved VLANs serve protocol modules. Reserved VLANs cannot be modified.
Use the display vlan command to display VLAN information.
Related command: vlan.
Example
# Display VLAN 2 information.
<Sysname> display vlan 2
 VLAN ID: 2
 VLAN Type: static
 Route interface: configured
 IP Address: 10.1.1.1
 Subnet Mask: 255.255.255.0
 Description: VLAN 0001
 Tagged   Ports: none
 Untagged Ports:
   Ethernet1/0/1  Ethernet1/0/2  Ethernet1/0/3
Table 1-2 Description on the fields of the display vlan command
VLAN ID
VLAN ID
VLAN Type
VLAN type (static or dynamic)
Route interface
Whether the VLAN interface is configured for the VLAN: not configured or configured
VLAN descriptive string
IP Address
IP address of the VLAN interface (not displayed if the VLAN interface has no IP address configured)
Subnet Mask
Subnet mask of the IP address (not displayed if the VLAN interface has no IP address configured)
Tagged Ports
Ports through which packets are forwarded with tags unchanged
Untagged Ports
Port through which packets are forwarded with tags stripped
interface Vlan-interface vlan-interface-id
undo interface Vlan-interface vlan-interface-id
View
Parameter
 vlan-interface-id: VLAN interface ID, in the range of 1 to 4,094.
Use the interface Vlan-interface command to enter the specified VLAN interface view. Use the undo interface Vlan-interface command to delete the specified VLAN interface. The VLAN interface must be created first before entering its view
Before creating a VLAN interface, make sure the corresponding VLAN has been created; otherwise, the VLAN interface cannot be created.
Related command: display interface Vlan-interface.
Example
# Create VLAN interface 2.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname] interface Vlan-interface 2
1.1.5  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
VLAN interface view
Parameter
ip-address: IP address of a VLAN interface, in dotted decimal format.
mask: Subnet mask that corresponds to the IP address of a VLAN interface, in dotted decimal format.
mask-length: Length of a sub-net mask, that is, the number of 1s in the subnet mask in binary notation.
sub: Indicates the address is a sub-IP address of the VLAN interface.
Use the ip address command to specify the IP address and subnet mask for a VLAN interface.
Use the undo ip address command to remove the IP address and sub-net mask for a VLAN interface.
By default, IP addresses of all VLAN interfaces are not configured.
An interface normally has one IP address. To enable a device to connect to multiple subnets, a maximum of 5 IP addresses can be configured on a VLAN interface, in which only one is the main IP address and all the rest are sub-IP addresses. Their relationship is illustrated as follows:
l           A newly configured main IP address will replace the original one, if there is one.
l           Execution of the undo ip address command without any parameter indicates that all IP addresses will be deleted from the VLAN interface.
l           Use the undo ip address ip-address { mask | mask-length } command to delete the main IP address.
l           Use the undo ip address ip-address { mask | mask-length } sub command to delete a sub-interface.
Note that before deletion of the main IP address you must first delete the sub-IP address.
Related command: display ip interface (refer to IP Address - IP Performance part).
Example
# Specify the IP address as 129.12.0.1, the sub-net mask as 255.255.255.0 for the VLAN interface 1.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
1.1.6  shutdown
shutdown
View
VLAN interface view
Parameter
None
Use the shutdown command to shut down a VLAN interface.
Use the undo shutdown command to bring up a VLAN interface.
By default, the VLAN interface is down if all ports in the VLAN are down, as long as one port in the VLAN is up, the VLAN interface will be up
You can use the undo shutdown command to bring up a VLAN interface after configurations of the related parameter and protocol. When there is a fault in a VLAN interface, you can use the shutdown command to shut down the interface and then bring it up using the undo shutdown command. In this way, the interface will probably resume.
Shutting down/bringing up a VLAN interface does not affect any Ethernet ports in the VLAN. The state of an Ethernet port does not change with the VLAN interface state.
Example
# Shut down the VLAN interface 2 and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
1.1.7  vlan
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
View
Parameter
vlan-id1: VLAN ID, in the range of 1 to 4,094. This parameter means creating/deleting a specified VLAN or entering the specified VLAN interface view.
vlan-id1 to vlan-id2: VLAN ID range. vlan-id1 and vlan-id2 are VLAN IDs in the range of 1 to 4,094, and vlan-id2 cannot be less than vlan-id1.
all: Creates or deletes all VLANs except for reserved VLANs.
Use the vlan command to create one or more VLANs.
Use the vlan vlan-id command to enter VLAN view. If the specified VLAN does not exist, the command creates the VLAN and enters its view.
