18-网络管理和监控命令参考
21-信息中心命令
本章节下载: 21-信息中心命令  (1.97 MB)
21-信息中心命令
1 信息中心
1.1 信息中心配置命令
1.1.1 check logfile
1.1.2 diagnostic-logfile save
1.1.3 display character-set
1.1.4 display diagnostic-logfile summary
1.1.5 display info-center
1.1.6 display info-center file-server
1.1.7 display info-center filter
1.1.8 display info-center source
1.1.9 display logbuffer
1.1.10 display logbuffer summary
1.1.11 display logfile summary
1.1.12 display security-logfile summary
1.1.13 enable log updown
1.1.14 info-center diagnostic-logfile directory
1.1.15 info-center diagnostic-logfile enable
1.1.16 info-center diagnostic-logfile frequency
1.1.17 info-center diagnostic-logfile quota
1.1.18 info-center enable
1.1.19 info-center file-server transport-type
1.1.20 info-center file-server user
1.1.21 info-center filter
1.1.22 info-center format
1.1.23 info-center logbuffer
1.1.24 info-center logbuffer reserved-size
1.1.25 info-center logbuffer size
1.1.26 info-center logfile directory
1.1.27 info-center logfile enable
1.1.28 info-center logfile frequency
1.1.29 info-center logfile module alarm-threshold
1.1.30 info-center logfile size-quota
1.1.31 info-center logging suppress duplicates
1.1.32 info-center logging suppress module
1.1.33 info-center loghost
1.1.34 info-center loghost locate-info with-sn
1.1.35 info-center loghost source
1.1.36 info-center loghost vsys-to-admin enable
1.1.37 info-center security-logfile alarm-threshold
1.1.38 info-center security-logfile directory
1.1.39 info-center security-logfile enable
1.1.40 info-center security-logfile frequency
1.1.41 info-center security-logfile size-quota
1.1.42 info-center source
1.1.43 info-center synchronous
1.1.44 info-center syslog min-age
1.1.45 info-center syslog min-age
1.1.46 info-center syslog trap buffersize
1.1.47 info-center syslog utf-8 enable
1.1.48 info-center timestamp
1.1.49 info-center timestamp loghost
1.1.50 info-center trace-logfile quota
1.1.51 logfile save
1.1.52 reset logbuffer
1.1.53 security syslog rate-limit
1.1.54 security-logfile save
1.1.55 snmp-agent trap enable syslog
1.1.56 terminal debugging
1.1.57 terminal logging level
1.1.58 terminal monitor
1 信息中心
设备支持的存储介质与设备型号相关,本手册使用flash类型的存储介质举例,实际使用过程中,请以设备实际情况为准。
非缺省vSystem不支持本特性的部分命令,具体情况请见本文相关描述。有关vSystem的详细介绍请参见“虚拟化技术配置指导”中的“vSystem”。
1.1  信息中心配置命令
1.1.1  check logfile
check logfile命令用来检查日志文件是否被篡改。
check logfile file-path
context-admin
file-path:日志文件的绝对路径。日志文件的后缀名必须为.log或.log.gz,否则,命令行执行失败。
非缺省vSystem不支持本命令。
信息中心将日志保存到日志文件时,会使用设备出厂密钥为该日志文件计算一个摘要,保存在该日志文件中,该摘要用于校验日志文件是否被篡改。
执行本命令后,信息中心会使用设备出厂密钥重新为日志文件计算一个摘要,如果新计算的摘要和日志文件中保存的摘要一致,则表示日志文件未被篡改;如果新计算的摘要和日志文件中保存的摘要不同,则表示日志文件被篡改。
# 检查日志文件flash:/logfile/logfile.log是否被篡改。
<Sysname> check logfile flash:/logfile/logfile.log
The integrity check for the logfile succeeded.
diagnostic-logfile save命令用来手动将诊断日志文件缓冲区中的内容全部保存到诊断日志文件。
context-admin
非缺省vSystem不支持本命令。
诊断日志文件的保存路径可以通过info-center diagnostic-logfile directory命令配置。
诊断日志文件保存成功后,诊断日志文件缓冲区中的内容会被清空。
如果执行本命令时,诊断日志文件缓冲区中没有日志,本命令会执行成功,但不会创建或更新已有诊断日志文件。
# 手动将诊断日志文件缓冲区中的内容保存到诊断日志文件。
<Sysname> diagnostic-logfile save
The contents in the diagnostic log file buffer have been saved to the file flash:/diagfile/diagfile.log.
·     info-center diagnostic-logfile enable
·     info-center diagnostic-logfile directory
display character-set命令用来显示设备或登录软件当前使用的字符集编码。
display character-set [ terminal ]
context-admin
context-operator
terminal:显示登录软件当前使用的中文字符集编码。不指定该参数时,显示设备当前使用的字符集编码(设备当前使用的字符集编码为GB18030,不支持通过命令行修改)。
非缺省vSystem不支持本命令。
当用户使用登录软件登录设备,且设备往登录软件发送的信息中包含中文字符时,如果登录软件和设备使用的中文字符集编码不同,可能会出现中文字符在登录软件上显示为乱码的情况。
执行display character-set terminal命令,设备会向用户使用的登录软件分别发送UTF-8和GB18030格式的字符串进行测试:
·     如果UTF-8行的Test characters字段显示为“中文”,则表示该登录软件使用的中文字符集编码为UTF-8;
·     如果GB18030行的Test characters字段显示为“中文”,则表示该登录软件使用的中文字符集编码为GB18030。
设备的实际显示信息与设备型号有关,请以设备实际显示为准。本文中的显示信息仅为示例。
# 显示设备当前使用的字符集编码。
[Sysname] display character-set
Current character set encoding: GB18030
# 显示用户的登录软件当前使用的字符集编码。
[Sysname] display character-set terminal
Character set           Test characters
UTF-8                   涓枃
GB18030                 中文
表1-1 display character-set命令显示信息描述表
设备当前使用的字符集编码
Character set
设备向登录软件发送测试字符时使用的字符集编码,取值为UTF-8和GB18030
Test characters
显示测试字符串的解析结果。Test Characters取值为“中文”的行的“Character set”取值即为登录软件当前使用的字符集编码
display diagnostic-logfile summary命令用来显示诊断日志文件的配置。
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示诊断日志文件配置。
<Sysname> display diagnostic-logfile summary
  Diagnostic log file: Enabled.
  Diagnostic log file size quota: 10 MB
  Diagnostic log file directory: flash:/diagfile
  Writing frequency: 24 hour 0 min 0 sec
表1-2 display logfile summary命令显示信息描述表
Diagnostic log file
诊断日志文件当前的状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
单个诊断日志文件最大能占用的存储空间的大小,单位为MB
诊断日志文件存储的路径
Writing frequency
系统自动保存诊断日志文件的频率
display info-center命令用来显示各个输出方向的信息。
display info-center
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示各个输出方向的信息。
<Sysname> display info-center
Information Center: Enabled
Console: Enabled
Monitor: Enabled
Log host: Enabled
    192.168.0.1, log output filter: loghost1
    port number: 5000, host facility: local7
Log buffer: Enabled
    Max buffer size 1024, current buffer size 512,
    Current messages 0, dropped messages 0, overwritten messages 0
Log file: Enabled
Security log file: Enabled
Information timestamp format:
    Log host: Date
    Other output destination: Date
表1-3 display info-center命令显示信息描述表
Information Center
信息中心当前的状态:
·     Enabled:表示允许输出日志
·     Disabled:表示禁止输出日志
Console
控制台方向当前的状态:
·     Enabled:表示允许向控制台输出日志
·     Disabled:表示禁止向控制台输出日志
Monitor
监视终端方向当前的状态:
·     Enabled:表示允许向监视终端输出日志
·     Disabled:表示禁止向监视终端输出日志
Log host: Enabled
日志主机方向的信息:
·     Enabled:表示允许向日志主机输出日志
·     Disabled:表示禁止向日志主机输出日志
只有开启后,才有下面具体的显示内容,包括:
·     日志主机的IP地址
·     关联的日志输出规则名称
·     日志主机接收日志信息的端口
·     日志主机的记录工具
Log buffer: Enabled
日志缓冲区方向的信息,包括开启状态、最大容量、当前容量、当前信息数、已丢弃的信息数、被覆盖的信息数
Log file
日志文件方向当前的状态:
·     Enabled:表示允许向日志文件输出日志
·     Disabled:表示禁止向日志文件输出日志
Security log file
安全日志文件方向当前的状态:
·     Enabled:表示允许向安全日志文件输出日志
·     Disabled:表示禁止向安全日志文件输出日志
    Log host: Date
信息时间戳配置,包括日志主机输出方向和非日志主机输出方向日志信息的时间戳类型,分为boot、date、iso、none和no-year-date五种
display info-center file-server命令用来显示远端服务器的相关配置以及备份记录。
context-admin
context-operator
非缺省vSystem不支持本命令。
当本机向远端服务器备份日志文件时,会记录本次备份操作的相关信息,最多可记录10条信息。使用本命令,可查看设备记录的备份操作信息,以便用户了解备份操作的执行时间和执行结果等信息。
# 显示远端服务器的相关配置以及备份记录。
<Sysname> display info-center file-server
Username: test
Protocol: ftp
IP: 1.1.1.1
Port: 22
VPN: vpnname
Directory: /backup
Filename prefix: my_backup
File type: logfile, security-logfile
Backup records:
 No. TimeStamp                FileName
 1   Wed Jan 15 14:20:18 2022 my_backup_20220115142018.log
!2   Wed Jan 15 14:33:10 2022 my_backup_20220115143310.log
 3   Wed Jan 15 14:49:37 2022 my_backup_20220115144937.log
The exclamation mark (!) indicates that the backup attempt failed.
