H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
HomeSupportSwitchesS3610[S5510] SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 0001-(V1.02)
10-IPv4 Routing Command
10-IPv4 Routing Command 908 KB
Table of Contents
Chapter 1 Static Route Configuration Commands. 1-1
1.1 Static Route Configuration Commands. 1-1
1.1.1 delete static-routes all 1-1
1.1.2 ip route-static. 1-2
1.1.3 ip route-static default-preference. 1-3
Chapter 2 RIP Configuration Commands. 2-1
2.1 RIP Configuration Commands. 2-1
2.1.1 checkzero. 2-1
2.1.2 default cost 2-2
2.1.3 default-route originate. 2-2
2.1.4 display rip. 2-3
2.1.5 display rip database. 2-5
2.1.6 display rip interface. 2-6
2.1.7 display rip route. 2-7
2.1.8 filter-policy export 2-9
2.1.9 filter-policy import 2-10
2.1.10 host-route. 2-11
2.1.11 import-route. 2-12
2.1.12 maximum load-balancing. 2-13
2.1.13 network. 2-14
2.1.14 peer 2-14
2.1.15 preference. 2-15
2.1.16 reset rip statistics. 2-16
2.1.17 rip. 2-16
2.1.18 rip authentication-mode. 2-17
2.1.19 rip input 2-18
2.1.20 rip metricin. 2-19
2.1.21 rip metricout 2-19
2.1.22 rip mib-binding. 2-20
2.1.23 rip output 2-21
2.1.24 rip poison-reverse. 2-21
2.1.25 rip split-horizon. 2-22
2.1.26 rip summary-address. 2-23
2.1.27 rip version. 2-23
2.1.28 silent-interface. 2-26
2.1.29 summary. 2-26
2.1.30 timers. 2-27
2.1.31 validate-source-address. 2-28
2.1.32 version. 2-29
Chapter 3 OSPF Configuration Commands. 3-1
3.1 OSPF Configuration Commands. 3-1
3.1.1 abr-summary. 3-1
3.1.2 area. 3-2
3.1.3 asbr-summary. 3-3
3.1.4 authentication-mode. 3-4
3.1.5 bandwidth-reference. 3-5
3.1.6 default 3-5
3.1.7 default-cost 3-6
3.1.8 default-route-advertise. 3-7
3.1.9 description. 3-8
3.1.10 display ospf abr-asbr 3-9
3.1.11 display ospf asbr-summary. 3-10
3.1.12 display ospf brief 3-11
3.1.13 display ospf cumulative. 3-14
3.1.14 display ospf error 3-16
3.1.15 display ospf interface. 3-18
3.1.16 display ospf lsdb. 3-19
3.1.17 display ospf nexthop. 3-22
3.1.18 display ospf peer 3-23
3.1.19 display ospf peer statistics. 3-25
3.1.20 display ospf request-queue. 3-26
3.1.21 display ospf retrans-queue. 3-27
3.1.22 display ospf routing. 3-28
3.1.23 display ospf vlink. 3-30
3.1.24 Enable log. 3-31
3.1.25 filter import/export 3-32
3.1.26 filter-policy export 3-32
3.1.27 filter-policy import 3-33
3.1.28 host-advertise. 3-34
3.1.29 import-route. 3-35
3.1.30 log-peer-change. 3-36
3.1.31 lsa-arrival-interval 3-37
3.1.32 lsa-generation-interval 3-38
3.1.33 lsdb-overflow-limit 3-38
3.1.34 maximum load-balancing. 3-39
3.1.35 maximum-routes. 3-40
3.1.36 network. 3-40
3.1.37 nssa. 3-41
3.1.38 opaque-capability enable. 3-42
3.1.39 ospf 3-43
3.1.40 ospf authentication-mode. 3-43
3.1.41 ospf cost 3-45
3.1.42 ospf dr-priority. 3-46
3.1.43 ospf mib-binding. 3-47
3.1.44 ospf mtu-enable. 3-47
3.1.45 ospf network-type. 3-48
3.1.46 ospf timer dead. 3-49
3.1.47 ospf timer hello. 3-50
3.1.48 ospf timer poll 3-51
3.1.49 ospf timer retransmit 3-51
3.1.50 ospf trans-delay. 3-52
3.1.51 peer 3-53
3.1.52 preference. 3-54
3.1.53 reset ospf counters. 3-55
3.1.54 reset ospf process. 3-55
3.1.55 reset ospf redistribution. 3-56
3.1.56 rfc1583 compatible. 3-56
3.1.57 silent-interface. 3-57
3.1.58 snmp-agent trap enable ospf 3-58
3.1.59 spf-schedule-interval 3-59
3.1.60 stub. 3-60
3.1.61 stub-router 3-61
3.1.62 vlink-peer 3-61
Chapter 4 IS-IS Configuration Commands. 4-1
4.1 IS-IS Configuration Commands. 4-1
4.1.1 area-authentication-mode. 4-1
4.1.2 auto cost enable. 4-2
4.1.3 bandwidth-reference. 4-3
4.1.4 circuit-cost 4-4
4.1.5 cost-style. 4-4
4.1.6 default-route-advertise. 4-5
4.1.7 display isis brief 4-6
4.1.8 display isis interface. 4-8
4.1.9 display isis license. 4-10
4.1.10 display isis lsdb. 4-12
4.1.11 display isis mesh-group. 4-13
4.1.12 display isis name-table. 4-14
4.1.13 display isis peer 4-15
4.1.14 display isis route. 4-16
4.1.15 display isis spf-log. 4-18
4.1.16 display isis statistics. 4-19
4.1.17 domain-authentication-mode. 4-22
4.1.18 filter-policy export 4-23
4.1.19 filter-policy import 4-24
4.1.20 flash-flood. 4-25
4.1.21 ignore-lsp-checksum-error 4-25
4.1.22 import-route. 4-26
4.1.23 import-route isis level-2 into level-1. 4-28
4.1.24 isis. 4-29
4.1.25 isis authentication-mode. 4-30
4.1.26 isis circuit-level 4-31
4.1.27 isis circuit-type. 4-32
4.1.28 isis cost 4-33
4.1.29 isis dis-name. 4-33
4.1.30 isis dis-priority. 4-34
4.1.31 isis enable. 4-35
4.1.32 isis mesh-group. 4-36
4.1.33 isis small-hello. 4-37
4.1.34 isis timer csnp. 4-38
4.1.35 isis timer hello. 4-39
4.1.36 isis timer holding-multiplier 4-40
4.1.37 isis timer lsp. 4-41
4.1.38 isis timer retransmit 4-42
4.1.39 is-level 4-43
4.1.40 is-name. 4-44
4.1.41 is-name map. 4-44
4.1.42 is-snmp-traps enable. 4-45
4.1.43 log-peer-change. 4-45
4.1.44 lsp-fragments-extend. 4-46
4.1.45 lsp-length originate. 4-47
4.1.46 lsp-length receive. 4-48
4.1.47 maximum load-balancing. 4-48
4.1.48 network-entity. 4-49
4.1.49 preference. 4-50
4.1.50 reset isis all 4-51
4.1.51 reset isis peer 4-51
4.1.52 set-overload. 4-52
4.1.53 spf-slice-size. 4-53
4.1.54 summary. 4-54
4.1.55 timer lsp-generation. 4-55
4.1.56 timer lsp-max-age. 4-56
4.1.57 timer lsp-refresh. 4-57
4.1.58 timer spf 4-58
4.1.59 virtual-system.. 4-59
Chapter 5 BGP Configuration Commands. 5-1
5.1 BGP Configuration Commands. 5-1
5.1.1 aggregate. 5-1
5.1.2 balance. 5-2
5.1.3 bestroute as-path-neglect 5-3
5.1.4 bestroute compare-med. 5-4
5.1.5 bestroute med-confederation. 5-4
5.1.6 bgp. 5-5
5.1.7 compare-different-as-med. 5-6
5.1.8 confederation id. 5-6
5.1.9 confederation nonstandard. 5-7
5.1.10 confederation peer-as. 5-8
5.1.11 dampening. 5-9
5.1.12 default ipv4-unicast 5-10
5.1.13 default local-preference. 5-11
5.1.14 default med. 5-11
5.1.15 default-route imported. 5-12
5.1.16 display bgp group. 5-13
5.1.17 display bgp network. 5-14
5.1.18 display bgp paths. 5-15
5.1.19 display bgp peer 5-16
5.1.20 display bgp routing-table. 5-18
5.1.21 display bgp routing-table as-path-acl 5-20
5.1.22 display bgp routing-table cidr 5-21
5.1.23 display bgp routing-table community. 5-22
5.1.24 display bgp routing-table community-list 5-23
5.1.25 display bgp routing-table dampened. 5-23
5.1.26 display bgp routing-table dampening parameter 5-24
5.1.27 display bgp routing-table different-origin-as. 5-25
5.1.28 display bgp routing-table flap-info. 5-26
5.1.29 display bgp routing-table peer 5-27
5.1.30 display bgp routing-table regular-expression. 5-28
5.1.31 display bgp routing-table statistic. 5-29
5.1.32 ebgp-interface-sensitive. 5-30
5.1.33 filter-policy export 5-30
5.1.34 filter-policy import 5-31
5.1.35 group. 5-32
5.1.36 import-route. 5-33
5.1.37 log-peer-change. 5-34
5.1.38 network. 5-34
5.1.39 peer advertise-community. 5-35
5.1.40 peer advertise-ext-community. 5-36
5.1.41 peer allow-as-loop. 5-37
5.1.42 peer as-number 5-37
5.1.43 peer as-path-acl 5-38
5.1.44 peer capability-advertise conventional 5-39
5.1.45 peer capability-advertise route-refresh. 5-39
5.1.46 peer connect-interface. 5-40
5.1.47 peer default-route-advertise. 5-41
5.1.48 peer description. 5-42
5.1.49 peer ebgp-max-hop. 5-42
5.1.50 peer enable. 5-43
5.1.51 peer fake-as. 5-44
5.1.52 peer filter-policy. 5-44
5.1.53 peer group. 5-45
5.1.54 peer ignore. 5-46
5.1.55 peer ip-prefix. 5-47
5.1.56 peer keep-all-routes. 5-47
5.1.57 peer log-change. 5-48
5.1.58 peer next-hop-local 5-49
5.1.59 peer password. 5-49
5.1.60 peer preferred-value. 5-50
5.1.61 peer public-as-only. 5-51
5.1.62 peer reflect-client 5-52
5.1.63 peer route-limit 5-53
5.1.64 peer route-policy. 5-53
5.1.65 peer route-update-interval 5-54
5.1.66 peer substitute-as. 5-55
5.1.67 peer timer 5-56
5.1.68 preference. 5-56
5.1.69 reflect between-clients. 5-57
5.1.70 reflector cluster-id. 5-58
5.1.71 refresh bgp. 5-59
5.1.72 reset bgp. 5-60
5.1.73 reset bgp dampening. 5-60
5.1.74 reset bgp flap-info. 5-61
5.1.75 reset bgp ipv4 all 5-61
5.1.76 router-id. 5-62
5.1.77 summary automatic. 5-63
5.1.78 synchronization. 5-63
5.1.79 timer 5-64
Chapter 6 Routing Policy Configuration Commands. 6-1
6.1 Common Routing Policy Configuration Commands. 6-1
6.1.1 apply as-path. 6-1
6.1.2 apply comm-list delete. 6-2
6.1.3 apply community. 6-3
6.1.4 apply cost 6-4
6.1.5 apply cost-type. 6-4
6.1.6 apply extcommunity. 6-5
6.1.7 apply isis. 6-6
6.1.8 apply local-preference. 6-7
6.1.9 apply origin. 6-7
6.1.10 apply preference. 6-8
6.1.11 apply preferred-value. 6-9
6.1.12 apply tag. 6-9
6.1.13 display ip as-path-acl 6-10
6.1.14 display ip community-list 6-11
6.1.15 display ip extcommunity-list 6-12
6.1.16 display route-policy. 6-12
6.1.17 if-match as-path. 6-13
6.1.18 if-match community. 6-14
6.1.19 if-match cost 6-15
6.1.20 if-match extcommunity. 6-16
6.1.21 if-match interface. 6-16
6.1.22 if-match route-type. 6-17
6.1.23 if-match tag. 6-18
6.1.24 ip as-path-acl 6-19
6.1.25 ip community-list 6-20
6.1.26 ip extcommunity-list 6-21
6.1.27 route-policy. 6-22
6.2 IPv4 Routing Policy Configuration Commands. 6-23
6.2.1 apply ip-address next-hop. 6-23
6.2.2 display ip ip-prefix. 6-24
6.2.3 if-match acl 6-25
6.2.4 if-match ip. 6-26
6.2.5 if-match ip-prefix. 6-27
6.2.6 ip ip-prefix. 6-27
6.2.7 reset ip ip-prefix. 6-29
Chapter 7 GR Configuration Commands. 7-1
7.1 GR Configuration Commands. 7-1
7.1.1 display isis graceful-restart status. 7-1
7.1.2 enable link-local-signaling. 7-2
7.1.3 enable out-of-band-resynchronization. 7-3
7.1.4 graceful-restart (BGP view) 7-3
7.1.5 graceful-restart (IS-IS view) 7-4
7.1.6 graceful-restart (OSPF view) 7-4
7.1.7 graceful-restart help. 7-5
7.1.8 graceful-restart interval 7-6
7.1.9 graceful-restart suppress-sa. 7-7
7.1.10 graceful-restart timer restart 7-8
7.1.11 graceful-restart timer wait-for-rib. 7-8
7.1.12 reset ospf process graceful-restart 7-9
&  Note:
The term “router” or a router icon used throughout this document represents a generic router or an Ethernet switch running routing protocols.
View
Parameter
None
Use the delete static-routes all command to delete all static routes.
When you use this command to delete static routes, the system will prompt you to confirm the operation before all the configured static routes.
Related command: ip route-static and display ip routing-table.
Example
# Delete all static routers on the router.
[Sysname] delete static-routes all
This will erase all ipv4 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:y
ip route-static ip-address { mask | mask-length } interface-type interface-number [ preference preference ] [ tag tag-value ] [ description description-text ]
undo ip route-static ip-address { mask | mask-length } interface-type interface-number [ preference preference ]
View
Parameter
ip-address: Destination IP address of the static route, in dotted decimal notation.
mask: Mask of the corresponding IP address, in dotted decimal notation.
mask-length: Mask length. Because a 32-bit mask must contain contiguous 1’s, a dotted decimal mask can appear in the form of mask length.
interface-type interface-number: Specifies the output interface by its type and number. If the output interface is a broadcast interface, such as a virtual template or a VLAN interface, the next hop address must be specified.
preference preference: Specifies the preference of the static route, which is in the range of 1 to 255 and defaults to 60.
tag tag-value: Sets the tag value of the static route, which is in the range of 1 to 4294967295 . The default tag value of the static route is 0.
description description-text: Sets the description information of the static route, which consists of 1 to 60 characters, including special characters like space, but excluding “?”.
Use the ip route-static command to configure a unicast static route.
Use the undo ip route-static command to delete a unicast static route.
When configuring a unicast static route, note that:
1)         If the destination IP address and the mask are both 0.0.0.0, the configured route is a default route. If routing table searching fails, the router will use the default route for packet forwarding.
2)         Different route management policies can be implemented for different route preference configurations. For example, specifying the same preference for different routes to the same destination address enables load sharing, while specifying different preferences for these routes enables route backup.
3)         When configuring a static route, you can specify the output interface or the next hop address based on the actual requirement. Note that the next hop address must not be the IP address of the local interface; otherwise, the route configuration will not take effect. When specifying the output interface, note that:
l           For a NULL0 or loopback interface, if the output interface has already been configured, there is no need to configure the next hop address.
l           It is not recommended to specify a broadcast interface (such as an Ethernet interface, virtual template, or VLAN interface) as the output interface for a static route, because a broadcast interface may have multiple next hops. If you have to do so, you must specify the corresponding next hop of the interface at the same time.
Related command: display ip routing-table and ip route-static default-preference.
Example
# Configure the next hop of the default route as 129.102.0.2.
[Sysname] ip route-static 0.0.0.0 0.0.0.0 129.102.0.2
# Configure the preference value of the static route as 50
[Sysname]ip route-static 3.3.3.3 24 4.4.4.4 preference 50
# Specify the description of the static route as "for internet & intranet".
[Sysname] ip route-static 3.3.3.3 24 4.4.4.4 description for internet & intranet
[Sysname] display current-configuration
……<omitted>
ip route-static 3.3.3.0 255.255.255.0 4.4.4.4 description for internet & intranet
return
# Configure the tag value of the static route as 45 and the description of the static route as "test"
[Sysname]ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description test
ip route-static default-preference default-preference-value
undo ip route-static default-preference
View
Parameter
default-preference-value: Default preference of the static route, which is in the range of 1 to 255.
Use the ip route-static default-preference command to configure the default preference for static routes.
Use the undo ip route-static default-preference command to restore the default preference to the default value.
By default, the default preference for static routes is 60.
Note that:
l           If no preference is specified when configuring a static route, the default preference is used.
l           When the default preference is re-configured, it applies to newly added static routes only.
Related command: display ip routing-table and ip route-static.
Example
# Set the default preference of static routes to 20.
[Sysname] ip route-static default-preference 120
&  Note:
The term “router” in this document refers to a router in a generic sense or an Ethernet switch running routing protocols.
2.1.1  checkzero
checkzero
undo checkzero
View
RIP view
Parameter
None
Use the checkzero command to enable the zero field check on RIP-1 messages.
Use the undo checkzero command to disable the zero field check.
The zero field check is enabled by default.
After the zero field check is enabled, the router discards RIP-1 messages in which zero fields are non-zero. If all messages are trusty, you can disable this feature to spare the processing time of the CPU.
Example
# Disable the zero field check on RIP-1 messages.
[Sysname] rip 100
[Sysname-rip-100] undo checkzero
2.1.2  default cost
default cost value
undo default cost
View
RIP view
Parameter
value: Default metric of redistributed routes, in the range of 0 to 16.
Use the default cost command to configure the default metric for redistributed routes.
Use the undo default cost command to restore the default.
By default, the default metric of redistributed routes is 0.
When you use the import-route command to redistribute routes from other protocols without specifying a metric, the metric specified by the default cost command applies.
Related command: import-route.
Example
# Set the default metric for redistributed routes to 3.
[Sysname] rip 100
[Sysname-rip-100] default cost 3
default-route originate cost value
undo default-route originate
View
RIP view
Parameter
value: Cost of the default route, in the range of 1 to 15.
Use the default-route originate cost command to advertise a default route with the specified metric to RIP neighbors.
Use the undo default-route originate command to disable the sending of a default route.
By default, no default route is sent to RIP neighbors.
The RIP router with this feature configured will not receive any default routes from RIP neighbors.
Example
# Send a default route with a metric of 2 to RIP neighbors.
[Sysname] rip 100
[Sysname-rip-100] default-route originate cost 2
# Disable default route sending.
[Sysname-rip-100] undo default-route originate
2.1.4  display rip
display rip [ process-id ]
View
Parameter
process-id: RIP process number, in the range of 1 to 65535.
Use the display rip command to display the current status and configuration information of the specified RIP process.
If process-id is not specified, information about all configured RIP processes is displayed.
Example
# Display the current status and configuration information of all configured RIP processes.
<Sysname> display rip
    RIP process : 1
       RIP version : 1
       Preference : 100
       Checkzero : Enabled
       Default-cost : 0
       Summary : Enabled
       Hostroutes : Enabled
       Maximum number of balanced paths : 1
       Update time   :   30 sec(s)  Timeout time         :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-collect time :  240 sec(s)
       Silent interfaces : None
       Default routes : Disabled
       Verify-source : Enabled
       Networks :
       10.0.0.0
       Configured peers : None
       Triggered updates sent : 0
       Number of routes changes : 1
       Number of replies to queries : 0
Table 2-1 Description on the fields of the display rip command
RIP process
RIP process number
RIP version
RIP version 1 or 2
Preference
RIP route priority
Checkzero
Indicates whether the zero field check is enabled for RIP-1 messages.
Default-cost
Default cost of the redistributed routes
Summary
Indicates whether the routing summarization is enabled
Hostroutes
Indicates whether to receive host routes
Maximum number of load balanced routes
Update time
RIP update interval
Timeout time
RIP timeout time
Suppress time
RIP suppress interval
RIP garbage collection interval
Silent interfaces
Number of silent interfaces, which do not periodically send updates
Default routes
Indicates whether a default route is sent to RIP neighbors
Verify-source
Indicates whether the source IP address is checked on the received RIP routing updates
Networks
Networks enabled with RIP
Configured peers
Configured neighbors
Number of sent triggered updates
Number of changed routes in the database
Number of RIP responses
display rip process-id database
View
Parameter
Use the display rip database command to display the active routes in the RIP database, which are sent in normal RIP routing updates.
Example
# Display the active routes in the database of RIP process 100.
<Sysname> display rip 100 database
  10.0.0.0/8, cost 1, ClassfulSumm
  10.0.0.0/24, cost 1, nexthop 10.0.0.1, Rip-interface
  11.0.0.0/8, cost 1, ClassfulSumm
  11.0.0.0/24, cost 1, nexthop 10.0.0.1, Imported
Table 2-2 Description on fields of the display rip database command
X.X.X.X/X
Destination address and subnet mask
cost
Cost of the route
classful-summ
Indicates the route is a RIP summary route.
Nexthop
Address of the next hop
Rip-interface
Routes learnt from a RIP–enabled interface
imported
Routes redistributed from other routing protocols
display rip process-id interface [ interface-type interface-number ]
View
Parameter
interface-type interface-number: Specifies an interface.
Use the display rip interface command to display the RIP interface information.
Example
# Display the interface information of RIP process 1.
<Sysname> display rip 1 interface
 Interface-name: Vlan-interface10
    Address/Mask:1.1.1.1/24              MetricIn/Out:0/1     Version:RIPv1
    Split-horizon/Poison-reverse:on/off  Input/Output:on/off
    Current packets number/Maximum packets number:0/2000
Table 2-3 Description on the fields of the display rip interface command
Interface-name
The name of an interface running RIP.
Address/Mask
The IP address and Mask of the interface.
MetricIn/Out
Additional routing metric added to the incoming and outgoing routes
Version
RIP version running on the interface
Split-horizon
Indicates whether the split-horizon is enabled (ON: enabled, OFF: disabled).
Poison-reverse
Indicates whether the poison-reverse is enabled (ON: enabled, OFF: disabled)
Input/Output
Indicates if the interface is allowed to receiving (Input) or sending (Output) RIP messages (on is allowed, off is not allowed).
Packets to be sent/Maximum packets that can be sent on the interface
display rip process-id route [ statistics | ip-address { mask | mask-length } | peer ip-address ]
View
Parameter
statistics: Displays the route statistics, including total number of routes and number of routes of each neighbor.
ip-address { mask | mask-length }: Displays route information about a specified IP address.
peer ip-address: Displays all routing information learned from a specified neighbor.
Use the display rip route command to display the routing information of a specified RIP process.
Example
# Display all routing information of RIP process 1.
<Sysname> display rip 1 route
              P - Permanent, A - Aging, S - Suppressed, G - Garbage-collect --------------------------------------------------------------------------
 Peer 21.0.0.23  on Vlan-interface10
      Destination/Mask        Nexthop     Cost    Tag   Flags   Sec
         56.0.0.0/8          21.0.0.23      1       0    RA     102
         34.0.0.0/8          21.0.0.23      1       0    RA      23
 Peer 21.0.0.12  on Vlan-interface10
         56.0.0.0/8          21.0.0.12      1       0    RA      34
# Display routing information for network 56.0.0.0/8 of RIP process 1.
<Sysname> display rip 1 route 56.0.0.0 8
# Display RIP process1 routing information learned from the specified neighbor.
<Sysname> display rip 1 route peer 21.0.0.23
Table 2-4 Description on the fields of the display rip route command
Route Flags
R — RIP route
T — TRIP route
P — The route never expires
A — The route is aging
S — The route is suppressed
G — The route is in Garbage-collect state
Routing information learned on a RIP interface from the specified neighbor
Destination/Mask
Destination IP address and subnet mask
Nexthop
Next hop of the route
Cost
Cost of the route
Tag
Route tag
Flags
Indicates the route state
Sec
Remaining time of the timer corresponding to the route state
# Display the routing statistics of RIP process 1.
<Sysname> display rip 1 route statistics
Peer         Aging     Permanent    Garbage
21.0.0.23      2          0              3
21.0.0.12      2          0              4
Total          4          0              7
Table 2-5 Description on the fields of the display rip route statistics command
Peer
IP address of a neighbor
Aging
Total number of aging routes learned from the specified neighbor
Permanent
Total number of permanent routes learned from the specified neighbor
Garbage
Total number of routes in the garbage-collection state learned from the specified neighbor
Total
Total number of routes learned from all RIP neighbors
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface-type interface-number ]
undo filter-policy export [ protocol [ process-id ] | interface-type interface-number ]
View
RIP view
Parameter
acl-number: Number of the Access Control List (ACL) used for filtering outbound routes, in the range of 2000 to 3999.
ip-prefix-name: Name of the IP prefix list used for filtering outbound routes, a string of 1 to 19 characters.
protocol: Filters outbound routes redistributed from a specified routing protocol, which can be bgp, direct, isis, ospf, rip, and static.
process-id: Process number of the specified routing protocol, in the range of 1 to 65535. You need to specify a process ID when the routing protocol is rip, ospf, or isis.
Use the filter-policy export command to define a RIP outbound route filtering policy. Only routes not filtered out can be advertised.
Use the undo filter-policy export command to restore the default.
By default, RIP does not filter outbound routes.
Note that:
l           If protocol is specified, RIP filters only the routes redistributed from the specified routing protocol. Otherwise, RIP filters all routes to be advertised.
l           If interface-type interface-number is specified, RIP filters only the routes advertised by the specified interface. Otherwise, RIP filters routes advertised by all RIP interfaces.
Related command: acl, import-route, and ip ip-prefix.
Example
# Reference ACL 2000 to filter outbound routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 export
# Reference IP prefix list abc to filter outbound routes on Vlan-interface 100.
[Sysname-rip-1] filter-policy ip-prefix abc export vlan-interface 100
filter-policy { acl-number | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] | gateway ip-prefix-name } import [ interface-type interface-number ]
undo filter-policy import [ interface-type interface-number ]
View
RIP view
Parameter
acl-number: Number of the Access Control List (ACL) used for filtering received routes, in the range of 2000 to 3999.
ip-prefix ip-prefix-name: References an IP prefix list to filter received routes. The ip-prefix-name is a string of 1 to 19 characters.
gateway ip-prefix-name: Sets the filtering policy for routes from the gateway.
Use the filter-policy import command to filter the received routes.
Use the undo filter-policy import command to restore the default.
By default, RIP does not filter received routes.
Related command: acl and ip ip-prefix.
Example
# Reference ACL 2000 to filter received routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 import
# Reference IP prefix list abc on Vlan-interface 100 to filter all received RIP routes.
[Sysname-rip-1] filter-policy ip-prefix abc import vlan-interface 100
2.1.10  host-route
host-route
undo host-route
View
RIP view
Parameter
None
Use the host-route command to enable host route reception.
Use the undo host-route command to disable host route reception.
By default, receiving host routes is enabled.
In some cases, a router may receive many host routes from the same network segment. These routes are not helpful for routing and occupy a large amount of network resources. You can use the undo host-route command to disable receiving of host routes.
Example
# Disable RIP from receiving host routes.
[Sysname] rip 1
[Sysname-rip-1] undo host-route
2.1.11  import-route
import-route protocol [ process-id | allow-ibgp ] [ cost cost-value | route-policy route-policy-name | tag tag-value ] *
undo import-route protocol [ process-id ]
View
RIP view
Parameter
protocol: Specify a routing protocol from which to redistribute routes, currently including bgp, direct, isis, ospf, rip, rip and static.
process-id: Process number of the routing protocol, in the range of 1 to 65535, used for isis, rip, and ospf.
cost-value: Cost for redistributed routes, in the range of 0 to 16. If cost-value is not specified, the default cost specified by the default cost command applies.
tag-value: Tag value marking redistributed routes, in the range of 0 to 65,535. The default is 0.
route-policy route-policy-name: Specifies a routing policy with 1 to 19 characters.
allow-ibgp: When the protocol argument is set to bgp, allow-ibgp is an optional keyword. The import-route bgp command only redistributes EBGP routes, while the import-route bgp allow-ibgp command additionally redistributes IBGP routes. Be careful to use the import-route bgp allow-ibgp command because such a configuration is dangerous.
Use the import-route command to redistribute routes from other routing protocols.
Use the undo import-route command to cancel route redistribution.
By default, RIP does not redistribute routes from other routing protocols.
l           You can specify a routing policy using keyword route-policy to redistribute only the specified routes.
l           You can configure a cost for redistributed routes using keyword cost.
l           You can configure a tag value for redistributed routes using keyword tag.
Related commands: default cost.
Example
# Redistribute static routes, and set the cost to 4.
[Sysname] rip 1
[Sysname-rip-1] import-route static cost 4
# Set the default cost for redistributed routes to 3.
[Sysname-rip-1] default cost 3
# Redistribute OSPF routes with the cost being the default cost.
[Sysname-rip-1] import-route ospf
maximum load-balancing number
undo maximum load-balancing
View
RIP view
Parameter
number: Maximum number of load balanced routes, ranging 1 to 4.
Use the maximum load-balancing command to specify the maximum number of load balanced routes in load sharing mode.
Use the undo maximum load-balancing command to restore the default.
By default, the maximum number of load balanced routes is 4.
Example
# Specify the maximum number of load balanced routes as 2.
[Sysname] rip
[Sysname-rip-1] maximum load-balancing 2
2.1.13  network
network network-address
undo network network-address
View
RIP view
Parameter
network-address: IP address of a network segment, which can be the IP network address of any interface.
Use the network command to enable RIP on a specified network.
Use the undo network command to disable RIP on a specified network.
Use the network 0.0.0.0 command to enable RIP on all interfaces.
RIP is disabled by default.
Example
# Enable RIP on the interface with network address 129.102.0.0.
[Sysname] rip 100
[Sysname-rip-100] network 129.102.0.0
2.1.14  peer
peer ip-address
undo peer ip-address
View
RIP view
Parameter
ip-address: IP address of a peer device, in dotted decimal format.
Use the peer command to specify the IP address of a neighbor in the non-broadcast multi-access (NBMA) network, where routing updates destined to the peer are unicast, rather than multicast or broadcast.
Use the undo peer command to remove the IP address of a neighbor.
By default, no neighbor is specified.
In general, it is not recommended to use this command. The neighbor might get the same message by receiving multicast (broadcast) and unicast messages. You are recommended to configure the related interfaces to work in silent mode when configuring this command.
Example
# Specify to send unicast updates to peer 202.38.165.1.
[Sysname] rip 1
[Sysname-rip-1] peer 202.38.165.1
2.1.15  preference
preference [ route-policy route-policy-name ] value
undo preference [ route-policy ]
View
RIP view
Parameter
route-policy-name: Routing policy name with 1 to 19 characters.
value: Priority for RIP route, in the range of 1 to 255. The smaller the value, the higher the priority.
Use the preference command to specify the RIP route priority.
Use the undo preference route-policy command to restore the default.
By default, the priority of RIP route is 100.