Use the vlan vlan-id1 to vlan-id2 command to create a range of VLANs from vlan-id1 to vlan-id2 in a bulk, except for the reserved VLANs.
Use the undo vlan command to delete VLAN(s).
&  Note:
l      As the default VLAN, VLAN 1 cannot be created, or removed.
l      You cannot create/remove reserved VLANs that are reserved for specific function implementation.
l      A VLAN configured with QoS policies cannot be removed.
Related command: display vlan.
Example
# Enter the VLAN interface view of VLAN 1.
[Sysname] vlan 1
# Create VLAN 4 to VLAN 100.
[Sysname] vlan 4 to 100
Please wait............. Done.
1.2.1  port
port interface-list
undo port interface-list
View
VLAN interface view
Parameter
interface interface-list: Ethernet interface list, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges.
Use the port command to add one Access port or a group of Access ports to a VLAN. Use the undo port command to remove one Access port or a group of Access ports from a VLAN.
Note:
l           This command is only applicable to Access ports.
l           All ports have their default link type configured as Access, however, users can manually configure the port type. For more information, refer to port link-type.
Example
# Add the ports from Ethernet 1/0/1 to Ethernet 1/0/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port Ethernet 1/0/1 to Ethernet 1/0/3
port access vlan vlan-id
undo port access vlan
View
Ethernet port view/port group view
Parameter
vlan-id : VLAN ID, in the range of 1 to 4,094.
Use the port access vlan command to add the current Access port to a specified VLAN.
Use the undo port access vlan command to add the current Access port to the default VLAN.
After executing the undo vlan command on an Access port to remove the default VLAN, VLAN 1 will become the default VLAN.
Execution of the above command under Ethernet port view will apply the configurations to the current port only whereas under port group view will apply the configurations to all ports in the port group. (For related configurations on port group, refer to Port Correlation Configurations part).
Ensure the VLAN specified by the vlan-id parameter exists before issuing the above commands.
Example
# Add Ethernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-Ethernet1/0/1] port access vlan 3
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Parameter
Use the port hybrid pvid vlan command to configure the default VLAN ID of the Hybrid port.
Use the undo port hybrid pvid command to restore the default, VLAN 1.
The default VLAN ID of local Hybrid port must be consistent with that of the peer; otherwise, packets cannot be forwarded properly.
Execution of the undo vlan command on a Hybrid port to remove a default VLAN does not affect the default VLAN configurations. That is to say, a non-existent VLAN can still be a default VLAN.
Execution of the above commands under Ethernet port view will apply to the current port only whereas under port group view will apply to all ports in the port group view. (For related configurations on port group, refer to Port Correlation Configurations part)
Related command: port link-type.
Example
# Configure the default VLAN ID for the Hybrid port Ethernet 1/0/1 to be 100.
[Sysname-Ethernet1/0/1] port link-type hybrid
[Sysname-Ethernet1/0/1] port hybrid pvid vlan 100
undo port hybrid vlan vlan-id-list
View
Parameter
vlan-id-list: The range of VLANs that the Hybrid ports will be added to, vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id1 and vlan-id2 range from 1 to 4,094, and vlan-id2 cannot be smaller than vlan-id1. &<1-10> indicates that you can specify up to 10 VLANs or 10 VLAN ranges.
tagged: Specifies to tag the packets of the specified VLAN (s).
untagged: Specifies not to tag the packets of the specified VLAN(s).
Use the port hybrid vlan command to add the current Hybrid port to the specified VLAN(s).
Use the undo port hybrid vlan command to remove the current Hybrid port from the specified VLAN(s).
The Hybrid port may belong to multiple VLANs. Repetitive execution of the port hybrid vlan command will yield a set VLANs, to which the Hybrid port belongs.
Execution of the above commands in Ethernet port view will apply to the current port only whereas under port group view will apply to all ports in the port group. (For related configurations on port group, refer to Port Correlation Configuration part).
Example
# Add the Hybrid port Ethernet1/0/4 to VLAN 2, VLAN 4, and the range of VLANs from VLAN 50 to VLAN 100 (these VLANs all exist). Configure to keep the VLAN tags of all packets of these VLANs when the packets are sent from Ethernet1/0/4.
[Sysname] interface Ethernet 1/0/4
[Sysname-Ethernet1/0/4] port link-type hybrid
[Sysname-Ethernet1/0/4] port hybrid vlan 2 4 50 to 100 tagged
 Please wait... Done.