表1-4 display info-center file-server命令显示信息描述表
Username
登录远端服务器时使用的用户名,未配置时显示为N/A
使用FTP或者SCP协议备份日志文件时,必须配置登录用户名和密码
Protocol
备份日志文件时使用的协议
IP
远端服务器的IP地址
Port
远端服务器的侦听端口号
VPN
远端服务器所属的VPN
Directory
远端服务器上日志文件的存储路径
Filename prefix
将日志文件保存到远端服务器上时使用的文件名前缀
Backup records
日志文件的备份记录,记录的内容包括:
·     No.:备份操作的序列号
·     TimeStamp:本机开始备份日志文件时的系统时间
·     FileName:日志文件存储在远端服务器上使用的文件名,该文件名由文件名前缀(取值见Filename prefix字段)+时间戳(取值见TimeStamp字段)组成
“!”表示该行描述的日志文件备份失败了
·     info-center file-server transport-type
·     info-center file-server user
display info-center filter命令用来显示用户创建的日志输出规则的相关信息。
display info-center filter [ filtername ]
context-admin
context-operator
filter-name:显示指定日志输出规则的相关信息。filter-name表示日志信息输出规则的名称,必须为设备上已创建的日志输出规则。不指定该参数时,显示所有日志输出规则的相关信息。
非缺省vSystem不支持本命令。
# 显示日志输出规则loghost1的相关信息。
<Sysname> display info-center filter loghost1
 Log output filter: loghost1
 Module                       Rule
 ARP                          Debugging
 CFGLOG                       Deny
 Default                      Informational
表1-5 日志主机关联日志输出规则描述表
Log output filter:
日志输出规则名
Module
输出规则中的模块
Rule
模块对应的输出规则
·     info-center filter
display info-center source命令用来显示日志信息的输出规则。
display info-center source [ module module-name ]
context-admin
context-operator
module module-name:显示指定模块日志信息的输出规则。module-name表示模块的名称,配置时需要完整输入,不区分大小写,执行display info-center source module ?命令,通过帮助信息可获得该参数的取值。不指定该参数时,表示显示所有模块日志信息的输出规则。
非缺省vSystem不支持本命令。
日志在各输出方向都有缺省输出规则,缺省输出规则请参见表1-6,用户也可以通过info-center source命令用来配置日志信息的输出规则,display info-center source命令显示的是日志信息当前的实际输出规则。
表1-6 日志信息的缺省输出规则
输出方向
日志信息来源
开关
等级
控制台
所有支持的模块
开
debugging
监视终端
所有支持的模块
关
debugging
日志主机
所有支持的模块
开
informational
日志缓冲区
所有支持的模块
开
informational
日志文件
所有支持的模块
开
informational
日志转换成SNMP告警输出
所有支持的模块
关
informational
# 显示所有模块日志信息的输出规则。
<Sysname> display info-center source
 Module   Console    Monitor    Loghost    Logbuffer  Logfile    Logtrap
 AAA      DEBUG      DEBUG      INFO       INFO       INFO       INFO
 ACL      DEBUG      DEBUG      INFO       INFO       INFO       INFO
 ADJ4     DEBUG      DEBUG      INFO       INFO       INFO       INFO
# 显示SYSLOG模块日志信息的输出规则。
<Sysname> display info-center source module syslog
 SYSLOG   DEBUG      DEBUG      INFO       INFO       INFO       INFO
表1-7 display info-center source命令显示信息描述表
Module
模块名称
Console
在控制台的输出规则,若取值为deny则代表日志不允许在该方向输出
Monitor
在监控终端的输出规则,若取值为deny则代表日志不允许在该方向输出
Loghost
在日志主机的输出规则,若取值为deny则代表日志不允许在该方向输出
Logbuffer
在日志缓冲区的输出规则,若取值为deny则代表日志不允许在该方向输出
Logfile
在日志文件的输出规则,若取值为deny则代表日志不允许在该方向输出
Logtrap
日志转换成SNMP告警输出的输出规则,若取值为deny则代表日志不允许在该方向输出
·     info-center source
display logbuffer命令用来显示日志缓冲区的状态和日志缓冲区记录的日志信息。
display logbuffer [ vsys vsys-name ] [ module module-name [ submodule submodule-name ] ] [ reverse ] [ level severity | size buffersize | slot slot-number ] * [ last-mins mins ]
context-admin
context-operator
vsys-admin
vsys-operator
vsys vsys-name:显示非缺省vSystem日志缓冲区中指定vSystem的日志信息。vsys-name表示vSystem的名称,为1~31个字符的字符串,取值包括大写字母、小写字母、数字、特殊字符“_”和“-”,区分大小写。非缺省vSystem不支持本参数。
module module-name:显示指定模块日志缓冲区的状态和日志缓冲区记录的日志信息。module-name表示模块的名称,配置时需要完整输入,不区分大小写,执行display logbuffer module ?命令,通过帮助信息可获得该参数的取值。不指定该参数时,表示该配置对通用日志缓冲区生效。
submodule submodule-name:显示当前模块下指定子模块日志缓冲区的状态和日志缓冲区记录的日志信息。submodule-name表示子模块名称,配置时需要完整输入,不区分大小写。当前模块是否支持子模块以及子模块的取值,请通过执行display logbuffer module module-name submodule ?命令获取。不指定该参数时,表示该配置对当前模块下所有子模块生效。
reverse:指定日志的显示顺序为从新到旧。如果不指定该参数,将先显示旧日志,最后显示最新的日志。
level severity:显示日志缓存中指定级别日志的信息,severity表示信息级别,取值范围为0~7。不带该参数时将显示系统日志缓冲区内所有级别的日志信息。
表1-8 信息级别列表
数值
信息级别
0
emergency
表示设备不可用的信息,如系统授权已到期
1
alert
表示设备出现重大故障,需要立刻做出反应的信息,如流量超出接口上限
2
critical
表示严重信息,如设备温度已经超过预警值,设备电源、风扇出现故障等
3
error
表示错误信息,如接口链路状态变化等
4
warning
表示警告信息,如接口连接断开,内存耗尽告警等
5
notification
表示正常出现但是重要的信息,如通过终端登录设备,设备重启等
6
informational
表示需要记录的通知信息,如通过命令行输入命令的记录信息,执行ping命令的日志信息等
7
debugging
表示调试过程产生的信息
size buffersize:显示日志缓冲区中指定条数的最新日志。buffersize表示要显示的日志缓冲区中最新的日志信息的条数,取值范围为1~1024。不带该参数时将显示系统日志缓冲区内所有的日志信息。
slot slot-number:显示指定成员设备的日志缓冲区状态及日志缓冲区中记录的日志信息。slot-number表示设备在IRF中的成员编号。如不指定该参数,将显示所有成员设备的日志缓冲区状态及日志缓冲区中记录的日志信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
last-mins mins:指定显示最近一段时间日志缓冲区状态及日志缓冲区中记录的日志信息,取值范围为1~43200,单位为分钟。不指定该参数时,不对显示信息进行时间过滤。
# 显示系统日志缓冲区的状态和缓冲区记录的日志信息。
<Sysname> display logbuffer
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 718
Current messages: 512
Some messages might not be displayed due to permission issues.
%Jun 17 15:57:09:578 2017 Sysname SYSLOG/7/SYS_RESTART:System restarted --
# 显示最近5分钟的日志缓冲区状态及日志缓冲区中记录的日志信息。
<Sysname> display logbuffer last-mins 5
Log buffer: Enabled
Dropped messages: 0
Overwritten messages: 0
Current messages: 191
%Jan  1 01:00:06:784 2018 Sysname SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.1.242-User=**; Command is display current-configuration
%Jan  1 01:03:19:691 2018 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.33.
%Jan  1 01:03:21:269 2018 Sysname SHELL/6/SHELL_CMD: -Line=vty1-IPAddr=192.168.1.33-User=**; Command is display logbuffer last-mins 5
表1-9 display logbuffer命令显示信息描述表
Log buffer
是否允许输出到日志缓冲区方向:
·     Enabled:表示允许
·     Disabled:表示不允许
Max buffer size
允许的日志缓冲区可存储的最大信息条数
Actual buffer size
当前配置的日志缓冲区可存储的最大信息条数
Dropped messages
被丢弃的信息数(内存分配失败或分配日志缓冲区过小时丢失的信息数)
被覆盖的信息数(如果缓冲区存储空间不足,最早收到的信息数会被新的信息覆盖掉)
Current messages
当前记录的信息数
Failed to obtain  the specified data. The following tries to display all data in the log  buffer.