You can specify a routing policy using keyword route-policy to set the specified priority to routes matching the routing policy.
l           If a priority is set for matched routes in the routing policy, the priority applies to these routes. The priority of other routes is the one set by the preference command.
l           If no priority is set for matched routes in the routing policy, the priority of all routes is the one set by the preference command.
Example
# Set the RIP route priority to 120.
[Sysname] rip 1
[Sysname-rip-1] preference 120
reset rip process-id statistics
View
Parameter
Use the reset rip statistics command to clear the statistics of the specified RIP process.
Example
# Clear statistics in RIP process 100.
<Sysname> reset rip 100 statistics
2.1.17  rip
rip [ process-id ]
undo rip [ process-id ]
View
Parameter
process-id: RIP process number, in the range of 1 to 65535. The default is 1.
Use the rip command to create a RIP process and enter RIP view.
Use the undo rip command to disable a RIP process.
By default, no RIP process runs.
Note that:
l           You must create the RIP process before configuring the global parameters. This rule does not apply to interface parameters.
l           The configured interface parameters become invalid after you disable the RIP process.
Example
# Create a RIP process and enter rip process view.
[Sysname] rip
[Sysname-rip-1]
rip authentication-mode { md5 { rfc2082 key-string key-id | rfc2453 key-string } | simple password }
undo rip authentication-mode
View
Interface view
Parameter
md5: MD5 authentication mode.
rfc2453: Uses the message format defined in RFC 2453 (IETF standard).
rfc2082: Uses the message format defined in RFC 2082.
key-id: MD5 key number, in the range of 1 to 255.
key-string: MD5 key string with 1 to 16 characters in plain text format, or 24 characters in cipher text format. When the display current-configuration command is used to display the system information, a 24-character cipher string is displayed as the MD5 key string.
simple: Plain text authentication mode.
password: Plain text authentication string with 1 to 16 characters.
Use the rip authentication-mode command to configure RIP-2 authentication mode and parameters.
Use the undo rip authentication-mode command to cancel authentication.
Note that the key string you configured can overwrite the old one if there is any.
Related command: rip version.
Example
# Configure MD5 authentication on Vlan-interface10 with the key string being rose in the format defined in RFC 2453.
[Sysname-Vlan-interface10] rip version 2
[Sysname-Vlan-interface10] rip authentication-mode md5 rfc2453 rose
2.1.19  rip input
rip input
undo rip input
View
Interface view
Parameter
None
Use the rip input command to enable the interface to receive RIP messages.
Use the undo rip input command to disable the interface from receiving RIP messages.
By default, an interface is enabled to receive RIP messages.
Related command: rip output.
Example
# Disable Vlan-interface10 from receiving RIP messages.
[Sysname-Vlan-interface10] undo rip input
2.1.20  rip metricin
rip metricin value
undo rip metricin
View
Interface view
Parameter
value: Additional metric added to received routes, in the range of 0 to 16.
Use the rip metricin command to add a metric to the received routes.
Use the undo rip metricin command to restore the default.
By default, the additional metric of a received route is 0.
When a valid RIP route is received, the system will add a metric to it and then put it into the routing table. Therefore, the metric of routes received on the configured interface is increased.
Related command: rip metricout.
Example
# Configure an additional metric for routes received on Vlan-interface10.
[Sysname-Vlan-interface10] rip metricin 2
rip metricout value
undo rip metricout
View
Interface view
Parameter
value: Additional metric of sent routes, in the range of 1 to 16.
Use the rip metricout command to add a metric to a sent route.
Use the undo rip metricout command to restore the default.
By default, the additional metric for sent routes is 1.
Before a RIP route is sent, a metric will be added to it. Therefore, when the metric is configured on an interface, the metric of RIP routes sent on the interface will be increased.
Related command: rip metricin.
Example
# Configure an additional metric of 12 for RIP routes sent on Vlan-interface10.
[Sysname-Vlan-interface10] rip metricout 12
rip mib-binding process-id
undo rip mib-binding
View
Parameter
Use the rip mib-binding command to bind MIB operations with a specified RIP process.
Use the undo rip mib-binding command to restore the default.
By default, MIB operations are bound to the RIP process with the smallest process ID.
Example
# Configure RIP 100 to accept SNMP requests.
[Sysname] rip mib-binding 100
# Restore the default.
[Sysname] undo rip mib-binding
2.1.23  rip output
rip output
undo rip output
View
Interface view
Parameter
None
Use the rip output command to enable the interface to send RIP messages.
Use the undo rip output command to disable the interface from sending RIP messages.
Sending RIP messages is enabled on an interface by default.
Related command: rip input.
Example
[Sysname-Vlan-interface10] undo rip output
rip poison-reverse
undo rip poison-reverse
View
Interface view
Parameter
None
Use the rip poison-reverse command to enable the poison reverse function.
Use the undo rip poison-reverse command to disable the poison reverse function.
By default, the poison reverse function is disabled.
Example
# Enable the poison reverse function for RIP routing updates on Vlan-interface10.
[Sysname-Vlan-interface10] rip poison-reverse
rip split-horizon
undo rip split-horizon
View
Interface view
Parameter
None
Use the rip split-horizon command to enable the split horizon function.
Use the undo rip split-horizon command to disable the split horizon function.
The split horizon function is enabled by default.
l           The split horizon function is necessary for preventing routing loops. Therefore, you are not recommended to disable it.
l           In special cases, make sure it is necessary to disable the split horizon function.
l           If no sub-interfaces are used in NBMA networks such as frame relay and X.25, split horizon should be disabled to guarantee proper route advertisement.
&  Note:
Only the poison reverse function takes effect if both the split horizon and poison reverse functions are enabled.
Example
# Enable the split horizon function on Vlan-interface10.
[Sysname-Vlan-interface10] rip split-horizon
rip summary-address ip-address { mask | mask-length }
undo rip summary-address ip-address { mask | mask-length }
View
Interface view
Parameter
ip-address: Summary IP address.
mask: Subnet mask in dotted decimal format.
mask-length: Subnet mask length.
Use the rip summary-address command to configure RIP-2 to advertise a summary route via the interface.
Use the undo rip summary-address command to remove the configuration.
Note that the summary address is valid only when the automatic summarization is disabled.
Related command: summary.
Example
# Advertise a local summary address on Vlan-interface10.
[Sysname-Vlan-interface10] rip summary-address 10.0.0.0 255.255.255.0
2.1.27  rip version
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
View
Interface view
Parameter
1: RIP version 1.
2: RIP version 2.
broadcast: Sends RIP-2 messages in broadcast mode.
multicast: Sends RIP-2 messages in multicast mode.
Use the rip version command to specify the RIP version for the interface.
Use the undo rip version command to restore the default.
By default, RIP-1 runs on an interface.
You can specify a RIP version in interface view or system view. Interface view takes precedence over system view. That is, the RIP version configured in system view takes effect on the interface only if no RIP version is configured in interface view.
By default, no RIP version is configured in interface view or system view.
&  Note:
l      If you configure version 1 in system view when no version is configured in interface view, you are configuring RIP version 1 in interface view.
l      If you configure version 2 in system view when no version is configured in interface view, you are configuring RIP version 2 multicast in interface view.
l      The RIP version configured in interface view is used for processing RIP packets. Each time the version configured in RIP system view changes, the version on all interfaces is reconfigured automatically.
Table 2-6 Description on RIP packets received
RIP version configuration
RIPv1 broadcast packet
RIPv1 unicast packet
RIPv2 broadcast packet
RIPv2 multicast packet
RIPv2 unicast packet
No version configured in interface view
No version configured in system view
Version 1 configured in interface view
No version configured in interface view and version 1 configured in system view
Version 2 multicast configured in interface view
No version configured in interface view and version 2 configured in system view
Version 2 broadcast configured in interface view
Table 2-7 Description on RIP packets sent
Type of packets sent
Example
# Configure Vlan-interface10 to broadcast RIP-2 messages.
[Sysname-Vlan-interface10] rip version 2 broadcast
silent-interface { all | interface-type interface-number }
undo silent-interface { all | interface-type interface-number }
View
RIP view
Parameter
all: Silents all interfaces.
Use the silent-interface command to disable an interface or all interfaces from sending routing updates. That is, the interface only receives but does not send RIP messages.
Use the undo silent-interface command to restore the default.
By default, all interfaces are allowed to send routing updates.
Example
# Configure all Vlan interfaces to work in the silent state, and activate Vlan-interface10.
[Sysname] rip 100
[Sysname-rip-100] silent-interface all
[Sysname-rip-100] undo silent-interface vlan-interface 10
[Sysname-rip-100] network 131.108.0.0
2.1.29  summary
summary
undo summary
View
RIP view
Parameter
None
Use the summary command to enable automatic RIP-2 summarization. Natural masks are used to advertise summary routes so as to reduce the size of routing tables.
Use the undo summary command to disable automatic RIP-2 summarization so that all subnet routes can be broadcasted.
By default, automatic RIP-2 summarization is enabled.
Enabling automatic RIP-2 summarization can reduce the size of the routing table to enhance the scalability and efficiency of large networks.
Example
# Enable RIP-2 automatic summarization.
[Sysname] rip
[Sysname-rip-1] summary
2.1.30  timers
undo timers { garbage-collect | suppress | timeout | update } *
View
RIP view
Parameter
garbage-collect-value: Garbage-collect timer time in seconds, in the range of 1 to 3,600.
suppress-value: Suppress timer time in seconds, in the range of 0 to 3,600.
timeout-value: Timeout timer time in seconds, in the range of 1 to 3,600.
update-value: Update timer time in seconds, in the range of 1 to 3,600.
Use the timers command to configure RIP timers. By adjusting RIP timers, you can improve network performance.
Use the undo timers command to restore the default.
By default, the garbage-collect timer time is 240 seconds, the suppress timer time 120 seconds, the timeout timer time 180 seconds, and the update timer time 30 seconds.
RIP is controlled by the above four timers.
l           The update timer defines the interval between routing updates.
l           The timeout timer defines the route aging time. If no routing update related to a route is received after the aging time, the metric of the route is set to 16 in the routing table.
l           The suppress timer defines how long a RIP route stays in the suppressed state. When the metric of a route is 16, the route enters the suppressed state. In the suppressed state, only routes which come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
l           The garbage-collect timer defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the Garbage-Collect timer length, RIP advertises the route with the routing metric set to 16. If no routing update is announced for that route after the Garbage-Collect timer expires, the route will be deleted from the routing table.
Note that:
l           Generally, you are not recommended to change the default values of these timers.
l           The time lengths of these timers must be kept consistent on all routers and access servers in the network.
Example
# Specifies the update, timeout, suppress, and garbage-collect timers as 5, 15, 15 and 30 respectively.
[Sysname] rip 100
[Sysname-rip-100] timers update 5
[Sysname-rip-100] timers timeout 15
[Sysname-rip-100] timers suppress 15
[Sysname-rip-100] timers garbage-collect 30
undo validate-source-address
View
RIP view
Parameter
None
Use the validate-source-address command to enable the source IP address validation on incoming RIP routing updates.
Use the undo validate-source-address command to disable the source IP address validation.
The source IP address validation is enabled by default.
Generally, disabling the validation is not recommended.
Example
# Enable the source IP address validation on incoming messages.
[Sysname-rip] rip 100
[Sysname-rip-100] validate-source-address
2.1.32  version
version { 1 | 2 }
undo version
View
RIP view
Parameter
1: Specifies the RIP version as RIP-1.
2: Specifies the RIP version as RIP-2.
Use the version command to specify a global RIP version.
Use the undo version command to restore the default.
By default, the RIP version is RIP-1.
Note that the global RIP version takes effect on RIP interfaces only when no interface RIP version is configured.
Example
# Specify RIP-2 as the global RIP version.
[Sysname] rip 100
[Sysname-rip-100] version 2
&  Note:
3.1.1  abr-summary
abr-summary ip-address { mask | mask-length } [ advertise | not-advertise ] [ cost cost ]
undo abr-summary ip-address { mask | mask-length }
View
OSPF area view
Parameter
ip-address: The IP address of the summary route, in dotted decimal format.
mask: The IP address mask of the summary route, in dotted decimal format.
mask-length: Mask length, in the range 0 to 32 bits.
advertise | not-advertise: Specifies to advertise or not to advertise the summary route. By default, the summary route is advertised.
cost cost: Specifies the cost of the summary route, in the range 1 to 16777215. The cost defaults to the biggest cost value among routes that are summarized.
Use the abr-summary command to configure a summary route on an Area Border Router.
Use the undo abr-summary command to remove a summary route.
By default, no route summarization is available on an ABR.
You can configure to advertise or not to advertise the summary route, and specify the route cost.
This command is available only on an ABR. Multiple contiguous networks may be available in an area, where you can summarize them into one network on the ABR for advertisement. The ABR advertises only the summary route to other areas.
With the undo abr-summary command used, summarized routes will be advertised.
Example
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area1 into 36.42.0.0/16 for advertisement to other areas.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
3.1.2  area
area area-id
undo area area-id
View
OSPF view
Parameter
area-id: The ID of an area, a decimal integer in the range 0 to 4294967295 that is translated into IP address format by the system, or an IP address.
Use the area command to create an area and enter area view.
Use the undo area command to remove a specified area.
No OSPF area is created by default.
Example
# Create Area0 and enter Area 0 view
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
3.1.3  asbr-summary
asbr-summary ip-address { mask | mask-length } [ tag tag-value | not-advertise | cost cost ]*
undo asbr-summary ip-address { mask | mask-length }
View
OSPF view
Parameter
ip-address: IP address of the summary route in dotted decimal notation.
mask: IP address mask in dotted decimal notation.
not-advertise: Specifies not to advertise the summary route. If the keyword is not specified, the route is advertised.
tag tag-value: Specifies the tag value of a route policy to control route advertisement, in the range 0 to 4294967295. The value defaults to 1.
cost cost: Specifies the cost of the summary route, in the range 1 to 16777214. For Type-1 external routes, the cost defaults to the biggest cost among routes that are summarized. For Type-2 external routes, the cost defaults to the value of the biggest cost among routes that are summarized plus 1.
Use the asbr-summary command to configure a summary route for redistributed routes.
Use the undo asbr-summary command to remove a summary route.
No route summarization is available by default.
You can configure to advertise the summary route or not, and specify the cost of the summary route.
With the asbr-summary command configured on an ASBR, it summarizes redistributed routes that fall into the specified address range into a single route in a Type-5 LSA and advertises the LSA into the attached area. If the ASBR resides in an NSSA area, it advertises the summary route in a Type-7 LSA into the area.
With the asbr-summary command configured on an NSSA ABR, it summarizes routes in Type-5 LSAs translated from Type-7 LSAs into a single route and advertises the summary route to other areas. This command does not take effect on non NSSA ABRs.
With the undo asbr-summary command used, summarized routes will be advertised.
Related command: display ospf asbr-summary.
Example
# Configure a summary route for redistributed routes.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode { simple | md5 }
undo authentication-mode
View
OSPF area view
Parameter
simple: Specifies the simple authentication mode.
md5: Specifies the MD5 ciphertext authentication mode.
Use the authentication-mode command to specify an authentication mode for the OSPF area.
Use the undo authentication-mode command to cancel a specified authentication mode.
By default, no authentication mode is configured for an OSPF area.
Routers that reside in the same area must have the same authentication mode: non-authentication, simple, or MD5.
Related command: ospf authentication-mode.
Example
# Specify the MD5 ciphertext authentication mode for OSPF area0.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5
bandwidth-reference value
undo bandwidth-reference
View
OSPF view
Parameter
value: Specifies a bandwidth reference value for link cost calculation, in the range 1 to 2,147,483,648, in Mbps.
Use the bandwidth-reference command to specify a reference bandwidth value for link cost calculation.
Use the undo bandwidth-reference command to restore the default value.
The value defaults to 100 Mbps.
When links have no cost values, OSPF calculates their cost values: cost=reference bandwidth value (Mbps) / link bandwidth (Mbps).
The reference value defaults to 100, namely, cost=100000000(bit/s)/link bandwidth.
Example
# Specify the reference bandwidth value as 1,000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
3.1.6  default
default { cost cost | limit limit | tag tag | type type } *
undo default { cost | limit | tag | type } *
View
OSPF view
Parameter
cost: Specifies the default cost for redistributed routes, in the range 0 to 16777214.
limit: Specifies the default upper limit of routes redistributed per time, in the range 1 to 2,147,483,647.
tag: Specifies the default tag for redistributed routes, in the range 0 to 4294967295.
type: Specifies the default type for redistributed routes: 1 or 2.
Use the default command to configure default parameters for redistributed routes: cost, route type (Type1 or Type2), tag, and the upper limit.
Use the undo default command to restore default values.
The cost, route type, tag, and the upper limit are 1, 2, 1 and 1000 by default.
Example
# Configure default parameters cost as 10, upper limit as 20000, tag as 100 and type as 2 for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 limit 20000 tag 100 type 2
3.1.7  default-cost
default-cost cost
undo default-cost
View
OSPF area view
Parameter
cost: Specifies the cost of the default route to the Stub or NSSA area, in the range 0 to 16777214.
Use the default-cost command to specify the cost for the default route to the stub or NSSA area.
Use the undo default-cost command to restore the default value.
The cost defaults to 1.
This command is only available on the ABR that is attached to a stub or NSSA area.
Related command: stub, nssa.
Example
# Configure Area1 as a stub area, and specify the cost of the default route to the stub area as 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
default-route-advertise [ always | cost cost | type type | route-policy route-policy-name ]*
default-route-advertise summary cost cost
undo default-route-advertise
View
OSPF view
Parameter
always: Generates a default external route in an ASE LSA into the OSPF routing domain, if the router has no default route configured. Without this keyword used, you have to configure a default route to distribute an ASE LSA into the OSPF routing domain.
cost cost: Specifies the cost for the ASE LSA, in the range 0 to 16777214. It defaults to 1.
type type: Specifies the ASE LSA type: 1 or 2, which defaults to 2.
route-policy route-policy-name: Specifies the route policy name, a string of 1 to 19 characters. If the default route matches the specified route policy, the route policy affects some value in the ASE LSA.
summary: Advertises the Type-3 summary LSA of the specified default route.
Use the default-route-advertise command to generate a default route into the OSPF routing domain.
Use the undo default-route-advertise command to disable OSPF from distributing a default external route.
By default, no default route is distributed.
Using the import-route command cannot redistribute a default route. To do so, use the default-route-advertise command. If the default route is not configured, to generate the ASE LSA for a default route, use the default-route-advertise always command.
The default-route-advertise summary command is available only for VPNs. The H3C S3610&S5510 series do not support this command.
Example
# Generate a default route in an ASE LSA into the OSPF routing domain (no default route configured on the router).
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
3.1.9  description
View
OSPF view/OSPF area view
Parameter
description: Describes OSPF process in OSPF view, or describes OSPF area in OSPF area view. description is a string of up to 80 characters.
Use the description command to describe an OSPF process or area.
Use the undo description command to remove the description.
No description is configured by default.
Use of this command is only for identification of an OSPF process or area, and has no special meaning.
Example
#Describe the OSPF process 100 as “The main process”.
[Sysname] ospf 100
[Sysname-ospf-100] description The main process
# Describe the OSPF area0 as “containing interface eth1/0, eth1/1”.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description containing interface eth1/0 eth1/1
display ospf [ process-id ] abr-asbr
View
Parameter
process-id: OSPF process ID, in the range 1 to 65535.
Use the display ospf abr-asbr command to display information about ABR/ASBR.
If no process is specified, ABR/ASBR information of all OSPF processes is displayed.
If you use this command on routers in a stub area, no ASBR information is displayed.
If you use this command on routers in an NSSA area, only information about ASBR is displayed.
Example
# Display information about ABR/ASBR.
<Sysname> display ospf abr-asbr
          OSPF Process 1 with Router ID 192.168.1.2
                  Routing Table to ABR and ASBR
 Type        Destination       Area       Cost  Nexthop         RtType
 Inter       3.3.3.3           0.0.0.0    3124  10.1.1.2        ASBR
 Intra       2.2.2.2           0.0.0.0    1562  10.1.1.2        ABR
Table 3-1 Description on the fields of the display ospf abr-asbr command
Intra-area router or Inter-area router
Destination
Router ID of an ABR/ASBR
Area
ID of the area of the next hop
Cost
Cost from the router to the ABR/ASBR
Nexthop
Next hop address
RtType
Router type: ABR, ASBR
display ospf [ process-id ] asbr-summary [ ip-address { mask | mask-length } ]
View
Parameter
ip-address: The matched IP address, in dotted decimal format.
mask: IP address mask, in dotted decimal format.
Use the display ospf asbr-summary command to display information about summarized redistributed routes.
If no OSPF process is specified, related information of all OSPF processes is displayed.
If no IP address is specified, information about all summarized redistributed routes will be displayed.
Related command: asbr-summary.
Example
# Display information about all summarized redistributed routes.
<Sysname> display ospf asbr-summary
                  Summary Addresses
 Total Summary Address Count: 1
                  Summary Address
 Net         : 30.1.0.0
 Mask        : 255.255.0.0
 Tag         : 20
 Status      : Advertise
 Cost        : 10 (Configured)
 The Count of Route is : 2
 Destination     Net Mask        Proto      Process   Type     Metric
 30.1.2.0        255.255.255.0   OSPF       1         2        1
 30.1.1.0        255.255.255.0   OSPF       1         2        1
Table 3-2 Description on the fields of the display ospf asbr-summary command
Total summary route number
Net
The address of the summary route
Mask
The mask of the summary route address
Tag
The tag of the summary route
Status
The advertisement status of the summary route
Cost
The cost to the summary route
The Count of Route
The count of routes that are summarized
Destination
Destination address of a summarized route
Net Mask
Network mask of a summarized route
Proto
Routing protocol
Process
Process ID of routing protocol
Type of a summarized route
Metric
Metric of a summarized route
display ospf [ process-id ] brief
View
Parameter
Use the display ospf brief command to display OSPF brief information. If no OSPF process is specified, brief information of all OSPF processes is displayed.
Information also includes:
l           The ID of the router configured with Traffic Engineering
l           The configured VPN ID
l           Whether the router restarted
Example
# Display OSPF brief information.
<Sysname> display ospf brief
          OSPF Process 100 with Router ID 192.168.0.36
                  OSPF Protocol Information
 RouterID: 192.168.0.36     Border Router:
 Route Tag: 0
 SPF-schedule-interval: 5 0 5000
 LSA generation interval: 5 0 5000
 LSA arrival interval: 1000
 Route Preference: 10
 ASE Route Preference: 150
 SPF Computation Count: 7
 RFC 1583 Compatible
 Area Count: 1   Nssa Area Count: 0
 ExChange/Loading Neighbors: 0
 Area: 0.0.0.0          (MPLS TE  not enabled)
 Authtype: None Area flag: Normal
 SPF Scheduled Count: 6
 Interface: 192.168.0.36 (Vlan-interface1)
 Cost: 1       State: BDR       Type: Broadcast    MTU: 1500
 Priority: 1
 Designated Router: 192.168.0.65
 Backup Designated Router: 192.168.0.36
 Timers: Hello 10 , Dead 40 , Poll  40 , Retransmit 5 , Transmit Delay 1
Table 3-3 Description on the fields of the display ospf brief command
RouterID
The current router ID
Border Router
An ABR, ASBR or NSSA ABR
Route Tag
The tag of redistributed routes
The current OSPF process supports no multi-VPN-instance
Interval for SPF calculation
The minimum LSA repeat arrival interval
Default ASE Parameter
Default ASE Parameter: Metric, tag, type.
Route Preference
Internal route priority
External route priority
SPF Computation count
The total number of routes calculated by SPF
RFC1583 Compatible
Compatible with routing rules defined in RFC1583
Area Count
Area number of the current process
Nssa Area Count
NSSA area number of the current process
Neighbors in ExChange/Loading state
Area
Area ID in the IP address format
Authtype
Authentication type of the area: Non-authentication, simple authentication, or MD5 authentication
Area flag
The type of the area
SPF scheduled Count
Routes in the area calculated by SPF
IP address of the interface
Cost
Interface cost
Interface state
Interface network type
MTU
Interface MTU
Priority
Router priority
Designated Router
The Designated Router
The Backup Designated Router
Timers
Intervals of timers: hello, dead, poll, retransmit, and transmit delay
display ospf [ process-id ] cumulative
View
Parameter
Use the display ospf cumulative command to display OSPF statistics.
Use of this command is helpful for troubleshooting.
Example
# Display OSPF statistics.
<Sysname> display ospf cumulative
                  Cumulations
  IO Statistics
             Type        Input     Output
            Hello          808        809
   DB Description            4          3
   Link-State Req            1          1
Link-State Update           12         18
   Link-State Ack           18         11
  ASE: (Disabled)
  LSAs originated by this router
  Router: 6
  Network: 0
  Sum-Net: 0
  Sum-Asbr: 0
  External: 1
  NSSA: 0
  Opq-Link: 0
  Opq-Area: 0
  Opq-As: 0
  LSAs Originated: 7  LSAs Received: 15
  Routing Table:
    Intra Area: 1  Inter Area: 1  ASE: 0
Table 3-4 Description on the fields of the display ospf cumulative command
IO statistics
Statistics about inbound/outbound packets and LSAs
OSPF packet type
Input
Packets received
Output
Packets sent
Hello
Hell packet
DB Description
Database Description packet
Link-State Req
Link-State Request packet
Link-State Update
Link-State Update packet
Link-State Ack
Link-State Acknowledge packet
ASE
ASE link state
Router
Type-1 LSA
Network
Type-2 LSA
Sum-Net
Type-3 LSA
Sum-Asbr
Type-4 LSA
External
Type-5 LSA
NSSA
Type-7 LSA
Opq-Link
Type-9 LSA
Opq-Area
Type-10 LSA
Opq-As
Type-11 LSA
LSAs originated
LSA originated
LSAs Received
LSA received
Routing Table
Routing table
Intra Area
Intra-area route number
Inter Area
Inter-area route number
ASE
ASE route number
3.1.14  display ospf error
display ospf [ process-id ] error
View
Parameter
Use the display ospf error command to display OSPF error information.
If no process is specified, OSPF error information of all OSPF processes is displayed.
Example
# Display OSPF error information.
<Sysname> display ospf error
          OSPF Process 1 with Router ID 192.168.80.100
                  OSPF Packet Error Statistics
0    : OSPF Router ID confusion     0    : OSPF bad packet
0    : OSPF bad version             0    : OSPF bad checksum
0    : OSPF bad area ID             0    : OSPF drop on unnumber interface
0    : OSPF bad virtual link        0    : OSPF bad authentication type
0    : OSPF bad authentication key  0    : OSPF packet too small
0    : OSPF Neighbor state low      0    : OSPF transmit error
0    : OSPF interface down          0    : OSPF unknown neighbor
0    : HELLO: Netmask mismatch      0    : HELLO: Hello timer mismatch
0    : HELLO: Dead timer mismatch   0    : HELLO: Extern option mismatch
0    : HELLO: NBMA neighbor unknown 0    : DD: MTU option mismatch
0    : DD: Unknown LSA type         0    : DD: Extern option mismatch
0    : LS ACK: Bad ack              0    : LS ACK: Unknown LSA type
0    : LS REQ: Empty request        0    : LS REQ: Bad request
0    : LS UPD: LSA checksum bad     0    : LS UPD: Received less recent LSA
0    : LS UPD: Unknown LSA type
Table 3-5 Description on the fields of the display ospf error command
Packets with duplicate route ID
OSPF bad packet
Packets illegal
OSPF bad version
Packets with wrong version
OSPF bad checksum
Packets with wrong checksum
OSPF bad area ID
Packets with invalid area ID
Packets dropped on the unnumbered interface
Packets on wrong virtual links
Packets with invalid authentication type
Packets with invalid authentication key
Packets too small in length
Packets received in low neighbor state
OSPF transmit error
Packets with error occurred when being transmitted
OSPF interface down
Shutdown times of the interface
Packets received from unknown neighbors
Hello packets with mask mismatch
Hello packets with hello timer mismatch
Hello packets with dead timer mismatch
Hello packets with option field mismatch
Hello packets received from unknown NBMA neighbors
DD packets with MTU mismatch
DD packets with unknown LSA type
DD packets with option field mismatch
LS ACK: Bad ack
LSAck packets for LSU packets error acknowledgement
LSAck packets with unknown LSA type
LSR packets with no request information
LS REQ: Bad request
LSR packets with wrong request
LSU packets with wrong LSA checksum
LSU packets without latest LSA
LSU packets with unknown LSA type
3.1.15  display ospf interface
display ospf [ process-id ] interface [ all | interface-type interface-number ]
View
Parameter
all: Display OSPF information of all interfaces.
interface-type interface-number: Interface type and interface number.
Use the display ospf interface command to display OSPF interface information.
If no OSPF process is specified, OSPF interface information of all OSPF processes is displayed.
Example
# Display OSPF interface information.
<Sysname> display ospf interface
          OSPF Process 1 with Router ID 192.168.1.1
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type         State    Cost  Pri   DR              BDR
 192.168.1.1     PTP          P-2-P    1562  1     0.0.0.0         0.0.0.0
 Area: 0.0.0.1
 172.16.0.1      Broadcast    DR       1     1     172.16.0.1      0.0.0.0
Table 3-6 Description on the fields of the display ospf interface command
Area
The ID of the area the interface attached to
IP address
Interface IP address (regardless of TE enabled or not)
Interface network type: PTP, PTMP, Broadcast, or NBMA
Interface state defined by interface state machine: DOWN, Waiting, p-2-p, DR, BDR, or DROther
Cost
Interface cost
Pri
Router priority
DR
The DR on the network segment where the interface resides
BDR
The BDR on the interface network segment
3.1.16  display ospf lsdb
display ospf [ process-id ] lsdb [ brief | [ { ase | router | network | summary | asbr | nssa | opaque-link | opaque-area | opaque-as } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ]
View
Parameter
brief: Displays brief LSDB information.
ase: Displays Type5 LSA (AS External LSA) information in the LSDB.
router: Displays Type1 LSA (Router LSA) information in the LSDB.
network: Displays Type2 LSA (Network LSA) information in the LSDB.
summary: Displays Type3 LSA (Network Summary LSA) information in the LSDB.
asbr: Displays Type4 LSA (ASBR Summary LSA) information in the LSDB.
nssa: Displays Type7 LSA (NSSA External LSA) information in the LSDB.
opaque-link: Displays Type9 LSA (Opaque-link LSA) information in the LSDB.
opaque-area: Displays Type10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type11 LSA (Opaque-AS LSA) information in the LSDB.
link-state-id: Link state ID, in the IP address format.
originate-router advertising-router-id: Specifies the IP address of the router by which to display information of LSAs advertised.
self-originate: Displays information about LSAs originated by this router.
Use the display ospf lsdb command to display LSDB information.
If no OSPF process is specified, LSDB information of all OSPF processes is displayed.