# Add Hybrid ports of port group 2 (including port Ethernet 1/0/1 to Ethernet 1/0/6) to VLAN 2. Packets are untagged.
[Sysname] vlan 2
[Sysname] port-group manual 2
[Sysname-port-group-manual-2] group-member Ethernet 1/0/1 to Ethernet 1/0/6
[Sysname-port-group-manual-2] port link-type hybrid
[Sysname-port-group-manual-2] port hybrid vlan 2 untagged
 Configuring Ethernet1/0/1... Done.
 Configuring Ethernet1/0/2... Done.
 Configuring Ethernet1/0/3... Done.
 Configuring Ethernet1/0/4... Done.
 Configuring Ethernet1/0/5... Done.
 Configuring Ethernet1/0/6... Done.
undo port link-type
View
Parameter
access: Configures the link type of a port as Access.
hybrid: Configures the link type of a port as Hybrid.
trunk: Configures the link type of a port as Trunk.
Use the port link-type command to configure the link type of a port.
Use the undo port link-type command to restore the default link type of a port, which is Access by default.
&  Note:
The Trunk and Hybrid ports cannot be converted to each other directly. You can convert either to the Access port, and then to the other type. For example, convert a Trunk port to an Access port, and then to a Hybrid port.
Example
# Configure Ethernet 1/0/1 to be a Trunk port.
[Sysname-Ethernet1/0/1] port link-type trunk
undo port trunk permit vlan { vlan-id-list | all }
View
Parameter
vlan-id-list: The range of VLANs that the Trunk ports will be added to, in the format of vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id1 and vlan-id2 range from 1 to 4,094 and vlan-id2 cannot be smaller than vlan-id1. &<1-10> indicates that you can specify up to 10 VLANs or VLAN ranges.
all: Adds the Trunk port to all VLANs.
Use the port trunk permit vlan command to add a Trunk port to a specified VLAN, a selection of VLANs, or all VLANs.
Use the undo port trunk permit vlan command to remove the Trunk port from a specified VLAN, a selection of VLANs, or all VLANs.
The Trunk port may belong to multiple VLANs. Repetitive execution of the port trunk permit vlan command will yield a set of vlan-id-list, to which the Trunk port belongs.
Execution of the above commands in Ethernet port view will apply to the current port only whereas under port group view will apply to all ports in the port group view. (For related configurations on port group, refer to Port Correlation Configuration part)
Example
# Configure the Trunk port Ethernet1/0/4 to permit packets of VLAN2, VLAN4, VLAN50 through VLAN100 (these VLANs already exist) to pass.
[Sysname-Ethernet1/0/4] port link-type trunk
[Sysname-Ethernet1/0/4] port trunk permit vlan 2 4 50 to 100
Please wait........... Done.
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Parameter
Use the port trunk pvid vlan command to configure the default VLAN ID for a Trunk port.
Use the undo port trunk pvid command to restore the default.
By default, the default VLAN on a Trunk port is VLAN 1.
Execution of the undo vlan command on a Trunk port to remove a default VLAN does not affect the default VLAN configurations. That is to say, a non-existent VLAN can still be a default VLAN.
Execution of the above commands in Ethernet port view will apply to the current port only whereas under port group view will apply to all ports in the port group view. (For related configurations on port group, refer to Port Correlation Configuration part).
You must configure the same default VLAN ID for the Trunk ports on the local and remote devices. Otherwise, packets of the default VLAN on the local end cannot be transmitted correctly to the remote end.
Example
# Configure the default VLAN ID for the Trunk port Ethernet 1/0/4 as 100.
[Sysname-Ethernet1/0/4] port trunk pvid vlan 100
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
View
Parameter
interface-type interface-number1: Specifies a port by its type and number.
interface-type interface-number1 to interface-type interface-number2: Specifies an port range.
all: Displays protocol information and protocol indexes of all ports.
Use the display protocol-vlan interface command to display protocol information and protocol index configured on the specified port(s).
Example
# Display the protocol information and protocol index configured on Ethernet 1/0/1.
<Sysname> display protocol-vlan interface Ethernet 1/0/1
Interface: Ethernet1/0/1
   VLAN ID   Protocol Index      Protocol Type
       2          0               ipv4
       2          3               at
display protocol-vlan vlan { vlan-id [ to vlan-id ] | all }
View
Parameter
vlan-id: VLAN ID, in the range of 1 to 4,094.
to: Specifies VLAN range, the value after this parameter must be greater than or equal to that before it.
all: Displays protocol information and protocol indexes of all VLANs..
Use the display protocol-vlan vlan command to display the protocol information and protocol index configured on the specified VLAN(s).