(和设备内部数据库信息交互异常)获取显示信息失败,下面将尝试显示日志缓冲区中的所有数据
由于当前登录用户的角色不同,可以查看的日志内容不同。关于用户角色的详细介绍,请参见“基础配置指导”中的“RBAC”
·     info-center logbuffer
·     reset logbuffer
display logbuffer summary命令用来显示系统日志缓冲区的概要信息。
display logbuffer summary [ level severity | slot slot-number ] *
context-admin
context-operator
level severity:显示日志缓存中指定级别日志的概要信息,severity表示信息级别,取值范围为0~7,具体内容请参见表1-10。不带该参数时,将显示系统日志缓冲区内所有级别的日志概要信息。
slot slot-number:显示指定成员设备的日志缓冲区的概要信息。slot-number表示设备在IRF中的成员编号。如不指定该参数,将显示所有成员设备上的日志缓冲区概要信息。‌‌
表1-10 信息级别列表
数值
信息级别
0
emergency
表示设备不可用的信息,如系统授权已到期
1
alert
2
critical
3
error
表示错误信息,如接口链路状态变化等
4
warning
5
notification
6
informational
7
debugging
表示调试过程产生的信息
非缺省vSystem不支持本命令。
# 显示系统日志缓冲区的概要信息。‌‌
<Sysname> display logbuffer summary
  Slot EMERG ALERT  CRIT ERROR  WARN NOTIF  INFO DEBUG
     1     0     0     0     7     0    34    38     0
表1-11 display logbuffer summary命令显示信息描述表
EMERG
emergency级别的信息数,请参见表1-12
ALERT
alert级别的信息数,请参见表1-12
CRIT
critical级别的信息数,请参见表1-12
ERROR
error级别的信息数,请参见表1-12
WARN
warning级别的信息数,请参见表1-12
NOTIF
notification级别的信息数,请参见表1-12
INFO
informational级别的信息数,请参见表1-12
DEBUG
debugging级别的信息数,请参见表1-12
表1-12 信息级别列表
数值
信息级别
0
emergency
表示设备不可用的信息,如系统授权已到期
1
alert
2
critical
3
error
表示错误信息,如接口链路状态变化等
4
warning
5
notification
6
informational
7
debugging
表示调试过程产生的信息
display logfile summary命令用来显示日志文件的配置。
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示日志文件配置。
<Sysname> display logfile summary
  Log file: Enabled.
  Log file size quota: 10 MB
  Log file directory: flash:/logfile
  Writing frequency: 24 hour 0 min 10 sec
表1-13 display logfile summary命令显示信息描述表
Log file
是否允许输出到日志文件方向:
·     Enabled:表示已开启
·     Disabled:表示未开启
Log file size quota
单个日志文件最大能占用的存储空间的大小,单位为MB
Log file directory
日志文件存储的路径
Writing frequency
系统自动保存日志文件的频率
display security-logfile summary命令用来显示安全日志文件的概要信息。
security-audit
非缺省vSystem不支持本命令。
只有具有安全日志管理员角色的本地用户才能使用本命令。安全日志管理员的配置请参见“安全命令参考”中的“AAA”。
# 显示安全日志文件概要信息。
<Sysname> display security-logfile summary
  Security log file size quota: 10 MB
  Security log file directory: flash:/seclog
  Alarm threshold: 80%
  Current usage: 30%
表1-14 display security-logfile summary命令显示信息描述表
Security log file
安全日志文件当前的状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
单个安全日志文件最大能占用的存储空间的大小
安全日志文件存储的路径
Alarm-threshold
安全日志文件使用率告警门限
Current usage
当前的安全日志文件使用率
Writing frequency
系统自动保存安全日志文件的频率
·     authorization-attribute(安全命令参考/AAA)
enable log updown命令用来允许端口在状态发生改变时生成Link up和Link down的日志信息。
undo enable log updown命令用来禁止端口在状态发生改变时生成Link up和Link down的日志信息。
enable log updown
允许所有端口在状态发生改变时生成端口Link up和Link down的日志信息。
context-admin
非缺省vSystem不支持本命令。
# 禁止端口GigabitEthernet1/0/1在状态发生改变时生成Link up和Link down的日志信息。
[Sysname-GigabitEthernet1/0/1] undo enable log updown
info-center diagnostic-logfile directory命令用来修改存储诊断日志文件的路径。
存储诊断日志文件路径为设备缺省文件系统根目录下的diagfile文件夹。
context-admin
dir-name:诊断日志文件存储的路径,为1~64个字符的字符串。
非缺省vSystem不支持本命令。
在执行该配置前,存储诊断日志文件的文件夹必须为当前已创建的目录。
配置会在IRF重启或主从设备倒换后失效。‌
# 配置存放诊断日志文件的目录为flash:/test。
<Sysname> mkdir test
[Sysname] info-center diagnostic-logfile directory flash:/test
info-center diagnostic-logfile enable命令用来开启诊断日志同步保存功能。
undo info-center diagose-logfile enable命令用来关闭诊断日志同步保存功能。
undo info-center diagnostic-logfile enable
诊断日志同步保存功能处于开启状态。
context-admin
非缺省vSystem不支持本命令。
开启诊断日志同步保存功能后,系统将诊断日志进行集中处理:当生成的诊断日志时,系统会将诊断日志信息同步保存到诊断日志文件。这样既实现了诊断日志的集中管理,又有利于用户随时快捷地查看诊断日志,了解设备状态。
# 开启诊断日志同步保存功能。
[Sysname] info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency命令用来配置设备自动保存诊断日志文件的频率。
undo info-center diagnostic-logfile frequency命令用来恢复缺省情况。
设备自动保存诊断日志文件的频率为86400秒。
context-admin
freq-sec:系统自动保存诊断日志文件的频率,取值范围为10~86400,单位为秒。
非缺省vSystem不支持本命令。
配置设备自动保存诊断日志文件的频率后,诊断日志会先被输出到诊断日志文件缓冲区(diagnostic-logfile buffer),系统会按照配置中指定的频率将诊断日志文件缓冲区的内容写入诊断日志文件。
# 配置诊断日志自动保存到文件的频率为600秒。
[Sysname] info-center diagnostic-logfile frequency 600
info-center diagnostic-logfile quota命令用来配置单个诊断日志文件最大可占用的存储空间的大小。
undo info-center diagnostic-logfile quota命令用来恢复缺省情况。
单个诊断日志文件最大能占用的存储空间为10MB。
context-admin
非缺省vSystem不支持本命令。
# 配置单个诊断日志文件最大能占用的存储空间的大小为6MB。
[Sysname] info-center diagnostic-logfile quota 6
info-center enable命令用来开启信息中心功能。
undo info-center enable命令用来关闭信息中心功能。
info-center enable
信息中心处于开启状态。
context-admin
非缺省vSystem不支持本命令。
# 开启信息中心功能。
[Sysname] info-center enable
info-center file-server transport-type命令用来配置将日志文件备份到远端服务器。
undo info-center file-server transport-type命令用来恢复缺省情况。
info-center file-server transport-type { ftp | scp | tftp } { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] filename-prefix filename-prefix [ file-type { logfile | security-logfile } ]
设备不会将日志文件备份到远端服务器。
context-admin
ftp:表示使用FTP协议将日志文件备份到远端服务器。本设备作为FTP客户端。关于FTP功能的详细介绍请参见“基础配置指导”中的“FTP和TFTP”。
scp:表示使用SCP协议将日志文件备份到远端服务器。SCP(Secure Copy)基于SSH2,可提供安全的文件复制功能。本设备作为SCP客户端。关于SCP功能的详细介绍请参见“安全配置指导”中的“SSH”。
tftp:表示使用TFTP协议将日志文件备份到远端服务器。本设备作为TFTP客户端。关于TFTP功能的详细介绍请参见“基础配置指导”中的“FTP和TFTP”。
ipv4-address:远端服务器的IPv4地址,必须和远端服务器侧的配置一致。
ipv6 ipv6-address:远端服务器的IPv6地址,必须和远端服务器侧的配置一致。
port port-number:远端服务器的侦听端口号,必须和远端服务器侧的配置一致。取值范围为1~65535,FTP缺省值为21,SCP缺省值为22,TFTP缺省值为69。
vpn-instance vpn-instance-name:指定远端服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示日志主机位于公网中。
directory directory:远端服务器上存储日志文件的路径,为1~63个字符的字符串,区分大小写。不指定该参数时,表示将日志文件备份到远端服务器的工作路径。使用该参数,可以将日志文件保存到远端服务器工作路径下的子目录(请先在远端服务器上创建子目录,如果指定的路径不存在,会导致备份失败)。对于TFTP和FTP服务器,该路径格式为相对路径;对于SCP服务器,该路径格式为绝对路径。
filename-prefix filename-prefix:远端服务器上存储日志文件时使用的文件名前缀,为1~30个字符的字符串,只能包含字母、数字、“_”和“-”,不区分大小写。
file-type { logfile | security-logfile }:表示将指定类型的日志文件备份。
·     logfile表示将info-center logfile directory命令指定的路径下的普通日志文件备份;