Example
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
         OSPF Process 1 with Router ID 192.168.0.1
                 Link State Database
                         Area: 0.0.0.0
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Metric
 Router    192.168.0.2     192.168.0.2        474  36    80000004       0
 Router    192.168.0.1     192.168.0.1         21  36    80000009       0
 Network   192.168.0.1     192.168.0.1        321  32    80000003       0
 Sum-Net   192.168.1.0     192.168.0.1        321  28    80000002       1
 Sum-Net   192.168.2.0     192.168.0.2        474  28    80000002       1
                         Area: 0.0.0.1
 Router    192.168.0.1     192.168.0.1         21  36    80000005       0
 Sum-Net   192.168.2.0     192.168.0.1        321  28    80000002       2
 Sum-Net   192.168.0.0     192.168.0.1        321  28    80000002       1
Table 3-7 Description on the fields of the display ospf lsdb command
Area
Area
LSA type
LinkState ID
Link state ID
AdvRouter
The router that advertised the LSA
Age
Age time of the LSA
Len
Length of the LSA
Sequence
Sequence number of the LSA
Metric
Cost of the LSA
# Display Type2 LSA (Network LSA) information in the LSDB.
<Sysname> display ospf 1 lsdb network
                         Area: 0.0.0.0
                 Link State Database
    Type      : Network
    LS ID     : 192.168.0.1
    Adv Rtr   : 192.168.0.1
    LS Age    : 1602
    Len       : 32
    Options   :  E
    Seq#      : 80000009
    Chksum    : 0x8027
    Net Mask  : 255.255.255.0
       Attached Router    192.168.0.2
       Attached Router    192.168.0.1
                         Area: 0.0.0.1
                 Link State Database
Table 3-8 Description on the fields of the display ospf 1 lsdb network command
LSA type
LS ID
DR IP address
Adv Rtr
Router that advertised the LSA
LS Age
LSA age time
Len
LSA length
Options
LSA options
Seq#
LSA sequence number
Chksum
LSA checksum
Net Mask
Network mask
Attached Router
ID of the router that established adjacency with the DR, and ID of the DR itself
3.1.17  display ospf nexthop
View
Parameter
Use the display ospf nexthop command to display OSPF next hop information.
If no OSPF process is specified, next hop information of all OSPF processes is displayed.
Example
# Display OSPF next hop information.
<Sysname> display ospf nexthop
                  Routing Nexthop Information
  Next Hops:
  Address         Refcount  IntfAddr        Intf Name
  192.168.0.36    1         192.168.0.36    Vlan-interface1
  192.168.0.65    1         192.168.0.36    Vlan-interface1
Table 3-9 Description on the fields of the display ospf nexthop command
Next hops
Information about Next hops
Address
Next hop address
Refcount
Reference count
IntfAddr
Outbound interface address
Intf Name
Outbound interface name
3.1.18  display ospf peer
display ospf [ process-id ] peer [ interface-type interface-number ] [ neighbor-id ]
View
Parameter
interface-type interface-number: Interface type and number
neighbor-id: Neighbor router ID.
Use the display ospf peer command to display information about OSPF neighbors.
If no OSPF process is specified, OSPF neighbor information of all OSPF processes is displayed.
Example
# Display OSPF neighbor information.
<Sysname> display ospf peer
                  Neighbors
 Area 0.0.0.0 interface 10.0.0.1(Vlan-interface100)'s neighbors
 Router ID: 192.168.0.55     Address: 10.0.0.2         GR State: Normal
   State: Full  Mode: Nbr is Master  Priority: 1
   DR: 10.0.0.2  BDR: 10.0.0.1  MTU: 0
   Dead timer due in 32  sec
   Neighbor is up for 00:02:28
 Last Neighbor Down Event:
 Local Address: 10.0.0.1
 Remote Address: 10.0.0.2
 Time: Apr 26 22:34:57 2000
 Reason: Reset ospf command was performed
Table 3-10 Description on the fields of the display ospf peer command
Area
Area neighbors attached to
The Interface connected to neighbors
Router ID
Neighbor router ID
Address
Neighbor router address
GR State
GR state
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading or Full
Mode
Neighbor mode for DD exchange: Master or Slave
Priority
Router priority
DR
The DR on the interface attached network segment
BDR
The BDR on the interface attached network segment
MTU
Interface MTU
Dead timer times out in 32 seconds
The neighbor has been up for 00:02:28
Authentication sequence number
Number of neighbor state changes
Event of the last neighbor state changed to "down"
Local Address
Local address
Remote Address
Neighbor address
Time
Time of the last neighbor state changed to "down"
Reason
Reason for the last neighbor state changed to "down"
3.1.19  display ospf peer statistics
View
Parameter
Use the display ospf peer statistics command to display OSPF neighbor statistics.
If no OSPF process is specified, OSPF neighbor statistics of all OSPF processes is displayed.
Example
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
                            Neighbor Statistics
Area ID       Down  Attempt Init 2-Way ExStart Exchange Loading Full Total
0.0.0.1       0      0         0     0     0        0          0        1     1
Total         0      0         0     0     0        0          0        1     1
Table 3-11 Description on the fields of the display ospf peer statistics command
Area ID
Area ID
Down
Under this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time.
Attempt
Available only in an NBMA network, such as Frame Relay, X.25 or ATM. Under this state, the OSPF router has not received any information from a neighbor for a period but can send Hello packets with a longer interval to keep neighbor relationship.
Init
Under this state, the router received a Hello packet from a neighbor but the packet gives no ID of the router, mutual communication is not available.
2-Way
Indicates mutual communication between the router and its neighbor is available. DR/BDR election finished under this state (or higher).
ExStart
Under this state, the router decides on sequence numbers for DD packets.
Exchange
Under this state, the router exchanges routing information with the neighbor.
Loading
Under this state, the router requests the neighbor for needed LSAs.
Full
Indicates LSDB synchronization has been accomplished between neighbors.
Total
Total number of neighbors under the same state
3.1.20  display ospf request-queue
View
Parameter
interface-type interface-number: Interface type and number.
neighbor-id: Neighbor ID.
Use the display ospf request-queue command to display OSPF request list information.
If no OSPF process is specified, OSPF request list information of all OSPF processes is displayed.
Example
# Display OSPF request list information.
<Sysname> display ospf request-queue
                 OSPF Request List
The Router's Neighbor is Router ID 2.2.2.2         Address 10.1.1.2
Interface 10.1.1.1         Area 0.0.0.0
Request list:
    Type       LinkState ID      AdvRouter        Sequence   Age
    Router     1.1.1.1           1.1.1.1          80000004   1
    Network    192.168.0.1       1.1.1.1          80000003   1
    Sum-Net    192.168.1.0       1.1.1.1          80000002   2
Table 3-12 Description on the fields of the display ospf request-queue command
Neighbor router ID
Address
Neighbor interface IP address
Local interface IP address
Area
Area ID
Request list
Request list information
LSA type
LinkState ID
Link state ID
AdvRouter
Advertising router
Sequence
LSA sequence number
Age
LSA age time
3.1.21  display ospf retrans-queue
View
Parameter
interface-type: Interface type.
interface-number: Interface number.
Use the display ospf retrans-queue command to display retransmit list information.
If no OSPF process is specified, retransmit list information of all OSPF processes is displayed.
Example
# Display OSPF retransmit list information.
<Sysname> display ospf retrans-queue
                 OSPF Retransmit List
  The Router's Neighbor is Router ID 192.168.0.55    Address 10.0.0.2
  Interface 10.0.0.1         Area 0.0.0.0
  Retransmit list:
       Network    10.0.0.1          192.168.0.36      80000002   1
       Router     192.168.0.36      192.168.0.36      80000006   1
Table 3-13 Description on the fields of the display ospf retrans-queue command
Neighbor router ID
Address
Interface address of the router
Area
Area ID
Retransmit list
Retransmit list
LSA type
LinkState ID
Link state ID
AdvRouter
Advertising router
Sequence
LSA sequence number
Age
LSA age time
3.1.22  display ospf routing
display ospf [ process-id ] routing [ interface interface-type interface-number ] [ nexthop nexthop-address ]
View
Parameter
interface interface-type interface-number: Specifies an interface via which to display routing information advertised.
nexthop nexthop-address: Displays routing information with the specified next hop.
Use the display ospf routing command to display routing table information.
If no OSPF process is specified, routing table information of all OSPF processes is displayed.
Example
# Display OSPF routing table information.
<Sysname> display ospf routing
                   Routing Tables
 Routing for Network
 Destination        Cost  Type       NextHop         AdvRouter     Area
 192.168.1.0/24     1562  stub       192.168.1.2     192.168.1.2   0.0.0.0
 172.16.0.0/16      1563  Inter      192.168.1.1     192.168.1.1   0.0.0.0
 Total Nets: 2
 Intra Area: 1  Inter Area: 1  ASE: 0  NSSA: 0
Table 3-14 Description on the fields of the display ospf routing command
Destination
Destination network
Cost
Cost to destination
Route type: intra-area, Transit, stub, Inter-area, Type1 External, Type2 External.
NextHop
Next hop address
AdvRouter
Advertising router
Area
Area ID
Total Nets
Total routes
Intra Area
Total intra-area routes
Inter Area
Total inter-area routes
ASE
Total ASE routes
NSSA
Total NSSA routes
3.1.23  display ospf vlink
View
Parameter
Use the display ospf vlink command to display OSPF virtual link information.
Example
# Display OSPF virtual link information.
<Sysname> display ospf vlink
                OSPF Process 100 with Router ID 10.0.0.1
                             Virtual Links
  Virtual-link Neighbor-id  -> 100.0.0.1, Neighbour-State: Down
   Interface: 100.0.0.2 (Vlan-interface100)
     Cost: 1 State: DR    Type: Broadcast
     Transit Area: 0.0.0.1
     Timers: Hello 10, Dead 40, Poll 0, Retransmit 5, Transmit Delay 1
Table 3-15 Description on the fields of the display ospf vlink command
 ID of neighbor connected to the router via the virtual link
Neighbour-State
Neighbor State: Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, Full.
Local interface’s IP address and name of the virtual link
Cost
Interface route cost
Interface state
Type: broadcast
Transit Area
Transit area ID if the interface attached to a virtual link
Timers
Values of timers: Hello, Dead, Poll (NBMA), Retransmit, and Interface transmit delay
3.1.24  Enable log
enable log [ config | error | state ]
undo enable log [ config | error | state ]
View
OSPF view
Parameter
config: Enables configuration logging.
error: Enables error logging.
state: Enables state logging.
Use the enable command to enable specified OSPF logging.
Use the undo enable command to disable specified logging.
OSPF logging is disabled by default.
If no keyword is specified, all logging is enabled.
Example
# Enable OSPF logging.
[Sysname] ospf 100
[Sysname-ospf-100] enable log
3.1.25  filter import/export
filter { acl-number | ip-prefix ip-prefix-name } { import | export }
undo filter { import | export }
View
OSPF area view
Parameter
acl-number: ACL number, in the range 2000 to 3999.
ip-prefix-name: IP address prefix list name, a string of up to 19 characters.
import: Filters imported LSAs.
export: Filters exported LSAs.
Use the filter command to configure exported/imported Summary LSAs filtering on an ABR.
Use the undo filter command to disable Summary LSA filtering.
By default, Summary LSAs filtering is disabled.
&  Note:
This command is only available on an ABR.
Example
# Apply IP prefix list “my-prefix-list” to filter inbound Type-3 LSAs, and ACL2000 to filter outbound Type-3 LSAs in OSPF area 1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] filter ip-prefix my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
3.1.26  filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
View
OSPF view
Parameter
protocol: Specifies a protocol from which to filter redistributed routes. Protocols include direct, static, rip, ospf, isis or bgp. If no protocol is specified, all redistributed routes are filtered.
process-id: Process ID, which is required when the protocol is rip, ospf or isis, in the range 1 to 65535.
Use the filter-policy export command to configure route redistribution filtering.
Use the undo filter-policy export command to disable route redistribution filtering.
By default, route redistribution is disabled.
You can use this command to filter redistributed routes as needed.
Related command: import-route.
Example
# Filter redistributed routes using ACL2000.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
3.1.27  filter-policy import
filter-policy { acl-number | ip-prefix ip-prefix-name | gateway ip-prefix-name } import
View
OSPF view
Parameter
acl-number: The number of an ACL used to filter received routes, in the range 2000 to 3999.
ip-prefix-name: The name of an IP address prefix list used to filter received routes, a string of up to 19 characters.
gateway ip-prefix-name: The name of an IP address prefix list used to filter routes received from the specified neighbors, a string of up to 19 characters.
Use the filter-policy import command to specify rules for filtering received routes.
Use the undo filter-policy import command to disable filtering.
By default, no filtering is available.
You can use the command to filter received routes as needed.
Example
# Filter received routes using ACL2000.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
3.1.28  host-advertise
host-advertise ip-address cost
undo host-advertise ip-address
View
OSPF area view
Parameter
ip-address: IP address of a host
cost: Cost of the route, in the range 1 to 65535.
Use the host-advertise command to configure a host route.
Use the undo host-advertise command to remove a host route.
No host route is configured by default.
Example
# Configure host route 1.1.1.1 and specify cost 100 for it.
[Sysname] ospf 100
[Sysname] area 0
[Sysname-ospf-100-area-0.0.0.0]host-advertise 1.1.1.1 100
3.1.29  import-route
import-route protocol [ process-id | allow-ibgp ] [ cost cost | type type | tag tag | route-policy route-policy-name ]*
View
OSPF view
Parameter
protocol: Specifies a protocol from which to redistribute routes: direct, static, rip, ospf, isis or bgp.
process-id: Process ID, which is optional when the protocol is rip, ospf or isis, in the range 1 to 65535.
allow-ibgp: Allows to redistribute IBGP routes, required when the protocol is bgp.
cost cost: Specifies route cost, in the range 0 to 16777214, which defaults to 1.
type type: Specifies cost type, 1 or 2, which defaults to 2.
tag tag : Specifies for external LSAs the tag, in the range 0 to 4294967295, which defaults to 1.
route-policy: Specifies a route policy to redistribute qualified routes only.
route-policy-name: Route policy name, a string of up to 19 characters.
Use the import-route command to redistribute routes from other protocols.
Use the undo import-route command to disable route redistribution.
Route redistribution is not available by default.
OSPF prioritize routes as follows:
l           Intra-area route
l           Inter-area route
l           Type1 External route
l           Type2 External route
An intra-area route is a route in an OSPF area. An inter-area route is between any two OSPF areas. Both of them are internal routes.
An external route is a route to a destination outside the OSPF AS.
A Type1 external route is an IGP route, such as RIP or STATIC, which has high reliability and whose cost is comparable with the cost of OSPF internal routes: Cost from an OSPF router to a Type1 external route= Cost from the router to the corresponding ASBR+ Cost from the ASBR to the external route.
A Type2 external route is an EGP route, which has low credibility, so OSPF considers the cost from ASBR to a Type2 external route is much bigger than the cost from the ASBR to an OSPF internal router. Therefore, Cost from an internal router to a Type2 external route=Cost from the ASBR to the Type2 external route.
Related command: default-route-advertise.
&  Note:
l      The import-route command cannot redistribute default routes.
l      Be cautious of using the import-route bgp allow-ibgp command, because it redistributes both EGBP and IBGP routes that may cause routing loops.
Example
# Redistribute routes from RIP process 40 and specify the type as type2, tag as 33, and cost as 50 for redistributed routes.
[Sysname> ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
3.1.30  log-peer-change
log-peer-change
undo log-peer-change
View
OSPF view
Parameter
None
Use the log-peer-change command to enable logging on OSPF neighbor state changes.
Use the undo log-peer-change command to disable the logging.
The logging is enabled by default.
With this feature enabled, neighbor state changes display on the terminal until the feature is disabled.
Example
# Enable logging on neighbors state changes.
[Sysname] ospf 100
[Sysname-ospf-100] log-peer-change
3.1.31  lsa-arrival-interval
lsa-arrival-interval interval
undo lsa-arrival-interval
View
OSPF view
Parameter
interval: Specifies the minimum interval between two received identical LSAs in milliseconds, in the range 0 to 60000.
Use the lsa-arrival-interval command to specify the minimum interval between two identical received LSAs.
Use the undo lsa-arrival-interval command to restore the default.
The interval defaults to 1000 milliseconds.
If an LSA that has the same LSA type, LS ID, originating router ID with the previous LSA is received within the interval, the LSA will be discarded. This feature helps you protect routers and bandwidth from being over-consumed due to frequent network changes.
 It is recommended the interval set by the lsa-arrival-interval command is smaller or equal to the interval set by the lsa-generation-interval command.
Related command: lsa-generation-interval.
Example
# Set the LSA minimum repeat arrival interval to 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-arrival-interval 200
3.1.32  lsa-generation-interval
undo lsa-generation-interval
View
OSPF view
Parameter
maximum-interval: The maximum LSA generation interval in seconds, in the range 1 to 60.
minimum-interval: The minimum LSA generation interval in milliseconds, in the range 10 to 60,000, which defaults to 0 millisecond.
incremental-interval: LSA generation incremental interval in milliseconds, in the range 10 to 60,000, which defaults to 5,000 milliseconds.
Use the lsa-generation-interval command to configure the OSPF LSA generation interval.
Use the undo lsa-generation-interval command to restore the default.
The LSA generation interval defaults to 5 seconds.
With this command configured, when network changes are not frequent, an LSA is generated at the minimum-interval. If network changes become frequent, LSA generation interval is incremented by a specified value each time a generation happens, up to the maximum-interval.
Related command: lsa-arrival-interval.
Example
# Configure the LSA generation maximum interval as 2 seconds, minimum interval as 100 milliseconds and incremental interval as 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
3.1.33  lsdb-overflow-limit
lsdb-overflow-limit number
undo lsdb-overflow-limit
View
OSPF view
Parameter
number: Specifies the upper limit of external LSAs in the LSDB.
Use the lsdb-overflow-limit command to specify the upper limit of external LSAs in the LSDB.
Use the undo lsdb-overflow-limit command to cancel limitation.
The upper limit is unlimited by default.
Example
# Specify the upper limit of external LSAs as 400,000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
3.1.34  maximum load-balancing
maximum load-balancing maximum
View
OSPF view
Parameter
maximum: Maximum number of load-balanced routes, ranging 1 to 4. No load balancing is available when the number is set to 1.
Use the maximum load-balancing command to specify the maximum number of load-balanced routes.
By default, the maximum number of load-balanced routes is 4.
Example
# Specify the maximum number of load-balanced routes as 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
[Sysname] ospf 100
[Sysname-ospf-100] undo maximum load-balancing
3.1.35  maximum-routes
maximum-routes { external | inter | intra } number
undo maximum-routes { external | inter | intra }
View
OSPF view
Parameter
external: Specifies the maximum number of external routes.
inter: Specifies the maximum number of inter-area routes.
intra : Specifies the maximum number of intra-area routes.
number: Maximum route number, ranging 0 to 16,384.
Use the maximum-routes command to specify the maximum route number of a specified type: inter-area, intra-area, external.
Use the undo maximum-routes command to restore the default route maximum value of a specified type.
By default, the maximum number of routes is 16,384.
Example
# Specify the maximum number of intra-area routes as 500.
[Sysname] ospf 100
[Sysname-ospf-100] maximum-routes intra 500
3.1.36  network
undo network ipaddress wildcard-mask
View
OSPF area view
Parameter
ip-address: IP address of the network attached to an interface
wildcard-mask: Wildcard mask of the IP address
Use the network command to configure an interface falling into the specified network segment to run OSPF and to belong to the current area.
Use the undo network command to remove an interface running OSPF in the current area.
By default, an interface neither runs OSPF nor belongs to any area.
With the network command, you can configure one or multiple interfaces to belong to one area. The interface whose primary IP address falls into the network segment specified with the network command will run OSPF and belong to the current area.
Related command: ospf.
Example
# Specify the interface whose primary IP address falls into 131.108.20.0/24 to run OSPF, and specify the interface to belong to area2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
3.1.37  nssa
nssa [ default-route-advertise | no-import-route | no-summary ]*
undo nssa
View
OSPF area view
Parameter
default-route-advertise: Used on an NSSA ABR or an ASBR only. If configured on an NSSA ABR, the ABR generates a default route in a Type7 LSA into the NSSA regardless of whether the default route is available. If configured on an ASBR, only a default route is available on the ASBR can it generates a Type7 LSA into the attached area.
no-import-route: Used only on the NSSA ABR that is also the ASBR of the OSPF routing domain to disable redistributing any route in Type7 LSA into the NSSA area, making sure routes can be redistributed correctly.
no-summary: Used only on an NSSA ABR to advertise only a default route in a Type3 summary LSA into the NSSA area, and all other summary LSAs are not advertised into the area. Area of this kind is known as NSSA Totally Stub area.
Use the nssa command to configure the current area as an NSSA area.
Use the undo nssa command to restore the default.
By default, no NSSA area is configured.
All routers attached to an NSSA area must be configured with the nssa command in area view.
Related commands: default-cost.
Example
# Configure area1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] nssa
3.1.38  opaque-capability enable
undo opaque-capability
View
OSPF view
Parameter
None
Use the opaque-capability enable command to enable Opaque LSA advertisement.
Use the undo opaque-capability command to disable Opaque LSA advertisement.
The feature is disabled by default.
Example
# Enable opaque link state advertising.
[Sysname] ospf 100
[Sysname-ospf-100]opaque-capability enable
3.1.39  ospf
ospf [ process-id | router-id router-id ] *
undo ospf process-id
View
Parameter
router-id: OSPF router ID
Use the ospf command to enable an OSPF process.
Use the undo ospf command to disable an OSPF process.
OSPF is not enabled by default.
You can specify multiple OSPF processes on a router and different Router IDs for these processes.
Enabling OSPF first is required before performing other tasks.
Example
# Enable OSPF process 100 and specify Router ID as 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
3.1.40  ospf authentication-mode
For MD5/HMAC-MD5 authentication:
ospf authentication-mode { md5 | hmac-md5 } key-id [ plain | cipher ] password
undo ospf authentication-mode { md5 | hmac-md5 } key-id
For simple authentication:
ospf authentication-mode simple [ plain | cipher ] password
undo ospf authentication-mode simple
View
Interface view
Parameter
md5: MD5 authentication.
hmac-md5: HMAC-MD5 authentication.
simple: Simple authentication.
key-id: Authentication key ID, in the range 1 to 255.
plain | cipher : Plain or cipher password. If plain is specified, only plain password is supported and displayed upon displaying the configuration file. If cipher is specified, both plain and cipher are supported, but only cipher password is displayed when displaying the configuration file.
password: Password of plain or cipher. Simple authentication: For plain type password, a plain password is a string of up to 8 characters. For cipher type password, a plain password is a string of up to 8 characters, and a cipher password is a string of up to 24 characters. MD5/HMAC-MD5 authentication: For plain type password, a plain password is a string of up to16 characters. For cipher type password, a plain password is a string of up to 16 characters, and a cipher password is a string of up to 24 characters.
Use the ospf authentication-mode command to set the authentication mode and key ID on an interface.
Use the undo ospf authentication-mode command to remove specified configuration.
By default, no authentication is available on an interface.
Interfaces attached to the same network segment must have the same authentication password and mode.
This configuration is not supported on the NULL interface.
Related command: authentication-mode.
Example
# Configure the network 131.119.0.0/16 in area1 to support MD5 cipher authentication, and set the interface key ID to 15, authentication password to password, and password type to cipher.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] network 131.119.0.0 0.0.255.255
[Sysname-ospf-100-area-0.0.0.1] authentication-mode md5
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname-Vlan-interface10] ospf authentication-mode md5 15 cipher password
# Configure the network 131.119.0.0/16 in area1 to support simple authentication, and set for the interface the authentication password to password, and password type to cipher.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] authentication-mode simple
[Sysname-Vlan-interface10] ospf authentication-mode simple cipher password
3.1.41  ospf cost
ospf cost value
undo ospf cost
View
Interface view
Parameter
value: Value of OSPF cost, in the range 1 to 65535.
Use the ospf cost command to set the cost value for an OSPF interface.
Use the undo ospf cost command to restore the default cost for an OSPF interface.
By default, an OSPF interface calculates its cost automatically: Interface default cost=100000000(bit/s)/Interface bandwidth(bit/s), default costs of some interfaces are:
l           1785 for the 56 Kbps serial interface
l           1562 for the 64 Kbps serial interface
l           48 for the E1 (2.048 Mbps) interface
l           1 for the Ethernet interface
You can use the ospf cost command to set interface cost manually.
Example
# Set the current OSPF interface cost to 65.
[Sysname-Vlan-interface10] ospf cost 65
3.1.42  ospf dr-priority
ospf dr-priority priority
undo ospf dr-priority
View
Interface view
Parameter
priority: DR Priority of the interface, in the range 0 to 255.
Use the ospf dr-priority command to set the priority for DR/BDR election on an interface.
Use the undo ospf dr-priority command to restore the default value.
By default, the priority is 1.
The bigger the value is, the higher the priority.
Example
# Set the DR priority on the current interface to 8.
[Sysname-Vlan-interface10] ospf dr-priority 8
3.1.43  ospf mib-binding
ospf mib-binding process-id
undo ospf mib-binding
View
Parameter
Use the ospf mib-binding command to bind an OSPF process to MIB operation.
Use the undo ospf mib-binding command to restore the default.
By default, MIB operation is bound to the first enabled OSPF process.
Example
# Bind OSPF process 100 to MIB operation.
[Sysname] ospf mib-binding 100
# Restore the default, that is, bind the first enabled OSPF process to MIB operation
[Sysname] undo ospf mib-binding
3.1.44  ospf mtu-enable
ospf mtu-enable
undo ospf mtu-enable
View
Interface view
Parameter
None
Use the ospf mtu-enable command to enable an interface to add real MTU into DD packets.
Use the undo ospf mtu-enable command to restore the default.
By default, an interface adds the MTU value of 0 into DD packets, that is, no real MTU is added.
You can use this command to add the real MTU value into DD packets on an interface.
After a virtual link established via Tunnel, two devices on the link from different manufactures may have different MTU values. To make them compatible, set the attached interface’s default MTU to 0, so you don’t need to use the ospf mtu-enable command in this case.
Example
# Enable the interface to add real MTU value into DD packets.
[Sysname-Vlan-interface10] ospf mtu-enable
3.1.45  ospf network-type
ospf network-type { broadcast | nbma | p2mp | p2p }
undo ospf network-type
View
Interface view
Parameter
broadcast: Specifies the network type as Broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
p2p: Specifies the network type as P2P.
Use the ospf network-type command to set the network type for an interface.
Use the undo ospf network-type command to restore the default network type for an interface.
By default, the network type of an interface depends on its physical media. The network type for Ethernet interfaces is Broadcast, for serial interfaces is P2P, and for ATM interfaces is NBMA.
If an interface attached to a broadcast network does not support multicast, you can configure the interface’s network type as NBMA or change NBMA to Broadcast. In this case, you do not need to configure any neighbor router.
The requirements for changing the type of a network from NBMA to Broadcast on an interface: Any two routers in the network are directly connected via a virtual link, or the network is fully meshed. If a network cannot meets the requirements, you have to change the network type of an attached interface to P2MP, thus two routers having no direct link can exchange routing information via another router. After changing the network type to P2MP, you do not need to configure any neighbor router.
If only two routers run OSPF on a network segment, you can configure associated interfaces’ network type as P2P.
Related command: ospf dr-priority.
&  Note:
When changing an interface’s network type to NBMA or the interface’s network type is NBMA, you need to use the peer command to configure adjacencies.
Example
# Configure the current interface’s network type as NBMA.
[Sysname-Vlan-interface10] ospf network-type nbma
3.1.46  ospf timer dead
ospf timer dead seconds
undo ospf timer dead
View
Interface view
Parameter
seconds: Dead interval in seconds, in the range 1 to 2,147,483,647.
Use the ospf timer dead command to set the dead interval.
Use the undo ospf timer dead command to restore the default.
The dead interval defaults to 40s for Broadcast, P2P interfaces and defaults to 120s for P2MP and NBMA interfaces
If an interface receives no Hello packet from the neighbor after the dead interval elapsed, the interface considers the neighbor as dead. The dead interval on an interface is at least four times the hello interval. Any two routers attached to the same segment must have the same dead interval.
Related command: ospf timer hello.
Example
# Configure the dead interval on the current interface as 60 seconds.
[Sysname-Vlan-interface10] ospf timer dead 60
3.1.47  ospf timer hello
ospf timer hello seconds
undo ospf timer hello
View
Interface view
Parameter
seconds: Hello interval in seconds, in the range 1 to 65535.
Use the ospf timer hello command to set the hello interval on an interface.
Use the undo ospf timer hello command to restore the default hello interval on an interface.
The hello interval defaults to 10s for P2P and Broadcast interfaces, and defaults to 30s for P2MP and NBMA interfaces
The shorter the hello interval, the faster the topology convergence speed and the more resources consumed. Make sure the hello interval on two neighboring interfaces is the same.
Related command: ospf timer dead.
Example
#Configure the hello interval on the current interface as 20 seconds.
[Sysname-Vlan-interface10] ospf timer hello 20
3.1.48  ospf timer poll
ospf timer poll seconds
undo ospf timer poll
View
Interface view
Parameter
seconds: Poll interval in seconds, in the range 1 to 2,147,483,647.
Use the ospf timer poll command to set the poll interval on an NBMA or P2MP interface.
Use the undo ospf timer poll command to restore the default value.
By default, the poll interval defaults to 120s.
When an NBMA or P2MP interface finds its neighbor is dead, it will send hello packets at poll intervals. The poll interval is at least four times the hello timer interval.
Example
# Set the poll timer interval on the current interface to 130 seconds.
[Sysname-Vlan-interface10] ospf timer poll 130
3.1.49  ospf timer retransmit
ospf timer retransmit interval
undo ospf timer retransmit
View
Interface view
Parameter
interval: LSA retransmit timer interval in seconds, in the range 1 to 3,600.
Use the ospf timer retransmit command to set the LSA retransmit interval on an interface.
Use the undo ospf timer retransmit command to restore the default.
The interval defaults to 5s.
After sending a LSA, an interface waits for an acknowledgement packet. If the interface receives no acknowledgement when the retransmit interval elapses, it will retransmit the LSA.
The retransmit interval should not be so small to avoid unnecessary retransmissions.
Example
# Set the LSA retransmit interval to 8 seconds.
[Sysname-Vlan-interface10] ospf timer retransmit 8
3.1.50  ospf trans-delay
ospf trans-delay seconds
undo ospf trans-delay
View
Interface view
Parameter
seconds: LSA transmit delay time in seconds, in the range 1 to 3,600.
Use the ospf trans-delay command to set the LSA transmit delay time on an interface.
Use the undo ospf trans-delay command to restore the default.
The delay time defaults to 1s.
Each LSA in the LSDB has an age (incremented 1 by a second), but a LSA is not aged out on transmission. It is necessary to add a transmit delay into its age time, which is important for transmission on low speed networks.
Example
# Set the LSA transmit delay time to 3 seconds on the current interface.
[Sysname-Vlan-interface10] ospf trans-delay 3
3.1.51  peer
peer ip-address [ dr-priority dr-priority ]
undo peer ip-address
View
OSPF view
Parameter
ip-address: Neighbor IP address.
dr-priority: Neighbor DR priority, in the range 0 to 255, the bigger the value, the higher the priority.
Use the peer command to specify the IP address of an NBMA neighbor, and the DR priority of the neighbor.
Use the undo peer command to remove the configuration.
The DR priority of NBMA neighbors defaults to 1.
On an X.25 or Frame Relay network, you can configure mappings to make the network fully meshed (any two routers have a direct link in between), so OSPF can handle such as DR/BDR election like on a broadcast network. Because routers cannot find neighbors via broadcast Hello packets, you need to specify neighbors and DR priorities on routers.
After booting, a router sends a Hello packet to routers with priorities higher than 0. When the DR and BDR are elected, they will send Hello packets to all neighbors for adjacency establishment.
Rather than using the priority set by the peer command for DR election, a router uses the priority to determine whether to send a Hello packet to the neighbor.