Example
# Display the protocol information and protocol index configured on all protocol-based-VLANs.
<Sysname> display protocol-vlan vlan all
VLAN ID:2
          0              ipv4
          3              at
 VLAN ID:3
          0              ipv4
          1              ipx snap
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo port hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
View
Parameter
protocol-index: The initial value of the protocol index, in the range of 0 to 11, automatically numbered according to the order in which protocols are associated with VLANs. Using the display protocol-vlan vlan all command can display the protocol index.
protocol-end: The last value of the protocol index, in the range of 0 to 11, must be greater than or equal to the initial value of the protocol index.
all: In the port hybrid protocol-vlan vlan command, the all keyword specifies to associate the current port with all protocol indexes of the specified protocol-based VLAN. In the undo port hybrid protocol-vlan command, the first all specifies to remove the associations between the current port and all protocol indexes of the specified protocol-based VLAN, and the second all specifies to remove the associations between the current port and all the protocol-based VLANs.
Use the port hybrid protocol-vlan vlan command to associate a port with a protocol-based VLAN.
Use the undo port hybrid protocol-vlan command to remove the association between the port and the protocol-based VLAN.
Execution of the above commands in Ethernet port view will apply the configurations to the current port only whereas under port group view will apply the configurations to all ports in the port group. (For related configurations on port group, refer to Port Correlation Configuration part).
Note that only the Hybrid port supports the above feature at the moment. Before issuing this command, ensure that the port has been added to the VLAN to be associated with and that the VLAN has been assigned with a protocol.
Related command: display protocol-vlan interface.
Example
# Associate the Hybrid port Ethernet 1/0/1 with protocol 0 to 4 in VLAN 3.
[Sysname-Ethernet1/0/1] port hybrid protocol-vlan vlan 3 0 to 4
1.3.4  protocol-vlan
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
View
VLAN view
Parameter
at: Specifies the AppleTalk based VLAN.
ipv4: Specifies the IPv4 based VLAN.
ipv6: Specifies the IPv6 based VLAN.
ipx: Specifies the IPX based VLAN. The keywords ethernetii, llc, raw, and snap are encapsulation formats.
mode: Specifies user-defined protocol templates for the VLAN, which could also have four encapsulation formats, namely, ethernetii, llc, raw, and snap.
ethernetii: Specifies the encapsulation format for Ethernet packets as ethernetii.
etype-id: Ethernet type of inbound packets, in the range of 0x0600 to 0xffff except for 0x0800, 0x86dd, 0x809b, and 0x8137.
llc: Specifies the encapsulation format for Ethernet packets to be llc.
dsap-id: Destination service access point, in the rang of 00 to ff.
ssap-id: Source service access point, in the rang of 00 to ff.
snap: Specifies the encapsulation format for Ethernet packets as snap.
etype-id: Ethernet type of inbound packets, in the range of 0x0600 to 0xffff, cannot be ipx snap under the snap encapsulation format.
protocol-index: The initial value of the protocol index, whose range varies by product. System will automatically assign an index if this parameter is not specified.
protocol-end: The last value of the protocol index, whose range varies by product and must be greater than or equal to the initial value of the protocol-index.
all: Specifies to remove all the configured protocol indexes.
  Caution:
l      If you specify some special values for both the dsap-id and ssap-id arguments when configuring the user-defined template for IIc encapsulation, the matched packets will take the same encapsulation format as some standard types of packets. For example, when dsap-id and ssap-id have the value of ff simultaneously, the encapsulation format will be the same as that of ipx raw packets; if they have the value of e0 simultaneously, the packet encapsulation format will be the same as that of ipx llc packets; if they have a value of aa simultaneously, the packet encapsulation format will be the same as that of snap packets. To prevent two commands from processing packets of the same protocol type in different ways, the system does not allow you to set both the dsap-id and ssap-id arguments to ff, e0, or aa.
l      Ensure that the etype keyword is not configured as 0x0800, 0x809b, 0x8137, or 0x86dd, as which are identical to protocol templates of ipv4, ipx, appletalk, and ipv6 respectively.
Use the protocol-vlan command to specify a protocol based VLAN.
Use the undo protocol-vlan command to remove the association between the VLAN and the protocol.
Related command: display protocol-vlan vlan.
&  Note:
You cannot configure a VLAN as a protocol based VLAN and voice VLAN at the same time.
Example
# Specify VLAN 3 as the IPv4 based VLAN.
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan ipv4
display ip-subnet-vlan interface { interface-list | all }
View
Parameter
interface-list: Ethernet interface list to be displayed, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where interface-type interface-number represents the port type and port number, &<1-10> indicates that you can specify up to 10 port ranges.
all: Specifies to display information about all the ports that have associated with the IP-subnet-based VLAN.