·     security-logfile表示将info-center security-logfile directory命令指定的路径下的安全日志文件备份。不指定该参数时,表示将对应路径的普通日志文件和安全日志文件均备份。
非缺省vSystem不支持本命令。
使用本命令可以将普通日志的日志文件和(或)安全日志的日志文件通过FTP、TFTP或者SCP协议备份到远端服务器,以提高日志文件的安全性。
当设备只支持单个日志文件时,日志写到文件尾后,设备会自动将该日志文件备份到远端服务器。
当设备支持多个日志文件时,写满一个日志文件后,设备会自动将该日志文件备份到远端服务器。
多次配置本命令,最新配置生效。
# 使用FTP协议将普通日志文件备份到IP地址为1.1.1.1、侦听端口号为8000的FTP服务器,日志存储到FTP服务器上时,使用的日志文件前缀为2-2-2-2。
[Sysname] info-center file-server transport-type ftp 1.1.1.1 port 8000 filename-prefix 2-2-2-2 file-type logfile
·     display info-center file-server
info-center file-server user命令用来配置登录远端服务器备份日志文件时使用的用户名和密码。
info-center file-server user user-name password { cipher | simple } password
undo info-center file-server user
未配置登录远端服务器备份日志文件时使用的用户名和密码。
context-admin
user-name:登录FTP服务器或SCP服务器备份日志文件时使用的用户名,为1~63个字符的字符串,区分大小写。
password { cipher | simple } password:登录FTP服务器或SCP服务器备份日志文件时使用的密码,区分大小写。
·     cipher表示以密文方式设置密码,密文密码为33~117个字符的字符串。
·     simple表示以明文方式设置密码,该密码将以密文形式存储,明文密码为1~63个字符的字符串。
非缺省vSystem不支持本命令。
使用FTP或SCP协议将日志文件备份到远端服务器前,请使用本命令配置远端服务器的登录用户名和密码,且本命令配置的参数值必须和远端服务器侧的配置相同。
多次执行本命令,最新配置生效。
# 登录FTP服务器或SCP服务器备份日志文件时使用的用户名为ftpuser,密码为ftp123456。
[Sysname] info-center file-server user ftpuser password simple ftp123456
info-center filter命令用来创建日志输出规则。
undo info-center filter命令用来删除日志输出规则。
info-center filter filter-name { module-name | default } { deny | level severity }
undo info-center filter filter-name [ module-name | default ]
未创建日志输出规则。
context-admin
filter-name:日志信息输出规则的名称,为1~8个字符的字符串,不区分大小写。
module-name:为指定模块配置日志输出规则,该参数的取值可通过在系统视图下输入info-center filter filter-name ?来获得。
default:配置所有应用模块日志信息的缺省输出规则。
deny:禁止输出日志信息。
level severity:指定允许输出的日志信息的最低级别,取值为alert、critical、debugging、emergency、error、informational、notification、warning,各参数的含义请参见表1-15。例如,本参数配置为warning,则表示配置对emergency、alert、critical、error和warning级别的日志均生效。
表1-15 信息级别列表
数值
信息级别
0
emergency
表示设备不可用的信息,如系统授权已到期
1
alert
2
critical
3
error
表示错误信息,如接口链路状态变化等
4
warning
5
notification
6
informational
7
debugging
表示调试过程产生的信息
非缺省vSystem不支持本命令。
多次执行本命令可以创建多个输出规则,将输出规则和日志主机绑定,可以为不同的日志主机指定不同的输出规则。info-center source命令也可以配置日志输出规则。本命令配置的输出规则目前只支持应用到日志主机输出方向,info-center source命令配置的日志输出规则适用于所有输出方向。对于日志主机输出方向,本命令配置的输出规则优先于info-center source命令配置的输出规则。
用户可以使用module-name参数为应用模块单独配置输出规则,也可以使用default参数为所有应用模块配置缺省输出规则,这两种配置可以同时存在。多次使用module-name参数为同一应用模块配置输出规则时,最后一次执行的命令生效;多次使用default参数配置缺省输出规则时,最后一次执行的命令生效。
对于应用模块:
·     优先使用带module-name参数的配置。
·     如果没有使用module-name参数为应用模块单独配置输出规则,则该模块使用default参数配置的输出规则。
如果配置了带module-name参数的命令,未配置带default参数的命令行,则未单独配置输出规则的应用模块允许alert~informational级别的日志输出。
给应用模块单独配置输出规则后,必须使用module-name参数来修改或删除该规则,使用default参数进行的配置对该模块不生效。
# 配置名称为loghost1的输出规则,用来允许ARP模块alert~notification级别的日志信息输出,SNMP模块alert~warning级别的日志信息输出,其他模块的日志信息禁止输出。
[Sysname] info-center filter loghost1 arp level notification
[Sysname] info-center filter loghost1 snmp level warning
[Sysname] info-center filter loghost1 default deny
·     display info-center filter
·     info-center loghost
info-center format命令用来配置发往日志主机的日志信息的输出格式。
undo info-center format命令用来恢复缺省情况。
info-center format { cmcc | damddos | rfc5424 | sgcc | unicom }
发往日志主机的日志信息的格式为非定制格式。
context-admin
cmcc:配置发往日志主机的日志信息的输出格式为中国移动格式。
damddos:配置发往日志主机的日志信息的输出格式为电信云堤格式。
本参数的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
F5000-AI-160-G、F5000-AI-120-G、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-AI160、F5000-AI360、F5000-CN160、F5000-AI120、F5000-CN-G85、F5000-CN-G65、F5000-CN-G55、F5000-E-G、F5000-E-G2、F5000-S-G2、F5000-M-G2、F5000-A-G2、F5080、F5060、F5030、F5000-E
不支持
F5000-AI-15
支持
F1000系列
F1000-AK9130、F1000-AI-90、F1000-AI-80、F1000-AI-70、F1000-AI-60、F1000-V90
支持
F1000-AI-75、F1000-AI-65、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-15、F1000-AI-10、F1000-AI-05、F1000-AI-03-E、F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-15-G、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G、F1000-AK1180-G、F1000-AK1080-G、F1000-AK1050-G、F1000-V60、F1000-V50
不支持
插卡
LSEM1FWESD0、LSXM1FWDF1、LSUM1FWDEC0、IM-NGFWX-IV、LSQM1FWDSC0、LSWM1FWD0、LSPM6FWD、LSPM6FWDB、LSCM1FWDSD0
不支持
rfc5424:配置发往日志主机的日志信息的输出格式为RFC 5424格式。
sgcc:配置发往日志主机的日志信息的输出格式为国家电网格式。
unicom:配置发往日志主机的日志信息的输出格式为中国联通格式。
非缺省vSystem不支持本命令。
发往日志主机的日志信息有以下格式:非定制格式、中国移动格式、RFC 5424格式、国家电网格式和中国联通格式。有关日志信息格式的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
本命令配置的日志格式对所有日志主机生效,info-center loghost命令中指定的日志格式对指定日志主机生效。对于同一日志主机,优先使用info-center loghost命令中指定的日志格式。
# 配置发往日志主机的日志信息的格式为RFC 5424格式。
[Sysname] info-center format rfc5424
info-center logbuffer命令用来允许日志信息输出到日志缓冲区。
undo info-center logbuffer命令用来禁止日志信息输出日志缓冲区。
允许日志信息输出到日志缓冲区。
context-admin
非缺省vSystem不支持本命令。
配置本命令后,缺省vSystem生成的日志会输出到缺省vSystem的日志缓冲区,非缺省vSystem生成的日志会输出到非缺省vSystem的日志缓冲区。所有非缺省vSystem共享同一块日志缓冲区。
配置info-center logbuffer命令后,设备会将业务模块生成的日志保存到日志缓冲区。其中,设备会为一些业务模块(例如会话等)、子模块分别创建独立的日志缓冲区,模块的日志缓冲区用来存储该模块的日志,子模块的日志缓冲区用来存储该子模块的日志,其它业务模块的日志会统一存储到通用日志缓冲区中。用户可使用display logbuffer命令查看这些日志缓冲区的内容或者使用info-center logbuffer size命令配置这些日志缓冲区的大小。
# 配置允许日志信息输出到日志缓冲区。
[Sysname] info-center logbuffer
·     display logbuffer
·     info-center enable
info-center logbuffer reserved-size命令用来为非缺省vSystem预留日志缓冲区资源。
undo info-center logbuffer reserved-size命令用来恢复缺省情况。
info-center logbuffer reserved-size reserved-size-value
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
F5000-AI-160-G、F5000-AI-120-G、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-AI160、F5000-AI360、F5000-CN160、F5000-AI120、F5000-AI-15、F5000-CN-G85、F5000-CN-G65、F5000-CN-G55、F5000-E-G、F5000-E-G2、F5000-S-G2、F5000-M-G2、F5000-A-G2、F5080、F5060、F5030、F5000-E
支持
F1000系列
F1000-AK9130、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AK1080-G 、F1000-AK1050-G