Example
# Specify the neighbor IP address 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
3.1.52  preference
preference [ ase ] [ route-policy route-policy-name ] value
undo preference [ ase ]
View
OSPF view
Parameter
ase: Sets priority for ASE routes. If the keyword is not specified, using the command sets priority for internal routes.
route-policy: Applies a route policy to set priorities for specified routes.
route-policy-name: Rout policy name, a string of 1 to 19 characters.
value: Priority value, in the range 1 to 255.
Use the preference command to set the priority of OSPF routes.
Use the undo preference command to restore the default.
The priority of OSPF internal routes defaults to 10, and the priority of OSPF external routes defaults to 150.
The smaller the value, the higher the priority.
If a route-policy is applied, priorities defined by the route-policy will apply, and priorities not defined by the policy will still use values set by the preference command.
Since a router may run multiple routing protocols, it has to decide on routes found by these protocols. Every protocol has a priority to help the router determine which route to use especially when multiple routes to the same destination are found by several routing protocols. The route found by the protocol with the highest priority will be used.
Example
# Set OSPF priority to 150.
[Sysname] ospf 100
[Sysname-ospf-100] preference 150
3.1.53  reset ospf counters
reset ospf [ process-id ] counters [ neighbor [ interface-type interface-number ] [ router-id ] ]
View
Parameter
neighbor: Clears neighbor statistics on an interface.
router-id: Neighbor router ID.
Use the reset ospf counters command to reset OSPF counters. If no OSPF process is specified, counters of all OSPF processes are reset.
Example
# Clear OSPF counters.
<Sysname> reset ospf counters
3.1.54  reset ospf process
View
Parameter
graceful-restart: Specifies to perform graceful restart
Use the reset ospf process command to reset all OSPF processes or a specified process.
Using the reset ospf process command will:
l           Clear all invalid LSAs without waiting for their timeouts
l           Make a newly configured Router ID take effect
l           Start a new round of DR/BDR election
l           Not loss any other previous OSPF configuration
The system prompts whether to reset OSPF process upon execution of this command.
You can choose to perform a normal restart or Graceful Restart.
Example
# Reset all OSPF processes with Graceful Restart.
<Sysname> reset ospf process graceful-restart
Warning : Reset OSPF process? [Y/N]y
3.1.55  reset ospf redistribution
View
Parameter
Use the reset ospf redistribution command to restart route redistribution.
Example
# Restart route redistribution.
<Sysname> reset ospf redistribution
3.1.56  rfc1583 compatible
rfc1583 compatible
undo rfc1583 compatible
View
OSPF view
Parameter
None
Use the rfc1583 compatible command to make routing rules defined in RFC1583 compatible.
Use the undo rfc1583 compatible command to disable the function.
By default, RFC1583 routing rules are compatible.
On selecting the best route when multiple AS external LSAs describe routes to the same destination, RFC1583 and RFC2328 have different routing rules.
Example
# Make RFC1583 routing rules compatible.
[Sysname] ospf 100
[Sysname-ospf-100] rfc1583 compatible
3.1.57  silent-interface
silent-interface { all | interface-type interface-number }
undo silent-interface { all | interface-type interface-number }
View
OSPF view
Parameter
all: Specifies all interfaces to disable them from sending OSPF packet.
Use the silent-interface command to disable specified interfaces from sending any OSPF packet.
Use the undo silent-interface command to restore default configuration.
By default, an interface sends OSPF packets.
A disabled interface is a Passive Interface, which cannot send any Hello packet.
To make no routing information obtained by other routers on a network segment, you can use this command to disable the interface from sending OSPF packets.
Example
# Disable an interface from sending OSPF packets.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface vlan-interface 10
3.1.58  snmp-agent trap enable ospf
snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | txretransmit | vifauthfail | vifcfgerror | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
undo snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | txretransmit | vifauthfail | vifcfgerror | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
View
Parameter
ifauthfail: Interface authentication failure information.
ifcfgerror: Interface configuration error information.
ifrxbadpkt: Information about error packets received.
ifstatechange: Interface state change information.
lsdbapproachoverflow: Information about cases approaching LSDB overflow
lsdboverflow: LSDB overflow information.
maxagelsa: LSA max age information.
nbrstatechange: Neighbor state change information.
originatelsa: Information about LSAs originated locally.
txretransmit: Packet receiving and forwarding information.
vifauthfail: Virtual interface authentication failure information.
vifcfgerror: Virtual interface configuration error information.
virifrxbadpkt: Information about error packets received by virtual interfaces.
virifstatechange: Virtual interface state change information.
viriftxretransmit: Virtual interface packet retransmit information.
virnbrstatechange: Virtual interface neighbor state change information.
Use the snmp-agent trap enable ospf command to enable TRAP function for a specified OSPF process. If no process is specified, TRAP function for all processes is enabled.
Use the undo snmp-agent trap enable ospf command to disable the function.
By default, this function is enabled.
Refer to SNMP-RMON for related information.
Example
# Enable trap packet transmission for all OSPF processes.
[Sysname] snmp-agent trap enable ospf
3.1.59  spf-schedule-interval
undo spf-schedule-interval
View
OSPF view
Parameter
maximum-interval: Maximum SPF calculation interval in seconds, in the range 1 to 60.
minimum-interval: Minimum SPF calculation interval in milliseconds, in the range 10 to 60,000.
incremental-interval: Incremental value for increasing SPF calculation interval in milliseconds, in the range 10 to 60,000.
Use the spf-schedule-interval command to set the OSPF SPF calculation interval.
Use the undo spf-schedule-interval command to restore the default.
The maximum SPF calculation interval defaults to 5 seconds.
Based on its LSDB, an OSPF router calculates the shortest route tree with itself as the root, using which to determine the next hop to a destination. Through adjusting SPF calculation interval, you can protect bandwidth and router resources from being over-consumed due to frequent network changes.
With this command configured, when network changes are not frequent, SPF calculation applies at the minimum-interval. If network changes become frequent, SPF calculation interval is incremented each time a calculation happens, up to the maximum-interval.
Example
# Configure the SPF calculation maximum interval as 10 seconds, minimum interval as 500 milliseconds and incremental interval as 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 200
3.1.60  stub
stub [ no-summary ]
undo stub
View
OSPF area view
Parameter
no-summary: Used only on a stub ABR. With it configured, the ABR advertises only a default route in a Summary LSA into the stub area (Stub area of this kind is known as totally stub area).
Use the stub command to configure an area as a stub area.
Use the undo stub command to remove the configuration.
No area is stub area by default. To configure an area as a stub area, all routers attached to it must be configured with this command.
Related command: default-cost.
Example
# Configure area1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
3.1.61  stub-router
stub-router
undo stub-router
View
OSPF view
Parameter
None
Use the stub-router command to enable a stub router. In router LSAs originated by a stub router, the costs for all links are set to the max value 65535. Therefore, its neighbors will calculate a big cost of sending a packet to the stub router. When a route with a smaller cost is available for a destination, the neighbor will not choose the stub router.
Use the undo stub-router command to restore the default.
By default, no stub router is configured.
Example
# Enable a stub-router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
3.1.62  vlink-peer
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | simple [ plain | cipher ] password | { md5 | hmac-md5 } key-id [ plain | cipher ] password ] *
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead | [ simple | { md5 | hmac-md5 } key-id ] ] *
View
OSPF area view
Parameter
router-id: ID of the neighbor router on the virtual link.
hello seconds: Hello interval in seconds, in the range 1 to 81,92, which defaults to 10 and is identical to the value on its virtual link neighbor.
retransmit seconds: Retransmit interval in seconds, in the range 1 to 3,600, which defaults to 5.
trans-delay seconds: Transmit delay interval in seconds, in the range 1 to 3,600, which defaults to 1.
dead seconds: Dead interval in seconds, in the range 1 to 32,768, which defaults to 40 and is identical to the value on its virtual link neighbor.
key-id: Key ID for MD5 or HMAC-MD5 authentication, in the range 1 to 255.
plain | cipher: Plain or cipher type. If plain is specified, only plain password is supported and displayed upon displaying the configuration file. If cipher is specified, both plain and cipher password are supported, but only cipher password is displayed when displaying the configuration file. By default, MD5 and HMAC-MD5 supports cipher password, and Simple supports plain password.
password: Password of plain or cipher. Simple authentication: For plain type, a plain password is a string of up to 8 characters. For cipher type, a plain password is a string of up to 8 characters, and a cipher password is a string of up to 24 characters. MD5/HMAC-MD5 authentication: For plain type, a plain password is a string of up to16 characters. For cipher type, a plain password is a string of up to 16 characters, and a cipher password is a string of up to 24 characters.
Use the vlink-peer command to create and configure a virtual link.
Use the undo vlink-peer command to remove a virtual link.
As defined in RFC2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
Considerations on parameters:
l           The smaller the hello interval is, the faster the network changes and the more network resource consumed.
l           The fact that the retransmit interval is too small will lead to unnecessary retransmissions. A bigger value is appropriate for a low speed network.
l           Consideration on interface transmission delay is necessary for specifying the trans-delay value.
The authentication mode (MD5 or Simple) at the non-backbone virtual link end follows the one at the backbone virtual link end. The two authentication modes are independent. You can specify neither of them.
Related command: authentication-mode, display ospf.
Example
# Configure a virtual link with the neighbor router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
Chapter 4  IS-IS Configuration Commands
&  Note:
The “router” in this document refers to a generic router or an Ethernet switch running routing protocols.
4.1  IS-IS Configuration Commands
4.1.1  area-authentication-mode
area-authentication-mode { simple | md5 } password [ ip | osi ]
undo area-authentication-mode
View
IS-IS view
Parameter
simple: Specifies to send the password in plain text.
md5: Specifies to send the password encrypted with MD5.
password: Password to be set. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or ciphertext. A plaintext password can be a string of up to 16 characters, such as user918. A cipher password must be a ciphertext string of up to 24 characters, such as (TT8F]Y\5SQ=^Q`MAF4<1!!.
ip: Specifies the system to check the configuration for the corresponding field of IP in LSP.
osi: Specifies the system to check the configuration for the corresponding field of OSI in LSP.
&  Note:
Whether a password should use ip or osi is not affected by the actual network environment.
Use the area-authentication-mode command to specify the IS-IS authentication mode and password for authenticating the received Level-1 routing packets (LSP, CSNP and PSNP). Packets with different passwords are discarded. The system also inserts the specified password into outbound Level-1 routing packets.
Use the undo area-authentication-mode command to disable such authentication.
No authentication for received Level-1 packets is provided by default.
Related command: reset isis all, domain-authentication-mode, isis authentication-mode
Example
# Set the area authentication password to hello, and the authentication mode to simple.
[Sysname] isis
[Sysname-isis-1] area-authentication-mode simple hello
4.1.2  auto cost enable
auto-cost enable
undo auto-cost enable
View
IS-IS view
Parameter
None
Use the auto-cost enable command to enable interfaces of the current IS-IS process to calculate interface cost automatically.
Use the undo auto-cost enable command to disable the function.
This function is disabled by default.
The preference of interface cost set by the auto-cost command is lower than that set by the circuit-cost command. The preference from high to low is: the cost set by the isis cost command, the global cost set by the circuit cost command, the cost automatically calculated and the default cost.
When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the following formula:
cost = (reference value/bandwidth)×10.
Related command: bandwidth-reference, cost-style.
Example
# Enable interfaces of IS-IS process 1 to calculate interface cost automatically.
[Sysname] isis
[Sysname-isis-1] auto-cost enable
4.1.3  bandwidth-reference
bandwidth-reference value
undo bandwidth-reference
View
IS-IS view
Parameter
value: Bandwidth reference value in Mbps, ranging from 1 to 2147483648.
Use the bandwidth-reference command to set the bandwidth reference value for calculating link cost.
Use the undo bandwidth-reference command to restore the default.
By default, the reference value is 100 Mbps.
Related command: auto-cost enable.
Example
# Configure the bandwidth reference of IS-IS process 1 as 200 Mbps.
[Sysname] isis
[Sysname-isis-1] bandwidth-reference 200
4.1.4  circuit-cost
circuit-cost value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
View
IS-IS view
Parameter
value: Specifies the global link cost value. The value range varies with cost types.
l           For types narrow, narrow-compatible and compatible: The cost value ranges from 0 to 63.
l           For types wide and wide-compatible: The cost value ranges from 0 to 16777215.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
Use the circuit-cost command to set a global link cost.
Use the undo circuit-cost command to restore the default.
By default, the global link cost is not configured.
If no keyword is specified, the specified cost applies to Level-1-2.
The preference of interface cost from high to low is: the cost set by the isis cost command, the global cost set by the circuit-cost command, the cost automatically calculated (auto-cost) and the default cost.
Related command: isis cost, cost-style.
Example
# Set the global Level-1 link cost of IS-IS process 1 to 11.
[Sysname] isis
[Sysname-isis-1] circuit-cost 11 level-1
4.1.5  cost-style
undo cost-style
View
IS-IS view
Parameter
narrow: Specifies to receive and send only packets of narrow cost style (The narrow cost ranges from 0 to 63).
wide: Specifies to receive and send only packets of wide cost style (The wide cost ranges from 0 to 16777215).
compatible: Specifies to receive and send both wide and narrow style packets.
narrow-compatible: Specifies to receive both narrow and wide style packets, but send only narrow style packets.
wide-compatible: Specifies to receive both narrow and wide style packets, but send only wide style packets.
relax-spf-limit: Specifies to allow receiving routes with cost bigger than 1,023. If this keyword is not configured, any route with cost bigger than 1,023 will be discarded. This keyword is only available when keywords compatible and narrow-compatible are included.
Use the cost-style command to set the cost style of packets.
Use the undo cost-style command to restore the default.
Only packets of narrow cost style can be received and sent by default.
Related command: isis cost.
Example
# Configure the router to send only packets of narrow cost style, but receive both narrow and wide cost style ones.
[Sysname] isis
[Sysname-isis-1] cost-style narrow-compatible
4.1.6  default-route-advertise
default-route-advertise [ route-policy route-policy-name | [ level-1 | level-2 | level-1-2 ] ] *
undo default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
Parameter
route-policy-name: Specifies the name of a routing policy, a string of 1 to 19 characters.
level-1: Specifies the level of the default route as Level-1.
level-2: Specifies the level of the default route as Level-2.
level-1-2: Specifies the level of the default route as Level-1-2.
&  Note:
If no level is specified, a Level-2 default route is generated.
Use the default-route-advertise command to generate a Level-1 or Level-2 default route.
Use the undo default-route-advertise command to disable the function.
Using the apply isis level-1 command in routing policy view will generate a default route in L1 LSP. Using the apply isis level-2 command in routing policy view will generate a default route in L2 LSP. Using the apply isis level-1-2 command in routing policy view will generate a default route in L1 LSP and L2 LSP respectively.
Example
# Generate a default route in L2 LSP.
[Sysname] isis
[Sysname-isis-1] default-route-advertise
4.1.7  display isis brief
display isis brief [ process-id ]
View
Parameter
process-id: IS-IS process ID, in the range of 1 to 65535.
Use the display isis brief command to view brief IS-IS configuration information.
Example
# Display brief IS-IS configuration information.
<Sysname> display isis brief
                  ISIS 1 Protocol Brief Information :
 network-entity:
     10.0000.0000.0001.00
 is-level :level-1-2
 cost-style:  narrow
 preference :  15
 Lsp-length receive :  1497
 Lsp-length originate :  level-1 1497
                         level-2 1497
 Timers:
     spf-slice-size:  0
     lsp-max-age:  1200
     lsp-refresh:  900
     Interval between SPFs:  level-1 10
                             level-2 10
Table 4-1 Description on the fields of the display isis brief command
network-entity
Network entity name
is-level
IS-IS Routing level
cost-style
Cost style
preference
Preference
Lsp-length receive
Maximum LSP that can be received
Maximum LSP that can be generated
Timers
Timers
spf-slice-size
Time of each SPF calculation slice (0 means SPF calculation time is not split.)
lsp-max-age
Maximum life period of LSP
lsp-refresh
Refresh period of LSP
Interval between SPF calculations
4.1.8  display isis interface
display isis interface [ verbose ] [ process-id ]
View
Parameter
verbose: Displays IS-IS interface detail information.
process-id: IS-IS process ID, in the range of 1 to 65535..
Use the display isis interface command to view IS-IS enabled interface information.
The information displayed by this command includes interface name, interface IP address, interface link state and so on. Besides all the information displayed by display isis interface, using the display isis interface verbose command displays other interface related information, such as CSNP packets broadcast intervals, Hello packets broadcast intervals and the number of invalid Hello packets.
Example
# Display IS-IS enabled interface information.
<Sysname> display isis interface
                       Interface information for ISIS(1)
  Interface:  Vlan-interface1
  Id      IPV4.State           IPV6.State        MTU  Type  DIS
  001          Up                  Down          1497 L1/L2 No/Yes
# Display detailed IS-IS enabled interface information.
<Sysname> display isis interface verbose
  SNPA Address                : 000f-e200-2201
  IP Address                  : 192.168.0.36
  Secondary IP Address(es)    :
  IPV6 Link Local Address     :
  IPV6 Global Address(es)     :
  Csnp Timer Value            :  L1    10  L2    10
  Hello Timer Value           :  L1    10  L2     3
  Hello Multiplier Value      :  L1     3  L2     3
  Lsp Timer Value             :  L12   33
  Cost                        :  L1    10  L2    10
  Priority                    :  L1    64  L2    64
  Retransmit Timer Value      :  L12    5
Table 4-2 Description on the fields of the display isis interface command
Id
Circuit ID
IPV4.State
IPv4 state
IPV6.State
IPv6 state
MTU
Interface MTU
Interface link type
DIS
Designated IS
SNPA Address
Subnet access point address
IP Address
Primary IP address
Secondary IP addresses
IPv6 link local address
IPv6 global address
Csnp Timer Value
Interval for sending CSNP packets
Hello Timer Value
Interval for sending Hello packets
Number of invalid Hello packets
Lsp Timer Value
Interval for sending LSP packets
Cost
Cost
Priority
Preference
LSP retransmission interval over point-to-point link
4.1.9  display isis license
View
Parameter
None
Use the display isis license command to display the information of the IS-IS license.
Example
# Display the information of the IS-IS license.
<Sysname> display isis license
                      ISIS Shell License Values
                      _________________________
 Feature Name         Active     Controllable
 ISIS Protocol        YES        NO
 IPV6                 YES        NO
 RESTART              YES        NO
 TE                   NO         NO
 MI                   NO         NO
 Resource Name             MinVal     MaxVal     CurrVal    Controllable
 Max Processes Resource    1          4          4          0
 Max Paths Resource        1          4          4          0
 Max IPv4 Rt Resource      12288      12288      12288      0
 Max IPv6 Rt Resource      4096       4096       4096       0
                      ISIS Core License Values
 Feature Name         Active
 ISIS Protocol        YES
 IPV6                 YES
 RESTART              YES
 TE                   NO
 MI                   NO
 Resource Name             Current Value
 Max Processes Resource    4
 Max Paths Resource        4
Table 4-3 Description on the fields of the display isis license command
License values of ISIS shell
Feature Name
Feature name
Active
Whether the state is active.
Controllable
Whether support reading configuration through License file.
ISIS Protocol
IS-IS Protocol
IPV6
IPv6
RESTART
Graceful Restart (GR)
TE
Traffic Engineering
MI
Multi-instance
Resource Name
Resource name
MinVal
Minimum value
MaxVal
Maximum value
CurrVal
Current value
License values of ISIS Core
Maximum number of processes supported
Max Paths Resource
Maximum equal cost paths
Maximum IPv4 routes supported
Maximum IPv6 routes supported
4.1.10  display isis lsdb
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ lsp-id LSPID | lsp-name lspname ] | local | verbose ] * [ process-id ]
View
Parameter
l1, level-1: Specifies level-1 LSDB.
l2, level-2: Specifies level-2 LSDB.
LSPID: LSP ID, in the form of sysid. Pseudo ID-fragment num.
lspname: LSP name, in the form of Symbolic name.[Pseudo ID]-fragment num.
local: Displays LSP information generated locally.
verbose: Displays LSDB detailed information.
&  Note:
If no level is specified, then both Level-1 and Level-2 (or Level-1-2) link state databases are displayed by default.
Use the display isis lsdb command to display IS-IS link state database.
Example
# Display Level-1 LSDB information.
<Sysname> dis isis lsdb level-1
                        Database information for ISIS(1)
                          Level-1 Link State Database
LSPID                  Seq Num      Checksum   Holdtime      Length  ATT/P/OL
0000.0000.0004.00-00* 0x000000130 x1b52      398           54      1/0/0
Table 4-4 Description on the fields of the display isis lsdb command
LSPID
Link state packet ID
Seq Num
LSP sequence number
Checksum
LSP checksum
Holdtime
LSP holdtime
Length
LSP length
ATT/P/OL
Attach bit (ATT)
Partition bit (P)
Overload bit (OL)
4.1.11  display isis mesh-group
display isis mesh-group [ process-id ]
View
Parameter
process-id: Specifies an IS-IS process ID, in the range of 1 to 65535.
Use the display isis mesh-group command to display IS-IS mesh-group.
Example
# Configure Vlan-interface 10 and Vlan-interface 20 on a switch to belong to mesh-group 100. (The process to establish Vlan-interface 10 and Vlan-interface 20 is omitted.)
[Sysname-Vlan-interface10] isis mesh-group 100
[Sysname-Vlan-interface10] quit
[Sysname] interface vlan-interface 20
[Sysname-Vlan-interface20] isis mesh-group 100
[Sysname-Vlan-interface20] quit
# Display the configuration information of IS-IS mesh-group.
[Sysname] display isis mesh-group
                       Mesh Group information for ISIS(1)
 Interface          Status
 Vlan10              100
 Vlan20              100
4.1.12  display isis name-table
display isis name-table [ process-id ]
View
Parameter
Use the display isis name-table command to display the host name-to-system ID mapping table.
Example
# Configure a name for the local IS-IS system.
[Sysname] isis
[Sysname-isis-1] is-name RUTA
# Configure a static mapping for the remote IS-IS system (0000.0000.0041).
[Sysname-isis-1] is-name map 0000.0000.0041 RUTB
# Display the IS-IS host name-to-system ID mapping table.
[Sysname-isis-1] display isis name-table
                       Name table information for ISIS(1)
 System ID            Hostname                            Type
0000.0000.0004        RUTA                                DYNAMIC
0000.0000.0041        RUTB                                STATIC
Table 4-5 Description on the fields of the display isis name-table command
System ID
System ID
Hostname
Hostname name of the system ID
Mapping type of system ID to host name (static or dynamic)
4.1.13  display isis peer
display isis peer [ verbose ] [ process-id ]
View
Parameter
verbose: When this parameter is used, the area address advertised in a neighbor’s Hello packet will be displayed. Otherwise the system displays only the summary information.
Use the display isis peer command to display IS-IS neighbor information.
Besides all the information displayed using the display isis peer command, the display isis peer verbose command displays neighbor area address, hold time of Up state and direct interface’s IP address.
Example
# Display detailed IS-IS neighbor information.
<Sysname> display isis peer verbose
                          Peer information for ISIS(1)
  System Id: 0000.0000.0006
  Interface: Vlan-interface1         Circuit Id: 0000.0000.0004.01
  State: Up     HoldTime: 198s       Type: L2(L1L2)     PRI: 64
  Area Address(es):86.0001
  Peer IP Address(es): 192.168.0.236
  Uptime: 00:40:34
  Adj Protocol:  IPV4
Table 4-6 Description on the fields of the display isis peer command
System Id
System ID
Interface connecting to the neighbor
Circuit Id
Circuit ID
HoldTime
Holdtime
Type of the neighbor
PRI
DIS Priority
Area Address(es)
The neighbor’s area address
Peer IP Address(es)
Interface IP address of the neighbor
Uptime
Time being up
Adj Protocol
Adjacency protocol
4.1.14  display isis route
display isis route [ ipv4 | [ level-1 | level-2 ] | verbose ] * [ process-id ]
View
Parameter
ipv4: Displays IS-IS IPv4 routing information (the default).
verbose: Displays IS-IS detailed IPv4 routing information.
level-1: Displays Level-1 IS-IS routes.
level-2: Displays Level-2 IS-IS routes.
&  Note:
If no level is specified, then both Level-1 and Level-2 (Level-1-2) routing information will be displayed.
Use the display isis route command to display IS-IS IPv4 routing information.
Example
# Display IS-IS IPv4 routing information
<Sysname> display isis route
                         Route information for ISIS(1)
                     ISIS(1) IPv4 Level-1 Forwarding Table
 IPV4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 192.168.0.0/24       10         NULL    Vlan1            Direct          R/L/-
      Flags: R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
                     ISIS(1) IPv4 Level-2 Forwarding Table
Table 4-7 Description on the fields of the display isis route command
IPV4 Destination
IPv4 destination address
IntCost
Interior routing cost
ExtCost
Exterior routing cost
ExitInterface
Exit interface
NextHop
Next hop
Flags
Routing state flag
R: The route has been added into the routing table.
L: The route has been broadcasted.
U: A route’s penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
4.1.15  display isis spf-log
display isis spf-log [ process-id ]
View
Parameter
Use the display isis spf-log command to display IS-IS SPF log record.
Example
# Display IS-IS SPF log record.
<Sysname> display isis spf-log
                        SPF Log information for ISIS(1)
   Level    Trig.Event                      No.Nodes  Duration   StartTime
   L2       IS_SPFTRIG_PERIODIC             2         0          13:3:24
   L1       IS_SPFTRIG_PERIODIC             2         0          13:18:8
   L2       IS_SPFTRIG_PERIODIC             2         0          13:18:8
   L1       IS_SPFTRIG_PERIODIC             2         0          13:32:28
   L2       IS_SPFTRIG_PERIODIC             2         0          13:32:28
   L1       IS_SPFTRIG_PERIODIC             2         0          13:44:0
   L2       IS_SPFTRIG_PERIODIC             2         0          13:44:0
   L1       IS_SPFTRIG_PERIODIC             2         0          13:55:43
-->L2       IS_SPFTRIG_PERIODIC             2         0          13:55:43
   L1       IS_SPFTRIG_PERIODIC             2         0          11:54:12
   L2       IS_SPFTRIG_PERIODIC             2         0          11:54:12
   L1       IS_SPFTRIG_PERIODIC             2         0          12:7:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:7:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:21:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:21:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:35:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:35:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:49:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:49:24
   L1       IS_SPFTRIG_PERIODIC             2         0          13:3:24
Table 4-8 Description on the fields of the display isis spf-log command
Level
SPF calculation level
Trig.Event
SPF triggered event
No.Nodes
Number of SPF calculation nodes
Duration
SPF calculation duration
StartTime
SPF calculation start time
4.1.16  display isis statistics
display isis statistics [ level-1 | level-2 | level-1-2 ] [ process-id ]
View
Parameter
level-1: IS-IS Level-1 statistic information.
level-2: IS-IS Level-2 statistic information.
level-1-2: IS-IS Level-1-2 statistic information.
Use the display isis statistics command to display the statistic information of IS-IS process, including the number of routes learned from other IS-IS routers, the number of routes redistributed from other protocols and the number of LSP generated locally.
Example
# Display IS-IS statistic information.
<Sysname> display isis statistics
                       Statistics information for ISIS(1)
                Routes Statistics in ISIS IPv4/IPv6 Route Table
Routes information:
        Total IPv4 Learnt Routes in ISIS IPv4 Route Table: 2
        Total IPv6 Learnt Routes in ISIS IPv6 Route Table: 0
                               Level-1 Statistics
Learnt routes information:
        Total IPv4 Learnt Destinations: 1
        Total IPv6 Learnt Destinations: 0
Imported routes information:
        IPv4 Imported Routes:
                        Static: 0       Direct: 0
                        ISIS:   0       BGP:    0
                        RIP:    0       OSPF:   0
        IPv6 Imported Routes:
                        Static: 0       Direct: 0
                        ISISv6: 0       BGP4+:  0
                        RIPng:  0       OSPFv3: 0
Lsp information:
                 LSP Source ID:          No. of used LSPs
                 0000.0000.0004                  001
                               Level-2 Statistics
                        Static: 0       Direct: 0
                        ISIS:   0       BGP:    0
                        RIP:    0       OSPF:   0
                        Static: 0       Direct: 0
                        ISISv6: 0       BGP4+:  0
                        RIPng:  0       OSPFv3: 0
Lsp information:
                 0000.0000.0004                  001
Table 4-9 Description on the fields of the display isis statistics command
Statistics information for ISIS(processid)
Statistics for the ISIS process
IPv4/IPv6 routing table statistics of the ISIS process
Routes information
Routing information
Level-1 Statistics
Level-1 Statistics
Level-2 Statistics
Level-2 Statistics
Redistributed IPv4 routes
l      Static
l      Direct
l      ISIS
l      BGP
l      RIP
l      OSPF
Redistributed IPv6 routes
l      Static
l      Direct
l      ISISv6
l      BGP4+
l      RIPng
l      OSPFv3
Lsp information
LSP information
l      LSP Source ID: ID of the source system
l      No. of used LSPs: number of uses LSPs
4.1.17  domain-authentication-mode
domain-authentication-mode { simple | md5 } password [ ip | osi ]
undo domain-authentication-mode
View
IS-IS view
Parameter
password: Specifies the password to be set. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or cipher text. A plain text password is a string of up to 16 characters, such as user918. A cipher password must be a string of 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
ip: Specifies to check the IP related fields in a LSP.
osi: Specifies to check the OSI related fields in a LSP.
Use the domain-authentication-mode command to enable IS-IS routing domain to authenticate Level-2 routing packets (LSP, CSNP and PSNP) according to the specified mode and password.
Use the undo domain-authentication-mode command to disable the authentication.
The authentication is not enabled by default.
Using this command can clear all Level-2 routing packets not matching the configured domain-authentication password, and insert the specified password into outbound Level-2 routing packets.
Related command: area-authentication-mode, isis authentication-mode.
Example
# Use the simple mode and password password1 to authenticate level-2 routing packets.
[Sysname] isis
[Sysname-isis-1] domain-authentication-mode simple password1
4.1.18  filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } export [ isis process-id | ospf process-id | rip process-id | bgp | direct | static]
undo filter-policy export [ isis process-id | ospf process-id | rip process-id | bgp | direct | static]
View
IS-IS view
Parameter
acl-number: Specifies the number of an ACL that is used to filter redistributed routes, ranging from 2000 to 3999.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter redistributed routes, a string of 1 to 19 characters.
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter redistributed routes, a string of 1 to 19 characters.
isis process-id: Filters routes redistributed from an IS-IS process. The process ID is in the range of 1 to 65535.
ospf process-id: Filters routes redistributed from an OSPF process. The process ID is in the range of 1 to 65535.
rip process-id: Filters routes redistributed from a RIP process. The process ID is in the range of 1 to 65535.
bgp: Filters routes redistributed from BGP.
direct: Filters redistributed direct routes.
static: Filters redistributed static routes.
If no parameter is specified, the system will filter all the redistributed routing information.
Use the filter-policy export command to configure IS-IS to filter the redistributed routes.
Use the undo filter-policy export command to disable IS-IS from filtering the redistributed routes.
IS-IS does not filter the redistributed routes by default.
In some cases, only routing information satisfying certain conditions can be redistributed. You can use the filter-policy command to reference filtering conditions.
Related command: filter-policy import.