Use the display ip-subnet-vlan interface command to display the IP-subnet-based VLAN information and IP subnet ID on a specified port.
Example
# Display the IP-subnet-based VLAN information and IP subnet index on Ethernet 1/0/1.
<Sysname> display ip-subnet-vlan interface Ethernet 1/0/1
  VLAN ID   Subnet-Index    IP ADDRESS        NET MASK
    3          0           192.168.1.0      255.255.255.0
display ip-subnet-vlan vlan { vlan-id [ to vlan-id ] | all }
View
Parameter
all: Display the IP subnet information and IP subnet index of all VLAN(s)..
Use the display ip-subnet-vlan vlan command to display the IP subnet information and IP subnet index on the specified VLAN(s).
Example
# Display the IP subnet information of all VLANs.
<Sysname> display ip-subnet-vlan vlan all
VLAN ID:  3
 Subnet Index      IP Address        Subnet Mask
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
undo ip-subnet-vlan { ip-subnet-index [ to ip-subnet-end ] | all }
View
VLAN view
Parameter
ip-subnet-index: IP subnet Index, in the range of 0 to 11. This value can be configured by users, or automatically numbered by system based on the order in which the IP subnet or IP address is associated with the VLAN.
ip-address : Source IP address or network address based on which the subnet-based VLANs are classified, in dotted decimal format.
mask: The subnet mask of the source IP address or network address, in dotted decimal format with a default value of 255.255.255.0.
ip-subnet-end: The last index value of the IP subnet, in the range of 0 to 11, must be greater than or equal to the ip-subnet-index value.
all: Removes the associations between the current VLAN and all the IP subnet indexes.
Use the ip-subnet-vlan command to associate the current VLAN with a specified IP subnet or IP address.
Use the undo ip-subnet-vlan command to delete the association.
Note that the IP subnet or IP address cannot be a multicast network segment or a multicast address.
Related command: display ip-subnet-vlan vlan.
Example
# Configure VLAN 3 to be an IP-subnet-based VLAN. Associate it with the 192.168.1.0/24 network segment.
[Sysname] vlan 3
[Sysname-vlan3] ip-subnet-vlan ip 192.168.1.0 255.255.255.0
port hybrid ip-subnet-vlan vlan vlan-id
undo port hybrid ip-subnet-vlan { vlan vlan-id | all }
View
Parameter
all: Remove the associations between the current port and all the IP-subnet-based VLANs.
Use the port hybrid ip-subnet-vlan vlan command to associate the current Ethernet port with an IP-subnet-based VLAN.
Use the undo port hybrid ip-subnet-vlan vlan command to remove the association between the current Ethernet port and an IP-subnet-based VLAN.
Note that only the Hybrid port supports the above feature at the moment. Before issuing this command, ensure that the port has been added to the IP-subnet-based VLAN to be associated with. Otherwise, the port cannot be associated with the VLAN.
Related command: display ip-subnet-vlan interface.
Example
# Associate Ethernet 1/0/8 with the IP-subnet-based VLAN 2.
[Sysname] interface Ethernet 1/0/8
[Sysname-Ethernet1/0/8] port link-type hybrid
[Sysname-Ethernet1/0/8] port hybrid vlan 2 tagged
[Sysname-Ethernet1/0/8] port hybrid ip-subnet-vlan vlan 2
View
Parameter
None
Use the display voice vlan oui command to display the Organizationally Unique Identifier (OUI) address(es), the OUI address mask, and the descriptive string currently supported by system.
Related command: voice vlan, voice vlan enable.
&  Note:
As the first 24 bits of a MAC address (in binary format), an OUI address is a globally unique identifier assigned to a vendor by IEEE.
Example
# Display the OUI address of a voice VLAN.
<Sysname> display voice vlan oui
Oui Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3com phone
Table 2-1 Description on the fields of the display voice vlan oui command
Oui Address
OUI address currently supported by system
Mask
OUI address mask currently supported by system
Descriptive string of the OUI address currently supported by system
View
Parameter
None
Use the display voice vlan state command to display the voice VLAN configuration.
Related command: voice vlan and voice vlan enable.
Example
# Display the voice VLAN configurations.
<Sysname> display voice vlan state
 Voice VLAN status: ENABLE
 Voice VLAN ID: 2
 Voice VLAN security mode: Security
 Voice VLAN aging time: 1440 minutes
 Voice VLAN enabled port and its mode:
 PORT               MODE
 Ethernet1/0/2    MANUAL
 Ethernet1/0/3    MANUAL
 Ethernet1/0/4    MANUAL
 Ethernet1/0/5    AUTO
Table 2-2 Description on the fields of the display voice vlan state command
Voice VLAN status
The current voice VLAN status, that is, whether it is enabled or disabled.