不支持
F1000-AI-90、F1000-AI-80、F1000-AI-75、F1000-AI-70、F1000-AI-65、F1000-AI-60、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-15、F1000-AI-10、F1000-AI-05、F1000-AI-03-E、F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-15-G、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G、F1000-AK1180-G、F1000-V90、F1000-V60、F1000-V50
支持
插卡
支持
所有非缺省vSystem共享并抢占非缺省vSystem日志缓冲区资源。
vSystem视图
reserved-size-value:表示为非缺省vSystem预留的日志缓冲区资源,用可存放的日志条数表示,取值范围为1~512。
缺省vSystem日志缓冲区用于存放缺省vSystem的日志,缺省vSystem日志缓冲区的大小可通过info-center logbuffer size命令配置。
非缺省vSystem日志缓冲区用于存放所有非缺省vSystem的日志。缺省情况下,所有非缺省vSystem均共享非缺省vSystem日志缓冲区资源。用户可通过命令行为指定非缺省vSystem预留日志缓冲区资源,预留的资源其它vSystem不能使用。所有非缺省vSystem会优先使用共享的日志缓冲区资源,当共享的日志缓冲区资源不足时,配置了本命令的vSystem可以再使用预留的日志缓冲区资源,未配置本命令的vSystem的日志将被丢弃。
# 为vsys1预留日志缓冲区资源,可存放100条日志。
<sysname> system-view
[sysname] vsys vsys1
[sysname-vsys-2-vsys1] info-center logbuffer reserved-size 100
info-center logbuffer size命令用来配置日志缓冲区可存储的信息条数。
undo info-center logbuffer size命令用来恢复缺省情况。
info-center logbuffer [ module module-name ] size buffersize
undo info-center logbuffer [ module module-name ] size
日志缓冲区可存储512条信息。
context-admin
module module-name:配置指定模块的日志缓冲区可存储的信息条数。module-name表示模块的名称,配置时需要完整输入,不区分大小写,执行info-center logbuffer module ?命令,通过帮助信息可获得该参数的取值。不指定该参数时,表示该配置对通用日志缓冲区生效。
buffersize:日志缓冲区可存储的信息条数,取值范围为0~1024,缺省值为512。
非缺省vSystem不支持本命令。
# 配置日志缓冲区可存储的信息条数为50。
[Sysname] info-center logbuffer size 50
# 恢复日志缓冲区可存储的信息条数为512。
[Sysname] undo info-center logbuffer size
·     display logbuffer
info-center logfile directory命令用来配置存放日志文件的目录。
存放日志文件的目录为设备缺省文件系统根目录下的logfile文件夹。
context-admin
dir-name:存放日志文件的路径,为1~64个字符的字符串。
非缺省vSystem不支持本命令。
在执行该配置前,存放日志文件的目录必须为当前已创建的目录。
生成的日志文件的后缀名为.log。
# 配置存放日志文件的目录为flash:/test。
[Sysname] info-center logfile directory flash:/test
·     info-center logfile enable
info-center logfile enable命令用来允许日志信息输出到日志文件。
undo info-center logfile enable命令用来禁止日志信息输出到日志文件。
允许日志信息输出到日志文件。
context-admin
非缺省vSystem不支持本命令。
配置本命令后,设备会将业务模块生成的日志保存到日志文件。其中,设备会为一些业务模块(例如会话、攻击防御等)、子模块分别分配独立的日志文件,模块的日志文件用来存储该模块的日志,子模块的日志文件用来存储该子模块的日志,其它业务模块的日志会统一存储到通用日志文件中。模块日志文件以模块名和“.log”后缀为文件名,形如:session.log等。
设备在出厂时已经确定了可以单独存储日志的业务模块的名称,用户不能修改。
# 配置允许日志信息输出到日志文件。
[Sysname] info-center logfile enable
info-center logfile frequency命令用来配置系统自动保存日志文件的频率。
undo info-center logfile frequency命令用来恢复缺省情况。
设备自动保存日志文件的频率为86400秒。
context-admin
freq-sec:系统自动保存日志文件的频率,取值范围为1~86400,单位为秒。
非缺省vSystem不支持本命令。
配置系统自动保存日志文件的频率后,系统会按照指定的频率将日志文件缓冲区的内容写入日志文件。
# 配置设备自动保存日志文件的频率为60000秒。
[Sysname] info-center logfile frequency 60000
info-center logfile module alarm-threshold命令用来配置模块日志文件使用率的告警门限。
undo info-center logfile module alarm-threshold命令用来恢复缺省情况。
info-center logfile module module-name alarm-threshold usage
undo info-center logfile module module-name alarm-threshold
模块日志文件使用率的告警门限是80。即当模块日志文件使用率达到80%时,系统会提醒用户。
context-admin
module-name:表示模块的名称,配置时需要完整输入,不区分大小写,执行info-center logfile module ?命令,通过帮助信息可获得该参数的取值。
usage:表示日志文件使用率的告警门限,取值范围为0~100。取值为0时,表示关闭该模块日志文件的使用率告警功能。
非缺省vSystem不支持本命令。
使用本命令可以配置模块日志文件使用率的告警门限。当使用率超过告警门限时,系统会生成日志提醒用户,此时,用户可以将日志文件进行备份,以防历史数据丢失。
# 当SESSION模块的日志文件使用率达到90%时进行告警。
[Sysname] info-center logfile module SESSION alarm-threshold 90
info-center logfile size-quota命令用来配置单个日志文件最大能占用的存储空间的大小。
undo info-center logfile size-quota命令用来恢复缺省情况。
info-center logfile [ module module-name ] size-quota size
undo info-center logfile [ module module-name ] size-quota
单个通用日志文件可使用的存储空间的最大值为10MB,指定模块的单个日志文件可使用的存储空间的最大值为1MB。
context-admin
module module-name:配置指定模块的单个日志文件最大能占用的存储空间的大小。module-name表示模块的名称,配置时需要完整输入,不区分大小写,执行info-center logfile module ?命令,通过帮助信息可获得该参数的取值。不指定该参数时,表示该配置对通用日志文件生效。
非缺省vSystem不支持本命令。
# 配置单个日志文件最大能占用的存储空间的大小为2MB。
[Sysname] info-center logfile size-quota 2
info-center logging suppress duplicates命令用来开启抑制重复日志输出功能。
undo info-center logging suppress duplicates命令用关闭抑制重复日志输出功能。
抑制重复日志输出功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
当设备持续生成相同的日志,大量重复的信息会浪费设备资源和网络资源,并导致有用的信息被淹没,不利于设备的维护。为了避免此问题,可开启重复日志抑制功能。
# 开启抑制重复日志输出功能。
[Sysname] info-center logging suppress duplicates
info-center logging suppress module命令用来禁止指定模块日志的输出。
undo info-center logging suppress module命令用来取消对指定模块日志输出的限制。
undo info-center logging suppress module module-name mnemonic { all | mnemonic-value }
未禁止指定模块日志的输出。
context-admin
module-name:指定需要被过滤的应用模块的名称,为1~8个字符的字符串,不区分大小写。执行info-center logging suppress module ?命令,设备会自动显示可配置的模块名称。
mnemonic { all | mnemonic-value }:表示需要被过滤的应用模块的助记符。其中:
·     all:表示过滤该模块的所有日志。
·     mnemonic-value:表示助记符的全部内容,为1~32个字符的字符串,不区分大小写。如果输入的是助记符的部分内容,将不会禁止输出该助记符对应的日志。
非缺省vSystem不支持本命令。
当系统日志较多时,对于用户不关心的日志,可以使用该命令,禁止指定模块日志的输出,或者禁止指定模块特定助记符的日志输出。
# 禁止SHELL模块助记符为SHELL_LOGIN的日志输出。
[Sysname] info-center logging suppress module shell mnemonic shell_login
info-center loghost命令用来配置日志主机及相关参数。
undo info-center loghost命令用来取消日志主机及相关参数的配置。
(缺省vSystem)
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ facility local-number | filter filter-name | format { cmcc | damddos | default | rfc5424 | sgcc | unicom } | port port-number | source-ip source-ip-address | tcp [ ssl-client-policy policy-name ] ] *
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ facility local-number  | filter filter-name | port port-number | source-ip source-ip-address ] * format rfc5424-json-v1 tcp [ end-with-length ] ssl-client-policy policy-name [ directory dir-name size-quota size ]
undo info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address }
(非缺省vSystem)
info-center loghost { ipv4-address | ipv6 ipv6-address } [ port port-number | tcp [ ssl-client-policy policy-name ] ] *