Example
# Reference ACL 2000 to filter the redistributed routes.
[Sysname] isis
[Sysname-isis-1] filter-policy 2000 export
4.1.19  filter-policy import
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } import
View
IS-IS view
Parameter
acl-number: Specifies the number of an ACL that is used to filter received routes, ranging from 2000 to 3999.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter received routes, a string of 1 to 19 characters.
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter received routes, a string of 1 to 19 characters.
Use the filter-policy import command to configure IS-IS to filter received routing information.
Use the undo filter-policy import command to disable IS-IS from filtering received routing information.
IS-IS does not filter received routing information by default.
In some cases, only the routing information satisfying certain conditions can be received. You can reference filtering conditions using the filter-policy command.
Related command: filter-policy export.
Example
# Reference ACL 2000 to filter received routing information.
[Sysname] isis
[Sysname-isis-1] filter-policy 2000 import
4.1.20  flash-flood
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
undo flash-flood [ level-1 | level-2 ]
View
IS-IS view
Parameter
flood-count flooding-count: Specifies the maximum number of LSPs to be sent in the fast-flooding process, ranging from 1 to 15. The default is 5.
max-timer-interval flooding-interval: Specifies the delay interval (in milliseconds) between when it is enabled and when it begins, ranging from 10 to 50,000. The default is 10.
level-1: Specifies to configure fast-flooding on level-1 only.
level-2: Specifies to configure fast-flooding on level-2 only. If no level is configured, the fast-flooding will be available on both level-1 and level-2 by default.
Use the flash-flood command to enable IS-IS LSP fast flooding and configure related parameters, including the maximum number of LSPs to be sent and the delay time before flooding.
Use the undo flash-flood command to disable fast-flooding.
Fast flooding is disabled by default.
Using this command can speed up LSP flooding that is triggered by topology changes, so as to reduce LSDB convergence time.
Example
# Enable fast flooding and configure the maximum LSPs be sent as 10 and the delay time as 100 milliseconds.
[Sysname] isis
[Sysname-isis-1] flash-flood flood-count 10 max-timer-interval 100
4.1.21  ignore-lsp-checksum-error
undo ignore-lsp-checksum-error
View
IS-IS view
Parameter
None
Use the ignore-lsp-checksum-error command to configure IS-IS to ignore LSP checksum error.
Use the undo ignore-lsp-checksum-error command to configure IS-IS to discard the LSP with checksum error.
IS-IS will discard the LSP with checksum error by default.
When the local IS-IS receives a LSP packet, it will calculate the checksum of the LSP packet and compare the checksum with that in the LSP packet. By default, the LSP packet will be discarded when checksum error occurs. You can use the ignore-lsp-checksum-error command to configure IS-IS not to discard the LSP packet with checksum error.
Example
# Configure IS-IS not to discard the LSP packet with checksum error.
[Sysname] isis
[Sysname-isis-1] ignore-lsp-checksum-error
4.1.22  import-route
import-route { isis [ process-id ] | ospf [ process-id ] | rip [ process-id ] | bgp [ allow-ibgp ] | direct | static } [ cost value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag-value ] *
undo import-route { isis [ process-id ] | ospf [ process-id ] | rip [ process-id ] | bgp | direct | static }
View
IS-IS view
Parameter
isis [ process-id ]: Redistributes routes from a specified ISIS process. process-id is in the range of 1 to 65535.
ospf [ process-id ]: Redistributes routes from a specified OSPF process. process-id is in the range of 1 to 65535.
rip [ process-id ]: Redistributes routes from a specified RIP process. process-id is in the range of 1 to 65535.
bgp: Redistributes BGP routes.
allow-ibgp: Redistributes IBGP routes.
direct: Redistributes direct routes.
static: Redistributes static routes.
value: Specifies a cost for redistributed routes, and defaults to 0. The value range varies with the cost type:
l           For cost types narrow, narrow-compatible, and compatible, the value ranges from 0 to 63.
l           For cost types wide and wide-compatible, the value ranges from 0 to 4,261,412,864.
cost-type { external | internal }: Specifies a cost type. If it is internal, it is the cost of routes within an area; if it is external, it is the cost of routes between areas. The type is external by default.
Configuration of this argument takes effect only when the cost type is set to narrow or narrow-compatible.
level-1: Redistributes routes into the Level-1 routing table.
level-2: Redistributes routes into the Level-2 routing table. If no level is specified, the routes are redistributed into the Level-2 routing table by default.
level-1-2: Redistributes routes into both Level-1 and Level-2 routing tables.
route-policy route-policy-name: Redistributes only routes satisfying the matching conditions of a routing policy.
tag tag-value: Sets a tag value to redistributed routes, ranging from 1 to 4294967295.
Use the import-route command to redistribute routes from other protocols.
Use the undo import-route command to disable route redistribution.
Route redistribution is not available by default.
IS-IS takes all the redistributed routes as external routes to destinations outside the IS-IS routing domain.
Related command: import-route isis level-2 into level-1.
&  Note:
Using the import-route bgp command redistributes only EBGP routes. Using the import-route bgp allow-ibgp command redistributes also IBGP routes, but this may cause routing loops. Be cautious with this command.
Example
# Redistribute static routes and set the cost to 15.
[Sysname] isis
[Sysname-isis-1] import-route static cost 15
4.1.23  import-route isis level-2 into level-1
import-route isis level-2 into level-1 [ filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } | tag tag-value ] *
undo import-route isis level-2 into level-1
View
IS-IS view
Parameter
tag tag-value: Specifies the tag value for redistributed routes, ranging from 1 to 4294967295.
Use the import-route isis level-2 into level-1 command to redistribute routes from Level-2 to Level-1area.
Use the undo import-route isis level-2 into level-1 command to disable this redistribution.
The redistribution is not available by default.
Note that:
If a filter policy is specified, only routes passing it can be advertised into Level-1 area.
You can specify a routing policy in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
Related command: import-route.
Example
# Configure the router to redistribute routes from Level-2 to Level-1.
[Sysname] isis
[Sysname-isis-1] import-route isis level-2 into level-1
4.1.24  isis
isis [ process-id ]
undo isis [ process-id ]
View
Parameter
process-id: Process ID, ranging from 1 to 65535. The default is 1.
Use the isis command to enable an IS-IS process and enter IS-IS view.
To run IS-IS, you must first use the isis command to enable an IS-IS process, then use the network-entity command to configure a Network Entity Title (NET) for the router, and then use the isis enable command to enable IS-IS on each interface that needs to run the IS-IS process.
Related command: isis enable, network-entity.
Example
# Enable IS-IS routing process 1, with the system ID being 0000.0000.0002, and area ID being 01.0001.
[Sysname] isis
[Sysname-isis-1] network-entity 01.0001.0000.0000.0002.00
4.1.25  isis authentication-mode
isis authentication-mode { simple | md5 } password [ level-1 | level-2 ] [ ip | osi ]
undo isis authentication-mode [ level-1 | level-2 ]
View
Interface view
Parameter
md5: Specifies to send the password in ciphertext.
password: Specifies a password. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or ciphertext. A plain text password can be a string of up to 16 characters, such as user918. A cipher password must be a string of 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
level-1: Specifies to set the password for Level-1.
level-2: Specifies to set the password for Level-2.
ip: Specifies the system to check IP related fields in a LSP.
osi: Specifies the system to check OSI related fields in a LSP.
Use the isis authentication-mode command to set the IS-IS authentication mode and password for an interface.
Use the undo isis authentication-mode command to disable the authentication and remove the password.
There is no password or authentication by default.
If you set a password without specifying any other parameter, the password applies to both Level-1 and Level-2, and the system checks the OSI related fields in a LSP.
Related command: area-authentication-mode, domain authentication-mode.
&  Note:
l      This command is not available in loopback interface view.
l      The level-1 and level-2 keywords are available only on the VLAN interface of switches after IS-IS is enabled on the interface using the isis enable command.
Example
# Set the plain text password tangshi for the Vlan-interface 10.
[Sysname-Vlan-interface10] isis authentication-mode simple tangshi level-1
4.1.26  isis circuit-level
isis circuit-level [ level-1 | level-1-2 | level-2 ]
undo isis circuit-level
View
Interface view
Parameter
level-1: Specifies to set up only level-1 adjacency on the interface.
level-1-2: Specifies to set up level-1-2 adjacency on the interface.
level-2: Specifies to set up only level-2 adjacency on the interface.
Use the isis circuit-level command to configure link adjacency level for an interface of a level-1-2 router.
Use the undo isis circuit-level command to restore the default.
An interface can establish level-1-2 adjacency by default.
This command is only available on a level-1-2 router. You can use it to configure an interface to establish the adjacency of a specified level (level-1 or level-2) with the neighbor, making the interface handle only the specified level hello packets. An interface can receive and send only one level hello packet on a point-to-point link. Using this command can reduce the router’s processing time and save bandwidth.
Related command: is-level.
Example
# Suppose Vlan-interface 10 is connected to a non backbone router in the same area. Configure the link adjacency level of Vlan-interface 10 as Level-1 to prevent sending and receiving Level-2 Hello packets.
[Sysname-Vlan-interface10] isis enable
[Sysname-Vlan-interface10] isis circuit-level level-1
4.1.27  isis circuit-type
isis circuit-type p2p
undo isis circuit-type
View
Interface view
Parameter
p2p: Specifies the interface’s network type as P2P.
Use the isis circuit-type command to configure the network type for an interface.
Use the undo isis circuit-type command to restore the default.
By default, the network type of a switch’s VLAN interface is broadcast.
&  Note:
This command is not available in the loopback interface view.
Example
# Configure the network type of Vlan-interface 10 as P2P.
[Sysname-Vlan-interface10] isis circuit-type p2p
4.1.28  isis cost
isis cost value [ level-1 | level-2 ]
undo isis cost [ level-1 | level-2 ]
View
Interface view
Parameter
value: Specifies a cost for SPF calculation on a specified level. The default is 10. The range of cost value differs from different cost types.
l           For types narrow, narrow-compatible and compatible: The cost value ranges from 1 to 63.
l           For types wide and wide-compatible: The cost value ranges from 1 to 16777215.
level-1: Applies the cost to Level-1.
level-2: Applies the cost to Level-2.
Use the isis cost command to set the link cost of an interface for SPF calculation.
Use the undo isis cost command to restore the default.
No cost is configured by default.
If neither level-1 nor level-2 is included, the cost applies to both level-1 and level-2.
You are recommended to configure a proper link cost for each interface; otherwise, the link cost for IS-IS route calculation may not reflect the actual cost.
Relate command: circuit-cost.
Example
# Configure the Level-2 link cost as 5 for Vlan-interface10.
[Sysname-Vlan-interface10] isis cost 5 level-2
4.1.29  isis dis-name
isis dis-name symbolic-name
undo isis dis-name
View
Interface view
Parameter
symbolic-name: Specifies a name for the local LAN, a string of 1 to 64 characters.
Use the isis dis-name command to configure a name for local LAN. If the local router is the DIS, the name will be advertised in a pseudonode LSP packet. This command is available only on a router with the dynamic hostname process enabled.
Use the undo isis dis-name command to disable this function.
No name is configured by default.
&  Note:
l      This command is not available in the loopback interface view.
l      This command is invalid on point-to-point links.
Example
# Configure the name as “LOCALAREA” for the local LAN.
[Sysname-Vlan-interface10] isis dis-name LOCALAREA
4.1.30  isis dis-priority
isis dis-priority value [ level-1 | level-2 ]
undo isis dis-priority [ level-1 | level-2 ]
View
Interface view
Parameter
value: Specifies a priority for DIS selection, ranging from 0 to 127.
level-1: Applies the DIS selection priority to Level-1.
level-2: Applies the DIS selection priority to level-2.
If neither level-1 nor level-2 is specified in this command, the DIS priority applies to both Level-1 and Level-2.
Use the isis dis-priority command to specify a DIS selection priority on a specified level for an interface.
Use the undo isis dis-priority command to restore the default priority of 64.
There is no backup DIS in IS-IS and the router with the 0 priority can also participate in DIS selection.
&  Note:
Example
# Configure the level-2 DIS priority as 127 for Vlan-interface 10.
[Sysname-Vlan-interface10] isis dis-priority 127 level-2
4.1.31  isis enable
isis enable [ process-id ] [ silent ]
undo isis enable
View
Interface view
Parameter
process-id: Specifies a IS-IS process ID, ranging from 1 to 65535. The default is 1.
silent: Specifies to restrain the interface from sending and receiving IS-IS hello packets, but the route to the interface’s network can be advertised through other interfaces.
Use the isis enable command to enable an IS-IS routing process on the interface.
Use the undo isis enable command to disable this configuration.
No IS-IS routing process is enabled on an interface by default.
To run IS-IS, you need to use the isis command to enable an IS-IS process, and use the network-entity command to configure a network entity title (NET) for the router, and then use the isis enable command to enable IS-IS on each interface that needs to run the IS-IS process.
Related command: isis, network-entity.
Example
# Create IS-IS routing process 1, and enable the IS-IS routing process on Vlan-interface 10.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] quit
[Sysname-Vlan-interface10] isis enable 1
4.1.32  isis mesh-group
isis mesh-group { mesh-group-number | mesh-blocked }
undo isis mesh-group
View
Interface view
Parameter
mesh-group-number: Specifies a mesh group number, ranging from 1 to 4294967295.
mesh-blocked: Blocks the interface to make it send LSPs only when receiving requests.
Use the isis mesh-group command to add the interface into a specified mesh group.
Use the undo isis mesh-group command to delete the interface from a mesh group.
An interface is not in any mesh group by default.
For an interface not in a mesh group, it follows the normal process to flood the received LSPs to other interfaces. For the NBMA network with high connectivity and multiple point-to-point links, this will cause repeated LSP flooding and bandwidth waste.
After an interface is added to a mesh group, it will only flood a received LSP to interfaces not belonging to the same mesh group.
When you add an interface to a mesh group or block the interface, make sure to retain some redundancy so that a link failure will not affect the normal LSP packet flooding.
&  Note:
l      A mesh-group is only available for a point-to-point link interface.
Example
# Add VLAN-interface10 and VLAN-interface20, both running IS-IS, to mesh-group 100. (The procedure of creating VLAN-interface10 and VLAN-interface20 is omitted.)
4.1.33  isis small-hello
isis small-hello
undo isis small-hello
View
Interface view
Parameter
None
Use the isis small-hello command to configure the interface to send small Hello packets without padding field.
Use the undo isis small-hello command to disable the feature.
An interface sends standard Hello packets by default.
&  Note:
Example
# Configure Vlan-interface 10 to send small Hello packets.
[Sysname] interface vlan-interface10
[Sysname-Vlan-interface10] isis small-hello
4.1.34  isis timer csnp
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ level-1 | level-2 ]
View
Interface view
Parameter
seconds: Specifies the interval in seconds for sending CSNP packets over broadcast network, ranging from 1 to 600.
level-1: Applies the interval to Level-1.
level-2: Applies the interval to Level-2.
&  Note:
l      If no level is specified, the CSNP interval applies to the current level ISIS process.
Use the isis timer csnp command to specify the interval for sending CSNP packets over broadcast network.
Use the undo isis timer csnp command to restore the default.
The default CSNP interval is 10 seconds.
This command only applies to the DIS router, which sends CSNP packets periodically. The DIS router works on both Level-1 and Level-2, and their time intervals should be configured respectively.
Example
# Configure Level-2 CSNP packets to be sent every 15 seconds over Vlan-interface 10.
[Sysname-Vlan-interface10] isis timer csnp 15 level-2
4.1.35  isis timer hello
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ level-1 | level-2 ]
View
Interface view
Parameter
seconds: Specifies the interval in seconds for sending Hello packets, ranging from 3 to 255.
level-1: Specifies the interval for sending Level-1 Hello packets.
level-2: Specifies the time interval for sending Level-2 Hello packets.
&  Note:
l      If no level is specified, the hello interval applies to the current level IS-IS process.
Use the isis timer hello command to specify the interval for sending Hello packets on a specified level over broadcast network.
Use the undo isis timer hello command to restore the default setting.
The default hello interval is 10 seconds.
The hello interval must be configured respectively for the Level-1 and Level-2 packets on a broadcast network. A point-to-point link does not require this. As the shorter the interval is, the more system resources will be occupied to send Hello packets, you should configure a proper interval as needed.
Related command: isis timer holding-multiplier.
Example
# Configure Level-2 Hello packets to be sent every 20 seconds over Vlan-interface 10.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] isis timer hello 20 level-2
4.1.36  isis timer holding-multiplier
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ level-1 | level-2 ]
View
Interface view
Parameter
value: Number of hello intervals, in the range of 3 to 1000.
level-1: Applies the number to the Level-1 IS-IS neighbor.
level-2: Applies the number to the Level-2 IS-IS neighbor.
&  Note:
l      If neither level-1 nor level-2 is specified in the command, the number applies to the current level IS-IS process.
Use the isis timer holding-multiplier command to configure the number of hello intervals, within which if the interface receive no hello packets, its neighbor is considered dead.
Use the undo isis timer holding-multiplier command to restore the default.
On an interface, the default number of hello intervals is three.
You can specify the number of hello intervals for Level-1 and Level-2 neighbors respectively on a broadcast network. For a point-to-point link, there is only one kind of Hello packet, so you need not specify Level-1 or Level-2.
The specified number of hello intervals is used to configure the Holddown time. If a router receives no Hello packets from a neighbor within Holddown time, it will take the neighbor as dead. The Holddown time can be configured differently for different routers within an area. You can adjust the Holddown time by changing either the hello interval or the number of Hello intervals on an interface.
Related command: isis timer hello.
Example
# Configure the number of Level-2 Hello intervals as 5 for interface Vlan-interface, that is, if no Hello packet is received from the interface within 5 hello intervals, the IS-IS neighbor is considered dead.
[Sysname-Vlan-interface10] isis timer holding-multiplier 5
4.1.37  isis timer lsp
isis timer lsp time [ count count ]
undo isis timer lsp
View
Interface view
Parameter
time: Specifies the minimum interval in milliseconds for sending link-state packets, ranging from 1 to 1000.
count: Specifies the maximum number of link-state packets to be sent at one time, in the range of 1 to 1000. The default is 100 for the broadcast interface and 11 for point-to-point interface.
Use the isis timer lsp command to configure the interval for sending link-state packets on the interface.
Use the undo isis timer lsp command to restore the default of 33ms.
Related command: isis timer retransmit.
&  Note:
Example
# Configure the interval as 500 milliseconds for sending LSPs on interface Vlan-interface 10.
[Sysname-Vlan-interface10] isis timer lsp 500
4.1.38  isis timer retransmit
isis timer retransmit seconds
undo isis timer retransmit
View
Interface view
Parameter
seconds: Specifies the interval in seconds for retransmitting LSP packets, ranging from 1 to 300.
Use the isis timer retransmit command to configure the interval for retransmitting LSP packets over point-to-point link.
Use the undo isis timer retransmit command to restore the default of 5s.
You need not use this command over a broadcast link where no LSP response is required.
Related command: isis timer lsp.
&  Note:
l      Configure a proper time to avoid unnecessary retransmissions.
Example
# Configure the LSP retransmission interval as 10 seconds for Vlan-interface 10.
[Sysname-Vlan-interface10] isis timer retransmit 10
4.1.39  is-level
is-level { level-1 | level-1-2 | level-2 }
undo is-level
View
IS-IS view
Parameter
level-1: Configures the router to work on Level-1, which means it only calculates routes within the area, and maintains the L1 LSDB.
level-1-2: Configures the router to work on Level-1-2, which means it calculates routes and maintains the LSDBs for both L1 and L2.
level-2: Configures the router to work on Level-2, which means it calculates routes and maintains the LSDB for L2 only.
Use the is-level command to configure IS-IS router type.
Use the undo is-level command to restore the default.
The default router type is level-1-2.
It is recommended to configure system level when you configure IS-IS.
You can configure all the routers as either Level-1 or Level-2 if there is only one area, because there is no need for all routers to maintain two identical databases at the same time. In this case, you are recommended to configure all the routers as Level-2 in the IP network for scalability consideration.
Related command: isis circuit-level.
Example
# Configure the router to work in Level-1.
[Sysname] isis
[Sysname-isis-1] is-level level-1
4.1.40  is-name
is-name sys-name
undo is-name
View
IS-IS view
Parameter
symbolic-name: Specifies a name for the local IS, a string of 1 to 64 characters.
Use the is-name command to enable the dynamic hostname process and configure a name for the router.
Use the undo is-name command to remove the configuration.
No IS name is configured by default.
Example
# Configure a name for the local IS.
[Sysname] isis
4.1.41  is-name map
is-name map sys-id map-sys-name
undo is-name map sys-id
View
IS-IS view
Parameter
sys-id: System ID or a pseudonode ID of a remote IS.
map-sys-name: Specifies a name for the remote IS.
Use the is-name map command to map a name to a remote IS. Each remote IS system ID corresponds to only one name.
Use the undo is-name map command to remove the configuration.
By default, no name is configured for a remote IS.
Example
# Map the name RUTB to the remote IS 0000.0000.0041.
[Sysname] isis
4.1.42  is-snmp-traps enable
undo is-snmp-traps
View
IS-IS view
Parameter
None
Use the is-snmp-traps enable command to enable the SNMP Trap function of IS-IS.
Use the undo is-snmp-traps command to disable this function.
SNMP Trap is enabled by default.
Example
# Enable SNMP Trap.
[Sysname] isis
[Sysname-isis-1] is-snmp-traps enable
4.1.43  log-peer-change
log-peer-change
undo log-peer-change
View
IS-IS view
Parameter
None
Use the log-peer-change command to enable logging on IS-IS adjacency state changes.
Use the undo log-peer-change command to disable the logging.
The feature is enabled by default.
After the feature is enabled, information about IS-IS adjacency state changes is sent to the configuration terminal.
Example
# Enable logging on the IS-IS adjacency state changes.
[Sysname] isis
[Sysname-isis-1] log-peer-change
4.1.44  lsp-fragments-extend
lsp-fragments-extend [ [ level-1 | level-2 | level-1-2 ] | [ mode-1 | mode-2 ] ] *
undo lsp-fragments-extend [ level-1 | level-2 | level-1-2 ]
View
IS-IS view
Parameter
mode-1: Fragment extension mode 1, used on a network where some routers do not support LSP fragment extension.
mode-2: Fragment extension mode 2, used on a network where all routers support LSP fragment extension.
level-1: Applies the fragment extension mode to Level-1 LSPs.
level-2: Applies the fragment extension mode to Level-2 LSPs.
level-1-2: Applies the fragment extension mode to both Level-1 and Level-2 LSPs.
&  Note:
The mode-1 and level-1-2 keywords are used by default.
Use the lsp-fragments–extend command to enable LSP fragment extension in a specified mode and level.
Use the undo lsp-fragments–extend command to disable this feature.
The feature is disabled by default.
Example
# Enable LSP fragment extension of mode-1 and Level-2.
[Sysname] isis
[Sysname-isis-1] lsp-fragments-extend mode-1 level-2
4.1.45  lsp-length originate
lsp-length originate size [ level-1 | level-2 ]
undo lsp-length originate [ level-1 | level-2 ]
View
IS-IS view
Parameter
size: Specifies the maximum size in bytes of a LSP packet, ranging from 512 to 16384.
level-1: Applies the size to Level-1 LSP packets.
level-2: Applies the size to Level-2 LSP packets.
&  Note:
If neither Level-1 nor Level-2 is specified in the command, the configured maximum size applies to the current IS-IS level.
Use the lsp-length originate command to configure the maximum size of generated Level-1 or Level-2 LSPs.
Use the undo lsp-length originate command to restore the default.
Example
# Configure the maximum size of the generated Level-2 LSPs as 1024 bytes.
[Sysname] isis
[Sysname-isis-1] lsp-length originate 1024 level-2
4.1.46  lsp-length receive
lsp-length receive size
undo lsp-length receive
View
IS-IS view
Parameter
size: Maximum size of received LSPs, in the range of 512 to 16,384 bytes.
Use the lsp-length receive command to configure the maximum size of received LSPs.
Use the undo lsp-length receive command to restore the default.
By default, the maximum size of received LSPs is 1,497 bytes.
Example
# Configure the maximum size of received LSPs.
[Sysname] isis
[Sysname-isis-1] lsp-length receive 1024
4.1.47  maximum load-balancing
maximum load-balancing number
undo maximum load-balancing
View
IS-IS view
Parameter
number: Maximum number of equal-cost load balanced routes, ranging 1 to 4.
Use the maximum load-balancing command to configure the maximum number of equal-cost load balanced routes.
Use the undo maximum load-balancing command to restore the default.
By default, the maximum number of equal-cost load balanced routes is 4.
Example
# Configure the maximum number of equal-cost load-balanced routes as 2.
[Sysname] isis 100
[Sysname-isis-100] maximum load-balancing 2
# Restore the default.
[Sysname-isis-100] undo maximum load-balancing
4.1.48  network-entity
network-entity net
undo network-entity net
View
IS-IS view
Parameter
net: Network Entity Title (NET) in the format of X…X.XXXX....XXXX.00, with the first part X…X being the area address, the middle part XXXX....XXXX (a total of 12 “X”) being the router’s system ID and the last part 00 being SEL.
Use the network-entity command to configure the Network Entity Title for an IS-IS routing process.
Use the undo network-entity command to delete a NET.
No NET is configured by default.
A NET is a network service access point (NSAP), and it is in the range of 8 to 20 bytes for IS-IS.
A NET has three parts: The first part is area ID, which ranges from 1 to 13 bytes. Routers in the same area must have the same area ID. The second part is the router’s 6-byte system ID, which is unique within the whole area and backbone area. The third part is the 1-byte SEL that must be 00. You need to configure only one NET for a router. When repartitioning an area, such as merging or splitting, you can reconfigure the router to ensure correct and continuous routing.
Related command: isis, isis enable.
Example
# Specify the NET as 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
[Sysname] isis
4.1.49  preference
preference { route-policy route-policy-name | preference } *
undo preference
View
IS-IS view
Parameter
preference: Specifies the preference for IS-IS protocol, ranging from 1 to 255. route-policy-name: Routing policy name, a string of 1 to 19 characters. The preference applies to routes passing the routing policy.
Use the preference command to configure the preference for IS-IS protocol.
Use the undo preference command to restore the default.
By default, the IS-IS protocol preference is 15.
If a routing policy is specified in this command, the preference (if any) set by the routing policy applies to those matched routes. Other routes use the preference set by the preference command.
When a router runs multiple routing protocols at the same time, the system will set a preference to each routing protocol. If several protocols find routes to the same destination, the route of the routing protocol with the highest preference is selected.
Example
# Configure the preference of IS-IS protocol as 25.
[Sysname] isis
[Sysname-isis-1] preference 25
4.1.50  reset isis all
reset isis all [ process-id ]
View
Parameter
process-id: Clears the data structure information of an IS-IS process numbered from 1 to 65535.
Use the reset isis all command to clear all ISIS data structure information.
No data structure information is cleared by default.
This command is used when the LSP needs to be updated immediately. For example, after performing the area-authentication-mode and domain-authentication-mode commands, you can use this command to clear old LSPs.
Example
# Clear all IS-IS data structure information.
<Sysname> reset isis all
4.1.51  reset isis peer
reset isis peer system-id [ process-id ]
View
Parameter
system-id: Specifies the system ID of an IS-IS neighbor.
process-id: Specifies the ID of an IS-IS process, in the range of 1 to 65535.
Use the reset isis peer command to clear the data structure information of a specified IS-IS neighbor.
The command is disabled by default.
This command is used when you need to re-establish an IS-IS neighbor.
Example
# Clear the data structure information of the neighbor with system ID being 0000.0c11.1111.
<Sysname> reset isis peer 0000.0c11.1111
4.1.52  set-overload
set-overload [ on-startup start-from-nbr system-id [ timeout [ nbr-timeout ] ] ] [ allow { interlevel | external } * ]
set-overload [ on-startup [ wait-for-bgp ] [ timeout ] ] [ allow { interlevel | external } * ]
undo set-overload
View
IS-IS view
Parameter
on-startup: Specifies to start the overload tag timeout timer upon system startup.
start-from-nbr system-id: Specifies to start the overload tag timeout timer when the router begins to establish the connection with a neighbor.
wait-for-bgp: Specifies to keep the overload tag after BGP convergence completes and remove the tag after convergence. However, upon receiving no signals from BGP to inform the convergence is done, IS-IS will not remove the overload tag until a specified timeout time or the default 10 minutes elapse.
timeout: Specifies the overload tag timeout timer, with an interval from 5 to 86,400 seconds. The timer is started after system startup. The default is 600 seconds.
nbr-timeout: Specifies the overload tag timeout timer that is started when the router begins to establish the connection with a neighbor after system startup. The time has an interval from 5 to 86,400 seconds. The default is 1,200 seconds.
allow: Specifies to allow advertising address prefixes. By default, no address prefixes are allowed to be advertised when the system is in overload state.
interlevel: Allows advertising IP address prefixes learnt from different IS-IS levels with the allow keyword specified.
external: Allows advertising IP address prefixes learnt from other routing protocols with the allow keyword specified.
Use the set-overload command to set the overload tag for the current router.
Use the undo set-overload command to clear the overload tag.
No overload flag is set by default.
When the overload flag is set for a router, the routes calculated by the router will be ignored by other routers when they calculate SPF. (But the routes directly connected to the router will not be ignored.)
When a router is set overload tag, other routers will not send packets to the router for forwarding.
Example
# Set overload flag on the current router.
[Sysname] isis
[Sysname-isis-1] set-overload
4.1.53  spf-slice-size
spf-slice-size duration-time
undo spf-slice-size
View
IS-IS view
Parameter
duration-time: Specifies the duration in milliseconds of each sliced SPF calculation, ranging from 150 to 50,000. Each sliced SPF calculation is ended when the duration time is reached. If the duration-time is set to 0, the entire SPF calculation will not be sliced.
Use the spf-slice-size command to specify the duration for each sliced SPF calculation.
Use the undo spf-slice-size command to restore the default.
The SPF calculation is not sliced by default.
To prevent the SPF calculation from occupying the system resources for a long time, you can use this command to slice the whole SPF calculation into pieces.
You are not recommended to change the default setting.
Example
# Set the duration of each sliced SPF calculation to 1 second.
[Sysname] isis
[Sysname-isis-1] spf-slice-size 1000
4.1.54  summary
summary ip-address { mask | mask-length } [ avoid-feedback | generate_null0_route | tag tag | [ level-1 | level-1-2 | level-2 ] ] *
undo summary ip-address { mask | mask-length } [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Parameter
ip-address: Destination IP address of a summary route.
mask: Mask of the destination IP address, in dotted decimal format.
mask-length: Mask length, in the range of 0 to 32.
avoid-feedback: Specifies to avoid learning aggregate routes by routing calculation.
generate_null0_route: Specifies to generate the Null 0 route to avoid routing loops.
tag tag: Specifies a management tag, in the range of 1 to 4294967295.
level-1: Specifies to summarize only the routes redistributed to Level-1 area.
level-1-2: Specifies to summarize all the routes redistributed to the Level-1 and Level-2 areas.
level-2: Specifies to summarize only the routes redistributed to the Level-2 area.
Use the summary command to configure a summary route.
Use the undo summary command to remove a summary route.
No summarization is configured by default.
If no level is specified, only the level-2 routes will be summarized by default.
You can summarize multiple contiguous networks with a summary network to reduce the size of the routing table, as well as that of LSP and LSDB generated by the router. It is allowed to summarize native IS-IS routes and redistributed routes. After summarization, the cost of the summary route is the smallest cost of those summarized routes.