Voice VLAN ID
ID of a voice VLAN
Security mode of a voice VLAN
Aging time of a voice VLAN
Current voice vlan enabled port and its mode
The port that is currently enabled with the voice VLAN feature and its working mode
PORT
port ID
MODE
Voice VLAN working mode: manual or automatic.
2.1.3  voice vlan
voice vlan vlan-id enable
undo voice vlan enable
View
Parameter
vlan-id: ID of the VLAN to be enabled with the voice VLAN feature, in the range of 2 to 4,094.
Use the voice vlan command to enable the voice VLAN feature globally.
Use the undo voice vlan enable command to disable the voice VLAN feature globally.
l           At one particular moment, only one VLAN of a certain device can have the voice VLAN feature enabled.
l           Ensure that a VLAN exists before enabling its voice VLAN feature and that it is not VLAN 1. Otherwise, the configurations will fail.
l           If a VLAN to be deleted has the voice VLAN feature enabled, you need to disable the voice VLAN feature first before deleting the VLAN.
Related command: display voice vlan state.
&  Note:
When configuring voice VLAN (under automatic mode and manual mode), note that:
l      Only one static VLAN of a device can have the voice VLAN feature enabled at a time. A dynamic VLAN cannot be configured as a voice VLAN.
l      You are not recommended to configure both voice VLAN and Q-in-Q (including basic Q-in-Q and selective Q-in-Q) on a device. Otherwise, the voice VLAN cannot work properly.
Example
# Enable the voice VLAN feature on VLAN 2(assuming that VLAN 2 already exists).
[Sysname] voice vlan 2 enable
voice vlan aging minutes
undo voice vlan aging
View
Parameter
minutes: Aging time of a voice VLAN, in the range of 5 to 43,200 minutes.
Use the voice vlan aging command to configure the aging time of a voice VLAN.
Use the undo voice vlan aging command to restore the aging time of a voice VLAN.
By default, the aging time of a voice VLAN is 1,440 minutes..
Under automatic mode, the system will decide whether to add a port to a voice VLAN based on the source MAC address contained in its inbound voice packets. After adding a port to the voice VLAN, the system will start the aging timer at the same time. If within the aging time, no voice packets is received from the port, it will be removed from the voice VLAN when the aging time expires.
Example
# Configure the aging time of the voice VLAN as 100 minutes.
[Sysname] voice vlan aging 100
voice vlan enable
View
Ethernet port view
Parameter
None
Use the voice vlan enable command to enable the voice VLAN feature on an Ethernet port.
Use the undo voice vlan enable command to disable the voice VLAN feature on an Ethernet port.
No voice VLAN is enabled on a port by default.
l           Under automatic mode, only The Trunk or Hybrid port can be configured with the voice VLAN feature. The Access port cannot be configured with this feature.
l           Before enabling the voice VLAN feature on a port, ensure that its is enabled globally first
l           Only after the voice VLAN feature is enabled under both system view and Ethernet port view will it functions properly.
Example
# Enable the voice VLAN feature on the port Ethernet 1/0/2.
[Sysname] interface Ethernet 1/0/2
[Sysname-Ethernet1/0/2] voice vlan enable
voice vlan mac-address oui mask oui-mask [ description text ]
undo voice vlan mac-address oui
View
Parameter
oui: MAC address, in the format of H-H-H, such as 1234-1234-1234.. The OUI address cannot be a broadcast, multicast or address of all 0s or all fs.
oui-mask: Valid length of the OUI address, represented in mask, in the format of H-H-H, from left to right are consecutive fs and 0s, for example, ffff-ff00-0000.
text: A case sensitive string that describes the OUI address, in the range of 1 to 30 characters.
Use the voice vlan mac-address command to make a specified OUI address identified by the voice VLAN.
Use the undo voice vlan mac-address command to remove an OUI address from being identified by the voice VLAN.
A maximum of 16 OUI addresses can be identified.
By default, there are 5 default OUI addresses, which can be removed or then added, as illustrated in the following table.
Table 2-3 Default OUI addresses
Number
OUI
1
0001-e300-0000
Siemens phone
2
0003-6b00-0000
Cisco phone
3
00d0-1e00-0000
Pingtel phone
4
00e0-7500-0000
Polycom phone
5
00e0-bb00-0000
3com phone
Related command: display voice vlan oui.