undo info-center loghost { ipv4-address | ipv6 ipv6-address }
未配置日志主机及相关参数。
context-admin
vsys-admin
vpn-instance vpn-instance-name:指定日志主机所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示日志主机位于公网中。
hostname:指定日志的主机名,为1~253个字符的字符串,不区分大小写,字符串中可以包含字母、数字、“-”、“_”和“.”。
ipv4-address:指定日志主机的IPv4地址。
ipv6 ipv6-address:指定日志主机的IPv6地址。
facility local-number:配置日志主机的记录工具。取值范围为local0~local7或original-facility,缺省值为local7。主要用于在日志主机端标志不同的日志来源,查找、过滤对应日志源的日志。如果将facility配置为original-facility,则表示设备发往日志主机的日志的Facility为业务模块生成日志时定义的初始Facility,不同日志的初始Facility可能不同。
filter filter-name:指定日志主机关联的日志输出规则的名称,只有符合规则的日志才能输出到对应的日志主机。filter-name表示日志信息输出规则的名称,为1~8个字符的字符串,不区分大小写。不指定该参数时,则采用info-center source命令日志主机方向的配置作为日志输出规则。
format { cmcc | damddos | default | rfc5424 | unicom | sgcc }:配置发往指定日志主机的日志信息中使用的日志格式。不指定该参数时,使用info-center format命令中配置的日志格式。用户可配置的日志格式包括:
·     cmcc:配置发往日志主机的日志信息的输出格式为中国移动格式。
·     damddos:配置发往日志主机的日志信息的输出格式为电信云堤格式。
·     default:配置发往日志主机的日志信息的输出格式为非定制格式。
·     rfc5424:配置发往日志主机的日志信息的输出格式为RFC 5424格式。
·     sgcc:配置发往日志主机的日志信息的输出格式为国家电网格式。
·     unicom:配置发往日志主机的日志信息的输出格式为中国联通格式。
damddos参数的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
不支持
F5000-AI-15
支持
F1000系列
F1000-AK9130、F1000-AI-90、F1000-AI-80、F1000-AI-70、F1000-AI-60、F1000-V90、
支持
不支持
插卡
不支持
port port-number:指定日志主机接收日志信息的端口号,取值范围为1~65535,缺省值为514。该参数的值需要和日志主机侧的配置一致,否则日志主机接收不到日志信息。
source-ip source-ip-address:配置发往指定日志主机的日志信息中使用的源IP地址。不指定该参数时,使用info-center loghost source命令中配置的源IP地址。
tcp:配置使用TCP协议发送日志。缺省使用UDP协议发送日志。
ssl-client-policy policy-name:配置使用基于TCP协议的SSL加密方式发送日志。policy-name表示SSL客户端策略名称,为1~31个字符的字符串,不区分大小写。不指定该参数时,表示使用非加密方式发送日志。
format rfc5424-json-v1:配置发往指定日志主机的日志信息中使用的日志格式为rfc5424-json-v1。其中,日志的内容区段采用Json格式,日志的其它区段采用RFC5424格式。配置该格式后,只有用户定制的日志才会发往日志主机,未定制的日志不会发往日志主机。
end-with-length:表示在日志中携带Length字段来表示一条日志的结束。不指定该参数时,表示使用“\n”换行符来表示一条日志的结束。
directory dir-name size-quota size:表示当设备和日志主机之间的TCP连接断开时,设备生成的需要发往日志主机的日志以文件形式保存到本地的指定路径。其中,dir-name表示保存日志文件的文件夹的绝对路径,为1~64个字符的字符串。日志文件的名称由设备使用本命令指定的IP地址或者日志主机的名称自动生成。size表示日志文件的大小,取值范围为1~70,单位为MB。当日志文件大小达到指定值时,设备会删除最旧的日志来存储新日志。不指定该参数时,表示当设备和日志主机之间的TCP连接断开时,设备生成的需要发往日志主机的日志不会以文件形式保存到本地。
应用场景
登录vSystem之后,使用本命令可以将本vSystem生成的日志发送给指定的日志主机。
tcp [ ssl-client-policy policy-name ]和format rfc5424-json-v1 tcp [ end-with-length ] ssl-client-policy ssl-client-policy-name directory dir-name size-quota size参数用于对日志传输安全性要求较高的环境。
工作机制
配置本命令时,用户可以指定:
·     日志过滤规则。只有符合过滤规则的日志才会发送给日志主机,以免用户不关心的日志发送给日志主机,占用网络带宽和日志主机上的资源。
·     tcp [ ssl-client-policy policy-name ]参数。当用户指定该参数后,设备可通过安全方式的TCP连接将日志发送给日志主机,从而提高日志传输过程的安全性。
·     format rfc5424-json-v1 tcp [ end-with-length ] ssl-client-policy ssl-client-policy-name [ directory dir-name size-quota size ]参数。当用户指定该参数后,设备会将用户定制的日志按照用户定制的格式以安全方式的TCP连接发送给日志主机。用户可以配置当TCP链接断开,将日志以文件的形式保存到本地,以便用户查询。日志文件有大小限制,支持覆盖保存。使用该参数可以大大提高日志传输的安全性。
·     多次配置本命令可以指定多个日志主机,设备会同时将指定的日志发往这些日志主机。
配置准备
如果要使用SSL加密方式发送日志,请先完成SSL客户端策略的相关配置,否则,SSL连接无法建立,会导致日志无法发送给日志主机。关于SSL客户端策略的相关配置请参见“安全配置指导”中的“SSL”。
注意事项
用户只有使用info-center enable命令开启了信息中心功能,配置info-center loghost命令才会生效。
# 配置系统向IP地址为1.1.1.1的日志主机发送日志信息。
[Sysname] info-center loghost 1.1.1.1
·     info-center format
·     ssl client-policy(安全命令参考/SSL)
info-center loghost locate-info with-sn命令用来配置向日志主机方向发送日志时,在日志定位信息中携带设备序列号。
undo info-center loghost locate-info with-sn命令用来恢复缺省情况。
向日志主机方向发送日志时,日志定位信息中未携带设备序列号。
context-admin
非缺省vSystem不支持本命令。
# 配置向日志主机方向发送日志时,在日志定位信息中携带设备序列号。
[Sysname] info-center loghost locate-info with-sn
info-center loghost source命令用来配置发送的日志信息的源IP地址。
undo info-center loghost source命令用来恢复缺省情况。
使用出接口的主IP地址作为发送的日志信息的源IP地址。
context-admin
interface-type interface-number:指定发送日志信息的源IP地址对应的出接口的类型和编号。
非缺省vSystem不支持本命令。
配置日志信息的源IP地址后,不管实际使用哪个物理接口发送日志信息,日志信息的源IP地址均为指定接口的主IP地址。
用户只有使用info-center enable命令开启了信息中心功能,配置info-center loghost source命令才会生效。
本命令配置的日志源IP地址对所有日志主机生效,info-center loghost命令中指定的日志源IP地址对指定日志主机生效。对于同一日志主机,优先使用info-center loghost命令中指定的日志源IP地址。
# 配置使用Loopback0的IP地址作为发送的日志信息的源IP地址。
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] info-center loghost source loopback 0
info-center loghost vsys-to-admin enable命令用来将非缺省vSystem生成的日志发往缺省vSystem下配置的日志主机。
undo info-center loghost vsys-to-admin enable命令用来恢复缺省情况。
系列
型号
F5000系列
支持
F1000系列
不支持
支持
插卡
支持
非缺省vSystem生成的日志不会发往缺省vSystem下配置的日志主机。
非缺省vSystem不支持本命令。
缺省vSystem和非缺省vSystem可以分别设置日志主机,分别将本vSystem生成的日志发往指定的日志主机。如果需要将缺省vSystem和所有非缺省vSystem的日志发往相同的日志主机,可以使用本命令,而不再需要分别登录到非缺省vSystem,挨个指定日志主机,从而达到简化配置的目的。
# 将非缺省vSystem生成的日志发往缺省vSystem下配置的日志主机。
<vsys-aaa> system-view
[Sysname] info-center loghost vsys-to-admin enable
info-center security-logfile alarm-threshold命令用来配置安全日志文件使用率的告警门限。
undo info-center security-logfile alarm-threshold命令用来恢复缺省情况。
安全日志文件使用率的告警门限是80(即当安全日志文件使用率达到80%时,系统会提醒用户)。
context-admin
usage:安全日志文件使用率的告警门限,取值范围为1~100的整数。
非缺省vSystem不支持本命令。
当安全日志文件大小达到上限时,新的安全日志会覆盖旧的安全日志,从而导致安全日志丢失。为防止这种情况发生,用户可以使用本命令配置安全日志文件使用率的告警门限。当使用率超过此门限值时,系统会发出日志提醒用户,此时,用户可以将安全日志文件进行备份,以防重要历史数据丢失。
# 配置当安全日志文件使用率达到90%时进行告警。
[Sysname] info-center security-logfile alarm-threshold 90
·     info-center security-logfile size-quota
info-center security-logfile directory命令用来修改存储安全日志文件的路径。
存储安全日志文件路径为设备缺省文件系统根目录下的seclog文件夹。
security-audit
dir-name:安全日志文件存储的路径,为1~64个字符的字符串。
非缺省vSystem不支持本命令。
在执行该配置前,存储安全日志文件的文件夹必须为当前已创建的目录。
只有配置了安全日志管理员权限的本地用户才能使用本命令。
# 配置存放安全日志文件的目录为flash:/test。
[Sysname] info-center security-logfile directory flash:/test
info-center security-logfile enable命令用来开启安全日志同步保存功能。
undo info-center security-logfile enable命令用来关闭安全日志同步保存功能。
安全日志同步保存功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