Note that the router summarizes only routes in local LSPs.
Example
# Configure a summary route 202.0.0.0/8.
[Sysname] isis
[Sysname-isis-1] summary 202.0.0.0 255.0.0.0
4.1.55  timer lsp-generation
timer lsp-generation max-interval [ min-interval [ inc-interval ] ] [ level-1 | level-2 ]
undo timer lsp-generation [ level-1 | level-2 ]
View
IS-IS view
Parameter
max-interval: Specifies the maximum interval (in seconds) for generating ISIS LSPs, ranging from 1 to 120.
min-interval: Specifies the minimum interval (in milliseconds) for generating ISIS LSPs, ranging from 10 to 60,000.
inc-interval: Specifies the incremental interval (in milliseconds) for generating ISIS LSPs, ranging from 10 to 60,000.
level-1: Applies the specified intervals to generating level-1 LSPs.
level-2: Applies the specified intervals to generating level-1 LSPs.
Use the timer lsp-generation command to specify intervals for ISIS LSP generation, including minimum generation interval, incremental interval and maximum generation interval.
Use the undo timer lsp-generation command to restore the default.
By default, the LSP generation maximum interval is 2 seconds.
By using this command to adjust the LSP generation interval, you can save the bandwidth and router resources that may be wasted due to frequent network changes. When the network changes are infrequent, the minimum LSP generation interval applies. When the network changes become frequent, an incremental value is added to the generation interval until the maximum generation interval is reached.
Example
# Set the maximum LSP generation interval to 10 seconds, minimum interval to 100 milliseconds and the incremental interval to 200 milliseconds.
[Sysname] isis
[Sysname-isis-1]timer lsp-generation 10 100 200
# Set the maximum LSP generation interval to 15 seconds.
[Sysname] isis
[Sysname-isis-1]timer lsp-generation 15
4.1.56  timer lsp-max-age
timer lsp-max-age seconds
undo timer lsp-max-age
View
IS-IS view
Parameter
seconds: Specifies the LSP maximum aging time in seconds, ranging from 1 to 65,535.
Use the timer lsp-max-age command to set the LSP maximum aging time for the current router.
Use the undo timer lsp-max-age command to restore the default.
A router puts the specified LSP maximum aging time into an LSP before advertisement.. When the LSP is received by other routers, the aging time will decrease as the time goes by. If no update is received for the LSP after its aging time decreases to 0, the LSP will be deleted from the LSDB.
Related command: timer lsp-refresh.
Example
# Set the maximum LSP aging time to 1,500 seconds.
[Sysname] isis
[Sysname-isis-1] timer lsp-max-age 1500
4.1.57  timer lsp-refresh
timer lsp-refresh seconds
undo timer lsp-refresh
View
IS-IS view
Parameter
seconds: Specifies the LSP refresh interval in seconds, ranging from 1 to 65,534.
Use the timer lsp-refresh command to set the LSP refresh interval.
Use the undo timer lsp-refresh to restore the default.
The default is 900 seconds.
With this feature, you can keep LSPs in synchronization for the whole area.
Related command: timer lsp-max-age.
&  Note:
To refresh LSPs before they are aged out, the interval set by the timer lsp-refresh command must be smaller than that set by the timer lsp-max-age command.
Example
# Set the LSP refresh interval to 1,500 seconds.
[Sysname] isis
[Sysname-isis-1] timer lsp-refresh 1500
4.1.58  timer spf
timer spf max-interval [ min-interval [ inc-interval ] ]
undo timer spf
View
IS-IS view
Parameter
max-interval: Specifies the maximum interval (in seconds) for SPF calculations, ranging from 1 to 120.
min-interval: Specifies the minimum interval (in milliseconds) for SPF calculations, ranging from 10 to 60,000.
inc-interval: Specifies the incremental interval (in milliseconds) for SPF calculations, ranging from 10 to 60,000.
Use the timer spf command to set the time intervals for ISIS routing calculation.
Use the undo timer spf command to restore the default.
The default IS-IS SPF calculation interval is 10 seconds.
When the network changes are infrequent, the SPF calculation interval decreases to the minimum interval. When the network changes become frequent, the calculation interval is increased by inc-interval*(2n-2), (n is the number of network changes that triggered SPF calculations) until the maximum interval is reached.
With this feature, you can prevent the router from over consumption due to frequent network changes.
Example
# Set the maximum SPF calculation interval to 10 seconds, minimum interval to 100 milliseconds and the incremental interval to 200 milliseconds.
[Sysname] isis
[Sysname-isis-1]timer spf 10 100 200
# Set the maximum SPF calculation interval to 15 seconds.
[Sysname] isis
[Sysname-isis-1]timer spf 15
4.1.59  virtual-system
virtual-system virtual-system-id
undo virtual-system virtual-system-id
View
IS-IS view
Parameter
virtual-system-id: Virtual system ID of the IS-IS process.
Use the virtual-system command to configure a virtual system ID for the IS-IS process. No extended LSPs are generated without the virtual system ID.
Use the undo virtual command to remove the virtual system ID.
Example
# Set a virtual system ID of 2222.2222.2222 for IS-IS process 1.
[Sysname] isis
[Sysname-isis-1] virtual-system 2222.2222.2222
Chapter 5  BGP Configuration Commands
l      The term “router” in this document refers to a generic router or an Ethernet switch running routing protocols.
l      For routing policy configuration commands, refer to Routing Policy Commands.
5.1  BGP Configuration Commands
5.1.1  aggregate
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
undo aggregate ip-address { mask | mask-length }
View
BGP view
Parameter
ip-address: Destination IP address of the summary route.
mask: Mask of the IP address, in dotted decimal notation.
mask-length: Mask length of the IP address, in the range 0 to 32.
as-set: Creates a route with AS set.
attribute-policy route-policy-name: Sets the attributes of the summary route according to a specified routing policy that is a string of 1 to 19 characters.
detail-suppressed: Only advertises the summary route.
suppress-policy route-policy-name: Suppresses some specific routes defined in the routing policy, which is a string of 1 to 19 characters.
origin-policy route-policy-name: Uses the routing policy to specify routes for summarization. The policy name is a string of 1 to 19 characters.
The keywords of the command are described as follows:
Table 5-1 Functions of the keywords
Keywords
Function
as-set
Used to create a summary route, whose AS path contains the AS path information of summarized routes. Use this keyword carefully when many AS paths need to be summarized, because the frequent changes of routes may lead to route oscillation.
detail-suppressed
This keyword does not suppress the summary route, but it suppresses the advertisement of all the more specific routes. To summarize only some specific routes, use the peer filter-policy command.
suppress-policy
Used to create a summary route and suppress the advertisement of some summarized routes. If you want to suppress some routes selectively and leave other routes still advertised, use the if-match clause of the route-policy command.
origin-policy
Selects only routes meeting the routing policy for route summarization
attribute-policy
Sets attributes for the summary route. The same work can be done by using the peer route-policy command.
Use the aggregate command to create a summary route in the BGP routing table.
Use the undo aggregate command to remove the summary route.
By default, no summary route is configured.
Example
# In BGP view, create a summary route 192.213.0.0/16 in the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp] aggregate 192.213.0.0 255.255.0.0
5.1.2  balance
balance number
undo balance
View
BGP view
Parameter
number: Number of BGP routes participating in load balancing, ranging 1 to 4. When it is set to 1, load balancing is disabled.
Use the balance command to configure the number of routes participating in BGP load balancing.
Use the undo balance command to disable load balancing.
By default, no load balancing is available.
Unlike IGP, BGP has no explicit metric for making load balancing decision. Instead, it implements load balancing using routing rules.
Related command: display bgp routing-table.
Example
# In BGP view, set the number of routes participating in BGP load balancing to 2.
[Sysname] bgp 100
[Sysname-bgp] balance 2
5.1.3  bestroute as-path-neglect
undo bestroute as-path-neglect
View
BGP view
Parameter
None
Use the bestroute as-path-neglect command to configure BGP to ignore AS_PATH in route selection.
Use the undo bestroute as-path-neglect command to use AS_PATH in route selection.
By default, the router takes AS_PATH as a factor when selecting a route.
Example
# In BGP view, ignore AS_PATH in route selection.
[Sysname] bgp 100
[Sysname-bgp] bestroute as-path-neglect
5.1.4  bestroute compare-med
undo bestroute compare-med
View
BGP view
Parameter
None
Use the bestroute compare-med command to configure BGP to compare MED values of routes from each AS for best route selection.
Use the undo bestroute compare-med command to disable this function.
This function is not available by default.
Example
# In BGP view, compare MED values of routes from each AS when selecting the best route.
[Sysname] bgp 100
[Sysname-bgp] bestroute compare-med
5.1.5  bestroute med-confederation
undo bestroute med-confederation
View
BGP view
Parameter
None
Use the bestroute med-confederation command to compare MED values of routes from confederation peers to select the optimal route.
Use the undo bestroute med-confederation command to disable the function.
The comparison is not enabled by default.
The system only compares MED values of routes from peers within the confederation. Routes from external ASs are advertised throughout the confederation without MED comparison.
Example
# In BGP view, compare MED values of routes from peers within the confederation.
[Sysname] bgp 100
[Sysname-bgp] bestroute med-confederation
5.1.6  bgp
bgp as-number
undo bgp [ as-number ]
View
Parameter
as-number: Specifies the local AS number, ranging from 1 to 65535.
Use the bgp command to enable BGP and enter the BGP view.
Use the undo bgp command to disable BGP.
By default, BGP is not enabled.
Example
# Enable BGP and set local AS number to 100.
[Sysname] bgp 100
[Sysname-bgp]
5.1.7  compare-different-as-med
undo compare-different-as-med
View
BGP view
Parameter
None
Use the compare-different-as-med command to enable comparison of MED values of paths from peers in different ASs when determining the best route.
Use the undo compare-different-as-med command to disable the comparison.
The comparison is disabled by default.
If there are several routes available for one destination, the route with the smallest MED value is selected.
Do not use this command unless associated ASs adopt the same IGP protocol and routing method.
Example
# In BGP view, compare MED values of paths from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp] compare-different-as-med
5.1.8  confederation id
confederation id as-number
undo confederation id
View
BGP view
Parameter
as-number: Number of the AS that contains multiple sub-ASs, in the range 1 to 65,535.
Use the confederation id command to configure a confederation ID.
Use the undo confederation id command to remove a specified confederation.
By default, no confederation ID is configured.
Confederation can be adopted to solve the problem of too many IBGP connections in a large AS. The solution is, first dividing the AS into several sub-ASs, and each sub-AS remains fully meshed. These sub-ASs form a confederation. Key IGP attributes of a route, such as next hop, MED, local preference, are not discarded across each sub-AS. The sub-ASs still look like a whole from the perspective outside of the AS. This can assure the integrality of the former AS, and ease the problem of too many connections in the AS.
Related command: confederation nonstandard and confederation peer-as.
Example
# Confederation 9 consists of four sub-ASs, namely, 38, 39, 40 and 41. Here, the peer 10.1.1.1 is a member of the confederation while the peer 200.1.1.1 is outside of the confederation. Take sub AS 41 as an example.
[Sysname] bgp 41
[Sysname-bgp] confederation id 9
[Sysname-bgp] confederation peer-as 38 39 40
[Sysname-bgp] group Confed38 external
[Sysname-bgp] peer Confed38 as-number 38
[Sysname-bgp] peer 10.1.1.1 group Confed38
[Sysname-bgp] group Remote98 external
[Sysname-bgp] peer Remote98 as-number 98
[Sysname-bgp] peer 200.1.1.1 group Remote98
5.1.9  confederation nonstandard
undo confederation nonstandard
View
BGP view
Parameter
None
Use the confederation nonstandard command to make the router compatible with routers not compliant with RFC3065 in the confederation.
Use the undo confederation nonstandard command to cancel this function.
By default, all routers in the confederation comply with RFC3065.
All devices in the confederation should be configured with this command for interworking with those nonstandard devices.
Related command: confederation id and confederation peer-as.
Example
# AS100 contains routers not compliant with RFC3065 and comprises two sub-ASs, 64000 and 65000.
[Sysname] bgp 64000
[Sysname-bgp] confederation id 100
[Sysname-bgp] confederation peer-as 65000
[Sysname-bgp] confederation nonstandard
5.1.10  confederation peer-as
undo confederation peer-as [ as-number-list ]
View
BGP view
Parameter
as-number-list: Sub-AS number list. Up to 32 sub-ASs can be configured in one command line. The expression is as-number-list = as-number &<1-32>, in which as-number specifies a sub-AS number, and &<1-32> indicates up to 32 numbers.
Use the confederation peer-as command to specify peer sub-ASs of the confederation.
Use the undo confederation peer-as command to remove specified peer sub-ASs from the confederation.
By default, no peer sub-AS of the confederation is configured.
Before this configuration, the confederation id command must be used to specify the confederation to which each sub-AS belongs.
If the undo confederation peer-as command without the as-number-list argument is used, all sub-ASs of the confederation are removed.
Related command: confederation nonstandard and confederation id.
Example
# Configure the confederation 10 to contain AS 2000 and 2001.
[Sysname] bgp 100
[Sysname-bgp] confederation peer-as 2000 2001
5.1.11  dampening
undo dampening
View
BGP view
Parameter
half-life-reachable: Specifies the half-life for available routes, in the range 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies the half-life for unavailable routes, in the range 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies the reuse threshold value for suppressed routes, in the range 1 to 20,000. Penalty value of a suppressed route that decreases under the value is reused. By default, its value is 750.
suppress: Specifies the suppression threshold for routes in the range 1 to 20,000. Routes with penalty value higher than the threshold are suppressed. By default, it is 2,000.
ceiling: Specifies the ceiling penalty value, in the range 1,001 to 20,000. The value must be bigger than suppress value. By default, the value is 16,000.
half-life-reachable, half-life-unreachable, reuse, suppress and ceiling are mutually dependent. Once any one is configured, all others should also be specified accordingly.
Use the dampening command to configure BGP route dampening.
Use the undo dampening command to disable route dampening.
By default, no route dampening is configured.
The command dampens only EBGP routes rather than IBGP routes.
Related command: reset bgp dampening, reset bgp flap-info, display bgp routing-table dampened, display bgp routing-table dampening parameter and display bgp routing-table flap-info.
Example
# In BGP view, configure BGP route dampening.
[Sysname] bgp 100
[Sysname-bgp] dampening 15 15 1000 2000 10000
5.1.12  default ipv4-unicast
undo default ipv4-unicast
View
BGP view
Parameter
None
Use the default ipv4-unicast command to enable IPv4 unicast address family of all peers.
Use the undo default ipv4-unicast command to disable IPv4 unicast address family of all peers.
IPv4 unicast address family is enabled by default.
Example
# Enable IPv4 unicast address family of all neighbors.
[Sysname] bgp 100
[Sysname-bgp] default ipv4-unicast
5.1.13  default local-preference
undo default local-preference
View
BGP view
Parameter
value: Default local preference, in the range 0 to 4,294,967,295. The larger the value is, the higher the preference is.
Use the default local-preference command to configure default local preference.
Use the undo default local-preference command to restore the default value.
By default, the value is 100.
Using this command can affect BGP route selection.
Example
# In BGP view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp] default local-preference 180
5.1.14  default med
default med med-value
undo default med
View
BGP view
Parameter
med-value: Default MED value, in the range 0 to 4,294,967,295.
Use the default med command to configure the default MED value.
Use the undo default med command to restore the default.
By default, the med-value is 0.
Multi-exit discriminator (MED) is an external metric for routes. Different from local preference, MED is exchanged between ASs and will stay in the AS once it enters the AS. The route with a lower MED is preferred. When a router running BGP obtains several routes with identical destination address and different next-hops from various external peers, it will select the best route depending on the MED value. In the case that all other conditions are the same, the system first selects the route with the smaller MED value as the external route of the autonomous system.
Example
# In BGP view, configure the default MED as 25.
[Sysname] bgp 100
[Sysname-bgp] default med 25
5.1.15  default-route imported
undo default-route imported
View
BGP view
Parameter
None
Use the default-route imported command to allow the redistribution of default route into BGP routing table.
Use the undo default-route imported command to disallow the redistribution.
By default, redistribution of default route is not allowed.
Using the default-route imported command cannot redistribute default routes. To do so, use the import-route command.
Example
# In BGP view, redistribute default route from OSPF into BGP.
[Sysname] bgp 100
[Sysname-bgp] default-route imported
[Sysname-bgp] import-route ospf 1
5.1.16  display bgp group
display bgp group [ group-name ]
View
Parameter
group-name: Peer group name, a string of 1 to 47 characters.
Use the display bgp group command to view the information of peer groups.
Example
# Display the information of the peer group "aaa".
<Sysname> display bgp group aaa
 BGP peer-group is aaa
 remote AS 200
 Type : external
 Maximum allowed prefix number: 150000
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Peer Preferred Value: 0
  Members:
  Peer        V    AS  MsgRcvd  MsgSent OutQ PrefRcv  Up/Down  State
  12.1.1.2    4   200        5        5    0       0  00:02:43  Established
Table 5-2 Description on the fields of the display bgp group command
BGP peer-group
Name of the BGP peer group
remote AS
AS number of peer group
type
Type of the BGP peer group: IBGP or EBGP
Threshold
Threshold value
Holdtime interval
Keepalive interval
Preferred value of the routes from the peer
No routing policy is configured for the peer
Members
Detailed information of the members in the peer group
Peer
IPv4 address of the peer
V
BGP version running on peers
AS
AS number of the peers
MsgRcvd
Number of messages received
MsgSent
Number of messages sent
OutQ
Number of messages to be sent
PrefRcv
Number of prefixes received
Up/Down
The lasting time of a session/the lasting time of present state (when no session is established)
State machine of peer
5.1.17  display bgp network
display bgp network
View
Parameter
None
Use the display bgp network command to view the routing information that has been advertised.
Example
# View the routing information that has been advertised.
<Sysname> display bgp network
  BGP Local Router ID is 2.2.2.2.
  Local AS Number is 100.
  Network          Mask            Route-policy        Short-cut
  100.1.2.0        255.255.255.0   test
  100.1.2.0        255.255.0.0                         Short-cut
Table 5-3 Description on the fields of the display bgp network command
BGP Local Router ID
BGP Local Router ID
Local AS Number
Local AS Number
Network
Network address
Mask
Mask
Route-policy
Routing policy
Short-cut
Short-cut route
5.1.18  display bgp paths
display bgp paths [as-regular-expression]
View
Parameter
as-regular-expression: Matched AS path regular expression.
Use the display bgp paths command to view information about AS paths.
Example
# Display information about the AS paths.
<Sysname> display bgp paths ^41.42$
    Address       Hash    Refcount  MED         Path/Origin
    0x38EF220     126     2                     41 42i
Table 5-4 Description on the fields of the display bgp paths command
Address
Route address in local database, in dotted hexadecimal notation
Hash
Hash index
Refcount
Count of routes that referenced the path
MED
MED of the route
Path
AS_PATH attribute of a route, recording the ASs a route has passed, for avoiding routing loops
Origin
Origin attribute of the route:
i
Indicates the route is interior to the AS.
Summary routes and routes defined using the network command are considered IGP routes.
e
Indicates that a route is learned from the exterior gateway protocol (EGP).
Short for INCOMPLETE. It indicates that the origin of a route is unknown and the route is learned by other means.
5.1.19  display bgp peer
display bgp peer [ ip-address { log-info | verbose } | group-name log-info | verbose ]
View
Parameter
ip-address: Specifies the IP address of an peer to be displayed, in dotted decimal notation.
group-name: Name of a peer group to be displayed, a string of 1 to 47 characters.
log-info: Displays log information of the specified peer.
verbose: Displays the detailed information of the peer/peer group.
Use the display bgp peer command to display peer/peer group information.
Example
# Display the detailed information of the peer 192.168.0.236.
<Sysname> display bgp peer 192.168.0.236 verbose
        Peer: 192.168.0.236     Local: 2.2.2.2
        Type: EBGP link
        BGP version 4, remote router ID 192.168.0.236
        BGP current state: Established, Up for 00h05m43s
        BGP current event: RecvKeepalive
        BGP last state: OpenConfirm
        Port:  Local - 1034     Remote - 179
        Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
        Received  : Active Hold Time: 180 sec
        Negotiated: Active Hold Time: 180 sec
        Peer optional capabilities:
        Peer support bgp multi-protocol extended
        Peer support bgp route refresh capability
        Address family IPv4 Unicast: advertised and received
 Received: Total 9 messages, Update messages 0
 Sent: Total 8 messages, Update messages 0
 Threshold: 75%
 Optional capabilities:
 Routing policy configured:
Table 5-5 Description on the fields of the display bgp peer command
Peer
IP address of the peer
Local
Local router ID
Peer type: Internal as IBGP peers and External as EBGP peers.
BGP version
BGP protocol version
remote router ID
Router ID of the peer
BGP current state
Current state of the peer
BGP current event
Current event of the peer
BGP last state
Last state of the peer
Port
Port number of local router and its peer
Local holdtime interval
Keepalive Time
Local keepalive interval
Received: Active Hold Time
Remote holdtime interval
Negotiated holdtime interval
Optional capabilities supported by the peer, including BGP multiple extension and routing refresh.
Advertise and receive routes in the form of IPv4 unicast
Received
Total numbers of received packets and updates
Sent
Total numbers of sent packets and updates
Threshold
Threshold value
Minimum time between route advertisements
Optional capabilities enabled by the peer
Preferred value specified for the routes from the peer
Local routing policy
5.1.20  display bgp routing-table
display bgp routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ]
View
Parameter
ip-address: Destination IP address.
mask: Network mask, in dotted decimal notation.
mask-length: Mask length, in the range 0 to 32.
longer-prefixes: Matches the longest prefix.
Use the display bgp routing command to view the BGP routing information in the BGP routing table.
Example
# Display BGP routing table information.
<Sysname> display bgp routing-table
 Total Number of Routes: 1
 BGP Local router ID is 3.3.3.3
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 *>  9.1.1.0/24        200.1.3.1                           0       20 10i
Table 5-6 Description on the fields of the display bgp routing command
BGP Local router ID
BGP Local router ID
Status codes
Status codes:
* – valid
> – best
d – damped
h – history
i – internal (IGP)
s – summary suppressed (suppressed)
S – Stale
Origin
i – IGP (originated in the AS)
e – EGP (learned through EGP)
? – incomplete (learned by other means)
Network
Destination network address
Next Hop
Next hop IP address
MED
MULTI_EXIT_DISC attribute
LocPrf
Local preference value
PrefVal
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops
PrefVal
Preferred value
Ogn
Origin attribute of the route, which can take on one of the following values:
i
Indicates that a route is interior to the AS.
Summary routes and the routes configured using the network command are considered IGP routes.
e
5.1.21  display bgp routing-table as-path-acl
display bgp routing-table as-path-acl as-path-acl-number
View
Parameter
as-path-acl-number: Number of an AS path ACL permitted by which to display routing information, ranging from 1 to 256.
Use the display bgp routing as-path-acl command to view routes permitted by an as-path ACL.
Example
# Display routes permitted by AS path ACL 1.
<Sysname> display bgp routing-table as-path-acl 1
 BGP Local router ID is 2.2.2.2
 *>  10.1.5.0/24     10.1.1.1                         0       65001
                                                              65004i
Refer to Table 5-6 for description on the fields above.
5.1.22  display bgp routing-table cidr
View
Parameter
None
Use the display bgp routing-table cidr command to view the CIDR (Classless Inter-Domain Routing) routing information.
Example
<Sysname> display bgp routing-table cidr
 *>  9.1.1.0/24       200.1.1.2                           0       100i
Refer to Table 5-6 for description on the above fields.
5.1.23  display bgp routing-table community
display bgp routing-table community [ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ]* [ whole-match ]
View
Parameter
aa:nn: Specifies a community number, in the range 0 to 65535.
&<1-13>: Specifies the argument before it can be entered up to 13 times.
no-advertise: Displays routes that are not advertised to any peer.
no-export: Displays routes that are not advertised outside the AS. If there is a confederation, displays routes not advertised outside the confederation, but to other sub ASs in the confederation.
no-export-subconfed: Displays routes that are neither advertised outside the AS nor to other sub ASs if confederation is configured.
whole-match: Displays the exactly matched routes.
Use the display bgp routing community command to display specified community routing information in the routing table.
Example
# Display the routing information matching the specified BGP community number.
<Sysname> display bgp routing-table community 100:100
 BGP Local router ID is 192.168.0.55
 *>  12.5.5.0/24      10.2.2.1        0                    0       39i
5.1.24  display bgp routing-table community-list
display bgp routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
View
Parameter
basic-community-list-number: Specifies a basic community-list number, in the range 1 to 99.
adv-community-list-number: Specifies an advanced community-list number, in the range 100 to 199.
whole-match: Displays routes exactly matching the specified basic-community-list-number.
&<1-16>: Specifies to allow entering the argument before it up to 16 times.
Use the display bgp routing-table community-list command to view the routing information matching the specified BGP community list.
Example
# View the routing information matching BGP community list 1.
<Sysname> display bgp routing-table community-list 1
5.1.25  display bgp routing-table dampened
View
Parameter
None
Use the display bgp routing-table dampened command to view BGP dampened routes.
Example
# Display BGP dampened routes.
<Sysname> display bgp routing-table dampened
 BGP Local router ID is 192.168.0.36
     Network            From              Reuse     Path/Origin
 *d  12.2.2.0/24        10.2.2.2          00:05:12  42i
Table 5-7 Description on the fields of the display bgp routing-table dampened command
From
Source IP address of the route
Reuse
Reuse time of the route
Refer to Table 5-6 for description on the other fields above.
5.1.26  display bgp routing-table dampening parameter
View
Parameter
None
Use the display bgp routing-table dampening parameter command to display BGP route dampening parameters.
Related command: dampening.
Example
# Display BGP route dampening parameters.
<Sysname> display bgp routing-table dampening parameter
 Maximum Suppress Time(in second) : 1778
 Ceiling Value                    : 10000
 Reuse Value                      : 2000
 HalfLife Time(in  second)        : 900
 Suppress-Limit                   : 4000
Table 5-8 Description on the fields of the display bgp routing-table dampening parameter command
Ceiling Value
Upper limit of penalty value
Reuse Value
Limit for a route to be unsuppressed
HalfLife Time
Half-life time of reachable routes
Suppress-Limit
Limit for a route to be suppressed
5.1.27  display bgp routing-table different-origin-as
View
Parameter
None
Use the display bgp routing-table different-origin-as command to view routes originating from different autonomous systems.
Example
# View the routes from different source ASs.
<Sysname> display bgp routing-table different-origin-as
 *>  55.0.0.0         12.1.1.1       0                    0       100?
 *                    14.1.1.2       0                    0       300?
5.1.28  display bgp routing-table flap-info
display bgp routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ]
View
Parameter
as-regular-expression: Display route flap information that matches the AS path regular expression.
as-path-acl-number: Number of the specified AS path ACL matched by which to display route flap information, ranging from 1 to 256.
ip-address: Destination network address.
longer-match: Matches the longest prefix.
Use the display bgp routing-table flap-info command to view BGP route flap statistics. If no parameter is specified, this command displays all the BGP route flap statistics.
Example
# Display BGP route flap statistics.
<Sysname> display bgp routing-table flap-info
     Network            From            Flaps  Duration     Reuse  Path/Origin
 *d  12.2.2.0/24      10.2.2.2        2     00:03:57  00:05:12  42i
Table 5-9 Description on the fields of the display bgp routing flap-info command
From
Flaps
The number of routing flaps
Duration
The duration time of the route
Reuse
5.1.29  display bgp routing-table peer
display bgp routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ]
View
Parameter
ip-address: Specifies the peer to be displayed.
advertised-routes: Routing information advertised to the specified peer.
received-routes: Routing information received from the specified peer.
network-address: IP address of the destination network segment.
mask: Mask of the destination network segment, in dotted decimal notation.
statistic: Displays route statistics.
Use the display bgp routing-table peer command to view the routing information advertised to or received from the specified BGP peer.
Related command: display bgp peer.
Example
# View the routing information advertised to BGP peer 200.1.2.1.
<Sysname> display bgp routing-table peer 200.1.2.1 advertised-routes
 *>  9.1.2.0/24        200.1.3.2      0                    0       30i
5.1.30  display bgp routing-table regular-expression
display bgp routing-table regular-expression as-regular-expression
View
Parameter
as-regular-expression: Matched AS regular expression.
Use the display bgp routing-table regular-expression command to view the routing information matching the specified AS regular expression.
Example
 Total Number of Routes: 2
 *>  9.1.1.0/24       200.1.2.1       0                    0       10i
# Display the routing information matching AS regular expression 10$.
<Sysname> display bgp routing-table regular-expression 10$
5.1.31  display bgp routing-table statistic
View
Parameter
None
Use the display bgp routing-table statistic command to display statistics about BGP routes.
Example
# Display BGP routes statistics.
<Sysname> display bgp routing-table statistic
 Total Number of Routes: 4
Table 5-10 Description on the fields of the display bgp routing-table statistic command
Total number of routes
5.1.32  ebgp-interface-sensitive
undo ebgp-interface-sensitive
View
BGP view
Parameter
None
Use the ebgp-interface-sensitive command to configure BGP to clear the EBGP session on any interface that becomes down.
Use the undo ebgp-interface-sensitive command to disable the function.
This function is enabled by default.
Example
# In BGP view, enable automatic BGP session clearing.
[Sysname] bgp 100
[Sysname-bgp] ebgp-interface-sensitive
5.1.33  filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ isis process-id | ospf process-id | rip process-id | direct | static ]
undo filter-policy export [ isis process-id | ospf process-id | rip process-id | direct | static ]
View
BGP view
Parameter
acl-number: Specifies the number of an ACL matching against the destination address field of routing information, ranging from 2000 to 3999.
ip-prefix-name: Specifies the name of the IP prefix list used to match against the destination address of routing information, a string of 1 to 19 characters.
isis process-id: Filters outgoing routes of an ISIS process. The ID is in the range 1 to 65535.
ospf process-id: Filters outgoing routes of an OSPF process. The ID is in the range 1 to 65535.
rip process-id: Filters outgoing routes of a RIP process. The ID is in the range 1 to 65535.Specifies the ID of a RIP process of which to filter advertised routes, in the range 1 to 65535.
direct: Filters direct routes.
static: Filters static routes.
If no routing protocol is specified, all outgoing routes are filtered.
Use the filter-policy export command to filter outgoing routes and only the routes permitted by the specified filter can be advertised.
Use the undo filter-policy export command to cancel filtering outgoing routes.
By default, outgoing routing information is not filtered.
Example
# In BGP view, use ACL 2000 to filter all outgoing routes.
[Sysname] bgp 100
[Sysname-bgp] filter-policy 2000 export
5.1.34  filter-policy import
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy import
View
BGP view
Parameter
ip-prefix-name: Specifies an IP prefix list name with a string of 1 to 19 characters. The matched object is the destination address field of the routing information.
Use the filter-policy import command to filter incoming routing information.
Use the undo filter-policy import command to cancel filtering incoming routing information.
By default, incoming routing information is not filtered.
Example
# In BGP view, use ACL 2000 to filter incoming routing information.
[Sysname] bgp 100
[Sysname-bgp] filter-policy 2000 import
5.1.35  group
group group-name { [ internal ] | external }
undo group group-name
View
BGP view
Parameter
group-name: Specifies the name of a peer group, a string of 1 to 47 characters.
internal: Creates an IBGP peer group.
external: Creates an EBGP peer group, including groups of other sub ASs in the confederation.