Example
# Set the OUI address to 00AA-BB00-0000, the OUI address mask to ffff-ff00-0000, and the descriptive string to ABC.
[Sysname] voice vlan mac-address 00aa-bb00-0000 mask ffff-ff00-0000 description ABC
# Display OUI address information.
[Sysname] display voice vlan oui
00aa-bb00-0000  ffff-ff00-0000  ABC
undo voice vlan mode auto
View
Ethernet port view
Parameter
None
Use the voice vlan mode auto command to configure the voice VLAN working mode on a port to be automatic.
Use the undo voice vlan mode auto command to configure the voice VLAN working mode on a port to be manual.
By default, the voice VLAN working mode is automatic.
Example
# Configure the voice VLAN working mode on Ethernet 1/0/1 to be manual.
[Sysname-Ethernet1/0/1] undo voice vlan mode auto
undo voice vlan security enable
View
Parameter
None
Use the voice vlan security enable command to enable the security mode for voice VLAN.
Use the undo voice vlan security enable command to disable the security mode for voice VLAN.
By default, the security mode of voice VLAN is enabled.
With the security mode enabled, voice packets with source MAC addresses not listed in the OUI address list will be filtered out on the incoming port. However, this feature does not affect other VLANs.
Example
# Disable the security mode of the voice VLAN.
[Sysname] undo voice vlan security enable
display garp statistics [ interface interface-list ]
View
Parameter
interface-list: Ethernet port list, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges. A port range defined without the to interface-type interface-number portion comprises only one port.
Use the display garp statistics command to display statistics about GARP for specified or all ports.
Example
# Display statistics about GARP for port Ethernet 1/0/1.
<Sysname> display garp statistics interface Ethernet1/0/1
        GARP statistics on port Ethernet1/0/1
        Number of GVRP Frames Received          : 0
        Number of GVRP Frames Transmitted       : 0
        Number of Frames Discarded              : 0
display garp timer [ interface interface-list ]
View
Parameter
Use the display garp timer command to display GARP timers.
Related command: garp timer, garp timer leaveall.
Example
# Display GARP timers on port Ethernet 1/0/1.
<Sysname> display garp timer interface Ethernet1/0/1
        GARP timers on port Ethernet1/0/1
                Garp Join Time          : 20 centiseconds
                Garp Leave Time         : 60 centiseconds
                Garp LeaveAll Time      : 1000 centiseconds
                Garp Hold Time          : 10 centiseconds
3.1.3  garp timer
garp timer { hold | join | leave } timer-value
undo garp timer { hold | join | leave }
View
Ethernet port view, port-group view
Parameter
hold: Sets the hold timer. When a GARP application entity receives the first registration request, it starts a hold timer and collects succeeding requests. When the timer expires, the entity sends all these requests in one Join message, thus saving bandwidth.
join: Sets the join timer. Each GARP application entity sends a Join message twice for reliability sake and uses a join timer to set the sending interval.
leave: Sets the leave timer. This timer starts upon receipt of a Leave message. When this timer expires, the GARP application entity removes attribute information as requested.
timer-value: Assigns a timer value, in centiseconds, and in steps of five. The default is 10 centiseconds for the hold timer, 20 centiseconds for the join timer, and 60 centiseconds for the leave timer.
Use the garp timer command to set a GARP timer for an Ethernet port or all ports in a port-group.
Use the undo garp timer command to restore the default value of a GARP timer.
The default value is 10 centiseconds for the hold timer, 20 centiseconds for the join timer, and 60 centiseconds for the leave timer.
Configured in Ethernet port view, the setting takes effect on the current port only; configured in port group view, the setting takes effect on all ports in the port group.
Note that:
l           The values of all timers must be multiples of five centiseconds, and the value range of a timer changes if that of other timers changes. If a timer value you want to set is beyond the configured range, you can set the value otherwise by changing the values of related timers.
l           If you want to restore the default value of all timers, follow this order: hold, join, leave, and leaveall.
l           When setting a GARP timer, make sure that the setting is in compliance with the dependencies shown in Table 3-1.
l           The undo garp timer command will not take effect if the default setting of the timer does not satisfy the dependencies shown in Table 3-1.
Table 3-1 Dependencies of GARP timers
Timer
Lower limit
Upper limit
Hold
10 centiseconds
Not greater than half of the join timer setting
Join
Not less than two times the hold timer setting
Less than half of the leave timer setting
Leave
Greater than two times the join timer setting
Less than the leaveall timer setting
Leaveall
Greater than the leave timer setting
32,765 centiseconds
Related command: display garp timer.