开启安全日志同步保存功能后,系统将安全日志进行集中处理:当生成的日志信息中有安全日志,在不影响日志信息现有输出规则的前提下,系统会将安全日志信息同步保存到专用的安全日志文件。这样既实现了安全日志的集中管理,又有利于用户随时快捷地查看安全日志,了解设备状态。
# 开启安全日志同步保存功能。
[Sysname] info-center security-logfile enable
info-center security-logfile frequency命令用来配置设备自动保存安全日志文件的频率。
undo info-center security-logfile frequency命令用来恢复缺省情况。
设备自动保存安全日志文件的频率为86400秒。
context-admin
freq-sec:系统自动保存安全日志文件的频率,取值范围为10~86400,单位为秒。
非缺省vSystem不支持本命令。
配置设备自动保存安全日志文件的频率后,安全日志会先被输出到安全日志文件缓冲区(security-logfile buffer),系统会按照配置中指定的频率将安全日志文件缓冲区的内容写入安全日志文件。
# 配置安全日志自动保存到文件的频率为600秒。
[Sysname] info-center security-logfile frequency 600
·     info-center security-logfile enable
info-center security-logfile size-quota命令用来配置单个安全日志文件最大能占用的存储空间的大小。
undo info-center security-logfile size-quota命令用来恢复缺省情况。
单个安全日志文件最大能占用的存储空间的大小为10MB。
context-admin
非缺省vSystem不支持本命令。
# 配置单个安全日志文件最大能占用的存储空间的大小为6MB。
[Sysname] info-center security-logfile size-quota 6
·     info-center security-logfile alarm-threshold
info-center source命令用来配置日志信息的输出规则。
undo info-center source命令用来恢复缺省情况。
info-center source { module-name | default } { console | logbuffer | logfile | loghost | logtrap | monitor } { deny | level severity }
undo info-center source { module-name | default } { console | logbuffer | logfile | loghost | logtrap | monitor }
日志信息的输出规则请参见表1-16:
表1-16 日志信息的缺省输出规则
输出方向
日志信息来源
开关
等级
控制台
所有支持的模块
开
debugging
监视终端
所有支持的模块
关
debugging
日志主机
所有支持的模块
开
informational
日志缓冲区
所有支持的模块
开
informational
日志文件
所有支持的模块
开
informational
日志转换成SNMP告警输出
所有支持的模块
关
informational
context-admin
module-name:配置指定应用模块日志信息的输出规则。系统支持的来源模块可以通过在系统视图下输入info-center source ?进行查看。
console:输出到控制台。
logbuffer:输出到日志缓冲区。
logfile:输出到日志文件。
loghost:输出到日志主机。
logtrap:输出到SNMP模块。配置本参数和snmp-agent trap enable syslog命令后,设备会对需要转换成SNMP告警信息的日志进行过滤,仅将符合本命令要求的日志换成成SNMP告警,通过SNMP连接输出到NMS。以便减少Trap的数量,让网络管理员可以聚焦自己关注的系统事件、状态变化。
monitor:输出到监视终端。
deny:禁止输出信息。
level severity:指定允许输出的日志信息的最低级别,取值为alert、critical、debugging、emergency、error、informational、notification、warning,各参数的含义请参见表1-17。例如,本参数配置为warning,则表示配置对emergency、alert、critical、error和warning级别的日志均生效。
表1-17 信息级别列表
数值
信息级别
0
emergency
表示设备不可用的信息,如系统授权已到期
1
alert
2
critical
3
error
表示错误信息,如接口链路状态变化等
4
warning
5
notification
6
informational
7
debugging
表示调试过程产生的信息
非缺省vSystem不支持本命令。
如果没有使用module-name参数为应用模块单独配置输出规则,则该模块使用default参数配置的输出规则。如果未使用default参数配置输出规则,则使用缺省输出规则。
给应用模块单独配置输出规则后,必须使用module-name参数来修改或删除该规则,使用default参数进行的新配置对该模块不生效。
多次使用module-name参数为同一应用模块配置输出规则,最后一次执行的命令生效;多次使用default参数配置缺省输出规则,最后一次执行的命令生效。
# 只允许VLAN模块的信息输出控制台,且输出信息的级别为emergency的日志信息。
[Sysname] info-center source default console deny
[Sysname] info-center source vlan console level emergency
# 在前面例子基础上撤销控制台方向上VLAN模块的输出(即全部信息不在控制台显示)。
[Sysname] undo info-center source vlan console
·     snmp-agent trap enable syslog
info-center synchronous命令用来开启命令行输入回显功能。
undo info-center synchronous命令用来关闭命令行输入回显功能。
命令行输入回显功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
当用户进行命令行、参数或者Y/N确认信息输入时,如果被大量的日志信息打断,用户可能记不清已经输入了哪些字符串,还需要输入哪些字符串。使用命令行输入回显功能,能够协助用户配置。系统会在日志信息输出完毕后回显用户已有的输入或者Y/N确认信息,以便用户继续执行配置。
# 开启设备命令行输入回显功能,输入display current-configuration命令查看设备当前配置。
[Sysname] info-center synchronous
Info-center synchronous output is on
[Sysname] display current-
此时,收到日志报文,则系统在所有的日志报文显示完以后,附加显示用户的输入(此例为“display current-”)。
%May 21 14:33:19:425 2007 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.44
此时,用户可以继续输入configuration(完成命令display current-configuration的完整输入),回车,即可执行该命令。
# 开启设备命令行输入回显功能,保存当前配置(输入交互信息)。
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
此时,收到日志信息,则系统会在所有的日志报文显示完以后,附加显示[Y/N]:。
[Y/N]:
此时,用户可以输入Y或者N,继续日志信息输出前的操作。
info-center syslog min-age命令用来配置日志信息和日志文件的最短保存时间。
undo info-center syslog min-age命令用来恢复缺省情况。
info-center syslog [ module module-name ] min-age min-age
undo info-center syslog [ module module-name ] min-age
未配置日志信息和日志文件的最短保存时间。
context-admin
module module-name:配置指定模块的日志信息的最短保存时间。module-name表示模块的名称,不区分大小写,执行info-center syslog module ?命令,通过帮助信息可获得该参数的取值。不指定该参数时,表示该配置对通用日志生效。
min-age:表示日志信息和日志文件的最短保存时间,取值范围为1~8760,单位为小时。
非缺省vSystem不支持本命令。
# 将日志信息和日志文件的最短保存时间配置为168小时。
[Sysname] info-center syslog min-age 168
info-center syslog min-age命令用来配置日志信息的最短保存时间。
未配置日志信息的最短保存时间。
context-admin
min-age:表示日志信息的最短保存时间,取值范围为1~8760,单位为小时。
非缺省vSystem不支持本命令。
# 将日志信息的最短保存时间配置为168小时。
info-center syslog trap命令用来配置日志告警缓冲区的大小。
undo info-center syslog trap命令用来恢复缺省情况。
undo info-center syslog trap buffersize
日志告警缓冲区的大小为1024条。
context-admin
buffersize:表示日志告警缓冲区的大小,取值范围为0~65535,单位为条。当取值为0时,表示不缓存日志告警。
非缺省vSystem不支持本命令。
配置snmp-agent trap enable syslog命令后,设备会将日志封装成告警信息,存储在日志告警缓冲区。用户通过访问“日志告警缓冲区对应的MIB节点”,就可以直接读取日志告警。
通常情况下,日志告警缓冲区的大小采用缺省值即可。当日志告警缓冲区内存储的信息达到上限,且还需要存储信息时,新信息会覆盖旧信息。
# 配置日志告警缓冲区的大小为2048条。
[Sysname] info-center syslog trap buffersize 2048
info-center syslog utf-8 enable命令用来配置信息中心使用UTF-8编码方式输出日志。
undo info-center syslog utf-8 enable命令用来恢复缺省情况。
信息中心使用GB18030编码方式输出日志。
context-admin
应用场景
当用户使用登录软件登录设备,且设备往登录软件发送的信息中包含中文字符时,如果登录软件和设备使用的中文字符集编码不同,可能会出现中文字符在登录软件上显示为乱码的情况。此时,可以使用本命令将设备和登录软件使用的编码配置为相同值。
背景知识
UTF-8和GB18030都是字符编码标准,用于将字符转换为计算机可处理的字节序列。这两种编码标准主要用于支持不同语言和地区的文本处理。UTF-8是国际化的标准,支持全球范围内的字符,而GB18030则是专注于中文及相关字符的编码标准。
·     UTF-8
¡     UTF-8是Unicode字符集的一种编码方式,它能够表示世界上几乎所有语言的字符。
¡     UTF-8使用可变长度的字节表示字符,常用字符(如ASCII字符)使用一个字节,而较少使用的字符可能使用多达四个字节。
¡     UTF-8的优点在于其广泛的兼容性,特别是在互联网和跨平台应用中被广泛使用。
·     GB18030
¡     GB18030是中华人民共和国国家标准中的字符编码标准,主要用于简体中文的字符表示。
¡     GB18030是GBK的扩展,能够表示Unicode字符集中的所有字符,也包含了对少数民族文字的支持。
¡     它同样使用可变长度的字节来编码字符,通常为1到4个字节。
注意事项
非缺省vSystem不支持本命令。
当使用Json格式向日志主机发送日志文件时,该日志文件中对应的编码格式固定为UTF-8,不受本命令配置的控制。
# 配置信息中心使用UTF-8编码方式输出日志。
[Sysname] info-center syslog utf-8 enable
info-center timestamp命令用来配置发往控制台、监视终端、日志缓冲区和日志文件方向的日志信息的时间戳输出格式。