Use the group command to create a peer group.
Use the undo group command to delete a peer group.
An IBGP peer group will be created if neither internal nor external is selected.
Example
# In BGP view, create an EBGP peer group "test" with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group.
[Sysname] bgp 100
[Sysname-bgp] group test external
[Sysname-bgp] peer test as-number 200
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp] peer 10.1.2.1 group test
5.1.36  import-route
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
undo import-route protocol [ process-id ]
View
BGP view
Parameter
protocol: Redistributes routes from the routing protocol, which can be direct, isis, ospf, rip and static at present.
process-id: Process ID, in the range 1 to 65535. It is available only when the protocol is isis, ospf or rip.
med-value: Specifies the MED value to be applied to redistributed routes, ranging from 0 to 4294967295. If not specified, the cost of a redistributed route is the MED.
route-policy-name: Specifies the route-policy for filtering redistributed routes, a string of 1 to 19 characters.
Use the import-route command to redistribute routes from other protocols.
Use the undo import-route command to remove the configuration.
By default, BGP does not redistribute routes from other protocols.
The routes redistributed to the BGP routing table using the import-route command has the ORIGIN attribute as incomplete.
Example
# In BGP view, redistribute routes from RIP.
[Sysname] bgp 100
[Sysname-bgp] import-route rip
5.1.37  log-peer-change
log-peer-change
View
BGP view
Parameter
None
Use the log-peer-change command to enable BGP global logging on peers going up and down.
Use the undo log-peer-change command to disable the function.
By default, the function is enabled.
Example
# Enable BGP logging on peers going up and down.
[Sysname] bgp 100
[Sysname-bgp] log-peer-change
5.1.38  network
network ip-address [ mask | mask-length ] [ short-cut | route-policy route-policy-name ]
undo network ip-address [ mask | mask-length ] [ short-cut ]
View
BGP view
Parameter
mask: Mask of the network address, in dotted decimal notation.
short-cut: Specifies the route to use the local preference. If the route is an EBGP route whose preference is higher than the local one. Using this keyword can configure the EBGP route to use the local preference, so the route is hard to become the optimal route.
route-policy-name: Routing policy applied to the route. The name is a string of 1 to 19 characters.
Use the network command to advertise a network to the BGP routing table.
Use the undo network command to remove a network from the routing table.
By default, no route is advertised.
Note that:
l           The network route must be in the local IP routing table, and using a routing policy makes route management more flexible.
l           The route advertised to the BGP routing table using the network command has the ORIGIN attribute as IGP.
Example
# In BGP view, advertise the network segment 10.0.0.0/16.
[Sysname] bgp 100
[Sysname-bgp] network 10.0.0.0 255.255.0.0
5.1.39  peer advertise-community
peer { group-name | ip-address } advertise-community
undo peer { group-name | ip-address } advertise-community
View
BGP view
Parameter
group-name: Specifies the name of the peer group, a string of 1 to 47 characters.
ip-address: IP address of the peer.
Use the peer advertise-community command to advertise community attribute to a peer/peer group.
Use the undo peer advertise-community command to cancel the advertisement.
By default, no community attribute is advertised to any peer group/peer.
Related command: ip community-list, if-match community-list, apply community (refer to Routing Policy Commands.)
Example
# In BGP view, advertise community attributes to peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test advertise-community
5.1.40  peer advertise-ext-community
peer { group-name | ip-address } advertise-ext-community
undo peer { group-name | ip-address } advertise-ext-community
View
BGP view
Parameter
group-name: Name of a peer group, a string of 1 to 47 characters.
ip-address: IP address of a peer.
Use the peer advertise-ext-community command to advertise extended community attribute to a peer/peer group.
Use the undo peer advertise-ext-community command to remove the configuration.
By default, no extended community attribute is advertised to a peer/peer group.
Refer to the ip extcommunity-list, if-match extcommunity and apply extcommunity commands in Routing Policy Commands.
&  Note:
Currently, the H3C S3610&S5510 series do not support this command.
Example
5.1.41  peer allow-as-loop
peer { group-name | peer-address } allow-as-loop [ number ]
undo peer { group-name | peer-address } allow-as-loop
View
BGP view
Parameter
number: Specifies the repeating times of the local AS number, in the range 1 to 10, which defaults to 1.
Use the peer allow-as-loop command to allow local AS number in the AS_PATH attribute of routes from a peer/peer group, and to configure the repeating times of the local AS number.
Use the undo peer allow-as-loop command to disable the feature.
By default, no local AS number is allowed.
Related command: display bgp routing-table peer.
Example
# In BGP view, configure the repeating times of the local AS number as 2 for routes from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 allow-as-loop 2
5.1.42  peer as-number
peer { group-name | ip-address } as-number as-number
undo peer group-name as-number
undo peer ip-address
View
BGP view
Parameter
as-number: AS number of the peer/peer group, in the range 1 to 65535.
Use the peer as-number command to specify an AS number for a peer/peer group.
Use the undo peer as-number command to delete the AS number of a peer group.
Use the undo peer command to delete a peer.
By default, no AS number is configured for a peer/peer group.
Example
# In BGP view, specify the AS number of the peer group test as 100.
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 100
5.1.43  peer as-path-acl
peer { group-name | ip-address } as-path-acl as-path-acl-number { import | export }
undo peer { group-name | ip-address } as-path-acl as-path-acl-number { import | export }
View
BGP view
Parameter
as-path-acl-number: AS path ACL list number, in the range 1 to 256.
import: Filters incoming routes.
export: Filters outgoing routes.
Use the peer as-path-acl command to specify an AS path ACL list to filter routes incoming from or outgoing to a peer/peer group.
Use the undo peer as-path-acl command to remove the configuration.
By default, no AS path ACL list is specified.
Related command: ip as-path-acl, if-match as-path and apply as-path (refer to IP Routing Policy Commands.)
Example
# In BGP view, specify the AS path ACL 1 to filter routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test as-path-acl 1 export
5.1.44  peer capability-advertise conventional
peer { group-name | ip-address } capability-advertise conventional
undo peer { group-name | ip-address } capability-advertise conventional
View
BGP view
Parameter
Use the peer capability-advertise conventional command to disable BGP route-refresh and multi-protocol extension of a peer/peer group.
Use the undo peer capability-advertise command to enable the function.
By default, route-refresh and multi-protocol extension are enabled.
Example
# In BGP view, disable route-refresh and multi-protocol extension of peer 160.89.2.33.
[Sysname] bgp 100
[Sysname-bgp] peer 160.89.2.33 as-number 100
[Sysname-bgp] peer 160.89.2.33 capability-advertise conventional
5.1.45  peer capability-advertise route-refresh
peer { group-name | ip-address } capability-advertise route-refresh
undo peer { group-name | ip-address } capability-advertise route-refresh
View
BGP view
Parameter
Use the peer capability-advertise route-refresh command to enable BGP route refresh.
Use the undo peer capability-advertise route-refresh command to disable the feature.
Example
# In BGP view, disable BGP route refresh of peer 160.89.2.33.
[Sysname] bgp 100
[Sysname-bgp] peer 160.89.2.33 capability-advertise route-refresh
5.1.46  peer connect-interface
peer { group-name | ip-address } connect-interface interface-type interface-number
undo peer { group-name | ip-address } connect-interface
View
BGP view
Parameter
group-name: Name of a peer group, a string 1 to 47 characters.
interface-type interface-number: Specifies the type and name of the interface.
Use the peer connect-interface command to specify the source interface of updates to a peer/peer group.
Use the undo peer connect-interface command to restore the best source interface.
By default, BGP uses the source interface of best updates.
For updates to be forwarded in case the interface experiences a failure, you can use a Loopback interface to forward route updates.
Example
# In BGP view, specify loopback0 as the source interface for route updates to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test connect-interface loopback 0
5.1.47  peer default-route-advertise
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ip-address } default-route-advertise
View
BGP view
Parameter
route-policy-name: Route-policy name, a string of 1 to 19 characters.
Use the peer default-route-advertise command to enable BGP to advertise a default route to a peer/peer group.
Use the undo peer default-route-advertise command to disable advertising default route.
By default, no default route is advertised to a peer/peer group.
For this command, no default route is required in the routing table. The router sends a default route unconditionally to a peer/peer group with the next hop being itself.
Example
# In BGP view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test default-route-advertise
5.1.48  peer description
peer { group-name | peer-address } description description-text
undo peer { group-name | ip-address } description
View
BGP view
Parameter
peer-address: IP address of a peer.
description-text: Description information for the peer/peer group, a string of 1 to 79 characters.
Use the peer description command to configure the description information for a peer/peer group.
Use the undo peer description command to remove the description information of a peer/peer group.
By default, no description information is configured for a peer (group).
Create a peer/peer group before configuring description information for it.
Example
# In BGP view, configure the description information of the peer group test as ISP1.
[Sysname] bgp 100
[Sysname-bgp] peer test description ISP1
5.1.49  peer ebgp-max-hop
peer { group-name | ip-address } ebgp-max-hop [ hop-count ]
undo peer { group-name | ip-address } ebgp-max-hop
View
BGP view
Parameter
hop-count: Maximum hop count, in the range 1 to 255. The default is 64.
Use the peer ebgp-max-hop command to allow establishing EBGP connection with a peer/peer group on an indirectly connected network.
Use the undo peer ebgp-max-hop command to cancel the existing configuration.
You can use the argument hop-count to specify the maximum route count of the EBGP connection.
Example
# In BGP view, allow establishing the EBGP connection with the peer group "test" on an indirectly connected network.
[Sysname] bgp 100
[Sysname-bgp] peer test ebgp-max-hop
5.1.50  peer enable
peer ip-address enable
undo peer ip-address enable
View
BGP view
Parameter
Use the peer enable command to enable the specified peer.
Use the undo peer enable command to disable the specified peer.
By default, BGP peer is enabled.
If the specified peer is disabled, the router will not exchange routing information with the specified peer.
Example
# Disable the specified peer 18.10.0.9.
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 group group1
[Sysname-bgp] undo peer 18.10.0.9 enable
5.1.51  peer fake-as
peer { group-name | ip-address } fake-as as-number
undo peer { group-name | ip-address } fake-as
View
BGP view
Parameter
as-number: Local autonomous system number, in the range 1 to 65535.
Use the peer fake-as command to configure a fake local AS number for a peer or peer group.
Use the undo peer fake-as command to remove the configuration.
By default, no fake local AS number is configured for a peer or peer group.
Example
# In BGP view, configure a fake AS number of 200 for the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test fake-as 200
5.1.52  peer filter-policy
peer { group-name | ip-address } filter-policy acl-number { import | export }
undo peer { group-name | ip-address } filter-policy acl-number { import | export }
View
BGP view
Parameter
acl-number: ACL number, in the range 2000 to 3999.
import: Applies the filter-policy to routes received from the peer/peer group.
export: Applies the filter-policy to routes advertised to the peer/peer group.
Use the peer filter-policy command to configure an ACL-based filter policy for a peer or peer group.
Use the undo peer filter-policy command to remove the configuration.
By default, no ACL-based filter policy is configured for a peer or peer group.
Related command: peer as-path-acl.
Example
# In BGP view, apply the ACL 2000 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test filter-policy 2000 export
5.1.53  peer group
peer ip-address group group-name [ as-number as-number ]
undo peer ip-address group group-name
View
BGP view
Parameter
as-number: Specifies the AS number of a peer, in the range 1 to 65535.
Use the peer group command to add a peer to a peer group.
Use the undo peer group command to delete a specified peer from a peer group.
By default, no peer is added into a peer group.
Example
# In BGP view, add the peer 10.1.1.1 to the EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 2004
5.1.54  peer ignore
peer { group-name | ip-address } ignore
undo peer { group-name | ip-address } ignore
View
BGP view
Parameter
Use the peer ignore command to disable session establishment with a peer or peer group.
Use the undo peer ignore command to remove the configuration.
By default, session establishment with a peer or peer group is allowed.
After the peer ignore command is executed, the system stops the session with the specified peer or peer group and clears all the related routing information. For a peer group, this means all sessions with the peer group will be tore down.
By default, a router allows establishing sessions with peers or peer group.
Example
# In BGP view, disable session establishment with the peer 10.10.10.10.
[Sysname] bgp 100
[Sysname-bgp] peer 10.10.10.10 ignore
5.1.55  peer ip-prefix
peer { group-name | ip-address } ip-prefix ip-prefix-name { import | export }
undo peer { group-name | ip-address } ip-prefix { import | export }
View
BGP view
Parameter
ip-address: Specifies the IP address of a peer.
ip-prefix-name: Specifies an IP prefix list name, a string of 1 to 19 characters.
import: Applies the filtering policy to routes received from the specified peer/peer group.
export: Applies the filtering policy to routes advertised to the specified peer/peer group.
Use the peer ip-prefix command to use an IP prefix list to filter routes received from or advertised to a peer or peer group.
Use the undo peer ip-prefix command to remove the configuration.
By default, no IP prefix list is specified.
Example
# In BGP view, use the IP prefix list “list 1” to filter routes advertised to the peer group “test”.
[Sysname] bgp 100
[Sysname-bgp] peer test ip-prefix list1 export
5.1.56  peer keep-all-routes
peer { group-name | ip-address } keep-all-routes
undo peer { group-name | ip-address } keep-all-routes
View
BGP view
Parameter
Use the peer keep-all-routes command to save the original routing information from a peer or peer group, even routes that failed to pass the inbound policy.
Use the undo peer keep-all-routes command to disable this function.
By default, the function is not available.
Example
# In BGP view, save the routing information from peer 131.100.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 131.100.1.1 as-number 200
[Sysname-bgp] peer 131.100.1.1 keep-all-routes
5.1.57  peer log-change
peer { group-name | ip-address } log-change
undo peer { group-name | ip-address } log-change
View
BGP view
Parameter
Use the peer log-change command to record the session state and event information for a specified peer or peer group.
Use the undo peer log-change command to remove the configuration.
By default, the session state and event information are recorded for the peer or peer group.
Example
# In BGP view, record the session state and event information for peer group “test”.
[Sysname] bgp 100
[Sysname-bgp] peer test log-change
5.1.58  peer next-hop-local
peer { group-name | ip-address } next-hop-local
undo peer { group-name | ip-address } next-hop-local
View
BGP view
Parameter
Use the peer next-hop-local command to set the next hop of routes advertised to a peer/peer group to the local router.
Use the undo peer next-hop-local command to remove the configuration.
By default, routes advertised to EBGP peer/peer group take the local router as the next hop, while routes to IBGP peer/peer group do not.
Example
# In BGP view, set the next hop of routes advertised to peer group “test” to the router itself.
[Sysname] bgp 100
[Sysname-bgp] peer test next-hop-local
5.1.59  peer password
peer { group-name | ip-address } password { cipher | simple } password
undo peer { group-name | ip-address } password
View
BGP view
Parameter
cipher: Displays the configured password in cipher text.
simple: Displays the configured password in plain text.
password: Password, a string of 1 to 16 characters when the keyword simple is used or when the keyword cipher is included but with the plain text password; a string of 24 characters when cipher text password and the keyword cipher are used.
Use the peer password command to configure BGP to perform MD5 authentication when a TCP connection is being established with a peer/peer group.
Use the undo peer password command to disable the function.
By default, no MD5 authentication is performed.
Once MD5 authentication is enabled, both parties involved in the authentication must be configured with the same authentication mode and password. Otherwise, the TCP connection will not be set up.
This command is used to configure MD5 authentication for a specific peer only when the peer group to which the peer belongs is not configured with MD5 authentication. Otherwise, the peer group configuration takes precedence.
Example
# In BGP view, perform MD5 authentication on the TCP connection set up between the local router 10.1.100.1 and the peer router 10.1.100.2.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.100.2 password simple aabbcc
# Perform the similar configuration on the peer.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.100.1 password simple aabbcc
5.1.60  peer preferred-value
peer { group-name | ip-address } preferred-value value
undo peer { group-name | ip-address } preferred-value
View
BGP view
Parameter
value: Preferred value, in the range 0 to 65535.
Use the peer preferred-value command to assign a preferred value to routes received from a peer or peer group.
Use the undo peer preferred-value command to restore the default value.
The default value is 0.
The routes learned from the peer each have an initial preferred value. The route with the biggest value is selected as the route to the network.
Example
# In BGP view, configure the preferred value as 50 for routes from peer 131.108.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 131.108.1.1 preferred-value 50
5.1.61  peer public-as-only
peer { group-name | ip-address } public-as-only
undo peer { group-name | ip-address } public-as-only
View
BGP view
Parameter
Use the peer public-as-only command to configure BGP updates to a peer/peer group to not carry private AS numbers.
Use the undo peer public-as-only command to carry private AS numbers in BGP updates sent to a peer/peer group.
By default, BGP updates carry private AS numbers.
The command does not take effect if the BGP update has both public and private AS numbers. The range of private AS number is from 64512 to 65535.
Example
# In BGP view, carry no private AS number in BGP updates sent to the peer “test”.
[Sysname] bgp 100
[Sysname-bgp] peer test public-as-only
5.1.62  peer reflect-client
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
View
BGP view
Parameter
Use the peer reflect-client command to configure the router as a router reflector and specify a peer/peer group as a client.
Use the undo peer reflect-client command to remove the configuration.
By default, neither route reflector nor client is configured.
Related command: reflect between-clients and reflect cluster-id.
Example
# In BGP view, configure the local device as a router reflector and specify the IBGP peer group "test" as a client.
[Sysname] bgp 100
[Sysname-bgp] peer test reflect-client
5.1.63  peer route-limit
peer { group-name | ip-address } route-limit limit [ percentage ]
undo peer { group-name | ip-address } route-limit
View
BGP view
Parameter
limit: Specifies the upper limit of address prefixes received from the peer or peer group, ranging from 1 to 12,288.
percentage: Specifies the percentage of routes to generate alarm information, ranging from 1 to 100. The default is 75.
Use the peer route-limit command to set the maximum number of routes allowed to receive from a peer/peer group.
Use the undo peer route-limit command to restore the default.
The number is unlimited by default.
Example
# In BGP view, set the number of routes allowed to receive from the peer 129.140.6.6 to 10000.
[Sysname] bgp 109
[Sysname-bgp] peer 129.140.6.6 as-number 110
[Sysname-bgp] peer 129.140.6.6 route-limit 10000
5.1.64  peer route-policy
peer { group-name | ip-address } route-policy route-policy-name { import | export }
undo peer { group-name | ip-address } route-policy route-policy-name { import | export }
View
BGP view
Parameter
route-policy-name: Specifies the route-policy name, a string of 1 to 19 characters.
import: Applies the route-policy to routes received from the peer (group).
export: Applies the route-policy to routes advertised to the peer (group).
Use the peer route-policy command to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use the undo peer route-policy command to remove the configuration.
By default, the peer (group) has no route-policy associated.
The peer route-policy command does not use the if-match interface clause in the specified routing policy. Refer to Routing Policy Commands for related commands.
Example
# In BGP view, apply routing policy test-policy to routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test route-policy test-policy export
5.1.65  peer route-update-interval
peer { group-name | ip-address } route-update-interval seconds
undo peer { group-name | ip-address } route-update-interval
View
BGP view
Parameter
group-name: Specifies the name of a peer group, a sting of 1 to 47 characters.
seconds: Specifies the minimum interval for sending the same update message. The range is 5 to 600 seconds.
Use the peer route-update-interval command to specify the interval for sending the same update to a peer/peer group.
Use the undo peer route-update-interval command to restore the default value.
By default, the interval is 5 seconds for IBGP peers, and 30 seconds for EBGP peers.
Example
# In BGP view, specify the interval for sending the same update to the peer group test as 10 seconds.
[Sysname] bgp 100
[Sysname-bgp] peer test route-update-interval 10
5.1.66  peer substitute-as
peer { group-name | ip-address } substitute-as
undo peer { group-name | ip-address } substitute-as
View
BGP view
Parameter
group-name: Name of a peer group, a sting of 1 to 47 characters.
Use the peer substitute-as command to replace the AS number of a peer/peer group in the AS_PATH attribute of routes outgoing to the peer/peer group with the local AS number.
Use the undo peer substitute-as command to remove the configuration.
No AS number is substituted by default.
Example
# In BGP view, substitute local AS number for AS number of peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 substitute-as
5.1.67  peer timer
peer { group-name | ip-address } timer keepalive keepalive hold holdtime
undo peer { group-name | ip-address } timer
View
BGP view
Parameter
keepalive: Specifies the keepalive interval in seconds, ranging from 1 to 21,845.
holdtime: Specifies the holdtime interval in seconds, ranging from 3 to 65,535.
Use the peer timer command to configure keepalive interval and holdtime interval for a peer or peer group.
Use the undo peer timer command to restore the default value.
By default, the keepalive and holdtime are 60s and 180s respectively.
Note that:
l           The timer configured by this command is preferred to the timer configured by the timer command.
l           The holdtime interval must be at least three times the keepalive interval.
Related command: timer.
Example
# In BGP view, configure the keepalive interval and holdtime interval for the peer group test as 40s and 60s.
[Sysname] bgp 100
[Sysname-bgp] peer test timer keepalive 40 hold 60
5.1.68  preference
undo preference
View
BGP view
Parameter
external-preference: Preference of EBGP route, in the range 1 to 255.
internal-preference: Preference of IBGP route, in the range 1 to 255. An IBGP is a route learned from another peer inside AS.
local-preference: Preference of local route, in the range 1 to 255.
route-policy-name: Route policy name, a string of 1 to 19 characters. You can set preference for routes passing the routing policy. For the routes not matched, the default value applies.
Use the preference command to configure preferences for external, internal, and local routes.
Use the undo preference command to restore the default preference.
For external-preference, internal-preference and local-preference, the bigger the preference value is, the lower the preference is, and the default values are 255, 255, 130 respectively.
Example
# In BGP view, configure preferences for EBGP, IBGP and local routes as 20, 20 and 200.
[Sysname] bgp 100
[Sysname-bgp] preference 20 20 200
5.1.69  reflect between-clients
undo reflect between-clients
View
BGP view
Parameter
None
Use the reflect between-clients command to enable route reflection between clients.
Use the undo reflect between-clients command to disable this function.
By default, route reflection between clients is enabled.
After a route reflector is configured, it reflects the routes of a client to other clients. If the clients of a route reflector are fully connected, disable route reflection between clients to reduce costs.
Related command: reflector cluster-id and peer reflect-client.
Example
# Disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp] undo reflect between-clients
5.1.70  reflector cluster-id
reflector cluster-id cluster-id
undo reflector cluster-id
View
BGP view
Parameter
cluster-id: Specifies the cluster ID of the route reflector, in integer (1 to 4294967295, the number is translated into IP address format by the system) or IP address format.
Use the reflector cluster-id command to configure the cluster ID of the route reflector.
Use the undo reflector cluster-id command to remove the configured cluster ID.
By default, each route reflector uses its router ID as the cluster ID.
Usually, there is only one route reflector in a cluster. The router ID of the reflector is the ID of the cluster. You can configure multiple route reflectors to improve the stability of the network. Use this command to configure the identical cluster ID for all the reflectors to avoid routing loops.
Related command: reflect between-clients and peer reflect-client.
Example
# Set cluster ID for local router to 80.
[Sysname] bgp 100
[Sysname-bgp] reflector cluster-id 80
5.1.71  refresh bgp
refresh bgp { all | ip-address | group group-name | external | internal } { export | import }
View
Parameter
all: Soft-reset all BGP connections.
ip-address: IP address of a peer with which to perform soft reset on the connection.
external: EBGP connection.
internal: IBGP connection.
export: Outbound direction on which to perform soft reset.
import: Inbound direction on which to perform soft reset.
Use the refresh bgp command to perform soft reset on specified BGP connections. Using this function can refresh the BGP routing table without tearing down BGP connections and apply a newly configured routing policy.
To perform BGP soft reset, all routers in the network should support Route-refresh. If a router not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command on the local router to save all route updates before performing soft reset.
Example
# Perform BGP soft reset.
<Sysname> refresh bgp all import
5.1.72  reset bgp
reset bgp { all | as-number | ip-address [ flap-info ] | group group-name | external | internal }
View
Parameter
all: Resets all BGP connections.
as-number: Specifies an AS number with which to reset connections to peers.
ip-address: Specifies the IP address of a peer with which to reset the connection.
flap-info: Clears history information of routing flap.
group group-name: Specifies to reset connections with the specified BGP peer group.
external: Resets all the EBGP connections.
internal: Resets all the IBGP connections.
Use the reset bgp command to reset specified connections.
Example
# Reset all the BGP connections.
<Sysname> reset bgp all
5.1.73  reset bgp dampening
reset bgp dampening [ ip-address [ mask | mask-length ] ]
View
Parameter
ip-address: IP address of a destination.
mask: Mask, in dotted decimal notation.
Use the reset bgp dampening command to clear route dampening information and release suppressed routes.
Related command: dampening, display bgp routing-table dampened.
Example
# Clear damping information of route 20.1.0.0/16 and release suppressed route.
<Sysname> reset bgp dampening 20.1.0.0 255.255.0.0
5.1.74  reset bgp flap-info
reset bgp flap-info [ regexp as-path-regexp | as-path-acl as-path-acl-number | ip-address [ mask | mask-length ] ]
View
Parameter
as-path-regexp: Clears the flap statistics of routes matching the AS path regular expression.
as-path-acl-number: Clears the flap statistics of routes matching an AS path ACL. The range of the argument is 1 to 256.
ip-address: Clears the flap statistics of a route.
Use the reset bgp flap-info command to clear the flap statistics of matched routes.
The flap statistics of all the routes will be cleared if no parameter or keyword is specified.
Example
# Clear the flap statistics of all routes matching AS path ACL 10.
<Sysname> reset bgp flap-info as-path-acl 10
5.1.75  reset bgp ipv4 all
reset bgp ipv4 all
View
Parameter
None
Use the reset bgp ipv4 all command to reset all the BGP connections of IPv4 unicast address family.
Example
# Reset all the BGP connections of IPv4 unicast address family.
<Sysname> reset bgp ipv4 all
5.1.76  router-id
router-id router-id
undo router-id
View
BGP view
Parameter
router-id: Router ID in IP address format.
Use the router-id command to specify a router ID.
Use the undo router-id command to remove a router ID.
To run BGP protocol, a router must have a router ID, which is an unsigned 32-bit integer, the unique ID of the router in the AS.
Router ID can be configured manually. If no router ID is specified, the system will acquire a router ID automatically from the current interface IP address. To acquire the router ID, the system finds the highest IP address first from addresses of Loopback interfaces, and then finds the highest from addresses of other interfaces if there is no Loopback interface. Only when the interface whose IP address is the Router ID or the manual Router ID is deleted will the system select another ID for the router. It is recommended to specify a loopback interface address as the router ID to enhance network reliability.
Example
# Specifies Router ID as 10.18.4.221.
[Sysname] bgp 100
[Sysname-bgp] router-id 10.18.4.221
5.1.77  summary automatic
summary automatic
undo summary automatic
View
BGP view
Parameter
None
Use the summary automatic command to enable automatic summarization for redistributed subnets.
Use the undo summary automatic command to disable automatic summarization.
By default, no automatic summarization is available.
Note that:
l           Neither the default route nor the routes imported using the network command can be summarized automatically.
l           With this feature enabled, BGP suppresses the routes from IGP to decrease routing information.
Example
# In BGP view, enable automatic summarization.
[Sysname] bgp 100
[Sysname-bgp] summary automatic
5.1.78  synchronization
synchronization
undo synchronization
View
BGP view
Parameter
None
Use the synchronization command to synchronize the BGP and IGP routes.
Use the undo synchronization command to disable synchronization.
The feature is disabled by default.
With this feature enabled and when a non-BGP router is responsible for forwarding packets in an AS, BGP speakers in the AS cannot advertise routing information to outside ASs unless all routers in the AS know the latest routing information.
When a BGP router receives an IBGP route, it checks only whether the next hop is reachable by default. If synchronization is enabled, the IBGP route is synchronized and advertised to EBGP peers only when the route is also advertised by IGP. Otherwise, the IBGP route cannot be advertised to EBGP peers.
Example
# Synchronize BGP and IGP routes.
[Sysname] bgp 100
[Sysname-bgp] synchronization
5.1.79  timer
undo timer
View
BGP view
Parameter
Use the timer command to configure BGP keepalive interval and holdtime interval.
Use the undo timer command to restore the default value.
By default, BGP keepalive and holdtime intervals are 60s and 180s.
Note that:
l           Timer configured using the peer timer command is preferred to the timer configured using this command.
l           The configured timer applies to all the BGP peers. It becomes valid only after the corresponding BGP connections are reset.
Related command: peer timer.
Example
# Configure keepalive interval and holdtime interval as 40s and 120s.
[Sysname] bgp 100
[Sysname-bgp] timer keepalive 40 hold 120
Chapter 6  Routing Policy Configuration Commands
&  Note:
l      The term “router” in this document refers to a generic router or an Ethernet switch running routing protocols.
l      The commands covered in section 6.1  "Common Routing Policy Configuration Commands" apply to both IPv4 and IPv6.
6.1  Common Routing Policy Configuration Commands
6.1.1  apply as-path
apply as-path as-number&<1-10> [ replace ]
undo apply as-path
View
Routing policy view
Parameter
as-number: Autonomous system number, in the range of 1 to 65535.
&<1-10>: Indicates you can enter as-number up to 10 times.
replace: Specifies to replace the original AS number.
Use the apply as-path command to set the AS-PATH attribute of BGP routing information.
Use the undo apply as-path command to remove the clause configuration.
No AS_PATH attribute is set by default.
With the replace keyword, the apply as-path command replaces the original AS_PATH attribute with specified AS numbers, or without the replace keyword, adds the specified AS numbers before the original AS_PATH attribute.
Example
# Create a routing policy named policy1 with a node number of 10, matching mode as permit. If routing information matches the AS-path-ACL 1, add AS number 200 before the original AS_PATH attribute.
[Sysname-route-policy] if-match as-path 1
[Sysname-route-policy] apply as-path 200
6.1.2  apply comm-list delete
apply comm-list comm-list-number delete
undo apply comm-list
View
Routing policy view
Parameter
comm-list-number: Community list number. The basic community list number ranges from 1 to 99 and the advanced community list number ranges from 100 to 199.
Use the apply comm-list delete command to specify a community list according to which to delete community attributes in routing information. The community list can be either basic or advanced.
Use the undo apply comm-list command to remove the clause configuration.
No community attribute is deleted by default.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If routing information matches the AS-path-ACL 1, delete community attributes specified in community list 1 of BGP routes.
[Sysname-route-policy] apply comm-list 1 delete
6.1.3  apply community
apply community { none | additive | { community-number&<1-16> | aa:nn&<1-16> | no-export-subconfed | no-export | no-advertise } * [ additive ] }
undo apply community
View
Routing policy view
Parameter
none: Specifies to delete community attribute of routing information.
community-number: Community sequence number, in the range of 1 to 4294967295.
aa:nn: Community number, both aa and nn are in the range of 0 to 65535.
&<1-16>: Indicates the argument before it can be entered up to 16 times.
no-export-subconfed: Specifies not to advertise matched routes out of sub autonomous system.
no-advertise: Specifies not to advertise matched routes to any peer.
no-export: Specifies not to advertise routes outside of the autonomous system or confederation, but advertise to other sub ASs in the confederation.
additive: Specifies community attributes added to the original routes.