Example
# Set the join timer to 25 centiseconds on Ethernet1/0/1 (assume that both hold and leave timers use the default value).
[Sysname-Ethernet1/0/1] garp timer join 25
garp timer leaveall timer-value
undo garp timer leaveall
View
Parameter
timer-value: Sets a Leaveall timer value in the range 65 to 32,765 centiseconds in steps of 5. This value must be greater than the leave timer value.
Use the garp timer leaveall command to set the leaveall timer.
Use the undo garp timer leaveall command to restore the default leaveall timer. This may fail if the default is less than the current leave timer value.
By default, the leaveall timer is 1000 centiseconds.
A leaveall timer starts upon the start of a GARP application entity. When this timer expires, the entity sends a LeaveAll message so that other entities can re-register its attribute information and starts another leaveall timer at the same time.
A GARP application entity may send LeaveAll messages at the interval set by its LeaveAll timer or the leaveall timer of another GARP application entity on the network, whichever is smaller.
Example
# Set the leaveall timer to 100 centiseconds (assume the leave timer is set to 60 centiseconds).
[Sysname] garp timer leaveall 100
reset garp statistics [ interface interface-list ]
View
Parameter
Use the reset garp statistics command to clear statistics about GARP on the specified or all ports.
Related command: display gvrp statistics.
Example
# Clear statistics about GARP on all ports.
<Sysname> reset garp statistics
display gvrp statistics [ interface interface-list ]
View
Parameter
Use the display gvrp statistics command to display statistics about GVRP for specified or all trunk ports.
Note that:
l           Without interface interface-list specified, this command displays the GVRP statistics on all trunk ports.
l           With interface interface-list specified, this command displays the GVRP statistics on the specified trunk port.
Example
# Display statistics about GVRP for trunk port Ethernet 1/0/1.
<Sysname> display gvrp statistics interface Ethernet1/0/1
        GVRP statistics on port Ethernet1/0/1
                GVRP Status                     : Enabled
                GVRP Running                    : YES
                GVRP Failed Registrations       : 0
                GVRP Last Pdu Origin            : 0000-0000-0000
                GVRP Registration Type          : Normal
Table 3-2 Description on the fields of the display gvrp statistics command
GVRP Status
Indicates the state of GVRP is enabled or disabled.
GVRP Running
Indicates whether GVRP is running.
Indicates the number of GVRP registration failures
Indicates the source MAC address in the last GVRP PDU.
Indicates the GVRP registration type on the port
display gvrp status
View
Parameter
None
Use the display gvrp status command to display the global enable/disable state of GVRP.
Example
# Display the global GVRP enable/disable state.
<Sysname> display gvrp status
GVRP is enabled
3.2.3  gvrp
gvrp
undo gvrp
View
System view, Ethernet port view, port-group view
Parameter
None
Use the gvrp command to enable GVRP globally, on a port, or on all ports in a port-group.
Use the undo gvrp command to disable GVRP globally, on a port, or on all ports in a port group.
By default, GVRP is disabled.
Note that the port where you enable GVRP must be a trunk, and before doing that you must enable GVRP globally.
Related command: display gvrp status.
Example
# Enable GVRP globally.
[Sysname] gvrp
GVRP is enabled globally.
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
Ethernet interface view, port-group view
Parameter
fixed: Sets the registration type to fixed.
forbidden: Sets the registration type to forbidden.
normal: Sets the registration type to normal.
Use the gvrp registration command to configure the GVRP registration type on a port or all ports in a port-group.
Use the undo gvrp registration command to restore the default GVRP registration type on a port or all ports in a port-group.
The default GVRP registration type is normal.
If configured in Ethernet port view, the setting takes effect on the current port only; if configured in port group view, the setting takes effect on all ports in the port group.
GVRP provides the following three registration types on a port:
l           Normal –– Enables a port to dynamically register/deregister VLANs, and to propagate both dynamic and static VLAN information.
l           Fixed –– Disables the port to dynamically register VLANs or propagate dynamic VLAN information, but allows the port to propagate static VLAN information. A trunk port with fixed registration type thus allows only manually configured VLANs to pass through even though it is configured to carry all VLANs.
l           Forbidden –– Disables the port to dynamically register VLANs, and to propagate VLAN information except for VLAN 1. A trunk port with forbidden registration type thus allows only VLAN 1 to pass through even though it is configured to carry all VLANs.
Note that this command is only available on trunk ports.
Example
# Set the GVRP registration type to fixed on port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] port trunk permit vlan all
[Sysname-Ethernet1/0/1] gvrp registration fixed