undo info-center timestamp命令用来恢复缺省情况。
时间戳输出格式为date格式。
context-admin
boot:系统启动后经历的时间,格式为:xxx.yyy,其中xxx是系统自启动后经历时间的毫秒数高32位,yyy是低32位,形如0.21990989(等效于Jun 25 14:09:26:881 2007)。
date:系统当前的日期和时间,格式为“MMM DD hh:mm:ss:ms YYYY”,形如Dec  8 10:12:21:708 2007。
·     “MMM”为英语月份的缩写,具体取值如下:Jan,Feb,Mar,Apr,May,Jun,Jul,Aug,Sep,Oct,Nov,Dec。
·     “DD”表示日期,如果日期的值小于10,则格式为“空格+日期”,如“ 7”。
·     “hh:mm:ss:ms”表示本地时间,hh为小时,取值范围为00~23;mm为分钟,ss为秒钟,mm和ss的取值范围均为00~59;ms为毫秒,取值范围为0~999。
·     “YYYY”表示年份。
none:不带时间信息。
非缺省vSystem不支持本命令。
# 配置日志信息时间戳输出格式为boot格式。
[Sysname] info-center timestamp boot
·     info-center timestamp loghost
info-center timestamp loghost命令用来配置发往日志主机的日志信息的时间戳输出格式。
undo info-center timestamp loghost命令用来恢复缺省情况。
info-center timestamp loghost { date [ with-milliseconds ] | iso [ with-milliseconds ] | no-year-date | none }
发往日志主机的日志信息的时间戳输出格式为date格式。
context-admin
date:配置时间戳输出格式为:mmm dd hh:mm:ss yyyy,形如Dec  8 10:12:21 2007,但最终显示格式由日志主机决定。
with-milliseconds:表示时间戳精确到毫秒,且毫秒用标准点号分割。对于date格式的时间戳,加毫秒后,形如:Dec 8 10:12:21.708 2018;对于iso格式的时间戳,加毫秒后,形如:2018-09-21T15:32:55.708。不指定该参数时,表示时间戳精确到秒。
iso:配置时间戳输出格式为ISO 8601标准格式,形如:2009-09-21T15:32:55。
no-year-date:系统当前日期和时间,但不包含年份信息。
none:不带时间信息。
非缺省vSystem不支持本命令。
# 配置发往日志主机的日志信息的时间戳为no-year-date格式。
[Sysname] info-center timestamp loghost no-year-date
info-center trace-logfile quota命令用来配置调试跟踪日志文件最大能占用的存储空间的大小。
undo info-center trace-logfile quota命令用来恢复缺省情况。
调试跟踪日志文件最大能占用的存储空间的大小为1MB。
context-admin
非缺省vSystem不支持本命令。
# 配置调试跟踪日志文件最大能占用的存储空间的大小为6MB。
[Sysname] info-center trace-logfile quota 6
1.1.51  logfile save
logfile save命令用来手动将日志文件缓冲区中的内容全部保存到日志文件。
logfile save
context-admin
非缺省vSystem不支持本命令。
日志文件的保存路径可以通过info-center logfile directory命令配置。
日志文件保存成功后,日志文件缓冲区中的内容会被清空。
如果执行本命令时,日志文件缓冲区中没有日志,本命令会执行成功,但不会创建或更新已有日志文件。
# 手动将日志文件缓冲区中的内容保存到日志文件。
<Sysname> logfile save
The contents in the log file buffer have been saved to the file flash:/logfile/logfile.log.
·     info-center logfile directory
reset logbuffer命令用来清除日志缓冲区中的信息。
reset logbuffer [ module module-name [ submodule submodule-name ] ]
context-admin
module module-name:清除指定模块日志缓冲区中的信息。module-name表示模块的名称,不区分大小写,执行reset logbuffer ?命令,通过帮助信息可获得该参数的取值。不指定该参数时,表示该配置对通用日志生效。
submodule submodule-name:清除当前模块下指定子模块日志缓冲区的状态和日志缓冲区记录的日志信息。submodule-name表示子模块名称,配置时需要完整输入,不区分大小写。当前模块是否支持子模块以及子模块的取值,请通过执行display logbuffer module module-name submodule ?命令获取。不指定该参数时,表示该配置对当前模块下所有子模块生效。
非缺省vSystem不支持本命令。
配置本命令,会同时清除缺省vSystem的日志缓冲区以及非缺省vSystem的日志缓冲区中的信息。
# 清除日志缓冲区中的信息。
<Sysname> reset logbuffer
·     display logbuffer
security syslog rate-limit命令用来配置安全业务日志信息的发送速率限制。
undo security syslog rate-limit命令用来恢复缺省情况。
security syslog rate-limit max-value
安全业务日志信息的发送速率最大值为1000。
context-admin
max-value:允许的日志信息发送速率最大值,取值范围为0~10000,单位为每秒日志条数。当取值为0时,表示不发送安全业务日志信息。
设备在处理某些安全业务时会产生大量的安全业务日志并发送至信息中心,此时会导致信息中心的负担过大。可以通过配置抑制安全业务日志输出功能,减少同一时刻发往日志中心的安全业务日志总数。配置本功能后,当日志信息发送速率超过本功能配置的阈值时,超出阈值的日志信息将被丢弃,管理员需要根据实际情况进行合理配置。
本功能支持的安全业务包括:AFT、ASPF、数据过滤、文件过滤、URL过滤、NAT、会话、防病毒、审计、IPS、共享上网、服务器外联防护和ATK。
# 配置安全业务日志信息的发送速率限制为每秒1000条。
[Sysname] security syslog rate-limit 1000
security-logfile save命令用来手动将安全日志文件缓冲区中的内容全部保存到安全日志文件。
security-audit
非缺省vSystem不支持本命令。
安全日志文件保存成功后,安全日志文件缓冲区中的内容会被立即清空。
需要注意的是,只有具有安全日志管理员角色的本地用户才能使用本命令。
如果执行本命令时,安全日志文件缓冲区中没有日志,本命令会执行成功,但不会创建或更新已有安全日志文件。
# 手动将安全日志缓冲区中的内容保存到安全日志文件。
<Sysname> security-logfile save
The contents in the security log file buffer have been saved to the file flash:/seclog/seclog.log.
·     info-center security-logfile directory
snmp-agent trap enable syslog命令用来将系统日志封装成告警信息发送。
undo snmp-agent trap enable syslog命令用来恢复缺省情况。
系统日志不会封装成告警信息发送。
context-admin
非缺省vSystem不支持本命令。
配置该命令后,设备除了根据输出规则将日志输出到各方向外,还会将日志信息封装成告警信息,发送到SNMP模块和日志告警缓冲区。
·     发送到SNMP模块后,是否输出到目的主机,以Trap还是Inform形式发送,由SNMP模块的配置决定,关于告警信息以及SNMP配置的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
·     发送到日志告警缓冲区后,用户可通过“日志告警缓冲区对应的MIB节点”来直接读取日志信息封装成的告警信息。用户还可通过info-center syslog trap buffersize命令来配置日志告警缓冲区的大小。
# 将系统日志封装成告警信息发送。
[Sysname] snmp-agent trap enable syslog
·     info-center syslog trap buffersize
terminal debugging命令用来允许调试信息输出到当前终端。
undo terminal debugging命令用来禁止调试信息输出到当前终端。
terminal debugging
不允许调试信息输出到当前终端。
context-admin
非缺省vSystem不支持本命令。
调试信息指的是打开业务模块的调试信息开关后,业务模块生成的debugging级别的日志信息。
如果需要在控制台显示调试信息,请先配置terminal debugging命令,再使能信息中心功能(信息中心功能缺省处于使能状态),最后使用debugging命令打开功能模块的调试信息开关。
如果需要在监视终端上显示调试信息,请先配置terminal monitor和terminal debugging命令,再使能信息中心功能(信息中心功能缺省处于使能状态),最后使用debugging命令打开功能模块的调试信息开关。
需要注意的是,本命令只对当前连接有效。当终端与设备重新建立连接后,本命令会恢复到缺省情况。
执行terminal logging level 7命令或terminal debugging命令,都可以开启当前终端对调试信息的显示功能,但两条命令有如下区别:
·     执行terminal logging level 7命令,当前终端允许输出级别为0~7的所有日志。
·     执行terminal debugging命令,当前终端仅输出terminal logging level命令配置的日志信息和级别为7的调试信息。
# 允许调试信息输出到当前终端。
<Sysname> terminal debugging
The current terminal is enabled to display debugging logs.
·     terminal logging level
·     terminal monitor
terminal logging level命令用来配置当前终端允许输出的日志信息的最低级别。
undo terminal logging level命令用来恢复缺省情况。
当前终端允许输出的日志信息的最低级别均为6(Informational)。
context-admin
severity:当前终端允许输出的日志信息的最低级别,取值为0~7的整数或者alert、critical、debugging、emergency、error、informational、notification、warning。
非缺省vSystem不支持本命令。
在配置了当前终端允许输出的日志信息的最低级别后,当系统输出信息时,所有信息等级高于或等于配置等级的信息都会被输出。例如,当配置的允许输出的日志信息的最低级别6(informational)时,等级0~6的信息均会被输出。
本命令配置的显示属性只对当前连接有效,当终端与设备的连接超时、重新建立连接后,显示属性将恢复到缺省情况。
# 配置当前终端监控的最低日志级别为debugging。
<Sysname> terminal logging level 7
terminal monitor命令用来允许日志信息输出到当前终端。
undo terminal monitor命令用来禁止日志信息输出到当前终端。
terminal monitor
允许日志信息输出到控制台,不允许日志信息输出到监视终端。
context-admin
vsys-admin
# 允许日志信息输出到当前终端。
<Sysname> terminal monitor