Use the apply community command to set community attribute for BGP routing information.
Use the undo apply community command to remove the apply clause.
No community attribute of BGP routing information is modified by default.
If match criteria of the route-policy are matched, then community attribute of BGP routing information is modified.
Related command: ip community-list, if-match community, route-policy.
Example
# Configure a routing policy named setcommunity with a node number of 16 and matching mode as permit. Set the community attribute of BGP routes matched by the AS-path-ACL 8 to no-export.
[Sysname-route-policy] if-match as-path 8
[Sysname-route-policy] apply community no-export
6.1.4  apply cost
apply cost [ + | - ] value
undo apply cost
View
Routing policy view
Parameter
+: Increases cost value.
+: Decreases cost value.
cost: Specifies a cost for routing information, ranging from 0 to 4294967295.
Use the apply cost command to set the cost for routing information.
Use the undo apply cost command to remove the clause configuration.
No cost is set for routing information by default.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip-address next-hop, apply local-preference, apply origin and apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches the outbound interface Vlan-interface 10 set the cost for the route to 120.
[Sysname-route-policy] if-match interface vlan-interface 10
[Sysname-route-policy] apply cost 120
6.1.5  apply cost-type
apply cost-type { external | internal | type-1 | type-2 }
undo apply cost-type
View
Routing policy view
Parameter
external: IS-IS external route.
internal: IS-IS internal route.
type-1: Type-1 external route of OSPF.
type-2: Type-2 external route of OSPF.
Use the apply cost-type command to set the cost type for routing information.
Use the undo apply cost-type command to remove the clause configuration.
No cost type is set for routing information by default.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches tag 8, set the cost type for the route to IS-IS internal route.
[Sysname-route-policy] if-match tag 8
[Sysname-route-policy] apply cost-type internal
6.1.6  apply extcommunity
apply extcommunity { rt route-target }&<1-16> [ additive ]
undo apply extcommunity
View
Routing policy view
Parameter
rt route-target: Specifies route target extended community attribute, which is a string of 3 to 21 characters. route-target has two forms:
A 16-bit AS number: a 32-bit self-defined number, for example, 101:3;
A 32-bit IP address: a 16-bit self-defined number, for example, 192.168.122.15:1.
additive: Can be added to existing communities.
Use the apply extcommunity command to set extended community attribute for BGP routing information.
Use the undo apply extcommunity command to remove the clause configuration.
No extended community attribute is set for routing information by default.
&  Note:
Example
6.1.7  apply isis
undo apply isis
View
Routing policy view
Parameter
level-1: Specifies to redistribute routes to level-1 area.
level-2: Specifies to redistribute routes to level-2 area.
level-1-2: Specifies to redistribute routes to level-1 and level-2 area.
Use the apply isis command to set redistribute routes to a specified IS-IS level area.
Use the undo apply isis command to remove the clause configuration.
No route is redistributed to a specified IS-IS level area by default.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply cost, apply origin and apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches tag 8, redistribute the route to IS-IS level-2 area.
[Sysname-route-policy] apply isis level-2
6.1.8  apply local-preference
undo apply local-preference
View
Routing policy view
Parameter
preference: BGP local preference, ranging from 0 to 4294967295.
Use the apply local-preference command to set the local preference for BGP routing information.
Use the undo apply local-preference command to remove the clause configuration.
No local preference is set for BGP routing information by default.
Related command: route-policy.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches AS-path-ACL 1, set the local preference for the route to 130.
[Sysname-route-policy] apply local-preference 130
6.1.9  apply origin
apply origin { igp | egp as-number | incomplete }
undo apply origin
View
Routing policy view
Parameter
igp: Set the origin of BGP routing information to internal routes.
egp: Set the origin of BGP routing information to external routes.
as-number: Specifies the autonomous system number for external routes, in the range of 1 to 65535.
incomplete: Set the origin of BGP routing information to unknown.
Use the apply origin command to set the origin attribute for BGP routing information.
Use the undo apply origin command to remove the clause configuration.
No origin attribute is set for routing information by default.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip-address next-hop, apply local-preference, apply cost and apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches the configured AS-path-ACL 1, set the origin for the route to IGP.
[Sysname-route-policy] apply origin igp
6.1.10  apply preference
apply preference preference
undo apply preference
View
Routing policy view
Parameter
preference: Routing preference, in the range of 1 to 255.
Use the apply preference command to set preference for routing protocol.
Use the undo apply preference command to remove the clause configuration.
No preference is set for routing protocol by default.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches OSPF external route type, set the preference for the routing protocol to 90.
[Sysname-route-policy] if-match route-type external-type1or2
[Sysname-route-policy] apply preference 90
6.1.11  apply preferred-value
undo apply preferred-value
View
Routing policy view
Parameter
preferred-value: Preferred value, in the range of 0 to 65535.
Use the apply preferred-value command to set the preferred value for BGP routing information.
Use the undo apply preferred-value command to remove the clause configuration.
No preferred value is set for BGP routing information by default.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a BGP route matches AS-path-ACL 1, set the preferred value for the BGP route to 66.
[Sysname-route-policy] apply preferred-value 66
6.1.12  apply tag
apply tag value
undo apply tag
View
Routing policy view
Parameter
value: Set the tag value for routing information, ranging from 0 to 4294967295.
Use the apply tag command to set specified tag value for RIP, OSPF or IS-IS routing information.
Use the undo apply tag command to remove the clause configuration.
No routing tag is set for RIP, OSPF or IS-IS routing information by default.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip-address next-hop, apply local-preference, apply cost and apply origin.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. If a route matches OSPF external route type 1, set the tag of the route to 100.
[Sysname-route-policy] apply tag 100
6.1.13  display ip as-path-acl
display ip as-path-acl [ as-path-acl-number ]
View
Parameter
as-path-acl-number: AS path ACL number, in the range of 1 to 256.
Use the display ip as-path-acl command to display BGP AS path ACL information.
All BGP AS path ACL information will be displayed if no as-path-acl-number is specified.
Related command: ip as-path-acl, if-match as-path and apply as-path.
Example
# Display the information of the BGP AS path ACL 1.
<Sysname> display ip as-path-acl 1
ListID    Mode      Expression
1         permit    2
Table 6-1 Description on the fields of the display ip as-path-acl command
ListID
AS path ACL ID
Mode
Matching mode: permit, deny
Expression
Regular expression for matching
6.1.14  display ip community-list
display ip community-list [ basic-community-list-number | adv-community-list-number ]
View
Parameter
basic-community-list-number: Basic community list number, in the range of 1 to 99.
adv-community-list-number: Advanced community list number, in the range of 100 to 199.
Use the display ip community-list command to display BGP community list information.
All BGP community list information will be displayed if no basic-community-list-number or adv-community-list-number is specified.
Related command: ip community-list, if-match community and apply community.
Example
# Display the information of the BGP community list 1.
<Sysname> display ip community-list 1
Community List Number 1
         permit  1:1 1:2 2:2
6.1.15  display ip extcommunity-list
View
Parameter
ext-comm-list-number: Extended community list number, in the range of 1 to 199.
Use the display ip extcommunity-list command to display BGP extended community list information.
All BGP extended community list information will be displayed if no ext-comm-list-number is displayed.
Related command: ip extcommunity-list, if-match extcommunity, apply extcommunity.
&  Note:
Example
6.1.16  display route-policy
display route-policy [ route-policy-name ]
View
Parameter
route-policy-name: Routing policy name, a string of 1 to 19 characters.
Use the display route-policy command to display routing policy information.
All routing policy information will be displayed if no route-policy-name is specified.
Example
# Display the information of routing policy 1.
<Sysname> display route-policy policy1
Route-policy : policy1
  permit : 10
        if-match ip-prefix abc
        apply cost 120
Table 6-2 Description on the fields of the display route-policy command.
Route-policy
Routing policy name
Permit
permit mode: permit, deny
Match criterion
apply cost 120
If the match criterion is satisfied, set the route cost to 120.
6.1.17  if-match as-path
if-match as-path as-path-acl-number&<1-16>
undo if-match as-path [ as-path-acl-number&<1-16> ]
View
Routing policy view
Parameter
Use the if-match as-path command to specify AS path ACL(s) for matching against the AS path attribute of BGP routing information.
Use the undo if-match as-path command to remove the match criterion.
The match criterion is not configured by default.
This command is one of the if-match clauses of a route policy, used for filtering BGP routing information and specifying match criteria according to the AS path attribute of routing information.
Related command: route-policy, ip as-path-acl.
Example
# Define an as-path-acl with the number of 2, allowing routing information with the AS number of 200 or 300 to pass. Then define a routing policy named test, whose node 10 is defined with an if-match clause to use the as-path-acl for matching.
[Sysname] ip as-path-acl 2 permit _*200.*300
[Sysname-route-policy] if-match as-path 2
6.1.18  if-match community
if-match community { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
undo if-match community [ basic-community-list-number | adv-community-list-number ]&<1-16>
View
Routing policy view
Parameter
whole-match: Specifies an exact match, namely, to match only the exactly communities.
Use the if-match community command to specify community list(s) for matching against the community attribute of BGP routing information.
Use the undo if-match community command to remove the match criterion.
This command is one of the if-match clauses of route policy, used for filtering BGP routing information and specifying match criterion according to the community attribute of BGP routing information.
Related command: route-policy and ip community-list.
Example
# Define community-list 1, allowing routing information with community number 100 or 200 to pass. Then define a routing policy named test, whose node 10 is defined with an if-match clause to reference the community-list for matching.
[Sysname-route-policy] if-match community 1
6.1.19  if-match cost
if-match cost value
undo if-match cost
View
Routing policy view
Parameter
cost: Specifies the cost to match, ranging from 0 to 4294967295.
Use the if-match cost command to specify a cost for matching against the cost of a route.
Use the undo if-match cost command to remove the match criterion.
This command is one of the if-match clauses of routing policy, used for matching routes with the specified route cost.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match tag, route-policy, apply ip-address next-hop, apply cost, apply local-preference, apply origin and apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass the routing information with the cost as 8.
[Sysname-route-policy] if-match cost 8
6.1.20  if-match extcommunity
if-match extcommunity ext-comm-list-number&<1-16>
undo if-match extcommunity [ ext-comm-list-number&<1-16> ]
View
Routing policy view
Parameter
Use the if-match extcommunity command to specify extended community list(s) for matching against the extended community attribute of routing information.
Use the undo if-match extcommunity command to remove the match criterion.
&  Note:
Example
6.1.21  if-match interface
View
Routing policy view
Parameter
interface-type: Interface type
interface-number: Interface number
Use the if-match interface command to specify interface(s) for matching against the outbound interfaces of routing information.
Use the undo if-match interface command to remove the match criterion.
Related command: if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip-address next-hop, apply cost, apply local-preference, apply origin, apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass the routing information with the outbound interface as Vlan-interface 1.
6.1.22  if-match route-type
if-match route-type { internal | external-type1 | external-type2 | external-type1or2 | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type2 | nssa-external-type1or2 } *
undo if-match route-type [ internal | external-type1 | external-type2 | external-type1or2 | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type2 | nssa-external-type1or2 ] *
View
Routing policy view
Parameter
internal: Internal routes (OSPF intra-area and inter-area routes).
external-type1: OSPF Type 1 external routes.
external-type2: OSPF Type 2 external routes.
external-type1or2: OSPF Type 1 or 2 external routes.
is-is-level-1: IS-IS Level-1 routes.
is-is-level-2: IS-IS Level-2 routes.
nssa-external-type1: OSPF NSSA Type 1 external routes.
nssa-external-type2: OSPF NSSA Type 2 external routes.
nssa-external-type1or2: OSPF NSSA Type 1 or 2 external routes.
Use the if-match route-type command to specify a route type for matching against routing information.
Use the undo if-match route-type command to remove the match criterion.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to match internal routes.
[Sysname-route-policy] if-match route-type internal
6.1.23  if-match tag
if-match tag value
undo if-match tag
View
Routing policy view
Parameter
value: Specifies a tag value, ranging from 0 to 4294967295.
Use the if-match tag command to specify a tag for matching against the tag field of RIP, OSPF and IS-IS routes.
Use the undo if-match tag command to remove the match criterion.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, route-policy, apply ip-address next-hop, apply cost, apply local-preference, apply origin and apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass RIP, OSPF and IS-IS routing information with the tag as 8.
6.1.24  ip as-path-acl
ip as-path-acl as-path-acl-number { deny | permit } regular-expression
undo ip as-path-acl as-path-acl-number
View
Parameter
deny: Specifies the matching mode for the AS path ACL as deny.
permit: Specifies the matching mode for the AS path ACL as permit.
regular-expression: Regular expression of AS path, a string of 1 to 50 characters.
BGP routing information contains the AS path attribute field that identifies the autonomous systems through which routing information has passed. Used to compare with the AS path attribute, a regular expression is a formula comprised of characters, for example, ^200. *100$, which matches AS path attribute fields that start with AS200 and end with AS100.
The meanings of special characters used in regular expressions are shown below:
Character
Meaning
Matches any single character, including blank space.
Matches 0 or more patterns.
Matches 1 or more patterns.
Matches the beginning of an input string.
Matches the end of an input string.
_
Matches a comma, left brace, right brace, left parenthesis, right parenthesis, the beginning of an input string, the end of an input string, or a space.
[ range ]
Means the range of single-character patterns.
Separates the ending points of a range.
Use the ip as-path-acl command to create an AS path ACL.
Use the undo ip as-path-acl command to remove an AS path ACL.
No AS path ACL is created by default.
Example
# Create an AS path ACL numbered 1, letting pass routing information whose AS_PATH starts with 10.
[Sysname] ip as-path-acl 1 permit ^10
6.1.25  ip community-list
ip community-list basic-comm-list-num { deny | permit } [ community-number-list ] [ internet | no-advertise | no-export | no-export-subconfed ] *
undo ip community-list basic-comm-list-num [ community-number-list ] [ internet | no-advertise | no-export | no-export-subconfed ] *
ip community-list adv-comm-list-num { deny | permit } regular-expression
undo ip community-list adv-comm-list-num [ regular-expression ]
View
Parameter
basic-comm-list-num: Basic community list number, in the range 1 to 99.
adv-comm-list-num: Advanced community list number, in the range 100 to 199.
regular-expression: Regular expression of advanced community attribute, a string of 1 to 50 characters.
deny: Specifies the matching mode of the community list as deny.
permit: Specifies the matching mode of the community list as permit.
community-number-list: Community number list, in the community number or aa:nn format, with community number in the range 1 to 4294967295 and aa and nn in the range 0 to 65535. Each format can be entered up to 16 times.
internet: Routes with this attribute can be advertised to all the BGP peers. By default, all routes have this attribute.
no-advertise: Routes with this attribute will not be advertised to other BGP peers.
no-export: Routes with this attribute will not be exported outside of the local AS, if the confederation is configured, will not be exported outside of the confederation but can be advertised to other ASs in the union.
no-export-subconfed: Routes with this attribute will not be exported outside of the local AS, even the union is available.
Use the ip community-list to define a community list.
Use the undo ip community-list command to remove a community list or entry.
No community list is defined by default.
Example
# Define a basic community list numbered 1, letting pass routing information with the internet community attribute.
# Define an advanced community list numbered 100, letting pass routing information with the community attribute starting with 10.
6.1.26  ip extcommunity-list
ip extcommunity-list ext-comm-list-number { deny | permit } { rt route-target }&<1-16>
undo ip extcommunity-list ext-comm-list-number
View
Parameter
ext-comm-list-number: Extended community list number, in the range 1 to 199.
permit: Specifies the matching mode for extended community list as permit.
deny: Specifies the matching mode for extended community list as deny.
Use the ip extcommunity-list to define an extended community list entry.
Use the undo ip extcommunity-list command to remove an extended community list.
No extended community list is defined by default.
&  Note:
Example
6.1.27  route-policy
route-policy route-policy-name { permit | deny } node node-number
undo route-policy route-policy-name [ node node-number ]
View
Parameter
route-policy-name: Route-policy name, a string of 1 to 19 characters for uniquely identifying a route-policy.
permit: Specifies the matching mode of the route policy node as permit. If a route satisfies all the if-match clauses, it is allowed to pass the filtering of the node and then executed with the apply clauses of the node. If a route fails to satisfy the if-match clauses of the node, it is matched by the next node of the route-policy.
deny: Specifies the matching mode of the route-policy node as deny. If a route satisfies all the if-match clauses, it is denied to pass the filtering of the node and is not matched to the next node.
node node-number: Routing policy node, in the range 0 to 65535. The node with a smaller node-number will be tested first when the routing policy is used for filtering routing information.
Use the route-policy command to create a routing policy and enter its view.
Use the undo route-policy command to remove a routing policy.
No routing policy is created by default.
A route-policy is used for routing information filtering or policy routing. It contains several nodes and a node comprises some if-match and apply clauses. The if-match clauses define the matching rules of the node and the apply clauses define the actions performed after a packet passes the filtering of the node. The relation among the if-match clauses of a node is logic AND, namely all the if-match clauses must be satisfied. The filter relation among different route-policy nodes is logic OR, namely it requires passing any one node to pass the route-policy.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, apply ip-address next-hop, apply local-preference, apply cost, apply origin and apply tag.
Example
# Configure routing policy 1 with node as 10 and matching mode as permit, and then enter routing policy view.
6.2  IPv4 Routing Policy Configuration Commands
6.2.1  apply ip-address next-hop
apply ip-address next-hop ip-address
undo apply ip-address next-hop
View
Routing policy view
Parameter
ip-address: IP address of the next hop.
Use the apply ip-address next-hop command to set the next hop for IPv4 routing information.
Use the undo apply ip-address next-hop command to remove the clause configuration.
No next hop address is configured for IPv4 routing information by default.
You cannot use the apply ip-address next-hop command to set next hop address when redistributing routes.
Related command: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply local-preference, apply cost, apply origin and apply tag.
Example
# Create a routing policy named policy1 with the node number being 10, matching mode permit. If matched by AS path ACL 1, routing information‘s next hop is set to 193.1.1.8.
[Sysname-route-policy] apply ip-address next-hop 193.1.1.8
6.2.2  display ip ip-prefix
display ip ip-prefix [ ip-prefix-name ]
View
Parameter
ip-prefix-name: IP prefix list name, a string of 1 to 19 characters.
Use the display ip ip-prefix command to display the statistics of IPv4 address prefix list. If no ip-prefix-name is specified, statistics of all the address prefix lists will be displayed.
Related command: ip ip-prefix.
Example
# Display the statistics of the address prefix list abc.
<Sysname> display ip ip-prefix abc
Prefix-list abc
Permitted 0
Denied 0
        index: 10               permit  1.0.0.0/11              ge  22  le  32
Table 6-3 Description on the fields of the display ip ip-prefix command.
Prefix-list
Name of address prefix list
Permitted
Number of routes satisfying the match criterion
Denied
Number of routes not satisfying the match criterion
index
Internal serial number of address prefix list
permit
Matching mode, having two values: permit and deny
1.0.0.0/11
Matched IP address and its mask length
ge
greater-equal, the minimum length of matched IP mask
le
less-equal, the maximum length of matched IP mask
6.2.3  if-match acl
if-match acl acl-number
undo if-match acl
View
Routing policy view
Parameter
acl-number: Specifies the number of an access control list for filtering, ranging from 2000 to 3999.
Use the if-match acl command to match destination IP addresses of routes against the specified ACL.
Use the undo if-match acl command to remove the match criterion.
No destination IP address is matched for routing information by default.
Related command: if-match interface, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip-address next-hop, apply cost, apply local-preference, apply origin and apply tag.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass the routing information with destinations matching the ACL 2000.
[Sysname-route-policy] if-match acl 2000
6.2.4  if-match ip
if-match ip { next-hop | route-source } { acl acl-number | ip-prefix ip-prefix-name }
undo if-match ip { next-hop | route-source } [ acl | ip-prefix ]
View
Routing policy view
Parameter
next-hop: Matches next hop address.
route-source: Match route advertising source address.
acl acl-number: Specifies the number an ACL with which to match routes, ranging from 2000 to 2999.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list with which to match routes, a string of 1 to 19 characters.
Use the if-match ip command to match IPv4 routing information (next hop or source address).
Use the undo if-match ip command to remove the match criterion.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass routing information whose next hop address matches IP prefix list p1.
[Sysname-route-policy] if-match ip next-hop ip-prefix p1
6.2.5  if-match ip-prefix
if-match ip-prefix ip-prefix-name
undo if-match ip-prefix
View
Routing policy view
Parameter
Use the if-match ip-prefix command to match the destination IP address of a route to the specified IP prefix list.
Use the undo if-match ip-prefix command to remove the match criterion.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an if-match clause to let pass the route whose destination address matches IP prefix list p1.
[Sysname-route-policy] if-match ip-prefix p1
6.2.6  ip ip-prefix
ip ip-prefix ip-prefix-name [ index index-number ] { permit | deny } ip-address mask-length [ greater-equal min-mask-length ] [ less-equal max-mask-length ]
undo ip ip-prefix ip-prefix-name [ index index-number ]
View
Parameter
ip-prefix-name: IPv4 prefix list name, a string of 1 to 19 characters, for uniquely specifying an address prefix list.
index-number: Index number, in the range 1 to 65535, for uniquely specifying an item of the IPv4 prefix list. The index with smaller index-number is tested first.
permit: Specifies the matching mode for the IPv4 prefix list as permit, that is, when a route to be filtered is in the range of the IPv4 prefix list, the route passes the IPv4 prefix list without needing to enter the next item for testing. If the route to be filtered is not in the prefix range, it will enter the next item test.
deny: Specifies the matching mode for the IPv4 prefix list as deny, that is, when a route to be filtered is in the IPv4 prefix list range, the route neither passes the filter nor enters the next node for testing. If not in the range, the route will enter the next item test.
ip-address mask-length: Specifies an IPv4 address prefix and mask length. The mask-length is in the range 0 to 32.
min-mask-length, max-mask-length: Specifies the range for address prefix if the IPv4 address and prefix length are matched. greater-equal means “greater than or equal to” and less-equal means “less than or equal to”. The range relation is mask-length <= min-mask-length <= max-mask-length <= 32. If only min-mask-length is specified, the prefix length range is [ min-mask-length, 32 ]. If only max-mask-length is specified, the prefix length range is [ mask-length, max-mask-length ]. If both min-mask-length and max-mask-length are specified, the prefix length range is [ min-mask-length, max-mask-length ].
Use the ip ip-prefix command to configure an IPv4 prefix list or an item.
Use the undo ip ip-prefix command to remove an IPv4 prefix list or an item.
No IPv4 prefix list is configured by default.
The IPv4 prefix list is used to filter IPv4 addresses. It may have multiple items, each of which specifies a range of IPv4 prefix. The filtering relation among items is logic OR, namely, passing any item means the IPv4 prefix list is passed. If no item is passed, the IP prefix list cannot be passed.
The IP prefix range is determined by mask-length and [ min-mask-length, max-mask-length ]. If both mask-length and [ min-mask-length, max-mask-length ] are specified, then the IP address to be filtered must satisfy both of them.
If ip-address mask-length is specified as 0.0.0.0 0, then only the default routes will be matched.
To match all the routes, use 0.0.0.0 0 less-equal 32.
Example
# Create a routing policy named policy1 with the node number of 10, matching mode as permit. Define an IP prefix list named p1 to let pass only the routes in the network segment 10.0.192.0/8 and with mask length 17 or 18.
[Sysname] ip ip-prefix p1 permit 10.0.192.0 8 greater-equal 17 less-equal 18
6.2.7  reset ip ip-prefix
reset ip ip-prefix [ ip-prefix-name ]
View
Parameter
ip-prefix-name: Unique IP prefix list name, a string of 1 to 19 characters.
Use the reset ip ip-prefix command to delete statistics of a specified IPv4 address prefix. If no ip-prefix-name is specified, the statistics of all the IPv4 address prefixes will be deleted.
Example
# Delete statistics of IPv4 address prefix abc.
<Sysname> reset ip ip-prefix abc
Chapter 7  GR Configuration Commands
&  Note:
The term “router” in this document refers to a router in a generic sense or an Ethernet switch running routing protocols.
7.1  GR Configuration Commands
7.1.1  display isis graceful-restart status
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
View
Parameter
level-1: Represents the Level-1 of the IS-IS Graceful Restart state.
level-2: Represents the Level-2 of the IS-IS Graceful Restart state.
process-id: The process ID of an IS-IS Graceful Restart, in the range 1 to 65,535.
Use the display isis graceful-restart status command to display IS-IS Graceful Restart status.
Example
# Display IS-IS Graceful Restart status.
<Sysname> display isis graceful-restart status
                        Restart information for ISIS(1)
IS-IS(1) Level-1 Restart Status
Restart Interval: 200
SA Bit Supported
  Total Number of Interfaces = 1
  Restart Status: RESTART COMPLETE
IS-IS(1) Level-2 Restart Status
SA Bit Supported
Table 7-1 Descriptions on the fields of display isis graceful-restart status
Restart Interval
Indicates the Graceful Restart interval
SA Bit Supported
Indicates whether SA is supported
The current IS-IS interface number
Restart Status
The Graceful Restart status of the current device
7.1.2  enable link-local-signaling
undo enable link-local-signaling
View
OSPF view
Parameter
None
Use the enable link-local-signaling command to enable the use of the Link-Local Signaling (LLC) in originated OSPF packets.
Use the undo enable link-local-signaling command to disable the use of Link-Local Signaling in originated OSPF packets.
By default, the use of the Link-Local Signaling for OSPF is disabled.
Example
# Enable the Link-Local Signaling for OSPF process 1.
[Sysname] ospf 1
             [Sysname-ospf-1] enable link-local-signaling
7.1.3  enable out-of-band-resynchronization
undo enable out-of-band-resynchronization
View
OSPF view
Parameter
None
Use the enable out-of-band-resynchronization command to enable the use of out-of-band resynchronization (OOB-Resynch) in originated OSPF packets.
Use the undo enable out-of-band-resynchronization command to disable the use of out-of-band resynchronization in originated OSPF packets.
By default, the use of out-of-band resynchronization is disabled.
Example
# Enable the out-of-band resynchronization for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
7.1.4  graceful-restart (BGP view)
graceful-restart
undo graceful-restart
View
BGP view
Parameter
None
Use the graceful-restart command to enable the Graceful Restart Capability for a BGP Speaker.
Use the undo graceful-restart command to disable the Graceful Restart Capability for a BGP Speaker.
By default, the Graceful Restart Capability for a BGP Speaker is disabled.
Note that, with BGP-based Graceful Restart, H3C S3610&S5510 series act as GR Helpers only.
Example
# Enable the Graceful Restart Capability for the current router.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart
7.1.5  graceful-restart (IS-IS view)
graceful-restart
View
IS-IS view
Parameter
None
Use the graceful-restart command to enable the IS-IS Graceful Restart Capability.
Use the undo graceful-restart command to disable the IS-IS Graceful Restart Capability.
By default, IS-IS Graceful Restart Capability is disabled.
Example
# Enable the Graceful Restart Capability for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart
7.1.6  graceful-restart (OSPF view)
graceful-restart
View
OSPF view
Parameter
None
Use the graceful-restart command to enable OSPF Graceful Restart Capability.
Use the undo graceful-restart command to disable OSPF Graceful Restart Capability.
By default, OSPF Graceful Restart Capability is disabled.
&  Note:
Before executing this command, enable OSPF LLS (link local signaling) and OOB (out of band resynchronization) first.
Example
# Enable Graceful Restart for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart
7.1.7  graceful-restart help
graceful-restart help { acl-number | prefix prefix-list }
View
OSPF view
Parameter
acl-number: The ACL number, in the range of 2,000 to 3,999.
prefix-list: The name of the specified address prefix list, in the range of 1 to 19 characters.
Use the graceful-restart help command to specify the routers for which the current router can serve as a GR Helper. (The routers can be specified by the ACL or the IP Prefix list.)
By default, the GR Helper Capability is not enabled.
&  Note:
Example
# Configure OSPF 1 to act as a GR Helper for routers defined in the ACL 2001.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart help 2001
7.1.8  graceful-restart interval
graceful-restart interval interval-value
undo graceful-restart interval
View
IS-IS view
Parameter
interval-value: Specifies the Graceful Restart interval ( the expected Graceful Restart interval), in the range of 30 to 1,800 seconds.
Use the graceful-restart interval command to configure the Graceful Restart interval. Use the undo graceful-restart interval command to restore the default Graceful Restart interval.
By default, the Graceful Restart interval is set to 300 seconds.
Example
# Configure the Graceful Restart interval for IS-IS process 1 to be 120 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart interval 120
7.1.9  graceful-restart suppress-sa
undo graceful-restart suppress-sa
View
IS-IS view
Parameter
None
Use the graceful-restart suppress-sa command to set the SA (Suppress-Advertisement) bit during restart.
Use the undo graceful-restart suppress-sa command to clear the SA bit.
By default, the SA bit is cleared during restart.
Note that:
l           For a router that has restarted its routing protocol, copies of LSPs generated by this router during the previous incarnation may still exist in the LSP databases of other routers in the network.
l           Copies of LSPs in the LSP databases in other routers which may look “newer” than LSPs generated by the restarting router after it initializes LSP fragment sequence numbers. This may result in temporary blackholes until new LSPs are regenerated and copies of them are flooded using higher sequence numbers upon completion of the restarting process.
l           These blackholes can be avoided if the neighbors of the restarting router suppress advertising the adjacency relationship with the restarting router until the latter has flooded its latest LSPs.
Example
# Set the SA bit in Graceful Restart.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart suppress-sa
7.1.10  graceful-restart timer restart
graceful-restart timer restart timer-value
undo graceful-restart timer restart
View
BGP view
Parameter
timer-value: Specifies the time taken to reestablish a session between the GR Restarter and the GR Helper, in the range 3 to 600 seconds.
Use the graceful-restart timer restart command to configure the maximum time taken by the peers to reestablish a BGP session.
Use the undo graceful-restart timer restart command to restore the default.
By default, the maximum time taken by the peers to reestablish a BGP session is 360 seconds.
Example
# Configure the maximum time taken by the peers to reestablish a BGP session to 150 seconds.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart timer restart 150
7.1.11  graceful-restart timer wait-for-rib
graceful-restart timer wait-for-rib timer-value
undo graceful-restart timer wait-for-rib
View
BGP view
Parameter
timer-value: Specifies the time to wait for the End-of-RIB, in the range 3 to 300 seconds.
Use the graceful-restart timer wait-for-rib command to configure the time to wait for the End-of-RIB.
Use the undo graceful-restart timer wait-for-rib command to restore the default.
By default, the time to wait for the End-of-RIB is 180 seconds.
&  Note:
l      After a BGP session has been successful (re)established, the End-of-RIB marker will be received in the time specified by this command.
l      It is intended to speed up route convergence.
Example
# Configure the time to wait for the End-of-RIB to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart timer wait-for-rib 100
7.1.12  reset ospf process graceful-restart
reset ospf [ process-id ] process graceful-restart
View
Parameter
process-id: Specifies OSPF process ID, in the range 1 to 65,535.
graceful-restart: Specifies that OSPF has enabled the Graceful Restart Capability.
Use the reset ospf process graceful-restart command to restart an OSPF process with a specified ID.
Example
# Restart OSPF 100 to trigger GR.
<Sysname> reset ospf 100 process graceful-restart
